Kendryte build warnings
Hello Sean,
when I compile for Kendryte K210 I see the following build warnings:
In file included from drivers/clk/kendryte/clk.c:15: include/kendryte/pll.h:46: warning: "nop" redefined 46 | #define nop() | In file included from ./arch/riscv/include/asm/io.h:13, from drivers/clk/kendryte/clk.c:7: ./arch/riscv/include/asm/barrier.h:16: note: this is the location of the previous definition 16 | #define nop() __asm__ __volatile__ ("nop") | In file included from ./arch/riscv/include/asm/io.h:13, from drivers/clk/kendryte/pll.c:8: ./arch/riscv/include/asm/barrier.h:16: warning: "nop" redefined 16 | #define nop() __asm__ __volatile__ ("nop") | In file included from drivers/clk/kendryte/pll.c:6: include/kendryte/pll.h:46: note: this is the location of the previous definition 46 | #define nop() |
Should nop() be the assembler instruction nop or nothing?
Best regards
Heinrich
On 7/28/20 6:56 AM, Heinrich Schuchardt wrote:
Hello Sean,
It should be the assembler instruction. The redefinion is to allow testing the frequency calculation function on the sandbox architecture (which has no nops). The actual code which uses the nop is never called, but it still gets compiled, so I added a shim. Can you send me the config you are using?
--Sean
Hello Sean,
--Sean
Please, find the config file appended.
I will provide a patch
#ifndef nop() #define nop() #endif
Another issue I found is that the memory size is not correctly set on the Kendryte as reported by bdinfo.
DRAM bank = 0x0000000000000000 -> start = 0x0000000080000000 -> size = 0x0000000000400000 DRAM bank = 0x0000000000000001 -> start = 0x0000000080400000 -> size = 0x0000000000200000 DRAM bank = 0x0000000000000002 -> start = 0x0000000080600000 -> size = 0x0000000000200000 memstart = 0x0000000000000000 memsize = 0x00000000 <<<<<<<<<<
I would have expected memsize = 0x800000.
On my MaixDuino I have an SD card slot which is connected to SPI0.
** MOSI - pin 28 ** MISO - pin 26 ** CLK - pin 27 ** CS - pin 29
Is there any ongoing work to enable the SD card slot on U-Boot yet?
Best regards
Heinrich
Hello Sean,
--Sean
That's about what I was thinking.
Ok, I will look into that.
Yes, I have an old patch series [1] to add SPI support. I stopped working on it while I was waiting for the series it depends on to be merged. I will probably start work on it again when the GPIO/Pinmux series [2] gets accepted. Be warned that it is buggy (sometimes there are weird erase bugs) and the SD card slot does not work, only the SPI. I'll gladly accept any help in this area, since I don't really have the equipment (logic analyzer/oscilloscope) necessary to debug the SPI protocol.
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=162653 [2] https://patchwork.ozlabs.org/project/uboot/list/?series=185489
--Sean
Ok, so as far as I can tell, only setup_board_part1 sets bi_memstart or bi_memsize. Outside of M68K, MIPS, PPC, and SH, the only generic code which reads those variables is env_get_bootm_size. ARM and MICROBLAZE both use the first DRAM bank to get the size, and everything else gets it from the "bootm_size" environmental variable.
I was having some troube booting certain image types earlier, so perhaps I just need set bootm_size to something sane. The Andestech boards don't set it in include/config/*.h, but instead include it in their Linux boot example. Rick, can you comment on how bootm_size (or bi_memsize) should be set?
On the subject of RAM layout, I have been unable to access the "ai ram" (the 3rd bank) without hanging the board. This ram is supposed to be usable by the cpu while the kpu is unused. For an example of what I am testing:
=> md.l 0x80400000 80400000: 00000000 00000000 00000000 00000000 ................ 80400010: 00000000 00000000 00000000 00000000 ................ 80400020: 00000000 00000000 00000000 00000000 ................ 80400030: 00000000 00000000 00000000 00000000 ................ 80400040: 00000000 00000000 00000000 00000000 ................ 80400050: 00000000 00000000 00000000 00000000 ................ 80400060: 00000000 00000000 00000000 00000000 ................ 80400070: 00000000 00000000 00000000 00000000 ................ 80400080: 00000000 00000000 00000000 00000000 ................ 80400090: 00000000 00000000 00000000 00000000 ................ 804000a0: 00000000 00000000 00000000 00000000 ................ 804000b0: 00000000 00000000 00000000 00000000 ................ 804000c0: 00000000 00000000 00000000 00000000 ................ 804000d0: 00000000 00000000 00000000 00000000 ................ 804000e0: 00000000 00000000 00000000 00000000 ................ 804000f0: 00000000 00000000 00000000 00000000 ................ => md.l 0x80600000 80600000:<board hangs here>
I have tried this on two boards (a maix bit, and a maixdiuino), and gotten the same result. I have tried different combinations of gating the KPU clock, and asserting the reset, but I wasn't able to get it working that way either. I also tried accessing this memory via JTAG, but it hangs via that method as well. I talked to Palmer Dabbelt when he was submitting his K210 series for Linux, and he was able to access this ram bank with no issues. Can you try accessing this memory area?
--Sean
Hello Sean,
--Sean
This seems to be general problem. I see the same on the Odroid C2.
You could fill this information in
fdtdec_setup_memory_banksize();
But I think it would be more reasonable to do this in board_init_f().
Best regards
Heinrich
--Sean
Sean Anderson
