[PATCH 0/3] mtd: spi-nor-core: Add support for s28hl512t, s28hl01gt, and s28hs01gt
These devices are variants of s28hs512t(1.8V 512Mb) with different density(1Gb) and power supply voltage(3V).
Datasheet: https://www.infineon.com/dgdl/Infineon-S28HS256T_S28HS512T_S28HS01GT_S28HL25...
Tested on Zynq-7000 platform with Infineon SPI controller
Takahiro Kuwano (3): mtd: spi-nor-core: Rename s28hs512t prefix mtd: spi-nor-core: Rename configuration macro for S28 support mtd: spi-nor-ids: Add s28hl512t, s28hl01gt, and s28hs01gt IDs
configs/j721s2_evm_a72_defconfig | 2 +- configs/j721s2_evm_r5_defconfig | 2 +- drivers/mtd/spi/Kconfig | 10 +++---- drivers/mtd/spi/spi-nor-core.c | 48 +++++++++++++++++--------------- drivers/mtd/spi/spi-nor-ids.c | 5 +++- 5 files changed, 36 insertions(+), 31 deletions(-)
Change prefix to support all other devices in SEMPER S28 family.
Signed-off-by: Takahiro Kuwano Takahiro.Kuwano@infineon.com --- drivers/mtd/spi/spi-nor-core.c | 34 +++++++++++++++++----------------- 1 file changed, 17 insertions(+), 17 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index e3c86e080a..5f16bf7b1a 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3369,15 +3369,15 @@ static int spi_nor_cypress_octal_dtr_enable(struct spi_nor *nor) return 0; }
-static int s28hs512t_erase_non_uniform(struct spi_nor *nor, loff_t addr) +static int s28hx_t_erase_non_uniform(struct spi_nor *nor, loff_t addr) { /* Factory default configuration: 32 x 4 KiB sectors at bottom. */ return spansion_erase_non_uniform(nor, addr, SPINOR_OP_S28_SE_4K, 0, SZ_128K); }
-static int s28hs512t_setup(struct spi_nor *nor, const struct flash_info *info, - const struct spi_nor_flash_parameter *params) +static int s28hx_t_setup(struct spi_nor *nor, const struct flash_info *info, + const struct spi_nor_flash_parameter *params) { struct spi_mem_op op; u8 buf; @@ -3404,19 +3404,19 @@ static int s28hs512t_setup(struct spi_nor *nor, const struct flash_info *info, return ret;
if (!(buf & SPINOR_REG_CYPRESS_CFR3V_UNISECT)) - nor->erase = s28hs512t_erase_non_uniform; + nor->erase = s28hx_t_erase_non_uniform;
return spi_nor_default_setup(nor, info, params); }
-static void s28hs512t_default_init(struct spi_nor *nor) +static void s28hx_t_default_init(struct spi_nor *nor) { nor->octal_dtr_enable = spi_nor_cypress_octal_dtr_enable; - nor->setup = s28hs512t_setup; + nor->setup = s28hx_t_setup; }
-static void s28hs512t_post_sfdp_fixup(struct spi_nor *nor, - struct spi_nor_flash_parameter *params) +static void s28hx_t_post_sfdp_fixup(struct spi_nor *nor, + struct spi_nor_flash_parameter *params) { /* * On older versions of the flash the xSPI Profile 1.0 table has the @@ -3446,10 +3446,10 @@ static void s28hs512t_post_sfdp_fixup(struct spi_nor *nor, params->rdsr_addr_nbytes = 4; }
-static int s28hs512t_post_bfpt_fixup(struct spi_nor *nor, - const struct sfdp_parameter_header *bfpt_header, - const struct sfdp_bfpt *bfpt, - struct spi_nor_flash_parameter *params) +static int s28hx_t_post_bfpt_fixup(struct spi_nor *nor, + const struct sfdp_parameter_header *bfpt_header, + const struct sfdp_bfpt *bfpt, + struct spi_nor_flash_parameter *params) { struct spi_mem_op op; u8 buf; @@ -3486,10 +3486,10 @@ static int s28hs512t_post_bfpt_fixup(struct spi_nor *nor, return 0; }
-static struct spi_nor_fixups s28hs512t_fixups = { - .default_init = s28hs512t_default_init, - .post_sfdp = s28hs512t_post_sfdp_fixup, - .post_bfpt = s28hs512t_post_bfpt_fixup, +static struct spi_nor_fixups s28hx_t_fixups = { + .default_init = s28hx_t_default_init, + .post_sfdp = s28hx_t_post_sfdp_fixup, + .post_bfpt = s28hx_t_post_bfpt_fixup, }; #endif /* CONFIG_SPI_FLASH_S28HS512T */
@@ -3824,7 +3824,7 @@ void spi_nor_set_fixups(struct spi_nor *nor)
#ifdef CONFIG_SPI_FLASH_S28HS512T if (!strcmp(nor->info->name, "s28hs512t")) - nor->fixups = &s28hs512t_fixups; + nor->fixups = &s28hx_t_fixups; #endif
#ifdef CONFIG_SPI_FLASH_MT35XU
Change configuration macro name to support all other devices in SEMPER S28 family.
