[U-Boot] [PATCH 2/2] fix spelling of 'functions' in 2 places (was 'funtcions')
Signed-off-by: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com ---
arch/sandbox/cpu/state.c | 2 +- common/board_r.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/sandbox/cpu/state.c b/arch/sandbox/cpu/state.c index 07584486db..862a71ddce 100644 --- a/arch/sandbox/cpu/state.c +++ b/arch/sandbox/cpu/state.c @@ -153,7 +153,7 @@ int sandbox_read_state(struct sandbox_state *state, const char *fname) return ret; }
- /* Call all the state read funtcions */ + /* Call all the state read functions */ got_err = false; blob = state->state_fdt; io = ll_entry_start(struct sandbox_state_io, state_io); diff --git a/common/board_r.c b/common/board_r.c index 6349e86f71..482f506661 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -664,7 +664,7 @@ static int run_main_loop(void)
/* * Over time we hope to remove these functions with code fragments and - * stub funtcions, and instead call the relevant function directly. + * stub functions, and instead call the relevant function directly. * * We also hope to remove most of the driver-related init and do it if/when * the driver is later used.
Simon Goldschmidt
