[U-Boot] [PATCH 1/2] ARM: imx: cm_fx6: export board and soc info to env
From: Christopher Spinrath christopher.spinrath@rwth-aachen.de
Like many other i.MX6 based boards, there are multiple variants of the cm-fx6 module featuring different SoC variants. Furthermore, the module can be paired with multiple baseboards.
At the same time modern distribution like Fedora require U-Boot to select a proper devicetree which depends on the SoC variant and the baseboard.
Thus, export the SoC variant and the actual board to the environment following the conventions of other i.MX6 devices (e.g. the NXP boards) such that the environment can select a devicetree file to load.
For now, we only know for sure that the cm-fx6 module and the SB-fx6m baseboard amount to a Utilite Computer variant (depending on the SoC). Further combinations may be added in the future; e.g. CompuLab's evaluation board once someone can verify the identification string stored in its eeprom.
Signed-off-by: Christopher Spinrath christopher.spinrath@rwth-aachen.de --- arch/arm/mach-imx/mx6/Kconfig | 1 + board/compulab/cm_fx6/cm_fx6.c | 21 +++++++++++++++++++++ include/configs/cm_fx6.h | 1 + 3 files changed, 23 insertions(+)
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 567a6a6bf5..057fca31ea 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -130,6 +130,7 @@ config TARGET_CM_FX6 bool "CM-FX6" select SUPPORT_SPL select MX6QDL + select BOARD_LATE_INIT select DM select DM_SERIAL select DM_GPIO diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index 620c3f2d0d..673de03071 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c @@ -621,6 +621,27 @@ int board_init(void) return 0; }
+int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + char baseboard_name[16]; + int err; + + if (is_mx6dq()) + env_set("board_rev", "MX6Q"); + else if (is_mx6dl()) + env_set("board_rev", "MX6DL"); + + err = cl_eeprom_get_product_name((uchar *)baseboard_name, 0); + if (err) + return 0; + + if (!strncmp("SB-FX6m", baseboard_name, 7)) + env_set("board_name", "Utilite"); +#endif + return 0; +} + int checkboard(void) { puts("Board: CM-FX6\n"); diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index ec3e6e6ca5..cb71ea8811 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -67,6 +67,7 @@ #define CONFIG_ENV_OFFSET (768 * 1024)
#ifndef CONFIG_SPL_BUILD +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \
Hi Christopher,
Patches look good.
Maybe you could combine both into a single one?
On 09/01/2018 22:51, Fabio Estevam wrote:
Hi Christopher,
Patches look good.
Agree.
Reviewed-by: Stefano Babic sbabic@denx.de
Both have a good explanation uin the commit message. I will merge them as they are.
Best regards, Stefano
- select BOARD_LATE_INIT select DM select DM_SERIAL select DM_GPIO
- char baseboard_name[16];
- int err;
- if (is_mx6dq())
- else if (is_mx6dl())
- err = cl_eeprom_get_product_name((uchar *)baseboard_name, 0);
- if (err)
- if (!strncmp("SB-FX6m", baseboard_name, 7))
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
