[U-Boot] [PATCH 29/31] 8xx, kmsupx4: add bootcount support
Signed-off-by: Heiko Schocher hs@denx.de --- include/configs/keymile-common.h | 2 +- include/configs/km8xx.h | 4 +--- 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/include/configs/keymile-common.h b/include/configs/keymile-common.h index 20f7bab..3736cd8 100644 --- a/include/configs/keymile-common.h +++ b/include/configs/keymile-common.h @@ -27,7 +27,7 @@ /* Do boardspecific init for all boards */ #define CONFIG_BOARD_EARLY_INIT_R 1
-#if defined(CONFIG_MGCOGE) || defined(CONFIG_MGSUVD) +#if defined(CONFIG_MGCOGE) || defined(CONFIG_MGSUVD) || defined(CONFIG_KMSUPX4) #define CONFIG_BOOTCOUNT_LIMIT #endif
diff --git a/include/configs/km8xx.h b/include/configs/km8xx.h index 0ab75b4..237eb6a 100644 --- a/include/configs/km8xx.h +++ b/include/configs/km8xx.h @@ -54,10 +54,8 @@ #define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ #define CONFIG_SYS_SMC_RXBUFLEN 128
-#if defined(CONFIG_MGSUVD) #define CONFIG_SYS_CPM_BOOTCOUNT_ADDR 0x1eb0 /* In case of SMC relocation, the - * default value is not working */ -#endif + * default value is not working */
#define CONFIG_PREBOOT "echo;" \ "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \
Heiko Schocher
