[U-Boot] [PATCH 2/2] ARM: increase lmb stack space reservation to 4KB
The bootm initrd image copy to ram can collide with the stack in cases where the print buffer size is large (i.e. 1K). The result is intermittent initrd decompression errors depending on the initrd size MOD 4KB since the initrd start address is 4KB aligned.
Cc: Albert ARIBAUD albert.u.boot@aribaud.net Signed-off-by: Rob Herring rob.herring@calxeda.com --- arch/arm/lib/bootm.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 599547d..999f201 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -69,8 +69,8 @@ void arch_lmb_reserve(struct lmb *lmb) sp = get_sp(); debug("## Current stack ends at 0x%08lx ", sp);
- /* adjust sp by 1K to be safe */ - sp -= 1024; + /* adjust sp by 4K to be safe */ + sp -= 4096; lmb_reserve(lmb, sp, gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size - sp); }
Albert,
Can you please apply this fix. I've seen other issues posted that appear to be the same cause and this same issue was fixed on PPC ~2 years ago.
Rob
- sp -= 1024;
- /* adjust sp by 4K to be safe */
- sp -= 4096; lmb_reserve(lmb, sp, gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size - sp);
Hi Rob,
- sp -= 1024;
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Rob Herring
