[U-Boot] [PATCH v4 00/29] Kconfig: Move console options to Kconfig
This series moves a number of console-related CONFIG options to Kconfig. Those that are not currently used are removed.
A few unused video drivers are also removed and there are a few minor adjustments to improve the code. But mostly this follows the output of the moveconfig tool.
It is build-tested to check that everything still works. The series is available at u-boot-dm/video-working
$ buildman -b video --step 0 -su boards.cfg is up to date. Nothing to do. Summary of 2 commits for 1213 boards (32 threads, 1 job per thread) 01: Merge git://www.denx.de/git/u-boot-ppc4xx blackfin: + cm-bf527 bf609-ezkit bf537-stamp sparc: + grsim grsim_leon2 gr_cpci_ax2000 gr_xc3s_1500 gr_ep2s60 sandbox: + sandbox_spl arc: ? nsim_700be nsim_hs38be tb100 axs101 axs103 nsim_700 nsim_hs38 nios2: + 10m50 3c120 microblaze: + microblaze-generic openrisc: + openrisc-generic 31: Convert CONFIG_SYS_STDIO_DEREGISTER to Kconfig arc: ? nsim_700be nsim_hs38be tb100 axs101 axs103 nsim_700 nsim_hs38
Changes in v4: - Rebase to master
Changes in v3: - Make SYS_CONSOLE_IS_IN_ENV default to y if CONSOLE_MUX is enabled - Change CONFIG_CFB_CONSOLE to default y if CONFIG_VIDEO
Changes in v2: - Drop the changes to Kconfig defaults - Change CONFIG_PRE_CON_BUF_SZ default to 4096 - Change CONFIG_PRE_CON_BUF_SZ to 'int' type - Drop the depend clause on the CONFIG_PRE_CON_BUF_SZ default - Move CONFIG_PRE_CON_BUF_ADDR default to common/Kconfig - Make CONFIG_SYS_CONSOLE_INFO_QUIET the default if !CONFIG_MUX - Add new patch to convert CONFIG_USB_KEYBOARD to Kconfig - Make CONFIG_SYS_STDIO_DEREGISTER the default if USB_KEYBOARD - Drop Kconfig changes
Simon Glass (29): Remove some merge markers Convert SILENT_CONSOLE options to Kconfig Convert CONSOLE_PRE_CONSOLE_BUFFER options to Kconfig Convert CONFIG_SYS_CONSOLE_IS_IN_ENV et al to Kconfig config: Drop CONFIG_CONSOLE config: Drop CONFIG_CONSOLE_DEV Convert CONFIG_VIDEO to Kconfig Convert CONFIG_CFB_CONSOLE to Kconfig Convert CONFIG_CFB_CONSOLE_ANSI to Kconfig Convert CONFIG_VIDEO_CT69000 to Kconfig Convert CONFIG_SYS_CONSOLE_BG_COL et al to Kconfig video: Drop the smiLynxEM driver video: Drop the imx25lcdc driver video: Drop the s3c-fb driver video: Drop the sed13806 driver Convert CONFIG_VGA_AS_SINGLE_DEVICE to Kconfig video: Drop CONFIG_VIDEO_HW_CURSOR Convert CONFIG_VIDEO_SW_CURSOR to Kconfig video: Drop CONFIG_VIDEO_SW_CURSOR Convert CONFIG_CONSOLE_EXTRA_INFO to Kconfig video: Move video_get_info_str() prototype to a header file video: Drop CONFIG_CONSOLE_INFO_QUIET Convert CONFIG_LCD to Kconfig Convert CONFIG_CONSOLE_SCROLL_LINES to Kconfig Convert CONFIG_SYS_CONSOLE_ENV_OVERWRITE to Kconfig Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to Kconfig Convert CONFIG_SYS_CONSOLE_INFO_QUIET to Kconfig Convert CONFIG_USB_KEYBOARD to Kconfig Convert CONFIG_SYS_STDIO_DEREGISTER to Kconfig
README | 131 ---- board/liebherr/lwmon5/lwmon5.c | 1 + board/mosaixtech/icon/icon.c | 1 + board/mpl/common/common_util.c | 1 + board/sunxi/Kconfig | 3 + board/tqc/tqm5200/tqm5200.c | 1 + common/Kconfig | 144 ++++ common/console.c | 6 +- common/stdio.c | 6 +- common/usb_kbd.c | 2 +- configs/B4420QDS_NAND_defconfig | 1 + configs/B4420QDS_SPIFLASH_defconfig | 1 + configs/B4420QDS_defconfig | 1 + configs/B4860QDS_NAND_defconfig | 1 + configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 1 + configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/B4860QDS_defconfig | 1 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 1 + .../BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 1 + .../BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 1 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/Chuwi_V7_CW0825_defconfig | 1 + configs/Cubietruck_plus_defconfig | 1 + configs/Cyrus_P5020_defconfig | 2 + configs/Cyrus_P5040_defconfig | 2 + configs/MIP405T_defconfig | 6 + configs/MIP405_defconfig | 7 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8544DS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 2 + configs/MPC8641HPCN_36BIT_defconfig | 2 + configs/MPC8641HPCN_defconfig | 2 + configs/MSI_Primo81_defconfig | 1 + configs/Merrii_A80_Optimus_defconfig | 1 + configs/MiniFAP_defconfig | 3 + configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/PATI_defconfig | 1 + configs/PIP405_defconfig | 7 + configs/PMC440_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 1 + configs/T1023RDB_NAND_defconfig | 1 + configs/T1023RDB_SDCARD_defconfig | 1 + configs/T1023RDB_SECURE_BOOT_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 1 + configs/T1023RDB_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 3 + configs/T1024QDS_DDR4_defconfig | 3 + configs/T1024QDS_NAND_defconfig | 3 + configs/T1024QDS_SDCARD_defconfig | 3 + configs/T1024QDS_SECURE_BOOT_defconfig | 3 + configs/T1024QDS_SPIFLASH_defconfig | 3 + configs/T1024QDS_defconfig | 3 + configs/T1024RDB_NAND_defconfig | 2 + configs/T1024RDB_SDCARD_defconfig | 2 + configs/T1024RDB_SECURE_BOOT_defconfig | 2 + configs/T1024RDB_SPIFLASH_defconfig | 2 + configs/T1024RDB_defconfig | 2 + configs/T1040D4RDB_NAND_defconfig | 2 + configs/T1040D4RDB_SDCARD_defconfig | 2 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 2 + configs/T1040D4RDB_SPIFLASH_defconfig | 2 + configs/T1040D4RDB_defconfig | 2 + configs/T1040QDS_DDR4_defconfig | 3 + configs/T1040QDS_SECURE_BOOT_defconfig | 3 + configs/T1040QDS_defconfig | 3 + configs/T1040RDB_NAND_defconfig | 2 + configs/T1040RDB_SDCARD_defconfig | 2 + configs/T1040RDB_SECURE_BOOT_defconfig | 2 + configs/T1040RDB_SPIFLASH_defconfig | 2 + configs/T1040RDB_defconfig | 2 + configs/T1042D4RDB_NAND_defconfig | 4 + configs/T1042D4RDB_SDCARD_defconfig | 4 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 4 + configs/T1042D4RDB_SPIFLASH_defconfig | 4 + configs/T1042D4RDB_defconfig | 4 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 4 + configs/T1042RDB_PI_NAND_defconfig | 4 + configs/T1042RDB_PI_SDCARD_defconfig | 4 + configs/T1042RDB_PI_SPIFLASH_defconfig | 4 + configs/T1042RDB_PI_defconfig | 4 + configs/T1042RDB_SECURE_BOOT_defconfig | 2 + configs/T1042RDB_defconfig | 2 + configs/TQM5200_B_HIGHBOOT_defconfig | 3 + configs/TQM5200_B_defconfig | 3 + configs/TQM5200_STK100_defconfig | 3 + configs/TQM5200_defconfig | 3 + configs/TQM823L_LCD_defconfig | 3 +- configs/TTTech_defconfig | 3 +- configs/VCMA9_defconfig | 1 + configs/a3m071_defconfig | 1 + configs/a4m072_defconfig | 1 + configs/a4m2k_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/aristainetos2_defconfig | 3 + configs/aristainetos2b_defconfig | 3 + configs/aristainetos_defconfig | 3 + configs/arndale_defconfig | 2 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 2 + configs/at91sam9261ek_dataflash_cs3_defconfig | 2 + configs/at91sam9261ek_nandflash_defconfig | 2 + configs/at91sam9263ek_dataflash_cs0_defconfig | 2 + configs/at91sam9263ek_dataflash_defconfig | 2 + configs/at91sam9263ek_nandflash_defconfig | 2 + configs/at91sam9263ek_norflash_boot_defconfig | 2 + configs/at91sam9263ek_norflash_defconfig | 2 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 2 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 2 + configs/at91sam9g10ek_nandflash_defconfig | 2 + configs/at91sam9m10g45ek_mmc_defconfig | 2 + configs/at91sam9m10g45ek_nandflash_defconfig | 2 + configs/at91sam9n12ek_mmc_defconfig | 2 + configs/at91sam9n12ek_nandflash_defconfig | 2 + configs/at91sam9n12ek_spiflash_defconfig | 2 + configs/at91sam9rlek_dataflash_defconfig | 2 + configs/at91sam9rlek_mmc_defconfig | 2 + configs/at91sam9rlek_nandflash_defconfig | 2 + configs/at91sam9x5ek_dataflash_defconfig | 2 + configs/at91sam9x5ek_mmc_defconfig | 2 + configs/at91sam9x5ek_nandflash_defconfig | 2 + configs/at91sam9x5ek_spiflash_defconfig | 2 + configs/bayleybay_defconfig | 6 + configs/bct-brettl2_defconfig | 1 + configs/beaver_defconfig | 1 + configs/bf518f-ezbrd_defconfig | 1 + configs/bf526-ezbrd_defconfig | 1 + configs/bf527-ad7160-eval_defconfig | 1 + configs/bf527-ezkit-v2_defconfig | 1 + configs/bf527-ezkit_defconfig | 1 + configs/bf527-sdp_defconfig | 1 + configs/bf533-ezkit_defconfig | 1 + configs/bf533-stamp_defconfig | 1 + configs/bf537-pnav_defconfig | 1 + configs/bf537-stamp_defconfig | 1 + configs/bf538f-ezkit_defconfig | 1 + configs/bf548-ezkit_defconfig | 1 + configs/bf561-acvilon_defconfig | 1 + configs/bf561-ezkit_defconfig | 1 + configs/br4_defconfig | 1 + configs/brppt1_mmc_defconfig | 4 + configs/brppt1_nand_defconfig | 4 + configs/brppt1_spi_defconfig | 4 + configs/brxre1_defconfig | 4 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/cgtqmx6eval_defconfig | 4 + configs/charon_defconfig | 3 + configs/chromebook_jerry_defconfig | 2 + configs/chromebook_link_defconfig | 6 + configs/chromebook_samus_defconfig | 3 + configs/chromebox_panther_defconfig | 6 + configs/cm-bf527_defconfig | 1 + configs/cm-bf533_defconfig | 1 + configs/cm-bf537e_defconfig | 1 + configs/cm-bf537u_defconfig | 1 + configs/cm-bf548_defconfig | 2 + configs/cm-bf561_defconfig | 1 + configs/cm5200_defconfig | 1 + configs/cm_fx6_defconfig | 2 + configs/cm_t3517_defconfig | 2 + configs/cm_t35_defconfig | 2 + configs/colibri_imx7_defconfig | 2 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + ...conga-qeval20-qa3-e3845-internal-uart_defconfig | 6 + configs/conga-qeval20-qa3-e3845_defconfig | 6 + .