[U-Boot] [PATCH 1/3] imx: cpu: move common chip revision id's
Move common chip revision id's to main cpu header file mx25 generic include cpu header for chip revision
Signed-off-by: Adrian Alonso aalonso@freescale.com --- arch/arm/cpu/arm926ejs/mx25/generic.c | 1 + arch/arm/include/asm/arch-imx/cpu.h | 12 ++++++++++++ arch/arm/include/asm/arch-mx25/imx-regs.h | 4 ---- arch/arm/include/asm/arch-mx5/imx-regs.h | 11 ----------- arch/arm/include/asm/arch-mx6/imx-regs.h | 4 ---- 5 files changed, 13 insertions(+), 19 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index 8912098..0b1a8f4 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -13,6 +13,7 @@ #include <div64.h> #include <netdev.h> #include <asm/io.h> +#include <asm/arch-imx/cpu.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h>
diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index 7e681e9..8a75902 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -27,6 +27,18 @@ #define MXC_SOC_MX6 0x60 #define MXC_SOC_MX7 0x70
+#define CHIP_REV_1_0 0x10 +#define CHIP_REV_1_1 0x11 +#define CHIP_REV_1_2 0x12 +#define CHIP_REV_1_5 0x15 +#define CHIP_REV_2_0 0x20 +#define CHIP_REV_2_5 0x25 +#define CHIP_REV_3_0 0x30 + +#define BOARD_REV_1_0 0x0 +#define BOARD_REV_2_0 0x1 +#define BOARD_VER_OFFSET 0x8 + #define CS0_128 0 #define CS0_64M_CS1_64M 1 #define CS0_64M_CS1_32M_CS2_32M 2 diff --git a/arch/arm/include/asm/arch-mx25/imx-regs.h b/arch/arm/include/asm/arch-mx25/imx-regs.h index 78c4e9b..1b00ed7 100644 --- a/arch/arm/include/asm/arch-mx25/imx-regs.h +++ b/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -526,8 +526,4 @@ struct cspi_regs { IMX_CSPI2_BASE, \ IMX_CSPI3_BASE
-#define CHIP_REV_1_0 0x10 -#define CHIP_REV_1_1 0x11 -#define CHIP_REV_1_2 0x12 - #endif /* _IMX_REGS_H */ diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 5f0e1e6..e73cc07 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -291,17 +291,6 @@ #define DP_MFD_216 (4 - 1) #define DP_MFN_216 3
-#define CHIP_REV_1_0 0x10 -#define CHIP_REV_1_1 0x11 -#define CHIP_REV_2_0 0x20 -#define CHIP_REV_2_5 0x25 -#define CHIP_REV_3_0 0x30 - -#define BOARD_REV_1_0 0x0 -#define BOARD_REV_2_0 0x1 - -#define BOARD_VER_OFFSET 0x8 - #define IMX_IIM_BASE (IIM_BASE_ADDR)
#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 74512ac..6249b33 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -325,10 +325,6 @@ #define WDOG3_BASE_ADDR (is_cpu_type(MXC_CPU_MX6UL) ? \ MX6UL_WDOG3_BASE_ADDR : MX6SX_WDOG3_BASE_ADDR)
-#define CHIP_REV_1_0 0x10 -#define CHIP_REV_1_2 0x12 -#define CHIP_REV_1_5 0x15 -#define CHIP_REV_2_0 0x20 #if !(defined(CONFIG_MX6SX) || defined(CONFIG_MX6UL)) #define IRAM_SIZE 0x00040000 #else
Signed-off-by: Adrian Alonso aalonso@freescale.com --- arch/arm/cpu/armv7/mx6/Makefile | 1 - arch/arm/cpu/armv7/mx6/hab.c | 502 --------------------------------------- arch/arm/imx-common/Makefile | 1 + arch/arm/imx-common/hab.c | 515 ++++++++++++++++++++++++++++++++++++++++ include/imx_hab.h | 140 +++++++++++ 5 files changed, 656 insertions(+), 503 deletions(-) delete mode 100644 arch/arm/cpu/armv7/mx6/hab.c create mode 100644 arch/arm/imx-common/hab.c create mode 100644 include/imx_hab.h
diff --git a/arch/arm/cpu/armv7/mx6/Makefile b/arch/arm/cpu/armv7/mx6/Makefile index bf6effc..8af191d 100644 --- a/arch/arm/cpu/armv7/mx6/Makefile +++ b/arch/arm/cpu/armv7/mx6/Makefile @@ -9,5 +9,4 @@
obj-y := soc.o clock.o obj-$(CONFIG_SPL_BUILD) += ddr.o -obj-$(CONFIG_SECURE_BOOT) += hab.o obj-$(CONFIG_MP) += mp.o diff --git a/arch/arm/cpu/armv7/mx6/hab.c b/arch/arm/cpu/armv7/mx6/hab.c deleted file mode 100644 index 27cabe4..0000000 --- a/arch/arm/cpu/armv7/mx6/hab.c +++ /dev/null @@ -1,502 +0,0 @@ -/* - * Copyright (C) 2010-2015 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/system.h> -#include <asm/arch/hab.h> -#include <asm/arch/clock.h> -#include <asm/arch/sys_proto.h> - -/* -------- start of HAB API updates ------------*/ - -#define hab_rvt_report_event_p \ -( \ - ((is_cpu_type(MXC_CPU_MX6Q) || \ - is_cpu_type(MXC_CPU_MX6D)) && \ - (soc_rev() >= CHIP_REV_1_5)) ? \ - ((hab_rvt_report_event_t *)HAB_RVT_REPORT_EVENT_NEW) : \ - (is_cpu_type(MXC_CPU_MX6DL) && \ - (soc_rev() >= CHIP_REV_1_2)) ? \ - ((hab_rvt_report_event_t *)HAB_RVT_REPORT_EVENT_NEW) : \ - ((hab_rvt_report_event_t *)HAB_RVT_REPORT_EVENT) \ -) - -#define hab_rvt_report_status_p \ -( \ - ((is_cpu_type(MXC_CPU_MX6Q) || \ - is_cpu_type(MXC_CPU_MX6D)) && \ - (soc_rev() >= CHIP_REV_1_5)) ? \ - ((hab_rvt_report_status_t *)HAB_RVT_REPORT_STATUS_NEW) :\ - (is_cpu_type(MXC_CPU_MX6DL) && \ - (soc_rev() >= CHIP_REV_1_2)) ? \ - ((hab_rvt_report_status_t *)HAB_RVT_REPORT_STATUS_NEW) :\ - ((hab_rvt_report_status_t *)HAB_RVT_REPORT_STATUS) \ -) - -#define hab_rvt_authenticate_image_p \ -( \ - ((is_cpu_type(MXC_CPU_MX6Q) || \ - is_cpu_type(MXC_CPU_MX6D)) && \ - (soc_rev() >= CHIP_REV_1_5)) ? \ - ((hab_rvt_authenticate_image_t *)HAB_RVT_AUTHENTICATE_IMAGE_NEW) : \ - (is_cpu_type(MXC_CPU_MX6DL) && \ - (soc_rev() >= CHIP_REV_1_2)) ? \ - ((hab_rvt_authenticate_image_t *)HAB_RVT_AUTHENTICATE_IMAGE_NEW) : \ - ((hab_rvt_authenticate_image_t *)HAB_RVT_AUTHENTICATE_IMAGE) \ -) - -#define hab_rvt_entry_p \ -( \ - ((is_cpu_type(MXC_CPU_MX6Q) || \ - is_cpu_type(MXC_CPU_MX6D)) && \ - (soc_rev() >= CHIP_REV_1_5)) ? \ - ((hab_rvt_entry_t *)HAB_RVT_ENTRY_NEW) : \ - (is_cpu_type(MXC_CPU_MX6DL) && \ - (soc_rev() >= CHIP_REV_1_2)) ? \ - ((hab_rvt_entry_t *)HAB_RVT_ENTRY_NEW) : \ - ((hab_rvt_entry_t *)HAB_RVT_ENTRY) \ -) - -#define hab_rvt_exit_p \ -( \ - ((is_cpu_type(MXC_CPU_MX6Q) || \ - is_cpu_type(MXC_CPU_MX6D)) && \ - (soc_rev() >= CHIP_REV_1_5)) ? \ - ((hab_rvt_exit_t *)HAB_RVT_EXIT_NEW) : \ - (is_cpu_type(MXC_CPU_MX6DL) && \ - (soc_rev() >= CHIP_REV_1_2)) ? \ - ((hab_rvt_exit_t *)HAB_RVT_EXIT_NEW) : \ - ((hab_rvt_exit_t *)HAB_RVT_EXIT) \ -) - -#define IVT_SIZE 0x20 -#define ALIGN_SIZE 0x1000 -#define CSF_PAD_SIZE 0x2000 -#define MX6DQ_PU_IROM_MMU_EN_VAR 0x009024a8 -#define MX6DLS_PU_IROM_MMU_EN_VAR 0x00901dd0 -#define MX6SL_PU_IROM_MMU_EN_VAR 0x00900a18 - -/* - * +------------+ 0x0 (DDR_UIMAGE_START) - - * | Header | | - * +------------+ 0x40 | - * | | | - * | | | - * | | | - * | | | - * | Image Data | | - * . | | - * . | > Stuff to be authenticated ----+ - * . | | | - * | | | | - * | | | | - * +------------+ | | - * | | | | - * | Fill Data | | | - * | | | | - * +------------+ Align to ALIGN_SIZE | | - * | IVT | | | - * +------------+ + IVT_SIZE - | - * | | | - * | CSF DATA | <---------------------------------------------------------+ - * | | - * +------------+ - * | | - * | Fill Data | - * | | - * +------------+ + CSF_PAD_SIZE - */ - -#define MAX_RECORD_BYTES (8*1024) /* 4 kbytes */ - -struct record { - uint8_t tag; /* Tag */ - uint8_t len[2]; /* Length */ - uint8_t par; /* Version */ - uint8_t contents[MAX_RECORD_BYTES];/* Record Data */ - bool any_rec_flag; -}; - -char *rsn_str[] = {"RSN = HAB_RSN_ANY (0x00)\n", - "RSN = HAB_ENG_FAIL (0x30)\n", - "RSN = HAB_INV_ADDRESS (0x22)\n", - "RSN = HAB_INV_ASSERTION (0x0C)\n", - "RSN = HAB_INV_CALL (0x28)\n", - "RSN = HAB_INV_CERTIFICATE (0x21)\n", - "RSN = HAB_INV_COMMAND (0x06)\n", - "RSN = HAB_INV_CSF (0x11)\n", - "RSN = HAB_INV_DCD (0x27)\n", - "RSN = HAB_INV_INDEX (0x0F)\n", - "RSN = HAB_INV_IVT (0x05)\n", - "RSN = HAB_INV_KEY (0x1D)\n", - "RSN = HAB_INV_RETURN (0x1E)\n", - "RSN = HAB_INV_SIGNATURE (0x18)\n", - "RSN = HAB_INV_SIZE (0x17)\n", - "RSN = HAB_MEM_FAIL (0x2E)\n", - "RSN = HAB_OVR_COUNT (0x2B)\n", - "RSN = HAB_OVR_STORAGE (0x2D)\n", - "RSN = HAB_UNS_ALGORITHM (0x12)\n", - "RSN = HAB_UNS_COMMAND (0x03)\n", - "RSN = HAB_UNS_ENGINE (0x0A)\n", - "RSN = HAB_UNS_ITEM (0x24)\n", - "RSN = HAB_UNS_KEY (0x1B)\n", - "RSN = HAB_UNS_PROTOCOL (0x14)\n", - "RSN = HAB_UNS_STATE (0x09)\n", - "RSN = INVALID\n", - NULL}; - -char *sts_str[] = {"STS = HAB_SUCCESS (0xF0)\n", - "STS = HAB_FAILURE (0x33)\n", - "STS = HAB_WARNING (0x69)\n", - "STS = INVALID\n", - NULL}; - -char *eng_str[] = {"ENG = HAB_ENG_ANY (0x00)\n", - "ENG = HAB_ENG_SCC (0x03)\n", - "ENG = HAB_ENG_RTIC (0x05)\n", - "ENG = HAB_ENG_SAHARA (0x06)\n", - "ENG = HAB_ENG_CSU (0x0A)\n", - "ENG = HAB_ENG_SRTC (0x0C)\n", - "ENG = HAB_ENG_DCP (0x1B)\n", - "ENG = HAB_ENG_CAAM (0x1D)\n", - "ENG = HAB_ENG_SNVS (0x1E)\n", - "ENG = HAB_ENG_OCOTP (0x21)\n", - "ENG = HAB_ENG_DTCP (0x22)\n", - "ENG = HAB_ENG_ROM (0x36)\n", - "ENG = HAB_ENG_HDCP (0x24)\n", - "ENG = HAB_ENG_RTL (0x77)\n", - "ENG = HAB_ENG_SW (0xFF)\n", - "ENG = INVALID\n", - NULL}; - -char *ctx_str[] = {"CTX = HAB_CTX_ANY(0x00)\n", - "CTX = HAB_CTX_FAB (0xFF)\n", - "CTX = HAB_CTX_ENTRY (0xE1)\n", - "CTX = HAB_CTX_TARGET (0x33)\n", - "CTX = HAB_CTX_AUTHENTICATE (0x0A)\n", - "CTX = HAB_CTX_DCD (0xDD)\n", - "CTX = HAB_CTX_CSF (0xCF)\n", - "CTX = HAB_CTX_COMMAND (0xC0)\n", - "CTX = HAB_CTX_AUT_DAT (0xDB)\n", - "CTX = HAB_CTX_ASSERT (0xA0)\n", - "CTX = HAB_CTX_EXIT (0xEE)\n", - "CTX = INVALID\n", - NULL}; - -uint8_t hab_statuses[5] = { - HAB_STS_ANY, - HAB_FAILURE, - HAB_WARNING, - HAB_SUCCESS, - -1 -}; - -uint8_t hab_reasons[26] = { - HAB_RSN_ANY, - HAB_ENG_FAIL, - HAB_INV_ADDRESS, - HAB_INV_ASSERTION, - HAB_INV_CALL, - HAB_INV_CERTIFICATE, - HAB_INV_COMMAND, - HAB_INV_CSF, - HAB_INV_DCD, - HAB_INV_INDEX, - HAB_INV_IVT, - HAB_INV_KEY, - HAB_INV_RETURN, - HAB_INV_SIGNATURE, - HAB_INV_SIZE, - HAB_MEM_FAIL, - HAB_OVR_COUNT, - HAB_OVR_STORAGE, - HAB_UNS_ALGORITHM, - HAB_UNS_COMMAND, - HAB_UNS_ENGINE, - HAB_UNS_ITEM, - HAB_UNS_KEY, - HAB_UNS_PROTOCOL, - HAB_UNS_STATE, - -1 -}; - -uint8_t hab_contexts[12] = { - HAB_CTX_ANY, - HAB_CTX_FAB, - HAB_CTX_ENTRY, - HAB_CTX_TARGET, - HAB_CTX_AUTHENTICATE, - HAB_CTX_DCD, - HAB_CTX_CSF, - HAB_CTX_COMMAND, - HAB_CTX_AUT_DAT, - HAB_CTX_ASSERT, - HAB_CTX_EXIT, - -1 -}; - -uint8_t hab_engines[16] = { - HAB_ENG_ANY, - HAB_ENG_SCC, - HAB_ENG_RTIC, - HAB_ENG_SAHARA, - HAB_ENG_CSU, - HAB_ENG_SRTC, - HAB_ENG_DCP, - HAB_ENG_CAAM, - HAB_ENG_SNVS, - HAB_ENG_OCOTP, - HAB_ENG_DTCP, - HAB_ENG_ROM, - HAB_ENG_HDCP, - HAB_ENG_RTL, - HAB_ENG_SW, - -1 -}; - -bool is_hab_enabled(void) -{ - struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; - struct fuse_bank *bank = &ocotp->bank[0]; - struct fuse_bank0_regs *fuse = - (struct fuse_bank0_regs *)bank->fuse_regs; - uint32_t reg = readl(&fuse->cfg5); - - return (reg & 0x2) == 0x2; -} - -static inline uint8_t get_idx(uint8_t *list, uint8_t tgt) -{ - uint8_t idx = 0; - uint8_t element = list[idx]; - while (element != -1) { - if (element == tgt) - return idx; - element = list[++idx]; - } - return -1; -} - -void process_event_record(uint8_t *event_data, size_t bytes) -{ - struct record *rec = (struct record *)event_data; - - printf("\n\n%s", sts_str[get_idx(hab_statuses, rec->contents[0])]); - printf("%s", rsn_str[get_idx(hab_reasons, rec->contents[1])]); - printf("%s", ctx_str[get_idx(hab_contexts, rec->contents[2])]); - printf("%s", eng_str[get_idx(hab_engines, rec->contents[3])]); -} - -void display_event(uint8_t *event_data, size_t bytes) -{ - uint32_t i; - - if (!