[PATCH v2 0/4] alist: Implement a pointer list / array of structs
This data structure provides a list of pointers / array of structures. I was planning to use it for the lmb restructure, to allow it to support any number of entries, but then I gave up on it.
There are quite a few places in U-Boot where such a list would be useful, since it supports growing the array.
The series includes a patch to convert an existing function to use this.
It adds a little under 300 bytes of code with Thumb2.
Example:
struct my_struct obj; struct my_struct *ptr = alist_add(&lst, &obj, struct my_struct);
// now ptr is in the list
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=371258&state=*
Changes in v2: - Fix 'typeee' typo - Make alist_get_ptr() take a const alist * - Make alist_add() take a struct rather than a pointer - Declare alist_expand_by() as static
Simon Glass (4): malloc: Support testing with realloc() lib: Handle a special case with str_to_list() alist: Add support for an allocated pointer list lib: Convert str_to_list() to use alist
common/dlmalloc.c | 4 + include/alist.h | 205 ++++++++++++++++++++++++++++++++++++++++++++++ lib/Makefile | 1 + lib/alist.c | 154 ++++++++++++++++++++++++++++++++++ lib/strto.c | 33 ++++---- test/lib/Makefile | 1 + test/lib/alist.c | 197 ++++++++++++++++++++++++++++++++++++++++++++ test/str_ut.c | 4 +- 8 files changed, 582 insertions(+), 17 deletions(-) create mode 100644 include/alist.h create mode 100644 lib/alist.c create mode 100644 test/lib/alist.c
At present in tests it is possible to cause an out-of-memory condition with malloc() but not realloc(). Add support to realloc() too, so code which uses that function can be tested.
(no changes since v1)
common/dlmalloc.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/common/dlmalloc.c b/common/dlmalloc.c index 9549c59f358..65b130fabcd 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -1758,6 +1758,10 @@ Void_t* rEALLOc_impl(oldmem, bytes) Void_t* oldmem; size_t bytes; panic("pre-reloc realloc() is not supported"); } #endif + if (CONFIG_IS_ENABLED(UNIT_TEST) && malloc_testing) { + if (--malloc_max_allocs < 0) + return NULL; + }
newp = oldp = mem2chunk(oldmem); newsize = oldsize = chunksize(oldp);
The current implementation can return an extra result at the end when the string ends with a space. Fix this by adding a special case.
lib/strto.c | 4 +++- test/str_ut.c | 4 +--- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/lib/strto.c b/lib/strto.c index 5157332d6c1..f83ac67c666 100644 --- a/lib/strto.c +++ b/lib/strto.c @@ -236,12 +236,14 @@ const char **str_to_list(const char *instr) return NULL;
/* count the number of space-separated strings */ - for (count = *str != '\0', p = str; *p; p++) { + for (count = 0, p = str; *p; p++) { if (*p == ' ') { count++; *p = '\0'; } } + if (p != str && p[-1]) + count++;
/* allocate the pointer array, allowing for a NULL terminator */ ptr = calloc(count + 1, sizeof(char *)); diff --git a/test/str_ut.c b/test/str_ut.c index 389779859a3..96e048975d8 100644 --- a/test/str_ut.c +++ b/test/str_ut.c @@ -342,9 +342,7 @@ static int test_str_to_list(struct unit_test_state *uts) ut_asserteq_str("space", ptr[3]); ut_assertnonnull(ptr[4]); ut_asserteq_str("", ptr[4]); - ut_assertnonnull(ptr[5]); - ut_asserteq_str("", ptr[5]); - ut_assertnull(ptr[6]); + ut_assertnull(ptr[5]); str_free_list(ptr); ut_assertok(ut_check_delta(start));
In various places it is useful to have an array of structures, but allow it to grow. In some cases we work around it by setting maximum number of entries, using a Kconfig option. In other places we use a linked list, which does not provide for random access and can complicate the code.
