[U-Boot] OMAP3: am3517_evm: Add BCH8 ECC and UBIFS NAND support
This patch series updates NAND support for the LogicPD AM3517 EVM/EXP development boards and their corresponding System On Modules.
OMAP3: am3517_evm: Use BCH8 ECC for NAND OMAP3: am3517_evm: Replace JFFS2 with UBI/UBIFS on NAND OMAP3: am3517_evm: Misc. comment and option cleanup
Select 8-bit BCH ecc-scheme with s/w based error correction - OMAP_ECC_BCH8_CODE_HW_DETECTION_SW
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- include/configs/am3517_evm.h | 23 ++++++++++++++++------- 1 file changed, 16 insertions(+), 7 deletions(-)
diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 4d662ad..98a59c5 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -328,8 +328,8 @@ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_BOARD_INIT #define CONFIG_SPL_NAND_SIMPLE -#define CONFIG_SPL_TEXT_BASE 0x40200800 -#define CONFIG_SPL_MAX_SIZE (54 * 1024) /* 8 KB for stack */ +#define CONFIG_SPL_TEXT_BASE 0x40200000 +#define CONFIG_SPL_MAX_SIZE (64 * 1024)
#define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ @@ -354,17 +354,26 @@ #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds"
/* NAND boot config */ +#define CONFIG_BCH +#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS -#define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ - 10, 11, 12, 13} +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, 10, \ + 11, 12, 13, 14, 16, 17, 18, 19, 20, \ + 21, 22, 23, 24, 25, 26, 27, 28, 30, \ + 31, 32, 33, 34, 35, 36, 37, 38, 39, \ + 40, 41, 42, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56 } + #define CONFIG_SYS_NAND_ECCSIZE 512 -#define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW +#define CONFIG_SYS_NAND_ECCBYTES 13 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW +#define CONFIG_SYS_NAND_MAX_OOBFREE 2 +#define CONFIG_SYS_NAND_MAX_ECCPOS 56 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- configs/am3517_evm_defconfig | 2 + include/configs/am3517_evm.h | 102 +++++++++++++++++++++++++++---------------- 2 files changed, 66 insertions(+), 38 deletions(-)
diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index cde84fe..c7699e0 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -4,9 +4,11 @@ CONFIG_TARGET_AM3517_EVM=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_PROMPT="AM3517_EVM # " +CONFIG_SYS_EXTRA_OPTIONS="NAND" # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_GPIO=y CONFIG_SYS_NS16550=y diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 98a59c5..734b8ba 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -34,8 +34,8 @@ /* * Display CPU and Board information */ -#define CONFIG_DISPLAY_CPUINFO 1 -#define CONFIG_DISPLAY_BOARDINFO 1 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO
/* Clock Defines */ #define V_OSCK 26000000 /* Clock output from T2 */ @@ -45,16 +45,16 @@
#define CONFIG_OF_LIBFDT
-#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 -#define CONFIG_REVISION_TAG 1 +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG
/* * Size of malloc() pool */ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB sector */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) +#define CONFIG_SYS_MALLOC_LEN (16 << 20) /* * DDR related */ @@ -90,10 +90,10 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ 115200} -#define CONFIG_MMC 1 -#define CONFIG_GENERIC_MMC 1 -#define CONFIG_OMAP_HSMMC 1 -#define CONFIG_DOS_PARTITION 1 +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_DOS_PARTITION
/* * USB configuration @@ -129,11 +129,15 @@ #endif /* CONFIG_USB_MUSB_AM35X */
/* commands to include */ -#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_CACHE #define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ +#define CONFIG_CMD_EXT2 /* EXT2 Support */ #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE +#define CONFIG_CMD_FS_GENERIC +#define CONFIG_PARTITION_UUIDS +#define CONFIG_CMD_PART +#define CONFIG_CMD_ASKENV
#define CONFIG_CMD_BOOTZ
@@ -141,8 +145,7 @@ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_DHCP -#undef CONFIG_CMD_PING - +#define CONFIG_CMD_PING
#define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_I2C @@ -162,9 +165,33 @@ #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10