(event_data && bytes > 0)) - return; - - for (i = 0; i < bytes; i++) { - if (i == 0) - printf("\t0x%02x", event_data[i]); - else if ((i % 8) == 0) - printf("\n\t0x%02x", event_data[i]); - else - printf(" 0x%02x", event_data[i]); - } - - process_event_record(event_data, bytes); -} - -int get_hab_status(void) -{ - uint32_t index = 0; /* Loop index */ - uint8_t event_data[128]; /* Event data buffer */ - size_t bytes = sizeof(event_data); /* Event size in bytes */ - enum hab_config config = 0; - enum hab_state state = 0; - hab_rvt_report_event_t *hab_rvt_report_event; - hab_rvt_report_status_t *hab_rvt_report_status; - - hab_rvt_report_event = hab_rvt_report_event_p; - hab_rvt_report_status = hab_rvt_report_status_p; - - if (is_hab_enabled()) - puts("\nSecure boot enabled\n"); - else - puts("\nSecure boot disabled\n"); - - /* Check HAB status */ - if (hab_rvt_report_status(&config, &state) != HAB_SUCCESS) { - printf("\nHAB Configuration: 0x%02x, HAB State: 0x%02x\n", - config, state); - - /* Display HAB Error events */ - while (hab_rvt_report_event(HAB_FAILURE, index, event_data, - &bytes) == HAB_SUCCESS) { - puts("\n"); - printf("--------- HAB Event %d -----------------\n", - index + 1); - puts("event data:\n"); - display_event(event_data, bytes); - puts("\n"); - bytes = sizeof(event_data); - index++; - } - } - /* Display message if no HAB events are found */ - else { - printf("\nHAB Configuration: 0x%02x, HAB State: 0x%02x\n", - config, state); - puts("No HAB Events Found!\n\n"); - } - return 0; -} - -uint32_t authenticate_image(uint32_t ddr_start, uint32_t image_size) -{ - uint32_t load_addr = 0; - size_t bytes; - ptrdiff_t ivt_offset = 0; - int result = 0; - ulong start; - hab_rvt_authenticate_image_t *hab_rvt_authenticate_image; - hab_rvt_entry_t *hab_rvt_entry; - hab_rvt_exit_t *hab_rvt_exit; - - hab_rvt_authenticate_image = hab_rvt_authenticate_image_p; - hab_rvt_entry = hab_rvt_entry_p; - hab_rvt_exit = hab_rvt_exit_p; - - if (is_hab_enabled()) { - printf("\nAuthenticate image from DDR location 0x%x...\n", - ddr_start); - - hab_caam_clock_enable(1); - - if (hab_rvt_entry() == HAB_SUCCESS) { - /* If not already aligned, Align to ALIGN_SIZE */ - ivt_offset = (image_size + ALIGN_SIZE - 1) & - ~(ALIGN_SIZE - 1); - - start = ddr_start; - bytes = ivt_offset + IVT_SIZE + CSF_PAD_SIZE; -#ifdef DEBUG - printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", - ivt_offset, ddr_start + ivt_offset); - puts("Dumping IVT\n"); - print_buffer(ddr_start + ivt_offset, - (void *)(ddr_start + ivt_offset), - 4, 0x8, 0); - - puts("Dumping CSF Header\n"); - print_buffer(ddr_start + ivt_offset+IVT_SIZE, - (void *)(ddr_start + ivt_offset+IVT_SIZE), - 4, 0x10, 0); - - get_hab_status(); - - puts("\nCalling authenticate_image in ROM\n"); - printf("\tivt_offset = 0x%x\n", ivt_offset); - printf("\tstart = 0x%08lx\n", start); - printf("\tbytes = 0x%x\n", bytes); -#endif - /* - * If the MMU is enabled, we have to notify the ROM - * code, or it won't flush the caches when needed. - * This is done, by setting the "pu_irom_mmu_enabled" - * word to 1. You can find its address by looking in - * the ROM map. This is critical for - * authenticate_image(). If MMU is enabled, without - * setting this bit, authentication will fail and may - * crash. - */ - /* Check MMU enabled */ - if (get_cr() & CR_M) { - if (is_cpu_type(MXC_CPU_MX6Q) || - is_cpu_type(MXC_CPU_MX6D)) { - /* - * This won't work on Rev 1.0.0 of - * i.MX6Q/D, since their ROM doesn't - * do cache flushes. don't think any - * exist, so we ignore them. - */ - if (!is_mx6dqp()) - writel(1, MX6DQ_PU_IROM_MMU_EN_VAR); - } else if (is_cpu_type(MXC_CPU_MX6DL) || - is_cpu_type(MXC_CPU_MX6SOLO)) { - writel(1, MX6DLS_PU_IROM_MMU_EN_VAR); - } else if (is_cpu_type(MXC_CPU_MX6SL)) { - writel(1, MX6SL_PU_IROM_MMU_EN_VAR); - } - } - - load_addr = (uint32_t)hab_rvt_authenticate_image( - HAB_CID_UBOOT, - ivt_offset, (void **)&start, - (size_t *)&bytes, NULL); - if (hab_rvt_exit() != HAB_SUCCESS) { - puts("hab exit function fail\n"); - load_addr = 0; - } - } else { - puts("hab entry function fail\n"); - } - - hab_caam_clock_enable(0); - - get_hab_status(); - } else { - puts("hab fuse not enabled\n"); - } - - if ((!is_hab_enabled()) || (load_addr != 0)) - result = 1; - - return result; -} - -int do_hab_status(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - if ((argc != 1)) { - cmd_usage(cmdtp); - return 1; - } - - get_hab_status(); - - return 0; -} - -static int do_authenticate_image(cmd_tbl_t *cmdtp, int flag, int argc, - char * const argv[]) -{ - ulong addr, ivt_offset; - int rcode = 0; - - if (argc < 3) - return CMD_RET_USAGE; - - addr = simple_strtoul(argv[1], NULL, 16); - ivt_offset = simple_strtoul(argv[2], NULL, 16); - - rcode = authenticate_image(addr, ivt_offset); - - return rcode; -} - -U_BOOT_CMD( - hab_status, CONFIG_SYS_MAXARGS, 1, do_hab_status, - "display HAB status", - "" - ); - -U_BOOT_CMD( - hab_auth_img, 3, 0, do_authenticate_image, - "authenticate image via HAB", - "addr ivt_offset\n" - "addr - image hex address\n" - "ivt_offset - hex offset of IVT in the image" - ); diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index 1698d06..4abffee 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -27,6 +27,7 @@ ifeq ($(SOC),$(filter $(SOC),mx6 mx7)) obj-y += cache.o init.o obj-$(CONFIG_CMD_SATA) += sata.o obj-$(CONFIG_IMX_VIDEO_SKIP) += video.o +obj-$(CONFIG_SECURE_BOOT) += hab.o endif ifeq ($(SOC),$(filter $(SOC),vf610)) obj-y += ddrmc-vf610.o diff --git a/arch/arm/imx-common/hab.c b/arch/arm/imx-common/hab.c new file mode 100644 index 0000000..4386e29 --- /dev/null +++ b/arch/arm/imx-common/hab.c @@ -0,0 +1,515 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <imx_hab.h> +#include <asm/io.h> +#include <asm/system.