Introduce a new data structure, which is a variable-sized list of structs each of the same, pre-set size. It provides O(1) access and is reasonably efficient at expanding linearly, since it doubles in size when it runs out of space.
include/alist.h | 205 ++++++++++++++++++++++++++++++++++++++++++++++ lib/Makefile | 1 + lib/alist.c | 154 ++++++++++++++++++++++++++++++++++ test/lib/Makefile | 1 + test/lib/alist.c | 197 ++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 558 insertions(+) create mode 100644 include/alist.h create mode 100644 lib/alist.c create mode 100644 test/lib/alist.c
diff --git a/include/alist.h b/include/alist.h new file mode 100644 index 00000000000..4eda5b6befa --- /dev/null +++ b/include/alist.h @@ -0,0 +1,205 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Handles a contiguous list of pointers which be allocated and freed + * + * Copyright 2023 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#ifndef __ALIST_H +#define __ALIST_H + +#include <stdbool.h> +#include <linux/bitops.h> +#include <linux/types.h> + +/** + * struct alist - object list that can be allocated and freed + * + * Holds a list of objects, each of the same size. The object is typically a + * C struct. The array is alloced in memory can change in size. + * + * The list rememebers the size of the list, but has a separate count of how + * much space is allocated, This allows it increase in size in steps as more + * elements are added, which is more efficient that reallocating the list every + * time a single item is added + * + * Two types of access are provided: + * + * alist_get...(index) + * gets an existing element, if its index is less that size + * + * alist_ensure(index) + * address an existing element, or creates a new one if not present + * + * @data: object data of size `@obj_size * @alloc`. The list can grow as + * needed but never shrinks + * @obj_size: Size of each object in bytes + * @count: number of objects in array + * @alloc: allocated length of array, to which @count can grow + * @flags: flags for the alist (ALISTF_...) + */ +struct alist { + void *data; + u16 obj_size; + u16 count; + u16 alloc; + u16 flags; +}; + +/** + * enum alist_flags - Flags for the alist + * + * @ALIST_FAIL: true if any allocation has failed. Once this has happened, the + * alist is dead and cannot grow further + */ +enum alist_flags { + ALISTF_FAIL = BIT(0), +}; + +/** + * alist_has() - Check if an index is within the list range + * + * Checks if index is within the current alist count + * + * @lst: alist to check + * @index: Index to check + * Returns: true if value, else false + */ +static inline bool alist_has(struct alist *lst, uint index) +{ + return index < lst->count; +} + +/** + * alist_err() - Check if the alist is still valid + * + * @lst: List to check + * Return: false if OK, true if any previous allocation failed + */ +static inline bool alist_err(struct alist *lst) +{ + return lst->flags & ALISTF_FAIL; +} + +/** + * alist_get_ptr() - Get the value of a pointer + * + * @lst: alist to check + * @index: Index to read from + * Returns: pointer, if present, else NULL + */ +const void *alist_get_ptr(const struct alist *lst, uint index); + +/** + * alist_getd() - Get the value of a pointer directly, with no checking + * + * This must only be called on indexes for which alist_has() returns true + * + * @lst: alist to check + * @index: Index to read from + * Returns: pointer value (may be NULL) + */ +static inline const void *alist_getd(struct alist *lst, uint index) +{ + return lst->data + index * lst->obj_size; +} + +#define alist_get(_lst, _index, _struct) \ + ((const _struct *)alist_get_ptr(_lst, _index)) + +/** + * alist_ensure_ptr() - Ensure an object exists at a given index + * + * This provides read/write access to an array element. If it does not exist, + * it is allocated, reading for the caller to store the object into + * + * Allocates a object at the given index if needed + * + * @lst: alist to check + * @index: Index to address + * Returns: pointer where struct can be read/written, or NULL if out of memory + */ +void *alist_ensure_ptr(struct alist *lst, uint index); + +/** + * alist_ensure() - Address a struct, the correct object type + * + * Use as: + * struct my_struct *ptr = alist_ensure(&lst, 4, struct my_struct); + */ +#define alist_ensure(_lst, _index, _struct) \ + ((_struct *)alist_ensure_ptr(_lst, _index)) + +/** + * alist_add_ptr() - Ad a new object to the list + * + * @lst: alist to add to + * @obj: Pointer to object to copy in + * Returns: pointer to where the object was copied, or NULL if out of memory + */ +void *alist_add_ptr(struct alist *lst, void *obj); + +/** + * alist_add() - Used to add an object with the correct type + * + * Use as: + * struct my_struct obj; + * struct my_struct *ptr = alist_add(&lst, obj, struct my_struct); + */ +#define alist_add(_lst, _obj, _struct) \ + ((_struct *)alist_add_ptr(_lst, (_struct *)(_obj))) + +/** + * alist_init() - Set up a new object list + * + * Sets up a list of objects, initially empty + * + * @lst: alist to set up + * @obj_size: Size of each element in bytes + * @alloc_size: Number of items to allowed to start, before reallocation is + * needed (0 to start with no space) + * Return: true if OK, false if out of memory + */ +bool alist_init(struct alist *lst, uint obj_size, uint alloc_size); + +#define alist_init_struct(_lst, _struct) \ + alist_init(_lst, sizeof(_struct), 0) + +/** + * alist_uninit_move_ptr() - Return the allocated contents and uninit the alist + * + * This returns the alist data to the caller, so that the caller receives data + * that it can be sure will hang around. The caller is responsible for freeing + * the data. + * + * If the alist size is 0, this returns NULL + * + * The alist is uninited as part of this. + * + * The alist must be inited before this can be called. + * + * @alist: alist to uninit + * @countp: if non-NULL, returns the number of objects in the returned data + * (which is @alist->size) + * Return: data contents, allocated with malloc(), or NULL if the data could not + * be allocated, or the data size is 0 + */ +void *alist_uninit_move_ptr(struct alist *alist, size_t *countp); + +/** + * alist_uninit_move() - Typed version of alist_uninit_move_ptr() + */ +#define alist_uninit_move(_lst, _countp, _struct) \ + (_struct *)alist_uninit_move_ptr(_lst, _countp) + +/** + * alist_uninit() - Free any memory used by an alist + * + * The alist must be inited before this can be called. + * + * @alist: alist to uninit + */ +void alist_uninit(struct alist *alist); + +#endif /* __ALIST_H */ diff --git a/lib/Makefile b/lib/Makefile index e389ad014f8..81b503ab526 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -147,6 +147,7 @@ endif obj-$(CONFIG_$(SPL_)OID_REGISTRY) += oid_registry.o
