[U-Boot] question regarding the odroidc2 board support
Greetings,
I'm using buildroot to generate images for the odroid c2 boards and from what I see, it uses u-boot.bin to burn into the image. I'm not seeing any other uboot product that is used for booting (unless I'm mistaken). I'm reading the odroid c2 readme file and I see it instructs the use to burn a alternative u-boot.bin from the one that was created by the env. I wonder how it is possible to actually use newer uboot when in the end uboot recommends to replace u-boot.bin with pre existing one?
Thanks,
Dagg.
On Thu, 22 Jun 2017 19:55:21 +0200 daggs daggs@gmx.com wrote:
Greetings,
From the spec I do see that C2 has SD card and eMMC.
I can only share my experience with Odroid XU3/U3.
The boot process would (probably) require some signed blobs from hardkernel (those binaries are corresponding to u-boot-spl.bin).
I can recommend looking to Hardkernel forum (they should have some topics dedicated for this SoM), or look for tizen.org wiki:
https://wiki.tizen.org/Quick_guide_for_odroidxu3
I hope, that the boot flow is similar for XU3 and C2.
Thanks,
Dagg. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Greetings Lukasz
Sent: Tuesday, June 27, 2017 at 10:57 AM From: "Lukasz Majewski" lukma@denx.de To: daggs daggs@gmx.com Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] question regarding the odroidc2 board support
Greetings,
Thanks,
Lukasz Majewski
indeed that is correct, the c2 has a singed binary. as said in my mail, I'm using buildroot to create my images, at the end buildroot takes the file u-boot.bin and burn it into the image at a specific location. the c2 readme explains how to extract the signed blob but I'd expect that it will overwrite part of the u-boot.bin file and no replace it. so I assume I'm missing a part. e.g. u-boot.bin isn't the only file needed from u-boot. am I correct?
Thanks.
Dagg.
On Tue, 27 Jun 2017 13:58:46 +0200 daggs daggs@gmx.com wrote:
Greetings Lukasz
Greetings,
Thanks,
Lukasz Majewski
I can only speak by having some experience with Odroid XU3.
XU3 had bl1.bin.hardkernel, which was signed (and this corresponds to u-boot's SPL binary).
This bl1 called "normal" u-boot (u-boot.bin).
And afterwards u-boot was calling uImage + DTB.
There was also problem with the eMMC layout - you had to jump somewhere else since the default "partition" for u-boot (512 KiB) was too small.
Also please pay a note if you need any TZW (trust zone) firmware for your platform.
Have you found any info on hardkerne's wiki/forum?
Thanks.
Dagg.
Lukasz Majewski
Greetings Lukasz,
Sent: Tuesday, June 27, 2017 at 4:12 PM From: "Lukasz Majewski" lukma@denx.de To: daggs daggs@gmx.com Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] question regarding the odroidc2 board support
Greetings Lukasz
Greetings,
Thanks,
Lukasz Majewski
Thanks.
Dagg.
Lukasz Majewski
yes, I did asked a question regarding this but didn't got any answer. I've decided to ask the uboot devs as from what I understand, the hardkernel guys must comply with uboot's guidelines.
so my question is, does u-boot.bin is the only product from u-boot which is added into the image?
Thanks,
Dagg.
Dagg.
On Wed, 28 Jun 2017 10:44:17 +0200 daggs daggs@gmx.com wrote:
Greetings Lukasz,
Greetings Lukasz
Greetings,
Thanks,
Lukasz Majewski
Thanks.
Dagg.
Lukasz Majewski
From my Exynos development experience - yes it is the only one.
Thanks,
Dagg.
Dagg.
Lukasz Majewski
daggs
Lukasz Majewski
