[PATCH] ARM: renesas: Enable rswitch, serdes and PHY driver on R8A779F0 S4 Spider
Enable Renesas RSwitch driver, matching SERDES PHY driver and Marvell 10G ethernet PHY driver in R8A779F0 S4 Spider board configuration to make ethernet available via the RSwitch ports.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Hai Pham hai.pham.ud@renesas.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Marek Vasut marek.vasut+renesas@mailbox.org Cc: Peng Fan peng.fan@nxp.com Cc: Ramon Fried rfried.dev@gmail.com Cc: Simon Glass sjg@chromium.org --- configs/r8a779f0_spider_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/r8a779f0_spider_defconfig b/configs/r8a779f0_spider_defconfig index c77ea84ed90..895ce3d41f1 100644 --- a/configs/r8a779f0_spider_defconfig +++ b/configs/r8a779f0_spider_defconfig @@ -59,6 +59,11 @@ CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB_10G=y +CONFIG_PHY_MARVELL_10G=y +CONFIG_DM_ETH_PHY=y +CONFIG_RENESAS_ETHER_SWITCH=y +CONFIG_PHY_R8A779F0_ETHERNET_SERDES=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y
