[U-Boot] [patch v3 1/2] pxe: Fix pxe boot with FIT image
When FIT image is used, a single image provides kernel, device tree and optionally ramdisk. Argc and argv need to be adjusted to support this.
Test cases: 1. Booting with legacy images 2. Booting with legacy images without initrd 3. Booting with FIT image Test commands: 1. pxe get && pxe boot 2. sysboot
Signed-off-by: York Sun york.sun@nxp.com Signed-off-by: Wenbin Song wenbin.song@nxp.com --- Changes for v2: no change --- cmd/pxe.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/cmd/pxe.c b/cmd/pxe.c index 9434a18..0a07f14 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -620,7 +620,7 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) char initrd_str[22]; char mac_str[29] = ""; char ip_str[68] = ""; - int bootm_argc = 3; + int bootm_argc = 2; int len = 0; ulong kernel_addr; void *buf; @@ -652,8 +652,6 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) strcpy(bootm_argv[2], getenv("ramdisk_addr_r")); strcat(bootm_argv[2], ":"); strcat(bootm_argv[2], getenv("filesize")); - } else { - bootm_argv[2] = "-"; }
if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) { @@ -785,8 +783,11 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) if (!bootm_argv[3]) bootm_argv[3] = getenv("fdt_addr");
- if (bootm_argv[3]) + if (bootm_argv[3]) { + if (!bootm_argv[2]) + bootm_argv[2] = "-"; bootm_argc = 4; + }
kernel_addr = genimg_get_kernel_addr(bootm_argv[1]); buf = map_sysmem(kernel_addr, 0);
Use environment variable "kernel_addr_r" to indicate the location in RAM where FIT image will be stored. Use label command "kernel" to indicate which <path> the FIT image at.
Signed-off-by: Wenbin Song wenbin.song@nxp.com --- Changes for v2: Fixup the email address of author. --- doc/README.pxe | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/doc/README.pxe b/doc/README.pxe index cc182c9..db11658 100644 --- a/doc/README.pxe +++ b/doc/README.pxe @@ -78,9 +78,9 @@ pxe boot address of the tftp server from which other files will be retrieved.
kernel_addr_r, initrd_addr_r - locations in RAM at which 'pxe boot' will - store the kernel and initrd it retrieves from tftp. These locations will - be passed to the bootm command to boot the kernel. These environment - variables are required to be set. + store the kernel(or FIT image) and initrd it retrieves from tftp. These + locations will be passed to the bootm command to boot the kernel. These + environment variables are required to be set.
fdt_addr_r - location in RAM at which 'pxe boot' will store the fdt blob it retrieves from tftp. The retrieval is possible if 'fdt' label is defined in @@ -138,9 +138,9 @@ menu default - set this label as the default label to boot; this is specified in a different way
kernel <path> - if this label is chosen, use tftp to retrieve the kernel - at <path>. it will be stored at the address indicated in - the kernel_addr_r environment variable, and that address - will be passed to bootm to boot this kernel. + (or FIT image) at <path>. it will be stored at the address + indicated in the kernel_addr_r environment variable, and + that address will be passed to bootm to boot this kernel.
append <string> - use <string> as the kernel command line when booting this label.
Test cases:
- Booting with legacy images
- Booting with legacy images without initrd
- Booting with FIT image
Test commands:
- pxe get && pxe boot
- sysboot
Wenbin song