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 2 + configs/controlcenterd_36BIT_SDCARD_defconfig | 2 + .../controlcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/coreboot-x86_defconfig | 5 + configs/cougarcanyon2_defconfig | 3 + configs/crownbay_defconfig | 6 + configs/d2net_v2_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 6 + configs/digsy_mtc_RAMBOOT_defconfig | 2 + configs/digsy_mtc_defconfig | 2 + configs/digsy_mtc_rev5_RAMBOOT_defconfig | 2 + configs/digsy_mtc_rev5_defconfig | 2 + configs/dms-ba16-1g_defconfig | 4 + configs/dms-ba16_defconfig | 4 + configs/dns325_defconfig | 1 + configs/duovero_defconfig | 1 + configs/e2220-1170_defconfig | 1 + configs/ea20_defconfig | 4 + configs/eb_cpu5282_defconfig | 2 + configs/eb_cpu5282_internal_defconfig | 2 + configs/efi-x86_defconfig | 3 + configs/espresso7420_defconfig | 2 + configs/evb-rk3288_defconfig | 2 + configs/fennec-rk3288_defconfig | 2 + configs/firefly-rk3288_defconfig | 2 + configs/fo300_defconfig | 3 + configs/galileo_defconfig | 3 + configs/ge_b450v3_defconfig | 2 + configs/ge_b650v3_defconfig | 2 + configs/ge_b850v3_defconfig | 2 + configs/goflexhome_defconfig | 1 + configs/gwventana_defconfig | 3 + configs/h2200_defconfig | 1 + configs/h8_homlet_v2_defconfig | 1 + configs/haleakala_defconfig | 1 + configs/harmony_defconfig | 1 + configs/ibf-dsp561_defconfig | 1 + configs/icon_defconfig | 3 + configs/igep0020_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0030_nand_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/imx31_phycore_eet_defconfig | 2 + configs/inetspace_v2_defconfig | 1 + configs/io64_defconfig | 1 + configs/ip04_defconfig | 1 + configs/ipek01_defconfig | 3 + configs/jetson-tk1_defconfig | 1 + configs/kc1_defconfig | 1 + configs/kilauea_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 3 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 3 + configs/ls1021aqds_nand_defconfig | 3 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 3 + configs/ls1021aqds_nor_defconfig | 3 + configs/ls1021aqds_nor_lpuart_defconfig | 3 + configs/ls1021aqds_qspi_defconfig | 3 + configs/ls1021aqds_sdcard_ifc_defconfig | 3 + configs/ls1021aqds_sdcard_qspi_defconfig | 3 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 3 + configs/ls1021atwr_nor_defconfig | 3 + configs/ls1021atwr_nor_lpuart_defconfig | 3 + configs/ls1021atwr_qspi_defconfig | 3 + .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 3 + configs/ls1021atwr_sdcard_ifc_defconfig | 3 + configs/ls1021atwr_sdcard_qspi_defconfig | 3 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/lwmon5_defconfig | 4 + configs/m28evk_defconfig | 2 + configs/m53evk_defconfig | 2 + configs/makalu_defconfig | 1 + configs/marsboard_defconfig | 3 + configs/mcx_defconfig | 2 + configs/microblaze-generic_defconfig | 1 + configs/miniarm-rk3288_defconfig | 2 + configs/minnowmax_defconfig | 6 + configs/mt_ventoux_defconfig | 2 + configs/mx23evk_defconfig | 2 + configs/mx28evk_auart_console_defconfig | 2 + configs/mx28evk_defconfig | 2 + configs/mx28evk_nand_defconfig | 2 + configs/mx28evk_spi_defconfig | 2 + configs/mx51evk_defconfig | 3 + configs/mx53loco_defconfig | 3 + configs/mx6cuboxi_defconfig | 3 + configs/mx6dlsabreauto_defconfig | 3 + configs/mx6dlsabresd_defconfig | 3 + configs/mx6qpsabreauto_defconfig | 3 + configs/mx6qsabreauto_defconfig | 3 + configs/mx6qsabrelite_defconfig | 4 + configs/mx6qsabresd_defconfig | 3 + configs/mx6sabresd_spl_defconfig | 3 + configs/mx6sxsabresd_defconfig | 2 + configs/mx6sxsabresd_spl_defconfig | 2 + configs/mx6ul_14x14_evk_defconfig | 8 +- configs/mx6ul_9x9_evk_defconfig | 8 +- configs/mx7dsabresd_defconfig | 2 + configs/mx7dsabresd_secure_defconfig | 2 + configs/nanopi_neo_defconfig | 1 + configs/net2big_v2_defconfig | 1 + configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 4 + configs/nitrogen6dl_defconfig | 4 + configs/nitrogen6q2g_defconfig | 4 + configs/nitrogen6q_defconfig | 4 + configs/nitrogen6s1g_defconfig | 4 + configs/nitrogen6s_defconfig | 4 + configs/nokia_rx51_defconfig | 3 + configs/novena_defconfig | 3 + configs/odroid-xu3_defconfig | 2 + configs/odroid_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/orangepi_2_defconfig | 1 + configs/orangepi_lite_defconfig | 1 + configs/orangepi_one_defconfig | 1 + configs/orangepi_pc_defconfig | 1 + configs/orangepi_pc_plus_defconfig | 1 + configs/orangepi_plus2e_defconfig | 1 + configs/orangepi_plus_defconfig | 1 + configs/origen_defconfig | 1 + configs/p2371-0000_defconfig | 1 + configs/p2371-2180_defconfig | 1 + configs/p2571_defconfig | 1 + configs/p2771-0000-000_defconfig | 1 + configs/p2771-0000-500_defconfig | 1 + configs/paz00_defconfig | 1 + configs/pdm360ng_defconfig | 2 + configs/peach-pi_defconfig | 2 + configs/peach-pit_defconfig | 2 + configs/picosam9g45_defconfig | 2 + configs/pine64_plus_defconfig | 1 + configs/plutux_defconfig | 1 + configs/pm9261_defconfig | 2 + configs/pm9263_defconfig | 2 + configs/popmetal-rk3288_defconfig | 2 + configs/pr1_defconfig | 1 + configs/pxm2_defconfig | 4 + configs/qemu-x86_defconfig | 6 + configs/qemu-x86_efi_payload32_defconfig | 6 + configs/qemu-x86_efi_payload64_defconfig | 6 + configs/rainier_defconfig | 1 + configs/rainier_ramboot_defconfig | 1 + configs/riotboard_defconfig | 3 + configs/rock2_defconfig | 2 + configs/rpi_2_defconfig | 3 + configs/rpi_3_32b_defconfig | 3 + configs/rpi_3_defconfig | 3 + configs/rpi_defconfig | 3 + configs/rut_defconfig | 4 + configs/s5p_goni_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 2 + configs/sama5d3xek_nandflash_defconfig | 2 + configs/sama5d3xek_spiflash_defconfig | 2 + configs/sama5d4ek_mmc_defconfig | 2 + configs/sama5d4ek_nandflash_defconfig | 2 + configs/sama5d4ek_spiflash_defconfig | 2 + configs/sandbox_defconfig | 1 + configs/sandbox_noblk_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 2 + configs/seaboard_defconfig | 2 + configs/sequoia_defconfig | 1 + configs/sequoia_ramboot_defconfig | 1 + configs/smdk2410_defconfig | 1 + configs/smdk5250_defconfig | 2 + configs/smdk5420_defconfig | 2 + configs/sniper_defconfig | 1 + configs/snow_defconfig | 2 + configs/socfpga_arria5_defconfig | 3 + configs/socfpga_cyclone5_defconfig | 3 + configs/socfpga_de0_nano_soc_defconfig | 3 + configs/socfpga_is1_defconfig | 3 + configs/socfpga_mcvevk_defconfig | 3 + configs/socfpga_sockit_defconfig | 3 + configs/socfpga_socrates_defconfig | 3 + configs/socfpga_sr1500_defconfig | 3 + configs/socfpga_vining_fpga_defconfig | 3 + configs/socrates_defconfig | 3 + configs/som-db5800-som-6867_defconfig | 6 + configs/spring_defconfig | 2 + configs/tbs2910_defconfig | 6 + configs/tcm-bf518_defconfig | 1 + configs/tcm-bf537_defconfig | 1 + configs/tec-ng_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 6 + configs/theadorable_debug_defconfig | 3 + configs/theadorable_defconfig | 3 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/venice2_defconfig | 1 + configs/ventana_defconfig | 2 + configs/wandboard_defconfig | 3 + configs/whistler_defconfig | 1 + configs/wtk_defconfig | 3 +- configs/xfi3_defconfig | 2 + configs/zipitz2_defconfig | 1 + drivers/net/ax88180.c | 6 +- drivers/serial/serial-uclass.c | 2 +- drivers/usb/host/isp116x-hcd.c | 6 +- drivers/video/Kconfig | 146 ++++ drivers/video/Makefile | 4 - drivers/video/cfb_console.c | 236 ++---- drivers/video/ct69000.c | 78 -- drivers/video/imx25lcdc.c | 121 --- drivers/video/s3c-fb.c | 172 ----- drivers/video/sed13806.c | 286 ------- drivers/video/smiLynxEM.c | 835 --------------------- include/asm-generic/global_data.h | 2 +- include/configs/10m50_devboard.h | 1 - include/configs/3c120_devboard.h | 1 - include/configs/B4860QDS.h | 3 - include/configs/BSC9131RDB.h | 2 - include/configs/BSC9132QDS.h | 2 - include/configs/C29XPCIE.h | 2 - include/configs/CPCI2DP.h | 2 - include/configs/CPCI4052.h | 2 +- include/configs/M52277EVB.h | 1 - include/configs/M5249EVB.h | 1 - include/configs/MIP405.h | 12 - include/configs/MPC8349ITX.h | 6 +- include/configs/MPC8536DS.h | 4 - include/configs/MPC8544DS.h | 4 - include/configs/MPC8572DS.h | 4 - include/configs/MPC8610HPCD.h | 6 - include/configs/MPC8641HPCN.h | 6 - include/configs/MigoR.h | 4 - include/configs/P1010RDB.h | 2 - include/configs/P1022DS.h | 8 - include/configs/PATI.h | 1 - include/configs/PIP405.h | 12 - include/configs/PLU405.h | 2 - include/configs/PMC405DE.h | 1 - include/configs/PMC440.h | 2 - include/configs/T102xQDS.h | 6 - include/configs/T102xRDB.h | 6 - include/configs/T1040QDS.h | 6 - include/configs/T104xRDB.h | 9 - include/configs/TQM5200.h | 7 - include/configs/UCP1020.h | 4 - include/configs/VCMA9.h | 2 - include/configs/VOM405.h | 2 - include/configs/a3m071.h | 3 - include/configs/a4m072.h | 1 - include/configs/ac14xx.h | 5 - include/configs/advantech_dms-ba16.h | 10 +- include/configs/am3517_crane.h | 1 - include/configs/amcc-common.h | 1 - include/configs/amcore.h | 1 - include/configs/ap325rxa.h | 3 - include/configs/ap_sh4a_4a.h | 3 - include/configs/aria.h | 6 - include/configs/aristainetos-common.h | 7 +- include/configs/aristainetos.h | 2 +- include/configs/aristainetos2.h | 2 +- include/configs/aristainetos2b.h | 2 +- include/configs/armadillo-800eva.h | 3 - include/configs/at91rm9200ek.h | 1 - include/configs/at91sam9261ek.h | 3 - include/configs/at91sam9263ek.h | 2 - include/configs/at91sam9m10g45ek.h | 2 - include/configs/at91sam9n12ek.h | 2 - include/configs/at91sam9rlek.h | 2 - include/configs/at91sam9x5ek.h | 2 - include/configs/bf527-ezkit.h | 3 - include/configs/bf533-stamp.h | 1 - include/configs/bf548-ezkit.h | 1 - include/configs/bfin_adi_common.h | 1 - include/configs/brppt1.h | 1 - include/configs/brxre1.h | 1 - include/configs/bur_cfg_common.h | 3 - include/configs/cgtqmx6eval.h | 10 +- include/configs/chromebook_jerry.h | 1 - include/configs/chromebook_samus.h | 2 - include/configs/clearfog.h | 1 - include/configs/cm-bf548.h | 1 - include/configs/cm5200.h | 1 - include/configs/cm_fx6.h | 7 - include/configs/cm_t35.h | 2 - include/configs/cm_t3517.h | 2 - include/configs/colibri_imx7.h | 5 - include/configs/colibri_pxa270.h | 1 - include/configs/colibri_t20.h | 1 - include/configs/controlcenterd.h | 5 - include/configs/cyrus.h | 4 - include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/digsy_mtc.h | 5 - include/configs/dns325.h | 2 - include/configs/ea20.h | 6 - include/configs/eb_cpu5282.h | 2 - include/configs/ecovec.h | 3 - include/configs/edminiv2.h | 1 - include/configs/el6x_common.h | 2 +- include/configs/embestmx6boards.h | 7 +- include/configs/evb_rk3288.h | 1 - include/configs/evb_rk3399.h | 1 - include/configs/exynos5-common.h | 3 - include/configs/exynos5-dt-common.h | 1 - include/configs/exynos7420-common.h | 3 - include/configs/fennec_rk3288.h | 1 - include/configs/firefly-rk3288.h | 1 - include/configs/ge_bx50v3.h | 10 +- include/configs/goflexhome.h | 2 - include/configs/gr_ep2s60.h | 1 - include/configs/gw_ventana.h | 6 - include/configs/h2200.h | 1 - include/configs/harmony.h | 1 - include/configs/hrcon.h | 2 - include/configs/icon.h | 5 - include/configs/imx31_phycore.h | 5 - include/configs/io64.h | 2 - include/configs/ipek01.h | 6 - include/configs/kc1.h | 6 - include/configs/kilauea.h | 2 - include/configs/km/km_arm.h | 1 - include/configs/kzm9g.h | 3 - include/configs/lacie_kw.h | 2 - include/configs/ls1021aqds.h | 7 - include/configs/ls1021atwr.h | 7 - include/configs/lsxl.h | 2 - include/configs/lwmon5.h | 8 - include/configs/m28evk.h | 1 - include/configs/m53evk.h | 4 - include/configs/ma5d4evk.h | 2 - include/configs/makalu.h | 2 - include/configs/maxbcm.h | 1 - include/configs/mcx.h | 4 - include/configs/microblaze-generic.h | 2 - include/configs/miniarm_rk3288.h | 1 - include/configs/mpc5121ads.h | 4 - include/configs/ms7722se.h | 3 - include/configs/mt_ventoux.h | 4 - include/configs/mv-common.h | 1 - include/configs/mvebu_db-88f3720.h | 2 - include/configs/mvebu_db-88f7040.h | 2 - include/configs/mx23evk.h | 2 - include/configs/mx28evk.h | 1 - include/configs/mx51evk.h | 5 - include/configs/mx53loco.h | 5 - include/configs/mx6cuboxi.h | 10 +- include/configs/mx6qsabreauto.h | 2 +- include/configs/mx6sabre_common.h | 7 +- include/configs/mx6sabresd.h | 2 +- include/configs/mx6sxsabresd.h | 5 - include/configs/mx6ul_14x14_evk.h | 5 - include/configs/mx7dsabresd.h | 5 - include/configs/mxs.h | 4 - include/configs/nitrogen6x.h | 7 - include/configs/nokia_rx51.h | 5 - include/configs/novena.h | 7 - include/configs/o2dnt-common.h | 6 +- include/configs/odroid.h | 2 - include/configs/omap3_evm.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_pandora.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/openrisc-generic.h | 1 - include/configs/origen.h | 2 - include/configs/paz00.h | 1 - include/configs/pcm058.h | 2 +- include/configs/pdm360ng.h | 4 - include/configs/peach-pi.h | 1 - include/configs/picosam9g45.h | 2 - include/configs/pm9261.h | 2 - include/configs/pm9263.h | 2 - include/configs/popmetal_rk3288.h | 1 - include/configs/pxm2.h | 5 - include/configs/r0p7734.h | 3 - include/configs/rcar-gen2-common.h | 3 - include/configs/rcar-gen3-common.h | 3 - include/configs/rk3288_common.h | 6 - include/configs/rock2.h | 1 - include/configs/rpi.h | 6 - include/configs/rut.h | 5 - include/configs/s5p_goni.h | 1 - include/configs/s5pc210_universal.h | 2 - include/configs/sama5d2_xplained.h | 2 - include/configs/sama5d3xek.h | 2 - include/configs/sama5d4_xplained.h | 2 - include/configs/sama5d4ek.h | 2 - include/configs/sandbox.h | 5 - include/configs/sansa_fuze_plus.h | 2 - include/configs/seaboard.h | 2 - include/configs/sequoia.h | 6 - include/configs/sh7752evb.h | 3 - include/configs/sh7753evb.h | 3 - include/configs/sh7757lcr.h | 3 - include/configs/sh7785lcr.h | 3 - include/configs/siemens-am33x-common.h | 1 - include/configs/smdk2410.h | 1 - include/configs/smdk5250.h | 1 - include/configs/smdk5420.h | 1 - include/configs/snapper9g45.h | 2 - include/configs/sniper.h | 6 - include/configs/socfpga_common.h | 3 - include/configs/socfpga_sr1500.h | 1 - include/configs/socrates.h | 6 - include/configs/spear-common.h | 1 - include/configs/strider.h | 2 - include/configs/sunxi-common.h | 13 - include/configs/tbs2910.h | 13 - include/configs/tegra-common.h | 6 - include/configs/theadorable.h | 4 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_armv7_common.h | 1 - include/configs/ti_omap4_common.h | 1 - include/configs/tqma6.h | 2 +- include/configs/tqma6_mba6.h | 2 +- include/configs/tqma6_wru4.h | 2 +- include/configs/trats.h | 2 - include/configs/trats2.h | 2 - include/configs/tricorder.h | 2 - include/configs/vct.h | 1 - include/configs/ventana.h | 2 - include/configs/wandboard.h | 5 - include/configs/x600.h | 1 - include/configs/x86-common.h | 12 - include/configs/xfi3.h | 2 - include/configs/xilinx-ppc.h | 1 - include/configs/xpress.h | 1 - include/configs/zc5202.h | 2 +- include/configs/zc5601.h | 2 +- include/configs/zipitz2.h | 1 - include/lcd_console.h | 3 - include/sed13806.h | 81 -- include/stdio_dev.h | 2 +- include/video.h | 11 + include/video_fb.h | 12 - scripts/config_whitelist.txt | 28 - 666 files changed, 1280 insertions(+), 2598 deletions(-) delete mode 100644 drivers/video/imx25lcdc.c delete mode 100644 drivers/video/s3c-fb.c delete mode 100644 drivers/video/sed13806.c delete mode 100644 drivers/video/smiLynxEM.c delete mode 100644 include/sed13806.h
These two files have patch merge markers in them, within comments or strings. Remove then, so that a search for merge markers does not show up matches in these files.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v4: None Changes in v3: None Changes in v2: None
drivers/net/ax88180.c | 6 +----- drivers/usb/host/isp116x-hcd.c | 6 +++--- 2 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/net/ax88180.c b/drivers/net/ax88180.c index 43a67a5..261fde0 100644 --- a/drivers/net/ax88180.c +++ b/drivers/net/ax88180.c @@ -698,11 +698,7 @@ static void ax88180_read_mac_addr (struct eth_device *dev) } }
-/* -=========================================================================== -<<<<<< Exported SubProgram Bodies >>>>>> -=========================================================================== -*/ +/* Exported SubProgram Bodies */ int ax88180_initialize (bd_t * bis) { struct eth_device *dev; diff --git a/drivers/usb/host/isp116x-hcd.c b/drivers/usb/host/isp116x-hcd.c index 0556f32..32874d7 100644 --- a/drivers/usb/host/isp116x-hcd.c +++ b/drivers/usb/host/isp116x-hcd.c @@ -428,10 +428,10 @@ static int isp116x_interrupt(struct isp116x *isp116x) isp116x_write_reg16(isp116x, HCuPINTENB, 0); irqstat = isp116x_read_reg16(isp116x, HCuPINT); isp116x_write_reg16(isp116x, HCuPINT, irqstat); - DBG(">>>>>> irqstat %x <<<<<<", irqstat); + DBG("------ irqstat %x ------", irqstat);
if (irqstat & HCuPINT_ATL) { - DBG(">>>>>> HCuPINT_ATL <<<<<<"); + DBG("------ HCuPINT_ATL ------"); udelay(500); ret = 1; } @@ -439,7 +439,7 @@ static int isp116x_interrupt(struct isp116x *isp116x) if (irqstat & HCuPINT_OPR) { intstat = isp116x_read_reg32(isp116x, HCINTSTAT); isp116x_write_reg32(isp116x, HCINTSTAT, intstat); - DBG(">>>>>> HCuPINT_OPR %x <<<<<<", intstat); + DBG("------ HCuPINT_OPR %x ------", intstat);
if (intstat & HCINT_UE) { ERR("unrecoverable error, controller disabled");
Reviewed-by: Jagan Teki jteki@openedev.com
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Jagan Teki jteki@openedev.com
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes.
