[U-Boot] [PATCH v8 2/2] arm: A320: Add support for Faraday A320 evaluation board
This patch adds support for A320 evaluation board from Faraday. This board uses FA526 processor by default and has 512kB and 32MB NOR flash, 64M RAM. FA526 is an ARMv4 processor and uses the ARM920T source in this patch.
Signed-off-by: Po-Yu Chuang ratbert@faraday-tech.com --- v2: move flash timing parameters to config header do not call timer_init() in board_init() remove interrupt_init() in board specific code move soc-specific headers to include/asm-arm/arch-faraday/ use write32 in assembly remove board/faraday/a320/u-boot.lds move register bases to soc-specific headers
v3: do not define network parameters in config file
v4: keep list of MAINTAINERS sorted cleanup Makefile use get_ram_size() for auto-sizing and memory testing formating
v5: soc: a320, board: a320evb move ram and flash base to soc-specific header move reset_cpu to soc-specific code no bank swap
v6: rebase v7: rebase v8: rebase fix compiler warning no space between function name and parenthesis
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 3 + board/faraday/a320evb/Makefile | 51 ++++++++ board/faraday/a320evb/a320evb.c | 73 +++++++++++ board/faraday/a320evb/config.mk | 35 +++++ board/faraday/a320evb/lowlevel_init.S | 118 +++++++++++++++++ cpu/arm920t/a320/Makefile | 47 +++++++ cpu/arm920t/a320/ftsmc020.c | 51 ++++++++ cpu/arm920t/a320/reset.S | 22 ++++ cpu/arm920t/a320/timer.c | 193 ++++++++++++++++++++++++++++ include/asm-arm/arch-a320/a320.h | 35 +++++ include/asm-arm/arch-a320/ftpmu010.h | 146 +++++++++++++++++++++ include/asm-arm/arch-a320/ftsdmc020.h | 103 +++++++++++++++ include/asm-arm/arch-a320/ftsmc020.h | 79 ++++++++++++ include/asm-arm/arch-a320/fttmr010.h | 73 +++++++++++ include/configs/a320evb.h | 222 +++++++++++++++++++++++++++++++++ 17 files changed, 1256 insertions(+), 0 deletions(-) create mode 100644 board/faraday/a320evb/Makefile create mode 100644 board/faraday/a320evb/a320evb.c create mode 100644 board/faraday/a320evb/config.mk create mode 100644 board/faraday/a320evb/lowlevel_init.S create mode 100644 cpu/arm920t/a320/Makefile create mode 100644 cpu/arm920t/a320/ftsmc020.c create mode 100644 cpu/arm920t/a320/reset.S create mode 100644 cpu/arm920t/a320/timer.c create mode 100644 include/asm-arm/arch-a320/a320.h create mode 100644 include/asm-arm/arch-a320/ftpmu010.h create mode 100644 include/asm-arm/arch-a320/ftsdmc020.h create mode 100644 include/asm-arm/arch-a320/ftsmc020.h create mode 100644 include/asm-arm/arch-a320/fttmr010.h create mode 100644 include/configs/a320evb.h
diff --git a/MAINTAINERS b/MAINTAINERS index d70a9d2..4b8d095 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -543,6 +543,10 @@ Rick Bronson rick@efn.org
AT91RM9200DK at91rm9200
+Po-Yu Chuang ratbert@faraday-tech.com + + a320evb FA526 (ARM920T-like) (a320 SoC) + George G. Davis gdavis@mvista.com
assabet SA1100 diff --git a/MAKEALL b/MAKEALL index d63c5c2..a10aade 100755 --- a/MAKEALL +++ b/MAKEALL @@ -538,6 +538,7 @@ LIST_ARM7=" \ #########################################################################
LIST_ARM9=" \ + a320evb \ ap920t \ ap922_XA10 \ ap926ejs \ diff --git a/Makefile b/Makefile index bcb3fe9..7c64553 100644 --- a/Makefile +++ b/Makefile @@ -2693,6 +2693,9 @@ shannon_config : unconfig ## ARM92xT Systems #########################################################################
