[U-Boot] [PATCH] cmd_mmc: add support device command for selecting mmc device
This patch improves device command for selecting mmc device
Signed-off-by: Minkyu Kang mk7.kang@samsung.com --- common/cmd_mmc.c | 69 ++++++++++++++++++++++++++++++++++++++++++++++++++---- 1 files changed, 64 insertions(+), 5 deletions(-)
diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index 16c919b..2557892 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -26,20 +26,79 @@ #include <mmc.h>
#ifndef CONFIG_GENERIC_MMC +int curr_device = -1; + int do_mmc (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { - if (mmc_legacy_init (1) != 0) { - printf ("No MMC card found\n"); + switch (argc) { + case 0: + case 1: + cmd_usage(cmdtp); + return 1; + case 2: + if (strncmp(argv[1], "init", 4) == 0) { + if (curr_device < 0) + curr_device = 1; + + if (mmc_legacy_init(curr_device) != 0) { + printf("No MMC card found\n"); + return 1; + } + + printf("mmc%d is available\n", curr_device); + return 0; + } else if (strncmp(argv[1], "dev", 3) == 0) { + if (curr_device < 0) { + printf("no MMC devices available\n"); + return 1; + } + + printf("mmc%d is current device\n", curr_device); + return 0; + } + + cmd_usage(cmdtp); + return 1; + case 3: + if (strncmp(argv[1], "init", 4) == 0) { + int dev = (int)simple_strtoul(argv[2], NULL, 10); + + if (mmc_legacy_init(dev) != 0) { + printf("No MMC card found\n"); + return 1; + } + + curr_device = dev; + + printf("mmc%d is available\n", curr_device); + return 0; + } else if (strncmp(argv[1], "dev", 3) == 0) { + int dev = (int)simple_strtoul(argv[2], NULL, 10); + +#ifdef CONFIG_SYS_MMC_SET_DEV + if (mmc_set_dev(dev) != 0) + return 1; +#endif + + curr_device = dev; + + printf("mmc%d is now current device\n", curr_device); + return 0; + } + + cmd_usage(cmdtp); return 1; } return 0; }
U_BOOT_CMD( - mmcinit, 1, 0, do_mmc, - "init mmc card", - NULL + mmc, 3, 1, do_mmc, + "MMC sub-system", + "mmc init [dev] - init MMC sub system\n" + "mmc device [dev] - show or set current device\n" ); + #else /* !CONFIG_GENERIC_MMC */
We should add Andy to CC, as it seems that he is the new MMC maintainer :)
Andy: Would be quite nice if you could comment on Minkyu's changes. See [1], [2] and [3] for the history, too.
Dirk
[1] http://lists.denx.de/pipermail/u-boot/2009-March/049660.html
[2] http://lists.denx.de/pipermail/u-boot/2009-March/049694.html
[3] http://lists.denx.de/pipermail/u-boot/2009-March/049707.html
- switch (argc) {
- case 0:
- case 1:
cmd_usage(cmdtp);
return 1;
- case 2:
curr_device = 1;
return 1;
return 1;
cmd_usage(cmdtp);
return 1;
- case 3:
return 1;
curr_device = dev;
return 1;
curr_device = dev;
return 1; } return 0;cmd_usage(cmdtp);
U_BOOT_CMD(
- "init mmc card",
- NULL
- mmc, 3, 1, do_mmc,
- "MMC sub-system",
- "mmc init [dev] - init MMC sub system\n"
- "mmc device [dev] - show or set current device\n"
On Saturday 28 March 2009 01:04:10 Minkyu Kang wrote:
- case 2:
why strncmp ? i dont think it makes sense to support "init", "init.moo" "initaksldfjaksldfjasdf" ...
no format modifiers -> use puts()
puts("No MMC card selected\n");
- case 3:
considering how much code is duplicated with "case 2", seems like it would make sense to unify them and have each piece check the argc
U_BOOT_CMD(
- "init mmc card",
- NULL
- "MMC sub-system",
first usage string should omit the command. run 'help mmc' on the board to see why ... -mike
Rather than porting features from the generic mmc framework into the legacy system, I'd really prefer if the omap driver were ported to the generic mmc framework. The framework already has support for multiple devices. We can then discuss how to deal with selecting which device is the default device as a side issue.
Andy
Andy Fleming
Dirk Behme
Mike Frysinger
Minkyu Kang