Changes in v4: None Changes in v3: None Changes in v2: - Drop the changes to Kconfig defaults
README | 5 --- common/Kconfig | 45 ++++++++++++++++++++++ configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/a4m072_defconfig | 1 + configs/arndale_defconfig | 1 + configs/bct-brettl2_defconfig | 1 + configs/bf518f-ezbrd_defconfig | 1 + configs/bf526-ezbrd_defconfig | 1 + configs/bf527-ad7160-eval_defconfig | 1 + configs/bf527-ezkit-v2_defconfig | 1 + configs/bf527-ezkit_defconfig | 1 + configs/bf527-sdp_defconfig | 1 + configs/bf533-ezkit_defconfig | 1 + configs/bf533-stamp_defconfig | 1 + configs/bf537-pnav_defconfig | 1 + configs/bf537-stamp_defconfig | 1 + configs/bf538f-ezkit_defconfig | 1 + configs/bf548-ezkit_defconfig | 1 + configs/bf561-acvilon_defconfig | 1 + configs/bf561-ezkit_defconfig | 1 + configs/br4_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/cm-bf527_defconfig | 1 + configs/cm-bf533_defconfig | 1 + configs/cm-bf537e_defconfig | 1 + configs/cm-bf537u_defconfig | 1 + configs/cm-bf548_defconfig | 1 + configs/cm-bf561_defconfig | 1 + configs/cm5200_defconfig | 1 + configs/espresso7420_defconfig | 1 + configs/evb-rk3288_defconfig | 1 + configs/fennec-rk3288_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/fo300_defconfig | 1 + configs/ibf-dsp561_defconfig | 1 + configs/ip04_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/miniarm-rk3288_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/pdm360ng_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/pr1_defconfig | 1 + configs/rock2_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_noblk_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/snow_defconfig | 1 + configs/spring_defconfig | 1 + configs/tcm-bf518_defconfig | 1 + configs/tcm-bf537_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/TQM5200.h | 1 - include/configs/UCP1020.h | 4 -- include/configs/a4m072.h | 1 - include/configs/bfin_adi_common.h | 1 - include/configs/cm5200.h | 1 - include/configs/exynos5-common.h | 1 - include/configs/exynos7420-common.h | 1 - include/configs/ls1021aqds.h | 3 -- include/configs/ls1021atwr.h | 3 -- include/configs/pdm360ng.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/sandbox.h | 1 - include/configs/tricorder.h | 2 - scripts/config_whitelist.txt | 3 -- 125 files changed, 150 insertions(+), 33 deletions(-)
diff --git a/README b/README index 68d6a49..cc75700 100644 --- a/README +++ b/README @@ -813,11 +813,6 @@ The following options need to be configured: default i/o. Serial console can be forced with environment 'console=serial'.
- When CONFIG_SILENT_CONSOLE is defined, all console - messages (by U-Boot and Linux!) can be silenced with - the "silent" environment variable. See - doc/README.silent for more information. - CONFIG_SYS_CONSOLE_BG_COL: define the backgroundcolor, default is 0x00. CONFIG_SYS_CONSOLE_FG_COL: define the foregroundcolor, default diff --git a/common/Kconfig b/common/Kconfig index 1198f26..a8dfd7c 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -170,6 +170,8 @@ config BOOTDELAY
See doc/README.autoboot for details.
+menu "Console" + config CONSOLE_RECORD bool "Console recording" help @@ -203,6 +205,49 @@ config IDENT_STRING help This options adds the board specific name to u-boot version.
+config SILENT_CONSOLE + bool "Support a silent console" + help + This option allows the console to be silenced, meaning that no + output will appear on the console devices. This is controlled by + setting the environment vaariable 'silent' to a non-empty value. + Note this also silences the console when booting Linux. + + When the console is set up, the variable is checked, and the + GD_FLG_SILENT flag is set. Changing the environment variable later + will update the flag. + +config SILENT_U_BOOT_ONLY + bool "Only silence the U-Boot console" + depends on SILENT_CONSOLE + help + Normally when the U-Boot console is silenced, Linux's console is + also silenced (assuming the board boots into Linux). This option + allows the linux console to operate normally, even if U-Boot's + is silenced. + +config SILENT_CONSOLE_UPDATE_ON_SET + bool "Changes to the 'silent' environment variable update immediately" + depends on SILENT_CONSOLE + default y if SILENT_CONSOLE + help + When the 'silent' environment variable is changed, update the + console silence flag immediately. This allows 'setenv' to be used + to silence or un-silence the console. + + The effect is that any change to the variable will affect the + GD_FLG_SILENT flag. + +config SILENT_CONSOLE_UPDATE_ON_RELOC + bool "Allow flags to take effect on relocation" + depends on SILENT_CONSOLE + help + In some cases the environment is not available until relocation + (e.g. NAND). This option makes the value of the 'silent' + environment variable take effect at relocation. + +endmenu + config SYS_NO_FLASH bool "Disable support for parallel NOR flash" default n diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index 828bb9b..395330d 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index 7767e0d..fd1f2f0 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index 7173342..a62560a 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index a1c93ae..5a2f3f9 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index 371d5f6..04787a0 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index f134850..1a96a63 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index b0e9827..6f6fc86 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 91beb24..737c648 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 11aceb8..444d7f8 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 70961ec..2eada3f 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 09fe6c4..2c0f761 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index e013fdc..aa24d57 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index e9c7708..b1d1159 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index 098ef3b..5a3a00f 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index d727450..e437f3e 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 002346a..55671a6 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index fc28d1f..f68d6f2 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 4f470aa..bda4fb3 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index ae6aacf..4ec922a 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index dd53bb4..6de7d31 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index 9e5a409..e144a88 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index a43304b..aa3f0f8 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index e0887de..00e5b12 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT,T1040RDB" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index 1782e07..466bdd7 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 28b7bb4..422a738 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index d2772fe..d631eca 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index f8c5d45..aeea55f 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index fa3c412..d6ceeba 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index fca6122..66a2c44 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index f611baf..71dabd9 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index aa02cec..6d01cf2 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND,SECURE_BOOT" CONFIG_BOOTDELAY=0 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 96985ac..0377d25 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index fd5da57..1894c62 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index bf41ff5..1cb34a5 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index 7d70b57..ef8332b 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index 1539c85..224d1d8 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,SECURE_BOOT,T1042RDB" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index 817c0dc..ee35e43 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/a4m072_defconfig b/configs/a4m072_defconfig index 18dddd9..bf4ac25 100644 --- a/configs/a4m072_defconfig +++ b/configs/a4m072_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_A4M072=y CONFIG_OF_BOARD_SETUP=y +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index e04ff5b..f78a88c 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for ARNDALE" CONFIG_DEFAULT_DEVICE_TREE="exynos5250-arndale" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ARNDALE # " diff --git a/configs/bct-brettl2_defconfig b/configs/bct-brettl2_defconfig index ad894a2..5dae665 100644 --- a/configs/bct-brettl2_defconfig +++ b/configs/bct-brettl2_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BCT_BRETTL2=y CONFIG_BOOTDELAY=1 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/bf518f-ezbrd_defconfig b/configs/bf518f-ezbrd_defconfig index e17c969..7f30237 100644 --- a/configs/bf518f-ezbrd_defconfig +++ b/configs/bf518f-ezbrd_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF518F_EZBRD=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/configs/bf526-ezbrd_defconfig b/configs/bf526-ezbrd_defconfig index d3cab9b..663a6a3 100644 --- a/configs/bf526-ezbrd_defconfig +++ b/configs/bf526-ezbrd_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF526_EZBRD=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/bf527-ad7160-eval_defconfig b/configs/bf527-ad7160-eval_defconfig index 45f4149..ccbb148 100644 --- a/configs/bf527-ad7160-eval_defconfig +++ b/configs/bf527-ad7160-eval_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_AD7160_EVAL=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y # CONFIG_CMD_BOOTD is not set CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/bf527-ezkit-v2_defconfig b/configs/bf527-ezkit-v2_defconfig index 3677e0a..d247280 100644 --- a/configs/bf527-ezkit-v2_defconfig +++ b/configs/bf527-ezkit-v2_defconfig @@ -2,6 +2,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_EZKIT=y CONFIG_SYS_EXTRA_OPTIONS="BF527_EZKIT_REV_2_1" CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/bf527-ezkit_defconfig b/configs/bf527-ezkit_defconfig index da41fe6..f011277 100644 --- a/configs/bf527-ezkit_defconfig +++ b/configs/bf527-ezkit_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_EZKIT=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/bf527-sdp_defconfig b/configs/bf527-sdp_defconfig index fec1307..0c5c4fd 100644 --- a/configs/bf527-sdp_defconfig +++ b/configs/bf527-sdp_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_SDP=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y # CONFIG_CMD_BOOTD is not set CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/configs/bf533-ezkit_defconfig b/configs/bf533-ezkit_defconfig index 853a5d4..53cd831 100644 --- a/configs/bf533-ezkit_defconfig +++ b/configs/bf533-ezkit_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF533_EZKIT=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/bf533-stamp_defconfig b/configs/bf533-stamp_defconfig index e0f5de9..f31b54b 100644 --- a/configs/bf533-stamp_defconfig +++ b/configs/bf533-stamp_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF533_STAMP=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/bf537-pnav_defconfig b/configs/bf537-pnav_defconfig index bbc171d..4fd2936 100644 --- a/configs/bf537-pnav_defconfig +++ b/configs/bf537-pnav_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_PNAV=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/bf537-stamp_defconfig b/configs/bf537-stamp_defconfig index d189ad4..b691702 100644 --- a/configs/bf537-stamp_defconfig +++ b/configs/bf537-stamp_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_STAMP=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/configs/bf538f-ezkit_defconfig b/configs/bf538f-ezkit_defconfig index 8507b40..4e835cc 100644 --- a/configs/bf538f-ezkit_defconfig +++ b/configs/bf538f-ezkit_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF538F_EZKIT=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/bf548-ezkit_defconfig b/configs/bf548-ezkit_defconfig index 8514d85..19ac4e9 100644 --- a/configs/bf548-ezkit_defconfig +++ b/configs/bf548-ezkit_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF548_EZKIT=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/configs/bf561-acvilon_defconfig