-/* - * Board NAND Info. +/* UBI and NAND partitioning */ +#define CONFIG_CMD_UBI /* UBI-formated MTD partition support */ +#define CONFIG_CMD_UBIFS /* Read-only UBI volume operations */ +#define CONFIG_RBTREE /* required by CONFIG_CMD_UBI */ +#define CONFIG_LZO /* required by CONFIG_CMD_UBIFS */ +#define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_MTDPARTS +/* NAND block size is 128 KiB. Synchronize these values with + * corresponding Device Tree entries in Linux: + * MLO(SPL) 4 * NAND_BLOCK_SIZE = 512 KiB @ 0x000000 + * U-Boot 15 * NAND_BLOCK_SIZE = 1920 KiB @ 0x080000 + * U-Boot environment 2 * NAND_BLOCK_SIZE = 256 KiB @ 0x260000 + * Kernel 64 * NAND_BLOCK_SIZE = 8 MiB @ 0x2A0000 + * DTB 4 * NAND_BLOCK_SIZE = 512 KiB @ 0xAA0000 + * RootFS Remaining Flash Space @ 0xB20000 */ +#define MTDIDS_DEFAULT "nand0=omap2-nand.0" +#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:" \ + "512k(MLO)," \ + "1920k(u-boot)," \ + "256k(u-boot-env)," \ + "8m(kernel)," \ + "512k(dtb)," \ + "-(rootfs)" + +/* Board NAND Info. */ #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ @@ -173,13 +200,6 @@
#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ -#define CONFIG_JFFS2_NAND -/* nand device jffs2 lives on */ -#define CONFIG_JFFS2_DEV "nand0" -/* start of jffs2 partition */ -#define CONFIG_JFFS2_PART_OFFSET 0x680000 -#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* sz of jffs2 part */ - /* Environment information */ #define CONFIG_BOOTDELAY 10
@@ -194,18 +214,24 @@ "bootenv=uEnv.txt\0" \ "cmdline=\0" \ "optargs=\0" \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ "mmcdev=0\0" \ "mmcpart=1\0" \ "mmcroot=/dev/mmcblk0p2 rw\0" \ "mmcrootfstype=ext4 rootwait fixrtc\0" \ "mmcargs=setenv bootargs console=${console} " \ + "${mtdparts} " \ "${optargs} " \ "root=${mmcroot} " \ "rootfstype=${mmcrootfstype} " \ "${cmdline}\0" \ "nandargs=setenv bootargs console=${console} " \ - "root=/dev/mtdblock4 rw " \ - "rootfstype=jffs2\0" \ + "${mtdparts} " \ + "${optargs} " \ + "root=ubi0:rootfs rw ubi.mtd=rootfs " \ + "rootfstype=ubifs rootwait " \ + "${cmdline}\0" \ "loadbootenv=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${bootenv}\0"\ "importbootenv=echo Importing environment from mmc ...; " \ "env import -t ${loadaddr} ${filesize}\0" \ @@ -218,8 +244,9 @@ "bootz ${loadaddr} - ${fdtaddr}\0" \ "nandboot=echo Booting from nand ...; " \ "run nandargs; " \ - "nand read ${loadaddr} 280000 400000; " \ - "bootm ${loadaddr}\0" \ + "nand read ${loadaddr} 2a0000 800000; " \ + "nand read ${fdtaddr} aa0000 80000; " \ + "bootm ${loadaddr} - ${fdtaddr}\0" \
#define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev}; if mmc rescan; then " \ @@ -240,17 +267,19 @@ "fi; " \ "else run nandboot; fi"
-#define CONFIG_AUTO_COMPLETE 1 /* * Miscellaneous configurable options */ +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_VERSION_VARIABLE #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 32 /* max number of command */ +#define CONFIG_SYS_MAXARGS 64 /* max number of command */ /* args */ /* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) @@ -287,7 +316,7 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of flash banks */ #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
-#if defined(CONFIG_CMD_NAND) +#if defined(CONFIG_NAND) #define CONFIG_SYS_FLASH_BASE NAND_BASE #endif
@@ -295,7 +324,7 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_IS_IN_NAND #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ @@ -309,13 +338,9 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) #define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ)
-/* Flash banks JFFS2 should use */ +/* Flash banks available */ #define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + \ CONFIG_SYS_MAX_NAND_DEVICE) -#define CONFIG_SYS_JFFS2_MEM_NAND -/* use flash_info[2] */ -#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS -#define CONFIG_SYS_JFFS2_NUM_BANKS 1
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 @@ -337,7 +362,7 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ #define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
#define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBDISK_SUPPORT @@ -350,6 +375,7 @@ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC +#define CONFIG_SPL_MTD_SUPPORT #define CONFIG_SPL_POWER_SUPPORT #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds"
- Display CPU and Board information
There's lots of clean up here and stuff too. Which is fine, but needs a better commit log / subject. Thanks!