obj-y += abuf.o +obj-y += alist.o obj-y += date.o obj-y += rtc-lib.o obj-$(CONFIG_LIB_ELF) += elf.o diff --git a/lib/alist.c b/lib/alist.c new file mode 100644 index 00000000000..237e68e1d21 --- /dev/null +++ b/lib/alist.c @@ -0,0 +1,154 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Handles a contiguous list of pointers which be allocated and freed + * + * Copyright 2023 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <alist.h> +#include <display_options.h> +#include <malloc.h> +#include <stdio.h> +#include <string.h> + +enum { + ALIST_INITIAL_SIZE = 4, /* default size of unsized list */ +}; + +bool alist_init(struct alist *lst, uint obj_size, uint start_size) +{ + /* Avoid realloc for the initial size to help malloc_simple */ + memset(lst, '\0', sizeof(struct alist)); + if (start_size) { + lst->data = calloc(obj_size, start_size); + if (!lst->data) { + lst->flags = ALISTF_FAIL; + return false; + } + lst->alloc = start_size; + } + lst->obj_size = obj_size; + + return true; +} + +void alist_uninit(struct alist *lst) +{ + free(lst->data); + + /* Clear fields to avoid any confusion */ + memset(lst, '\0', sizeof(struct alist)); +} + +/** + * alist_expand_to() - Expand a list to the given size + * + * @lst: List to modify + * @inc_by: Amount to expand to + * Return: true if OK, false if out of memory + */ +static bool alist_expand_to(struct alist *lst, uint new_alloc) +{ + void *new_data; + + if (lst->flags & ALISTF_FAIL) + return false; + new_data = realloc(lst->data, lst->obj_size * new_alloc); + if (!new_data) { + lst->flags |= ALISTF_FAIL; + return false; + } + memset(new_data + lst->obj_size * lst->alloc, '\0', + lst->obj_size * (new_alloc - lst->alloc)); + lst->alloc = new_alloc; + lst->data = new_data; + + return true; +} + +/** + * alist_expand_by() - Expand a list by the given amount + * + * @lst: alist to expand + * @inc_by: Amount to expand by + * Return: true if OK, false if out of memory + */ +static bool alist_expand_by(struct alist *lst, uint inc_by) +{ + return alist_expand_to(lst, lst->alloc + inc_by); +} + +/** + * alist_expand_min() - Expand to at least the provided size + * + * Expands to the lowest power of two which can incorporate the new size + * + * @lst: alist to expand + * @min_alloc: Minimum new allocated size; if 0 then ALIST_INITIAL_SIZE is used + * Return: true if OK, false if out of memory + */ +static bool alist_expand_min(struct alist *lst, uint min_alloc) +{ + uint new_alloc; + + for (new_alloc = lst->alloc ?: ALIST_INITIAL_SIZE; + new_alloc < min_alloc;) + new_alloc *= 2; + + return alist_expand_to(lst, new_alloc); +} + +const void *alist_get_ptr(const struct alist *lst, uint index) +{ + if (index >= lst->count) + return NULL; + + return lst->data + index * lst->obj_size; +} + +void *alist_ensure_ptr(struct alist *lst, uint index) +{ + uint minsize = index + 1; + void *ptr; + + if (index >= lst->alloc && !alist_expand_min(lst, minsize)) + return NULL; + + ptr = lst->data + index * lst->obj_size; + if (minsize >= lst->count) + lst->count = minsize; + + return ptr; +} + +void *alist_add_ptr(struct alist *lst, void *obj) +{ + void *ptr; + + ptr = alist_ensure_ptr(lst, lst->count); + if (!ptr) + return ptr; + memcpy(ptr, obj, lst->obj_size); + + return ptr; +} + +void *alist_uninit_move_ptr(struct alist *alist, size_t *countp) +{ + void *ptr; + + if (countp) + *countp = alist->count; + if (!alist->count) { + alist_uninit(alist); + return NULL; + } + + ptr = alist->data; + + /* Clear everything out so there is no record of the data */ + alist_init(alist, alist->obj_size, 