[U-Boot-Users] bug in cfi_flash error detection
Hi all,
recently I got back a board from our customer, where some bits in the (nor) flash could not be programmed due to an error in the flash chip (-> very rare error).
I tought, this would be a good reason, to test the common cfi_flash driver with this board (so far we used a board specific flash driver on this board).
But the cfi_flash driver does not detect the error as I expected. I took a closer look to the driver and found some bugs (at least in my opinion).
I added a patch wich tries to fix it, but I'm not sure if this is the proper way it should be done (e. g. because it adds bytes to cfi_flash.o).
Here a brief description of what the patch tries to fix:
- Timeout calculation in flash_status_check(): The function calculates seconds instead of miliseconds. And on some boards the range of ulong is exceeded in the calculation (because CFG_HZ is very big on some boards).
- In flash_status_check() a bogus error message is printed (secotor number is always 0 and the printed data value is not from the address where the error occours).
- flash_status_check() uses always the erase block timeout, regardles if eraseing flash or writing flash.
- If the write timeout of the flash device is below 1 ms it is erroneously calculated to zero.
Any comment would be welcome.
Regards, Martin
TQ-Systems GmbH Mühlstraße 2, Gut Delling, 82229 Seefeld Tel. +49 (8153) 93 08-157, Fax +49 (8153) 93 08-7157 martin.krause@tqs.de www.tq-group.com
Martin Krause wrote:
Hi all,
Some of the issues you are fixing are also fixed my earlier patch in the pipeline (from July). See my patch below for items 1,3,4 in your list.
http://sourceforge.net/mailarchive/message.php?msg_id=12234135
I think, in flash_status_check() your patch timeout check is not correct. get_timer() returns in msec as well as tout is in msecs. So, they are directly comparable without involving CFG_HZ.
I think the full status check needs to be applied to sector 0 irrespective of what sector you are operating with because this is where the flash status register resides. I think some flash ignore the sector address while others require sector 0. I would be careful in changing this without verifying for a wide range of flash chips. Yes, the sector number will be wrong in error if you activate debug outputs but it is only cosmetic as far as I can see. Also, finding the sector number each time from address is a time consuming search that will slow the flash write operation unnecessarily. I am more willing to take the wrong sector number in debug output (if enabled) than slowed down status check which is used in a number of places.
Best regards, Tolunay
In message 47F3F98010FF784EBEE6526EAAB078D1C05E04@tq-mailsrv.tq-net.de you wrote:
- Timeout calculation in flash_status_check(): The function calculates seconds instead of miliseconds.=20 And on some boards the range of ulong is exceeded in the calculation (because CFG_HZ is very big on some boards).
This is a bug with such boards. CFG_HZ should always be set to 1000. Looking back I have to admit that it was a major design error to create this variable at all.
Martin Krause
Tolunay Orkun