- Make comment 'one-liners' truly one line - Drop some CFI verbage and definitions * NOR Support needs to be added with current conventions
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- include/configs/am3517_evm.h | 255 +++++++++++++++++++------------------------ 1 file changed, 111 insertions(+), 144 deletions(-)
diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 734b8ba..5b689a8 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -13,14 +13,17 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_CACHELINE_SIZE 64 +/* High Level Configuration Options */
-/* - * High Level Configuration Options - */ -#define CONFIG_OMAP 1 /* in a TI OMAP core */ -#define CONFIG_OMAP3_AM3517EVM 1 /* working with AM3517EVM */ +#define CONFIG_OMAP #define CONFIG_OMAP_COMMON + +#define CONFIG_SYS_CACHELINE_SIZE 64 + +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ + /* Common ARM Erratas */ #define CONFIG_ARM_ERRATA_454179 #define CONFIG_ARM_ERRATA_430973 @@ -28,59 +31,48 @@
#define CONFIG_EMIF4 /* The chip has EMIF4 controller */
+/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80100000 +#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 + #include <asm/arch/cpu.h> /* get chip and board defs */ #include <asm/arch/omap.h>
-/* - * Display CPU and Board information - */ +/* Display CPU and Board information */ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO - -/* Clock Defines */ -#define V_OSCK 26000000 /* Clock output from T2 */ -#define V_SCLK (V_OSCK >> 1) - -#define CONFIG_MISC_INIT_R - #define CONFIG_OF_LIBFDT - +#define CONFIG_MISC_INIT_R #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_REVISION_TAG
-/* - * Size of malloc() pool - */ -#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB sector */ +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (16 << 20) -/* - * DDR related - */ -#define CONFIG_SYS_CS0_SIZE (256 * 1024 * 1024)
-/* - * Hardware drivers - */ +/* Hardware drivers */
-/* - * OMAP GPIO configuration - */ +/* OMAP GPIO configuration */ #define CONFIG_OMAP_GPIO
-/* - * NS16550 Configuration - */ +/* NS16550 Configuration */ #define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ - #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE (-4) #define CONFIG_SYS_NS16550_CLK V_NS16550_CLK
-/* - * select serial console configuration - */ +/* select serial console configuration */ #define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 /* UART3 on AM3517 EVM */ @@ -90,6 +82,8 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ 115200} + +/* SD/MMC */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_OMAP_HSMMC @@ -111,7 +105,6 @@
#define CONFIG_USB_STORAGE #define CONGIG_CMD_STORAGE -#define CONFIG_CMD_FAT
#ifdef CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL @@ -129,33 +122,29 @@ #endif /* CONFIG_USB_MUSB_AM35X */
/* commands to include */ +#define CONFIG_CMD_NAND #define CONFIG_CMD_CACHE -#define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FS_GENERIC -#define CONFIG_PARTITION_UUIDS #define CONFIG_CMD_PART #define CONFIG_CMD_ASKENV - #define CONFIG_CMD_BOOTZ - -#define CONFIG_CMD_I2C /* I2C serial bus support */ -#define CONFIG_CMD_MMC /* MMC support */ -#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MMC #define CONFIG_CMD_DHCP #define CONFIG_CMD_PING +#define CONFIG_CMD_MTDPARTS
-#define CONFIG_SYS_NO_FLASH +/* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_OMAP24_I2C_SPEED 100000 #define CONFIG_SYS_OMAP24_I2C_SLAVE 1 #define CONFIG_SYS_I2C_OMAP34XX
-/* - * Ethernet - */ +/* Ethernet */ #define CONFIG_DRIVER_TI_EMAC #define CONFIG_DRIVER_TI_EMAC_USE_RMII #define CONFIG_MII @@ -165,14 +154,45 @@ #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10
-/* UBI and NAND partitioning */ -#define CONFIG_CMD_UBI /* UBI-formated MTD partition support */ -#define CONFIG_CMD_UBIFS /* Read-only UBI volume operations */ -#define CONFIG_RBTREE /* required by CONFIG_CMD_UBI */ -#define CONFIG_LZO /* required by CONFIG_CMD_UBIFS */ -#define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ -#define CONFIG_MTD_DEVICE -#define CONFIG_CMD_MTDPARTS +/* Board NAND Info. */ +#ifdef CONFIG_NAND +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_NAND_OMAP_GPMC_PREFETCH +#define CONFIG_BCH +#define CONFIG_CMD_UBI /* UBI-formated MTD partition support */ +#define CONFIG_CMD_UBIFS /* Read-only UBI volume operations */ +#define CONFIG_RBTREE /* required by CONFIG_CMD_UBI */ +#define CONFIG_LZO /* required by CONFIG_CMD_UBIFS */ +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ + /* to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ + /* to access */ + /* nand at CS0 */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ + /* NAND devices */ +#define CONFIG_SYS_NAND_BUSWIDTH_16BIT +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, 10, \ + 11, 12, 13, 14, 16, 17, 18, 19, 20, \ + 21, 22, 23, 24, 25, 26, 27, 28, 30, \ + 31, 32, 33, 34, 35, 36, 37, 38, 39, \ + 40, 41, 42, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56 } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 13 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW +#define CONFIG_SYS_NAND_MAX_OOBFREE 2 +#define CONFIG_SYS_NAND_MAX_ECCPOS 56 +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ /* NAND block size is 128 KiB. Synchronize these values with * corresponding Device Tree entries in Linux: * MLO(SPL) 4 * NAND_BLOCK_SIZE = 512 KiB @ 0x000000 @@ -190,16 +210,11 @@ "8m(kernel)," \ "512k(dtb)," \ "-(rootfs)" +#else +#define MTDIDS_DEFAULT +#define MTDPARTS_DEFAULT +#endif /* CONFIG_NAND */
