[U-Boot] [PATCH 1/1] [rfc] usb: musb: some more Blackfin stuff
any thoughts on how to generalize this ?
Signed-off-by: Bryan Wu bryan.wu@analog.com Signed-off-by: Cliff Cai cliff.cai@analog.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/usb/musb/musb_hcd.c | 20 ++++++++++++++++++++ 1 files changed, 20 insertions(+), 0 deletions(-)
diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index 040ac8a..7fcf803 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -143,7 +143,11 @@ static void write_toggle(struct usb_device *dev, u8 ep, u8 dir_out)
if (dir_out) { if (!toggle) +#ifdef CONFIG_USB_BLACKFIN + writew(0, &musbr->txcsr); +#else writew(MUSB_TXCSR_CLRDATATOG, &musbr->txcsr); +#endif else { csr = readw(&musbr->txcsr); csr |= MUSB_TXCSR_H_WR_DATATOGGLE; @@ -153,7 +157,11 @@ static void write_toggle(struct usb_device *dev, u8 ep, u8 dir_out) } } else { if (!toggle) +#ifdef CONFIG_USB_BLACKFIN + writew(0, &musbr->rxcsr); +#else writew(MUSB_RXCSR_CLRDATATOG, &musbr->rxcsr); +#endif else { csr = readw(&musbr->rxcsr); csr |= MUSB_RXCSR_H_WR_DATATOGGLE; @@ -899,6 +907,13 @@ int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer,
dev->status = 0; dev->act_len = len; + +#ifdef CONFIG_USB_BLACKFIN + /* Set device address to USB_FADDR register */ + if (setup->request == USB_REQ_SET_ADDRESS) + writew(dev->devnum, &musbr->faddr); +#endif + return len; }
@@ -969,6 +984,11 @@ int submit_bulk_msg(struct usb_device *dev, unsigned long pipe, nextlen = ((len-txlen) < dev->epmaxpacketout[ep]) ? (len-txlen) : dev->epmaxpacketout[ep];
+#ifdef CONFIG_USB_BLACKFIN + /* Set the transfer data size */ + writew(nextlen, &musbr->txcount); +#endif + /* Write the data to the FIFO */ write_fifo(MUSB_BULK_EP, nextlen, (void *)(((u8 *)buffer) + txlen));
Mike Frysinger
