[PATCH 0/3] sunxi: devicetree updates from Linux v6.6
This updates the devicetree files to match the Linux kernel repository as of v6.6-rc6. Mostly cosmetic changes, but we gain some new board files and the T113s board .dtsi files, which are needed for the pending U-Boot patches.
Split per architecture, with the T113s being separate due to its RISC-V relationship.
Andre Przywara (3): sunxi: dts: arm64: update devicetree files from Linux-v6.6-rc6 sunxi: dts: arm: update devicetree files from Linux-v6.6-rc6 sunxi: dts: arm: add T113s/D1 DT files from Linux-v6.6-rc6
arch/arm/dts/axp209.dtsi | 7 + arch/arm/dts/sun50i-a64.dtsi | 3 +- arch/arm/dts/sun50i-h6-pine-h64-model-b.dts | 2 +- arch/arm/dts/sun50i-h616-orangepi-zero.dtsi | 134 +++ arch/arm/dts/sun50i-h616-orangepi-zero2.dts | 121 +-- arch/arm/dts/sun50i-h616-x96-mate.dts | 2 +- arch/arm/dts/sun50i-h618-orangepi-zero3.dts | 94 ++ arch/arm/dts/sun5i-r8-chip.dts | 6 + arch/arm/dts/sun5i.dtsi | 11 +- arch/arm/dts/sun7i-a20-icnova-a20-adb4006.dts | 137 +++ arch/arm/dts/sun7i-a20-icnova-a20.dtsi | 62 ++ arch/arm/dts/sun8i-a23-a33.dtsi | 2 +- arch/arm/dts/sun8i-a83t.dtsi | 2 +- .../arm/dts/sun8i-t113s-mangopi-mq-r-t113.dts | 35 + arch/arm/dts/sun8i-t113s.dtsi | 59 ++ arch/arm/dts/sun8i-v3s.dtsi | 2 +- arch/arm/dts/sunxi-d1s-t113-mangopi-mq-r.dtsi | 126 +++ arch/riscv/dts/sunxi-d1-t113.dtsi | 15 + arch/riscv/dts/sunxi-d1s-t113.dtsi | 927 ++++++++++++++++++ include/dt-bindings/clock/sun20i-d1-ccu.h | 158 +++ include/dt-bindings/clock/sun20i-d1-r-ccu.h | 19 + include/dt-bindings/clock/sun50i-h6-ccu.h | 2 +- include/dt-bindings/clock/sun50i-h616-ccu.h | 2 +- include/dt-bindings/clock/sun6i-rtc.h | 2 +- include/dt-bindings/reset/sun20i-d1-ccu.h | 79 ++ include/dt-bindings/reset/sun20i-d1-r-ccu.h | 16 + include/dt-bindings/reset/sun50i-h6-ccu.h | 2 +- include/dt-bindings/reset/sun50i-h6-r-ccu.h | 2 +- include/dt-bindings/reset/sun50i-h616-ccu.h | 2 +- 29 files changed, 1899 insertions(+), 132 deletions(-) create mode 100644 arch/arm/dts/sun50i-h616-orangepi-zero.dtsi create mode 100644 arch/arm/dts/sun50i-h618-orangepi-zero3.dts create mode 100644 arch/arm/dts/sun7i-a20-icnova-a20-adb4006.dts create mode 100644 arch/arm/dts/sun7i-a20-icnova-a20.dtsi create mode 100644 arch/arm/dts/sun8i-t113s-mangopi-mq-r-t113.dts create mode 100644 arch/arm/dts/sun8i-t113s.dtsi create mode 100644 arch/arm/dts/sunxi-d1s-t113-mangopi-mq-r.dtsi create mode 100644 arch/riscv/dts/sunxi-d1-t113.dtsi create mode 100644 arch/riscv/dts/sunxi-d1s-t113.dtsi create mode 100644 include/dt-bindings/clock/sun20i-d1-ccu.h create mode 100644 include/dt-bindings/clock/sun20i-d1-r-ccu.h create mode 100644 include/dt-bindings/reset/sun20i-d1-ccu.h create mode 100644 include/dt-bindings/reset/sun20i-d1-r-ccu.h
Sync the devicetree files from the official Linux kernel tree, v6.6-rc6. This is covering Allwinner SoCs with 64-bit ARM cores.
Only small cosmetic changes (clock name fixed), but we add the DT for the new OrangePi Zero 3 board, for which U-Boot enablement patches are pending.
As before, this omits the non-backwards compatible changes to the R_INTC controller, to remain compatible with older kernels.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64.dtsi | 3 +- arch/arm/dts/sun50i-h6-pine-h64-model-b.dts | 2 +- arch/arm/dts/sun50i-h616-orangepi-zero.dtsi | 134 ++++++++++++++++++++ arch/arm/dts/sun50i-h616-orangepi-zero2.dts | 121 +----------------- arch/arm/dts/sun50i-h616-x96-mate.dts | 2 +- arch/arm/dts/sun50i-h618-orangepi-zero3.dts | 94 ++++++++++++++ include/dt-bindings/clock/sun50i-h6-ccu.h | 2 +- include/dt-bindings/clock/sun50i-h616-ccu.h | 2 +- include/dt-bindings/clock/sun6i-rtc.h | 2 +- include/dt-bindings/reset/sun50i-h6-ccu.h | 2 +- include/dt-bindings/reset/sun50i-h6-r-ccu.h | 2 +- include/dt-bindings/reset/sun50i-h616-ccu.h | 2 +- 12 files changed, 240 insertions(+), 128 deletions(-) create mode 100644 arch/arm/dts/sun50i-h616-orangepi-zero.dtsi create mode 100644 arch/arm/dts/sun50i-h618-orangepi-zero3.dts
diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index 135762b34fd..2240eaec5dd 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -93,6 +93,7 @@ L2: l2-cache { compatible = "cache"; cache-level = <2>; + cache-unified; }; };
@@ -407,7 +408,7 @@ interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_TCON0>, <&ccu CLK_TCON0>; clock-names = "ahb", "tcon-ch0"; - clock-output-names = "tcon-pixel-clock"; + clock-output-names = "tcon-data-clock"; #clock-cells = <0>; resets = <&ccu RST_BUS_TCON0>, <&ccu RST_BUS_LVDS>; reset-names = "lcd", "lvds"; diff --git a/arch/arm/dts/sun50i-h6-pine-h64-model-b.dts b/arch/arm/dts/sun50i-h6-pine-h64-model-b.dts index 686f58e7700..b710f1a0f53 100644 --- a/arch/arm/dts/sun50i-h6-pine-h64-model-b.dts +++ b/arch/arm/dts/sun50i-h6-pine-h64-model-b.dts @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (C) 2019 Corentin LABBE clabbe@baylibre.com */ diff --git a/arch/arm/dts/sun50i-h616-orangepi-zero.dtsi b/arch/arm/dts/sun50i-h616-orangepi-zero.dtsi new file mode 100644 index 00000000000..15290e6892f --- /dev/null +++ b/arch/arm/dts/sun50i-h616-orangepi-zero.dtsi @@ -0,0 +1,134 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2020 Arm Ltd. + * + * DT nodes common between Orange Pi Zero 2 and Orange Pi Zero 3. + * Excludes PMIC nodes and properties, since they are different between the two. + */ + +#include "sun50i-h616.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/leds/common.h> + +/ { + aliases { + ethernet0 = &emac0; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + + led-0 { + function = LED_FUNCTION_POWER; + color = <LED_COLOR_ID_RED>; + gpios = <&pio 2 12 GPIO_ACTIVE_HIGH>; /* PC12 */ + default-state = "on"; + }; + + led-1 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_GREEN>; + gpios = <&pio 2 13 GPIO_ACTIVE_HIGH>; /* PC13 */ + }; + }; + + reg_vcc5v: vcc5v { + /* board wide 5V supply directly from the USB-C socket */ + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + reg_usb1_vbus: regulator-usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <®_vcc5v>; + enable-active-high; + gpio = <&pio 2 16 GPIO_ACTIVE_HIGH>; /* PC16 */ + }; +}; + +&ehci1 { + status = "okay"; +}; + +/* USB 2 & 3 are on headers only. */ + +&emac0 { + pinctrl-names = "default"; + pinctrl-0 = <&ext_rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + allwinner,rx-delay-ps = <3100>; + allwinner,tx-delay-ps = <700>; + status = "okay"; +}; + +&mdio0 { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + +&mmc0 { + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + bus-width = <4>; + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&spi0_pins>, <&spi0_cs0_pin>; + + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <40000000>; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_ph_pins>; + status = "okay"; +}; + +&usbotg { + /* + * PHY0 pins are connected to a USB-C socket, but a role switch + * is not implemented: both CC pins are pulled to GND. + * The VBUS pins power the device, so a fixed peripheral mode + * is the best choice. + * The board can be powered via GPIOs, in this case port0 *can* + * act as a host (with a cable/adapter ignoring CC), as VBUS is + * then provided by the GPIOs. Any user of this setup would + * need to adjust the DT accordingly: dr_mode set to "host", + * enabling OHCI0 and EHCI0. + */ + dr_mode = "peripheral"; + status = "okay"; +}; + +&usbphy { + usb1_vbus-supply = <®_usb1_vbus>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-h616-orangepi-zero2.dts b/arch/arm/dts/sun50i-h616-orangepi-zero2.dts index cb8600d0ea1..d83852e72f0 100644 --- a/arch/arm/dts/sun50i-h616-orangepi-zero2.dts +++ b/arch/arm/dts/sun50i-h616-orangepi-zero2.dts @@ -1,99 +1,23 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (C) 2020 Arm Ltd. */
