[U-Boot] [PATCH] fit: Add support for printing more than one FPGA node name
This would print out all the FPGA node names setting to fpga property.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- common/image-fit.c | 14 +++++++++++--- 1 files changed, 11 insertions(+), 3 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index ac901e1..816e17d 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -263,6 +263,7 @@ static void fit_conf_print(const void *fit, int noffset, const char *p) int ret; int fdt_index, loadables_index; int ndepth; + ulong count;
/* Mandatory properties */ ret = fit_get_desc(fit, noffset, &desc); @@ -299,9 +300,16 @@ static void fit_conf_print(const void *fit, int noffset, const char *p) printf("%s\n", uname); }
- uname = fdt_getprop(fit, noffset, FIT_FPGA_PROP, NULL); - if (uname) - printf("%s FPGA: %s\n", p, uname); + count = fit_conf_get_prop_node_count(fit, noffset, FIT_FPGA_PROP); + + for (ndepth = 0; ndepth < count; ndepth++) { + int images_noffset = fit_conf_get_prop_node_index(fit, noffset, + FIT_FPGA_PROP, ndepth); + uname = fit_get_name(fit, images_noffset, NULL); + + if (uname) + printf("%s FPGA: %s\n", p, uname); + }
/* Print out all of the specified loadables */ for (loadables_index = 0;
ulong count;
- if (uname)
if (uname)
While I'm fine with the conceptual change here, both fit_conf_get_prop_node_count / fit_conf_get_prop_node_index are defined later in the file and while public functions not documented in a header. Can you please do a patch that does so first, as we otherwise get a warning? Thanks!
- ulong count;
- if (uname)
- count = fit_conf_get_prop_node_count(fit, noffset,
FIT_FPGA_PROP);
- for (ndepth = 0; ndepth < count; ndepth++) {
FIT_FPGA_PROP,
ndepth);
if (uname)
uname);
The header file in this patch https://patchwork.ozlabs.org/patch/105828 9/ , unfortunately the review taking a bit longer than what i expected.
I would update you once the whole series patches are accepted.
Thanks a lot.
- ulong count;
- if (uname)
FIT_FPGA_PROP);
FIT_FPGA_PROP,
ndepth);
if (uname)
uname);
The header file in this patch https://patchwork.ozlabs.org/patch/1058289/, unfortunately the review taking a bit longer than what i expected.
Ah, OK, I'll hold off until the other series is complete.
- ulong count;
NULL);
- if (uname)
FIT_FPGA_PROP);
FIT_FPGA_PROP,
ndepth);
NULL);
if (uname)
uname);
The header file in this patch https://patchwork.ozlabs.org/patch/10 58289/, unfortunately the review taking a bit longer than what i expected.
The series is already in mainline master branch.
Thanks.
ulong count;
- if (uname)
if (uname)
There's a problem here. When I use buildman to make multiple boards (say 'arm', but something smaller should trigger it too), all of my builds get stuck on mkimage doing something. A build of a single board is fine.
Chee, Tien Fong
