[U-Boot] [PATCH] usb: dwc3: fix Kconfig dependency to accept host driver in drivers/usb/dwc3
We see the choice of USB_DWC3_HOST / _GADGET in drivers/usb/dwc3/Kconfig, but we can not choose USB_DWC3_HOST unless USB_GADGET is defined. This is strange.
Loosen the "depends on" and also move "select USB_GADGET_DUALSPEED" to the correct place.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/usb/dwc3/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/dwc3/Kconfig b/drivers/usb/dwc3/Kconfig index e93398fe7c1c..7f2f400c09ce 100644 --- a/drivers/usb/dwc3/Kconfig +++ b/drivers/usb/dwc3/Kconfig @@ -1,7 +1,6 @@ config USB_DWC3 bool "DesignWare USB3 DRD Core Support" - depends on (USB && USB_GADGET) - select USB_GADGET_DUALSPEED + depends on (USB_HOST || USB_GADGET) help Say Y here if your system has a Dual Role SuperSpeed USB controller based on the DesignWare USB3 IP Core. @@ -21,6 +20,7 @@ config USB_DWC3_HOST config USB_DWC3_GADGET bool "Gadget only mode" depends on USB_GADGET + select USB_GADGET_DUALSPEED help Select this when you want to use DWC3 in gadget mode only, thereby the host feature will be regressed.
Applied, thanks
- depends on (USB_HOST || USB_GADGET) help Say Y here if your system has a Dual Role SuperSpeed USB controller based on the DesignWare USB3 IP Core.
- select USB_GADGET_DUALSPEED help Select this when you want to use DWC3 in gadget mode only, thereby the host feature will be regressed.
2017-08-25 6:57 GMT+09:00 Marek Vasut marex@denx.de:
Applied, thanks
Marek,
I noticed redundant parentheses for depends on. Could you fix it up locally like follows?
depends on USB_HOST || USB_GADGET
Thanks.
Applied, thanks
Marek,
Hrmm, fixed.
Masahiro Yamada
