[RFC PATCH v2 0/4] mtd: ubi: Enable accessing RO filesystems in UBI vols
Hi list,
This is the second version of my RFC patchset to treat static UBI volumes as DM block devices, allowing users to access read-only filesystems (SquashFS, EROFS) contained within such volumes.
This is a rebased and updated version, as requested by Heiko.
Previously, we have agreed on a syntax, which my downstream is now starting to use: => ls ubi 0:rootfs /boot => ls ubi 0:2 /boot
This is still not yet ready for mainline inclusion, because the actual UBI DM access is happening in disk/part.c, which is not "clean" with the way the DM/legacy switching is currently plumbed. I'm still looking for guidance on how to name/implement block functions for looking up a *subvolume* block device by type+parentidx+{name,ID}.
Changes v1->v2: - Rebased onto next post-2023.10's release. - Fix NULL dereference caused by passing NULL to `blk_create_device` - Parse UBI index/volume numbers with `dectoul` instead of `hextoul`, to match Linux's behavior of treating these numbers as decimal. - Do not treat a valid decimal number as a volume name, even if the volume ID doesn't exist, to match Linux's behavior of always treating decimal numbers as volume IDs.
Cheers, Sam
Sam Edwards (4): mtd: ubi: register UBI attachments as DM devices mtd: ubi: bind block device driver for static volumes disk: part: fall-through if "ubi" requested but ubifs not mounted HACK: enable access to `ubi 0:volname` block devices
cmd/ubi.c | 11 +++ disk/part.c | 69 +++++++++++-- drivers/mtd/ubi/Makefile | 1 + drivers/mtd/ubi/ubi-uclass.c | 185 +++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/ubi_uboot.h | 5 + 6 files changed, 264 insertions(+), 8 deletions(-) create mode 100644 drivers/mtd/ubi/ubi-uclass.c
This is in preparation for exposing static UBI volumes as block devices.
A UBI uclass and driver are introduced, and a "ubi0" virtual device with the proper driver is created below whichever MTD device is attached as the active UBI partition. This virtual device will soon be the parent for the BLK devices that represent the static volumes.
Signed-off-by: Sam Edwards CFSworks@gmail.com --- cmd/ubi.c | 11 ++++++ drivers/mtd/ubi/Makefile | 1 + drivers/mtd/ubi/ubi-uclass.c | 74 ++++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/ubi_uboot.h | 5 +++ 5 files changed, 92 insertions(+) create mode 100644 drivers/mtd/ubi/ubi-uclass.c
diff --git a/cmd/ubi.c b/cmd/ubi.c index 0a6a80bdd1..314c7f60f4 100644 --- a/cmd/ubi.c +++ b/cmd/ubi.c @@ -560,6 +560,13 @@ static int ubi_detach(void) cmd_ubifs_umount(); #endif
+#ifdef CONFIG_DM_MTD + /* + * Clean up any UBI devices in DM + */ + ubi_dm_unbind_all(); +#endif + /* * Call ubi_exit() before re-initializing the UBI subsystem */ @@ -598,6 +605,10 @@ int ubi_part(char *part_name, const char *vid_header_offset) return err; }
+#ifdef CONFIG_DM_MTD + ubi_dm_bind(0); +#endif + ubi = ubi_devices[0];