/dts-v1/;
-#include "sun50i-h616.dtsi" - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/leds/common.h> +#include "sun50i-h616-orangepi-zero.dtsi"
/ { model = "OrangePi Zero2"; compatible = "xunlong,orangepi-zero2", "allwinner,sun50i-h616"; - - aliases { - ethernet0 = &emac0; - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - leds { - compatible = "gpio-leds"; - - led-0 { - function = LED_FUNCTION_POWER; - color = <LED_COLOR_ID_RED>; - gpios = <&pio 2 12 GPIO_ACTIVE_HIGH>; /* PC12 */ - default-state = "on"; - }; - - led-1 { - function = LED_FUNCTION_STATUS; - color = <LED_COLOR_ID_GREEN>; - gpios = <&pio 2 13 GPIO_ACTIVE_HIGH>; /* PC13 */ - }; - }; - - reg_vcc5v: vcc5v { - /* board wide 5V supply directly from the USB-C socket */ - compatible = "regulator-fixed"; - regulator-name = "vcc-5v"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - }; - - reg_usb1_vbus: regulator-usb1-vbus { - compatible = "regulator-fixed"; - regulator-name = "usb1-vbus"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <®_vcc5v>; - enable-active-high; - gpio = <&pio 2 16 GPIO_ACTIVE_HIGH>; /* PC16 */ - }; };
-&ehci1 { - status = "okay"; -}; - -/* USB 2 & 3 are on headers only. */ - &emac0 { - pinctrl-names = "default"; - pinctrl-0 = <&ext_rgmii_pins>; - phy-mode = "rgmii"; - phy-handle = <&ext_rgmii_phy>; phy-supply = <®_dcdce>; - allwinner,rx-delay-ps = <3100>; - allwinner,tx-delay-ps = <700>; - status = "okay"; -}; - -&mdio0 { - ext_rgmii_phy: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - }; };
&mmc0 { vmmc-supply = <®_dcdce>; - cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ - bus-width = <4>; - status = "okay"; -}; - -&ohci1 { - status = "okay"; };
&r_rsb { @@ -211,44 +135,3 @@ vcc-ph-supply = <®_aldo1>; vcc-pi-supply = <®_aldo1>; }; - -&spi0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&spi0_pins>, <&spi0_cs0_pin>; - - flash@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <40000000>; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_ph_pins>; - status = "okay"; -}; - -&usbotg { - /* - * PHY0 pins are connected to a USB-C socket, but a role switch - * is not implemented: both CC pins are pulled to GND. - * The VBUS pins power the device, so a fixed peripheral mode - * is the best choice. - * The board can be powered via GPIOs, in this case port0 *can* - * act as a host (with a cable/adapter ignoring CC), as VBUS is - * then provided by the GPIOs. Any user of this setup would - * need to adjust the DT accordingly: dr_mode set to "host", - * enabling OHCI0 and EHCI0. - */ - dr_mode = "peripheral"; - status = "okay"; -}; - -&usbphy { - usb1_vbus-supply = <®_usb1_vbus>; - status = "okay"; -}; diff --git a/arch/arm/dts/sun50i-h616-x96-mate.dts b/arch/arm/dts/sun50i-h616-x96-mate.dts index 07424c28b69..959b6fd1848 100644 --- a/arch/arm/dts/sun50i-h616-x96-mate.dts +++ b/arch/arm/dts/sun50i-h616-x96-mate.dts @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (C) 2021 Arm Ltd. */ diff --git a/arch/arm/dts/sun50i-h618-orangepi-zero3.dts b/arch/arm/dts/sun50i-h618-orangepi-zero3.dts new file mode 100644 index 00000000000..00fe28caac9 --- /dev/null +++ b/arch/arm/dts/sun50i-h618-orangepi-zero3.dts @@ -0,0 +1,94 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2023 Arm Ltd. + */ + +/dts-v1/; + +#include "sun50i-h616-orangepi-zero.dtsi" + +/ { + model = "OrangePi Zero3"; + compatible = "xunlong,orangepi-zero3", "allwinner,sun50i-h618"; +}; + +&emac0 { + phy-supply = <®_dldo1>; +}; + +&ext_rgmii_phy { + motorcomm,clk-out-frequency-hz = <125000000>; +}; + +&mmc0 { + /* + * The schematic shows the card detect pin wired up to PF6, via an + * inverter, but it just doesn't work. + */ + broken-cd; + vmmc-supply = <®_dldo1>; +}; + +&r_i2c { + status = "okay"; + + axp313: pmic@36 { + compatible = "x-powers,axp313a"; + reg = <0x36>; + #interrupt-cells = <1>; + interrupt-controller; + interrupt-parent = <&pio>; + interrupts = <2 9 IRQ_TYPE_LEVEL_LOW>; /* PC9 */ + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + + regulators { + /* Supplies VCC-PLL, so needs to be always on. */ + reg_aldo1: aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc1v8"; + }; + + /* Supplies VCC-IO, so needs to be always on. */ + reg_dldo1: dldo1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc3v3"; + }; + + reg_dcdc1: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <810000>; + regulator-max-microvolt = <990000>; + regulator-name = "vdd-gpu-sys"; + }; + + reg_dcdc2: dcdc2 { + regulator-always-on; + regulator-min-microvolt = <810000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpu"; + }; + + reg_dcdc3: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-dram"; + }; + }; + }; +}; + +&pio { + vcc-pc-supply = <®_dldo1>; + vcc-pf-supply = <®_dldo1>; + vcc-pg-supply = <®_aldo1>; + vcc-ph-supply = <®_dldo1>; + vcc-pi-supply = <®_dldo1>; +}; diff --git a/include/dt-bindings/clock/sun50i-h6-ccu.h b/include/dt-bindings/clock/sun50i-h6-ccu.h index a1545cd60e7..ef9123d8193 100644 --- a/include/dt-bindings/clock/sun50i-h6-ccu.h +++ b/include/dt-bindings/clock/sun50i-h6-ccu.h @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ /* * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io */ diff --git a/include/dt-bindings/clock/sun50i-h616-ccu.h b/include/dt-bindings/clock/sun50i-h616-ccu.h index 1191aca53ac..6f8f01e6762 100644 --- a/include/dt-bindings/clock/sun50i-h616-ccu.h +++ b/include/dt-bindings/clock/sun50i-h616-ccu.h @@ -1,4 +1,4 @@ -/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ /* * Copyright (C) 2020 Arm Ltd. */ diff --git a/include/dt-bindings/clock/sun6i-rtc.h b/include/dt-bindings/clock/sun6i-rtc.h index c845493e4d3..3bd3aa3d57c 100644 --- a/include/dt-bindings/clock/sun6i-rtc.h +++ b/include/dt-bindings/clock/sun6i-rtc.h @@ -1,4 +1,4 @@ -/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */
#ifndef _DT_BINDINGS_CLK_SUN6I_RTC_H_ #define _DT_BINDINGS_CLK_SUN6I_RTC_H_ diff --git a/include/dt-bindings/reset/sun50i-h6-ccu.h b/include/dt-bindings/reset/sun50i-h6-ccu.h index 81106f45509..d038ddfa481 100644 --- a/include/dt-bindings/reset/sun50i-h6-ccu.h +++ b/include/dt-bindings/reset/sun50i-h6-ccu.h @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ /* * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io */ diff --git a/include/dt-bindings/reset/sun50i-h6-r-ccu.h b/include/dt-bindings/reset/sun50i-h6-r-ccu.h index 7950e799c76..d541ade884f 100644 --- a/include/dt-bindings/reset/sun50i-h6-r-ccu.h +++ b/include/dt-bindings/reset/sun50i-h6-r-ccu.h @@ -1,4 +1,4 @@ -/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ /* * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz */ diff --git a/include/dt-bindings/reset/sun50i-h616-ccu.h b/include/dt-bindings/reset/sun50i-h616-ccu.h index cb6285a8d12..1bd8bb0a11b 100644 --- a/include/dt-bindings/reset/sun50i-h616-ccu.h +++ b/include/dt-bindings/reset/sun50i-h616-ccu.h @@ -1,4 +1,4 @@ -/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ /* * Copyright (C) 2020 Arm Ltd. */
Sync the devicetree files from the official Linux kernel tree, v6.6-rc6. This is covering Allwinner SoCs with 32-bit ARM cores, minus the T113s board and related .dtsi files, which come separately.
