[U-Boot] [PATCH] OMAP3: Zoom1: Fix ARM relocation support
Signed-off-by: Dirk Behme dirk.behme@googlemail.com ---
Compile tested only.
board/logicpd/zoom1/config.mk | 2 +- include/configs/omap3_zoom1.h | 6 ++++++ 2 files changed, 7 insertions(+), 1 deletion(-)
Index: u-boot.git/board/logicpd/zoom1/config.mk =================================================================== --- u-boot.git.orig/board/logicpd/zoom1/config.mk +++ u-boot.git/board/logicpd/zoom1/config.mk @@ -30,4 +30,4 @@ # (mem base + reserved)
# For use with external or internal boots. -CONFIG_SYS_TEXT_BASE = 0x80e80000 +CONFIG_SYS_TEXT_BASE = 0x80008000 Index: u-boot.git/include/configs/omap3_zoom1.h =================================================================== --- u-boot.git.orig/include/configs/omap3_zoom1.h +++ u-boot.git/include/configs/omap3_zoom1.h @@ -236,6 +236,12 @@ #define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default */ /* load address */
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 +#define CONFIG_SYS_INIT_RAM_SIZE 0x800 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) /* * OMAP3 has 12 GP timers, they can be driven by the system clock * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK).
Dirk Behme
