[PATCH v2 0/4] mtd: rawnand: brcmnand: Add BCMBCA support
This adds support for the NAND controller on the Broadcom BCA (Broadband Access) platforms.
This requires the series with brcmnand fixes that I sent separately to be merged first. See: https://patchwork.ozlabs.org/project/uboot/list/?series=424109
The development was done on the Genexis XG6846B which is a derivative of the BCM96846 reference design, but probably has a different flash layout, be sure to check the last patch in the series for a comment on that.
Signed-off-by: Linus Walleij linus.walleij@linaro.org --- Changes in v2: - Switch to using OF_UPSTREAM instead of syncing DTS files. - Mention the Linux version the BCMBCA NAND driver is based on. - Link to v1: https://lore.kernel.org/r/20240930-bcmbca-nand-support-v1-0-e637c65de947@lin...
--- Linus Walleij (4): mtd: rawnand: brcmnand: Add BCMBCA RAW NAND driver drivers: nand: bcmbca: Enable on BCM6846 board: bcm96846: Enable NAND options board: bcm96846: Switch to using OF_UPSTREAM
arch/arm/dts/bcm6846.dtsi | 103 ------------------- arch/arm/dts/bcm96846.dts | 30 ------ arch/arm/mach-bcmbca/bcm6846/Kconfig | 4 + configs/bcm96846_defconfig | 15 ++- drivers/mtd/nand/raw/Kconfig | 7 ++ drivers/mtd/nand/raw/brcmnand/Makefile | 1 + drivers/mtd/nand/raw/brcmnand/bcmbca_nand.c | 152 ++++++++++++++++++++++++++++ 7 files changed, 178 insertions(+), 134 deletions(-) --- base-commit: a404065479be2c1fe1167c3c91367e8194a69d1b change-id: 20240930-bcmbca-nand-support-4447e176bbbd
The Broadcom BCA platforms are broadband access SoCs. This is a port of the upstream Linux driver to U-Boot. It was based on drivers/mtd/nand/raw/brcmnand/bcmbca_nand.c from Linux v6.11.
Reviewed-by: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Linus Walleij linus.walleij@linaro.org --- drivers/mtd/nand/raw/Kconfig | 7 ++ drivers/mtd/nand/raw/brcmnand/Makefile | 1 + drivers/mtd/nand/raw/brcmnand/bcmbca_nand.c | 152 ++++++++++++++++++++++++++++ 3 files changed, 160 insertions(+)
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 9f3f1267cbd1..c345fc1f1fba 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -120,6 +120,13 @@ config NAND_BRCMNAND Enable the driver for NAND flash on platforms using a Broadcom NAND controller.
+config NAND_BRCMNAND_BCMBCA + bool "Support Broadcom NAND controller on BCMBCA platforms" + depends on NAND_BRCMNAND && ARCH_BCMBCA + help + Enable support for broadcom nand driver on BCA (broadband + access) platforms such as BCM6846. + config NAND_BRCMNAND_6368 bool "Support Broadcom NAND controller on bcm6368" depends on NAND_BRCMNAND && ARCH_BMIPS diff --git a/drivers/mtd/nand/raw/brcmnand/Makefile b/drivers/mtd/nand/raw/brcmnand/Makefile index 0c6325aaa618..24d0d5684490 100644 --- a/drivers/mtd/nand/raw/brcmnand/Makefile +++ b/drivers/mtd/nand/raw/brcmnand/Makefile @@ -6,6 +6,7 @@ obj-$(CONFIG_NAND_BRCMNAND_6753) += bcm6753_nand.o obj-$(CONFIG_NAND_BRCMNAND_68360) += bcm68360_nand.o obj-$(CONFIG_NAND_BRCMNAND_6838) += bcm6838_nand.o obj-$(CONFIG_NAND_BRCMNAND_6858) += bcm6858_nand.o +obj-$(CONFIG_NAND_BRCMNAND_BCMBCA) += bcmbca_nand.o obj-$(CONFIG_NAND_BRCMNAND_IPROC) += iproc_nand.o obj-$(CONFIG_NAND_BRCMNAND) += brcmnand.o