Signed-off-by: Takahiro Kuwano Takahiro.Kuwano@infineon.com --- configs/j721s2_evm_a72_defconfig | 2 +- configs/j721s2_evm_r5_defconfig | 2 +- drivers/mtd/spi/Kconfig | 10 +++++----- drivers/mtd/spi/spi-nor-core.c | 6 +++--- drivers/mtd/spi/spi-nor-ids.c | 2 +- 5 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 14dfb6946f..d7566c7cec 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -150,7 +150,7 @@ CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_SOFT_RESET=y CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_S28HS512T=y +CONFIG_SPI_FLASH_S28HX_T=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_MT35XU=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 98d69a18b9..eade24908f 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -129,7 +129,7 @@ CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_SOFT_RESET=y CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_S28HS512T=y +CONFIG_SPI_FLASH_S28HX_T=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_MT35XU=y CONFIG_PINCTRL=y diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 096338f27b..7b858a3a91 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -166,13 +166,13 @@ config SPI_FLASH_SPANSION help Add support for various Spansion SPI flash chips (S25FLxxx)
-config SPI_FLASH_S28HS512T - bool "Cypress S28HS512T chip support" +config SPI_FLASH_S28HX_T + bool "Cypress SEMPER Octal (S28) chip support" depends on SPI_FLASH_SPANSION help - Add support for the Cypress S28HS512T chip. This is a separate config - because the fixup hooks for this flash add extra size overhead. Boards - that don't use the flash can disable this to save space. + Add support for the Cypress S28HL-T and S28HS-T chip. This is a separate + config because the fixup hooks for this flash add extra size overhead. + Boards that don't use the flash can disable this to save space.
config SPI_FLASH_STMICRO bool "STMicro SPI flash support" diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 5f16bf7b1a..67e54a5cb5 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3310,7 +3310,7 @@ static struct spi_nor_fixups s25fl256l_fixups = { }; #endif
-#ifdef CONFIG_SPI_FLASH_S28HS512T +#ifdef CONFIG_SPI_FLASH_S28HX_T /** * spi_nor_cypress_octal_dtr_enable() - Enable octal DTR on Cypress flashes. * @nor: pointer to a 'struct spi_nor' @@ -3491,7 +3491,7 @@ static struct spi_nor_fixups s28hx_t_fixups = { .post_sfdp = s28hx_t_post_sfdp_fixup, .post_bfpt = s28hx_t_post_bfpt_fixup, }; -#endif /* CONFIG_SPI_FLASH_S28HS512T */ +#endif /* CONFIG_SPI_FLASH_S28HX_T */
#ifdef CONFIG_SPI_FLASH_MT35XU static int spi_nor_micron_octal_dtr_enable(struct spi_nor *nor) @@ -3822,7 +3822,7 @@ void spi_nor_set_fixups(struct spi_nor *nor) nor->fixups = &s25fl256l_fixups; #endif
-#ifdef CONFIG_SPI_FLASH_S28HS512T +#ifdef CONFIG_SPI_FLASH_S28HX_T if (!strcmp(nor->info->name, "s28hs512t")) nor->fixups = &s28hx_t_fixups; #endif diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 4fe8b0d92c..743a87f172 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -294,7 +294,7 @@ const struct flash_info spi_nor_ids[] = { USE_CLSR) }, { INFO6("s25hs02gt", 0x342b1c, 0x0f0090, 256 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, -#ifdef CONFIG_SPI_FLASH_S28HS512T +#ifdef CONFIG_SPI_FLASH_S28HX_T { INFO("s28hs512t", 0x345b1a, 0, 256 * 1024, 256, SPI_NOR_OCTAL_DTR_READ) }, #endif #endif
Add flash info table entries for s28hl512gt, s28hl01gt, and s28hs01gt. These devices have the same functionality as s28hs512t.
In spi-nor-core, use device ID byte to detect S28 family instead of device name.
Signed-off-by: Takahiro Kuwano Takahiro.Kuwano@infineon.com --- drivers/mtd/spi/spi-nor-core.c | 12 +++++++----- drivers/mtd/spi/spi-nor-ids.c | 3 +++ 2 files changed, 10 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 67e54a5cb5..ead97cee1c 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3812,6 +3812,13 @@ void spi_nor_set_fixups(struct spi_nor *nor) nor->fixups = &s25hx_t_fixups; break;
+#ifdef CONFIG_SPI_FLASH_S28HX_T + case 0x5a: /* S28HL (Octal, 3.3V) */ + case 0x5b: /* S28HS (Octal, 1.8V) */ + nor->fixups = &s28hx_t_fixups; + break; +#endif + default: break; } @@ -3822,11 +3829,6 @@ void spi_nor_set_fixups(struct spi_nor *nor) nor->fixups = &s25fl256l_fixups; #endif
-#ifdef CONFIG_SPI_FLASH_S28HX_T - if (!strcmp(nor->info->name, "s28hs512t")) - nor->fixups = &s28hx_t_fixups; -#endif - #ifdef CONFIG_SPI_FLASH_MT35XU if (!strcmp(nor->info->name, "mt35xu512aba")) nor->fixups = &mt35xu512aba_fixups; diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 743a87f172..7e7a3e97bc 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -295,7 +295,10 @@ const struct flash_info spi_nor_ids[] = { { INFO6("s25hs02gt", 0x342b1c, 0x0f0090, 256 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, #ifdef CONFIG_SPI_FLASH_S28HX_T + { INFO("s28hl512t", 0x345a1a, 0, 256 * 1024, 256, SPI_NOR_OCTAL_DTR_READ) }, + { INFO("s28hl01gt", 0x345a1b, 0, 256 * 1024, 512, SPI_NOR_OCTAL_DTR_READ) }, { INFO("s28hs512t", 0x345b1a, 0, 256 * 1024, 256, SPI_NOR_OCTAL_DTR_READ) }, + { INFO("s28hs01gt", 0x345b1b, 0, 256 * 1024, 512, SPI_NOR_OCTAL_DTR_READ) }, #endif #endif #ifdef CONFIG_SPI_FLASH_SST /* SST */
Applied to u-boot-spi/master
Jagan Teki
