[U-Boot-Users] [PATCH] QE UEC: Add MII Commands
Add MII commands to the UEC driver. Note that once a UEC device is selected, any device on its MDIO bus can be addressed.
Signed-off-by: David Saada david.saada@ecitele.com
diff -purN a/drivers/qe/uec.c b/drivers/qe/uec.c --- a/drivers/qe/uec.c 2008-01-14 11:48:28.000000000 +0200 +++ b/drivers/qe/uec.c 2008-01-15 10:25:46.411493000 +0200 @@ -29,6 +29,7 @@ #include "uccf.h" #include "uec.h" #include "uec_phy.h" +#include "miiphy.h"
#if defined(CONFIG_QE)
@@ -88,6 +89,17 @@ static uec_info_t eth3_uec_info = { }; #endif
+#define MAXCONTROLLERS (4) + +static struct eth_device *devlist[MAXCONTROLLERS]; + +static int uec_miiphy_read(char *devname, unsigned char addr, + unsigned char reg, unsigned short *value); +static int uec_miiphy_write(char *devname, unsigned char addr, + unsigned char reg, unsigned short value); +u16 phy_read (struct uec_mii_info *mii_info, u16 regnum); +void phy_write (struct uec_mii_info *mii_info, u16 regnum, u16 val); + static int uec_mac_enable(uec_private_t *uec, comm_dir_e mode) { uec_t *uec_regs; @@ -1267,6 +1279,8 @@ int uec_initialize(int index) return -EINVAL; }
+ devlist[index] = dev; + uec->uec_info = uec_info;
sprintf(dev->name, "FSL UEC%d", index); @@ -1297,6 +1311,45 @@ int uec_initialize(int index)
phy_change(dev);
+#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) \ + && !defined(BITBANGMII) + miiphy_register(dev->name, uec_miiphy_read, uec_miiphy_write); +#endif + return 1; } + +#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) \ + && !defined(BITBANGMII) + +/* + * Read a MII PHY register. + * + * Returns: + * 0 on success + */ +static int uec_miiphy_read(char *devname, unsigned char addr, + unsigned char reg, unsigned short *value) +{ + *value = uec_read_phy_reg(devlist[0], addr, reg); + + return 0; +} + +/* + * Write a MII PHY register. + * + * Returns: + * 0 on success + */ +static int uec_miiphy_write(char *devname, unsigned char addr, + unsigned char reg, unsigned short value) +{ + uec_write_phy_reg(devlist[0], addr, reg, value); + + return 0; +} + +#endif + #endif /* CONFIG_QE */
Hi David,
Long ago I did something like that too (quite useful for playing with MII registers ;-).
Though, I've done it in different way: I modified miiphyutil.c's miiphy_register() to accept eth_device instead of device name, thus no need of devlist hack in the UEC driver...
Unfortunately I didn't find time to convert every user of the miiphy_register() and submit the patch. So.. while you're at it, maybe something like this would be better approach?
diff --git a/common/miiphyutil.c b/common/miiphyutil.c index 281f0b2..3750bb6 100644 --- a/common/miiphyutil.c +++ b/common/miiphyutil.c @@ -48,10 +48,11 @@
struct mii_dev { struct list_head link; + struct eth_device *edev; char *name; - int (*read) (char *devname, unsigned char addr, + int (*read) (struct eth_device *edev, unsigned char addr, unsigned char reg, unsigned short *value); - int (*write) (char *devname, unsigned char addr, + int (*write) (struct eth_device *edev, unsigned char addr, unsigned char reg, unsigned short value); };
@@ -72,12 +73,13 @@ void miiphy_init () * * Register read and write MII access routines for the device <name>. */ -void miiphy_register (char *name, - int (*read) (char *devname, unsigned char addr, +void miiphy_register (struct eth_device *edev, + int (*read) (struct eth_device *edev, unsigned char addr, unsigned char reg, unsigned short *value), - int (*write) (char *devname, unsigned char addr, + int (*write) (struct eth_device *edev, unsigned char addr, unsigned char reg, unsigned short value)) { + char *name = edev->name; struct list_head *entry; struct mii_dev *new_dev; struct mii_dev *miidev; @@ -109,6 +111,7 @@ void miiphy_register (char *name, INIT_LIST_HEAD (&new_dev->link); new_dev->read = read; new_dev->write = write; + new_dev->edev = edev; new_dev->name = (char *)(new_dev + 1); strncpy (new_dev->name, name, name_len); new_dev->name[name_len] = '\0'; @@ -175,7 +178,7 @@ int miiphy_read (char *devname, unsigned char addr, unsigned char reg,