+a320evb_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm920t a320evb faraday a320 + ######################################################################### ## Atmel AT91RM9200 Systems ######################################################################### diff --git a/board/faraday/a320evb/Makefile b/board/faraday/a320evb/Makefile new file mode 100644 index 0000000..74f660d --- /dev/null +++ b/board/faraday/a320evb/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := a320evb.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/faraday/a320evb/a320evb.c b/board/faraday/a320evb/a320evb.c new file mode 100644 index 0000000..85b11b9 --- /dev/null +++ b/board/faraday/a320evb/a320evb.c @@ -0,0 +1,73 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <netdev.h> +#include <asm/io.h> + +#include <asm/arch/ftsmc020.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscellaneous platform dependent initialisations + */ + +int board_init(void) +{ + gd->bd->bi_arch_number = MACH_TYPE_FARADAY; + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + ftsmc020_init(); /* initialize Flash */ + return 0; +} + +int dram_init(void) +{ + unsigned long sdram_base = PHYS_SDRAM_1; + unsigned long expected_size = PHYS_SDRAM_1_SIZE; + unsigned long actual_size; + + actual_size = get_ram_size((void *)sdram_base, expected_size); + + gd->bd->bi_dram[0].start = sdram_base; + gd->bd->bi_dram[0].size = actual_size; + + if (expected_size != actual_size) + printf("Warning: Only %lu of %lu MiB SDRAM is working\n", + actual_size >> 20, expected_size >> 20); + + return 0; +} + +int board_eth_init(bd_t *bd) +{ + return ftmac100_initialize(bd); +} + +ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) +{ + if (banknum == 0) { /* non-CFI boot flash */ + info->portwidth = FLASH_CFI_8BIT; + info->chipwidth = FLASH_CFI_BY8; + info->interface = FLASH_CFI_X8; + return 1; + } else + return 0; +} diff --git a/board/faraday/a320evb/config.mk b/board/faraday/a320evb/config.mk new file mode 100644 index 0000000..aa25b98 --- /dev/null +++ b/board/faraday/a320evb/config.mk @@ -0,0 +1,35 @@ +# +# (C) Copyright 2009 Faraday Technology +# Po-Yu Chuang ratbert@faraday-tech.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# Faraday A320 board with FA526/FA626TE/ARM926EJ-S cpus +# +# see http://www.faraday-tech.com/ for more information + +# A320 has 1 bank of 64 MB DRAM +# +# 1000'0000 to 1400'0000 +# +# Linux-Kernel is expected to be at 1000'8000, entry 1000'8000 +# +# we load ourself to 13f8'0000 +# +# download area is 1200'0000 + +TEXT_BASE = 0x13f80000 diff --git a/board/faraday/a320evb/lowlevel_init.S b/board/faraday/a320evb/lowlevel_init.S new file mode 100644 index 0000000..97718c0 --- /dev/null +++ b/board/faraday/a320evb/lowlevel_init.S @@ -0,0 +1,118 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <config.h> +#include <version.h> + +#include <asm/macro.h> +#include <asm/arch/ftsdmc020.h> + +/* + * parameters for the SDRAM controller + */ +#define TP0_A (CONFIG_FTSDMC020_BASE + FTSDMC020_OFFSET_TP0) +#define TP1_A (CONFIG_FTSDMC020_BASE + FTSDMC020_OFFSET_TP1) +#define CR_A (CONFIG_FTSDMC020_BASE + FTSDMC020_OFFSET_CR) +#define B0_BSR_A (CONFIG_FTSDMC020_BASE + FTSDMC020_OFFSET_BANK0_BSR) +#define ACR_A (CONFIG_FTSDMC020_BASE + FTSDMC020_OFFSET_ACR) + +#define TP0_D CONFIG_SYS_FTSDMC020_TP0 +#define TP1_D CONFIG_SYS_FTSDMC020_TP1 +#define CR_D1 FTSDMC020_CR_IPREC +#define CR_D2 FTSDMC020_CR_ISMR +#define CR_D3 FTSDMC020_CR_IREF + +#define B0_BSR_D (CONFIG_SYS_FTSDMC020_BANK0_BSR | \ + FTSDMC020_BANK_BASE(PHYS_SDRAM_1)) +#define ACR_D FTSDMC020_ACR_TOC(0x18) + +/* + * numeric 7 segment display + */ +.macro led, num + write32 CONFIG_DEBUG_LED, \num +.endm + +/* + * Waiting for SDRAM to set up + */ +.macro wait_sdram + ldr r0, =CONFIG_FTSDMC020_BASE +1: + ldr r1, [r0, #FTSDMC020_OFFSET_CR] + cmp r1, #0 + bne 1b +.endm + +.globl lowlevel_init +lowlevel_init: + mov r11, lr + + led 0x0 + + bl init_sdmc + + led 0x1 + + /* everything is fine now */ + mov lr, r11 + mov pc, lr + +/* + * memory initialization + */ +init_sdmc: + led 0x10 + + /* set SDRAM register */ + + write32 TP0_A, TP0_D + led 0x11 + + write32 TP1_A, TP1_D + led 0x12 + + /* set to precharge */ + write32 CR_A, CR_D1 + led 0x13 + + wait_sdram + led 0x14 + + /* set mode register */ + write32 CR_A, CR_D2 + led 0x15 + + wait_sdram + led 0x16 + + /* set to refresh */ + write32 CR_A, CR_D3 + led 0x17 + + wait_sdram + led 0x18 + + write32 B0_BSR_A, B0_BSR_D + led 0x19 + + write32 ACR_A, ACR_D + led 0x1a + + mov pc, lr diff --git a/cpu/arm920t/a320/Makefile b/cpu/arm920t/a320/Makefile new file mode 100644 index 0000000..f030c53 --- /dev/null +++ b/cpu/arm920t/a320/Makefile @@ -0,0 +1,47 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +SOBJS += reset.o +COBJS += timer.o +COBJS += ftsmc020.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/cpu/arm920t/a320/ftsmc020.c b/cpu/arm920t/a320/ftsmc020.c new file mode 100644 index 0000000..7646537 --- /dev/null +++ b/cpu/arm920t/a320/ftsmc020.c @@ -0,0 +1,51 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/ftsmc020.h> + +struct ftsmc020_config { + unsigned int config; + unsigned int timing; +}; + +static struct ftsmc020_config config[] = CONFIG_SYS_FTSMC020_CONFIGS; + +static struct ftsmc020 *smc = (struct ftsmc020 *)CONFIG_FTSMC020_BASE; + +static void ftsmc020_setup_bank(unsigned int bank, struct ftsmc020_config *cfg) +{ + if (bank > 3) { + printf("bank # %u invalid\n", bank); + return; + } + + writel(cfg->config, &smc->bank[bank].cr); + writel(cfg->timing, &smc->bank[bank].tpr); +} + +void ftsmc020_init(void) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(config); i++) + ftsmc020_setup_bank(i, &config[i]); +} diff --git a/cpu/arm920t/a320/reset.S b/cpu/arm920t/a320/reset.S new file mode 100644 index 0000000..12ca527 --- /dev/null +++ b/cpu/arm920t/a320/reset.S @@ -0,0 +1,22 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +.global reset_cpu +reset_cpu: + b reset_cpu diff --git a/cpu/arm920t/a320/timer.c b/cpu/arm920t/a320/timer.c new file mode 100644 index 0000000..bb65593 --- /dev/null +++ b/cpu/arm920t/a320/timer.c @@ -0,0 +1,193 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/ftpmu010.h> +#include <asm/arch/fttmr010.h> + +static ulong timestamp; +static ulong lastdec; + +static struct fttmr010 *tmr = (struct fttmr010 *)CONFIG_FTTMR010_BASE; +static struct ftpmu010 *pmu = (struct ftpmu010 *)CONFIG_FTPMU010_BASE; + +#define TIMER_CLOCK 32768 +#define TIMER_LOAD_VAL 0xffffffff + +int timer_init(void) +{ + unsigned int oscc; + unsigned int cr; + + debug("%s()\n", __func__); + + /* disable timers */ + writel(0, &tmr->cr); + + /* + * use 32768Hz oscillator for RTC, WDT, TIMER + */ + + /* enable the 32768Hz oscillator */ + oscc = readl(&pmu->OSCC); + oscc &= ~(FTPMU010_OSCC_OSCL_OFF | FTPMU010_OSCC_OSCL_TRI); + writel(oscc, &pmu->OSCC); + + /* wait until ready */ + while (!(readl(&pmu->OSCC) & FTPMU010_OSCC_OSCL_STABLE)) + ; + + /* select 32768Hz oscillator */ + oscc = readl(&pmu->OSCC); + oscc |= FTPMU010_OSCC_OSCL_RTCLSEL; + writel(oscc, &pmu->OSCC); + + /* setup timer */ + writel(TIMER_LOAD_VAL, &tmr->timer3_load); + writel(TIMER_LOAD_VAL, &tmr->timer3_counter); + writel(0, &tmr->timer3_match1); + writel(0, &tmr->timer3_match2); + + /* we don't want timer to issue interrupts */ + writel(FTTMR010_TM3_MATCH1 | + FTTMR010_TM3_MATCH2 | + FTTMR010_TM3_OVERFLOW, + &tmr->interrupt_mask); + + cr = readl(&tmr->cr); + cr |= FTTMR010_TM3_CLOCK; /* use external clock */ + cr |= FTTMR010_TM3_ENABLE; + writel(cr, &tmr->cr); + + /* init the timestamp and lastdec value */ + reset_timer_masked(); + + return 0; +} + +/* + * timer without interrupts + */ + +/* + * reset time + */ +void reset_timer_masked(void) +{ + /* capure current decrementer value time */ + lastdec = readl(&tmr->timer3_counter) / (TIMER_CLOCK / CONFIG_SYS_HZ); + timestamp = 0; /* start "advancing" time stamp from 0 */ + + debug("%s(): lastdec = %lx\n", __func__, lastdec); +} + +void reset_timer(void) +{ + debug("%s()\n", __func__); + reset_timer_masked(); +} + +/* + * return timer ticks + */ +ulong get_timer_masked(void) +{ + /* current tick value */ + ulong now = readl(&tmr->timer3_counter) / (TIMER_CLOCK / CONFIG_SYS_HZ); + + debug("%s(): now = %lx, lastdec = %lx\n", __func__, now, lastdec); + + if (lastdec >= now) { + /* + * normal mode (non roll) + * move stamp fordward with absoulte diff ticks + */ + timestamp += lastdec - now; + } else { + /* + * we have overflow of the count down timer + * + * nts = ts + ld + (TLV - now) + * ts=old stamp, ld=time that passed before passing through -1 + * (TLV-now) amount of time after passing though -1 + * nts = new "advancing time stamp"...it could also roll and + * cause problems. + */ + timestamp += lastdec + TIMER_LOAD_VAL - now; + } + + lastdec = now; + + debug("%s() returns %lx\n", __func__, timestamp); + + return timestamp; +} + +/* + * return difference between timer ticks and base + */ +ulong get_timer(ulong base) +{ + debug("%s(%lx)\n", __func__, base); + return get_timer_masked() - base; +} + +void set_timer(ulong t) +{ + debug("%s(%lx)\n", __func__, t); + timestamp = t; +} + +/* delay x useconds AND perserve advance timstamp value */ +void udelay(unsigned long usec) +{ + long tmo = usec * (TIMER_CLOCK / 1000) / 1000; + unsigned long now, last = readl(&tmr->timer3_counter); + + debug("%s(%lu)\n", __func__, usec); + while (tmo > 0) { + now = readl(&tmr->timer3_counter); + if (now > last) /* count down timer overflow */ + tmo -= TIMER_LOAD_VAL + last - now; + else + tmo -= last - now; + last = now; + } +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + debug("%s()\n", __func__); + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + debug("%s()\n", __func__); + return CONFIG_SYS_HZ; +} diff --git a/include/asm-arm/arch-a320/a320.h b/include/asm-arm/arch-a320/a320.h new file mode 100644 index 0000000..5c0a097 --- /dev/null +++ b/include/asm-arm/arch-a320/a320.h @@ -0,0 +1,35 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __A320_H +#define __A320_H + +/* + * Hardware register bases + */ +#define CONFIG_FTSMC020_BASE 0x90200000 /* Static Memory Controller */ +#define CONFIG_DEBUG_LED 0x902ffffc /* Debug LED */ +#define CONFIG_FTSDMC020_BASE 0x90300000 /* SDRAM Controller */ +#define CONFIG_FTMAC100_BASE 0x90900000 /* Ethernet */ +#define CONFIG_FTPMU010_BASE 0x98100000 /* Power Management Unit */ +#define CONFIG_FTTMR010_BASE 0x98400000 /* Timer */ +#define CONFIG_FTRTC010_BASE 0x98600000 /* Real Time Clock*/ + +#endif /* __A320_H */ + diff --git a/include/asm-arm/arch-a320/ftpmu010.h b/include/asm-arm/arch-a320/ftpmu010.h new file mode 100644 index 0000000..8ef7a37 --- /dev/null +++ b/include/asm-arm/arch-a320/ftpmu010.h @@ -0,0 +1,146 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * Power Management Unit + */ +#ifndef __FTPMU010_H +#define __FTPMU010_H + +struct ftpmu010 { + unsigned int IDNMBR0; /* 0x00 */ + unsigned int reserved0; /* 0x04 */ + unsigned int OSCC; /* 0x08 */ + unsigned int PMODE; /* 0x0C */ + unsigned int PMCR; /* 0x10 */ + unsigned int PED; /* 0x14 */ + unsigned int PEDSR; /* 0x18 */ + unsigned int reserved1; /* 0x1C */ + unsigned int PMSR; /* 0x20 */ + unsigned int PGSR; /* 0x24 */ + unsigned int MFPSR; /* 0x28 */ + unsigned int MISC; /* 0x2C */ + unsigned int PDLLCR0; /* 0x30 */ + unsigned int PDLLCR1; /* 0x34 */ + unsigned int AHBMCLKOFF; /* 0x38 */ + unsigned int APBMCLKOFF; /* 0x3C */ + unsigned int DCSRCR0; /* 0x40 */ + unsigned int DCSRCR1; /* 0x44 */ + unsigned int DCSRCR2; /* 0x48 */ + unsigned int SDRAMHTC; /* 