[U-Boot] [PATCH v5 1/2] APM821xx: Add CPU support
APM821XX is a new line of SoCs which are derivatives of PPC44X family of processors. This patch adds support of CPU, cache, tlb, 32k ocm, bootstraps, PLB and AHB bus.
Signed-off-by: Tirumala R Marri tmarri@apm.com --- V4: * Rebase with Stefan Roese tree V5: * Move CONFIG_SYS_PERIPHERAL_BASE to apm821xx.h --- arch/powerpc/cpu/ppc4xx/cpu.c | 19 ++++++++ arch/powerpc/cpu/ppc4xx/cpu_init.c | 5 +- arch/powerpc/cpu/ppc4xx/speed.c | 75 ++++++++++++++++++++++++++++++- arch/powerpc/cpu/ppc4xx/start.S | 11 +++-- arch/powerpc/include/asm/apm821xx.h | 70 ++++++++++++++++++++++++++++ arch/powerpc/include/asm/ppc4xx-ebc.h | 3 +- arch/powerpc/include/asm/ppc4xx-isram.h | 14 +++++- arch/powerpc/include/asm/ppc4xx-sdram.h | 12 +++--- arch/powerpc/include/asm/ppc4xx-uic.h | 5 +- arch/powerpc/include/asm/ppc4xx.h | 4 ++ arch/powerpc/include/asm/processor.h | 1 + 11 files changed, 200 insertions(+), 19 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/cpu.c b/arch/powerpc/cpu/ppc4xx/cpu.c index 6009b0c..f3bdf18 100644 --- a/arch/powerpc/cpu/ppc4xx/cpu.c +++ b/arch/powerpc/cpu/ppc4xx/cpu.c @@ -250,6 +250,20 @@ static char *bootstrap_str[] = { }; static char bootstrap_char[] = { 'A', 'B', 'C', 'D', 'E', 'G', 'F', 'H' }; #endif +#if defined(CONFIG_APM821XX) +#define SDR0_PINSTP_SHIFT 29 +static char *bootstrap_str[] = { + "RESERVED", + "RESERVED", + "RESERVED", + "NAND (8 bits)", + "NOR (8 bits)", + "NOR (8 bits) w/PLL Bypassed", + "I2C (Addr 0x54)", + "I2C (Addr 0x52)", +}; +static char bootstrap_char[] = { 'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H' }; +#endif
#if defined(SDR0_PINSTP_SHIFT) static int bootstrap_option(void) @@ -590,6 +604,11 @@ int checkcpu (void) strcpy(addstr, "No Security support"); break;
+ case PVR_APM821XX_RA: + puts("APM821XX Rev. A"); + strcpy(addstr, "Security support"); + break; + case PVR_VIRTEX5: puts("440x5 VIRTEX5"); break; diff --git a/arch/powerpc/cpu/ppc4xx/cpu_init.c b/arch/powerpc/cpu/ppc4xx/cpu_init.c index d54b30e..125241b 100644 --- a/arch/powerpc/cpu/ppc4xx/cpu_init.c +++ b/arch/powerpc/cpu/ppc4xx/cpu_init.c @@ -237,7 +237,8 @@ cpu_init_f (void)
reconfigure_pll(CONFIG_SYS_PLL_RECONFIG);
-#if (defined(CONFIG_405EP) || defined (CONFIG_405EX)) && !defined(CONFIG_SYS_4xx_GPIO_TABLE) +#if !defined(CONFIG_APM821XX) && (defined(CONFIG_405EP) ||\ + defined (CONFIG_405EX)) && !defined(CONFIG_SYS_4xx_GPIO_TABLE) /* * GPIO0 setup (select GPIO or alternate function) */ @@ -393,7 +394,7 @@ cpu_init_f (void) #if defined(CONFIG_405EX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) /* * Set PLB4 arbiter (Segment 0 and 1) to 4 deep pipeline read */ diff --git a/arch/powerpc/cpu/ppc4xx/speed.c b/arch/powerpc/cpu/ppc4xx/speed.c index abd4e91..09d6671 100644 --- a/arch/powerpc/cpu/ppc4xx/speed.c +++ b/arch/powerpc/cpu/ppc4xx/speed.c @@ -189,7 +189,7 @@ ulong get_PCI_freq (void) #elif defined(CONFIG_440)
