[U-Boot] [RFC Patch 0/5] Resolve conflict for merging
Tom,
I made these patches on top of my fsl-qoriq master. Once merged, the ad-hoc config error should not appear. In this set, I start to convert some options to Kconfig. Please let me know if this is the right solution. I also convert the MMDC driver to use data structure as you suggested. Do not apply to your tree. I will request a pull after we agree on them.
[RFC Patch 1/5] armv8: ls1046a: Convert CONFIG_LS1046A to Kconfig [RFC Patch 2/5] driver: ddr: fsl_mmdc: Pass board parameters through [RFC Patch 3/5] armv8: ls1012a: Convert CONFIG_LS1012A to Kconfig [RFC Patch 4/5] Convert CONFIG_SYS_FSL_ERRATUM_A010315 to Kconfig [RFC Patch 5/5] armv8: ls1046ardb_emmc: Fix a typo in defconfig
York
Move this option to Kconfig and clean up existing uses.
Signed-off-by: York Sun york.sun@nxp.com CC: Mingkai Hu mingkai.hu@nxp.com CC: Gong Qianyu Qianyu.Gong@nxp.com --- arch/arm/Kconfig | 4 ++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 2 ++ arch/arm/cpu/armv8/fsl-layerscape/Makefile | 2 +- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 2 +- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 2 +- arch/arm/include/asm/arch-fsl-layerscape/config.h | 3 ++- drivers/net/fm/Makefile | 2 +- include/configs/ls1046a_common.h | 1 - 8 files changed, 12 insertions(+), 6 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/Kconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 1560bcc..aed89c9 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -843,6 +843,7 @@ config TARGET_LS1043ARDB
config TARGET_LS1046AQDS bool "Support ls1046aqds" + select ARCH_LS1046A select ARM64 select ARMV8_MULTIENTRY select SUPPORT_SPL @@ -855,6 +856,7 @@ config TARGET_LS1046AQDS
config TARGET_LS1046ARDB bool "Support ls1046ardb" + select ARCH_LS1046A select ARM64 select ARMV8_MULTIENTRY select SUPPORT_SPL @@ -951,6 +953,8 @@ source "arch/arm/cpu/armv7/mx5/Kconfig"
source "arch/arm/cpu/armv7/omap-common/Kconfig"
+source "arch/arm/cpu/armv8/fsl-layerscape/Kconfig" + source "arch/arm/mach-orion5x/Kconfig"
source "arch/arm/mach-rmobile/Kconfig" diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig new file mode 100644 index 0000000..c234eff --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -0,0 +1,2 @@ +config ARCH_LS1046A + bool "Freescale Layerscape LS1046A SoC" diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index 8c1317f..f9590af 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -34,6 +34,6 @@ ifneq ($(CONFIG_LS1012A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1012a_serdes.o endif
-ifneq ($(CONFIG_LS1046A),) +ifneq ($(CONFIG_ARCH_LS1046A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1046a_serdes.o endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 6451a36..5d0b7a4 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -180,7 +180,7 @@ ENTRY(lowlevel_init) dsb sy #endif
-#ifdef CONFIG_LS1046A +#ifdef CONFIG_ARCH_LS1046A /* Initialize the L2 RAM latency */ mrs x1, S3_1_c11_c0_2 mov x0, #0x1C7 diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 5ca721d..463d1e3 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -228,7 +228,7 @@ int sata_init(void) { struct ccsr_ahci __iomem *ccsr_ahci = (void *)CONFIG_SYS_SATA;
-#ifdef CONFIG_LS1046A +#ifdef CONFIG_ARCH_LS1046A /* Disable SATA ECC */ out_le32((void *)CONFIG_SYS_DCSR_DCFG_ADDR + 0x520, 0x80000000); #endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 81a5e7c..e7c7d98 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -7,6 +7,7 @@ #ifndef _ASM_ARMV8_FSL_LAYERSCAPE_CONFIG_H_ #define _ASM_ARMV8_FSL_LAYERSCAPE_CONFIG_H_
+#include <linux/kconfig.h> #include <fsl_ddrc_version.h>
#define CONFIG_STANDALONE_LOAD_ADDR 0x80300000 @@ -213,7 +214,7 @@
#define GICD_BASE 0x01401000 #define GICC_BASE 0x01402000 -#elif defined(CONFIG_LS1046A) +#elif defined(CONFIG_ARCH_LS1046A) #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_NUM_FMAN 1 diff --git a/drivers/net/fm/Makefile b/drivers/net/fm/Makefile index 344fbe2..316fef4 100644 --- a/drivers/net/fm/Makefile +++ b/drivers/net/fm/Makefile @@ -39,4 +39,4 @@ obj-$(CONFIG_PPC_T4080) += t4240.o obj-$(CONFIG_PPC_B4420) += b4860.o obj-$(CONFIG_PPC_B4860) += b4860.o obj-$(CONFIG_LS1043A) += ls1043.o -obj-$(CONFIG_LS1046A) += ls1046.o +obj-$(CONFIG_ARCH_LS1046A) += ls1046.o diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 5856de8..7c5e635 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -10,7 +10,6 @@ #define CONFIG_REMAKE_ELF #define CONFIG_FSL_LAYERSCAPE #define CONFIG_FSL_LSCH2 -#define CONFIG_LS1046A #define CONFIG_MP #define CONFIG_SYS_FSL_CLK #define CONFIG_GICV2
Instead of using multiple macros, a data structure is used to pass board-specific parameters to MMDC DDR driver.