Only small changes: Bluetooth got enabled on the C.H.I.P., and a clock got renamed. More interesting is the addition of a board, for which U-Boot enablement patches are pending.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/axp209.dtsi | 7 + arch/arm/dts/sun5i-r8-chip.dts | 6 + arch/arm/dts/sun5i.dtsi | 11 +- arch/arm/dts/sun7i-a20-icnova-a20-adb4006.dts | 137 ++++++++++++++++++ arch/arm/dts/sun7i-a20-icnova-a20.dtsi | 62 ++++++++ arch/arm/dts/sun8i-a23-a33.dtsi | 2 +- arch/arm/dts/sun8i-a83t.dtsi | 2 +- arch/arm/dts/sun8i-v3s.dtsi | 2 +- 8 files changed, 225 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/sun7i-a20-icnova-a20-adb4006.dts create mode 100644 arch/arm/dts/sun7i-a20-icnova-a20.dtsi
diff --git a/arch/arm/dts/axp209.dtsi b/arch/arm/dts/axp209.dtsi index ca240cd6f6c..469d0f7d518 100644 --- a/arch/arm/dts/axp209.dtsi +++ b/arch/arm/dts/axp209.dtsi @@ -48,6 +48,13 @@ * http://dl.linux-sunxi.org/AXP/AXP209%20Datasheet%20v1.0_cn.pdf */
+/ { + pmic-temp { + compatible = "iio-hwmon"; + io-channels = <&axp_adc 4>; /* Internal temperature */ + }; +}; + &axp209 { compatible = "x-powers,axp209"; interrupt-controller; diff --git a/arch/arm/dts/sun5i-r8-chip.dts b/arch/arm/dts/sun5i-r8-chip.dts index fd37bd1f392..4192c23848c 100644 --- a/arch/arm/dts/sun5i-r8-chip.dts +++ b/arch/arm/dts/sun5i-r8-chip.dts @@ -255,6 +255,12 @@ pinctrl-0 = <&uart3_pg_pins>, <&uart3_cts_rts_pg_pins>; status = "okay"; + + bluetooth { + compatible = "realtek,rtl8723bs-bt"; + device-wake-gpios = <&axp_gpio 3 GPIO_ACTIVE_HIGH>; + host-wake-gpios = <&pio 1 3 GPIO_ACTIVE_HIGH>; /* PB3 */ + }; };
&usb_otg { diff --git a/arch/arm/dts/sun5i.dtsi b/arch/arm/dts/sun5i.dtsi index 250d6b87ab4..d7c7b454a11 100644 --- a/arch/arm/dts/sun5i.dtsi +++ b/arch/arm/dts/sun5i.dtsi @@ -286,7 +286,7 @@ clock-names = "ahb", "tcon-ch0", "tcon-ch1"; - clock-output-names = "tcon-pixel-clock"; + clock-output-names = "tcon-data-clock"; #clock-cells = <0>; status = "disabled";
@@ -517,6 +517,15 @@ bias-pull-up; };
+ /omit-if-no-ref/ + mmc2_4bit_pe_pins: mmc2-4bit-pe-pins { + pins = "PE4", "PE5", "PE6", "PE7", + "PE8", "PE9"; + function = "mmc2"; + drive-strength = <30>; + bias-pull-up; + }; + mmc2_8bit_pins: mmc2-8bit-pins { pins = "PC6", "PC7", "PC8", "PC9", "PC10", "PC11", "PC12", "PC13", diff --git a/arch/arm/dts/sun7i-a20-icnova-a20-adb4006.dts b/arch/arm/dts/sun7i-a20-icnova-a20-adb4006.dts new file mode 100644 index 00000000000..577ead1d02a --- /dev/null +++ b/arch/arm/dts/sun7i-a20-icnova-a20-adb4006.dts @@ -0,0 +1,137 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +// Copyright (C) 2023 In-Circuit GmbH + +/dts-v1/; + +#include "sun7i-a20-icnova-a20.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> + +/ { + model = "In-Circuit ICnova A20 ADB4006"; + compatible = "incircuit,icnova-a20-adb4006", "incircuit,icnova-a20", + "allwinner,sun7i-a20"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + led-0 { + function = LED_FUNCTION_POWER; + color = <LED_COLOR_ID_YELLOW>; + gpios = <&pio 7 21 GPIO_ACTIVE_HIGH>; /* PH21 */ + default-state = "on"; + }; + + led-1 { + function = LED_FUNCTION_HEARTBEAT; + color = <LED_COLOR_ID_RED>; + gpios = <&pio 7 20 GPIO_ACTIVE_HIGH>; /* PH20 */ + linux,default-trigger = "heartbeat"; + }; + }; +}; + +&ahci { + target-supply = <®_ahci_5v>; + status = "okay"; +}; + +&codec { + status = "okay"; +}; + +&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mmc0 { + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&otg_sram { + status = "okay"; +}; + +®_ahci_5v { + status = "okay"; +}; + +&ac_power_supply { + status = "okay"; +}; + +®_usb1_vbus { + status = "okay"; +}; + +®_usb2_vbus { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + usb0_id_det-gpios = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ + usb0_vbus_det-gpios = <&pio 7 5 GPIO_ACTIVE_HIGH>; /* PH5 */ + usb1_vbus-supply = <®_usb1_vbus>; + usb2_vbus-supply = <®_usb2_vbus>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun7i-a20-icnova-a20.dtsi b/arch/arm/dts/sun7i-a20-icnova-a20.dtsi new file mode 100644 index 00000000000..46616c6bc89 --- /dev/null +++ b/arch/arm/dts/sun7i-a20-icnova-a20.dtsi @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +// Copyright (C) 2023 In-Circuit GmbH + +#include "sun7i-a20.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/interrupt-controller/irq.h> + +&cpu0 { + cpu-supply = <®_dcdc2>; +}; + +&gmac { + pinctrl-names = "default"; + pinctrl-0 = <&gmac_mii_pins>; + phy-handle = <&phy1>; + phy-mode = "mii"; + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + axp209: pmic@34 { + reg = <0x34>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +&gmac_mdio { + phy1: ethernet-phy@1 { + reg = <1>; + }; +}; + +#include "axp209.dtsi" + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-int-dll"; +}; + +®_ldo1 { + regulator-name = "vdd-rtc"; +}; + +®_ldo2 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "avcc"; +}; diff --git a/arch/arm/dts/sun8i-a23-a33.dtsi b/arch/arm/dts/sun8i-a23-a33.dtsi index 84c6d9379a3..a0cac966af3 100644 --- a/arch/arm/dts/sun8i-a23-a33.dtsi +++ b/arch/arm/dts/sun8i-a23-a33.dtsi @@ -190,7 +190,7 @@ clock-names = "ahb", "tcon-ch0", "lvds-alt"; - clock-output-names = "tcon-pixel-clock"; + clock-output-names = "tcon-data-clock"; #clock-cells = <0>; resets = <&ccu RST_BUS_LCD>, <&ccu RST_BUS_LVDS>; diff --git a/arch/arm/dts/sun8i-a83t.dtsi b/arch/arm/dts/sun8i-a83t.dtsi index 9c07660080d..cc40622466a 100644 --- a/arch/arm/dts/sun8i-a83t.dtsi +++ b/arch/arm/dts/sun8i-a83t.dtsi @@ -456,7 +456,7 @@ interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_TCON0>, <&ccu CLK_TCON0>; clock-names = "ahb", "tcon-ch0"; - clock-output-names = "tcon-pixel-clock"; + clock-output-names = "tcon-data-clock"; #clock-cells = <0>; resets = <&ccu RST_BUS_TCON0>, <&ccu RST_BUS_LVDS>; reset-names = "lcd", "lvds"; diff --git a/arch/arm/dts/sun8i-v3s.dtsi b/arch/arm/dts/sun8i-v3s.dtsi index b001251644f..3b9a282c274 100644 --- a/arch/arm/dts/sun8i-v3s.dtsi +++ b/arch/arm/dts/sun8i-v3s.dtsi @@ -191,7 +191,7 @@ <&ccu CLK_TCON0>; clock-names = "ahb", "tcon-ch0"; - clock-output-names = "tcon-pixel-clock"; + clock-output-names = "tcon-data-clock"; #clock-cells = <0>; resets = <&ccu RST_BUS_TCON0>; reset-names = "lcd";
This copies in some devicetree files from the official Linux kernel tree, v6.6-rc6. It covers a board with the Allwinner T113s SoC, which shares many devices with its RISC-V sibling, the Allwinner D1(s). This is the reason for the core .dtsi files landing in the arch/riscv directory.