obj-$(CONFIG_NAND_BRCMNAND) += brcmnand_compat.o diff --git a/drivers/mtd/nand/raw/brcmnand/bcmbca_nand.c b/drivers/mtd/nand/raw/brcmnand/bcmbca_nand.c new file mode 100644 index 000000000000..2753783ae70f --- /dev/null +++ b/drivers/mtd/nand/raw/brcmnand/bcmbca_nand.c @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <asm/io.h> +#include <memalign.h> +#include <nand.h> +#include <linux/bitops.h> +#include <linux/err.h> +#include <linux/errno.h> +#include <linux/io.h> +#include <linux/ioport.h> +#include <dm.h> +#include <linux/printk.h> + +#include "brcmnand.h" + +struct bcmbca_nand_soc { + struct brcmnand_soc soc; + void __iomem *base; +}; + +#define BCMBCA_NAND_INT 0x00 +#define BCMBCA_NAND_STATUS_SHIFT 0 +#define BCMBCA_NAND_STATUS_MASK (0xfff << BCMBCA_NAND_STATUS_SHIFT) + +#define BCMBCA_NAND_INT_EN 0x04 +#define BCMBCA_NAND_ENABLE_SHIFT 0 +#define BCMBCA_NAND_ENABLE_MASK (0xffff << BCMBCA_NAND_ENABLE_SHIFT) + +enum { + BCMBCA_NP_READ = BIT(0), + BCMBCA_BLOCK_ERASE = BIT(1), + BCMBCA_COPY_BACK = BIT(2), + BCMBCA_PAGE_PGM = BIT(3), + BCMBCA_CTRL_READY = BIT(4), + BCMBCA_DEV_RBPIN = BIT(5), + BCMBCA_ECC_ERR_UNC = BIT(6), + BCMBCA_ECC_ERR_CORR = BIT(7), +}; + +#if defined(CONFIG_ARM64) +#define ALIGN_REQ 8 +#else +#define ALIGN_REQ 4 +#endif + +static inline bool bcmbca_nand_is_buf_aligned(void *flash_cache, void *buffer) +{ + return IS_ALIGNED((uintptr_t)buffer, ALIGN_REQ) && + IS_ALIGNED((uintptr_t)flash_cache, ALIGN_REQ); +} + +static bool bcmbca_nand_intc_ack(struct brcmnand_soc *soc) +{ + struct bcmbca_nand_soc *priv = + container_of(soc, struct bcmbca_nand_soc, soc); + void __iomem *mmio = priv->base + BCMBCA_NAND_INT; + u32 val = brcmnand_readl(mmio); + + if (val & (BCMBCA_CTRL_READY << BCMBCA_NAND_STATUS_SHIFT)) { + /* Ack interrupt */ + val &= ~BCMBCA_NAND_STATUS_MASK; + val |= BCMBCA_CTRL_READY << BCMBCA_NAND_STATUS_SHIFT; + brcmnand_writel(val, mmio); + return true; + } + + return false; +} + +static void bcmbca_nand_intc_set(struct brcmnand_soc *soc, bool en) +{ + struct bcmbca_nand_soc *priv = + container_of(soc, struct bcmbca_nand_soc, soc); + void __iomem *mmio = priv->base + BCMBCA_NAND_INT_EN; + u32 val = brcmnand_readl(mmio); + + /* Don't ack any interrupts */ + val &= ~BCMBCA_NAND_STATUS_MASK; + + if (en) + val |= BCMBCA_CTRL_READY << BCMBCA_NAND_ENABLE_SHIFT; + else + val &= ~(BCMBCA_CTRL_READY << BCMBCA_NAND_ENABLE_SHIFT); + + brcmnand_writel(val, mmio); +} + +static void bcmbca_read_data_bus(struct brcmnand_soc *soc, + void __iomem *flash_cache, u32 *buffer, int fc_words) +{ + /* + * memcpy can do unaligned aligned access depending on source + * and dest address, which is incompatible with nand cache. Fallback + * to the memcpy_fromio in such case + */ + if (bcmbca_nand_is_buf_aligned((void __force *)flash_cache, buffer)) + memcpy((void *)buffer, (void __force *)flash_cache, fc_words * 4); + else + memcpy_fromio((void *)buffer, flash_cache, fc_words * 4); +} + +static int bcmbca_nand_probe(struct udevice *dev) +{ + struct udevice *pdev = dev; + struct bcmbca_nand_soc *priv = dev_get_priv(dev); + struct brcmnand_soc *soc; + struct resource res; + + soc = &priv->soc; + + dev_read_resource_byname(pdev, "nand-int-base", &res); + priv->base = devm_ioremap(dev, res.start, resource_size(&res)); + if (IS_ERR(priv->base)) + return PTR_ERR(priv->base); + + soc->ctlrdy_ack = bcmbca_nand_intc_ack; + soc->ctlrdy_set_enabled = bcmbca_nand_intc_set; + soc->read_data_bus = bcmbca_read_data_bus; + + /* Disable and ack all interrupts */ + brcmnand_writel(0, priv->base + BCMBCA_NAND_INT_EN); + brcmnand_writel(0, priv->base + BCMBCA_NAND_INT); + + return brcmnand_probe(pdev, soc); +} + +static const struct udevice_id bcmbca_nand_dt_ids[] = { + { + .compatible = "brcm,nand-bcm63138", + }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(bcmbca_nand) = { + .name = "bcmbca-nand", + .id = UCLASS_MTD, + .of_match = bcmbca_nand_dt_ids, + .probe = bcmbca_nand_probe, + .priv_auto = sizeof(struct bcmbca_nand_soc), +}; + +void board_nand_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MTD, + DM_DRIVER_GET(bcmbca_nand), &dev); + if (ret && ret != -ENODEV) + pr_err("Failed to initialize %s. (error %d)\n", dev->name, + ret); +}
The BCM6846 has the BRCMBCA NAND controller so enable it.
Reviewed-by: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Linus Walleij linus.walleij@linaro.org --- arch/arm/mach-bcmbca/bcm6846/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-bcmbca/bcm6846/Kconfig b/arch/arm/mach-bcmbca/bcm6846/Kconfig index 229ab88dbb0d..5ef9535369ec 100644 --- a/arch/arm/mach-bcmbca/bcm6846/Kconfig +++ b/arch/arm/mach-bcmbca/bcm6846/Kconfig @@ -8,6 +8,9 @@ if BCM6846 config TARGET_BCM96846 bool "Broadcom 6846 Reference Board" depends on ARCH_BCMBCA + imply MTD_RAW_NAND + imply NAND_BRCMNAND + imply NAND_BRCMNAND_BCMBCA
config SYS_SOC default "bcm6846"
This adds reasonable NAND options to the BCM96846 reference design:
- CMD_NAND, MTD_RAW_NAND - Disable SYS_NAND_ONFI_DETECTION as this just give error messages - MTD, MTDPARTS with DM and related config options - CMD_UBI and CMD_UBIFS as this is likely used with ubi/ubifs
What I didn't add was something like the following:
CONFIG_MTDPARTS_DEFAULT="nand0:256k(cfi),257024k(image)"
Because I don't actually have a BCM96846 reference design. These are only available to Broadcom and their customers I think, but perhaps the people at Broadcom can provide the detail of the flash layout for BCM96846 so we can add this too so the bcm96846_config is usable out of the box.
Signed-off-by: Linus Walleij linus.walleij@linaro.org --- configs/bcm96846_defconfig | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/configs/bcm96846_defconfig b/configs/bcm96846_defconfig index ea643eddcc66..2f94bd295122 100644 --- a/configs/bcm96846_defconfig +++ b/configs/bcm96846_defconfig @@ -18,5 +18,17 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CACHE=y +CONFIG_CMD_NAND=y +CONFIG_CMD_UBI=y +CONFIG_CMD_UBIFS=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_MTDPARTS=y CONFIG_OF_EMBED=y CONFIG_CLK=y +CONFIG_MTD=y +CONFIG_MTDIDS_DEFAULT="nand0=nand0" +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_MTD_UBI_FASTMAP=y +CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 +CONFIG_SYS_NAND_ONFI_DETECTION=n
This board clearly develops first in Linux which had more hardware listed, so let's start to use OF_UPSTREAM. This makes the NAND driver work.