Signed-off-by: York Sun york.sun@nxp.com CC: Shengzhou Liu Shengzhou.Liu@nxp.com --- board/freescale/ls1012afrdm/ls1012afrdm.c | 18 ++++++++++++++- board/freescale/ls1012aqds/ls1012aqds.c | 18 ++++++++++++++- board/freescale/ls1012ardb/ls1012ardb.c | 18 ++++++++++++++- drivers/ddr/fsl/fsl_mmdc.c | 38 +++++++++++++++---------------- include/configs/ls1012afrdm.h | 16 ------------- include/configs/ls1012aqds.h | 16 ------------- include/configs/ls1012ardb.h | 15 ------------ include/fsl_mmdc.h | 21 +++++++++++++---- 8 files changed, 87 insertions(+), 73 deletions(-)
diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrdm/ls1012afrdm.c index d644e94..b03bdb8 100644 --- a/board/freescale/ls1012afrdm/ls1012afrdm.c +++ b/board/freescale/ls1012afrdm/ls1012afrdm.c @@ -26,7 +26,23 @@ int checkboard(void)
int dram_init(void) { - mmdc_init(); + static const struct fsl_mmdc_info mparam = { + 0x04180000, /* mdctl */ + 0x00030035, /* mdpdc */ + 0x12554000, /* mdotc */ + 0xbabf7954, /* mdcfg0 */ + 0xdb328f64, /* mdcfg1 */ + 0x01ff00db, /* mdcfg2 */ + 0x00001680, /* mdmisc */ + 0x0f3c8000, /* mdref */ + 0x00002000, /* mdrwd */ + 0x00bf1023, /* mdor */ + 0x0000003f, /* mdasp */ + 0x0000022a, /* mpodtctrl */ + 0xa1390003, /* mpzqhwctrl */ + }; + + mmdc_init(&mparam);
gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
diff --git a/board/freescale/ls1012aqds/ls1012aqds.c b/board/freescale/ls1012aqds/ls1012aqds.c index 188b6bc..94440b3 100644 --- a/board/freescale/ls1012aqds/ls1012aqds.c +++ b/board/freescale/ls1012aqds/ls1012aqds.c @@ -54,7 +54,23 @@ int checkboard(void)
int dram_init(void) { - mmdc_init(); + static const struct fsl_mmdc_info mparam = { + 0x05180000, /* mdctl */ + 0x00030035, /* mdpdc */ + 0x12554000, /* mdotc */ + 0xbabf7954, /* mdcfg0 */ + 0xdb328f64, /* mdcfg1 */ + 0x01ff00db, /* mdcfg2 */ + 0x00001680, /* mdmisc */ + 0x0f3c8000, /* mdref */ + 0x00002000, /* mdrwd */ + 0x00bf1023, /* mdor */ + 0x0000003f, /* mdasp */ + 0x0000022a, /* mpodtctrl */ + 0xa1390003, /* mpzqhwctrl */ + }; + + mmdc_init(&mparam);
diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index 50f9187..778434d 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -58,7 +58,23 @@ int checkboard(void)
diff --git a/drivers/ddr/fsl/fsl_mmdc.c b/drivers/ddr/fsl/fsl_mmdc.c index 1e35967..52eec0f 100644 --- a/drivers/ddr/fsl/fsl_mmdc.c +++ b/drivers/ddr/fsl/fsl_mmdc.c @@ -26,7 +26,7 @@ static void set_wait_for_bits_clear(void *ptr, u32 value, u32 bits) printf("Error: %p wait for clear timeout.\n", ptr); }
-void mmdc_init(void) +void mmdc_init(const struct fsl_mmdc_info *priv) { struct mmdc_regs *mmdc = (struct mmdc_regs *)CONFIG_SYS_FSL_DDR_ADDR; unsigned int tmp; @@ -35,26 +35,26 @@ void mmdc_init(void) out_be32(&mmdc->mdscr, MDSCR_ENABLE_CON_REQ);