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> + +/* -------- start of HAB API updates ------------*/ + +#define hab_rvt_report_event_p \ +( \ + ((is_cpu_type(MXC_CPU_MX6Q) || \ + is_cpu_type(MXC_CPU_MX6D)) && \ + (soc_rev() >= CHIP_REV_1_5)) ? \ + ((hab_rvt_report_event_t *)HAB_RVT_REPORT_EVENT_NEW) : \ + (is_cpu_type(MXC_CPU_MX6DL) && \ + (soc_rev() >= CHIP_REV_1_2)) ? \ + ((hab_rvt_report_event_t *)HAB_RVT_REPORT_EVENT_NEW) : \ + ((hab_rvt_report_event_t *)HAB_RVT_REPORT_EVENT) \ +) + +#define hab_rvt_report_status_p \ +( \ + ((is_cpu_type(MXC_CPU_MX6Q) || \ + is_cpu_type(MXC_CPU_MX6D)) && \ + (soc_rev() >= CHIP_REV_1_5)) ? \ + ((hab_rvt_report_status_t *)HAB_RVT_REPORT_STATUS_NEW) :\ + (is_cpu_type(MXC_CPU_MX6DL) && \ + (soc_rev() >= CHIP_REV_1_2)) ? \ + ((hab_rvt_report_status_t *)HAB_RVT_REPORT_STATUS_NEW) :\ + ((hab_rvt_report_status_t *)HAB_RVT_REPORT_STATUS) \ +) + +#define hab_rvt_authenticate_image_p \ +( \ + ((is_cpu_type(MXC_CPU_MX6Q) || \ + is_cpu_type(MXC_CPU_MX6D)) && \ + (soc_rev() >= CHIP_REV_1_5)) ? \ + ((hab_rvt_authenticate_image_t *)HAB_RVT_AUTHENTICATE_IMAGE_NEW) : \ + (is_cpu_type(MXC_CPU_MX6DL) && \ + (soc_rev() >= CHIP_REV_1_2)) ? \ + ((hab_rvt_authenticate_image_t *)HAB_RVT_AUTHENTICATE_IMAGE_NEW) : \ + ((hab_rvt_authenticate_image_t *)HAB_RVT_AUTHENTICATE_IMAGE) \ +) + +#define hab_rvt_entry_p \ +( \ + ((is_cpu_type(MXC_CPU_MX6Q) || \ + is_cpu_type(MXC_CPU_MX6D)) && \ + (soc_rev() >= CHIP_REV_1_5)) ? \ + ((hab_rvt_entry_t *)HAB_RVT_ENTRY_NEW) : \ + (is_cpu_type(MXC_CPU_MX6DL) && \ + (soc_rev() >= CHIP_REV_1_2)) ? \ + ((hab_rvt_entry_t *)HAB_RVT_ENTRY_NEW) : \ + ((hab_rvt_entry_t *)HAB_RVT_ENTRY) \ +) + +#define hab_rvt_exit_p \ +( \ + ((is_cpu_type(MXC_CPU_MX6Q) || \ + is_cpu_type(MXC_CPU_MX6D)) && \ + (soc_rev() >= CHIP_REV_1_5)) ? \ + ((hab_rvt_exit_t *)HAB_RVT_EXIT_NEW) : \ + (is_cpu_type(MXC_CPU_MX6DL) && \ + (soc_rev() >= CHIP_REV_1_2)) ? \ + ((hab_rvt_exit_t *)HAB_RVT_EXIT_NEW) : \ + ((hab_rvt_exit_t *)HAB_RVT_EXIT) \ +) + +#define IVT_SIZE 0x20 +#define ALIGN_SIZE 0x1000 +#define CSF_PAD_SIZE 0x2000 +#define MX6DQ_PU_IROM_MMU_EN_VAR 0x009024a8 +#define MX6DLS_PU_IROM_MMU_EN_VAR 0x00901dd0 +#define MX6SL_PU_IROM_MMU_EN_VAR 0x00900a18 + +/* + * +------------+ 0x0 (DDR_UIMAGE_START) - + * | Header | | + * +------------+ 0x40 | + * | | | + * | | | + * | | | + * | | | + * | Image Data | | + * . | | + * . | > Stuff to be authenticated ----+ + * . | | | + * | | | | + * | | | | + * +------------+ | | + * | | | | + * | Fill Data | | | + * | | | | + * +------------+ Align to ALIGN_SIZE | | + * | IVT | | | + * +------------+ + IVT_SIZE - | + * | | | + * | CSF DATA | <---------------------------------------------------------+ + * | | + * +------------+ + * | | + * | Fill Data | + * | | + * +------------+ + CSF_PAD_SIZE + */ + +#define MAX_RECORD_BYTES (8*1024) /* 4 kbytes */ + +struct record { + uint8_t tag; /* Tag */ + uint8_t len[2]; /* Length */ + uint8_t par; /* Version */ + uint8_t contents[MAX_RECORD_BYTES];/* Record Data */ + bool any_rec_flag; +}; + +char *rsn_str[] = {"RSN = HAB_RSN_ANY (0x00)\n", + "RSN = HAB_ENG_FAIL (0x30)\n", + "RSN = HAB_INV_ADDRESS (0x22)\n", + "RSN = HAB_INV_ASSERTION (0x0C)\n", + "RSN = HAB_INV_CALL (0x28)\n", + "RSN = HAB_INV_CERTIFICATE (0x21)\n", + "RSN = HAB_INV_COMMAND (0x06)\n", + "RSN = HAB_INV_CSF (0x11)\n", + "RSN = HAB_INV_DCD (0x27)\n", + "RSN = HAB_INV_INDEX (0x0F)\n", + "RSN = HAB_INV_IVT (0x05)\n", + "RSN = HAB_INV_KEY (0x1D)\n", + "RSN = HAB_INV_RETURN (0x1E)\n", + "RSN = HAB_INV_SIGNATURE (0x18)\n", + "RSN = HAB_INV_SIZE (0x17)\n", + "RSN = HAB_MEM_FAIL (0x2E)\n", + "RSN = HAB_OVR_COUNT (0x2B)\n", + "RSN = HAB_OVR_STORAGE (0x2D)\n", + "RSN = HAB_UNS_ALGORITHM (0x12)\n", + "RSN = HAB_UNS_COMMAND (0x03)\n", + "RSN = HAB_UNS_ENGINE (0x0A)\n", + "RSN = HAB_UNS_ITEM (0x24)\n", + "RSN = HAB_UNS_KEY (0x1B)\n", + "RSN = HAB_UNS_PROTOCOL (0x14)\n", + "RSN = HAB_UNS_STATE (0x09)\n", + "RSN = INVALID\n", + NULL}; + +char *sts_str[] = {"STS = HAB_SUCCESS (0xF0)\n", + "STS = HAB_FAILURE (0x33)\n", + "STS = HAB_WARNING (0x69)\n", + "STS = INVALID\n", + NULL}; + +char *eng_str[] = {"ENG = HAB_ENG_ANY (0x00)\n", + "ENG = HAB_ENG_SCC (0x03)\n", + "ENG = HAB_ENG_RTIC (0x05)\n", + "ENG = HAB_ENG_SAHARA (0x06)\n", + "ENG = HAB_ENG_CSU (0x0A)\n", + "ENG = HAB_ENG_SRTC (0x0C)\n", + "ENG = HAB_ENG_DCP (0x1B)\n", + "ENG = HAB_ENG_CAAM (0x1D)\n", + "ENG = HAB_ENG_SNVS (0x1E)\n", + "ENG = HAB_ENG_OCOTP (0x21)\n", + "ENG = HAB_ENG_DTCP (0x22)\n", + "ENG = HAB_ENG_ROM (0x36)\n", + "ENG = HAB_ENG_HDCP (0x24)\n", + "ENG = HAB_ENG_RTL (0x77)\n", + "ENG = HAB_ENG_SW (0xFF)\n", + "ENG = INVALID\n", + NULL}; + +char *ctx_str[] = {"CTX = HAB_CTX_ANY(0x00)\n", + "CTX = HAB_CTX_FAB (0xFF)\n", + "CTX = HAB_CTX_ENTRY (0xE1)\n", + "CTX = HAB_CTX_TARGET (0x33)\n", + "CTX = HAB_CTX_AUTHENTICATE (0x0A)\n", + "CTX = HAB_CTX_DCD (0xDD)\n", + "CTX = HAB_CTX_CSF (0xCF)\n", + "CTX = HAB_CTX_COMMAND (0xC0)\n", + "CTX = HAB_CTX_AUT_DAT (0xDB)\n", + "CTX = HAB_CTX_ASSERT (0xA0)\n", + "CTX = HAB_CTX_EXIT (0xEE)\n", + "CTX = INVALID\n", + NULL}; + +uint8_t hab_statuses[5] = { + HAB_STS_ANY, + HAB_FAILURE, + HAB_WARNING, + HAB_SUCCESS, + -1 +}; + +uint8_t hab_reasons[26] = { + HAB_RSN_ANY, + HAB_ENG_FAIL, + HAB_INV_ADDRESS, + HAB_INV_ASSERTION, + HAB_INV_CALL, + HAB_INV_CERTIFICATE, + HAB_INV_COMMAND, + HAB_INV_CSF, + HAB_INV_DCD, + HAB_INV_INDEX, + HAB_INV_IVT, + HAB_INV_KEY, + HAB_INV_RETURN, + HAB_INV_SIGNATURE, + HAB_INV_SIZE, + HAB_MEM_FAIL, + HAB_OVR_COUNT, + HAB_OVR_STORAGE, + HAB_UNS_ALGORITHM, + HAB_UNS_COMMAND, + HAB_UNS_ENGINE, + HAB_UNS_ITEM, + HAB_UNS_KEY, + HAB_UNS_PROTOCOL, + HAB_UNS_STATE, + -1 +}; + +uint8_t hab_contexts[12] = { + HAB_CTX_ANY, + HAB_CTX_FAB, + HAB_CTX_ENTRY, + HAB_CTX_TARGET, + HAB_CTX_AUTHENTICATE, + HAB_CTX_DCD, + HAB_CTX_CSF, + HAB_CTX_COMMAND, + HAB_CTX_AUT_DAT, + HAB_CTX_ASSERT, + HAB_CTX_EXIT, + -1 +}; + +uint8_t hab_engines[16] = { + HAB_ENG_ANY, + HAB_ENG_SCC, + HAB_ENG_RTIC, + HAB_ENG_SAHARA, + HAB_ENG_CSU, + HAB_ENG_SRTC, + HAB_ENG_DCP, + HAB_ENG_CAAM, + HAB_ENG_SNVS, + HAB_ENG_OCOTP, + HAB_ENG_DTCP, + HAB_ENG_ROM, + HAB_ENG_HDCP, + HAB_ENG_RTL, + HAB_ENG_SW, + -1 +}; + +bool is_hab_enabled(void) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + uint32_t reg; +#if CONFIG_MX7 + struct fuse_bank *bank = &ocotp->bank[1]; + struct fuse_bank1_regs *fuse = + (struct fuse_bank1_regs *)bank->fuse_regs; + reg = readl(&fuse->cfg0); +#elif CONFIG_MX6 + struct fuse_bank *bank = &ocotp->bank[0]; + struct fuse_bank0_regs *fuse = + (struct fuse_bank0_regs *)bank->fuse_regs; + reg = readl(&fuse->cfg5); +#endif + + if (is_soc_type(MXC_SOC_MX7)) + return (reg & 0x2000000) == 0x2000000; + else if (is_soc_type(MXC_SOC_MX6)) + return (reg & 0x2) == 0x2; + + return 0; +} + +static inline uint8_t get_idx(uint8_t *list, uint8_t tgt) +{ + uint8_t idx = 0; + uint8_t element = list[idx]; + while (element != -1) { + if (element == tgt) + return idx; + element = list[++idx]; + } + return -1; +} + +void process_event_record(uint8_t *event_data, size_t bytes) +{ + struct record *rec = (struct record *)event_data; + + printf("\n\n%s", sts_str[get_idx(hab_statuses, rec->contents[0])]); + printf("%s", rsn_str[get_idx(hab_reasons, rec->contents[1])]); + printf("%s", ctx_str[get_idx(hab_contexts, rec->contents[2])]); + printf("%s", eng_str[get_idx(hab_engines, rec->contents[3])]); +} + +void display_event(uint8_t *event_data, size_t bytes) +{ + uint32_t i; + + if (!(event_data && bytes > 0)) + return; + + for (i = 0; i < bytes; i++) { + if (i == 0) + printf("\t0x%02x", event_data[i]); + else if ((i % 8) == 0) + printf("\n\t0x%02x", event_data[i]); + else + printf(" 0x%02x", event_data[i]); + } + + process_event_record(event_data, bytes); +} + +int get_hab_status(void) +{ + uint32_t index = 0; /* Loop index */ + uint8_t event_data[128]; /* Event data buffer */ + size_t bytes = sizeof(event_data); /* Event size in bytes */ + enum hab_config config = 0; + enum hab_state state = 0; + hab_rvt_report_event_t *hab_rvt_report_event; + hab_rvt_report_status_t *hab_rvt_report_status; + + hab_rvt_report_event = hab_rvt_report_event_p; + hab_rvt_report_status = hab_rvt_report_status_p; + + if (is_hab_enabled()) + puts("\nSecure boot enabled\n"); + else + puts("\nSecure boot disabled\n"); + + /* Check HAB status */ + if (hab_rvt_report_status(&config, &state) != HAB_SUCCESS) { + printf("\nHAB Configuration: 0x%02x, HAB State: 0x%02x\n", + config, state); + + /* Display HAB Error events */ + while (hab_rvt_report_event(HAB_FAILURE, index, event_data, + &bytes) == HAB_SUCCESS) { + puts("\n"); + printf("--------- HAB Event %d -----------------\n", + index + 1); + puts("event data:\n"); + display_event(event_data, bytes); + puts("\n"); + bytes = sizeof(event_data); + index++; + } + } + /* Display message if no HAB events are found */ + else { + printf("\nHAB Configuration: 0x%02x, HAB State: 0x%02x\n", + config, state); + puts("No HAB Events Found!\n\n"); + } + return 0; +} + +uint32_t authenticate_image(uint32_t ddr_start, uint32_t image_size) +{ + uint32_t load_addr = 0; + size_t bytes; + ptrdiff_t ivt_offset = 0; + int result = 0; + ulong start; + hab_rvt_authenticate_image_t *hab_rvt_authenticate_image; + hab_rvt_entry_t *hab_rvt_entry; + hab_rvt_exit_t *hab_rvt_exit; + + hab_rvt_authenticate_image = hab_rvt_authenticate_image_p; + hab_rvt_entry = hab_rvt_entry_p; + hab_rvt_exit = hab_rvt_exit_p; + + if (is_hab_enabled()) { + printf("\nAuthenticate image from DDR location 0x%x...