#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) static u8 pll_fwdv_multi_bits[] = { /* values for: 1 - 16 */ 0x00, 0x01, 0x0f, 0x04, 0x09, 0x0a, 0x0d, 0x0e, 0x03, 0x0c, @@ -250,6 +250,78 @@ u32 get_cpr0_fbdv(unsigned long cpr_reg_fbdv) return 0; }
+#if defined(CONFIG_APM821XX) + +void get_sys_info(sys_info_t *sysInfo) +{ + unsigned long plld; + unsigned long temp; + unsigned long mul; + unsigned long cpudv; + unsigned long plb2dv; + unsigned long ddr2dv; + + /* Calculate Forward divisor A and Feeback divisor */ + mfcpr(CPR0_PLLD, plld); + + temp = CPR0_PLLD_FWDVA(plld); + sysInfo->pllFwdDivA = get_cpr0_fwdv(temp); + + temp = CPR0_PLLD_FDV(plld); + sysInfo->pllFbkDiv = get_cpr0_fbdv(temp); + + /* Calculate OPB clock divisor */ + mfcpr(CPR0_OPBD, temp); + temp = CPR0_OPBD_OPBDV(temp); + sysInfo->pllOpbDiv = temp ? temp : 4; + + /* Calculate Peripheral clock divisor */ + mfcpr(CPR0_PERD, temp); + temp = CPR0_PERD_PERDV(temp); + sysInfo->pllExtBusDiv = temp ? temp : 4; + + /* Calculate CPU clock divisor */ + mfcpr(CPR0_CPUD, temp); + temp = CPR0_CPUD_CPUDV(temp); + cpudv = temp ? temp : 8; + + /* Calculate PLB2 clock divisor */ + mfcpr(CPR0_PLB2D, temp); + temp = CPR0_PLB2D_PLB2DV(temp); + plb2dv = temp ? temp : 4; + + /* Calculate DDR2 clock divisor */ + mfcpr(CPR0_DDR2D, temp); + temp = CPR0_DDR2D_DDR2DV(temp); + ddr2dv = temp ? temp : 4; + + /* Calculate 'M' based on feedback source */ + mfcpr(CPR0_PLLC, temp); + temp = CPR0_PLLC_SEL(temp); + if (temp == 0) { + /* PLL internal feedback */ + mul = sysInfo->pllFbkDiv; + } else { + /* PLL PerClk feedback */ + mul = sysInfo->pllFwdDivA * sysInfo->pllFbkDiv * cpudv + * plb2dv * 2 * sysInfo->pllOpbDiv * + sysInfo->pllExtBusDiv; + } + + /* Now calculate the individual clocks */ + sysInfo->freqVCOMhz = (mul * CONFIG_SYS_CLK_FREQ) + (mul >> 1); + sysInfo->freqProcessor = sysInfo->freqVCOMhz / + sysInfo->pllFwdDivA / cpudv; + sysInfo->freqPLB = sysInfo->freqVCOMhz / + sysInfo->pllFwdDivA / cpudv / plb2dv / 2; + sysInfo->freqOPB = sysInfo->freqPLB / sysInfo->pllOpbDiv; + sysInfo->freqEBC = sysInfo->freqOPB / sysInfo->pllExtBusDiv; + sysInfo->freqDDR = sysInfo->freqVCOMhz / + sysInfo->pllFwdDivA / cpudv / ddr2dv / 2; + sysInfo->freqUART = sysInfo->freqPLB; +} + +#else /* * AMCC_TODO: verify this routine against latest EAS, cause stuff changed * with latest EAS @@ -307,6 +379,7 @@ void get_sys_info (sys_info_t * sysInfo)
return; } +#endif
#elif defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) diff --git a/arch/powerpc/cpu/ppc4xx/start.S b/arch/powerpc/cpu/ppc4xx/start.S index 7a65d9f..c2d52bf 100644 --- a/arch/powerpc/cpu/ppc4xx/start.S +++ b/arch/powerpc/cpu/ppc4xx/start.S @@ -703,7 +703,8 @@ _start: defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460SX) mtdcr L2_CACHE_CFG,r0 /* Ensure L2 Cache is off */ -#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM821XX) lis r1, 0x0000 ori r1,r1,0x0008 /* Set L2_CACHE_CFG[RDBW]=1 */ mtdcr L2_CACHE_CFG,r1 @@ -731,7 +732,8 @@ _start: lis r1, 0x8003 ori r1,r1, 0x0980 /* fourth 64k */ mtdcr