[U-Boot] [PATCH] mmc: replace the printf() instead of error()
Replace the printf() instead of error(). It is occurred the compiler error with "undefined reference to 'error'".
Fixes: e0079fecd75b ("mmc: refacstor SD startup to make it easier to support new modes")
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/mmc.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 55a53c2200..a5a521eec3 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -828,7 +828,7 @@ static int mmc_get_capabilities(struct mmc *mmc) return 0;
if (!ext_csd) { - error("No ext_csd found!\n"); /* this should enver happen */ + printf("No ext_csd found!\n"); /* this should enver happen */ return -ENOTSUPP; }
@@ -1433,7 +1433,7 @@ static inline int bus_width(uint cap) return 4; if (cap == MMC_MODE_1BIT) return 1; - error("invalid bus witdh capability 0x%x\n", cap); + printf("invalid bus witdh capability 0x%x\n", cap); return 0; }
@@ -1638,7 +1638,7 @@ error: } }
- error("unable to select a mode\n"); + printf("unable to select a mode\n"); return -ENOTSUPP; }
@@ -1844,7 +1844,7 @@ error: } }
return -ENOTSUPP; }
Applied to u-boot-mmc.
Best Regards, Jaehoon Chung
if (!ext_csd) {
return -ENOTSUPP; }printf("No ext_csd found!\n"); /* this should enver happen */
- printf("invalid bus witdh capability 0x%x\n", cap); return 0;
- printf("unable to select a mode\n"); return -ENOTSUPP;
return -ENOTSUPP;
Hi Jaehoon
2017-10-23 13:49 GMT+09:00 Jaehoon Chung jh80.chung@samsung.com:
if (!ext_csd) {
No. Please use pr_err().
Why don't you squash this to e0079fecd75b?
This loses bisect'ability.
On 10/24/2017 11:38 AM, Masahiro Yamada wrote:
Hi Jaehoon
if (!ext_csd) {
Ok..Will change.
Will rebase this. I will drop the PR. Thanks for comment.
Jaehoon Chung
Masahiro Yamada