We are only adjusting the include path to accommodate for the differences in the U-Boot build system.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- .../arm/dts/sun8i-t113s-mangopi-mq-r-t113.dts | 35 + arch/arm/dts/sun8i-t113s.dtsi | 59 ++ arch/arm/dts/sunxi-d1s-t113-mangopi-mq-r.dtsi | 126 +++ arch/riscv/dts/sunxi-d1-t113.dtsi | 15 + arch/riscv/dts/sunxi-d1s-t113.dtsi | 927 ++++++++++++++++++ include/dt-bindings/clock/sun20i-d1-ccu.h | 158 +++ include/dt-bindings/clock/sun20i-d1-r-ccu.h | 19 + include/dt-bindings/reset/sun20i-d1-ccu.h | 79 ++ include/dt-bindings/reset/sun20i-d1-r-ccu.h | 16 + 9 files changed, 1434 insertions(+) create mode 100644 arch/arm/dts/sun8i-t113s-mangopi-mq-r-t113.dts create mode 100644 arch/arm/dts/sun8i-t113s.dtsi create mode 100644 arch/arm/dts/sunxi-d1s-t113-mangopi-mq-r.dtsi create mode 100644 arch/riscv/dts/sunxi-d1-t113.dtsi create mode 100644 arch/riscv/dts/sunxi-d1s-t113.dtsi create mode 100644 include/dt-bindings/clock/sun20i-d1-ccu.h create mode 100644 include/dt-bindings/clock/sun20i-d1-r-ccu.h create mode 100644 include/dt-bindings/reset/sun20i-d1-ccu.h create mode 100644 include/dt-bindings/reset/sun20i-d1-r-ccu.h
diff --git a/arch/arm/dts/sun8i-t113s-mangopi-mq-r-t113.dts b/arch/arm/dts/sun8i-t113s-mangopi-mq-r-t113.dts new file mode 100644 index 00000000000..8b3a7538381 --- /dev/null +++ b/arch/arm/dts/sun8i-t113s-mangopi-mq-r-t113.dts @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2022 Arm Ltd. + +#include <dt-bindings/interrupt-controller/irq.h> + +/dts-v1/; + +#include "sun8i-t113s.dtsi" +#include "sunxi-d1s-t113-mangopi-mq-r.dtsi" + +/ { + model = "MangoPi MQ-R-T113"; + compatible = "widora,mangopi-mq-r-t113", "allwinner,sun8i-t113s"; + + aliases { + ethernet0 = &rtl8189ftv; + }; +}; + +&cpu0 { + cpu-supply = <®_vcc_core>; +}; + +&cpu1 { + cpu-supply = <®_vcc_core>; +}; + +&mmc1 { + rtl8189ftv: wifi@1 { + reg = <1>; + interrupt-parent = <&pio>; + interrupts = <6 10 IRQ_TYPE_LEVEL_LOW>; /* PG10 = WL_WAKE_AP */ + interrupt-names = "host-wake"; + }; +}; diff --git a/arch/arm/dts/sun8i-t113s.dtsi b/arch/arm/dts/sun8i-t113s.dtsi new file mode 100644 index 00000000000..b94b69142af --- /dev/null +++ b/arch/arm/dts/sun8i-t113s.dtsi @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2022 Arm Ltd. + +#define SOC_PERIPHERAL_IRQ(nr) GIC_SPI nr + +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <../../riscv/dts/sunxi-d1s-t113.dtsi> +#include <../../riscv/dts/sunxi-d1-t113.dtsi> + +/ { + interrupt-parent = <&gic>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <0>; + clocks = <&ccu CLK_CPUX>; + clock-names = "cpu"; + }; + + cpu1: cpu@1 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <1>; + clocks = <&ccu CLK_CPUX>; + clock-names = "cpu"; + }; + }; + + gic: interrupt-controller@1c81000 { + compatible = "arm,gic-400"; + reg = <0x03021000 0x1000>, + <0x03022000 0x2000>, + <0x03024000 0x2000>, + <0x03026000 0x2000>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + interrupt-controller; + #interrupt-cells = <3>; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + }; + + pmu { + compatible = "arm,cortex-a7-pmu"; + interrupts = <GIC_SPI 172 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>; + }; +}; diff --git a/arch/arm/dts/sunxi-d1s-t113-mangopi-mq-r.dtsi b/arch/arm/dts/sunxi-d1s-t113-mangopi-mq-r.dtsi new file mode 100644 index 00000000000..a415c4a78a7 --- /dev/null +++ b/arch/arm/dts/sunxi-d1s-t113-mangopi-mq-r.dtsi @@ -0,0 +1,126 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2022 Arm Ltd. +/* + * Common peripherals and configurations for MangoPi MQ-R boards. + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> + +/ { + aliases { + serial3 = &uart3; + }; + + chosen { + stdout-path = "serial3:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + + led-0 { + color = <LED_COLOR_ID_BLUE>; + function = LED_FUNCTION_STATUS; + gpios = <&pio 3 22 GPIO_ACTIVE_LOW>; /* PD22 */ + }; + }; + + /* board wide 5V supply directly from the USB-C socket */ + reg_vcc5v: regulator-5v { + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + /* SY8008 DC/DC regulator on the board */ + reg_3v3: regulator-3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <®_vcc5v>; + }; + + /* SY8008 DC/DC regulator on the board, also supplying VDD-SYS */ + reg_vcc_core: regulator-core { + compatible = "regulator-fixed"; + regulator-name = "vcc-core"; + regulator-min-microvolt = <880000>; + regulator-max-microvolt = <880000>; + vin-supply = <®_vcc5v>; + }; + + /* XC6206 LDO on the board */ + reg_avdd2v8: regulator-avdd { + compatible = "regulator-fixed"; + regulator-name = "avdd2v8"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + vin-supply = <®_3v3>; + }; + + wifi_pwrseq: wifi-pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&pio 6 12 GPIO_ACTIVE_LOW>; /* PG12 */ + }; +}; + +&dcxo { + clock-frequency = <24000000>; +}; + +&ehci1 { + status = "okay"; +}; + +&mmc0 { + pinctrl-0 = <&mmc0_pins>; + pinctrl-names = "default"; + vmmc-supply = <®_3v3>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + pinctrl-0 = <&mmc1_pins>; + pinctrl-names = "default"; + vmmc-supply = <®_3v3>; + non-removable; + bus-width = <4>; + mmc-pwrseq = <&wifi_pwrseq>; + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&pio { + vcc-pb-supply = <®_3v3>; + vcc-pd-supply = <®_3v3>; + vcc-pe-supply = <®_avdd2v8>; + vcc-pf-supply = <®_3v3>; + vcc-pg-supply = <®_3v3>; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pb_pins>; + status = "okay"; +}; + +/* The USB-C socket has its CC pins pulled to GND, so is hardwired as a UFP. */ +&usb_otg { + dr_mode = "peripheral"; + status = "okay"; +}; + +&usbphy { + usb1_vbus-supply = <®_vcc5v>; + status = "okay"; +}; diff --git a/arch/riscv/dts/sunxi-d1-t113.dtsi b/arch/riscv/dts/sunxi-d1-t113.dtsi new file mode 100644 index 00000000000..b7156123df5 --- /dev/null +++ b/arch/riscv/dts/sunxi-d1-t113.dtsi @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: (GPL-2.0+ or MIT) +// Copyright (C) 2021-2022 Samuel Holland samuel@sholland.org + +/ { + soc { + dsp_wdt: watchdog@1700400 { + compatible = "allwinner,sun20i-d1-wdt"; + reg = <0x1700400 0x20>; + interrupts = <SOC_PERIPHERAL_IRQ(122) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&dcxo>, <&rtc CLK_OSC32K>; + clock-names = "hosc", "losc"; + status = "reserved"; + }; + }; +}; diff --git a/arch/riscv/dts/sunxi-d1s-t113.dtsi b/arch/riscv/dts/sunxi-d1s-t113.dtsi new file mode 100644 index 00000000000..822f022eec2 --- /dev/null +++ b/arch/riscv/dts/sunxi-d1s-t113.dtsi @@ -0,0 +1,927 @@ +// SPDX-License-Identifier: (GPL-2.0+ or MIT) +// Copyright (C) 2021-2022 Samuel Holland samuel@sholland.org + +#include <dt-bindings/clock/sun6i-rtc.h> +#include <dt-bindings/clock/sun8i-de2.h> +#include <dt-bindings/clock/sun8i-tcon-top.h> +#include <dt-bindings/clock/sun20i-d1-ccu.h> +#include <dt-bindings/clock/sun20i-d1-r-ccu.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/reset/sun8i-de2.h> +#include <dt-bindings/reset/sun20i-d1-ccu.h> +#include <dt-bindings/reset/sun20i-d1-r-ccu.