/* 2. configure the desired timing parameters */ - out_be32(&mmdc->mdotc, CONFIG_MMDC_MDOTC); - out_be32(&mmdc->mdcfg0, CONFIG_MMDC_MDCFG0); - out_be32(&mmdc->mdcfg1, CONFIG_MMDC_MDCFG1); - out_be32(&mmdc->mdcfg2, CONFIG_MMDC_MDCFG2); + out_be32(&mmdc->mdotc, priv->mdotc); + out_be32(&mmdc->mdcfg0, priv->mdcfg0); + out_be32(&mmdc->mdcfg1, priv->mdcfg1); + out_be32(&mmdc->mdcfg2, priv->mdcfg2);
/* 3. configure DDR type and other miscellaneous parameters */ - out_be32(&mmdc->mdmisc, CONFIG_MMDC_MDMISC); + out_be32(&mmdc->mdmisc, priv->mdmisc); out_be32(&mmdc->mpmur0, MMDC_MPMUR0_FRC_MSR); - out_be32(&mmdc->mdrwd, CONFIG_MMDC_MDRWD); - out_be32(&mmdc->mpodtctrl, CONFIG_MMDC_MPODTCTRL); + out_be32(&mmdc->mdrwd, priv->mdrwd); + out_be32(&mmdc->mpodtctrl, priv->mpodtctrl);
/* 4. configure the required delay while leaving reset */ - out_be32(&mmdc->mdor, CONFIG_MMDC_MDOR); + out_be32(&mmdc->mdor, priv->mdor);
/* 5. configure DDR physical parameters */ /* set row/column address width, burst length, data bus width */ - tmp = CONFIG_MMDC_MDCTL & ~(MDCTL_SDE0 | MDCTL_SDE1); + tmp = priv->mdctl & ~(MDCTL_SDE0 | MDCTL_SDE1); out_be32(&mmdc->mdctl, tmp); /* configure address space partition */ - out_be32(&mmdc->mdasp, CONFIG_MMDC_MDASP); + out_be32(&mmdc->mdasp, priv->mdasp);
/* 6. perform a ZQ calibration - not needed here, doing in #8b */
@@ -84,7 +84,7 @@ void mmdc_init(void) out_be32(&mmdc->mdscr, CMD_ADDR_MSB_MR_OP(0x4) | MDSCR_ENABLE_CON_REQ | CMD_ZQ_CALIBRATION | CMD_BANK_ADDR_0);
- set_wait_for_bits_clear(&mmdc->mpzqhwctrl, CONFIG_MMDC_MPZQHWCTRL, + set_wait_for_bits_clear(&mmdc->mpzqhwctrl, priv->mpzqhwctrl, MPZQHWCTRL_ZQ_HW_FORCE);
/* 9a. calibrations now, wr lvl */ @@ -116,11 +116,11 @@ void mmdc_init(void) out_be32(&mmdc->mppdcmpr2, MPPDCMPR2_MPR_COMPARE_EN);
/* set absolute read delay offset */ -#if defined(CONFIG_MMDC_MPRDDLCTL) - out_be32(&mmdc->mprddlctl, CONFIG_MMDC_MPRDDLCTL); -#else - out_be32(&mmdc->mprddlctl, MMDC_MPRDDLCTL_DEFAULT_DELAY); -#endif + if (priv->mprddlctl) + out_be32(&mmdc->mprddlctl, priv->mprddlctl); + else + out_be32(&mmdc->mprddlctl, MMDC_MPRDDLCTL_DEFAULT_DELAY); + set_wait_for_bits_clear(&mmdc->mpdgctrl0, AUTO_RD_DQS_GATING_CALIBRATION_EN, AUTO_RD_DQS_GATING_CALIBRATION_EN); @@ -142,13 +142,13 @@ void mmdc_init(void) CMD_BANK_ADDR_3);
/* 10. configure power-down, self-refresh entry, exit parameters */ - out_be32(&mmdc->mdpdc, CONFIG_MMDC_MDPDC); + out_be32(&mmdc->mdpdc, priv->mdpdc); out_be32(&mmdc->mapsr, MMDC_MAPSR_PWR_SAV_CTRL_STAT);
/* 11. ZQ config again? do nothing here */
/* 12. refresh scheme */ - set_wait_for_bits_clear(&mmdc->mdref, CONFIG_MMDC_MDREF, + set_wait_for_bits_clear(&mmdc->mdref, priv->mdref, MDREF_START_REFRESH);
/* 13. disable CON_REQ */ diff --git a/include/configs/ls1012afrdm.h b/include/configs/ls1012afrdm.h index 136d648..612f243 100644 --- a/include/configs/ls1012afrdm.h +++ b/include/configs/ls1012afrdm.h @@ -20,22 +20,6 @@ #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
