[U-Boot] [PATCH 1/6] davinci: ea20: reorganisation LCD startup
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: Tom Rini trini@ti.com CC: Stefano Babic sbabic@denx.de --- board/davinci/ea20/ea20.c | 23 +++++++++++++++-------- 1 files changed, 15 insertions(+), 8 deletions(-)
diff --git a/board/davinci/ea20/ea20.c b/board/davinci/ea20/ea20.c index 7e00040..69307e4 100644 --- a/board/davinci/ea20/ea20.c +++ b/board/davinci/ea20/ea20.c @@ -176,6 +176,9 @@ int board_early_init_f(void) if (davinci_configure_pin_mux(gpio_pins, ARRAY_SIZE(gpio_pins)) != 0) return 1;
+ /* Set DISP_ON high to enable LCD output*/ + gpio_direction_output(97, 1); + /* Set the RESETOUTn low */ gpio_direction_output(111, 0);
@@ -188,9 +191,6 @@ int board_early_init_f(void) /* Set LCD_B_PWR low to power down LCD Backlight*/ gpio_direction_output(102, 0);
- /* Set DISP_ON low to disable LCD output*/ - gpio_direction_output(97, 0); - #ifndef CONFIG_USE_IRQ irq_init(); #endif @@ -250,11 +250,6 @@ int board_early_init_f(void) writel(readl(&davinci_syscfg_regs->mstpri[2]) & 0x0fffffff, &davinci_syscfg_regs->mstpri[2]);
- /* Set LCD_B_PWR low to power up LCD Backlight*/ - gpio_set_value(102, 1); - - /* Set DISP_ON low to disable LCD output*/ - gpio_set_value(97, 1);
return 0; } @@ -276,6 +271,9 @@ int board_init(void)
int board_late_init(void) { + unsigned char buf[2]; + int ret; + /* PinMux for HALTEN */ if (davinci_configure_pin_mux(halten_pin, ARRAY_SIZE(halten_pin)) != 0) return 1; @@ -285,6 +283,15 @@ int board_late_init(void)
setenv("stdout", "serial");
+ /* Set fixed contrast settings for LCD via I2C potentiometer */ + buf[0] = 0x00; + buf[1] = 0xd7; + ret = i2c_write(0x2e, 6, 1, buf, 2); + if (ret) + puts("\nContrast Settings FAILED\n"); + + /* Set LCD_B_PWR high to power up LCD Backlight*/ + gpio_set_value(102, 1); return 0; } #endif /* CONFIG_BOARD_LATE_INIT */
Do not allow to overwrite it when video is enabled.
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: Tom Rini trini@ti.com CC: Stefano Babic sbabic@denx.de --- board/davinci/ea20/ea20.c | 11 +++++++++-- include/configs/ea20.h | 2 ++ 2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/board/davinci/ea20/ea20.c b/board/davinci/ea20/ea20.c index 69307e4..0edd910 100644 --- a/board/davinci/ea20/ea20.c +++ b/board/davinci/ea20/ea20.c @@ -254,6 +254,15 @@ int board_early_init_f(void) return 0; }
+/* + * Do not overwrite the console + * Use always serial for U-Boot console + */ +int overwrite_console(void) +{ + return 1; +} + int board_init(void) { /* arch number of the board */ @@ -281,8 +290,6 @@ int board_late_init(void) /* Set HALTEN to high */ gpio_direction_output(134, 1);
- setenv("stdout", "serial"); - /* Set fixed contrast settings for LCD via I2C potentiometer */ buf[0] = 0x00; buf[1] = 0xd7; diff --git a/include/configs/ea20.h b/include/configs/ea20.h index a9caa81..f9a1462 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -125,6 +125,8 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_CMD_BMP +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #endif
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: Anatolij Gustschin agust@denx.de CC: Tom Rini trini@ti.com CC: Stefano Babic sbabic@denx.de --- drivers/video/cfb_console.c | 61 ++++++++++++++++++++++++++++--------------- 1 files changed, 40 insertions(+), 21 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 19d061f..21b52bd 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -66,7 +66,11 @@ * CONFIG_CONSOLE_TIME - display time/date in upper right * corner, needs CONFIG_CMD_DATE and * CONFIG_CONSOLE_CURSOR - * CONFIG_VIDEO_LOGO - display Linux Logo in upper left corner + * CONFIG_VIDEO_LOGO - display Linux Logo in upper left corner. + * Use CONFIG_SPLASH_SCREEN_ALIGN with + * environment variable "splashpos" to place + * the logo on other position. In this case + * no CONSOLE_EXTRA_INFO is possible. * CONFIG_VIDEO_BMP_LOGO - use bmp_logo instead of linux_logo * CONFIG_CONSOLE_EXTRA_INFO - display additional board information * strings that normaly goes to serial @@ -369,6 +373,8 @@ static void *video_fb_address; /* frame buffer address */ static void *video_console_address; /* console buffer start address */
static int video_logo_height = VIDEO_LOGO_HEIGHT; +static int video_logo_xpos; +static int video_logo_ypos;
static int __maybe_unused cursor_state; static int __maybe_unused old_col; @@ -1594,40 +1600,53 @@ static void *video_logo(void) __maybe_unused int y_off = 0;
#ifdef CONFIG_SPLASH_SCREEN - char *s; ulong addr; - - s = getenv("splashimage"); +#endif +#if defined(CONFIG_SPLASH_SCREEN) || defined(CONFIG_SPLASH_SCREEN_ALIGN) + char *s; +#endif +#ifdef CONFIG_SPLASH_SCREEN_ALIGN + s = getenv("splashpos"); if (s != NULL) { - int x = 0, y = 0; + if (s[0] == 'm') + video_logo_xpos = BMP_ALIGN_CENTER; + else + video_logo_xpos = simple_strtol(s, NULL, 0);