\n", + ddr_start); + + hab_caam_clock_enable(1); + + if (hab_rvt_entry() == HAB_SUCCESS) { + /* If not already aligned, Align to ALIGN_SIZE */ + ivt_offset = (image_size + ALIGN_SIZE - 1) & + ~(ALIGN_SIZE - 1); + + start = ddr_start; + bytes = ivt_offset + IVT_SIZE + CSF_PAD_SIZE; +#ifdef DEBUG + printf("\nivt_offset = 0x%x, ivt addr = 0x%x\n", + ivt_offset, ddr_start + ivt_offset); + puts("Dumping IVT\n"); + print_buffer(ddr_start + ivt_offset, + (void *)(ddr_start + ivt_offset), + 4, 0x8, 0); + + puts("Dumping CSF Header\n"); + print_buffer(ddr_start + ivt_offset+IVT_SIZE, + (void *)(ddr_start + ivt_offset+IVT_SIZE), + 4, 0x10, 0); + + get_hab_status(); + + puts("\nCalling authenticate_image in ROM\n"); + printf("\tivt_offset = 0x%x\n", ivt_offset); + printf("\tstart = 0x%08lx\n", start); + printf("\tbytes = 0x%x\n", bytes); +#endif + /* + * If the MMU is enabled, we have to notify the ROM + * code, or it won't flush the caches when needed. + * This is done, by setting the "pu_irom_mmu_enabled" + * word to 1. You can find its address by looking in + * the ROM map. This is critical for + * authenticate_image(). If MMU is enabled, without + * setting this bit, authentication will fail and may + * crash. + */ + if (is_soc_type(MXC_SOC_MX6) && (get_cr() & CR_M)) { + /* Check MMU enabled */ + if (is_cpu_type(MXC_CPU_MX6Q) || + is_cpu_type(MXC_CPU_MX6D)) { + /* + * This won't work on Rev 1.0.0 of + * i.MX6Q/D, since their ROM doesn't + * do cache flushes. don't think any + * exist, so we ignore them. + */ + if (!is_mx6dqp()) + writel(1, MX6DQ_PU_IROM_MMU_EN_VAR); + } else if (is_cpu_type(MXC_CPU_MX6DL) || + is_cpu_type(MXC_CPU_MX6SOLO)) { + writel(1, MX6DLS_PU_IROM_MMU_EN_VAR); + } else if (is_cpu_type(MXC_CPU_MX6SL)) { + writel(1, MX6SL_PU_IROM_MMU_EN_VAR); + } + } + + load_addr = (uint32_t)hab_rvt_authenticate_image( + HAB_CID_UBOOT, + ivt_offset, (void **)&start, + (size_t *)&bytes, NULL); + if (hab_rvt_exit() != HAB_SUCCESS) { + puts("hab exit function fail\n"); + load_addr = 0; + } + } else { + puts("hab entry function fail\n"); + } + + hab_caam_clock_enable(0); + + get_hab_status(); + } else { + puts("hab fuse not enabled\n"); + } + + if ((!is_hab_enabled()) || (load_addr != 0)) + result = 1; + + return result; +} + +int do_hab_status(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + if ((argc != 1)) { + cmd_usage(cmdtp); + return 1; + } + + get_hab_status(); + + return 0; +} + +static int do_authenticate_image(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + ulong addr, ivt_offset; + int rcode = 0; + + if (argc < 3) + return CMD_RET_USAGE; + + addr = simple_strtoul(argv[1], NULL, 16); + ivt_offset = simple_strtoul(argv[2], NULL, 16); + + rcode = authenticate_image(addr, ivt_offset); + + return rcode; +} + +U_BOOT_CMD( + hab_status, CONFIG_SYS_MAXARGS, 1, do_hab_status, + "display HAB status", + "" + ); + +U_BOOT_CMD( + hab_auth_img, 3, 0, do_authenticate_image, + "authenticate image via HAB", + "addr ivt_offset\n" + "addr - image hex address\n" + "ivt_offset - hex offset of IVT in the image" + ); diff --git a/include/imx_hab.h b/include/imx_hab.h new file mode 100644 index 0000000..3579292 --- /dev/null +++ b/include/imx_hab.h @@ -0,0 +1,140 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. All Rights Reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + * +*/ + +#ifndef __SECURE_IMX_H__ +#define __SECURE_IMX_H__ + +#include <linux/types.h> + +/* -------- start of HAB API updates ------------*/ +/* The following are taken from HAB4 SIS */ + +/* Status definitions */ +enum hab_status { + HAB_STS_ANY = 0x00, + HAB_FAILURE = 0x33, + HAB_WARNING = 0x69, + HAB_SUCCESS = 0xf0 +}; + +/* Security Configuration definitions */ +enum hab_config { + HAB_CFG_RETURN = 0x33, /**< Field Return IC */ + HAB_CFG_OPEN = 0xf0, /**< Non-secure IC */ + HAB_CFG_CLOSED = 0xcc /**< Secure IC */ +}; + +/* State definitions */ +enum hab_state { + HAB_STATE_INITIAL = 0x33, /**< Initialising state (transitory) */ + HAB_STATE_CHECK = 0x55, /**< Check state (non-secure) */ + HAB_STATE_NONSECURE = 0x66, /**< Non-secure state */ + HAB_STATE_TRUSTED = 0x99, /**< Trusted state */ + HAB_STATE_SECURE = 0xaa, /**< Secure state */ + HAB_STATE_FAIL_SOFT = 0xcc, /**< Soft fail state */ + HAB_STATE_FAIL_HARD = 0xff, /**< Hard fail state (terminal) */ + HAB_STATE_NONE = 0xf0, /**< No security state machine */ + HAB_STATE_MAX +}; + +enum hab_reason { + HAB_RSN_ANY = 0x00, /* Match any reason */ + HAB_ENG_FAIL = 0x30, /* Engine failure */ + HAB_INV_ADDRESS = 0x22, /* Invalid address: access denied */ + HAB_INV_ASSERTION = 0x0c, /* Invalid assertion */ + HAB_INV_CALL = 0x28, /* Function called out of sequence */ + HAB_INV_CERTIFICATE = 0x21, /* Invalid certificate */ + HAB_INV_COMMAND = 0x06, /* Invalid command: command malformed */ + HAB_INV_CSF = 0x11, /* Invalid csf */ + HAB_INV_DCD = 0x27, /* Invalid dcd */ + HAB_INV_INDEX = 0x0f, /* Invalid index: access denied */ + HAB_INV_IVT = 0x05, /* Invalid ivt */ + HAB_INV_KEY = 0x1d, /* Invalid key */ + HAB_INV_RETURN = 0x1e, /* Failed callback function */ + HAB_INV_SIGNATURE = 0x18, /* Invalid signature */ + HAB_INV_SIZE = 0x17, /* Invalid data size */ + HAB_MEM_FAIL = 0x2e, /* Memory failure */ + HAB_OVR_COUNT = 0x2b, /* Expired poll count */ + HAB_OVR_STORAGE = 0x2d, /* Exhausted storage region */ + HAB_UNS_ALGORITHM = 0x12, /* Unsupported algorithm */ + HAB_UNS_COMMAND = 0x03, /* Unsupported command */ + HAB_UNS_ENGINE = 0x0a, /* Unsupported engine */ + HAB_UNS_ITEM = 0x24, /* Unsupported configuration item */ + HAB_UNS_KEY = 0x1b, /* Unsupported key type/parameters */ + HAB_UNS_PROTOCOL = 0x14, /* Unsupported protocol */ + HAB_UNS_STATE = 0x09, /* Unsuitable state */ + HAB_RSN_MAX +}; + +enum hab_context { + HAB_CTX_ANY = 0x00, /* Match any context */ + HAB_CTX_FAB = 0xff, /* Event logged in hab_fab_test() */ + HAB_CTX_ENTRY = 0xe1, /* Event logged in hab_rvt.entry() */ + HAB_CTX_TARGET = 0x33, /* Event logged in