0x4C */ + unsigned int PSPR0; /* 0x50 */ + unsigned int PSPR1; /* 0x54 */ + unsigned int PSPR2; /* 0x58 */ + unsigned int PSPR3; /* 0x5C */ + unsigned int PSPR4; /* 0x60 */ + unsigned int PSPR5; /* 0x64 */ + unsigned int PSPR6; /* 0x68 */ + unsigned int PSPR7; /* 0x6C */ + unsigned int PSPR8; /* 0x70 */ + unsigned int PSPR9; /* 0x74 */ + unsigned int PSPR10; /* 0x78 */ + unsigned int PSPR11; /* 0x7C */ + unsigned int PSPR12; /* 0x80 */ + unsigned int PSPR13; /* 0x84 */ + unsigned int PSPR14; /* 0x88 */ + unsigned int PSPR15; /* 0x8C */ + unsigned int AHBDMA_RACCS; /* 0x90 */ + unsigned int reserved2; /* 0x94 */ + unsigned int reserved3; /* 0x98 */ + unsigned int JSS; /* 0x9C */ + unsigned int CFC_RACC; /* 0xA0 */ + unsigned int SSP1_RACC; /* 0xA4 */ + unsigned int UART1TX_RACC; /* 0xA8 */ + unsigned int UART1RX_RACC; /* 0xAC */ + unsigned int UART2TX_RACC; /* 0xB0 */ + unsigned int UART2RX_RACC; /* 0xB4 */ + unsigned int SDC_RACC; /* 0xB8 */ + unsigned int I2SAC97_RACC; /* 0xBC */ + unsigned int IRDATX_RACC; /* 0xC0 */ + unsigned int reserved4; /* 0xC4 */ + unsigned int USBD_RACC; /* 0xC8 */ + unsigned int IRDARX_RACC; /* 0xCC */ + unsigned int IRDA_RACC; /* 0xD0 */ + unsigned int ED0_RACC; /* 0xD4 */ + unsigned int ED1_RACC; /* 0xD8 */ +}; + +/* + * ID Number 0 Register + */ +#define FTPMU010_ID_A320A 0x03200000 +#define FTPMU010_ID_A320C 0x03200010 +#define FTPMU010_ID_A320D 0x03200030 + +/* + * OSC Control Register + */ +#define FTPMU010_OSCC_OSCH_TRI (1 << 11) +#define FTPMU010_OSCC_OSCH_STABLE (1 << 9) +#define FTPMU010_OSCC_OSCH_OFF (1 << 8) + +#define FTPMU010_OSCC_OSCL_TRI (1 << 3) +#define FTPMU010_OSCC_OSCL_RTCLSEL (1 << 2) +#define FTPMU010_OSCC_OSCL_STABLE (1 << 1) +#define FTPMU010_OSCC_OSCL_OFF (1 << 0) + +/* + * Power Mode Register + */ +#define FTPMU010_PMODE_DIVAHBCLK_MASK (0x7 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_2 (0x0 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_3 (0x1 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_4 (0x2 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_6 (0x3 << 4) +#define FTPMU010_PMODE_DIVAHBCLK_8 (0x4 << 4) +#define FTPMU010_PMODE_DIVAHBCLK(pmode) (((pmode) >> 4) & 0x7) +#define FTPMU010_PMODE_FCS (1 << 2) +#define FTPMU010_PMODE_TURBO (1 << 1) +#define FTPMU010_PMODE_SLEEP (1 << 0) + +/* + * Power Manager Status Register + */ +#define FTPMU010_PMSR_SMR (1 << 10) + +#define FTPMU010_PMSR_RDH (1 << 2) +#define FTPMU010_PMSR_PH (1 << 1) +#define FTPMU010_PMSR_CKEHLOW (1 << 0) + +/* + * Multi-Function Port Setting Register + */ +#define FTPMU010_MFPSR_MODEMPINSEL (1 << 14) +#define FTPMU010_MFPSR_AC97CLKOUTSEL (1 << 13) +#define FTPMU010_MFPSR_AC97PINSEL (1 << 3) + +/* + * PLL/DLL Control Register 0 + */ +#define FTPMU010_PDLLCR0_HCLKOUTDIS(cr0) (((cr0) >> 20) & 0xf) +#define FTPMU010_PDLLCR0_DLLFRAG (1 << 19) +#define FTPMU010_PDLLCR0_DLLSTSEL (1 << 18) +#define FTPMU010_PDLLCR0_DLLSTABLE (1 << 17) +#define FTPMU010_PDLLCR0_DLLDIS (1 << 16) +#define FTPMU010_PDLLCR0_PLL1NS(cr0) (((cr0) >> 3) & 0x1ff) +#define FTPMU010_PDLLCR0_PLL1STSEL (1 << 2) +#define FTPMU010_PDLLCR0_PLL1STABLE (1 << 1) +#define FTPMU010_PDLLCR0_PLL1DIS (1 << 0) + +#endif /* __FTPMU010_H */ diff --git a/include/asm-arm/arch-a320/ftsdmc020.h b/include/asm-arm/arch-a320/ftsdmc020.h new file mode 100644 index 0000000..0699772 --- /dev/null +++ b/include/asm-arm/arch-a320/ftsdmc020.h @@ -0,0 +1,103 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * SDRAM Controller + */ +#ifndef __FTSDMC020_H +#define __FTSDMC020_H + +#define FTSDMC020_OFFSET_TP0 0x00 +#define FTSDMC020_OFFSET_TP1 0x04 +#define FTSDMC020_OFFSET_CR 0x08 +#define FTSDMC020_OFFSET_BANK0_BSR 0x0C +#define FTSDMC020_OFFSET_BANK1_BSR 0x10 +#define FTSDMC020_OFFSET_BANK2_BSR 