- addr = simple_strtoul(s, NULL, 16); -#ifdef CONFIG_SPLASH_SCREEN_ALIGN - s = getenv("splashpos"); + s = strchr(s + 1, ','); if (s != NULL) { - if (s[0] == 'm') - x = BMP_ALIGN_CENTER; + if (s[1] == 'm') + video_logo_ypos = BMP_ALIGN_CENTER; else - x = simple_strtol(s, NULL, 0); - - s = strchr(s + 1, ','); - if (s != NULL) { - if (s[1] == 'm') - y = BMP_ALIGN_CENTER; - else - y = simple_strtol(s + 1, NULL, 0); - } + video_logo_ypos = simple_strtol(s + 1, NULL, 0); } + } #endif /* CONFIG_SPLASH_SCREEN_ALIGN */ +#ifdef CONFIG_SPLASH_SCREEN + s = getenv("splashimage"); + if (s != NULL) { + + addr = simple_strtoul(s, NULL, 16);
- if (video_display_bitmap(addr, x, y) == 0) { + + if (video_display_bitmap(addr, \ + video_logo_xpos, \ + video_logo_ypos) == 0) { video_logo_height = 0; return ((void *) (video_fb_address)); } } #endif /* CONFIG_SPLASH_SCREEN */
- logo_plot(video_fb_address, VIDEO_COLS, 0, 0); + logo_plot(video_fb_address, \ + VIDEO_COLS, \ + video_logo_xpos, \ + video_logo_ypos); + +#ifdef CONFIG_SPLASH_SCREEN_ALIGN + /* when using splashpos for video_logo, no console output */ + return (video_fb_address + video_logo_height * VIDEO_LINE_LEN); +#endif
sprintf(info, " %s", version_string);
Extend the driver for placing the video/bmp logo as specified by "splashpos" environment variable.
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de Signed-off-by: Anatolij Gustschin agust@denx.de CC: Tom Rini trini@ti.com CC: Stefano Babic sbabic@denx.de --- v2: - remove some ifdefs - revise commit log - adjust video_logo_height by video_logo_ypos and thus fix return address for video console offset - add BMP_ALIGN_CENTER case to logo_plot() for proper logo offset calculation if "m" specifier is used in splashpos
drivers/video/cfb_console.c | 88 ++++++++++++++++++++++++++++++------------ 1 files changed, 63 insertions(+), 25 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 19d061f..81e5e08 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -66,7 +66,11 @@ * CONFIG_CONSOLE_TIME - display time/date in upper right * corner, needs CONFIG_CMD_DATE and * CONFIG_CONSOLE_CURSOR - * CONFIG_VIDEO_LOGO - display Linux Logo in upper left corner + * CONFIG_VIDEO_LOGO - display Linux Logo in upper left corner. + * Use CONFIG_SPLASH_SCREEN_ALIGN with + * environment variable "splashpos" to place + * the logo on other position. In this case + * no CONSOLE_EXTRA_INFO is possible. * CONFIG_VIDEO_BMP_LOGO - use bmp_logo instead of linux_logo * CONFIG_CONSOLE_EXTRA_INFO - display additional board information * strings that normaly goes to serial @@ -369,6 +373,8 @@ static void *video_fb_address; /* frame buffer address */ static void *video_console_address; /* console buffer start address */
static int __maybe_unused cursor_state; static int __maybe_unused old_col; @@ -1488,8 +1494,21 @@ void logo_plot(void *screen, int width, int x, int y) int ycount = video_logo_height; unsigned char r, g, b, *logo_red, *logo_blue, *logo_green; unsigned char *source; - unsigned char *dest = (unsigned char *) screen + - ((y * width * VIDEO_PIXEL_SIZE) + x * VIDEO_PIXEL_SIZE); + unsigned char *dest; + +#ifdef CONFIG_SPLASH_SCREEN_ALIGN + if (x == BMP_ALIGN_CENTER) + x = max(0, (VIDEO_VISIBLE_COLS - VIDEO_LOGO_WIDTH) / 2); + else if (x < 0) + x = max(0, VIDEO_VISIBLE_COLS - VIDEO_LOGO_WIDTH + x + 1); + + if (y == BMP_ALIGN_CENTER) + y = max(0, (VIDEO_VISIBLE_ROWS - VIDEO_LOGO_HEIGHT) / 2); + else if (y < 0) + y = max(0, VIDEO_VISIBLE_ROWS - VIDEO_LOGO_HEIGHT + y + 1); +#endif /* CONFIG_SPLASH_SCREEN_ALIGN */ + + dest = (unsigned char *)screen + (y * width + x) * VIDEO_PIXEL_SIZE;
#ifdef CONFIG_VIDEO_BMP_LOGO source = bmp_logo_bitmap; @@ -1592,42 +1611,61 @@ static void *video_logo(void) char info[128]; int space, len; __maybe_unused int y_off = 0; + __maybe_unused ulong addr; + __maybe_unused char *s;
-#ifdef CONFIG_SPLASH_SCREEN - char *s; - ulong addr; - - s = getenv("splashimage"); +#ifdef CONFIG_SPLASH_SCREEN_ALIGN + s = getenv("splashpos"); if (s != NULL) { - int x = 0, y = 0; + if (s[0] == 'm') + video_logo_xpos = BMP_ALIGN_CENTER; + else + video_logo_xpos = simple_strtol(s, NULL, 0);
- if (video_display_bitmap(addr, x, y) == 0) { +#ifdef CONFIG_SPLASH_SCREEN + s = getenv("splashimage"); + if (s != NULL) { + + addr = simple_strtoul(s, NULL, 16); + + + if (video_display_bitmap(addr, + video_logo_xpos, + video_logo_ypos) == 0) { video_logo_height = 0; return ((void *) (video_fb_address)); } } #endif /* CONFIG_SPLASH_SCREEN */
- logo_plot(video_fb_address, VIDEO_COLS, 0, 0); + logo_plot(video_fb_address, VIDEO_COLS, + video_logo_xpos, video_logo_ypos); + +#ifdef CONFIG_SPLASH_SCREEN_ALIGN + /* + * when using splashpos for video_logo, skip any info + * output on video console if the logo is not at 0,0 + */ + if (video_logo_xpos || video_logo_ypos) { + /* + * video_logo_height is used in text and cursor offset + * calculations. Since the console is below the logo, + * we need to adjust the logo height + */ + video_logo_height += video_logo_ypos; + return video_fb_address + video_logo_height * VIDEO_LINE_LEN; + } +#endif
Hello Anatolij,
[U-Boot] [PATCH v2 3/6] video: cfb_console: logo can be positioned via the splashpos variable
v2:
- revise commit log
- CONFIG_CONSOLE_TIME - display time/date in upper right
- CONFIG_VIDEO_LOGO - display Linux Logo in upper left corner
- CONFIG_VIDEO_LOGO - display Linux Logo in upper left corner.