-/* DDR board-specific timing parameters */ -#define CONFIG_MMDC_MDCTL 0x04180000 -#define CONFIG_MMDC_MDPDC 0x00030035 -#define CONFIG_MMDC_MDOTC 0x12554000 -#define CONFIG_MMDC_MDCFG0 0xbabf7954 -#define CONFIG_MMDC_MDCFG1 0xdb328f64 -#define CONFIG_MMDC_MDCFG2 0x01ff00db -#define CONFIG_MMDC_MDMISC 0x00001680 -#define CONFIG_MMDC_MDREF 0x0f3c8000 -#define CONFIG_MMDC_MDRWD 0x00002000 -#define CONFIG_MMDC_MDOR 0x00bf1023 -#define CONFIG_MMDC_MDASP 0x0000003f -#define CONFIG_MMDC_MPODTCTRL 0x0000022a -#define CONFIG_MMDC_MPZQHWCTRL 0xa1390003 - - /* * USB */ diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index b6d12dd..54abf30 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -19,22 +19,6 @@ #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
-/* DDR board-specific timing parameters */ -#define CONFIG_MMDC_MDCTL 0x05180000 -#define CONFIG_MMDC_MDPDC 0x00030035 -#define CONFIG_MMDC_MDOTC 0x12554000 -#define CONFIG_MMDC_MDCFG0 0xbabf7954 -#define CONFIG_MMDC_MDCFG1 0xdb328f64 -#define CONFIG_MMDC_MDCFG2 0x01ff00db -#define CONFIG_MMDC_MDMISC 0x00001680 -#define CONFIG_MMDC_MDREF 0x0f3c8000 -#define CONFIG_MMDC_MDRWD 0x00002000 -#define CONFIG_MMDC_MDOR 0x00bf1023 -#define CONFIG_MMDC_MDASP 0x0000003f -#define CONFIG_MMDC_MPODTCTRL 0x0000022a -#define CONFIG_MMDC_MPZQHWCTRL 0xa1390003 - - /* * QIXIS Definitions */ diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index 2076ce5..0c13dde 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -19,21 +19,6 @@ #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
-/* DDR board-specific timing parameters */ -#define CONFIG_MMDC_MDCTL 0x05180000 -#define CONFIG_MMDC_MDPDC 0x00030035 -#define CONFIG_MMDC_MDOTC 0x12554000 -#define CONFIG_MMDC_MDCFG0 0xbabf7954 -#define CONFIG_MMDC_MDCFG1 0xdb328f64 -#define CONFIG_MMDC_MDCFG2 0x01ff00db -#define CONFIG_MMDC_MDMISC 0x00001680 -#define CONFIG_MMDC_MDREF 0x0f3c8000 -#define CONFIG_MMDC_MDRWD 0x00002000 -#define CONFIG_MMDC_MDOR 0x00bf1023 -#define CONFIG_MMDC_MDASP 0x0000003f -#define CONFIG_MMDC_MPODTCTRL 0x0000022a -#define CONFIG_MMDC_MPZQHWCTRL 0xa1390003 - /* * USB */ diff --git a/include/fsl_mmdc.h b/include/fsl_mmdc.h index 1d09ff4..d5c4f8d 100644 --- a/include/fsl_mmdc.h +++ b/include/fsl_mmdc.h @@ -150,10 +150,23 @@ struct mmdc_regs { u32 mpdccr; };
-void mmdc_init(void); +struct fsl_mmdc_info { + u32 mdctl; + u32 mdpdc; + u32 mdotc; + u32 mdcfg0; + u32 mdcfg1; + u32 mdcfg2; + u32 mdmisc; + u32 mdref; + u32 mdrwd; + u32 mdor; + u32 mdasp; + u32 mpodtctrl; + u32 mpzqhwctrl; + u32 mprddlctl; +};
-#if !defined(CONFIG_MMDC_MDCTL) -#error Must configure board-specific timing CONFIG_MMDC_* in <board>.h for MMDC -#endif +void mmdc_init(const struct fsl_mmdc_info *);
#endif /* FSL_MMDC_H */
Thanks for doing this!
