[PATCH] arm64: versal-net: Align node names with dt-schema
dt-schema is forcing some rules for node names that's why align them with it. Labels are not changing that's why this change is not breaking any other board specific DTSes.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/versal-net-mini-emmc.dts | 4 ++-- arch/arm/dts/versal-net-mini-ospi.dtsi | 2 +- arch/arm/dts/versal-net-mini-qspi.dtsi | 2 +- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/versal-net-mini-emmc.dts b/arch/arm/dts/versal-net-mini-emmc.dts index 8a864ba3ed3f..e200fb694c6b 100644 --- a/arch/arm/dts/versal-net-mini-emmc.dts +++ b/arch/arm/dts/versal-net-mini-emmc.dts @@ -42,14 +42,14 @@ bootph-all; };
- amba: amba { + amba: axi { bootph-all; compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; ranges;
- sdhci1: sdhci@f1050000 { + sdhci1: mmc@f1050000 { compatible = "xlnx,versal-net-emmc"; status = "okay"; non-removable; diff --git a/arch/arm/dts/versal-net-mini-ospi.dtsi b/arch/arm/dts/versal-net-mini-ospi.dtsi index 5d188db62d92..d511b823754b 100644 --- a/arch/arm/dts/versal-net-mini-ospi.dtsi +++ b/arch/arm/dts/versal-net-mini-ospi.dtsi @@ -42,7 +42,7 @@ bootph-all; };
- amba: amba { + amba: axi { bootph-all; compatible = "simple-bus"; #address-cells = <0x2>; diff --git a/arch/arm/dts/versal-net-mini-qspi.dtsi b/arch/arm/dts/versal-net-mini-qspi.dtsi index 097b58c633b8..e29a3f36d6e4 100644 --- a/arch/arm/dts/versal-net-mini-qspi.dtsi +++ b/arch/arm/dts/versal-net-mini-qspi.dtsi @@ -42,7 +42,7 @@ bootph-all; };
- amba: amba {
- amba: axi { bootph-all; compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; ranges;
- amba: amba {
- amba: axi { bootph-all; compatible = "simple-bus"; #address-cells = <0x2>;
- amba: amba {
Applied. M
Michal Simek
