[PATCH] smegw01: Fix inverted CONFIG_SYS_BOOT_LOCKED logic
CONFIG_SYS_BOOT_LOCKED means that a restricted boot environment will be used. In this case, hab_auth_img_or_fail should be called to prevent U-Boot to continue running when the fitImage authentication fails.
Fix the logic accordingly.
Additionally, select CONFIG_SYS_BOOT_LOCKED by default.
Signed-off-by: Eduard Strehlau eduard@lionizers.com Signed-off-by: Fabio Estevam festevam@denx.de --- Hi Tom,
We have just identified this bug.
Could you please pick this one directly for U-Boot 2023.10?
Thanks
board/storopack/smegw01/smegw01.env | 4 ++-- configs/smegw01_defconfig | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/storopack/smegw01/smegw01.env b/board/storopack/smegw01/smegw01.env index 528310dd81..93de866910 100644 --- a/board/storopack/smegw01/smegw01.env +++ b/board/storopack/smegw01/smegw01.env @@ -67,9 +67,9 @@ mmcboot= run altbootcmd; fi; #ifdef CONFIG_SYS_BOOT_LOCKED - hab_auth_img ${fileaddr} ${filesize}; -#else hab_auth_img_or_fail ${fileaddr} ${filesize}; +#else + hab_auth_img ${fileaddr} ${filesize}; #endif run mmcargs; if bootm; then diff --git a/configs/smegw01_defconfig b/configs/smegw01_defconfig index 616038387e..03d403ddc8 100644 --- a/configs/smegw01_defconfig +++ b/configs/smegw01_defconfig @@ -7,7 +7,7 @@ CONFIG_ENV_OFFSET=0x100000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx7d-smegw01" CONFIG_TARGET_SMEGW01=y -# CONFIG_SYS_BOOT_LOCKED is not set +CONFIG_SYS_BOOT_LOCKED=y CONFIG_ENV_OFFSET_REDUND=0x110000 CONFIG_ARMV7_BOOT_SEC_DEFAULT=y # CONFIG_ARMV7_VIRT is not set
Hi Tom,
OK.
Fabio Estevam
