[U-Boot] [PATCH v2 1/1] efi_selftest: don't hang on missing timer
qemu-riscv32_defconfig and qemu-riscv64_defconfig do not supply a timer. This causes the EFI selftest to hang on tests which require a timer.
So let's disable CONFIG_TIMER for these boards and use this variable to decide which tests have to be disabled.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: add missing obj-y += \ --- configs/qemu-riscv32_defconfig | 1 + configs/qemu-riscv64_defconfig | 1 + lib/efi_selftest/Makefile | 10 +++++++--- 3 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/configs/qemu-riscv32_defconfig b/configs/qemu-riscv32_defconfig index ff1fb1f30ec..70da323bdc1 100644 --- a/configs/qemu-riscv32_defconfig +++ b/configs/qemu-riscv32_defconfig @@ -3,4 +3,5 @@ CONFIG_TARGET_QEMU_VIRT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y +# CONFIG_TIMER is not set CONFIG_OF_BOARD=y diff --git a/configs/qemu-riscv64_defconfig b/configs/qemu-riscv64_defconfig index d6c1a5d646a..258f395b9d5 100644 --- a/configs/qemu-riscv64_defconfig +++ b/configs/qemu-riscv64_defconfig @@ -4,4 +4,5 @@ CONFIG_CPU_RISCV_64=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y +# CONFIG_TIMER is not set CONFIG_OF_BOARD=y diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 4b1c0bb84b1..aec498fbcf2 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -19,7 +19,6 @@ efi_selftest_console.o \ efi_selftest_crc32.o \ efi_selftest_devicepath.o \ efi_selftest_devicepath_util.o \ -efi_selftest_events.o \ efi_selftest_event_groups.o \ efi_selftest_exception.o \ efi_selftest_exitbootservices.o \ @@ -32,11 +31,16 @@ efi_selftest_snp.o \ efi_selftest_textinput.o \ efi_selftest_textinputex.o \ efi_selftest_textoutput.o \ -efi_selftest_tpl.o \ efi_selftest_unicode_collation.o \ efi_selftest_util.o \ -efi_selftest_variables.o \ +efi_selftest_variables.o + +ifeq ($(CONFIG_TIMER),) +obj-y += \ +efi_selftest_events.o \ +efi_selftest_tpl.o \ efi_selftest_watchdog.o +endif
obj-$(CONFIG_CPU_V7) += efi_selftest_unaligned.o
Travis is quite unhappy about this:
riscv: +qemu-riscv64qemu-riscv32 +lib/built-in.o: In function `tick_to_time': +lib/time.c:119: undefined reference to `get_tbclk' +lib/built-in.o: In function `usec_to_tick': +lib/time.c:145: undefined reference to `get_tbclk' +common/built-in.o: In function `cread_add_str': +common/cli_readline.c:239: undefined reference to `get_tbclk'
Wouldn't it make more sense to just enable timer support for the qemu riscv models instead?
I'll remove the patch from my queue for the time being.
Alex
Alex
I think it makes sense to keep timer support for the RISC-V QEMU targets enabled. Bin's patch series [1] adds timer support for the RISC-V QEMU targets, so EFI selftest will not be broken for long.
Lukas
[1]: https://patchwork.ozlabs.org/project/uboot/list/?series=75644
diff --git a/configs/qemu-riscv32_defconfig b/configs/qemu- riscv32_defconfig index ff1fb1f30ec..70da323bdc1 100644 --- a/configs/qemu-riscv32_defconfig +++ b/configs/qemu-riscv32_defconfig @@ -3,4 +3,5 @@ CONFIG_TARGET_QEMU_VIRT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y +# CONFIG_TIMER is not set CONFIG_OF_BOARD=y diff --git a/configs/qemu-riscv64_defconfig b/configs/qemu- riscv64_defconfig index d6c1a5d646a..258f395b9d5 100644 --- a/configs/qemu-riscv64_defconfig +++ b/configs/qemu-riscv64_defconfig @@ -4,4 +4,5 @@ CONFIG_CPU_RISCV_64=y CONFIG_NR_DRAM_BANKS=1 CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y +# CONFIG_TIMER is not set CONFIG_OF_BOARD=y diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 4b1c0bb84b1..aec498fbcf2 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -19,7 +19,6 @@ efi_selftest_console.o \ efi_selftest_crc32.o \ efi_selftest_devicepath.o \ efi_selftest_devicepath_util.o \ -efi_selftest_events.o \ efi_selftest_event_groups.o \ efi_selftest_exception.o \ efi_selftest_exitbootservices.o \ @@ -32,11 +31,16 @@ efi_selftest_snp.o \ efi_selftest_textinput.o \ efi_selftest_textinputex.o \ efi_selftest_textoutput.o \ -efi_selftest_tpl.o \ efi_selftest_unicode_collation.o \ efi_selftest_util.o \ -efi_selftest_variables.o \ +efi_selftest_variables.o
Alexander Graf
Auer, Lukas