hab_rvt.check_target() */ + HAB_CTX_AUTHENTICATE = 0x0a, /* Logged in hab_rvt.authenticate_image() */ + HAB_CTX_DCD = 0xdd, /* Event logged in hab_rvt.run_dcd() */ + HAB_CTX_CSF = 0xcf, /* Event logged in hab_rvt.run_csf() */ + HAB_CTX_COMMAND = 0xc0, /* Event logged executing csf/dcd command */ + HAB_CTX_AUT_DAT = 0xdb, /* Authenticated data block */ + HAB_CTX_ASSERT = 0xa0, /* Event logged in hab_rvt.assert() */ + HAB_CTX_EXIT = 0xee, /* Event logged in hab_rvt.exit() */ + HAB_CTX_MAX +}; + +/*Function prototype description*/ +typedef enum hab_status hab_rvt_report_event_t(enum hab_status, uint32_t, + uint8_t* , size_t*); +typedef enum hab_status hab_rvt_report_status_t(enum hab_config *, + enum hab_state *); +typedef enum hab_status hab_loader_callback_f_t(void**, size_t*, const void*); +typedef enum hab_status hab_rvt_entry_t(void); +typedef enum hab_status hab_rvt_exit_t(void); +typedef void *hab_rvt_authenticate_image_t(uint8_t, ptrdiff_t, + void **, size_t *, hab_loader_callback_f_t); +typedef void hapi_clock_init_t(void); + +#define HAB_ENG_ANY 0x00 /* Select first compatible engine */ +#define HAB_ENG_SCC 0x03 /* Security controller */ +#define HAB_ENG_RTIC 0x05 /* Run-time integrity checker */ +#define HAB_ENG_SAHARA 0x06 /* Crypto accelerator */ +#define HAB_ENG_CSU 0x0a /* Central Security Unit */ +#define HAB_ENG_SRTC 0x0c /* Secure clock */ +#define HAB_ENG_DCP 0x1b /* Data Co-Processor */ +#define HAB_ENG_CAAM 0x1d /* CAAM */ +#define HAB_ENG_SNVS 0x1e /* Secure Non-Volatile Storage */ +#define HAB_ENG_OCOTP 0x21 /* Fuse controller */ +#define HAB_ENG_DTCP 0x22 /* DTCP co-processor */ +#define HAB_ENG_ROM 0x36 /* Protected ROM area */ +#define HAB_ENG_HDCP 0x24 /* HDCP co-processor */ +#define HAB_ENG_RTL 0x77 /* RTL simulation engine */ +#define HAB_ENG_SW 0xff /* Software engine */ + +#if defined(CONFIG_MX6SX) || defined(CONFIG_MX7D) +#define HAB_RVT_UNIFIED_BASE 0x00000100 +#else +#define HAB_RVT_UNIFIED_BASE 0x00000094 +#endif + +#define HAB_RVT_ENTRY (*(uint32_t *) (HAB_RVT_UNIFIED_BASE + 0x04)) +#define HAB_RVT_EXIT (*(uint32_t *) (HAB_RVT_UNIFIED_BASE + 0x08)) +#define HAB_RVT_AUTHENTICATE_IMAGE (*(uint32_t *) (HAB_RVT_UNIFIED_BASE + 0x10)) +#define HAB_RVT_REPORT_EVENT (*(uint32_t *) (HAB_RVT_UNIFIED_BASE + 0x20)) +#define HAB_RVT_REPORT_STATUS (*(uint32_t *) (HAB_RVT_UNIFIED_BASE + 0x24)) + +#define HAB_RVT_REPORT_EVENT_NEW (*(uint32_t *)0x000000B8) +#define HAB_RVT_REPORT_STATUS_NEW (*(uint32_t *)0x000000BC) +#define HAB_RVT_AUTHENTICATE_IMAGE_NEW (*(uint32_t *)0x000000A8) +#define HAB_RVT_ENTRY_NEW (*(uint32_t *)0x0000009C) +#define HAB_RVT_EXIT_NEW (*(uint32_t *)0x000000A0) + +#define HAB_RVT_CLOCK_INIT ((hapi_clock_init_t *)0x0000024D) + +#define HAB_CID_ROM 0 /**< ROM Caller ID */ +#define HAB_CID_UBOOT 1 /**< UBOOT Caller ID*/ +/* ----------- end of HAB API updates ------------*/ + +#endif
Hi Adrian,
I find nice that cod in hab.c is factorized, but merging this together with the changes for mx7 makes a review difficult and does not allow a real diff between version. I will propose you split this patch in two parts:
- first patch simply move hab.c from cpu/armv7 to arm/imx-common/ - second patch add changes for mx7
Then it is also easy in case of git bisect to track what is changed.
Best regards, Stefano Babic
- Copyright (C) 2010-2015 Freescale Semiconductor, Inc.
- +------------+ 0x0 (DDR_UIMAGE_START) -
- | Header | |
- +------------+ 0x40 |
- | Image Data | |
- . | > Stuff to be authenticated ----+
- | Fill Data | | |
- +------------+ Align to ALIGN_SIZE | |
- | IVT | | |
- +------------+ + IVT_SIZE - |
- | CSF DATA | <---------------------------------------------------------+
- | Fill Data |
- +------------+ + CSF_PAD_SIZE
-struct record {
"RSN = INVALID\n",
NULL};
"STS = INVALID\n",
NULL};
"ENG = INVALID\n",
NULL};
"CTX = INVALID\n",
NULL};
- HAB_STS_ANY,
- HAB_FAILURE,
- HAB_WARNING,
- HAB_SUCCESS,
- -1
- HAB_RSN_ANY,
- HAB_ENG_FAIL,
- HAB_INV_ADDRESS,
- HAB_INV_CALL,
- HAB_INV_COMMAND,
- HAB_INV_CSF,
- HAB_INV_DCD,
- HAB_INV_INDEX,
- HAB_INV_IVT,
- HAB_INV_KEY,
- HAB_INV_RETURN,
- HAB_INV_SIZE,
- HAB_MEM_FAIL,
- HAB_OVR_COUNT,
- HAB_OVR_STORAGE,
- HAB_UNS_COMMAND,
- HAB_UNS_ENGINE,
- HAB_UNS_ITEM,
- HAB_UNS_KEY,
- HAB_UNS_PROTOCOL,
- HAB_UNS_STATE,
- -1
- HAB_CTX_ANY,
- HAB_CTX_FAB,
- HAB_CTX_ENTRY,
- HAB_CTX_TARGET,
- HAB_CTX_DCD,
- HAB_CTX_CSF,
- HAB_CTX_COMMAND,
- HAB_CTX_AUT_DAT,
- HAB_CTX_ASSERT,
- HAB_CTX_EXIT,
- -1
- HAB_ENG_ANY,
- HAB_ENG_SCC,
- HAB_ENG_RTIC,
- HAB_ENG_SAHARA,
- HAB_ENG_CSU,
- HAB_ENG_SRTC,
- HAB_ENG_DCP,
- HAB_ENG_CAAM,
- HAB_ENG_SNVS,
- HAB_ENG_OCOTP,
- HAB_ENG_DTCP,
- HAB_ENG_ROM,
- HAB_ENG_HDCP,
- HAB_ENG_RTL,
- HAB_ENG_SW,
- -1
- uint8_t idx = 0;
if (element == tgt)
return idx;
- return -1;
- uint32_t i;
return;
if (i == 0)
else
- else
config, state);
puts("\n");
index + 1);
puts("\n");
index++;
- else {
config, state);
- size_t bytes;
- int result = 0;
- ulong start;
ddr_start);
~(ALIGN_SIZE - 1);
start = ddr_start;
-#ifdef DEBUG
4, 0x8, 0);
4, 0x10, 0);
get_hab_status();
-#endif
* crash.
if (!is_mx6dqp())
HAB_CID_UBOOT,
load_addr = 0;
} else {
get_hab_status();
- } else {
result = 1;
- return result;
cmd_usage(cmdtp);
return 1;
- get_hab_status();
- int rcode = 0;
- if (argc < 3)
- return rcode;
-U_BOOT_CMD(
-U_BOOT_CMD(
"addr ivt_offset\n"
- Copyright (C) 2015 Freescale Semiconductor, Inc.