return 0; diff --git a/drivers/mtd/ubi/Makefile b/drivers/mtd/ubi/Makefile index 30d00fbdfe..375075f75e 100644 --- a/drivers/mtd/ubi/Makefile +++ b/drivers/mtd/ubi/Makefile @@ -7,3 +7,4 @@ obj-y += attach.o build.o vtbl.o vmt.o upd.o kapi.o eba.o io.o wl.o crc32.o obj-$(CONFIG_MTD_UBI_FASTMAP) += fastmap.o obj-y += misc.o obj-y += debug.o +obj-$(CONFIG_DM_MTD) += ubi-uclass.o diff --git a/drivers/mtd/ubi/ubi-uclass.c b/drivers/mtd/ubi/ubi-uclass.c new file mode 100644 index 0000000000..f8971e793e --- /dev/null +++ b/drivers/mtd/ubi/ubi-uclass.c @@ -0,0 +1,74 @@ +// SPDX-License-Identifier: GPL-2.0 +/** + * ubi-uclass.c - UBI partition and volume block device uclass driver + * + * Copyright (C) 2023 Sam Edwards CFSworks@gmail.com + */ + +#define LOG_CATEGORY UCLASS_UBI + +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <ubi_uboot.h> + +int ubi_dm_bind(unsigned int index) +{ + struct udevice *dev; + int ret; + char name[16]; + const char *name_dup; + struct ubi_device *ubi = ubi_devices[index]; + const struct mtd_info *mtd = ubi->mtd; + + /* MTD partitions are not in DM; navigate to the real MTD device */ + if (mtd->parent) + mtd = mtd->parent; + + snprintf(name, sizeof(name), "ubi%u", index); + name_dup = strdup(name); + ret = device_bind(mtd->dev, DM_DRIVER_GET(ubi), name_dup, ubi, + ofnode_null(), &dev); + if (ret) { + free((void *)name_dup); + return ret; + } + + device_set_name_alloced(dev); + + return 0; +} + +int ubi_dm_unbind_all(void) +{ + int ret; + struct uclass *uc; + struct udevice *dev; + struct udevice *next; + + ret = uclass_get(UCLASS_UBI, &uc); + if (ret) + return ret; + + uclass_foreach_dev_safe(dev, next, uc) { + ret = device_remove(dev, DM_REMOVE_NORMAL); + if (ret) + return ret; + + ret = device_unbind(dev); + if (ret) + return ret; + } + + return 0; +} + +U_BOOT_DRIVER(ubi) = { + .id = UCLASS_UBI, + .name = "ubi_dev", +}; + +UCLASS_DRIVER(ubi) = { + .id = UCLASS_UBI, + .name = "ubi", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 0432c95c9e..ee11fbb38d 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -140,6 +140,7 @@ enum uclass_id { UCLASS_THERMAL, /* Thermal sensor */ UCLASS_TIMER, /* Timer device */ UCLASS_TPM, /* Trusted Platform Module TIS interface */ + UCLASS_UBI, /* Unsorted Block Images MTD partition */ UCLASS_UFS, /* Universal Flash Storage */ UCLASS_USB, /* USB bus */ UCLASS_USB_DEV_GENERIC, /* USB generic device */ diff --git a/include/ubi_uboot.h b/include/ubi_uboot.h index 6da348eb62..9d37848f03 100644 --- a/include/ubi_uboot.h +++ b/include/ubi_uboot.h @@ -52,6 +52,11 @@ extern int ubi_part(char *part_name, const char *vid_header_offset); extern int ubi_volume_write(char *volume, void *buf, size_t size); extern int ubi_volume_read(char *volume, char *buf, size_t size);
+#ifdef CONFIG_DM_MTD +extern int ubi_dm_bind(unsigned int); +extern int ubi_dm_unbind_all(void); +#endif + extern struct ubi_device *ubi_devices[]; int cmd_ubifs_mount(char *vol_name); int cmd_ubifs_umount(void);
This makes static UBI volumes readable as block devices, however no mechanism for selecting these volume devices yet exists.
