[U-Boot] [PATCH v2] Add support for initializing MMC
Firmware loader would encounter problem if the MMC is accessed before initializing it. This patch would adding the support of probing block device and initializing MMC before the MMC is accessed by firmware loader.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com
--- Changes in v2: - Initializing MMC through probing the blk device --- drivers/misc/fs_loader.c | 32 ++++++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/drivers/misc/fs_loader.c b/drivers/misc/fs_loader.c index 57a14a3..d981b5a 100644 --- a/drivers/misc/fs_loader.c +++ b/drivers/misc/fs_loader.c @@ -12,6 +12,7 @@ #include <linux/string.h> #include <mapmem.h> #include <malloc.h> +#include <mmc.h> #include <spl.h>
DECLARE_GLOBAL_DATA_PTR; @@ -252,6 +253,37 @@ static int fs_loader_ofdata_to_platdata(struct udevice *dev)
static int fs_loader_probe(struct udevice *dev) { +#if defined(CONFIG_DM_MMC) && defined(CONFIG_BLK) + int ret; + struct device_platdata *plat = dev->platdata; + + ret = mmc_initialize(NULL); + if (ret) { + debug("MMC: could not initialize mmc. error: %d\n", ret); + + return ret; + } + + if (plat->phandlepart.phandle) { + ofnode node = ofnode_get_by_phandle(plat->phandlepart.phandle); + + struct udevice *mmc_dev = NULL; + + ret = device_get_global_by_ofnode(node, &mmc_dev); + if (!ret) { + struct mmc *mmc = mmc_get_mmc_dev(mmc_dev); + struct udevice *dev; + + if (blk_get_from_parent(mmc->dev, &dev)) + { + debug("MMC: No block device: %d\n", + ret); + + return ret; + } + } + } +#endif return 0; };
Changes in v2:
Please ignore this patch, just realized missing a line status checking code. I would resend another patch.
diff --git a/drivers/misc/fs_loader.c b/drivers/misc/fs_loader.c index 57a14a3..d981b5a 100644 --- a/drivers/misc/fs_loader.c +++ b/drivers/misc/fs_loader.c @@ -12,6 +12,7 @@ #include <linux/string.h> #include <mapmem.h> #include <malloc.h> +#include <mmc.h> #include <spl.h> DECLARE_GLOBAL_DATA_PTR; @@ -252,6 +253,37 @@ static int fs_loader_ofdata_to_platdata(struct udevice *dev) static int fs_loader_probe(struct udevice *dev) { +#if defined(CONFIG_DM_MMC) && defined(CONFIG_BLK)
- int ret;
- struct device_platdata *plat = dev->platdata;
- ret = mmc_initialize(NULL);
- if (ret) {
ret);
return ret;
- if (plat->phandlepart.phandle) {
if (!ret) {
ret);
return ret;
Chee, Tien Fong