b/configs/bf561-acvilon_defconfig index 6428d18..744eb1c 100644 --- a/configs/bf561-acvilon_defconfig +++ b/configs/bf561-acvilon_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF561_ACVILON=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_SYS_PROMPT="Acvilon> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/bf561-ezkit_defconfig b/configs/bf561-ezkit_defconfig index f8206b8..abb612c 100644 --- a/configs/bf561-ezkit_defconfig +++ b/configs/bf561-ezkit_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF561_EZKIT=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/br4_defconfig b/configs/br4_defconfig index db5d915..90ce839 100644 --- a/configs/br4_defconfig +++ b/configs/br4_defconfig @@ -1,5 +1,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BR4=y +CONFIG_SILENT_CONSOLE=y CONFIG_SYS_PROMPT="br4>" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 2da4b6c..b3c6970 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DM_KEYBOARD=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-jerry" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/cm-bf527_defconfig b/configs/cm-bf527_defconfig index 773edfb..bc280a4 100644 --- a/configs/cm-bf527_defconfig +++ b/configs/cm-bf527_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF527=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/cm-bf533_defconfig b/configs/cm-bf533_defconfig index 6fa231d..5bc851a 100644 --- a/configs/cm-bf533_defconfig +++ b/configs/cm-bf533_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF533=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/cm-bf537e_defconfig b/configs/cm-bf537e_defconfig index 16f129b..db636e1 100644 --- a/configs/cm-bf537e_defconfig +++ b/configs/cm-bf537e_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF537E=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/cm-bf537u_defconfig b/configs/cm-bf537u_defconfig index 68e8659..f4726b0 100644 --- a/configs/cm-bf537u_defconfig +++ b/configs/cm-bf537u_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF537U=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/cm-bf548_defconfig b/configs/cm-bf548_defconfig index 0589803..bcf6d8f 100644 --- a/configs/cm-bf548_defconfig +++ b/configs/cm-bf548_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF548=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/cm-bf561_defconfig b/configs/cm-bf561_defconfig index 5a32f56..3acbc53 100644 --- a/configs/cm-bf561_defconfig +++ b/configs/cm-bf561_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF561=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/cm5200_defconfig b/configs/cm5200_defconfig index 8b98484..f8e28d9 100644 --- a/configs/cm5200_defconfig +++ b/configs/cm5200_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_CM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y diff --git a/configs/espresso7420_defconfig b/configs/espresso7420_defconfig index 2281d7e..0ab0437 100644 --- a/configs/espresso7420_defconfig +++ b/configs/espresso7420_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_IDENT_STRING=" for ESPRESSO7420" CONFIG_DEFAULT_DEVICE_TREE="exynos7420-espresso7420" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SILENT_CONSOLE=y CONFIG_SYS_PROMPT="ESPRESSO7420 # " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 85f957f..f5525db 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_EVB_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-evb" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 1170b87..4ce748b 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_FENNEC_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-fennec" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index a6c5094..61c46de 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_FIREFLY_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index e7370d3..697a147 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="FO300" CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/ibf-dsp561_defconfig b/configs/ibf-dsp561_defconfig index 036a92f..c598298 100644 --- a/configs/ibf-dsp561_defconfig +++ b/configs/ibf-dsp561_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_IBF_DSP561=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/ip04_defconfig b/configs/ip04_defconfig index 277988c..1e05d3e 100644 --- a/configs/ip04_defconfig +++ b/configs/ip04_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_IP04=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index b746ad7..31d7b0d 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_FSL_DDR4=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index b6df305..82cdf37 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_SYS_FSL_DDR4=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 3beda1e..a822ff0 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" CONFIG_SYS_FSL_DDR3=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 03e7bb2..cfade1b 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_SYS_FSL_DDR3=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 66fdc5b..da431fa 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 6db90ff..20d5d7e 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_SYS_FSL_DDR3=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index be2c05e..e07629f 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_SYS_FSL_DDR3=y CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index d76606f..d950f39 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_SYS_FSL_DDR3=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 4fcc92c..b9bca02 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_SYS_FSL_DDR3=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 34cbb4d..e5a0eca 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 307153f..43ba7fe 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 2f95780..8cfaeaf 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index e8ae266..4762425 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index fefd174..25760e4 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SECURE_BOOT" CONFIG_BOOTDELAY=0 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 68848d8..5f9efdf 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 9faba8d..e272ea7 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/miniarm-rk3288_defconfig b/configs/miniarm-rk3288_defconfig index bc5c980..52f1feb 100644 --- a/configs/miniarm-rk3288_defconfig +++ b/configs/miniarm-rk3288_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_MINIARM_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-miniarm" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 8164484..eabf22a 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5422-odroidxu3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ODROID-XU3 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/pdm360ng_defconfig b/configs/pdm360ng_defconfig index 9b8aa2f..8225506 100644 --- a/configs/pdm360ng_defconfig +++ b/configs/pdm360ng_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 9472bb0..e5f34a1 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for Peach-Pi" CONFIG_DEFAULT_DEVICE_TREE="exynos5800-peach-pi" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pi # " diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index d208d68..ddcb451 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for Peach-Pit" CONFIG_DEFAULT_DEVICE_TREE="exynos5420-peach-pit" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pit # " diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 2b5b26f..30268e5 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_POPMETAL_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-popmetal" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/pr1_defconfig b/configs/pr1_defconfig index e7cf5e8..a26ba61 100644 --- a/configs/pr1_defconfig +++ b/configs/pr1_defconfig @@ -1,5 +1,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_PR1=y +CONFIG_SILENT_CONSOLE=y CONFIG_SYS_PROMPT="pr1>" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index a89cb15..def639f 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_ROCK2=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-rock2-square" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 # CONFIG_SPL_MMC_SUPPORT is not set diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index fc9b4ac..143dd09 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index bc5793f..c051d41 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -15,6 +15,7 @@ CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index ebaf768..cd6f694 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 6e335f0..de62cb3 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for SMDK5250" CONFIG_DEFAULT_DEVICE_TREE="exynos5250-smdk5250" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5250 # " diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index c1d8c45..04521f2 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for SMDK5420" CONFIG_DEFAULT_DEVICE_TREE="exynos5420-smdk5420" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5420 # " diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 3d8c8ea..a5754f8 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for snow" CONFIG_DEFAULT_DEVICE_TREE="exynos5250-snow" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="snow # " diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 74287ea..0c394c8 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for spring" CONFIG_DEFAULT_DEVICE_TREE="exynos5250-spring" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="spring # " diff --git a/configs/tcm-bf518_defconfig b/configs/tcm-bf518_defconfig index fd31cfc..9288e56 100644 --- a/configs/tcm-bf518_defconfig +++ b/configs/tcm-bf518_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_TCM_BF518=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/tcm-bf537_defconfig b/configs/tcm-bf537_defconfig index d66e499..8459390 100644 --- a/configs/tcm-bf537_defconfig +++ b/configs/tcm-bf537_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_TCM_BF537=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 281eabb..5bf0c9a 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_TRICORDER=y CONFIG_BOOTDELAY=0 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP3 Tricorder # " diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index 7bdf5f5..68d8fb6 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_TRICORDER=y CONFIG_SYS_EXTRA_OPTIONS="FLASHCARD" CONFIG_BOOTDELAY=0 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index ed0838b..38a457d 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -33,7 +33,6 @@
#define CONFIG_DEEP_SLEEP #if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_SILENT_CONSOLE #define CONFIG_BOARD_EARLY_INIT_F #endif
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index da739be..29df5bd 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -38,7 +38,6 @@ #define CONFIG_DEEP_SLEEP #endif #if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_SILENT_CONSOLE #define CONFIG_BOARD_EARLY_INIT_F #endif
diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index c2d0fac..4aa2f2b 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -45,7 +45,6 @@ /* support deep sleep */ #define CONFIG_DEEP_SLEEP #if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_SILENT_CONSOLE #define CONFIG_BOARD_EARLY_INIT_F #endif
diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index ab97c74..6bff7cb 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -159,7 +159,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_DEEP_SLEEP #if defined(CONFIG_DEEP_SLEEP) #define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_SILENT_CONSOLE #endif
#ifndef CONFIG_SYS_TEXT_BASE diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index df12dc1..297a9ef 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -51,7 +51,6 @@
#ifdef CONFIG_FO300 #define CONFIG_SYS_DEVICE_NULLDEV 1 /* enable null device */ -#define CONFIG_SILENT_CONSOLE 1 /* enable silent startup */ #define CONFIG_BOARD_EARLY_INIT_F 1 /* used to detect S1 switch position */ #define CONFIG_USB_BIN_FIXUP 1 /* for a buggy USB device */ #if 0 diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index d62c9b3..e15e837 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -52,10 +52,6 @@
