Re: [U-Boot-Users] How to use u-boot to load kernel and file system to one partition in NAND
-----Original Message----- From: wd@denx.de [mailto:wd@denx.de] Sent: Thursday, November 02, 2006 2:47 PM To: Nancy Isaac Cc: Charles Krinke; u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] How to use u-boot to load kernel and file system to one partition in NAND
In message 9BB2AECBBDD3E6499663C42C1DFD40AAE49768@PETWM02.calix.local you wrote:
The problem I have is not really how to put the kernel in NAND, but
how
to upgrade it. I don't really want to overwrite what I have, instead
I
want to load another image and have u-boot be able to pick up one or
the
other. This way, I can have two copies and in case the new version is bad, I can always have one to fall back on. This is why, I was
thinking
that either having a soft link to a file in a single partition nand or have three separate partitions (two of them for kernel, one for file system).
Why not simply using different names for both images, and switching the boot filename in U-Boot? Remember that U-Boot is scriptable, so this is a trivial thing to do.
Thanks. I will try this out.
Nancy Isaac