0x14 +#define FTSDMC020_OFFSET_BANK3_BSR 0x18 +#define FTSDMC020_OFFSET_BANK4_BSR 0x1C +#define FTSDMC020_OFFSET_BANK5_BSR 0x20 +#define FTSDMC020_OFFSET_BANK6_BSR 0x24 +#define FTSDMC020_OFFSET_BANK7_BSR 0x28 +#define FTSDMC020_OFFSET_ACR 0x34 + +/* + * Timing Parametet 0 Register + */ +#define FTSDMC020_TP0_TCL(x) ((x) & 0x3) +#define FTSDMC020_TP0_TWR(x) (((x) & 0x3) << 4) +#define FTSDMC020_TP0_TRF(x) (((x) & 0xf) << 8) +#define FTSDMC020_TP0_TRCD(x) (((x) & 0x7) << 12) +#define FTSDMC020_TP0_TRP(x) (((x) & 0xf) << 16) +#define FTSDMC020_TP0_TRAS(x) (((x) & 0xf) << 20) + +/* + * Timing Parametet 1 Register + */ +#define FTSDMC020_TP1_REF_INTV(x) ((x) & 0xffff) +#define FTSDMC020_TP1_INI_REFT(x) (((x) & 0xf) << 16) +#define FTSDMC020_TP1_INI_PREC(x) (((x) & 0xf) << 20) + +/* + * Configuration Register + */ +#define FTSDMC020_CR_SREF (1 << 0) +#define FTSDMC020_CR_PWDN (1 << 1) +#define FTSDMC020_CR_ISMR (1 << 2) +#define FTSDMC020_CR_IREF (1 << 3) +#define FTSDMC020_CR_IPREC (1 << 4) +#define FTSDMC020_CR_REFTYPE (1 << 5) + +/* + * SDRAM External Bank Base/Size Register + */ +#define FTSDMC020_BANK_ENABLE (1 << 28) + +#define FTSDMC020_BANK_BASE(addr) (((addr) >> 20) << 16) + +#define FTSDMC020_BANK_DDW_X4 (0 << 12) +#define FTSDMC020_BANK_DDW_X8 (1 << 12) +#define FTSDMC020_BANK_DDW_X16 (2 << 12) +#define FTSDMC020_BANK_DDW_X32 (3 << 12) + +#define FTSDMC020_BANK_DSZ_16M (0 << 8) +#define FTSDMC020_BANK_DSZ_64M (1 << 8) +#define FTSDMC020_BANK_DSZ_128M (2 << 8) +#define FTSDMC020_BANK_DSZ_256M (3 << 8) + +#define FTSDMC020_BANK_MBW_8 (0 << 4) +#define FTSDMC020_BANK_MBW_16 (1 << 4) +#define FTSDMC020_BANK_MBW_32 (2 << 4) + +#define FTSDMC020_BANK_SIZE_1M 0x0 +#define FTSDMC020_BANK_SIZE_2M 0x1 +#define FTSDMC020_BANK_SIZE_4M 0x2 +#define FTSDMC020_BANK_SIZE_8M 0x3 +#define FTSDMC020_BANK_SIZE_16M 0x4 +#define FTSDMC020_BANK_SIZE_32M 0x5 +#define FTSDMC020_BANK_SIZE_64M 0x6 +#define FTSDMC020_BANK_SIZE_128M 0x7 +#define FTSDMC020_BANK_SIZE_256M 0x8 + +/* + * Arbiter Control Register + */ +#define FTSDMC020_ACR_TOC(x) ((x) & 0x1f) +#define FTSDMC020_ACR_TOE (1 << 8) + +#endif /* __FTSDMC020_H */ diff --git a/include/asm-arm/arch-a320/ftsmc020.h b/include/asm-arm/arch-a320/ftsmc020.h new file mode 100644 index 0000000..95d9500 --- /dev/null +++ b/include/asm-arm/arch-a320/ftsmc020.h @@ -0,0 +1,79 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * Static Memory Controller + */ +#ifndef __FTSMC020_H +#define __FTSMC020_H + +#ifndef __ASSEMBLY__ + +struct ftsmc020 { + struct { + unsigned int cr; /* 0x00, 0x08, 0x10, 0x18 */ + unsigned int tpr; /* 0x04, 0x0c, 0x14, 0x1c */ + } bank[4]; + unsigned int pad[8]; /* 0x20 - 0x3c */ + unsigned int ssr; /* 0x40 */ +}; + +void ftsmc020_init(void); + +#endif /* __ASSEMBLY__ */ + +/* + * Memory Bank Configuration Register + */ +#define FTSMC020_BANK_ENABLE (1 << 28) +#define FTSMC020_BANK_BASE(x) ((x) & 0x0fff1000) + +#define FTSMC020_BANK_WPROT (1 << 11) + +#define FTSMC020_BANK_SIZE_32K (0xb << 4) +#define FTSMC020_BANK_SIZE_64K (0xc << 4) +#define FTSMC020_BANK_SIZE_128K (0xd << 4) +#define FTSMC020_BANK_SIZE_256K (0xe << 4) +#define FTSMC020_BANK_SIZE_512K (0xf << 4) +#define FTSMC020_BANK_SIZE_1M (0x0 << 4) +#define FTSMC020_BANK_SIZE_2M (0x1 << 4) +#define FTSMC020_BANK_SIZE_4M (0x2 << 4) +#define FTSMC020_BANK_SIZE_8M (0x3 << 4) +#define FTSMC020_BANK_SIZE_16M (0x4 << 4) +#define FTSMC020_BANK_SIZE_32M (0x5 << 4) + +#define FTSMC020_BANK_MBW_8 (0x0 << 0) +#define FTSMC020_BANK_MBW_16 (0x1 << 0) +#define FTSMC020_BANK_MBW_32 (0x2 << 0) + +/* + * Memory Bank Timing Parameter Register + */ +#define FTSMC020_TPR_ETRNA(x) (((x) & 0xf) << 28) +#define FTSMC020_TPR_EATI(x) (((x) & 0xf) << 24) +#define FTSMC020_TPR_RBE (1 << 