#define CONFIG_LAST_STAGE_INIT
-#if !defined(CONFIG_DONGLE) -#define CONFIG_SILENT_CONSOLE -#endif - #endif
#if defined(CONFIG_TARGET_UCP1020) diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index b5be7b2..f7bb29e 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -35,7 +35,6 @@ #define CONFIG_BAUDRATE 9600 /* ... at 9600 bps */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } /* define to enable silent console */ -#define CONFIG_SILENT_CONSOLE #define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */
/* diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index 502ddad..c401b73 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -78,7 +78,6 @@ #define CONFIG_AUTO_COMPLETE 1 #define CONFIG_LOADS_ECHO 1 #define CONFIG_JTAG_CONSOLE -#define CONFIG_SILENT_CONSOLE #ifndef CONFIG_BAUDRATE # define CONFIG_BAUDRATE 57600 #endif diff --git a/include/configs/cm5200.h b/include/configs/cm5200.h index a054faf..b65ca3e 100644 --- a/include/configs/cm5200.h +++ b/include/configs/cm5200.h @@ -33,7 +33,6 @@ #define CONFIG_PSC_CONSOLE 1 /* console is on PSC1 */ #define CONFIG_BAUDRATE 57600 /* ... at 57600 bps */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } -#define CONFIG_SILENT_CONSOLE 1 /* needed to silence i2c_init() */
/* * Ethernet configuration diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 51a0d19..111b23d 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -42,7 +42,6 @@ /* select serial console configuration */ #define CONFIG_BAUDRATE 115200 #define EXYNOS5_DEFAULT_UART_OFFSET 0x010000 -#define CONFIG_SILENT_CONSOLE #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_CONSOLE_MUX
diff --git a/include/configs/exynos7420-common.h b/include/configs/exynos7420-common.h index d112fbc..475d6ca 100644 --- a/include/configs/exynos7420-common.h +++ b/include/configs/exynos7420-common.h @@ -53,7 +53,6 @@
/* select serial console configuration */ #define CONFIG_BAUDRATE 115200 -#define CONFIG_SILENT_CONSOLE #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_CONSOLE_MUX
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index eefd93d..5aa823f 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -19,9 +19,6 @@ #define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_DEEP_SLEEP -#if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_SILENT_CONSOLE -#endif
/* * Size of malloc() pool diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index da07329..a6a0173 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -18,9 +18,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DEEP_SLEEP -#ifdef CONFIG_DEEP_SLEEP -#define CONFIG_SILENT_CONSOLE -#endif
/* * Size of malloc() pool diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h index 2e72889..9791665 100644 --- a/include/configs/pdm360ng.h +++ b/include/configs/pdm360ng.h @@ -36,7 +36,6 @@
/* Used for silent command in environment */ #define CONFIG_SYS_DEVICE_NULLDEV -#define CONFIG_SILENT_CONSOLE
/* Video */ #define CONFIG_VIDEO diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index afd3257..55c213e 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -38,7 +38,6 @@ #define CONFIG_SPL_STACK 0xff718000 #define CONFIG_SPL_TEXT_BASE 0xff704004
-#define CONFIG_SILENT_CONSOLE #ifndef CONFIG_SPL_BUILD # define CONFIG_SYS_CONSOLE_IS_IN_ENV # define CONFIG_CONSOLE_MUX diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 94e024b..bd005fc 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -67,7 +67,6 @@
#define CONFIG_SYS_LONGHELP /* #undef to save memory */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#define CONFIG_SILENT_CONSOLE
/* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index ac7b31b..6cd3ca5 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -39,8 +39,6 @@ #include <asm/arch/cpu.h> /* get chip and board defs */ #include <asm/arch/omap.h>
-#define CONFIG_SILENT_CONSOLE - /* Clock Defines */ #define V_OSCK 26000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK >> 1) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 04e9536..297a60b 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4086,9 +4086,6 @@ CONFIG_SIEMENS_DRACO CONFIG_SIEMENS_MACH_TYPE CONFIG_SIEMENS_PXM2 CONFIG_SIEMENS_RUT -CONFIG_SILENT_CONSOLE -CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC -CONFIG_SILENT_CONSOLE_UPDATE_ON_SET CONFIG_SIMU CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION CONFIG_SKIP_LOWLEVEL_INIT
thanks!
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Jagan Teki jteki@openedev.com
Changes in v4: None Changes in v3: None Changes in v2: - Change CONFIG_PRE_CON_BUF_SZ default to 4096 - Change CONFIG_PRE_CON_BUF_SZ to 'int' type - Drop the depend clause on the CONFIG_PRE_CON_BUF_SZ default - Move CONFIG_PRE_CON_BUF_ADDR default to common/Kconfig
README | 17 ---------------- board/sunxi/Kconfig | 3 +++ common/Kconfig | 42 +++++++++++++++++++++++++++++++++++++++ common/console.c | 6 +++--- configs/tbs2910_defconfig | 2 ++ include/asm-generic/global_data.h | 2 +- include/configs/sunxi-common.h | 6 ------ include/configs/tbs2910.h | 4 ---- scripts/config_whitelist.txt | 3 --- 9 files changed, 51 insertions(+), 34 deletions(-)
diff --git a/README b/README index cc75700..0614a60 100644 --- a/README +++ b/README @@ -832,23 +832,6 @@ The following options need to be configured: must be defined, to setup the maximum idle timeout for the SMC.
-- Pre-Console Buffer: - Prior to the console being initialised (i.e. serial UART - initialised etc) all console output is silently discarded. - Defining CONFIG_PRE_CONSOLE_BUFFER will cause U-Boot to - buffer any console messages prior to the console being - initialised to a buffer of size CONFIG_PRE_CON_BUF_SZ - bytes located at CONFIG_PRE_CON_BUF_ADDR. The buffer is - a circular buffer, so if more than CONFIG_PRE_CON_BUF_SZ - bytes are output before the console is initialised, the - earlier bytes are discarded. - - Note that when printing the buffer a copy is made on the - stack so CONFIG_PRE_CON_BUF_SZ must fit on the stack. - - 'Sane' compilers will generate smaller code if - CONFIG_PRE_CON_BUF_SZ is a power of 2 - - Autoboot Command: CONFIG_BOOTCOMMAND Only needed when CONFIG_BOOTDELAY is enabled; diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index b139d1c..c0ffeb3 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -3,6 +3,9 @@ if ARCH_SUNXI config IDENT_STRING default " Allwinner Technology"
+config PRE_CONSOLE_BUFFER + default y + config SPL_GPIO_SUPPORT default y
diff --git a/common/Kconfig b/common/Kconfig index a8dfd7c..7988de2 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -246,6 +246,48 @@ config SILENT_CONSOLE_UPDATE_ON_RELOC (e.g. NAND). This option makes the value of the 'silent' environment variable take effect at relocation.
+config PRE_CONSOLE_BUFFER + bool "Buffer characters before the console is available" + help + Prior to the console being initialised (i.e. serial UART + initialised etc) all console output is silently discarded. + Defining CONFIG_PRE_CONSOLE_BUFFER will cause U-Boot to + buffer any console messages prior to the console being + initialised to a buffer. The buffer is a circular buffer, so + if it overflows, earlier output is discarded. + + Note that this is not currently supported in SPL. It would be + useful to be able to share the pre-console buffer with SPL. + +config PRE_CON_BUF_SZ + int "Sets the size of the pre-console buffer" + depends on PRE_CONSOLE_BUFFER + default 4096 + help + The size of the pre-console buffer affects how much console output + can be held before it overflows and starts discarding earlier + output. Normally there is very little output at this early stage, + unless debugging is enabled, so allow enough for ~10 lines of + text. + + This is a useful feature if you are using a video console and + want to see the full boot output on the console. Without this + option only the post-relocation output will be displayed. + +config PRE_CON_BUF_ADDR + hex "Address of the pre-console buffer" + depends on PRE_CONSOLE_BUFFER + default 0x2f000000 if ARCH_SUNXI && MACH_SUN9I + default 0x4f000000 if ARCH_SUNXI && !MACH_SUN9I + help + This sets the start address of the pre-console buffer. This must + be in available memory and is accessed before relocation and + possibly before DRAM is set up. Therefore choose an address + carefully. + + We should consider removing this option and allocating the memory + in board_init_f_init_reserve() instead. + endmenu
config SYS_NO_FLASH diff --git a/common/console.c b/common/console.c index c7f3243..f0f9bab 100644 --- a/common/console.c +++ b/common/console.c @@ -201,7 +201,7 @@ static void console_putc(int file, const char c) } }
-#ifdef CONFIG_PRE_CONSOLE_BUFFER +#if CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) static void console_puts_noserial(int file, const char *s) { int i; @@ -247,7 +247,7 @@ static inline void console_putc(int file, const char c) stdio_devices[file]->putc(stdio_devices[file], c); }
-#ifdef CONFIG_PRE_CONSOLE_BUFFER +#if CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) static inline void console_puts_noserial(int file, const char *s) { if (strcmp(stdio_devices[file]->name, "serial") != 0) @@ -413,7 +413,7 @@ int tstc(void) #define PRE_CONSOLE_FLUSHPOINT1_SERIAL 0 #define PRE_CONSOLE_FLUSHPOINT2_EVERYTHING_BUT_SERIAL 1
-#ifdef CONFIG_PRE_CONSOLE_BUFFER +#if CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) #define CIRC_BUF_IDX(idx) ((idx) % (unsigned long)CONFIG_PRE_CON_BUF_SZ)
static void pre_console_putc(const char c) diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index fbff9fe..0871408 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_TBS2910=y +CONFIG_PRE_CONSOLE_BUFFER=y +CONFIG_PRE_CON_BUF_ADDR=0x7c000000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_HUSH_PARSER=y diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index dc4cbdb..e02863d 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -45,7 +45,7 @@ typedef struct global_data { unsigned long board_type; #endif unsigned long have_console; /* serial_init() was called */ -#ifdef CONFIG_PRE_CONSOLE_BUFFER +#if CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) unsigned long precon_buf_idx; /* Pre-Console buffer index */ #endif unsigned long env_addr; /* Address of Environment struct */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 33f2ab7..634a4c7 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -68,7 +68,6 @@ #define CONFIG_SYS_SDRAM_BASE 0x20000000 #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* default load address */ #define CONFIG_SYS_TEXT_BASE 0x2a000000 -#define CONFIG_PRE_CON_BUF_ADDR 0x2f000000 /* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ @@ -79,7 +78,6 @@ #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_LOAD_ADDR 0x42000000 /* default load address */ #define CONFIG_SYS_TEXT_BASE 0x4a000000 -#define CONFIG_PRE_CON_BUF_ADDR 0x4f000000 /* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ @@ -371,10 +369,6 @@ extern int soft_i2c_gpio_scl; #ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h>
-/* Enable pre-console buffer to get complete log on the VGA console */ -#define CONFIG_PRE_CONSOLE_BUFFER -#define CONFIG_PRE_CON_BUF_SZ 4096 /* Aprox 2 80*25 screens */ - #ifdef CONFIG_ARM64 /* * Boards seem to come with at least 512MB of DRAM. diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index d877336..90e4982 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -50,10 +50,6 @@ #define CONFIG_CONSOLE_MUX #define CONFIG_CONS_INDEX 1
-#define CONFIG_PRE_CONSOLE_BUFFER -#define CONFIG_PRE_CON_BUF_SZ 4096 -#define CONFIG_PRE_CON_BUF_ADDR 0x7C000000 - /* *** Command definition *** */ #define CONFIG_CMD_BMODE #define CONFIG_CMD_PART diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 297a60b..64f21f1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3719,9 +3719,6 @@ CONFIG_PQ_MDS_PIB CONFIG_PQ_MDS_PIB_ATM CONFIG_PRAM CONFIG_PREBOOT -CONFIG_PRE_CONSOLE_BUFFER -CONFIG_PRE_CON_BUF_ADDR -CONFIG_PRE_CON_BUF_SZ CONFIG_PRIMEVIEW_V16C6448AC CONFIG_PRINTK CONFIG_PROC_FS
On Tue, Oct 18, 2016 at 7:42 AM, Simon Glass sjg@chromium.org wrote:
Move these option to Kconfig and tidy up existing uses.
thanks!
