[U-Boot] Please pull u-boot-ti/master
Hello,
The following changes since commit 3da0e5750b24a9491058df6126c7be577a276c09:
arm: factorize relocate_code routine (2013-05-30 20:24:38 +0200)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to 4596dcc1d4ea5763e0f92cf5becd9fc7d4c6e674:
am33xx/omap: Move save_omap_boot_params to omap-common/boot-common.c (2013-06-05 08:46:49 -0400)
---------------------------------------------------------------- Tom Rini (3): omap-common/hwinit-common.c: Mark omap_rev_string as static am33xx: Correct NON_SECURE_SRAM_START/END am33xx/omap: Move save_omap_boot_params to omap-common/boot-common.c
arch/arm/cpu/armv7/omap-common/boot-common.c | 39 ++++++++++++++++++++++++ arch/arm/cpu/armv7/omap-common/hwinit-common.c | 38 +---------------------- arch/arm/include/asm/arch-am33xx/omap.h | 4 +-- arch/arm/include/asm/arch-am33xx/sys_proto.h | 1 + arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + arch/arm/include/asm/arch-omap5/sys_proto.h | 1 + board/isee/igep0033/board.c | 9 ++++++ board/phytec/pcm051/board.c | 9 ++++++ board/ti/am335x/board.c | 9 ++++++ board/ti/ti814x/evm.c | 9 ++++++ include/configs/am335x_evm.h | 10 ++++-- include/configs/igep0033.h | 10 ++++-- include/configs/pcm051.h | 10 ++++-- 13 files changed, 105 insertions(+), 45 deletions(-)
Hi Tom,
On Wed, 5 Jun 2013 08:54:18 -0400, Tom Rini trini@ti.com wrote:
Hello,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