-/* Board NAND Info. */ -#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ - /* to access nand */ -#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ - /* to access */ - /* nand at CS0 */ - -#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ - /* NAND devices */ /* Environment information */ #define CONFIG_BOOTDELAY 10
@@ -267,22 +282,25 @@ "fi; " \ "else run nandboot; fi"
-/* - * Miscellaneous configurable options - */ +/* Miscellaneous configurable options */ #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_VERSION_VARIABLE -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_PARTITION_UUIDS + +/* We set the max number of command args high to avoid HUSH bugs. */ +#define CONFIG_SYS_MAXARGS 64 + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 512 /* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 64 /* max number of command */ - /* args */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + + sizeof(CONFIG_SYS_PROMPT) + 16) /* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + /* memtest works on */ #define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ @@ -299,16 +317,18 @@ #define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 #define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */
-/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ -#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 -#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 +/* Physical Memory Map */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 +#define CONFIG_SYS_CS0_SIZE (256 * 1024 * 1024) +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 +#define CONFIG_SYS_INIT_RAM_SIZE 0x800 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE)
-/*----------------------------------------------------------------------- - * FLASH and environment organization - */ +/* FLASH and environment organization */
/* **** PISMO SUPPORT *** */ #define CONFIG_SYS_MAX_FLASH_SECT 520 /* max number of sectors */ @@ -323,31 +343,12 @@ /* Monitor at start of flash */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
-#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_ENV_IS_IN_NAND -#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ - #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_ENV_SIZE CONFIG_SYS_ENV_SECT_SIZE +#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET - -/*----------------------------------------------------------------------- - * CFI FLASH driver setup - */ -/* timeout values are in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) - -/* Flash banks available */ -#define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + \ - CONFIG_SYS_MAX_NAND_DEVICE) - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 -#define CONFIG_SYS_INIT_RAM_SIZE 0x800 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) +#define CONFIG_ENV_IS_IN_NAND
/* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK @@ -379,38 +380,4 @@ #define CONFIG_SPL_POWER_SUPPORT #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds"
-/* NAND boot config */ -#define CONFIG_BCH -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT -#define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_PAGE_COUNT 64 -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_OOBSIZE 64 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) -#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS -#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, 10, \ - 11, 12, 13, 14, 16, 17, 18, 19, 20, \ - 21, 22, 23, 24, 25, 26, 27, 28, 30, \ - 31, 32, 33, 34, 35, 36, 37, 38, 39, \ - 40, 41, 42, 44, 45, 46, 47, 48, 49, \ - 50, 51, 52, 53, 54, 55, 56 } - -#define CONFIG_SYS_NAND_ECCSIZE 512 -#define CONFIG_SYS_NAND_ECCBYTES 13 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW -#define CONFIG_SYS_NAND_MAX_OOBFREE 2 -#define CONFIG_SYS_NAND_MAX_ECCPOS 56 -#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 - -/* - * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM - * 64 bytes before this address should be set aside for u-boot.img's - * header. That is 0x800FFFC0--0x80100000 should not be used for any - * other needs. - */ -#define CONFIG_SYS_TEXT_BASE 0x80100000 -#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 - #endif /* __CONFIG_H */
- NOR Support needs to be added with current conventions
... and you could move most of 2/3 into here, aside from the parts strictly about UBI/UBIFS.
Okay. I will submit a version 2 with only two commits.
- Derald
-- Tom
Derald D. Woods