- CONFIG_VIDEO_BMP_LOGO - use bmp_logo instead of linux_logo
- CONFIG_CONSOLE_EXTRA_INFO - display additional board information
bufferaddress */
y)
- unsigned char *dest;
- if (x == BMP_ALIGN_CENTER)
- else if (x < 0)
- if (y == BMP_ALIGN_CENTER)
- else if (y < 0)
- dest = (unsigned char *)screen + (y * width + x) * VIDEO_PIXEL_SIZE;
- __maybe_unused ulong addr;
- __maybe_unused char *s;
- char *s;
- ulong addr;
- s = getenv("splashpos"); if (s != NULL) {
int x = 0, y = 0;
if (s[0] == 'm')
else
if (s[0] == 'm')
if (s[1] == 'm')
if (s != NULL) {
if (s[1] == 'm')
else
- if (s != NULL) {
video_logo_xpos,
}video_logo_ypos) == 0) { video_logo_height = 0; return ((void *) (video_fb_address)); }
- when using splashpos for video_logo, skip any info
- output on video console if the logo is not at 0,0
- if (video_logo_xpos || video_logo_ypos) {
I have some trouble with this version when using splashpos = m,m . In this case video_logo_ypos is 32767 (BMP_ALIGN_CENTER) here. Following extension isworking for me:
#ifdef CONFIG_SPLASH_SCREEN_ALIGN /* * when using splashpos for video_logo, skip any info * output on video console if the logo is not at 0,0 */ if (video_logo_xpos || video_logo_ypos) { /* * video_logo_height is used in text and cursor offset * calculations. Since the console is below the logo, * we need to adjust the logo height */ if (video_logo_ypos == BMP_ALIGN_CENTER) video_logo_height += max(0, (VIDEO_VISIBLE_ROWS - \ VIDEO_LOGO_HEIGHT) / 2); else if (video_logo_ypos >= 0) video_logo_height += video_logo_ypos;
return video_fb_address + video_logo_height * VIDEO_LINE_LEN; } #endif
Should i post a version 3 for this patch?
-- 1.7.1
Regards,
Bastian.
Hello Bastian,
On Wed, 5 Sep 2012 12:52:59 +0200 Bastian.Ruppert@sewerin.de wrote: ...
Ah, indeed. Thanks for testing and catching it.
OK. But please use
else if (video_logo_ypos > 0) video_logo_height += video_logo_ypos;
Yes, please.
Thanks,
Anatolij
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: Tom Rini trini@ti.com Acked-by: Stefano Babic sbabic@denx.de --- board/davinci/ea20/ea20.c | 23 +++++++++++++++-------- 1 files changed, 15 insertions(+), 8 deletions(-)
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: Tom Rini trini@ti.com Acked-by: Stefano Babic sbabic@denx.de --- board/davinci/ea20/ea20.c | 11 +++++++++-- include/configs/ea20.h | 2 ++ 2 files changed, 11 insertions(+), 2 deletions(-)
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de Signed-off-by: Anatolij Gustschin agust@denx.de CC: Tom Rini trini@ti.com CC: Stefano Babic sbabic@denx.de --- v3: - logo offset calculation is no longer based on BMP_ALIGN_CENTER if "m" specifier is used in splashpos
v2: - remove some ifdefs - revise commit log - adjust video_logo_height by video_logo_ypos and thus fix return address for video console offset - add BMP_ALIGN_CENTER case to logo_plot() for proper logo offset calculation if "m" specifier is used in splashpos --- drivers/video/cfb_console.c | 93 +++++++++++++++++++++++++++++++----------- 1 files changed, 68 insertions(+), 25 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 19d061f..3ae420b 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -66,7 +66,11 @@ * CONFIG_CONSOLE_TIME - display time/date in upper right * corner, needs CONFIG_CMD_DATE and * CONFIG_CONSOLE_CURSOR - * CONFIG_VIDEO_LOGO - display Linux Logo in upper left corner + * CONFIG_VIDEO_LOGO - display Linux Logo in upper left corner. + * Use CONFIG_SPLASH_SCREEN_ALIGN with + * environment variable "splashpos" to place + * the logo on other position. In this case + * no CONSOLE_EXTRA_INFO is possible. * CONFIG_VIDEO_BMP_LOGO - use bmp_logo instead of linux_logo * CONFIG_CONSOLE_EXTRA_INFO - display additional board information * strings that normaly goes to serial @@ -369,6 +373,8 @@ static void *video_fb_address; /* frame buffer address */ static void *video_console_address; /* console buffer start address */
#ifdef CONFIG_VIDEO_BMP_LOGO source = bmp_logo_bitmap; @@ -1592,42 +1611,66 @@ static void *video_logo(void) char info[128]; int space, len; __maybe_unused int y_off = 0; + __maybe_unused ulong addr; + __maybe_unused char *s;
- logo_plot(video_fb_address, VIDEO_COLS, 0, 0); + logo_plot(video_fb_address, VIDEO_COLS, + video_logo_xpos, video_logo_ypos); + +#ifdef CONFIG_SPLASH_SCREEN_ALIGN + /* + * when using splashpos for video_logo, skip any info + * output on video console if the logo is not at 0,0 + */ + if (video_logo_xpos || video_logo_ypos) { + /* + * video_logo_height is used in text and cursor offset + * calculations. Since the console is below the logo, + * we need to adjust the logo height + */ + if (video_logo_ypos == BMP_ALIGN_CENTER) + video_logo_height += max(0, (VIDEO_VISIBLE_ROWS - \ + VIDEO_LOGO_HEIGHT) / 2); + else if (video_logo_ypos > 0) + video_logo_height += video_logo_ypos; + + return video_fb_address + video_logo_height * VIDEO_LINE_LEN; + } +#endif
On Thu, 6 Sep 2012 08:07:36 +0200 Bastian Ruppert Bastian.Ruppert@Sewerin.de wrote:
v3:
v2:
- revise commit log
Acked-by: Anatolij Gustschin agust@denx.de
Thanks!