Signed-off-by: Sam Edwards CFSworks@gmail.com --- drivers/mtd/ubi/ubi-uclass.c | 111 +++++++++++++++++++++++++++++++++++ 1 file changed, 111 insertions(+)
diff --git a/drivers/mtd/ubi/ubi-uclass.c b/drivers/mtd/ubi/ubi-uclass.c index f8971e793e..b2c47bfe0c 100644 --- a/drivers/mtd/ubi/ubi-uclass.c +++ b/drivers/mtd/ubi/ubi-uclass.c @@ -8,10 +8,120 @@ #define LOG_CATEGORY UCLASS_UBI
#include <common.h> +#include <blk.h> #include <dm.h> #include <dm/device-internal.h> #include <ubi_uboot.h>
+static ulong ubi_bread(struct udevice *dev, lbaint_t lba, lbaint_t blkcnt, + void *dst) +{ + int err, lnum; + struct blk_desc *blk = dev_get_uclass_plat(dev); + struct ubi_device *ubi = dev_get_plat(dev->parent); + struct ubi_volume *vol = ubi->volumes[blk->devnum]; + lbaint_t lba_per_peb = vol->usable_leb_size / blk->blksz; + lbaint_t lba_off, lba_len, total = 0; + + while (blkcnt) { + lnum = lba / lba_per_peb; + lba_off = lba % lba_per_peb; + lba_len = lba_per_peb - lba_off; + if (lba_len > blkcnt) + lba_len = blkcnt; + + err = ubi_eba_read_leb(ubi, vol, lnum, dst, + lba_off << blk->log2blksz, + lba_len << blk->log2blksz, 0); + if (err) { + pr_err("UBI read error %x\n", err); + break; + } + + lba += lba_len; + blkcnt -= lba_len; + dst += lba_len << blk->log2blksz; + total += lba_len; + } + + return total; +} + +static const struct blk_ops ubi_block_ops = { + .read = ubi_bread, +}; + +U_BOOT_DRIVER(ubi_block) = { + .name = "ubi_block", + .id = UCLASS_BLK, + .ops = &ubi_block_ops, +}; + +static bool is_power_of_two(unsigned int x) +{ + return (x & -x) == x; +} + +static unsigned int choose_blksz_for_volume(const struct ubi_volume *vol) +{ + /* + * U-Boot assumes a power-of-two blksz; however, UBI LEBs are + * very often not suitably sized. To solve this, we divide the + * LEBs into a whole number of LBAs per LEB, such that each LBA + * addresses a power-of-two-sized block. To choose the blksz, + * we either: + * 1) Use the volume alignment, if it's a non-unity power of + * two. The LEB size is a multiple of this alignment, and it + * allows the user to force a particular blksz if needed for + * their use case. + * 2) Otherwise, find the greatest power-of-two factor of the + * LEB size. + */ + if (vol->alignment > 1 && is_power_of_two(vol->alignment)) + return vol->alignment; + + unsigned int blksz = 1; + while ((vol->usable_leb_size & blksz) == 0) + blksz <<= 1; + return blksz; +} + +static int ubi_post_bind(struct udevice *dev) +{ + int i; + int ret; + unsigned int blksz; + lbaint_t lba; + struct udevice *blkdev; + struct ubi_device *ubi = dev_get_plat(dev); + + for (i = 0; i < ubi->vtbl_slots; i++) { + struct ubi_volume *vol = ubi->volumes[i]; + if (!vol || vol->vol_id >= UBI_INTERNAL_VOL_START || + vol->vol_type != UBI_STATIC_VOLUME) + continue; + + if (vol->updating || vol->upd_marker) { + pr_err("** UBI volume %d ("%s") midupdate; ignored\n", + vol->vol_id, vol->name); + continue; + } + + blksz = choose_blksz_for_volume(vol); + lba = DIV_ROUND_UP((unsigned long long)vol->used_bytes, blksz); + + pr_debug("UBI volume %d ("%s"): %lu blocks, %d bytes each\n", + vol->vol_id, vol->name, lba, blksz); + + ret = blk_create_device(dev, "ubi_block", vol->name, UCLASS_UBI, + vol->vol_id, blksz, lba, &blkdev); + if (ret) + return ret; + } + + return 0; +} + int ubi_dm_bind(unsigned int index) { struct udevice *dev; @@ -71,4 +181,5 @@ U_BOOT_DRIVER(ubi) = { UCLASS_DRIVER(ubi) = { .id = UCLASS_UBI, .name = "ubi", + .post_bind = ubi_post_bind, };
Since we're adding the ability to access static UBI volumes as block devices, it is no longer an error to use the "ubi" ifname with UBIFS unmounted.
