Re: [U-Boot] [PATCH 1/1] ARM DaVinci: Add common peripherals andmodules enable functions.
From: u-boot-bounces@lists.denx.de on behalf of Hugo Villeneuve Sent: Fri 11/21/2008 2:35 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH 1/1] ARM DaVinci: Add common peripherals andmodules enable functions.
Taken all the duplicated code for enabling common modules and apply software workarounds from the board specific code into common functions. Also added comments explaining the workarounds (from TI errata documents) and replaced some numerical bit numbers with more meaningful defines.
Signed-off-by: Hugo Villeneuve hugo.villeneuve@lyrtech.com
board/davinci/common/psc.c | 65 ++++++++++++++++++++++++++ +++++++++ board/davinci/common/psc.h | 3 ++ board/davinci/dvevm/dvevm.c | 35 +++++-------------- board/davinci/schmoogie/schmoogie.c | 37 +++++-------------- board/davinci/sffsdr/sffsdr.c | 31 +++-------------- board/davinci/sonata/sonata.c | 35 +++++-------------- 6 files changed, 101 insertions(+), 105 deletions(-)
I sent this patch two months ago but I didn´t receive feedback...
Hugo V.
diff --git a/board/davinci/common/psc.c b/board/davinci/common/psc.c index d538d51..28e2a4b 100644 --- a/board/davinci/common/psc.c +++ b/board/davinci/common/psc.c @@ -26,6 +26,14 @@ #include <common.h> #include <asm/arch/hardware.h>
+#define PINMUX0_EMACEN (1 << 31) +#define PINMUX0_AECS5 (1 << 11) +#define PINMUX0_AECS4 (1 << 10)
+#define PINMUX1_I2C (1 << 7) +#define PINMUX1_UART1 (1 << 1) +#define PINMUX1_UART0 (1 << 0)
- The DM6446 includes two separate power domains: "Always On" and
"DSP". The
- "Always On" power domain is always on when the chip is on. The
"Always On" @@ -115,3 +123,60 @@ void dsp_on(void) REG(PSC_GBLCTL) &= ~0x1f; } #endif /* CONFIG_SYS_USE_DSPLINK */
+void davinci_enable_uart0(void) +{
- lpsc_on(DAVINCI_LPSC_UART0);
- /* Bringup UART0 out of reset */
- REG(UART0_PWREMU_MGMT) = 0x0000e003;
- /* Enable UART0 MUX lines */
- REG(PINMUX1) |= PINMUX1_UART0;
+#ifdef CONFIG_DRIVER_TI_EMAC +void davinci_enable_emac(void) +{
- lpsc_on(DAVINCI_LPSC_EMAC);
- lpsc_on(DAVINCI_LPSC_EMAC_WRAPPER);
- lpsc_on(DAVINCI_LPSC_MDIO);
- /* Enable GIO3.3V cells used for EMAC */
- REG(VDD3P3V_PWDN) = 0;
- /* Enable EMAC. */
- REG(PINMUX0) |= PINMUX0_EMACEN;
+} +#endif
+void davinci_enable_i2c(void) +{
- lpsc_on(DAVINCI_LPSC_I2C);
- /* Enable I2C pin Mux */
- REG(PINMUX1) |= PINMUX1_I2C;
+void davinci_errata_workarounds(void) +{
* Workaround for TMS320DM6446 errata 1.3.22:
* PSC: PTSTAT Register Does Not Clear After Warm/Maximum
Reset
* Revision(s) Affected: 1.3 and earlier
- REG(PSC_SILVER_BULLET) = 0;
* Set the PR_OLD_COUNT bits in the Bus Burst Priority
Register (PBBPR)
* as suggested in TMS320DM6446 errata 2.1.2:
* On DM6446 Silicon Revision 2.1 and earlier, under certain
conditions
* low priority modules can occupy the bus and prevent high
priority
* modules like the VPSS from getting the required DDR2
throughput.
* A hex value of 0x20 should provide a good ARM (cache
enabled)
* performance and still allow good utilization by the VPSS
or other
* modules.