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: Anatolij Gustschin agust@denx.de CC: Tom Rini trini@ti.com CC: Stefano Babic sbabic@denx.de --- drivers/video/cfb_console.c | 46 +++++++++++++++++++++++++++++++++++++++--- 1 files changed, 42 insertions(+), 4 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 3ae420b..c3e36c4 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -1486,7 +1486,39 @@ int video_display_bitmap(ulong bmp_image, int x, int y)
#ifdef CONFIG_VIDEO_LOGO -void logo_plot(void *screen, int width, int x, int y) +static void plot_logo_or_black(void *screen, int width, int x, int y, \ + int black); + +static void logo_plot(void *screen, int width, int x, int y) +{ + plot_logo_or_black(screen, width, x, y, 0); +} + +static void logo_black(void) +{ + plot_logo_or_black(video_fb_address, \ + VIDEO_COLS, \ + video_logo_xpos, \ + video_logo_ypos, \ + 1); +} + +static int do_clrlogo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + if (argc != 1) + return cmd_usage(cmdtp); + + logo_black(); + return 0; +} + +U_BOOT_CMD( + clrlogo, 1, 0, do_clrlogo, + "fill the boot logo area with black", + " " + ); + +static void plot_logo_or_black(void *screen, int width, int x, int y, int black) {
int xcount, i; @@ -1544,9 +1576,15 @@ void logo_plot(void *screen, int width, int x, int y) #endif xcount = VIDEO_LOGO_WIDTH; while (xcount--) { - r = logo_red[*source - VIDEO_LOGO_LUT_OFFSET]; - g = logo_green[*source - VIDEO_LOGO_LUT_OFFSET]; - b = logo_blue[*source - VIDEO_LOGO_LUT_OFFSET]; + if (black) { + r = 0x00; + g = 0x00; + b = 0x00; + } else { + r = logo_red[*source - VIDEO_LOGO_LUT_OFFSET]; + g = logo_green[*source - VIDEO_LOGO_LUT_OFFSET]; + b = logo_blue[*source - VIDEO_LOGO_LUT_OFFSET]; + }
switch (VIDEO_DATA_FORMAT) { case GDF__8BIT_INDEX:
On Thu, 6 Sep 2012 08:07:37 +0200 Bastian Ruppert Bastian.Ruppert@Sewerin.de wrote:
Thanks!
From this commit id: b78375a806ed04eb22b963255cfdef8df702de47 auto
negotiation is enabled in RMII mode. Some boards based on da850 need to suppress this procedure.
CC: Rajashekhara, Sudhakar sudhakar.raj@ti.com CC: Lad, Prabhakar prabhakar.lad@ti.com CC: Hadli, Manjunath manjunath.hadli@ti.com CC: sbabic@denx.de Acked-by: Stefano Babic sbabic@denx.de CC: Tom Rini trini@ti.com Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de --- drivers/net/davinci_emac.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index b2516d1..fe988d7 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -897,7 +897,8 @@ int davinci_emac_initialize(void) }
#if defined(CONFIG_DRIVER_TI_EMAC_USE_RMII) && \ - defined(CONFIG_MACH_DAVINCI_DA850_EVM) + defined(CONFIG_MACH_DAVINCI_DA850_EVM) && \ + !defined(CONFIG_DRIVER_TI_EMAC_RMII_NONEG) for (i = 0; i < num_phy; i++) { if (phy[i].is_phy_connected(i)) phy[i].auto_negotiate(i);
Hi Bastian,
Thanks for the patch.
On Thu, Sep 6, 2012 at 11:37 AM, Bastian Ruppert Bastian.Ruppert@sewerin.de wrote:
From this commit id: b78375a806ed04eb22b963255cfdef8df702de47 auto negotiation is enabled in RMII mode. Some boards based on da850 need to suppress this procedure.
instead of CONFIG_DRIVER_TI_EMAC_RMII_NONEG why not have CONFIG_DRIVER_TI_EMAC_RMII_AUTO_NEGOTIATE ?
Thx, --Prabhakar Lad
-- 1.7.0.4
On Fri, Sep 7, 2012 at 1:08 AM, Prabhakar Lad prabhakar.csengg@gmail.com wrote:
Hi Bastian,
Good idea, opt-in is better than opt-out, please make it so.