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of York Sun Sent: Thursday, September 22, 2016 4:21 AM To: trini@konsulko.com Cc: u-boot@lists.denx.de Subject: [U-Boot] [RFC Patch 2/5] driver: ddr: fsl_mmdc: Pass board parameters through data structure
I doubt if it is one of the reason for root-cause. May not be part of this patch set
- mmdc_init();
- static const struct fsl_mmdc_info mparam = {
- mmdc_init(&mparam);
Why cannot #define directly be used in fsl_mmdc.c.
If objective is to remove #define from board file, they even be required to avoid magic numbers.
-prabhakar
- mmdc_init();
Please see the previous thread about this between York and I. The end goal is not to have no magic numbers, the end goal is to make it clear what the magic numbers are doing. I still wish there was also a link to a tech note / manual / whatever to decode each of these values and a comment about what DDR part is being used on the board, but this is a step in the right direction.
And as a side bonus, this moves things one step closer to being able to have more than one board supported by a given binary.
Move this config to Kconfig option and clean up existing uses.
Signed-off-by: York Sun york.sun@nxp.com CC: Calvin Johnson calvin.johnson@nxp.com CC: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- arch/arm/Kconfig | 3 +++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 7 +++++++ arch/arm/cpu/armv8/fsl-layerscape/Makefile | 2 +- arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 4 ++-- arch/arm/include/asm/arch-fsl-layerscape/config.h | 6 ++---- arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 2 +- include/configs/ls1012a_common.h | 1 - include/linux/usb/xhci-fsl.h | 2 +- 8 files changed, 17 insertions(+), 10 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index aed89c9..c974db4 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -788,6 +788,7 @@ config TARGET_HIKEY
config TARGET_LS1012AQDS bool "Support ls1012aqds" + select ARCH_LS1012A select ARM64 help Support for Freescale LS1012AQDS platform. @@ -797,6 +798,7 @@ config TARGET_LS1012AQDS
config TARGET_LS1012ARDB bool "Support ls1012ardb" + select ARCH_LS1012A select ARM64 help Support for Freescale LS1012ARDB platform. @@ -806,6 +808,7 @@ config TARGET_LS1012ARDB
config TARGET_LS1012AFRDM bool "Support ls1012afrdm" + select ARCH_LS1012A select ARM64 help Support for Freescale LS1012AFRDM platform. diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index c234eff..a823d39 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -1,2 +1,9 @@ +config ARCH_LS1012A + bool "Freescale Layerscape LS1012A SoC" + select SYS_FSL_MMDC + config ARCH_LS1046A bool "Freescale Layerscape LS1046A SoC" + +config SYS_FSL_MMDC + bool "Freescale Multi Mode DDR Controller" diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index f9590af..51c1cee 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -30,7 +30,7 @@ ifneq ($(CONFIG_LS1043A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1043a_serdes.o endif
-ifneq ($(CONFIG_LS1012A),) +ifneq ($(CONFIG_ARCH_LS1012A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1012a_serdes.o endif
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 8922197..55005f0 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -60,7 +60,7 @@ void get_sys_info(struct sys_info *sys_info) sys_info->freq_ddrbus = sysclk; #endif
-#ifdef CONFIG_LS1012A +#ifdef CONFIG_ARCH_LS1012A sys_info->freq_ddrbus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_SHIFT) & FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_MASK; @@ -91,7 +91,7 @@ void get_sys_info(struct sys_info *sys_info) freq_c_pll[cplx_pll] / core_cplx_pll_div[c_pll_sel]; }
-#ifdef CONFIG_LS1012A +#ifdef CONFIG_ARCH_LS1012A sys_info->freq_systembus = sys_info->freq_ddrbus / 2; sys_info->freq_ddrbus *= 2; #endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index e7c7d98..a7fda18 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -18,9 +18,7 @@ #define CONFIG_SYS_FSL_DDRC_ARM_GEN3 /* Enable Freescale ARM DDR3 driver */ #endif