0); + + return ptr; +} diff --git a/test/lib/Makefile b/test/lib/Makefile index e75a263e6a4..70f14c46b1e 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -5,6 +5,7 @@ ifeq ($(CONFIG_SPL_BUILD),) obj-y += cmd_ut_lib.o obj-y += abuf.o +obj-y += alist.o obj-$(CONFIG_EFI_LOADER) += efi_device_path.o obj-$(CONFIG_EFI_SECURE_BOOT) += efi_image_region.o obj-y += hexdump.o diff --git a/test/lib/alist.c b/test/lib/alist.c new file mode 100644 index 00000000000..f9050a963e0 --- /dev/null +++ b/test/lib/alist.c @@ -0,0 +1,197 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2023 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <alist.h> +#include <string.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> + +struct my_struct { + uint val; + uint other_val; +}; + +enum { + obj_size = sizeof(struct my_struct), +}; + +/* Test alist_init() */ +static int lib_test_alist_init(struct unit_test_state *uts) +{ + struct alist lst; + ulong start; + + start = ut_check_free(); + + /* with a size of 0, the fields should be inited, with no memory used */ + memset(&lst, '\xff', sizeof(lst)); + ut_assert(alist_init_struct(&lst, struct my_struct)); + ut_asserteq_ptr(NULL, lst.data); + ut_asserteq(0, lst.count); + ut_asserteq(0, lst.alloc); + ut_assertok(ut_check_delta(start)); + alist_uninit(&lst); + ut_asserteq_ptr(NULL, lst.data); + ut_asserteq(0, lst.count); + ut_asserteq(0, lst.alloc); + + /* use an impossible size */ + ut_asserteq(false, alist_init(&lst, obj_size, + CONFIG_SYS_MALLOC_LEN)); + ut_assertnull(lst.data); + ut_asserteq(0, lst.count); + ut_asserteq(0, lst.alloc); + + /* use a small size */ + ut_assert(alist_init(&lst, obj_size, 4)); + ut_assertnonnull(lst.data); + ut_asserteq(0, lst.count); + ut_asserteq(4, lst.alloc); + + /* free it */ + alist_uninit(&lst); + ut_asserteq_ptr(NULL, lst.data); + ut_asserteq(0, lst.count); + ut_asserteq(0, lst.alloc); + ut_assertok(ut_check_delta(start)); + + /* Check for memory leaks */ + ut_assertok(ut_check_delta(start)); + + return 0; +} +LIB_TEST(lib_test_alist_init, 0); + +/* Test alist_get() and alist_getd() */ +static int lib_test_alist_get(struct unit_test_state *uts) +{ + struct alist lst; + ulong start; + void *ptr; + + start = ut_check_free(); + + ut_assert(alist_init(&lst, obj_size, 3)); + ut_asserteq(0, lst.count); + ut_asserteq(3, lst.alloc); + + ut_assertnull(alist_get_ptr(&lst, 2)); + ut_assertnull(alist_get_ptr(&lst, 3)); + + ptr = alist_ensure_ptr(&lst, 1); + ut_assertnonnull(ptr); + ut_asserteq(2, lst.count); + ptr = alist_ensure_ptr(&lst, 2); + ut_asserteq(3, lst.count); + ut_assertnonnull(ptr); + + ptr = alist_ensure_ptr(&lst, 3); + ut_assertnonnull(ptr); + ut_asserteq(4, lst.count); + ut_asserteq(6, lst.alloc); + + ut_assertnull(alist_get_ptr(&lst, 4)); + + alist_uninit(&lst); + + /* Check for memory leaks */ + ut_assertok(ut_check_delta(start)); + + return 0; +} +LIB_TEST(lib_test_alist_get, 0); + +/* Test alist_has() */ +static int lib_test_alist_has(struct unit_test_state *uts) +{ + struct alist lst; + ulong start; + void *ptr; + + start = ut_check_free(); + + ut_assert(alist_init(&lst, obj_size, 3)); + + ut_assert(!alist_has(&lst, 0)); + ut_assert(!alist_has(&lst, 1)); + ut_assert(!alist_has(&lst, 2)); + ut_assert(!alist_has(&lst, 3)); + + /* create a new one to force expansion */ + ptr = alist_ensure_ptr(&lst, 4); + ut_assertnonnull(ptr); + + ut_assert(alist_has(&lst, 0)); + ut_assert(alist_has(&lst, 1)); + ut_assert(alist_has(&lst, 