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_IS_IN_ENV CONFIG_CONSOLE_MUX
Changes in v4: None Changes in v3: - Make SYS_CONSOLE_IS_IN_ENV default to y if CONSOLE_MUX is enabled
Changes in v2: None
README | 6 ------ common/Kconfig | 21 +++++++++++++++++++++ configs/B4420QDS_NAND_defconfig | 1 + configs/B4420QDS_SPIFLASH_defconfig | 1 + configs/B4420QDS_defconfig | 1 + configs/B4860QDS_NAND_defconfig | 1 + configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 1 + configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/B4860QDS_defconfig | 1 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 1 + .../BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 1 + .../BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 1 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/Cubietruck_plus_defconfig | 1 + configs/Cyrus_P5020_defconfig | 1 + configs/Cyrus_P5040_defconfig | 1 + configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/Merrii_A80_Optimus_defconfig | 1 + configs/MiniFAP_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/PATI_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/PMC440_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 1 + configs/T1023RDB_NAND_defconfig | 1 + configs/T1023RDB_SDCARD_defconfig | 1 + configs/T1023RDB_SECURE_BOOT_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 1 + configs/T1023RDB_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/TQM5200_B_HIGHBOOT_defconfig | 1 + configs/TQM5200_B_defconfig | 1 + configs/TQM5200_STK100_defconfig | 1 + configs/TQM5200_defconfig | 1 + configs/a3m071_defconfig | 1 + configs/a4m2k_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/arndale_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/beaver_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cei-tk1-som_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/charon_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t3517_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/colibri_t30_defconfig | 1 + .../conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + .../controlcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/d2net_v2_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/digsy_mtc_RAMBOOT_defconfig | 1 + configs/digsy_mtc_defconfig | 1 + configs/digsy_mtc_rev5_RAMBOOT_defconfig | 1 + configs/digsy_mtc_rev5_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/dns325_defconfig | 1 + configs/duovero_defconfig | 1 + configs/e2220-1170_defconfig | 1 + configs/ea20_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/espresso7420_defconfig | 1 + configs/evb-rk3288_defconfig | 1 + configs/fennec-rk3288_defconfig | 1 + configs/fo300_defconfig | 1 + configs/galileo_defconfig | 1 + configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/gwventana_defconfig | 1 + configs/h2200_defconfig | 1 + configs/h8_homlet_v2_defconfig | 1 + configs/haleakala_defconfig | 1 + configs/igep0020_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0030_nand_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/imx31_phycore_eet_defconfig | 1 + configs/inetspace_v2_defconfig | 1 + configs/io64_defconfig | 1 + configs/ipek01_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/kc1_defconfig | 1 + configs/kilauea_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/makalu_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mcx_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + configs/miniarm-rk3288_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlsabreauto_defconfig | 1 + configs/mx6dlsabresd_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 1 + configs/mx6qsabreauto_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6qsabresd_defconfig | 1 + configs/mx6sabresd_spl_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 7 ++++--- configs/mx6ul_9x9_evk_defconfig | 7 ++++--- configs/mx7dsabresd_defconfig | 1 + configs/mx7dsabresd_secure_defconfig | 1 + configs/nanopi_neo_defconfig | 1 + configs/net2big_v2_defconfig | 1 + configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/novena_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/orangepi_2_defconfig | 1 + configs/orangepi_lite_defconfig | 1 + configs/orangepi_one_defconfig | 1 + configs/orangepi_pc_defconfig | 1 + configs/orangepi_pc_plus_defconfig | 1 + configs/orangepi_plus2e_defconfig | 1 + configs/orangepi_plus_defconfig | 1 + configs/origen_defconfig | 1 + configs/p2371-0000_defconfig | 1 + configs/p2371-2180_defconfig | 1 + configs/p2571_defconfig | 1 + configs/p2771-0000-000_defconfig | 1 + configs/p2771-0000-500_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/pine64_plus_defconfig | 1 + configs/plutux_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/rainier_defconfig | 1 + configs/rainier_ramboot_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_defconfig | 1 + configs/s5p_goni_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/sequoia_defconfig | 1 + configs/sequoia_ramboot_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/sniper_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/socrates_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/tbs2910_defconfig | 3 ++- configs/tec-ng_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/venice2_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/whistler_defconfig | 1 + configs/xfi3_defconfig | 1 + include/configs/B4860QDS.h | 3 --- include/configs/BSC9131RDB.h | 2 -- include/configs/BSC9132QDS.h | 2 -- include/configs/C29XPCIE.h | 2 -- include/configs/MIP405.h | 1 - include/configs/P1010RDB.h | 2 -- include/configs/PATI.h | 1 - include/configs/PIP405.h | 1 - include/configs/PMC440.h | 2 -- include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 3 --- include/configs/TQM5200.h | 1 - include/configs/a3m071.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/am3517_crane.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/at91sam9261ek.h | 2 -- include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/bur_cfg_common.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm_fx6.h | 2 -- include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/controlcenterd.h | 2 -- include/configs/cyrus.h | 2 -- include/configs/digsy_mtc.h | 1 - include/configs/dns325.h | 2 -- include/configs/ea20.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/exynos5-common.h | 2 -- include/configs/exynos7420-common.h | 2 -- include/configs/ge_bx50v3.h | 1 - include/configs/goflexhome.h | 2 -- include/configs/gw_ventana.h | 2 -- include/configs/h2200.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/io64.h | 2 -- include/configs/ipek01.h | 1 - include/configs/kc1.h | 6 ------ include/configs/kilauea.h | 2 -- include/configs/lacie_kw.h | 2 -- include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/lsxl.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m53evk.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/makalu.h | 2 -- include/configs/mcx.h | 1 - include/configs/microblaze-generic.h | 2 -- include/configs/mt_ventoux.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx6cuboxi.h | 2 -- include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mxs.h | 1 - include/configs/nitrogen6x.h | 2 -- include/configs/nokia_rx51.h | 1 - include/configs/novena.h | 2 -- include/configs/odroid.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_pandora.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/origen.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/rk3288_common.h | 5 ----- include/configs/rpi.h | 2 -- include/configs/s5p_goni.h | 1 - include/configs/s5pc210_universal.h | 1 - include/configs/sama5d2_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/sandbox.h | 2 -- include/configs/sequoia.h | 2 -- include/configs/snapper9g45.h | 2 -- include/configs/sniper.h | 6 ------ include/configs/socfpga_common.h | 1 - include/configs/socrates.h | 1 - include/configs/sunxi-common.h | 3 --- include/configs/tbs2910.h | 2 -- include/configs/tegra-common.h | 2 -- include/configs/ti_omap4_common.h | 1 - include/configs/trats.h | 1 - include/configs/trats2.h | 1 - include/configs/wandboard.h | 1 - include/configs/x86-common.h | 2 -- scripts/config_whitelist.txt | 2 -- 448 files changed, 373 insertions(+), 164 deletions(-)
diff --git a/README b/README index 0614a60..fff5772 100644 --- a/README +++ b/README @@ -3623,12 +3623,6 @@ Configuration Settings: - CONFIG_SYS_CONSOLE_INFO_QUIET Suppress display of console information at boot.
-- CONFIG_SYS_CONSOLE_IS_IN_ENV - If the board specific function - extern int overwrite_console (void); - returns 1, the stdin, stderr and stdout are switched to the - serial port, else the settings in the environment are used. - - CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Enable the call to overwrite_console().
diff --git a/common/Kconfig b/common/Kconfig index 7988de2..777724f 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -288,6 +288,27 @@ config PRE_CON_BUF_ADDR We should consider removing this option and allocating the memory in board_init_f_init_reserve() instead.