Hello,
Re: [U-Boot] [PATCH v3 5/6] da850/omap-l138: davinci_emac: Suppress auto negotiation if needed
Hi Bastian,
i can see what you mean! But in this case i would like to answer back. Normally, one almost certainly use the auto negotiation. On the ea20 board there is a seldom case where auto negotiation is counterproductive. In my opinion the feature "disable it" is opt-in. So i would like to leave it as it is.
Regards,
Bastian.
On Sun, Sep 9, 2012 at 11:01 PM, Bastian.Ruppert@sewerin.de wrote:
Hello,
Hi Bastian,
I will defer to Prabhakar for a final answer on this.
Hi Bastian,
Hello,
Hi Bastian,
Ok. 'NONEG' doesn't sound good can you make it NO_NEGOTIATE ?
Thanks, --Prabhakar
Hello, Prabhakar, hello Tom
Hello,
Hi Bastian,
need
counterproductive.
Ok, i will use CONFIG_DRIVER_TI_EMAC_RMII_NO_NEGOTIATE. It is not too long, isn´t it?
Tom, would you like to receive a complete v4 patch series for this? Or should i post version 4 for the affected patches only?
Thanks,
Bastian.
Hello,
Hi Bastian,
On Thu, Sep 6, 2012 at 11:37 AM, Bastian Ruppert Bastian.Ruppert@sewerin.de wrote: > From this commit id: b78375a806ed04eb22b963255cfdef8df702de47 auto > negotiation is enabled in RMII mode. Some boards based on da850
need
> to suppress this procedure. > > CC: Rajashekhara, Sudhakar sudhakar.raj@ti.com > CC: Lad, Prabhakar prabhakar.lad@ti.com > CC: Hadli, Manjunath manjunath.hadli@ti.com > CC: sbabic@denx.de > Acked-by: Stefano Babic sbabic@denx.de > CC: Tom Rini trini@ti.com > Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de > --- > drivers/net/davinci_emac.c | 3 ++- > 1 files changed, 2 insertions(+), 1 deletions(-) > > diff --git a/drivers/net/davinci_emac.c
> index b2516d1..fe988d7 100644 > --- a/drivers/net/davinci_emac.c > +++ b/drivers/net/davinci_emac.c > @@ -897,7 +897,8 @@ int davinci_emac_initialize(void) > } > > #if defined(CONFIG_DRIVER_TI_EMAC_USE_RMII) && \ > - defined(CONFIG_MACH_DAVINCI_DA850_EVM) > + defined(CONFIG_MACH_DAVINCI_DA850_EVM) && \ > + !defined(CONFIG_DRIVER_TI_EMAC_RMII_NONEG) instead of CONFIG_DRIVER_TI_EMAC_RMII_NONEG why not have CONFIG_DRIVER_TI_EMAC_RMII_AUTO_NEGOTIATE ?
counterproductive.
Whichever is easier for you to post, thanks.
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: Tom Rini trini@ti.com Acked-by: Stefano Babic sbabic@denx.de --- include/configs/ea20.h | 106 ++++++++++++++++++++++++++++++------------------ 1 files changed, 66 insertions(+), 40 deletions(-)
diff --git a/include/configs/ea20.h b/include/configs/ea20.h index f9a1462..373db74 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -30,6 +30,7 @@ #define CONFIG_USE_SPIFLASH #define CONFIG_SYS_USE_NAND #define CONFIG_DRIVER_TI_EMAC_USE_RMII +#define CONFIG_DRIVER_TI_EMAC_RMII_NONEG #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_LATE_INIT #define CONFIG_VIDEO @@ -98,6 +99,7 @@ * Network & Ethernet Configuration */ #ifdef CONFIG_DRIVER_TI_EMAC +#define CONFIG_EMAC_MDIO_PHY_NUM 0 #define CONFIG_MII #define CONFIG_BOOTP_DEFAULT #define CONFIG_BOOTP_DNS @@ -121,9 +123,11 @@ #define CONFIG_VIDEO_DA8XX #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO +#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CMD_BMP #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE @@ -197,6 +201,7 @@
#define CONFIG_NAND_DAVINCI #define CONFIG_SYS_NAND_PAGE_2K +#define CONFIG_SYS_NAND_NO_SUBPAGE #define CONFIG_SYS_NAND_CS 2 #define CONFIG_SYS_NAND_BASE DAVINCI_ASYNC_EMIF_DATA_CE2_BASE #undef CONFIG_SYS_NAND_HW_ECC @@ -235,31 +240,39 @@ #define xstr(s) str(s) #define str(s) #s
- #define CONFIG_HOSTNAME ea20 -#define CONFIG_EXTRA_ENV_SETTINGS \ +#define CONFIG_EXTRA_ENV_SETTINGS \ "as=3\0" \ - "netdev=eth0\0" \ + "netdev=eth0\0" \ "nfsargs=setenv bootargs root=/dev/nfs rw " \ "nfsroot=${serverip}:${rootpath}\0" \ "rfsbargs=setenv bootargs root=/dev/nfs rw " \ "nfsroot=${serverip}:${rfsbpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "mtdids=nand0=davinci_nand.0\0" \ - "mtdparts=mtdparts=davinci_nand.0:8m(Settings),8m(aKernel)," \ - "8m(bKernel),76m(aRootfs),76m(bRootfs),-(MassSD)\0" \ + "testrfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${testrfspath}\0" \ + "ramargs=setenv bootargs root=/dev/ram rw initrd=" \ + "0x${ramdisk_addr_r},4M\0" \ + "mtdids=nand0=davinci_nand.0\0" \ + "serverip=192.168.5.249\0" \ + "ipaddr=192.168.5.248\0" \ + "rootpath=/opt/eldk/arm\0" \ + "splashpos=230,180\0" \ + "testrfspath=/opt/eldk/test_arm\0" \ + "tempmac=setenv ethaddr 02:ea:20:ff:ff:ff\0" \ "nandargs=setenv bootargs rootfstype=ubifs ro chk_data_crc " \ "ubi.mtd=${as} root=ubi0:rootfs\0" \ + "nandrwargs=setenv bootargs rootfstype=ubifs rw chk_data_crc " \ + "ubi.mtd=${as} root=ubi0:rootfs\0" \ "addip_sta=setenv bootargs ${bootargs} " \ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ ":${hostname}:${netdev}:off panic=1\0" \ "addip_dyn=setenv bootargs ${bootargs} ip=dhcp\0" \ - "addip=if test -n ${ipdyn};then run addip_dyn;" \ + "addip=if test -n ${ipdyn};then run addip_dyn;" \ "else run addip_sta;fi\0" \ "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ "addtty=setenv bootargs ${bootargs}" \ " console=${consoledev},${baudrate}n8\0" \ - "addmisc=setenv bootargs ${bootargs} ${misc}\0" \ + "addmisc=setenv bootargs ${bootargs} ${misc}\0" \ "addmem=setenv bootargs ${bootargs} mem=${memory}\0" \ "consoledev=ttyS0\0" \ "loadaddr=c0000014\0" \ @@ -267,44 +280,57 @@ "kernel_addr_r=c0700000\0" \ "hostname=" xstr(CONFIG_HOSTNAME) "\0" \ "bootfile=" xstr(CONFIG_HOSTNAME) "/uImage\0" \ - "ramdisk_file=" xstr(CONFIG_HOSTNAME) "/uRamdisk\0" \ + "ramdisk_file=" xstr(CONFIG_HOSTNAME) "/image.ext2\0" \ "flash_self=run ramargs addip addtty addmtd addmisc addmem;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ + "bootm ${kernel_addr_r}\0" \ "flash_nfs=run nfsargs addip addtty addmtd addmisc addmem;" \ "bootm ${kernel_addr}\0" \ - "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \ + "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \ "run nfsargs addip addtty addmtd addmisc addmem;" \ - "bootm ${kernel_addr_r}\0" \ - "net_rfsb=tftp ${kernel_addr_r} ${bootfile}; " \ - "run rfsbargs addip addtty addmtd addmisc addmem; " \ - "bootm ${kernel_addr_r}\0" \ + "bootm ${kernel_addr_r}\0" \ + "net_rfsb=tftp ${kernel_addr_r} ${bootfile}; " \ + "run rfsbargs addip addtty addmtd addmisc addmem; " \ + "bootm ${kernel_addr_r}\0" \ + "net_testrfs=tftp ${kernel_addr_r} ${bootfile}; " \ + "run testrfsargs addip addtty addmtd addmisc addmem; " \ + "bootm ${kernel_addr_r}\0" \ "net_self_load=tftp ${kernel_addr_r} ${bootfile};" \ "tftp ${ramdisk_addr_r} ${ramdisk_file};\0" \ - "nand_nand=ubi part nand0,${as};ubifsmount rootfs;" \ - "ubifsload ${kernel_addr_r} /boot/uImage;" \ - "ubifsumount; run nandargs addip addtty " \ - "addmtd addmisc addmem;bootm ${kernel_addr_r}\0" \ - "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.bin\0" \ - "load_magic=if sf probe 0;then sf " \ - "read c0000000 0x10000 0x60000;fi\0" \ - "load_nand=ubi part nand0,${as};ubifsmount rootfs;" \ - "if ubifsload c0000014 /boot/u-boot.bin;" \ - "then mw c0000008 ${filesize};else echo Error reading " \ - "u-boot from nand!;fi\0" \ - "load_net=if sf probe 0;then sf read c0000000 0x10000 0x60000;" \ - "tftp c0000014 ${u-boot};" \ - "mw c0000008 ${filesize};" \ - "fi\0" \ - "upd=if sf probe 0;then sf erase 10000 60000;" \ - "sf write c0000000 10000 60000;" \ - "fi\0" \ - "ubootupd_net=if run load_net;then echo Updating u-boot;" \ - "if run upd; then echo U-Boot updated;" \ + "nand_nand=ubi part nand0,${as};ubifsmount rootfs;" \ + "ubifsload ${kernel_addr_r} /boot/uImage;" \ + "ubifsumount; run nandargs addip addtty " \ + "addmtd addmisc addmem;clrlogo;" \ + "bootm ${kernel_addr_r}\0" \ + "nand_nandrw=ubi part nand0,${as};ubifsmount rootfs;" \ + "ubifsload ${kernel_addr_r} /boot/uImage;" \ + "ubifsumount; run nandrwargs addip addtty " \ + "addmtd addmisc addmem;clrlogo;" \ + "bootm ${kernel_addr_r}\0" \ + "net_nandrw=tftp ${kernel_addr_r} ${bootfile}; run nandrwargs" \ + " addip addtty addmtd addmisc addmem;" \ + "clrlogo;bootm ${kernel_addr_r}\0" \ + "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.bin\0" \ + "load_magic=if sf probe 0;then sf " \ + "read c0000000 0x10000 0x60000;fi\0" \ + "load_nand=ubi part nand0,${as};ubifsmount rootfs;" \ + "if ubifsload c0000014 /boot/u-boot.bin;" \ + "then mw c0000008 ${filesize};else echo Error reading" \ + " u-boot from nand!;fi\0" \ + "load_net=if sf probe 0;then sf read c0000000 0x10000 " \ + "0x60000;tftp c0000014 ${u-boot};" \ + "mw c0000008 ${filesize};fi\0" \ + "upd=if sf probe 0;then sf erase 10000 60000;" \ + "sf write c0000000 10000 60000;fi\0" \ + "ublupdate=if tftp C0700000 ${ublname};then sf probe 0; " \ + "sf erase 0 10000;" \ + "sf write 0xc0700000 0 ${filesize};fi\0" \ + "ubootupd_net=if run load_net;then echo Updating u-boot;" \ + "if run upd; then echo U-Boot updated;" \ "else echo Error updating u-boot !;" \ "echo Board without bootloader !!;" \ "fi;" \ - "else echo U-Boot not downloaded..exiting;fi\0" \ - "ubootupd_nand=echo run load_magic,run load_nand,run upd;\0" \ - "bootcmd=run net_nfs\0" + "else echo U-Boot not downloaded..exiting;fi\0" \ + "ubootupd_nand=echo run load_magic,run load_nand,run upd;\0" \ + "bootcmd=run tempmac;run net_testrfs\0"
#endif /* __CONFIG_H */
Hi Bastian,
there is a number of issues with this patch, please see comments below.