-#ifdef CONFIG_LS1012A -#define CONFIG_SYS_FSL_MMDC /* Freescale MMDC driver */ -#else +#ifndef CONFIG_ARCH_LS1012A #define CONFIG_SYS_FSL_DDR /* Freescale DDR driver */ #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0 #endif @@ -208,7 +206,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A009942 #define CONFIG_SYS_FSL_ERRATUM_A009660 #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 -#elif defined(CONFIG_LS1012A) +#elif defined(CONFIG_ARCH_LS1012A) #define CONFIG_MAX_CPUS 1 #undef CONFIG_SYS_FSL_DDRC_ARM_GEN3
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 95a4293..df51871 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -60,7 +60,7 @@ #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x4800000000ULL #define CONFIG_SYS_PCIE3_PHYS_ADDR 0x5000000000ULL /* LUT registers */ -#ifdef CONFIG_LS1012A +#ifdef CONFIG_ARCH_LS1012A #define PCIE_LUT_BASE 0xC0000 #else #define PCIE_LUT_BASE 0x10000 diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index fba2fac..5fb6c47 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -9,7 +9,6 @@
#define CONFIG_FSL_LAYERSCAPE #define CONFIG_FSL_LSCH2 -#define CONFIG_LS1012A #define CONFIG_GICV2
#define CONFIG_SYS_HAS_SERDES diff --git a/include/linux/usb/xhci-fsl.h b/include/linux/usb/xhci-fsl.h index 199f366..d04e3cc 100644 --- a/include/linux/usb/xhci-fsl.h +++ b/include/linux/usb/xhci-fsl.h @@ -51,7 +51,7 @@ struct fsl_xhci { struct dwc3 *dwc3_reg; };
-#if defined(CONFIG_LS102XA) || defined(CONFIG_LS1012A) +#if defined(CONFIG_LS102XA) || defined(CONFIG_ARCH_LS1012A) #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 #define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0
Signed-off-by: York Sun york.sun@nxp.com CC: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 12 ++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 - 2 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index a823d39..a329240 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -1,9 +1,21 @@ config ARCH_LS1012A bool "Freescale Layerscape LS1012A SoC" select SYS_FSL_MMDC + select SYS_FSL_ERRATUM_A010315 + +config ARCH_LS1021A + bool "Freescale Layerscape LS1021A SoC" + select SYS_FSL_ERRATUM_A010315 + +config ARCH_LS1043A + bool "Freescale Layerscape LS1043A SoC" + select SYS_FSL_ERRATUM_A010315
config SYS_FSL_MMDC bool "Freescale Multi Mode DDR Controller" + +config SYS_FSL_ERRATUM_A010315 + bool "Workaround for PCIe erratum A010315" diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index a7fda18..a5c6c4c 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -169,7 +169,6 @@
#define CONFIG_SYS_FSL_SRDS_1
-#define CONFIG_SYS_FSL_ERRATUM_A010315 /* SoC related */ #ifdef CONFIG_LS1043A #define CONFIG_MAX_CPUS 4
It should be EMMC_BOOT instead of CONFIG_EMMC_BOOT.
Signed-off-by: York Sun york.sun@nxp.com CC: Gong Qianyu Qianyu.Gong@nxp.com --- configs/ls1046ardb_emmc_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 2daddf4..a1ee1ab 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -6,7 +6,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SYS_FSL_DDR4,CONFIG_EMMC_BOOT" +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SYS_FSL_DDR4,EMMC_BOOT" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=10 CONFIG_HUSH_PARSER=y
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of York Sun Sent: Thursday, September 22, 2016 4:21 AM To: trini@konsulko.com Cc: u-boot@lists.denx.de Subject: [U-Boot] [RFC Patch 0/5] Resolve conflict for merging
Tom,
Are we expecting similar fixes for LS1043, LS2085, LS1021? Or platform maintainers will be fixing taking this patch set as reference.
--prabhakar
Tom,
I will do some converting and see how it goes.
York
Prabhakar Kushwaha
York Sun
york sun