- | Header | |
- | Image Data | |
- | Fill Data | | |
- | IVT | | |
- | Fill Data |
+struct record {
"RSN = INVALID\n",
NULL};
"STS = INVALID\n",
NULL};
"ENG = INVALID\n",
NULL};
"CTX = INVALID\n",
NULL};
- HAB_STS_ANY,
- HAB_FAILURE,
- HAB_WARNING,
- HAB_SUCCESS,
- -1
- HAB_RSN_ANY,
- HAB_ENG_FAIL,
- HAB_INV_ADDRESS,
- HAB_INV_CALL,
- HAB_INV_COMMAND,
- HAB_INV_CSF,
- HAB_INV_DCD,
- HAB_INV_INDEX,
- HAB_INV_IVT,
- HAB_INV_KEY,
- HAB_INV_RETURN,
- HAB_INV_SIZE,
- HAB_MEM_FAIL,
- HAB_OVR_COUNT,
- HAB_OVR_STORAGE,
- HAB_UNS_COMMAND,
- HAB_UNS_ENGINE,
- HAB_UNS_ITEM,
- HAB_UNS_KEY,
- HAB_UNS_PROTOCOL,
- HAB_UNS_STATE,
- -1
- HAB_CTX_ANY,
- HAB_CTX_FAB,
- HAB_CTX_ENTRY,
- HAB_CTX_TARGET,
- HAB_CTX_DCD,
- HAB_CTX_CSF,
- HAB_CTX_COMMAND,
- HAB_CTX_AUT_DAT,
- HAB_CTX_ASSERT,
- HAB_CTX_EXIT,
- -1
- HAB_ENG_ANY,
- HAB_ENG_SCC,
- HAB_ENG_RTIC,
- HAB_ENG_SAHARA,
- HAB_ENG_CSU,
- HAB_ENG_SRTC,
- HAB_ENG_DCP,
- HAB_ENG_CAAM,
- HAB_ENG_SNVS,
- HAB_ENG_OCOTP,
- HAB_ENG_DTCP,
- HAB_ENG_ROM,
- HAB_ENG_HDCP,
- HAB_ENG_RTL,
- HAB_ENG_SW,
- -1
- uint32_t reg;
+#if CONFIG_MX7
- struct fuse_bank *bank = &ocotp->bank[1];
- struct fuse_bank1_regs *fuse =
- reg = readl(&fuse->cfg0);
+#elif CONFIG_MX6
- reg = readl(&fuse->cfg5);
- if (is_soc_type(MXC_SOC_MX7))
- else if (is_soc_type(MXC_SOC_MX6))
- uint8_t idx = 0;
if (element == tgt)
return idx;
- return -1;
- uint32_t i;
return;
if (i == 0)
else
- else
config, state);
puts("\n");
index + 1);
puts("\n");
index++;
- else {
config, state);
- size_t bytes;
- int result = 0;
- ulong start;
ddr_start);
~(ALIGN_SIZE - 1);
start = ddr_start;
+#ifdef DEBUG
4, 0x8, 0);
4, 0x10, 0);
get_hab_status();
* crash.
if (!is_mx6dqp())
HAB_CID_UBOOT,
load_addr = 0;
} else {
get_hab_status();
- } else {
result = 1;
- return result;
cmd_usage(cmdtp);
return 1;
- get_hab_status();
- int rcode = 0;
- if (argc < 3)
- return rcode;
+U_BOOT_CMD(
+U_BOOT_CMD(
"addr ivt_offset\n"
- Copyright (C) 2015 Freescale Semiconductor, Inc. All Rights Reserved.
- HAB_STS_ANY = 0x00,
- HAB_FAILURE = 0x33,
- HAB_WARNING = 0x69,
- HAB_SUCCESS = 0xf0
- HAB_CFG_RETURN = 0x33, /**< Field Return IC */
- HAB_CFG_OPEN = 0xf0, /**< Non-secure IC */
- HAB_CFG_CLOSED = 0xcc /**< Secure IC */
- HAB_STATE_INITIAL = 0x33, /**< Initialising state (transitory) */
- HAB_STATE_CHECK = 0x55, /**< Check state (non-secure) */
- HAB_STATE_NONSECURE = 0x66, /**< Non-secure state */
- HAB_STATE_TRUSTED = 0x99, /**< Trusted state */
- HAB_STATE_SECURE = 0xaa, /**< Secure state */
- HAB_STATE_FAIL_SOFT = 0xcc, /**< Soft fail state */
- HAB_STATE_FAIL_HARD = 0xff, /**< Hard fail state (terminal) */
- HAB_STATE_NONE = 0xf0, /**< No security state machine */
- HAB_STATE_MAX
+enum hab_reason {
- HAB_RSN_ANY = 0x00, /* Match any reason */
- HAB_ENG_FAIL = 0x30, /* Engine failure */
- HAB_INV_ADDRESS = 0x22, /* Invalid address: access denied */
- HAB_INV_ASSERTION = 0x0c, /* Invalid assertion */
- HAB_INV_CALL = 0x28, /* Function called out of sequence */
- HAB_INV_CERTIFICATE = 0x21, /* Invalid certificate */
- HAB_INV_COMMAND = 0x06, /* Invalid command: command malformed */
- HAB_INV_CSF = 0x11, /* Invalid csf */
- HAB_INV_DCD = 0x27, /* Invalid dcd */
- HAB_INV_INDEX = 0x0f, /* Invalid index: access denied */
- HAB_INV_IVT = 0x05, /* Invalid ivt */
- HAB_INV_KEY = 0x1d, /* Invalid key */
- HAB_INV_RETURN = 0x1e, /* Failed callback function */
- HAB_INV_SIGNATURE = 0x18, /* Invalid signature */
- HAB_INV_SIZE = 0x17, /* Invalid data size */
- HAB_MEM_FAIL = 0x2e, /* Memory failure */
- HAB_OVR_COUNT = 0x2b, /* Expired poll count */
- HAB_OVR_STORAGE = 0x2d, /* Exhausted storage region */
- HAB_UNS_ALGORITHM = 0x12, /* Unsupported algorithm */
- HAB_UNS_COMMAND = 0x03, /* Unsupported command */
- HAB_UNS_ENGINE = 0x0a, /* Unsupported engine */
- HAB_UNS_ITEM = 0x24, /* Unsupported configuration item */
- HAB_UNS_KEY = 0x1b, /* Unsupported key type/parameters */
- HAB_UNS_PROTOCOL = 0x14, /* Unsupported protocol */
- HAB_UNS_STATE = 0x09, /* Unsuitable state */
- HAB_RSN_MAX
+enum hab_context {
- HAB_CTX_ANY = 0x00, /* Match any context */
- HAB_CTX_FAB = 0xff, /* Event logged in hab_fab_test() */
- HAB_CTX_ENTRY = 0xe1, /* Event logged in hab_rvt.entry() */
- HAB_CTX_TARGET = 0x33, /* Event logged in hab_rvt.check_target() */
- HAB_CTX_AUTHENTICATE = 0x0a, /* Logged in hab_rvt.authenticate_image() */
- HAB_CTX_DCD = 0xdd, /* Event logged in hab_rvt.run_dcd() */
- HAB_CTX_CSF = 0xcf, /* Event logged in hab_rvt.run_csf() */
- HAB_CTX_COMMAND = 0xc0, /* Event logged executing csf/dcd command */
- HAB_CTX_AUT_DAT = 0xdb, /* Authenticated data block */
- HAB_CTX_ASSERT = 0xa0, /* Event logged in hab_rvt.assert() */
- HAB_CTX_EXIT = 0xee, /* Event logged in hab_rvt.exit() */
- HAB_CTX_MAX
enum hab_state *);
Add secure boot support for mx7dsabresd target board
Signed-off-by: Adrian Alonso aalonso@freescale.com --- board/freescale/mx7dsabresd/imximage.cfg | 7 +++++++ include/configs/mx7dsabresd.h | 4 ++++ 2 files changed, 11 insertions(+)
diff --git a/board/freescale/mx7dsabresd/imximage.cfg b/board/freescale/mx7dsabresd/imximage.cfg index 91b70ee..76574ff 100644 --- a/board/freescale/mx7dsabresd/imximage.cfg +++ b/board/freescale/mx7dsabresd/imximage.cfg @@ -23,6 +23,13 @@ IMAGE_VERSION 2 BOOT_FROM sd
/* + * Secure boot support + */ +#ifdef CONFIG_SECURE_BOOT +CSF CONFIG_CSF_SIZE +#endif + +/* * Device Configuration Data (DCD) * * Each entry must have the format: diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 2a736c4..7e32b5a 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -14,6 +14,10 @@ #define CONFIG_DBG_MONITOR #define PHYS_SDRAM_SIZE SZ_1G
+/* Uncomment to enable secure boot support */ +/* #define CONFIG_SECURE_BOOT */ +#define CONFIG_CSF_SIZE 0x4000 + /* Network */ #define CONFIG_CMD_MII #define CONFIG_FEC_MXC
Adrian Alonso
Stefano Babic
