Re: [U-Boot-Users] [PATCH] 83xx: Put the version (and magic) after the HRCW.
Sam Song wrote:
Jerry Van Baren gerald.vanbaren@comcast.net wrote:
Put the version (and magic) after the HRCW. This puts it in a fixed location in flash, not at the
start
of flash but as close as we can get.
Nice effort. Space saving and better version check.
I guess the same change could apply for MPC8260/47/8.
Thanks,
Sam
Yes. Most boards have the version in the first bytes of flash, but this was not possible on the 82xx because of the HRCW, so it was put in .data. This set up was copied for the 83xx (which also has a HRCW). My change moves it back to .text just after the HRCW. I put also the u-boot magic number back in in honor of Wolfgang. ;-)
If you change the file names in the patch, it probably would apply. :-) I intend to do this (perhaps literally), but ran out of ambition tonight.
Looks almost the same as the patch I sent the other day. I am good with either version.
Jocke
start
Thanks,
Sam
Jocke
Hi Jocke,
Yes, your patch, and my objection to its removal of the HRCW, was the genesis of this one. The two differences are (a) I kept the HRCW and (b) I put the "u-boot magic number" in (no known reason to do this, but it Just Seemed Right[tm]). The result of (b) is that the version starts at flash offset 0x44 rather than 0x40. Should be NBD.
Thanks, gvb
Jerry Van Baren
Joakim Tjernlund