if (strcmp (devname, dev->name) == 0) { found_dev = 1; - read_ret = dev->read (devname, addr, reg, value); + read_ret = dev->read (dev->edev, addr, reg, value); break; } } @@ -212,7 +215,7 @@ int miiphy_write (char *devname, unsigned char addr, unsigned char reg,
if (strcmp (devname, dev->name) == 0) { found_dev = 1; - write_ret = dev->write (devname, addr, reg, value); + write_ret = dev->write (dev->edev, addr, reg, value); break; } } diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index a27c12a..2d29403 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -1296,6 +1296,9 @@ int uec_initialize(int index)
phy_change(dev);
+ if (index == 1) + uec_mmiphy_register(dev); + return 1; } #endif /* CONFIG_QE */ diff --git a/drivers/qe/uec_phy.c b/drivers/qe/uec_phy.c index 6882d03..ccd6645 100644 --- a/drivers/qe/uec_phy.c +++ b/drivers/qe/uec_phy.c @@ -681,4 +681,28 @@ void change_phy_interface_mode (struct eth_device *dev, enet_interface_e mode) marvell_phy_interface_mode (dev, mode); #endif } + + +#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) \ + && !defined(BITBANGMII) +static int uec_miiphy_read(struct eth_device *dev, unsigned char addr, + unsigned char reg, unsigned short *value) +{ + *value = uec_read_phy_reg(dev, addr, reg); + return 0; +} + +static int uec_miiphy_write(struct eth_device *dev, unsigned char addr, + unsigned char reg, unsigned short value) +{ + uec_write_phy_reg(dev, addr, reg, value); + return 0; +} + +void uec_mmiphy_register(struct eth_device *dev) +{ + miiphy_register(dev, uec_miiphy_read, uec_miiphy_write); +} +#endif + #endif /* CONFIG_QE */ diff --git a/drivers/qe/uec_phy.h b/drivers/qe/uec_phy.h index 6f769fb..ef62f0b 100644 --- a/drivers/qe/uec_phy.h +++ b/drivers/qe/uec_phy.h @@ -261,4 +261,5 @@ int uec_read_phy_reg (struct eth_device *dev, int mii_id, int regnum); void mii_clear_phy_interrupt (struct uec_mii_info *mii_info); void mii_configure_phy_interrupt (struct uec_mii_info *mii_info, u32 interrupts); +void uec_mmiphy_register(struct eth_device *dev); #endif /* __UEC_PHY_H__ */ diff --git a/include/miiphy.h b/include/miiphy.h index 5518a0a..0ff4ae6 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -48,10 +48,10 @@ int miiphy_link (char *devname, unsigned char addr);
void miiphy_init (void);
-void miiphy_register (char *devname, - int (*read) (char *devname, unsigned char addr, +void miiphy_register (struct eth_device *edev, + int (*read) (struct eth_device *edev, unsigned char addr, unsigned char reg, unsigned short *value), - int (*write) (char *devname, unsigned char addr, + int (*write) (struct eth_device *edev, unsigned char addr, unsigned char reg, unsigned short value));
int miiphy_set_current_dev (char *devname);
Hi David,
- struct eth_device *edev; char *name;
- int (*read) (struct eth_device *edev, unsigned char addr, unsigned char reg, unsigned short *value);
- int (*write) (struct eth_device *edev, unsigned char addr, unsigned char reg, unsigned short value);
- Register read and write MII access routines for the device <name>.
char
*value),
char
value))
- char *name = edev->name; struct list_head *entry; struct mii_dev *new_dev; struct mii_dev *miidev;
- new_dev->edev = edev; new_dev->name = (char *)(new_dev + 1); strncpy (new_dev->name, name, name_len); new_dev->name[name_len] = '\0';
addr,
unsigned char reg,
value);
value);
break; }
addr,
unsigned char reg,
value);
value);
break; }
phy_change(dev);
- if (index == 1)
- return 1;
- && !defined(BITBANGMII)
addr,
- *value = uec_read_phy_reg(dev, addr, reg);
addr,
- uec_write_phy_reg(dev, addr, reg, value);
- miiphy_register(dev, uec_miiphy_read, uec_miiphy_write);
+} +#endif
addr);
char
*value),
char
value));
Hi Anton, Your approach is better of course, as it deals with this problem in a more structural way than mine. However, there are talks about a more general PHY library coming our way, and I suggest whoever implements it (likely Ben) to consider including your patch there.
David.
Anton Vorontsov
David Saada