ISRAM0_SB3CR,r1 -#elif defined(CONFIG_440SPE) || defined(CONFIG_460EX) || defined(CONFIG_460GT) +#elif defined(CONFIG_440SPE) || defined(CONFIG_460EX) || \ + defined(CONFIG_460GT) || defined(CONFIG_APM821XX) lis r1,0x0000 /* BAS = X_0000_0000 */ ori r1,r1,0x0984 /* first 64k */ mtdcr ISRAM0_SB0CR,r1 @@ -744,7 +746,8 @@ _start: lis r1, 0x0003 ori r1,r1, 0x0984 /* fourth 64k */ mtdcr ISRAM0_SB3CR,r1 -#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM821XX) lis r2,0x7fff ori r2,r2,0xffff mfdcr r1,ISRAM1_DPC @@ -755,7 +758,7 @@ _start: mtdcr ISRAM1_PMEG,r1
lis r1,0x0004 /* BAS = 4_0004_0000 */ - ori r1,r1,0x0984 /* 64k */ + ori r1,r1,ISRAM1_SIZE /* ocm size */ mtdcr ISRAM1_SB0CR,r1 #endif #elif defined(CONFIG_460SX) diff --git a/arch/powerpc/include/asm/apm821xx.h b/arch/powerpc/include/asm/apm821xx.h new file mode 100644 index 0000000..d08f8a6 --- /dev/null +++ b/arch/powerpc/include/asm/apm821xx.h @@ -0,0 +1,70 @@ +/* + * Copyright (c) 2010, Applied Micro Circuits Corporation + * Author: Tirumala R Marri tmarri@apm.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _APM821XX_H_ +#define _APM821XX_H_ + +#define CONFIG_SDRAM_PPC4xx_IBM_DDR2 /* IBM DDR(2) controller */ +/* Memory mapped registers */ +#define CONFIG_SYS_PERIPHERAL_BASE 0xEF600000 +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_PERIPHERAL_BASE + 0x0200) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_PERIPHERAL_BASE + 0x0300) + +#define GPIO0_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0700) + +#define SDR0_SRST0_DMC 0x00200000 +#define SDR0_SRST1_AHB 0x00000040 /* PLB4XAHB bridge */ +/* AHB config. */ +#define AHB_TOP 0xA4 +#define AHB_BOT 0xA5 + + +#define PLLSYS0_FWD_DIV_A_MASK 0x000000f0 /* Fwd Div A */ +#define PLLSYS0_FWD_DIV_B_MASK 0x0000000f /* Fwd Div B */ +#define PLLSYS0_FB_DIV_MASK 0x0000ff00 /* Feedback divisor */ +#define PLLSYS0_OPB_DIV_MASK 0x0c000000 /* OPB Divisor */ +#define PLLSYS0_EPB_DIV_MASK 0x00000300 /* EPB divisor */ +#define PLLSYS0_EXTSL_MASK 0x00000080 /* PerClk feedback path */ +#define PLLSYS0_PLBEDV0_DIV_MASK 0xe0000000 /* PLB Early Clock Divisor */ +#define PLLSYS0_PERCLK_DIV_MASK 0x03000000 /* Peripheral Clk Divisor */ +#define PLLSYS0_SEL_MASK 0x18000000 /* 0 = PLL, 1 = PerClk */ +/* + + * Clocking Controller + + */ +/* values for clkcfga register - indirect addressing of these regs */ +#define CPR0_CLKUPD 0x0020 +#define CPR0_PLLC 0x0040 +#define CPR0_PLLC_SEL(pllc) (((pllc) & 0x01000000) >> 24) +#define CPR0_PLLD 0x0060 +#define CPR0_PLLD_FDV(plld) (((plld) & 0xff000000) >> 24) +#define CPR0_PLLD_FWDVA(plld) (((plld) & 0x000f0000) >> 16) +#define CPR0_CPUD 0x0080 +#define CPR0_CPUD_CPUDV(cpud) (((cpud) & 0x07000000) >> 24) +#define CPR0_PLB2D 0x00a0 +#define CPR0_PLB2D_PLB2DV(plb2d) (((plb2d) & 0x06000000) >> 25) +#define CPR0_OPBD 0x00c0 +#define CPR0_OPBD_OPBDV(opbd) (((opbd) & 0x03000000) >> 24) +#define CPR0_PERD 0x00e0 +#define CPR0_PERD_PERDV(perd) (((perd) & 0x03000000) >> 24) +#define CPR0_DDR2D 0x0100 +#define CPR0_DDR2D_DDR2DV(ddr2d) (((ddr2d) & 0x06000000) >> 25) +#define CLK_ICFG 0x0140 + +#endif /* _APM821XX_H_ */ diff --git a/arch/powerpc/include/asm/ppc4xx-ebc.h b/arch/powerpc/include/asm/ppc4xx-ebc.h index 9c17e46..75af130 100644 --- a/arch/powerpc/include/asm/ppc4xx-ebc.h +++ b/arch/powerpc/include/asm/ppc4xx-ebc.h @@ -69,7 +69,8 @@ #define EBC_NUM_BANKS 6 #endif
