[U-Boot] [PATCH 1/1] Fix JFFS2 NOR sector size routine
This patch fixes the JFFS2 scanning code when not using CONFIG_JFFS2_CMDLINE.
Signed-off-by: Mark Jackson mpfj@mimc.co.uk --- common/cmd_jffs2.c | 7 ++++++- 1 files changed, 6 insertions(+), 1 deletions(-)
diff --git a/common/cmd_jffs2.c b/common/cmd_jffs2.c index d0a7cea..2f3b3a9 100644 --- a/common/cmd_jffs2.c +++ b/common/cmd_jffs2.c @@ -1814,7 +1814,12 @@ static inline u32 get_part_sector_size_nor(struct mtdids *id, struct part_info * flash = &flash_info[id->num];
start_phys = flash->start[0] + part->offset; - end_phys = start_phys + part->size; + + if (part->size == SIZE_REMAINING) { + end_phys = start_phys + flash->size; + } else { + end_phys = start_phys + part->size; + }
for (i = 0; i < flash->sector_count; i++) { if (flash->start[i] >= end_phys)
- if (part->size == SIZE_REMAINING) {
- } else {
That looks wrong if part->offset != 0; shouldn't it be:
if (part->size == SIZE_REMAINING) end_phys = flash->start[0] + flash->size; else end_phys = start_phys + part->size;
-Scott
diff --git a/common/cmd_jffs2.c b/common/cmd_jffs2.c index d0a7cea..2f3b3a9 100644 --- a/common/cmd_jffs2.c +++ b/common/cmd_jffs2.c @@ -1814,7 +1814,12 @@ static inline u32 get_part_sector_size_nor(struct mtdids *id, struct part_info * flash =&flash_info[id->num];
- } else {
-Scott
Yes ... that seems perfectly reasonable !!
I'll update my patch, retest and resubmit.
Thanks Mark
Mark Jackson
Scott Wood