On Fri, 10 Aug 2012 09:26:43 +0200 Bastian Ruppert Bastian.Ruppert@Sewerin.de wrote:
- char *s;
these ifdefs should be better reduced, I think we can use __maybe_unused here, like for y_off above.
int x = 0, y = 0;
if (s[0] == 'm')
The 'm' case will work with splashscreen, but not with the video logo. There is no proper offset calculation in logo_plot() if xpos or ypos are set to BMP_ALIGN_CENTER. As a result the logo offset will be wrong and an access to wrong offset can even brick the board (on boards with small frame buffers).
video_logo_xpos, \
no need to use "" here.
- logo_plot(video_fb_address, \
VIDEO_COLS, \
video_logo_xpos, \
ditto.
- /* when using splashpos for video_logo, no console output */
- return (video_fb_address + video_logo_height * VIDEO_LINE_LEN);
The returned address is used as text console offset, so if the logo is moved down, the video_logo_height should be increased by video_logo_ypos. Otherwise the text and cursor positions will be wrong in the video console.
I've fixed these issues and submitted a patch v2 3/6. Please test.
Thanks,
Anatolij
Hi Bastian,
Hello Anatolij,
corner.
buffer address */
- char *s;
OK.
int x = 0, y = 0;
if (s[0] == 'm')
video_logo_xpos, \
VIDEO_COLS, \
video_logo_xpos, \
ditto.
OK.
Thanks,
Anatolij
Thank you for your effort,
Bastian.
CC: Rajashekhara, Sudhakar sudhakar.raj@ti.com CC: Lad, Prabhakar prabhakar.lad@ti.com CC: Hadli, Manjunath manjunath.hadli@ti.com CC: sbabic@denx.de Acked-by: Stefano Babic sbabic@denx.de CC: Tom Rini trini@ti.com Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de --- v4: - use more expressive CONFIG name
v3: v2: - related to other patches of this series --- drivers/net/davinci_emac.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index b2516d1..1db586d 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -897,7 +897,8 @@ int davinci_emac_initialize(void) }
#if defined(CONFIG_DRIVER_TI_EMAC_USE_RMII) && \ - defined(CONFIG_MACH_DAVINCI_DA850_EVM) + defined(CONFIG_MACH_DAVINCI_DA850_EVM) && \ + !defined(CONFIG_DRIVER_TI_EMAC_RMII_NO_NEGOTIATE) for (i = 0; i < num_phy; i++) { if (phy[i].is_phy_connected(i)) phy[i].auto_negotiate(i);
Hi Bastian,
On Fri, Sep 14, 2012 at 1:59 PM, Bastian Ruppert Bastian.Ruppert@sewerin.de wrote:
Acked-by: Prabhakar Lad prabhakar.lad@ti.com
Thanks, --Prabhakar
v4:
v3: v2:
-- 1.7.0.4
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: Tom Rini trini@ti.com Acked-by: Stefano Babic sbabic@denx.de --- v4: - use more expressive CONFIG name for emac rmii no autonegotiation
v3: v2: - related to other patches of this series --- include/configs/ea20.h | 106 ++++++++++++++++++++++++++++++------------------ 1 files changed, 66 insertions(+), 40 deletions(-)
diff --git a/include/configs/ea20.h b/include/configs/ea20.h index f9a1462..e237fd0 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -30,6 +30,7 @@ #define CONFIG_USE_SPIFLASH #define CONFIG_SYS_USE_NAND #define CONFIG_DRIVER_TI_EMAC_USE_RMII +#define CONFIG_DRIVER_TI_EMAC_RMII_NO_NEGOTIATE #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_LATE_INIT #define CONFIG_VIDEO @@ -98,6 +99,7 @@ * Network & Ethernet Configuration */ #ifdef CONFIG_DRIVER_TI_EMAC +#define CONFIG_EMAC_MDIO_PHY_NUM 0 #define CONFIG_MII #define CONFIG_BOOTP_DEFAULT #define CONFIG_BOOTP_DNS @@ -121,9 +123,11 @@ #define CONFIG_VIDEO_DA8XX #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO +#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CMD_BMP #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE @@ -197,6 +201,7 @@
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 21b52bd..b5e8a00 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -1486,7 +1486,39 @@ int video_display_bitmap(ulong bmp_image, int x, int y)
int xcount, i; @@ -1531,9 +1563,15 @@ void logo_plot(void *screen, int width, int x, int y) #endif xcount = VIDEO_LOGO_WIDTH; while (xcount--) { - r = logo_red[*source - VIDEO_LOGO_LUT_OFFSET]; - g = logo_green[*source - VIDEO_LOGO_LUT_OFFSET]; - b = logo_blue[*source - VIDEO_LOGO_LUT_OFFSET]; + if (black) { + r = 0x00; + g = 0x00; + b = 0x00; + } else { + r = logo_red[*source - VIDEO_LOGO_LUT_OFFSET]; + g = logo_green[*source - VIDEO_LOGO_LUT_OFFSET]; + b = logo_blue[*source - VIDEO_LOGO_LUT_OFFSET]; + }