-#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) +#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_APM821XX) #define EBC_NUM_BANKS 3 #endif
diff --git a/arch/powerpc/include/asm/ppc4xx-isram.h b/arch/powerpc/include/asm/ppc4xx-isram.h index d6d17ac..32e1297 100644 --- a/arch/powerpc/include/asm/ppc4xx-isram.h +++ b/arch/powerpc/include/asm/ppc4xx-isram.h @@ -25,7 +25,8 @@ /* * Internal SRAM */ -#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) +#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_APM821XX) #define ISRAM0_DCR_BASE 0x380 #else #define ISRAM0_DCR_BASE 0x020 @@ -42,7 +43,8 @@ #define ISRAM0_REVID (ISRAM0_DCR_BASE+0x09) /* SRAM bus revision id reg */ #define ISRAM0_DPC (ISRAM0_DCR_BASE+0x0a) /* SRAM data parity check reg */
-#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM821XX) #define ISRAM1_DCR_BASE 0x0B0 #define ISRAM1_SB0CR (ISRAM1_DCR_BASE+0x00) /* SRAM1 bank config 0*/ #define ISRAM1_BEAR (ISRAM1_DCR_BASE+0x04) /* SRAM1 bus error addr reg */ @@ -54,13 +56,19 @@ #define ISRAM1_DPC (ISRAM1_DCR_BASE+0x0a) /* SRAM1 data parity check reg */ #endif /* CONFIG_460EX || CONFIG_460GT */
+#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#define ISRAM1_SIZE 0x0984 /* OCM size 64k */ +#elif defined(CONFIG_APM821XX) +#define ISRAM1_SIZE 0x0784 /* OCM size 32k */ +#endif + /* * L2 Cache */ #if defined (CONFIG_440GX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) #define L2_CACHE_BASE 0x030 #define L2_CACHE_CFG (L2_CACHE_BASE+0x00) /* L2 Cache Config */ #define L2_CACHE_CMD (L2_CACHE_BASE+0x01) /* L2 Cache Command */ diff --git a/arch/powerpc/include/asm/ppc4xx-sdram.h b/arch/powerpc/include/asm/ppc4xx-sdram.h index ac150c2..d570d79 100644 --- a/arch/powerpc/include/asm/ppc4xx-sdram.h +++ b/arch/powerpc/include/asm/ppc4xx-sdram.h @@ -292,7 +292,7 @@ */ #if defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) #define SDRAM_RXBAS_SDBA_MASK 0xFFE00000 /* Base address */ #define SDRAM_RXBAS_SDBA_ENCODE(n) ((u32)(((phys_size_t)(n) >> 2) & 0xFFE00000)) #define SDRAM_RXBAS_SDBA_DECODE(n) ((((phys_size_t)(n)) & 0xFFE00000) << 2) @@ -365,7 +365,7 @@ /* * Memory controller registers */ -#ifdef CONFIG_405EX +#if defined(CONFIG_405EX) || defined(CONFIG_APM821XX) #define SDRAM_BESR 0x00 /* PLB bus error status (read/clear) */ #define SDRAM_BESRT 0x01 /* PLB bus error status (test/set) */ #define SDRAM_BEARL 0x02 /* PLB bus error address low */ @@ -375,9 +375,9 @@ #define SDRAM_PLBOPT 0x08 /* PLB slave options */ #define SDRAM_PUABA 0x09 /* PLB upper address base */ #define SDRAM_MCSTAT 0x1F /* memory controller status */ -#else /* CONFIG_405EX */ +#else /* CONFIG_405EX || CONFIG_APM821XX */ #define SDRAM_MCSTAT 0x14 /* memory controller status */ -#endif /* CONFIG_405EX */ +#endif /* CONFIG_405EX || CONFIG_APM821XX */ #define SDRAM_MCOPT1 0x20 /* memory controller options 1 */ #define SDRAM_MCOPT2 0x21 /* memory controller options 2 */ #define SDRAM_MODT0 0x22 /* on die termination for bank 0 */ @@ -423,12 +423,12 @@ #define SDRAM_MEMODE 0x89 /* memory extended mode */ #define SDRAM_ECCES 0x98 /* ECC error status */ #define SDRAM_CID 0xA4 /* core ID */ -#ifndef CONFIG_405EX +#if !defined(CONFIG_405EX) && !defined(CONFIG_APM821XX) #define SDRAM_RID 0xA8 /* revision ID */ #endif #define SDRAM_FCSR 0xB0 /* feedback calibration status */ #define SDRAM_RTSR 0xB1 /* run time status tracking */ -#ifdef CONFIG_405EX +#if defined(CONFIG_405EX) || defined(CONFIG_APM821XX) #define SDRAM_RID 0xF8 /* revision ID */ #endif
diff --git a/arch/powerpc/include/asm/ppc4xx-uic.h b/arch/powerpc/include/asm/ppc4xx-uic.h index 782d045..3714a0a 100644 --- a/arch/powerpc/include/asm/ppc4xx-uic.h +++ b/arch/powerpc/include/asm/ppc4xx-uic.h @@ -31,7 +31,7 @@ */ #if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM821XX) #define UIC_MAX 4 #elif defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_405EX) @@ -252,7 +252,8 @@ #define VECNUM_ETH0 (32 + 28) #endif /* CONFIG_440SPE */
-#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM821XX) /* UIC 0 */ #define VECNUM_UIC2NCI 10 #define VECNUM_UIC2CI 11 diff --git a/arch/powerpc/include/asm/ppc4xx.h b/arch/powerpc/include/asm/ppc4xx.h index 87a16ec..1b98f8b 100644 --- a/arch/powerpc/include/asm/ppc4xx.h +++ b/arch/powerpc/include/asm/ppc4xx.h @@ -79,6 +79,10 @@ #include <asm/ppc460sx.h> #endif
+#if defined(CONFIG_APM821XX) +#include <asm/apm821xx.h> +#endif + /* * Configure which SDRAM/DDR/DDR2 controller is equipped */ diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 84a1e2e..9cafe85 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -916,6 +916,7 @@ #define PVR_460SX_RA_V1 0x13541801 /* 460SX rev A Variant 1 Security disabled */ #define PVR_460GX_RA 0x13541802 /* 460GX rev A */ #define PVR_460GX_RA_V1 0x13541803 /* 460GX rev A Variant 1 Security disabled */ +#define PVR_APM821XX_RA 0x12C41C80 /* APM821XX rev A */ #define PVR_601 0x00010000 #define PVR_602 0x00050000 #define PVR_603 0x00030000
Hi Marri,
Hopefully the last (coding style related) comments below.
<snip>
"RESERVED",
"RESERVED",
"RESERVED",
"NAND (8 bits)",
"NOR (8 bits)",
"I2C (Addr 0x54)",
"I2C (Addr 0x52)",
Indentation with tabs instead of spaces please.
- Copyright (c) 2010, Applied Micro Circuits Corporation
- Author: Tirumala R Marri tmarri@apm.com
- MA 02111-1307 USA
Insert empty line here.
Please use tab instead of spaces for indentation.
Again, empty would look better here.
Tabs vs. spaces again.
Remove one of those empty lines.
Tabs vs spaces again. Please fix globally and resubmit. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
tmarriļ¼ apm.com