Ideally, the access to UBIFS should instead be called "ubifs" but it would break backwards compatibility to change this. Instead, use the UBIFS mount status to disambiguate what the user means by "ubi"
There is no change in functionality in this patch: UBIFS access works the same and an error still occurs when using "ubi" without UBIFS mounted. The only difference is that now, the error message is a plain "Bad device specification" and does not suggest using ubifsmount.
Signed-off-by: Sam Edwards CFSworks@gmail.com --- disk/part.c | 14 ++++++-------- 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/disk/part.c b/disk/part.c index 72241b7b23..a4b6d265da 100644 --- a/disk/part.c +++ b/disk/part.c @@ -511,15 +511,13 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str,
#if IS_ENABLED(CONFIG_CMD_UBIFS) && !IS_ENABLED(CONFIG_SPL_BUILD) /* - * Special-case ubi, ubi goes through a mtd, rather than through - * a regular block device. + * Special-case ubifs, which does not go through the block device layer + * and also must be mounted ahead of time. U-Boot has historically + * called this "ubi" too, even though *static* UBI volumes are + * accessible as block devices. For backward compatibility, assume that + * when UBIFS is mounted, the user intends "ubi" to mean "ubifs." */ - if (!strcmp(ifname, "ubi")) { - if (!ubifs_is_mounted()) { - printf("UBIFS not mounted, use ubifsmount to mount volume first!\n"); - return -EINVAL; - } - + if (ubifs_is_mounted() && !strcmp(ifname, "ubi")) { strcpy((char *)info->type, BOOT_PART_TYPE); strcpy((char *)info->name, "UBI"); return 0;
--- disk/part.c | 55 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 55 insertions(+)
diff --git a/disk/part.c b/disk/part.c index a4b6d265da..7c995f583c 100644 --- a/disk/part.c +++ b/disk/part.c @@ -14,6 +14,9 @@ #include <malloc.h> #include <part.h> #include <ubifs_uboot.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/uclass-internal.h>
#undef PART_DEBUG
@@ -524,6 +527,58 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str, } #endif
+#if IS_ENABLED(CONFIG_CMD_UBI) && !IS_ENABLED(CONFIG_SPL_BUILD) + /* + * Also special-case UBI, which may use names to find the specific + * volumes, so this deviates a bit from the typical devnum:partnum + * syntax. + */ + if (!strcmp(ifname, "ubi")) { + dev = dectoul(dev_part_str, &ep); + if (*ep == ':') { + struct udevice *ubi_dev = NULL; + struct udevice *vol_dev = NULL; + part_str = &ep[1]; + + ret = uclass_find_device(UCLASS_UBI, dev, &ubi_dev); + if (!ubi_dev || ret) { + printf("** Cannot find UBI %x\n", dev); + return -EINVAL; + } + + part = dectoul(part_str, &ep); + if (!*ep) { + struct udevice *tmp_dev; + device_foreach_child(tmp_dev, ubi_dev) { + struct blk_desc *desc = dev_get_uclass_plat(tmp_dev); + if (desc->devnum == part) { + vol_dev = tmp_dev; + break; + } + } + } else { + ret = device_find_child_by_name(ubi_dev, part_str, &vol_dev); + } + + if (!vol_dev || ret) { + printf("** UBI volume %s not found\n", part_str); + return -EINVAL; + } + + ret = device_probe(vol_dev); + if (ret) + return ret; + + *desc = dev_get_uclass_plat(vol_dev); + part_get_info_whole_disk(*desc, info); + return 0; + } + + printf("UBIFS not mounted, use ubifsmount to mount volume first!\n"); + return -EINVAL; + } +#endif + /* If no dev_part_str, use bootdevice environment variable */ if (CONFIG_IS_ENABLED(ENV_SUPPORT)) { if (!dev_part_str || !strlen(dev_part_str) ||
Sam Edwards