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + + dcxo: dcxo-clk { + compatible = "fixed-clock"; + clock-output-names = "dcxo"; + #clock-cells = <0>; + }; + + de: display-engine { + compatible = "allwinner,sun20i-d1-display-engine"; + allwinner,pipelines = <&mixer0>, <&mixer1>; + status = "disabled"; + }; + + soc { + compatible = "simple-bus"; + ranges; + dma-noncoherent; + #address-cells = <1>; + #size-cells = <1>; + + pio: pinctrl@2000000 { + compatible = "allwinner,sun20i-d1-pinctrl"; + reg = <0x2000000 0x800>; + interrupts = <SOC_PERIPHERAL_IRQ(69) IRQ_TYPE_LEVEL_HIGH>, + <SOC_PERIPHERAL_IRQ(71) IRQ_TYPE_LEVEL_HIGH>, + <SOC_PERIPHERAL_IRQ(73) IRQ_TYPE_LEVEL_HIGH>, + <SOC_PERIPHERAL_IRQ(75) IRQ_TYPE_LEVEL_HIGH>, + <SOC_PERIPHERAL_IRQ(77) IRQ_TYPE_LEVEL_HIGH>, + <SOC_PERIPHERAL_IRQ(79) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_APB0>, + <&dcxo>, + <&rtc CLK_OSC32K>; + clock-names = "apb", "hosc", "losc"; + gpio-controller; + interrupt-controller; + #gpio-cells = <3>; + #interrupt-cells = <3>; + + /omit-if-no-ref/ + can0_pins: can0-pins { + pins = "PB2", "PB3"; + function = "can0"; + }; + + /omit-if-no-ref/ + can1_pins: can1-pins { + pins = "PB4", "PB5"; + function = "can1"; + }; + + /omit-if-no-ref/ + clk_pg11_pin: clk-pg11-pin { + pins = "PG11"; + function = "clk"; + }; + + /omit-if-no-ref/ + dsi_4lane_pins: dsi-4lane-pins { + pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", + "PD6", "PD7", "PD8", "PD9"; + drive-strength = <30>; + function = "dsi"; + }; + + /omit-if-no-ref/ + lcd_rgb666_pins: lcd-rgb666-pins { + pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", + "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", + "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", + "PD18", "PD19", "PD20", "PD21"; + function = "lcd0"; + }; + + /omit-if-no-ref/ + mmc0_pins: mmc0-pins { + pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; + function = "mmc0"; + }; + + /omit-if-no-ref/ + mmc1_pins: mmc1-pins { + pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5"; + function = "mmc1"; + }; + + /omit-if-no-ref/ + mmc2_pins: mmc2-pins { + pins = "PC2", "PC3", "PC4", "PC5", "PC6", "PC7"; + function = "mmc2"; + }; + + /omit-if-no-ref/ + rgmii_pe_pins: rgmii-pe-pins { + pins = "PE0", "PE1", "PE2", "PE3", "PE4", + "PE5", "PE6", "PE7", "PE8", "PE9", + "PE11", "PE12", "PE13", "PE14", "PE15"; + function = "emac"; + }; + + /omit-if-no-ref/ + rmii_pe_pins: rmii-pe-pins { + pins = "PE0", "PE1", "PE2", "PE3", "PE4", + "PE5", "PE6", "PE7", "PE8", "PE9"; + function = "emac"; + }; + + /omit-if-no-ref/ + spi0_pins: spi0-pins { + pins = "PC2", "PC3", "PC4", "PC5"; + function = "spi0"; + }; + + /omit-if-no-ref/ + uart1_pg6_pins: uart1-pg6-pins { + pins = "PG6", "PG7"; + function = "uart1"; + }; + + /omit-if-no-ref/ + uart1_pg8_rts_cts_pins: uart1-pg8-rts-cts-pins { + pins = "PG8", "PG9"; + function = "uart1"; + }; + + /omit-if-no-ref/ + uart3_pb_pins: uart3-pb-pins { + pins = "PB6", "PB7"; + function = "uart3"; + }; + }; + + ccu: clock-controller@2001000 { + compatible = "allwinner,sun20i-d1-ccu"; + reg = <0x2001000 0x1000>; + clocks = <&dcxo>, + <&rtc CLK_OSC32K>, + <&rtc CLK_IOSC>; + clock-names = "hosc", "losc", "iosc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + gpadc: adc@2009000 { + compatible = "allwinner,sun20i-d1-gpadc"; + reg = <0x2009000 0x400>; + clocks = <&ccu CLK_BUS_GPADC>; + resets = <&ccu RST_BUS_GPADC>; + interrupts = <SOC_PERIPHERAL_IRQ(57) IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #io-channel-cells = <1>; + }; + + dmic: dmic@2031000 { + compatible = "allwinner,sun20i-d1-dmic", + "allwinner,sun50i-h6-dmic"; + reg = <0x2031000 0x400>; + interrupts = <SOC_PERIPHERAL_IRQ(24) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DMIC>, + <&ccu CLK_DMIC>; + clock-names = "bus", "mod"; + resets = <&ccu RST_BUS_DMIC>; + dmas = <&dma 8>; + dma-names = "rx"; + status = "disabled"; + #sound-dai-cells = <0>; + }; + + i2s1: i2s@2033000 { + compatible = "allwinner,sun20i-d1-i2s", + "allwinner,sun50i-r329-i2s"; + reg = <0x2033000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(27) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2S1>, + <&ccu CLK_I2S1>; + clock-names = "apb", "mod"; + resets = <&ccu RST_BUS_I2S1>; + dmas = <&dma 4>, <&dma 4>; + dma-names = "rx", "tx"; + status = "disabled"; + #sound-dai-cells = <0>; + }; + + i2s2: i2s@2034000 { + compatible = "allwinner,sun20i-d1-i2s", + "allwinner,sun50i-r329-i2s"; + reg = <0x2034000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(28) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2S2>, + <&ccu CLK_I2S2>; + clock-names = "apb", "mod"; + resets = <&ccu RST_BUS_I2S2>; + dmas = <&dma 5>, <&dma 5>; + dma-names = "rx", "tx"; + status = "disabled"; + #sound-dai-cells = <0>; + }; + + timer: timer@2050000 { + compatible = "allwinner,sun20i-d1-timer", + "allwinner,sun8i-a23-timer"; + reg = <0x2050000 0xa0>; + interrupts = <SOC_PERIPHERAL_IRQ(59) IRQ_TYPE_LEVEL_HIGH>, + <SOC_PERIPHERAL_IRQ(60) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&dcxo>; + }; + + wdt: watchdog@20500a0 { + compatible = "allwinner,sun20i-d1-wdt-reset", + "allwinner,sun20i-d1-wdt"; + reg = <0x20500a0 0x20>; + interrupts = <SOC_PERIPHERAL_IRQ(63) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&dcxo>, <&rtc CLK_OSC32K>; + clock-names = "hosc", "losc"; + status = "reserved"; + }; + + uart0: serial@2500000 { + compatible = "snps,dw-apb-uart"; + reg = <0x2500000 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupts = <SOC_PERIPHERAL_IRQ(2) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_UART0>; + resets = <&ccu RST_BUS_UART0>; + dmas = <&dma 14>, <&dma 14>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart1: serial@2500400 { + compatible = "snps,dw-apb-uart"; + reg = <0x2500400 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupts = <SOC_PERIPHERAL_IRQ(3) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_UART1>; + resets = <&ccu RST_BUS_UART1>; + dmas = <&dma 15>, <&dma 15>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart2: serial@2500800 { + compatible = "snps,dw-apb-uart"; + reg = <0x2500800 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupts = <SOC_PERIPHERAL_IRQ(4) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_UART2>; + resets = <&ccu RST_BUS_UART2>; + dmas = <&dma 16>, <&dma 16>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart3: serial@2500c00 { + compatible = "snps,dw-apb-uart"; + reg = <0x2500c00 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupts = <SOC_PERIPHERAL_IRQ(5) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_UART3>; + resets = <&ccu RST_BUS_UART3>; + dmas = <&dma 17>, <&dma 17>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart4: serial@2501000 { + compatible = "snps,dw-apb-uart"; + reg = <0x2501000 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupts = <SOC_PERIPHERAL_IRQ(6) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_UART4>; + resets = <&ccu RST_BUS_UART4>; + dmas = <&dma 18>, <&dma 18>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart5: serial@2501400 { + compatible = "snps,dw-apb-uart"; + reg = <0x2501400 0x400>; + reg-io-width = <4>; + reg-shift = <2>; + interrupts = <SOC_PERIPHERAL_IRQ(7) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_UART5>; + resets = <&ccu RST_BUS_UART5>; + dmas = <&dma 19>, <&dma 19>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + i2c0: i2c@2502000 { + compatible = "allwinner,sun20i-d1-i2c", + "allwinner,sun8i-v536-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x2502000 0x400>; + interrupts = <SOC_PERIPHERAL_IRQ(9) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C0>; + resets = <&ccu RST_BUS_I2C0>; + dmas = <&dma 43>, <&dma 43>; + dma-names = "rx", "tx"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1: i2c@2502400 { + compatible = "allwinner,sun20i-d1-i2c", + "allwinner,sun8i-v536-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x2502400 0x400>; + interrupts = <SOC_PERIPHERAL_IRQ(10) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C1>; + resets = <&ccu RST_BUS_I2C1>; + dmas = <&dma 44>, <&dma 44>; + dma-names = "rx", "tx"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c2: i2c@2502800 { + compatible = "allwinner,sun20i-d1-i2c", + "allwinner,sun8i-v536-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x2502800 0x400>; + interrupts = <SOC_PERIPHERAL_IRQ(11) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C2>; + resets = <&ccu RST_BUS_I2C2>; + dmas = <&dma 45>, <&dma 45>; + dma-names = "rx", "tx"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c3: i2c@2502c00 { + compatible = "allwinner,sun20i-d1-i2c", + "allwinner,sun8i-v536-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x2502c00 0x400>; + interrupts = <SOC_PERIPHERAL_IRQ(12) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C3>; + resets = <&ccu RST_BUS_I2C3>; + dmas = <&dma 46>, <&dma 46>; + dma-names = "rx", "tx"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + can0: can@2504000 { + compatible = "allwinner,sun20i-d1-can"; + reg = <0x02504000 0x400>; + interrupts = <SOC_PERIPHERAL_IRQ(21) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_CAN0>; + resets = <&ccu RST_BUS_CAN0>; + pinctrl-names = "default"; + pinctrl-0 = <&can0_pins>; + status = "disabled"; + }; + + can1: can@2504400 { + compatible = "allwinner,sun20i-d1-can"; + reg = <0x02504400 0x400>; + interrupts = <SOC_PERIPHERAL_IRQ(22) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_CAN1>; + resets = <&ccu RST_BUS_CAN1>; + pinctrl-names = "default"; + pinctrl-0 = <&can1_pins>; + status = "disabled"; + }; + + syscon: syscon@3000000 { + compatible = "allwinner,sun20i-d1-system-control"; + reg = <0x3000000 0x1000>; + ranges; + #address-cells = <1>; + #size-cells = <1>; + }; + + dma: dma-controller@3002000 { + compatible = "allwinner,sun20i-d1-dma"; + reg = <0x3002000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(50) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DMA>, <&ccu CLK_MBUS_DMA>; + clock-names = "bus", "mbus"; + resets = <&ccu RST_BUS_DMA>; + dma-channels = <16>; + dma-requests = <48>; + #dma-cells = <1>; + }; + + sid: efuse@3006000 { + compatible = "allwinner,sun20i-d1-sid"; + reg = <0x3006000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + }; + + crypto: crypto@3040000 { + compatible = "allwinner,sun20i-d1-crypto"; + reg = <0x3040000 0x800>; + interrupts = <SOC_PERIPHERAL_IRQ(52) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_CE>, + <&ccu CLK_CE>, + <&ccu CLK_MBUS_CE>, + <&rtc CLK_IOSC>; + clock-names = "bus", "mod", "ram", "trng"; + resets = <&ccu RST_BUS_CE>; + }; + + mbus: dram-controller@3102000 { + compatible = "allwinner,sun20i-d1-mbus"; + reg = <0x3102000 0x1000>, + <0x3103000 0x1000>; + reg-names = "mbus", "dram"; + interrupts = <SOC_PERIPHERAL_IRQ(43) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_MBUS>, + <&ccu CLK_DRAM>, + <&ccu CLK_BUS_DRAM>; + clock-names = "mbus", "dram", "bus"; + dma-ranges = <0 0x40000000 0x80000000>; + #address-cells = <1>; + #size-cells = <1>; + #interconnect-cells = <1>; + }; + + mmc0: mmc@4020000 { + compatible = "allwinner,sun20i-d1-mmc"; + reg = <0x4020000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(40) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_MMC0>, <&ccu CLK_MMC0>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC0>; + reset-names = "ahb"; + cap-sd-highspeed; + max-frequency = <150000000>; + no-mmc; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc1: mmc@4021000 { + compatible = "allwinner,sun20i-d1-mmc"; + reg = <0x4021000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(41) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_MMC1>, <&ccu CLK_MMC1>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC1>; + reset-names = "ahb"; + cap-sd-highspeed; + max-frequency = <150000000>; + no-mmc; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc2: mmc@4022000 { + compatible = "allwinner,sun20i-d1-emmc", + "allwinner,sun50i-a100-emmc"; + reg = <0x4022000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(42) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_MMC2>, <&ccu CLK_MMC2>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC2>; + reset-names = "ahb"; + cap-mmc-highspeed; + max-frequency = <150000000>; + mmc-ddr-1_8v; + mmc-ddr-3_3v; + no-sd; + no-sdio; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + spi0: spi@4025000 { + compatible = "allwinner,sun20i-d1-spi", + "allwinner,sun50i-r329-spi"; + reg = <0x04025000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(15) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>; + clock-names = "ahb", "mod"; + dmas = <&dma 22>, <&dma 22>; + dma-names = "rx", "tx"; + resets = <&ccu RST_BUS_SPI0>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + spi1: spi@4026000 { + compatible = "allwinner,sun20i-d1-spi-dbi", + "allwinner,sun50i-r329-spi-dbi", + "allwinner,sun50i-r329-spi"; + reg = <0x04026000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(16) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_SPI1>; + clock-names = "ahb", "mod"; + dmas = <&dma 23>, <&dma 23>; + dma-names = "rx", "tx"; + resets = <&ccu RST_BUS_SPI1>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + usb_otg: usb@4100000 { + compatible = "allwinner,sun20i-d1-musb", + "allwinner,sun8i-a33-musb"; + reg = <0x4100000 0x400>; + interrupts = <SOC_PERIPHERAL_IRQ(29) IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + clocks = <&ccu CLK_BUS_OTG>; + resets = <&ccu RST_BUS_OTG>; + extcon = <&usbphy 0>; + phys = <&usbphy 0>; + phy-names = "usb"; + status = "disabled"; + }; + + usbphy: phy@4100400 { + compatible = "allwinner,sun20i-d1-usb-phy"; + reg = <0x4100400 0x100>, + <0x4101800 0x100>, + <0x4200800 0x100>; + reg-names = "phy_ctrl", + "pmu0", + "pmu1"; + clocks = <&dcxo>, + <&dcxo>; + clock-names = "usb0_phy", + "usb1_phy"; + resets = <&ccu RST_USB_PHY0>, + <&ccu RST_USB_PHY1>; + reset-names = "usb0_reset", + "usb1_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + + ehci0: usb@4101000 { + compatible = "allwinner,sun20i-d1-ehci", + "generic-ehci"; + reg = <0x4101000 0x100>; + interrupts = <SOC_PERIPHERAL_IRQ(30) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI0>, + <&ccu CLK_BUS_EHCI0>, + <&ccu CLK_USB_OHCI0>; + resets = <&ccu RST_BUS_OHCI0>, + <&ccu RST_BUS_EHCI0>; + phys = <&usbphy 0>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci0: usb@4101400 { + compatible = "allwinner,sun20i-d1-ohci", + "generic-ohci"; + reg = <0x4101400 0x100>; + interrupts = <SOC_PERIPHERAL_IRQ(31) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI0>, + <&ccu CLK_USB_OHCI0>; + resets = <&ccu RST_BUS_OHCI0>; + phys = <&usbphy 0>; + phy-names = "usb"; + status = "disabled"; + }; + + ehci1: usb@4200000 { + compatible = "allwinner,sun20i-d1-ehci", + "generic-ehci"; + reg = <0x4200000 0x100>; + interrupts = <SOC_PERIPHERAL_IRQ(33) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI1>, + <&ccu CLK_BUS_EHCI1>, + <&ccu CLK_USB_OHCI1>; + resets = <&ccu RST_BUS_OHCI1>, + <&ccu RST_BUS_EHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci1: usb@4200400 { + compatible = "allwinner,sun20i-d1-ohci", + "generic-ohci"; + reg = <0x4200400 0x100>; + interrupts = <SOC_PERIPHERAL_IRQ(34) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI1>, + <&ccu CLK_USB_OHCI1>; + resets = <&ccu RST_BUS_OHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + emac: ethernet@4500000 { + compatible = "allwinner,sun20i-d1-emac", + "allwinner,sun50i-a64-emac"; + reg = <0x4500000 0x10000>; + interrupts = <SOC_PERIPHERAL_IRQ(46) IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + clocks = <&ccu CLK_BUS_EMAC>; + clock-names = "stmmaceth"; + resets = <&ccu RST_BUS_EMAC>; + reset-names = "stmmaceth"; + syscon = <&syscon>; + status = "disabled"; + + mdio: mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + display_clocks: clock-controller@5000000 { + compatible = "allwinner,sun20i-d1-de2-clk", + "allwinner,sun50i-h5-de2-clk"; + reg = <0x5000000 0x10000>; + clocks = <&ccu CLK_BUS_DE>, <&ccu CLK_DE>; + clock-names = "bus", "mod"; + resets = <&ccu RST_BUS_DE>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + mixer0: mixer@5100000 { + compatible = "allwinner,sun20i-d1-de2-mixer-0"; + reg = <0x5100000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER0>, + <&display_clocks CLK_MIXER0>; + clock-names = "bus", "mod"; + resets = <&display_clocks RST_MIXER0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer0_out: port@1 { + reg = <1>; + + mixer0_out_tcon_top_mixer0: endpoint { + remote-endpoint = <&tcon_top_mixer0_in_mixer0>; + }; + }; + }; + }; + + mixer1: mixer@5200000 { + compatible = "allwinner,sun20i-d1-de2-mixer-1"; + reg = <0x5200000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER1>, + <&display_clocks CLK_MIXER1>; + clock-names = "bus", "mod"; + resets = <&display_clocks RST_MIXER1>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer1_out: port@1 { + reg = <1>; + + mixer1_out_tcon_top_mixer1: endpoint { + remote-endpoint = <&tcon_top_mixer1_in_mixer1>; + }; + }; + }; + }; + + dsi: dsi@5450000 { + compatible = "allwinner,sun20i-d1-mipi-dsi", + "allwinner,sun50i-a100-mipi-dsi"; + reg = <0x5450000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(92) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_MIPI_DSI>, + <&tcon_top CLK_TCON_TOP_DSI>; + clock-names = "bus", "mod"; + resets = <&ccu RST_BUS_MIPI_DSI>; + phys = <&dphy>; + phy-names = "dphy"; + status = "disabled"; + + port { + dsi_in_tcon_lcd0: endpoint { + remote-endpoint = <&tcon_lcd0_out_dsi>; + }; + }; + }; + + dphy: phy@5451000 { + compatible = "allwinner,sun20i-d1-mipi-dphy", + "allwinner,sun50i-a100-mipi-dphy"; + reg = <0x5451000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(92) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_MIPI_DSI>, + <&ccu CLK_MIPI_DSI>; + clock-names = "bus", "mod"; + resets = <&ccu RST_BUS_MIPI_DSI>; + #phy-cells = <0>; + }; + + tcon_top: tcon-top@5460000 { + compatible = "allwinner,sun20i-d1-tcon-top"; + reg = <0x5460000 0x1000>; + clocks = <&ccu CLK_BUS_DPSS_TOP>, + <&ccu CLK_TCON_TV>, + <&ccu CLK_TVE>, + <&ccu CLK_TCON_LCD0>; + clock-names = "bus", "tcon-tv0", "tve0", "dsi"; + clock-output-names = "tcon-top-tv0", "tcon-top-dsi"; + resets = <&ccu RST_BUS_DPSS_TOP>; + #clock-cells = <1>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon_top_mixer0_in: port@0 { + reg = <0>; + + tcon_top_mixer0_in_mixer0: endpoint { + remote-endpoint = <&mixer0_out_tcon_top_mixer0>; + }; + }; + + tcon_top_mixer0_out: port@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + tcon_top_mixer0_out_tcon_lcd0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon_lcd0_in_tcon_top_mixer0>; + }; + + tcon_top_mixer0_out_tcon_tv0: endpoint@2 { + reg = <2>; + remote-endpoint = <&tcon_tv0_in_tcon_top_mixer0>; + }; + }; + + tcon_top_mixer1_in: port@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + + tcon_top_mixer1_in_mixer1: endpoint@1 { + reg = <1>; + remote-endpoint = <&mixer1_out_tcon_top_mixer1>; + }; + }; + + tcon_top_mixer1_out: port@3 { + reg = <3>; + #address-cells = <1>; + #size-cells = <0>; + + tcon_top_mixer1_out_tcon_lcd0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon_lcd0_in_tcon_top_mixer1>; + }; + + tcon_top_mixer1_out_tcon_tv0: endpoint@2 { + reg = <2>; + remote-endpoint = <&tcon_tv0_in_tcon_top_mixer1>; + }; + }; + + tcon_top_hdmi_in: port@4 { + reg = <4>; + + tcon_top_hdmi_in_tcon_tv0: endpoint { + remote-endpoint = <&tcon_tv0_out_tcon_top_hdmi>; + }; + }; + + tcon_top_hdmi_out: port@5 { + reg = <5>; + }; + }; + }; + + tcon_lcd0: lcd-controller@5461000 { + compatible = "allwinner,sun20i-d1-tcon-lcd"; + reg = <0x5461000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(90) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON_LCD0>, + <&ccu CLK_TCON_LCD0>; + clock-names = "ahb", "tcon-ch0"; + clock-output-names = "tcon-pixel-clock"; + resets = <&ccu RST_BUS_TCON_LCD0>, + <&ccu RST_BUS_LVDS0>; + reset-names = "lcd", "lvds"; + #clock-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon_lcd0_in: port@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + + tcon_lcd0_in_tcon_top_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon_top_mixer0_out_tcon_lcd0>; + }; + + tcon_lcd0_in_tcon_top_mixer1: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_top_mixer1_out_tcon_lcd0>; + }; + }; + + tcon_lcd0_out: port@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + tcon_lcd0_out_dsi: endpoint@1 { + reg = <1>; + remote-endpoint = <&dsi_in_tcon_lcd0>; + }; + }; + }; + }; + + tcon_tv0: lcd-controller@5470000 { + compatible = "allwinner,sun20i-d1-tcon-tv"; + reg = <0x5470000 0x1000>; + interrupts = <SOC_PERIPHERAL_IRQ(91) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON_TV>, + <&tcon_top CLK_TCON_TOP_TV0>; + clock-names = "ahb", "tcon-ch1"; + resets = <&ccu RST_BUS_TCON_TV>; + reset-names = "lcd"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon_tv0_in: port@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + + tcon_tv0_in_tcon_top_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon_top_mixer0_out_tcon_tv0>; + }; + + tcon_tv0_in_tcon_top_mixer1: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_top_mixer1_out_tcon_tv0>; + }; + }; + + tcon_tv0_out: port@1 { + reg = <1>; + + tcon_tv0_out_tcon_top_hdmi: endpoint { + remote-endpoint = <&tcon_top_hdmi_in_tcon_tv0>; + }; + }; + }; + }; + + ppu: power-controller@7001000 { + compatible = "allwinner,sun20i-d1-ppu"; + reg = <0x7001000 0x1000>; + clocks = <&r_ccu CLK_BUS_R_PPU>; + resets = <&r_ccu RST_BUS_R_PPU>; + #power-domain-cells = <1>; + }; + + r_ccu: clock-controller@7010000 { + compatible = "allwinner,sun20i-d1-r-ccu"; + reg = <0x7010000 0x400>; + clocks = <&dcxo>, + <&rtc CLK_OSC32K>, + <&rtc CLK_IOSC>, + <&ccu CLK_PLL_PERIPH0_DIV3>; + clock-names = "hosc", "losc", "iosc", "pll-periph"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + rtc: rtc@7090000 { + compatible = "allwinner,sun20i-d1-rtc", + "allwinner,sun50i-r329-rtc"; + reg = <0x7090000 0x400>; + interrupts = <SOC_PERIPHERAL_IRQ(144) IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu CLK_BUS_R_RTC>, + <&dcxo>, + <&r_ccu CLK_R_AHB>; + clock-names = "bus", "hosc", "ahb"; + #clock-cells = <1>; + }; + }; +}; diff --git a/include/dt-bindings/clock/sun20i-d1-ccu.h b/include/dt-bindings/clock/sun20i-d1-ccu.h new file mode 100644 index 00000000000..fdbfb404f92 --- /dev/null +++ b/include/dt-bindings/clock/sun20i-d1-ccu.h @@ -0,0 +1,158 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (C) 2020 huangzhenwei@allwinnertech.com + * Copyright (C) 2021 Samuel Holland samuel@sholland.org + */ + +#ifndef _DT_BINDINGS_CLK_SUN20I_D1_CCU_H_ +#define _DT_BINDINGS_CLK_SUN20I_D1_CCU_H_ + +#define CLK_PLL_CPUX 0 +#define CLK_PLL_DDR0 1 +#define CLK_PLL_PERIPH0_4X 2 +#define CLK_PLL_PERIPH0_2X 3 +#define CLK_PLL_PERIPH0_800M 4 +#define CLK_PLL_PERIPH0 5 +#define CLK_PLL_PERIPH0_DIV3 6 +#define CLK_PLL_VIDEO0_4X 7 +#define CLK_PLL_VIDEO0_2X 8 +#define CLK_PLL_VIDEO0 9 +#define CLK_PLL_VIDEO1_4X 10 +#define CLK_PLL_VIDEO1_2X 11 +#define CLK_PLL_VIDEO1 12 +#define CLK_PLL_VE 13 +#define CLK_PLL_AUDIO0_4X 14 +#define CLK_PLL_AUDIO0_2X 15 +#define CLK_PLL_AUDIO0 16 +#define CLK_PLL_AUDIO1 17 +#define CLK_PLL_AUDIO1_DIV2 18 +#define CLK_PLL_AUDIO1_DIV5 19 +#define CLK_CPUX 20 +#define CLK_CPUX_AXI 21 +#define CLK_CPUX_APB 22 +#define CLK_PSI_AHB 23 +#define CLK_APB0 24 +#define CLK_APB1 25 +#define CLK_MBUS 26 +#define CLK_DE 27 +#define CLK_BUS_DE 28 +#define CLK_DI 29 +#define CLK_BUS_DI 30 +#define CLK_G2D 31 +#define CLK_BUS_G2D 32 +#define CLK_CE 33 +#define CLK_BUS_CE 34 +#define CLK_VE 35 +#define CLK_BUS_VE 36 +#define CLK_BUS_DMA 37 +#define CLK_BUS_MSGBOX0 38 +#define CLK_BUS_MSGBOX1 39 +#define CLK_BUS_MSGBOX2 40 +#define CLK_BUS_SPINLOCK 41 +#define CLK_BUS_HSTIMER 42 +#define CLK_AVS 43 +#define CLK_BUS_DBG 44 +#define CLK_BUS_PWM 45 +#define CLK_BUS_IOMMU 46 +#define CLK_DRAM 47 +#define CLK_MBUS_DMA 48 +#define CLK_MBUS_VE 49 +#define CLK_MBUS_CE 50 +#define CLK_MBUS_TVIN 51 +#define CLK_MBUS_CSI 52 +#define CLK_MBUS_G2D 53 +#define CLK_MBUS_RISCV 54 +#define CLK_BUS_DRAM 55 +#define CLK_MMC0 56 +#define CLK_MMC1 57 +#define CLK_MMC2 58 +#define CLK_BUS_MMC0 59 +#define CLK_BUS_MMC1 60 +#define CLK_BUS_MMC2 61 +#define CLK_BUS_UART0 62 +#define CLK_BUS_UART1 63 +#define CLK_BUS_UART2 64 +#define CLK_BUS_UART3 65 +#define CLK_BUS_UART4 66 +#define CLK_BUS_UART5 67 +#define CLK_BUS_I2C0 68 +#define CLK_BUS_I2C1 69 +#define CLK_BUS_I2C2 70 +#define CLK_BUS_I2C3 71 +#define CLK_SPI0 72 +#define CLK_SPI1 73 +#define CLK_BUS_SPI0 74 +#define CLK_BUS_SPI1 75 +#define CLK_EMAC_25M 76 +#define CLK_BUS_EMAC 77 +#define CLK_IR_TX 78 +#define CLK_BUS_IR_TX 79 +#define CLK_BUS_GPADC 80 +#define CLK_BUS_THS 81 +#define CLK_I2S0 82 +#define CLK_I2S1 83 +#define CLK_I2S2 84 +#define CLK_I2S2_ASRC 85 +#define CLK_BUS_I2S0 86 +#define CLK_BUS_I2S1 87 +#define CLK_BUS_I2S2 88 +#define CLK_SPDIF_TX 89 +#define CLK_SPDIF_RX 90 +#define CLK_BUS_SPDIF 91 +#define CLK_DMIC 92 +#define CLK_BUS_DMIC 93 +#define CLK_AUDIO_DAC 94 +#define CLK_AUDIO_ADC 95 +#define CLK_BUS_AUDIO 96 +#define CLK_USB_OHCI0 97 +#define CLK_USB_OHCI1 98 +#define CLK_BUS_OHCI0 99 +#define CLK_BUS_OHCI1 100 +#define CLK_BUS_EHCI0 101 +#define CLK_BUS_EHCI1 102 +#define CLK_BUS_OTG 103 +#define CLK_BUS_LRADC 104 +#define CLK_BUS_DPSS_TOP 105 +#define CLK_HDMI_24M 106 +#define CLK_HDMI_CEC_32K 107 +#define CLK_HDMI_CEC 108 +#define CLK_BUS_HDMI 109 +#define CLK_MIPI_DSI 110 +#define CLK_BUS_MIPI_DSI 111 +#define CLK_TCON_LCD0 112 +#define CLK_BUS_TCON_LCD0 113 +#define CLK_TCON_TV 114 +#define CLK_BUS_TCON_TV 115 +#define CLK_TVE 116 +#define CLK_BUS_TVE_TOP 117 +#define CLK_BUS_TVE 118 +#define CLK_TVD 119 +#define CLK_BUS_TVD_TOP 120 +#define CLK_BUS_TVD 121 +#define CLK_LEDC 122 +#define CLK_BUS_LEDC 123 +#define CLK_CSI_TOP 124 +#define CLK_CSI_MCLK 125 +#define CLK_BUS_CSI 126 +#define CLK_TPADC 127 +#define CLK_BUS_TPADC 128 +#define CLK_BUS_TZMA 129 +#define CLK_DSP 130 +#define CLK_BUS_DSP_CFG 131 +#define CLK_RISCV 132 +#define CLK_RISCV_AXI 133 +#define CLK_BUS_RISCV_CFG 134 +#define CLK_FANOUT_24M 135 +#define CLK_FANOUT_12M 136 +#define CLK_FANOUT_16M 137 +#define CLK_FANOUT_25M 138 +#define CLK_FANOUT_32K 139 +#define CLK_FANOUT_27M 140 +#define CLK_FANOUT_PCLK 141 +#define CLK_FANOUT0 142 +#define CLK_FANOUT1 143 +#define CLK_FANOUT2 144 +#define CLK_BUS_CAN0 145 +#define CLK_BUS_CAN1 146 + +#endif /* _DT_BINDINGS_CLK_SUN20I_D1_CCU_H_ */ diff --git a/include/dt-bindings/clock/sun20i-d1-r-ccu.h b/include/dt-bindings/clock/sun20i-d1-r-ccu.h new file mode 100644 index 00000000000..f95c170711e --- /dev/null +++ b/include/dt-bindings/clock/sun20i-d1-r-ccu.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (C) 2021 Samuel Holland samuel@sholland.org + */ + +#ifndef _DT_BINDINGS_CLK_SUN20I_D1_R_CCU_H_ +#define _DT_BINDINGS_CLK_SUN20I_D1_R_CCU_H_ + +#define CLK_R_AHB 0 + +#define CLK_BUS_R_TIMER 2 +#define CLK_BUS_R_TWD 3 +#define CLK_BUS_R_PPU 4 +#define CLK_R_IR_RX 5 +#define CLK_BUS_R_IR_RX 6 +#define CLK_BUS_R_RTC 7 +#define CLK_BUS_R_CPUCFG 8 + +#endif /* _DT_BINDINGS_CLK_SUN20I_D1_R_CCU_H_ */ diff --git a/include/dt-bindings/reset/sun20i-d1-ccu.h b/include/dt-bindings/reset/sun20i-d1-ccu.h new file mode 100644 index 00000000000..79e52aca591 --- /dev/null +++ b/include/dt-bindings/reset/sun20i-d1-ccu.h @@ -0,0 +1,79 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2020 huangzhenwei@allwinnertech.com + * Copyright (C) 2021 Samuel Holland samuel@sholland.org + */ + +#ifndef _DT_BINDINGS_RST_SUN20I_D1_CCU_H_ +#define _DT_BINDINGS_RST_SUN20I_D1_CCU_H_ + +#define RST_MBUS 0 +#define RST_BUS_DE 1 +#define RST_BUS_DI 2 +#define RST_BUS_G2D 3 +#define RST_BUS_CE 4 +#define RST_BUS_VE 5 +#define RST_BUS_DMA 6 +#define RST_BUS_MSGBOX0 7 +#define RST_BUS_MSGBOX1 8 +#define RST_BUS_MSGBOX2 9 +#define RST_BUS_SPINLOCK 10 +#define RST_BUS_HSTIMER 11 +#define RST_BUS_DBG 12 +#define RST_BUS_PWM 13 +#define RST_BUS_DRAM 14 +#define RST_BUS_MMC0 15 +#define RST_BUS_MMC1 16 +#define RST_BUS_MMC2 17 +#define RST_BUS_UART0 18 +#define RST_BUS_UART1 19 +#define RST_BUS_UART2 20 +#define RST_BUS_UART3 21 +#define RST_BUS_UART4 22 +#define RST_BUS_UART5 23 +#define RST_BUS_I2C0 24 +#define RST_BUS_I2C1 25 +#define RST_BUS_I2C2 26 +#define RST_BUS_I2C3 27 +#define RST_BUS_SPI0 28 +#define RST_BUS_SPI1 29 +#define RST_BUS_EMAC 30 +#define RST_BUS_IR_TX 31 +#define RST_BUS_GPADC 32 +#define RST_BUS_THS 33 +#define RST_BUS_I2S0 34 +#define RST_BUS_I2S1 35 +#define RST_BUS_I2S2 36 +#define RST_BUS_SPDIF 37 +#define RST_BUS_DMIC 38 +#define RST_BUS_AUDIO 39 +#define RST_USB_PHY0 40 +#define RST_USB_PHY1 41 +#define RST_BUS_OHCI0 42 +#define RST_BUS_OHCI1 43 +#define RST_BUS_EHCI0 44 +#define RST_BUS_EHCI1 45 +#define RST_BUS_OTG 46 +#define RST_BUS_LRADC 47 +#define RST_BUS_DPSS_TOP 48 +#define RST_BUS_HDMI_SUB 49 +#define RST_BUS_HDMI_MAIN 50 +#define RST_BUS_MIPI_DSI 51 +#define RST_BUS_TCON_LCD0 52 +#define RST_BUS_TCON_TV 53 +#define RST_BUS_LVDS0 54 +#define RST_BUS_TVE 55 +#define RST_BUS_TVE_TOP 56 +#define RST_BUS_TVD 57 +#define RST_BUS_TVD_TOP 58 +#define RST_BUS_LEDC 59 +#define RST_BUS_CSI 60 +#define RST_BUS_TPADC 61 +#define RST_DSP 62 +#define RST_BUS_DSP_CFG 63 +#define RST_BUS_DSP_DBG 64 +#define RST_BUS_RISCV_CFG 65 +#define RST_BUS_CAN0 66 +#define RST_BUS_CAN1 67 + +#endif /* _DT_BINDINGS_RST_SUN20I_D1_CCU_H_ */ diff --git a/include/dt-bindings/reset/sun20i-d1-r-ccu.h b/include/dt-bindings/reset/sun20i-d1-r-ccu.h new file mode 100644 index 00000000000..e20babc990a --- /dev/null +++ b/include/dt-bindings/reset/sun20i-d1-r-ccu.h @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (C) 2021 Samuel Holland samuel@sholland.org + */ + +#ifndef _DT_BINDINGS_RST_SUN20I_D1_R_CCU_H_ +#define _DT_BINDINGS_RST_SUN20I_D1_R_CCU_H_ + +#define RST_BUS_R_TIMER 0 +#define RST_BUS_R_TWD 1 +#define RST_BUS_R_PPU 2 +#define RST_BUS_R_IR_RX 3 +#define RST_BUS_R_RTC 4 +#define RST_BUS_R_CPUCFG 5 + +#endif /* _DT_BINDINGS_RST_SUN20I_D1_R_CCU_H_ */
On Friday, October 20, 2023 2:26:05 AM CEST Andre Przywara wrote:
This updates the devicetree files to match the Linux kernel repository as of v6.6-rc6. Mostly cosmetic changes, but we gain some new board files and the T113s board .dtsi files, which are needed for the pending U-Boot patches.
Split per architecture, with the T113s being separate due to its RISC-V relationship.
Andre Przywara (3): sunxi: dts: arm64: update devicetree files from Linux-v6.6-rc6 sunxi: dts: arm: update devicetree files from Linux-v6.6-rc6 sunxi: dts: arm: add T113s/D1 DT files from Linux-v6.6-rc6
I compared all DTs and they are identical, except r_intc, as mentioned.
Reviewed-by: Jernej Skrabec jernej.skrabec@gmail.com
Best regards, Jernej
arch/arm/dts/axp209.dtsi | 7 + arch/arm/dts/sun50i-a64.dtsi | 3 +- arch/arm/dts/sun50i-h6-pine-h64-model-b.dts | 2 +- arch/arm/dts/sun50i-h616-orangepi-zero.dtsi | 134 +++ arch/arm/dts/sun50i-h616-orangepi-zero2.dts | 121 +-- arch/arm/dts/sun50i-h616-x96-mate.dts | 2 +- arch/arm/dts/sun50i-h618-orangepi-zero3.dts | 94 ++ arch/arm/dts/sun5i-r8-chip.dts | 6 + arch/arm/dts/sun5i.dtsi | 11 +- arch/arm/dts/sun7i-a20-icnova-a20-adb4006.dts | 137 +++ arch/arm/dts/sun7i-a20-icnova-a20.dtsi | 62 ++ arch/arm/dts/sun8i-a23-a33.dtsi | 2 +- arch/arm/dts/sun8i-a83t.dtsi | 2 +- .../arm/dts/sun8i-t113s-mangopi-mq-r-t113.dts | 35 + arch/arm/dts/sun8i-t113s.dtsi | 59 ++ arch/arm/dts/sun8i-v3s.dtsi | 2 +- arch/arm/dts/sunxi-d1s-t113-mangopi-mq-r.dtsi | 126 +++ arch/riscv/dts/sunxi-d1-t113.dtsi | 15 + arch/riscv/dts/sunxi-d1s-t113.dtsi | 927 ++++++++++++++++++ include/dt-bindings/clock/sun20i-d1-ccu.h | 158 +++ include/dt-bindings/clock/sun20i-d1-r-ccu.h | 19 + include/dt-bindings/clock/sun50i-h6-ccu.h | 2 +- include/dt-bindings/clock/sun50i-h616-ccu.h | 2 +- include/dt-bindings/clock/sun6i-rtc.h | 2 +- include/dt-bindings/reset/sun20i-d1-ccu.h | 79 ++ include/dt-bindings/reset/sun20i-d1-r-ccu.h | 16 + include/dt-bindings/reset/sun50i-h6-ccu.h | 2 +- include/dt-bindings/reset/sun50i-h6-r-ccu.h | 2 +- include/dt-bindings/reset/sun50i-h616-ccu.h | 2 +- 29 files changed, 1899 insertions(+), 132 deletions(-) create mode 100644 arch/arm/dts/sun50i-h616-orangepi-zero.dtsi create mode 100644 arch/arm/dts/sun50i-h618-orangepi-zero3.dts create mode 100644 arch/arm/dts/sun7i-a20-icnova-a20-adb4006.dts create mode 100644 arch/arm/dts/sun7i-a20-icnova-a20.dtsi create mode 100644 arch/arm/dts/sun8i-t113s-mangopi-mq-r-t113.dts create mode 100644 arch/arm/dts/sun8i-t113s.dtsi create mode 100644 arch/arm/dts/sunxi-d1s-t113-mangopi-mq-r.dtsi create mode 100644 arch/riscv/dts/sunxi-d1-t113.dtsi create mode 100644 arch/riscv/dts/sunxi-d1s-t113.dtsi create mode 100644 include/dt-bindings/clock/sun20i-d1-ccu.h create mode 100644 include/dt-bindings/clock/sun20i-d1-r-ccu.h create mode 100644 include/dt-bindings/reset/sun20i-d1-ccu.h create mode 100644 include/dt-bindings/reset/sun20i-d1-r-ccu.h
Andre Przywara
Jernej Škrabec