2)); + ut_assert(alist_has(&lst, 3)); + ut_assert(alist_has(&lst, 4)); + ut_assert(!alist_has(&lst, 5)); + + alist_uninit(&lst); + + /* Check for memory leaks */ + ut_assertok(ut_check_delta(start)); + + return 0; +} +LIB_TEST(lib_test_alist_has, 0); + +/* Test alist_ensure() */ +static int lib_test_alist_ensure(struct unit_test_state *uts) +{ + struct my_struct *ptr3, *ptr4; + struct alist lst; + ulong start; + + start = ut_check_free(); + + ut_assert(alist_init_struct(&lst, struct my_struct)); + ut_asserteq(obj_size, lst.obj_size); + ut_asserteq(0, lst.count); + ut_asserteq(0, lst.alloc); + ptr3 = alist_ensure_ptr(&lst, 3); + ut_asserteq(4, lst.count); + ut_asserteq(4, lst.alloc); + ut_assertnonnull(ptr3); + ptr3->val = 3; + + ptr4 = alist_ensure_ptr(&lst, 4); + ut_asserteq(8, lst.alloc); + ut_asserteq(5, lst.count); + ut_assertnonnull(ptr4); + ptr4->val = 4; + ut_asserteq(4, alist_get(&lst, 4, struct my_struct)->val); + + ut_asserteq_ptr(ptr4, alist_ensure(&lst, 4, struct my_struct)); + + alist_ensure(&lst, 4, struct my_struct)->val = 44; + ut_asserteq(44, alist_get(&lst, 4, struct my_struct)->val); + ut_asserteq(3, alist_get(&lst, 3, struct my_struct)->val); + ut_assertnull(alist_get(&lst, 7, struct my_struct)); + ut_asserteq(8, lst.alloc); + ut_asserteq(5, lst.count); + + /* add some more, checking handling of malloc() failure */ + malloc_enable_testing(0); + ut_assertnonnull(alist_ensure(&lst, 7, struct my_struct)); + ut_assertnull(alist_ensure(&lst, 8, struct my_struct)); + malloc_disable_testing(); + + lst.flags &= ~ALISTF_FAIL; + ut_assertnonnull(alist_ensure(&lst, 8, struct my_struct)); + ut_asserteq(16, lst.alloc); + ut_asserteq(9, lst.count); + + alist_uninit(&lst); + + /* Check for memory leaks */ + ut_assertok(ut_check_delta(start)); + + return 0; +} +LIB_TEST(lib_test_alist_ensure, 0);
Use this new data structure in the utility function.
lib/strto.c | 35 +++++++++++++++++++---------------- 1 file changed, 19 insertions(+), 16 deletions(-)
diff --git a/lib/strto.c b/lib/strto.c index f83ac67c666..f059408755a 100644 --- a/lib/strto.c +++ b/lib/strto.c @@ -9,6 +9,7 @@ * Wirzenius wrote this portably, Torvalds fucked it up :-) */
+#include <alist.h> #include <errno.h> #include <malloc.h> #include <vsprintf.h> @@ -226,37 +227,39 @@ void str_to_upper(const char *in, char *out, size_t len)
const char **str_to_list(const char *instr) { - const char **ptr; - char *str, *p; - int count, i; + struct alist alist; + char *str, *p, *start;
/* don't allocate if the string is empty */ str = *instr ? strdup(instr) : (char *)instr; if (!str) return NULL;
- /* count the number of space-separated strings */ - for (count = 0, p = str; *p; p++) { + alist_init_struct(&alist, char *); + + if (*str) + alist_add(&alist, &str, char *); + for (start = str, p = str; *p; p++) { if (*p == ' ') { - count++; *p = '\0'; + start = p + 1; + if (*start) + alist_add(&alist, &start, char *); } } - if (p != str && p[-1]) - count++;
- /* allocate the pointer array, allowing for a NULL terminator */ - ptr = calloc(count + 1, sizeof(char *)); - if (!ptr) { - if (*str) + /* terminate list */ + p = NULL; + alist_add(&alist, &p, char *); + if (alist_err(&alist)) { + alist_uninit(&alist); + + if (*instr) free(str); return NULL; }
- for (i = 0, p = str; i < count; p += strlen(p) + 1, i++) - ptr[i] = p; - - return ptr; + return alist_uninit_move(&alist, NULL, const char *); }
void str_free_list(const char **ptr)