CC: Rajashekhara, Sudhakar sudhakar.raj@ti.com CC: Lad, Prabhakar prabhakar.lad@ti.com CC: Hadli, Manjunath manjunath.hadli@ti.com CC: sbabic@denx.de CC: Tom Rini trini@ti.com Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de --- drivers/net/davinci_emac.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
for (i = 0; i < num_phy; i++) { if (phy[i].is_phy_connected(i)) phy[i].auto_negotiate(i);!defined(CONFIG_DRIVER_TI_EMAC_RMII_NONEG)
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: Tom Rini trini@ti.com CC: Stefano Babic sbabic@denx.de --- include/configs/ea20.h | 106 ++++++++++++++++++++++++++++++------------------ 1 files changed, 66 insertions(+), 40 deletions(-)
- Network & Ethernet Configuration
- "netdev=eth0\0" \
- "netdev=eth0\0" \ "nfsargs=setenv bootargs root=/dev/nfs rw " \ "nfsroot=${serverip}:${rootpath}\0" \ "rfsbargs=setenv bootargs root=/dev/nfs rw " \ "nfsroot=${serverip}:${rfsbpath}\0" \
- "testrfsargs=setenv bootargs root=/dev/nfs rw " \
- "nfsroot=${serverip}:${testrfspath}\0" \
- "ramargs=setenv bootargs root=/dev/ram rw initrd=" \
- "0x${ramdisk_addr_r},4M\0" \
- "serverip=192.168.5.249\0" \
- "ipaddr=192.168.5.248\0" \
- "rootpath=/opt/eldk/arm\0" \
- "splashpos=230,180\0" \
- "testrfspath=/opt/eldk/test_arm\0" \
- "tempmac=setenv ethaddr 02:ea:20:ff:ff:ff\0" \ "nandargs=setenv bootargs rootfstype=ubifs ro chk_data_crc " \ "ubi.mtd=${as} root=ubi0:rootfs\0" \
- "nandrwargs=setenv bootargs rootfstype=ubifs rw chk_data_crc " \
- "ubi.mtd=${as} root=ubi0:rootfs\0" \ "addip_sta=setenv bootargs ${bootargs} " \ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ ":${hostname}:${netdev}:off panic=1\0" \ "addip_dyn=setenv bootargs ${bootargs} ip=dhcp\0" \
- "addip=if test -n ${ipdyn};then run addip_dyn;" \ "else run addip_sta;fi\0" \ "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ "addtty=setenv bootargs ${bootargs}" \ " console=${consoledev},${baudrate}n8\0" \
- "addmisc=setenv bootargs ${bootargs} ${misc}\0" \ "addmem=setenv bootargs ${bootargs} mem=${memory}\0" \ "consoledev=ttyS0\0" \ "loadaddr=c0000014\0" \
- "ramdisk_file=" xstr(CONFIG_HOSTNAME) "/image.ext2\0" \ "flash_self=run ramargs addip addtty addmtd addmisc addmem;" \
"flash_nfs=run nfsargs addip addtty addmtd addmisc addmem;" \ "bootm ${kernel_addr}\0" \"bootm ${kernel_addr_r}\0" \
- "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \ "run nfsargs addip addtty addmtd addmisc addmem;" \
- "net_testrfs=tftp ${kernel_addr_r} ${bootfile}; " \
"net_self_load=tftp ${kernel_addr_r} ${bootfile};" \ "tftp ${ramdisk_addr_r} ${ramdisk_file};\0" \"bootm ${kernel_addr_r}\0" \
"fi\0" \
"fi\0" \
- "nand_nandrw=ubi part nand0,${as};ubifsmount rootfs;" \
- "net_nandrw=tftp ${kernel_addr_r} ${bootfile}; run nandrwargs" \
- "load_net=if sf probe 0;then sf read c0000000 0x10000 " \
- "ublupdate=if tftp C0700000 ${ublname};then sf probe 0; " \
"fi;" \"if run upd; then echo U-Boot updated;" \ "else echo Error updating u-boot !;" \ "echo Board without bootloader !!;" \
- "bootcmd=run tempmac;run net_testrfs\0"
For the series, I'm fine with the davinci side of the changes but want Anatolij and Stefano to ack as well before I pull into u-boot-ti, thanks!
Still waiting for Anatolij (thanks Stefano!) before I take this, FYI.
Hello Tom,
Re: [U-Boot] [PATCH 1/6] davinci: ea20: reorganisation LCD startup
with the version 3 for this patches, Anatolij seems to be pleased.
Thanks,
Bastian.
- /* Set DISP_ON high to enable LCD output*/
- gpio_direction_output(97, 1);
- /* Set the RESETOUTn low */ gpio_direction_output(111, 0);
- unsigned char buf[2];
- int ret;
- /* PinMux for HALTEN */ if (davinci_configure_pin_mux(halten_pin, ARRAY_SIZE(halten_pin)) != 0) return 1;
- buf[0] = 0x00;
- buf[1] = 0xd7;
- ret = i2c_write(0x2e, 6, 1, buf, 2);
- if (ret)
- /* Set LCD_B_PWR high to power up LCD Backlight*/
- gpio_set_value(102, 1); return 0;
participants (7)
Anatolij Gustschin
Bastian Ruppert
Prabhakar Lad
Prabhakar Lad
Stefano Babic
