[PATCH v2 0/4] mtd: omap_gpmc: Fix GPMC & NAND drivers
When testing the driver with K3 platform, build and functional issues were found in the ti-gpmc and omap_gpmc NAND driver. Fix those.
cheers, -roger
Changelog:
v2: - Added "mtd: rawnand: omap_gpmc: fix OF based partition parsing for NAND". - Dropped defconfig patch.
CI test results: https://github.com/u-boot/u-boot/pull/467
v1: https://lore.kernel.org/all/20240109122605.51951-1-rogerq@kernel.org/
Roger Quadros (4): memory: ti-gpmc: Fix build mtd: rawnand: omap_gpmc: Use DT provided IO address mtd: rawnand: omap_gpmc: fix OF based partition parsing for NAND arm: mach-k3: am642: Define NAND boot device
arch/arm/mach-k3/am642_init.c | 3 +++ arch/arm/mach-k3/include/mach/am64_spl.h | 1 + drivers/memory/ti-gpmc.c | 2 +- drivers/mtd/nand/raw/omap_gpmc.c | 21 ++++++++++++++++----- 4 files changed, 21 insertions(+), 6 deletions(-)
base-commit: c2c598e87cfe56f5991730762c00733c5aa9a994 prerequisite-patch-id: e0465f3e924302d1c4bd47f2129b4eb3bd9faead
sys_proto.h no longer exists for K3 platform so drop it. Include sizes.h to so SZ_16M is visible.
Signed-off-by: Roger Quadros rogerq@kernel.org ---
Notes: v2: no change
drivers/memory/ti-gpmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/memory/ti-gpmc.c b/drivers/memory/ti-gpmc.c index 775e78c9a5..0b8674339e 100644 --- a/drivers/memory/ti-gpmc.c +++ b/drivers/memory/ti-gpmc.c @@ -6,7 +6,6 @@ */
#include <asm/io.h> -#include <asm/arch/sys_proto.h> #include <clk.h> #include <common.h> #include <dm.h> @@ -17,6 +16,7 @@ #include <linux/mtd/omap_gpmc.h> #include <linux/ioport.h> #include <linux/io.h> +#include <linux/sizes.h> #include "ti-gpmc.h"
enum gpmc_clk_domain {
Hi Roger,
Reviewed-by: Dario Binacchi dario.binacchi@amarulasolutions.com
Thanks and regards, Dario
2.34.1
Dario Binacchi
Senior Embedded Linux Developer
__________________________________
Amarula Solutions SRL
Via Le Canevare 30, 31100 Treviso, Veneto, IT
T. +39 042 243 5310 info@amarulasolutions.com
www.amarulasolutions.com
For DM case we can get the NAND chip's IO address from DT so we don't need to rely on CFG_SYS_NAND_BASE.
drivers/mtd/nand/raw/omap_gpmc.c | 19 ++++++++++++++----- 1 file changed, 14 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/nand/raw/omap_gpmc.c b/drivers/mtd/nand/raw/omap_gpmc.c index 0e25bd5dc2..f827c578d9 100644 --- a/drivers/mtd/nand/raw/omap_gpmc.c +++ b/drivers/mtd/nand/raw/omap_gpmc.c @@ -8,13 +8,15 @@ #include <log.h> #include <system-constants.h> #include <asm/io.h> -#include <dm/uclass.h> +#include <dm.h> #include <linux/errno.h>
#ifdef CONFIG_ARCH_OMAP2PLUS #include <asm/arch/mem.h> #endif
+#include <linux/io.h> +#include <linux/ioport.h> #include <linux/mtd/omap_gpmc.h> #include <linux/mtd/nand_ecc.h> #include <linux/mtd/rawnand.h> @@ -1124,7 +1126,7 @@ int __maybe_unused omap_nand_switch_ecc(uint32_t hardware, uint32_t eccstrength) * nand_scan about special functionality. See the defines for further * explanation */ -int gpmc_nand_init(struct nand_chip *nand) +int gpmc_nand_init(struct nand_chip *nand, void __iomem *nand_base) { int32_t gpmc_config = 0; int cs = cs_next++; @@ -1164,7 +1166,7 @@ int gpmc_nand_init(struct nand_chip *nand) info->control = NULL; info->cs = cs; info->ws = wscfg[cs]; - info->fifo = (void __iomem *)CFG_SYS_NAND_BASE; + info->fifo = nand_base; nand_set_controller_data(nand, &omap_nand_info[cs]); nand->cmd_ctrl = omap_nand_hwcontrol; nand->options |= NAND_NO_PADDING | NAND_CACHEPRG; @@ -1214,9 +1216,16 @@ static int gpmc_nand_probe(struct udevice *dev) { struct nand_chip *nand = dev_get_priv(dev); struct mtd_info *mtd = nand_to_mtd(nand); + struct resource res; + void __iomem *base; int ret;
- gpmc_nand_init(nand); + ret = dev_read_resource(dev, 0, &res); + if (ret) + return ret; + + base = devm_ioremap(dev, res.start, resource_size(&res)); + gpmc_nand_init(nand, base);
ret = nand_scan(mtd, CONFIG_SYS_NAND_MAX_CHIPS); if (ret) @@ -1270,7 +1279,7 @@ void board_nand_init(void)
int board_nand_init(struct nand_chip *nand) { - return gpmc_nand_init(nand); + return gpmc_nand_init(nand, (void __iomem *)CFG_SYS_NAND_BASE); }
#endif /* CONFIG_SYS_NAND_SELF_INIT */
Hi Roger,
- nand_scan about special functionality. See the defines for further
- explanation
if (ret)
return ret;
gpmc_nand_init(nand, base); ret = nand_scan(mtd, CONFIG_SYS_NAND_MAX_CHIPS); if (ret)
2.34.1
Set NAND chip ofnode and device so OF based partition parsing can work.
Notes: v2: initial commit
drivers/mtd/nand/raw/omap_gpmc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mtd/nand/raw/omap_gpmc.c b/drivers/mtd/nand/raw/omap_gpmc.c index f827c578d9..b36b6fabae 100644 --- a/drivers/mtd/nand/raw/omap_gpmc.c +++ b/drivers/mtd/nand/raw/omap_gpmc.c @@ -1226,6 +1226,8 @@ static int gpmc_nand_probe(struct udevice *dev)
base = devm_ioremap(dev, res.start, resource_size(&res)); gpmc_nand_init(nand, base); + mtd->dev = dev; + nand_set_flash_node(nand, dev_ofnode(dev));
AM642 SoC supports booting from GPMC NAND device. Define boot device for it.
Notes: v2: No change
arch/arm/mach-k3/am642_init.c | 3 +++ arch/arm/mach-k3/include/mach/am64_spl.h | 1 + 2 files changed, 4 insertions(+)
diff --git a/arch/arm/mach-k3/am642_init.c b/arch/arm/mach-k3/am642_init.c index 6085379f1d..ddf47ef0a9 100644 --- a/arch/arm/mach-k3/am642_init.c +++ b/arch/arm/mach-k3/am642_init.c @@ -348,6 +348,9 @@ static u32 __get_primary_bootmedia(u32 main_devstat) case BOOT_DEVICE_EMMC: return BOOT_DEVICE_MMC1;
+ case BOOT_DEVICE_NAND: + return BOOT_DEVICE_NAND; + case BOOT_DEVICE_MMC: if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_MMC_PORT_MASK) >> MAIN_DEVSTAT_PRIMARY_MMC_PORT_SHIFT) diff --git a/arch/arm/mach-k3/include/mach/am64_spl.h b/arch/arm/mach-k3/include/mach/am64_spl.h index b4f396b2c0..a0a517019c 100644 --- a/arch/arm/mach-k3/include/mach/am64_spl.h +++ b/arch/arm/mach-k3/include/mach/am64_spl.h @@ -22,6 +22,7 @@
#define BOOT_DEVICE_USB 0x2A #define BOOT_DEVICE_DFU 0x0A +#define BOOT_DEVICE_NAND 0x0B #define BOOT_DEVICE_GPMC_NOR 0x0C #define BOOT_DEVICE_PCIE 0x0D #define BOOT_DEVICE_XSPI 0x0E
cheers, -roger
Changelog:
v2:
base-commit: c2c598e87cfe56f5991730762c00733c5aa9a994 prerequisite-patch-id: e0465f3e924302d1c4bd47f2129b4eb3bd9faead -- 2.34.1
Applied to nand-next,
Dario Binacchi
Roger Quadros