20) +#define FTSMC020_TPR_AST(x) (((x) & 0x3) << 18) +#define FTSMC020_TPR_CTW(x) (((x) & 0x3) << 16) +#define FTSMC020_TPR_ATI(x) (((x) & 0xf) << 12) +#define FTSMC020_TPR_AT2(x) (((x) & 0x3) << 8) +#define FTSMC020_TPR_WTC(x) (((x) & 0x3) << 6) +#define FTSMC020_TPR_AHT(x) (((x) & 0x3) << 4) +#define FTSMC020_TPR_TRNA(x) (((x) & 0xf) << 0) + +#endif /* __FTSMC020_H */ diff --git a/include/asm-arm/arch-a320/fttmr010.h b/include/asm-arm/arch-a320/fttmr010.h new file mode 100644 index 0000000..72abcb3 --- /dev/null +++ b/include/asm-arm/arch-a320/fttmr010.h @@ -0,0 +1,73 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * Timer + */ +#ifndef __FTTMR010_H +#define __FTTMR010_H + +struct fttmr010 { + unsigned int timer1_counter; /* 0x00 */ + unsigned int timer1_load; /* 0x04 */ + unsigned int timer1_match1; /* 0x08 */ + unsigned int timer1_match2; /* 0x0c */ + unsigned int timer2_counter; /* 0x10 */ + unsigned int timer2_load; /* 0x14 */ + unsigned int timer2_match1; /* 0x18 */ + unsigned int timer2_match2; /* 0x1c */ + unsigned int timer3_counter; /* 0x20 */ + unsigned int timer3_load; /* 0x24 */ + unsigned int timer3_match1; /* 0x28 */ + unsigned int timer3_match2; /* 0x2c */ + unsigned int cr; /* 0x30 */ + unsigned int interrupt_state; /* 0x34 */ + unsigned int interrupt_mask; /* 0x38 */ +}; + +/* + * Timer Control Register + */ +#define FTTMR010_TM3_UPDOWN (1 << 11) +#define FTTMR010_TM2_UPDOWN (1 << 10) +#define FTTMR010_TM1_UPDOWN (1 << 9) +#define FTTMR010_TM3_OFENABLE (1 << 8) +#define FTTMR010_TM3_CLOCK (1 << 7) +#define FTTMR010_TM3_ENABLE (1 << 6) +#define FTTMR010_TM2_OFENABLE (1 << 5) +#define FTTMR010_TM2_CLOCK (1 << 4) +#define FTTMR010_TM2_ENABLE (1 << 3) +#define FTTMR010_TM1_OFENABLE (1 << 2) +#define FTTMR010_TM1_CLOCK (1 << 1) +#define FTTMR010_TM1_ENABLE (1 << 0) + +/* + * Timer Interrupt State & Mask Registers + */ +#define FTTMR010_TM3_OVERFLOW (1 << 8) +#define FTTMR010_TM3_MATCH2 (1 << 7) +#define FTTMR010_TM3_MATCH1 (1 << 6) +#define FTTMR010_TM2_OVERFLOW (1 << 5) +#define FTTMR010_TM2_MATCH2 (1 << 4) +#define FTTMR010_TM2_MATCH1 (1 << 3) +#define FTTMR010_TM1_OVERFLOW (1 << 2) +#define FTTMR010_TM1_MATCH2 (1 << 1) +#define FTTMR010_TM1_MATCH1 (1 << 0) + +#endif /* __FTTMR010_H */ diff --git a/include/configs/a320evb.h b/include/configs/a320evb.h new file mode 100644 index 0000000..fcc5563 --- /dev/null +++ b/include/configs/a320evb.h @@ -0,0 +1,222 @@ +/* + * (C) Copyright 2009 Faraday Technology + * Po-Yu Chuang ratbert@faraday-tech.com + * + * Configuation settings for the Faraday A320 board. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/a320.h> + +/*----------------------------------------------------------------------- + * CPU and Board Configuration Options + */ +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#undef CONFIG_SKIP_LOWLEVEL_INIT + +/*----------------------------------------------------------------------- + * Timer + */ +#define CONFIG_SYS_HZ 1000 /* timer ticks per second */ + +/*----------------------------------------------------------------------- + * Real Time Clock + */ +#define CONFIG_RTC_FTRTC010 + +/*----------------------------------------------------------------------- + * Serial console configuration + */ + +/* FTUART is a high speed NS 16C550A compatible UART */ +#define CONFIG_BAUDRATE 38400 +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_COM1 0x98200000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_CLK 18432000 + +/* valid baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/*----------------------------------------------------------------------- + * Ethernet + */ +#define CONFIG_NET_MULTI +#define CONFIG_FTMAC100 + +#define CONFIG_BOOTDELAY 3 + +/*----------------------------------------------------------------------- + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_PING + +/*----------------------------------------------------------------------- + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "A320 # " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* max number of command args */ +#define CONFIG_SYS_MAXARGS 16 + +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4 * 1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4 * 1024) /* FIQ stack */ +#endif + +/*----------------------------------------------------------------------- + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) + +/*----------------------------------------------------------------------- + * size in bytes reserved for initial data +*/ +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +/*----------------------------------------------------------------------- + * SDRAM controller configuration + */ +#define CONFIG_SYS_FTSDMC020_TP0 (FTSDMC020_TP0_TRAS(2) | \ + FTSDMC020_TP0_TRP(1) | \ + FTSDMC020_TP0_TRCD(1) | \ + FTSDMC020_TP0_TRF(3) | \ + FTSDMC020_TP0_TWR(1) | \ + FTSDMC020_TP0_TCL(2)) + +#define CONFIG_SYS_FTSDMC020_TP1 (FTSDMC020_TP1_INI_PREC(4) | \ + FTSDMC020_TP1_INI_REFT(8) | \ + FTSDMC020_TP1_REF_INTV(0x180)) + +#define CONFIG_SYS_FTSDMC020_BANK0_BSR (FTSDMC020_BANK_ENABLE | \ + FTSDMC020_BANK_DDW_X16 | \ + FTSDMC020_BANK_DSZ_256M | \ + FTSDMC020_BANK_MBW_32 | \ + FTSDMC020_BANK_SIZE_64M) + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x10000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ + +/* + * Load address and memory test area should agree with + * board/faraday/a320/config.mk. Be careful not to overwrite U-boot itself. + */ +#define CONFIG_SYS_LOAD_ADDR 0x12000000 + +/* memtest works on 63 MB in DRAM */ +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x13F00000 + +/*----------------------------------------------------------------------- + * Static memory controller configuration + */ + +#include <asm/arch/ftsmc020.h> + +#define FTSMC020_BANK0_CONFIG (FTSMC020_BANK_ENABLE | \ + FTSMC020_BANK_BASE(PHYS_FLASH_1) | \ + FTSMC020_BANK_SIZE_1M | \ + FTSMC020_BANK_MBW_8) + +#define FTSMC020_BANK0_TIMING (FTSMC020_TPR_RBE | \ + FTSMC020_TPR_AST(3) | \ + FTSMC020_TPR_CTW(3) | \ + FTSMC020_TPR_ATI(0xf) | \ + FTSMC020_TPR_AT2(3) | \ + FTSMC020_TPR_WTC(3) | \ + FTSMC020_TPR_AHT(3) | \ + FTSMC020_TPR_TRNA(0xf)) + +#define FTSMC020_BANK1_CONFIG (FTSMC020_BANK_ENABLE | \ + FTSMC020_BANK_BASE(PHYS_FLASH_2) | \ + FTSMC020_BANK_SIZE_32M | \ + FTSMC020_BANK_MBW_32) + +#define FTSMC020_BANK1_TIMING (FTSMC020_TPR_AST(3) | \ + FTSMC020_TPR_CTW(3) | \ + FTSMC020_TPR_ATI(0xf) | \ + FTSMC020_TPR_AT2(3) | \ + FTSMC020_TPR_WTC(3) | \ + FTSMC020_TPR_AHT(3) | \ + FTSMC020_TPR_TRNA(0xf)) + +#define CONFIG_SYS_FTSMC020_CONFIGS { \ + { FTSMC020_BANK0_CONFIG, FTSMC020_BANK0_TIMING, }, \ + { FTSMC020_BANK1_CONFIG, FTSMC020_BANK1_TIMING, }, \ +} + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ + +/* use CFI framework */ +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER + +/* support JEDEC */ +#define CONFIG_FLASH_CFI_LEGACY +#define CONFIG_SYS_FLASH_LEGACY_512Kx8 + +#define PHYS_FLASH_1 0x00000000 +#define PHYS_FLASH_2 0x00400000 +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#define CONFIG_SYS_FLASH_BANKS_LIST { PHYS_FLASH_1, PHYS_FLASH_2, } + +#define CONFIG_SYS_MONITOR_BASE PHYS_FLASH_1 + +/* max number of memory banks */ +#define CONFIG_SYS_MAX_FLASH_BANKS 2 + +/* max number of sectors on one chip */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 + +#undef CONFIG_SYS_FLASH_EMPTY_INFO + +/* environments */ +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR 0x00060000 +#define CONFIG_ENV_SIZE 0x20000 + +#endif /* __CONFIG_H */
Po-Yu Chuang
