[U-Boot] [PATCH] boards.cfg: update local documentation
The "options" field at the moment is only documented in the changelog which isn't terribly useful to people without git.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- boards.cfg | 14 +++++++++++--- 1 files changed, 11 insertions(+), 3 deletions(-)
diff --git a/boards.cfg b/boards.cfg index d6c3401..443f9bd 100644 --- a/boards.cfg +++ b/boards.cfg @@ -3,9 +3,7 @@ # # Syntax: # white-space separated list of entries; -# each entry has the following fields: -# -# Targetname Architecture CPU Boardname Vendor SoC +# each entry has the fields documented below. # # Unused fields can be specified as "-", or omitted if they # are the last field on the line. @@ -13,6 +11,16 @@ # Lines starting with '#' are comments. # Blank lines are ignored. # +# The options field takes the form: +# <board config name>[:comma separated config options] +# Each config option has the form (value defaults to "1"): +# option[=value] +# So if you have: +# FOO:HAS_BAR,BAZ=64 +# The file include/configs/FOO.h will be used, and these defines created: +# #define CONFIG_HAS_BAR 1 +# #define CONFIG_BAZ 64 +# # To keep the list sorted, use something like # # :.,$! sort -f -k2,2 -k3,3 -k6,6 -k5,5 -k1,1
Dear Mike Frysinger,
Applied, thanks.
Mike Frysinger