- REG(VBPR) = 0x20;
+} diff --git a/board/davinci/common/psc.h b/board/davinci/common/psc.h index 6ab2575..b18a185 100644 --- a/board/davinci/common/psc.h +++ b/board/davinci/common/psc.h @@ -24,5 +24,8 @@
void lpsc_on(unsigned int id); void dsp_on(void); +void davinci_enable_uart0(void); +void davinci_enable_emac(void); +void davinci_enable_i2c(void);
#endif /* __PSC_H */ diff --git a/board/davinci/dvevm/dvevm.c b/board/davinci/dvevm/dvevm.c index abf60b3..f740124 100644 --- a/board/davinci/dvevm/dvevm.c +++ b/board/davinci/dvevm/dvevm.c @@ -27,7 +27,6 @@ #include <common.h> #include <i2c.h> #include <asm/arch/hardware.h> -#include <asm/arch/emac_defs.h> #include "../common/psc.h" #include "../common/misc.h"
@@ -41,16 +40,13 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR;
- /* Workaround for TMS320DM6446 errata 1.3.22 */
- /* Configure AEMIF pins (although this should be configured
at boot time
* with pull-up/pull-down resistors) */
REG(PINMUX0) = 0x00000c1f;
davinci_errata_workarounds();
/* Power on required peripherals */
- lpsc_on(DAVINCI_LPSC_TIMER1); lpsc_on(DAVINCI_LPSC_GPIO);
#if !defined(CONFIG_SYS_USE_DSPLINK) @@ -58,24 +54,11 @@ int board_init(void) dsp_on(); #endif /* CONFIG_SYS_USE_DSPLINK */
- REG(PINMUX1) |= 1;
- /* Enable EMAC and AEMIF pins */
- REG(PINMUX0) = 0x80000c1f;
- REG(PINMUX1) |= (1 << 7);
- /* Set the Bus Priority Register to appropriate value */
- REG(VBPR) = 0x20;
davinci_enable_uart0();
davinci_enable_emac();
davinci_enable_i2c();
lpsc_on(DAVINCI_LPSC_TIMER1); timer_init();
return(0);
diff --git a/board/davinci/schmoogie/schmoogie.c b/board/davinci/schmoogie/schmoogie.c index 3504a2e..433769a 100644 --- a/board/davinci/schmoogie/schmoogie.c +++ b/board/davinci/schmoogie/schmoogie.c @@ -27,7 +27,6 @@ #include <common.h> #include <i2c.h> #include <asm/arch/hardware.h> -#include <asm/arch/emac_defs.h> #include "../common/psc.h" #include "../common/misc.h"
at boot time
- REG(VBPR) = 0x20;
return(0);
@@ -87,7 +70,7 @@ int misc_init_r(void) int i = 0;
/* Set serial number from UID chip */
- u_int8_t crc_tbl[256] = {
- const u_int8_t crc_tbl[256] = { 0x00, 0x5e, 0xbc, 0xe2, 0x61, 0x3f, 0xdd,
0x83, 0xc2, 0x9c, 0x7e, 0x20, 0xa3, 0xfd, 0x1f, 0x41, 0x9d, 0xc3, 0x21, 0x7f, 0xfc, 0xa2, 0x40, 0x1e, diff --git a/board/davinci/sffsdr/sffsdr.c b/board/davinci/sffsdr/sffsdr.c index 9296d7b..e76f86d 100644 --- a/board/davinci/sffsdr/sffsdr.c +++ b/board/davinci/sffsdr/sffsdr.c @@ -30,7 +30,6 @@ #include <common.h> #include <i2c.h> #include <asm/arch/hardware.h> -#include <asm/arch/emac_defs.h> #include "../common/psc.h" #include "../common/misc.h"
@@ -51,16 +50,9 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR;
#if !defined(CONFIG_SYS_USE_DSPLINK) @@ -68,24 +60,11 @@ int board_init(void) dsp_on(); #endif /* CONFIG_SYS_USE_DSPLINK */
- REG(VBPR) = 0x20;
return(0);
diff --git a/board/davinci/sonata/sonata.c b/board/davinci/sonata/sonata.c index 6de9356..d56b443 100644 --- a/board/davinci/sonata/sonata.c +++ b/board/davinci/sonata/sonata.c @@ -26,7 +26,6 @@
#include <common.h> #include <asm/arch/hardware.h> -#include <asm/arch/emac_defs.h> #include "../common/psc.h" #include "../common/misc.h"
@@ -40,16 +39,13 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR;
at boot time
#if !defined(CONFIG_SYS_USE_DSPLINK) @@ -57,24 +53,11 @@ int board_init(void) dsp_on(); #endif /* CONFIG_SYS_USE_DSPLINK */
- REG(VBPR) = 0x20;
return(0);
-- 1.5.4.5
--------------- Hugo Villeneuve www.hugovil.com ---------------
Dear Jean-Christophe,
In message 20090119095618.083e0208.hugo@hugovil.com Hugo Villeneuve you wrote:
Taken all the duplicated code for enabling common modules and apply software workarounds from the board specific code into common functions. Also added comments explaining the workarounds (from TI errata documents) and replaced some numerical bit numbers with more meaningful defines. =
I sent this patch two months ago but I didn=B4t receive feedback...
Please comment.
Ack they will be present in the next merge
Best Regards, J.
On Sat, 24 Jan 2009 17:16:58 +0100 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com wrote:
board/davinci/common/psc.c | 65 ++++++++++++++++++++++ ++++ +++++++++ board/davinci/common/psc.h | 3 ++ board/davinci/dvevm/dvevm.c | 35 +++++-------------- board/davinci/schmoogie/schmoogie.c | 37 +++++-------------- board/davinci/sffsdr/sffsdr.c | 31 +++-------------- board/davinci/sonata/sonata.c | 35 +++++-------------- 6 files changed, 101 insertions(+), 105 deletions(-)
Best Regards, J.
Hi Jean-Christophe, Still no sign of it in the arm tree.
Hugo V.
Hugo Villeneuve