Suggested-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Linus Walleij linus.walleij@linaro.org --- arch/arm/dts/bcm6846.dtsi | 103 ----------------------------------- arch/arm/dts/bcm96846.dts | 30 ---------- arch/arm/mach-bcmbca/bcm6846/Kconfig | 1 + configs/bcm96846_defconfig | 3 +- 4 files changed, 3 insertions(+), 134 deletions(-)
diff --git a/arch/arm/dts/bcm6846.dtsi b/arch/arm/dts/bcm6846.dtsi deleted file mode 100644 index 8aa47a2583b2..000000000000 --- a/arch/arm/dts/bcm6846.dtsi +++ /dev/null @@ -1,103 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - compatible = "brcm,bcm6846", "brcm,bcmbca"; - #address-cells = <1>; - #size-cells = <1>; - - interrupt-parent = <&gic>; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - CA7_0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - CA7_1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a7"; - reg = <0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - }; - }; - - timer { - compatible = "arm,armv7-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; - arm,cpu-registers-not-fw-configured; - }; - - pmu: pmu { - compatible = "arm,cortex-a7-pmu"; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&CA7_0>, <&CA7_1>; - }; - - clocks: clocks { - periph_clk: periph-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - }; - }; - - psci { - compatible = "arm,psci-0.2"; - method = "smc"; - }; - - axi@81000000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x81000000 0x8000>; - - gic: interrupt-controller@1000 { - compatible = "arm,cortex-a7-gic"; - #interrupt-cells = <3>; - interrupt-controller; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; - reg = <0x1000 0x1000>, - <0x2000 0x2000>, - <0x4000 0x2000>, - <0x6000 0x2000>; - }; - }; - - bus@ff800000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0xff800000 0x800000>; - - uart0: serial@640 { - compatible = "brcm,bcm6345-uart"; - reg = <0x640 0x1b>; - interrupts = <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&periph_clk>; - clock-names = "refclk"; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/bcm96846.dts b/arch/arm/dts/bcm96846.dts deleted file mode 100644 index c70ebccabc19..000000000000 --- a/arch/arm/dts/bcm96846.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 Broadcom Ltd. - */ - -/dts-v1/; - -#include "bcm6846.dtsi" - -/ { - model = "Broadcom BCM96846 Reference Board"; - compatible = "brcm,bcm96846", "brcm,bcm6846", "brcm,bcmbca"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x08000000>; - }; -}; - -&uart0 { - status = "okay"; -}; diff --git a/arch/arm/mach-bcmbca/bcm6846/Kconfig b/arch/arm/mach-bcmbca/bcm6846/Kconfig index 5ef9535369ec..1f5639f46dfb 100644 --- a/arch/arm/mach-bcmbca/bcm6846/Kconfig +++ b/arch/arm/mach-bcmbca/bcm6846/Kconfig @@ -8,6 +8,7 @@ if BCM6846 config TARGET_BCM96846 bool "Broadcom 6846 Reference Board" depends on ARCH_BCMBCA + imply OF_UPSTREAM imply MTD_RAW_NAND imply NAND_BRCMNAND imply NAND_BRCMNAND_BCMBCA diff --git a/configs/bcm96846_defconfig b/configs/bcm96846_defconfig index 2f94bd295122..877a606a9651 100644 --- a/configs/bcm96846_defconfig +++ b/configs/bcm96846_defconfig @@ -9,11 +9,12 @@ CONFIG_TARGET_BCM96846=y CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 -CONFIG_DEFAULT_DEVICE_TREE="bcm96846" +CONFIG_DEFAULT_DEVICE_TREE="broadcom/bcm96846" CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_SYS_LOAD_ADDR=0x01000000 CONFIG_IDENT_STRING=" Broadcom BCM6846" CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_OF_UPSTREAM=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y
Hi
On Fri, Oct 11, 2024 at 4:49 PM Linus Walleij linus.walleij@linaro.org wrote:
Changes in v2:
Acked-by: Michael Trimarchi michael@amarulasolutions.com
I will queue in weekend
Michael
Hi
On Fri, Oct 11, 2024 at 9:54 PM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi
Changes in v2:
Applied thanks
Michael
Michael
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com www.amarulasolutions.com
Linus Walleij