+config CONSOLE_MUX + bool "Enable console multiplexing" + default y if DM_VIDEO || VIDEO || LCD + help + This allows multiple devices to be used for each console 'file'. + For example, stdout can be set to go to serial and video. + Similarly, stdin can be set to come from serial and keyboard. + Input can be provided from either source. Console multiplexing + adds a small amount of size to U-Boot. Changes to the environment + variables stdout, stdin and stderr will take effect immediately. + +config SYS_CONSOLE_IS_IN_ENV + bool "Select console devices from the environment" + default y if CONSOLE_MUX + help + This allows multiple input/output devices to be set at boot time. + For example, if stdout is set to "serial,video" then output will + be sent to both the serial and video devices on boot. The + environment variables can be updated after boot to change the + input/output devices. + endmenu
config SYS_NO_FLASH diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index c192177..d3cf286 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index 2c2e3c2..2dd25fe 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index bfd64af..406241a 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index d01baaa..00fe182 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/B4860QDS_SECURE_BOOT_defconfig b/configs/B4860QDS_SECURE_BOOT_defconfig index 75124a8..2923547 100644 --- a/configs/B4860QDS_SECURE_BOOT_defconfig +++ b/configs/B4860QDS_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index 52f78be..80e729e 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y diff --git a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig index cd80c91..09c8a5b 100644 --- a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index 1f642e3..31f64ab 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index 9a69785..c056b26 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,NAND,SYS_CLK_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index 46b5b8e..bf26e23 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig index 9a50d0c..576d193 100644 --- a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,SPIFLASH,SYS_CLK_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/BSC9131RDB_SPIFLASH_defconfig b/configs/BSC9131RDB_SPIFLASH_defconfig index ebb41d2..db717be 100644 --- a/configs/BSC9131RDB_SPIFLASH_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig index 5bed9aa..8ebd0da 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND_SECBOOT,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index defeee1..cb3b0ee 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND,SYS_CLK_100_DDR_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig index 3a695fc..aa4f418 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND_SECBOOT,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index 6600d1e..29646d2 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND,SYS_CLK_100_DDR_133" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig index 8d26cc5..6f3c5e5 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig index eb1c1de..dc75009 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig index 5359109..f947215 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig index 83a9840..190e2e7 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_133" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig index f50c833..512a675 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig index 2f28087..83b8dee 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig index 596ebad..c92458e 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig index cc12251..0a49a45 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig index c56f9d2..1e90d68 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig index 86f5b87..a6a814d 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig index f9f671e..4ba0a15 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig index 8594ff3..cbf0a59 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index 1c03d44..c3cc168 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,NAND" CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/C29XPCIE_NOR_SECBOOT_defconfig b/configs/C29XPCIE_NOR_SECBOOT_defconfig index f932373..15d89f1 100644 --- a/configs/C29XPCIE_NOR_SECBOOT_defconfig +++ b/configs/C29XPCIE_NOR_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,SECURE_BOOT" CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y diff --git a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig index 7f4189e..49799be 100644 --- a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig +++ b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,SPIFLASH,SECURE_BOOT" CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index ff16c7a..9f89263 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,SPIFLASH" CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index 8dd57d2..83493d4 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE" CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index f2c6fe7..dbe3336 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -13,6 +13,7 @@ CONFIG_I2C0_ENABLE=y CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-cubietruck-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cyrus_P5020_defconfig b/configs/Cyrus_P5020_defconfig index d8c8957..6495440 100644 --- a/configs/Cyrus_P5020_defconfig +++ b/configs/Cyrus_P5020_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000,PPC_P5020" CONFIG_BOOTDELAY=10 +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/Cyrus_P5040_defconfig b/configs/Cyrus_P5040_defconfig index f5d3cc2..4566abb 100644 --- a/configs/Cyrus_P5040_defconfig +++ b/configs/Cyrus_P5040_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000,PPC_P5040" CONFIG_BOOTDELAY=10 +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 9b96b85..6f144a4 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -4,6 +4,7 @@ CONFIG_4xx=y CONFIG_TARGET_MIP405T=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 96b5c26..66590b1 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -4,6 +4,7 @@ CONFIG_4xx=y CONFIG_TARGET_MIP405=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index 198fda9..774d137 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_CLK_FREQ=1008000000 CONFIG_MMC0_CD_PIN="PH18" CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-optimus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index 266f2ce..aec6b9a 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MINIFAP" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig index 864643c..986dc7f 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND_SECBOOT,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index fc14f50..7155011 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig index 17dd94b..f687a84 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 6de688f..cf42d2f 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 4006383..f3f0fca 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig index 6ff1f50..94a1c22 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 94f1501..c56d9e3 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig index 911f607..df0cc7a 100644 --- a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND_SECBOOT,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index db003ef..f6943a8 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig index 9599528..50166ce 100644 --- a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index e25da5c..6a6bcaf 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index d8d069e..64959d7 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig index 7050462..a4073f6 100644 --- a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index b8229fa..eea19e6 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig index 55da2e4..3ac3839 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND_SECBOOT,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index dd170a5..406a58a 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig index 166df05..a1375b3 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index e751041..c95c28c 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index b907459..38fbb18 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig index f26fa72..f201f13 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index e87c9d6..87e23dd 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig index 7fad176..ececb7e 100644 --- a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND_SECBOOT,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 11f0866..f45db61 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig index 6282ccb..ecafb24 100644 --- a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index d477a88..231c806 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 613131a..14f67b0 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig index c2238d6..524afd9 100644 --- a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index fb7334b..591075f 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/PATI_defconfig b/configs/PATI_defconfig index 6ec48ff..541f6de 100644 --- a/configs/PATI_defconfig +++ b/configs/PATI_defconfig @@ -4,6 +4,7 @@ CONFIG_5xx=y CONFIG_TARGET_PATI=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="pati=> " # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index f290cb1..f7bdf5a 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -4,6 +4,7 @@ CONFIG_4xx=y CONFIG_TARGET_PIP405=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/PMC440_defconfig b/configs/PMC440_defconfig index af38882..cd2f0d2 100644 --- a/configs/PMC440_defconfig +++ b/configs/PMC440_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_PMC440=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index a9c7fc1..d15ac20 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -14,6 +14,7 @@ CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-sinovoip-bpi-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPD(25)" +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index b24d21b..fed2560 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index 7f84498..c45de13 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1023RDB_SECURE_BOOT_defconfig b/configs/T1023RDB_SECURE_BOOT_defconfig index fa538f3..3e5765e 100644 --- a/configs/T1023RDB_SECURE_BOOT_defconfig +++ b/configs/T1023RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index c75abbb..9ec82d5 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1023RDB_defconfig b/configs/T1023RDB_defconfig index af99ff0..c0fe36b 100644 --- a/configs/T1023RDB_defconfig +++ b/configs/T1023RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index 395330d..93637e4 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index fd1f2f0..ac419b4 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index a62560a..6ed4e9e 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index 5a2f3f9..243b2b1 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index 04787a0..e3a249f 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 1a96a63..8a8b854 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index 6f6fc86..b5c6c1e 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 737c648..dfc9697 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 444d7f8..15545d8 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 2eada3f..43ba56b 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 2c0f761..99d2a40 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index aa24d57..72fc86f 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index b1d1159..c420dc3 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index 5a3a00f..ff4bbe3 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index e437f3e..f548e21 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 55671a6..00feb36 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index f68d6f2..55adc62 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index bda4fb3..8526426 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index 4ec922a..6dee606 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 6de7d31..716490b 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index e144a88..da6ef10 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index aa3f0f8..49b6221 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index 00e5b12..98e7855 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT,T1040RDB" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index 466bdd7..31ea589 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 422a738..b898f93 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index d631eca..ce34ec1 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index aeea55f..63e88df 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index d6ceeba..9035ab9 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 66a2c44..b26304c 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 71dabd9..ff39f15 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index 6d01cf2..3e4e9e2 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND,SECURE_BOOT" CONFIG_BOOTDELAY=0 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 0377d25..5fd9c1e 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 1894c62..95a4c8a 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 1cb34a5..f05e33c 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index ef8332b..07faad5 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index 224d1d8..e9d4145 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,SECURE_BOOT,T1042RDB" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index ee35e43..8e11872 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index be90d79..353fdc1 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,SYS_TEXT_BASE=0xFFF00000" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index a405e92..ec3655d 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 904fcd1..823e2ae 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="STK52XX_REV100" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index e478f4c..c47ff76 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/a3m071_defconfig b/configs/a3m071_defconfig index ae696b5..804ad63 100644 --- a/configs/a3m071_defconfig +++ b/configs/a3m071_defconfig @@ -8,6 +8,7 @@ CONFIG_TARGET_A3M071=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/a4m2k_defconfig b/configs/a4m2k_defconfig index 144291e..0bf0b00 100644 --- a/configs/a4m2k_defconfig +++ b/configs/a4m2k_defconfig @@ -9,6 +9,7 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="A4M2K" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index ec33397..41c1f52 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA30=y CONFIG_TARGET_APALIS_T30=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-apalis" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Apalis T30 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 35d7e94..2f1e4da 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_ARISTAINETOS2=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 6b2c44d..708bc24 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_ARISTAINETOS2B=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index a06d9ee..de00afd 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_ARISTAINETOS=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index f78a88c..5dd6fda 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-arndale" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ARNDALE # " diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index b2a46cb..31c18e5 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index a16e7e1..3338e4b 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS3" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 17d0fdd..92c2a73 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 5b36688..7f1a6e5 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 5b36688..7f1a6e5 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 024d750..c17f702 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 297e4e7..f6d8a63 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_BOOT_NORFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 237bdee..2e056de 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NORFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index f00f61b..4e1d27b 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index dc413b2..e6b59da 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS3" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 325e0ee..efa4101 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index de374cf..c655c81 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 70cb74f..e1d8a17 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index b2b53b9..63b5ba3 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9N12EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index f2c0f3c..2914685 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 62b01d6..c248b2e 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_SPIFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 5d92c5f..e1597aa 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9RLEK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index d7214f2..443f06f 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9RLEK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 205e44d..9450da9 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9RLEK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 441a940..516f54b 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9X5EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 9962d1f..0a181b4 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AT91SAM9X5EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 8fb4af7..a6204b6 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 2125635..9b1238e 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_SPIFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index f8f5f5c..1c3625f 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -15,6 +15,7 @@ CONFIG_SEABIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 6758c56..0c5e59f 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA30=y CONFIG_TARGET_BEAVER=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-beaver" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (Beaver) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 8d3ef0e..7277cd1 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,EMMC_BOOT" CONFIG_BOOTDELAY=-2 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index f624197..3e02895 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_BOOTDELAY=-2 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 474477a..d7d0f66 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,SPI_BOOT,EMMC_BOOT" CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=-2 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 49c26e2..5acc776 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_BOOTDELAY=-2 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 44955fa..ffd52c2 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA30=y CONFIG_TARGET_CARDHU=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-cardhu" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (Cardhu) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index cc162f9..89024b7 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA124=y CONFIG_TARGET_CEI_TK1_SOM=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-cei-tk1-som" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (TK1-SOM) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 5a053f5..f1ee51d 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " diff --git a/configs/charon_defconfig b/configs/charon_defconfig index 724441e..8517f2b 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_CHARON=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 2475222..2e5cbf4 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -10,6 +10,7 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 6df4d4c..1ae6102 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -8,6 +8,7 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 7c413d5..693ccad 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL,SPL" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-FX6 # " diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index dfc2539..b131b27 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_CM_T3517=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3517 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 79fa39c..9a2f624 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_CM_T35=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3x # " diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 4eca7b9..8fe1e04 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx7-colibri" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_imx7/imximage.cfg,MX7D" CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri iMX7 # " # CONFIG_CMD_BOOTD is not set diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 31275d0..42f32a9 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA30=y CONFIG_TARGET_COLIBRI_T30=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-colibri" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri T30 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 6bee9c6..9af9774 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 76ff904..077630e 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -14,6 +14,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index 84c68b6..e73cc76 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD,DEVELOP" CONFIG_BOOTDELAY=10 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index 0d1cc82..c3c60d8 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig index e45b4df..0fdb0f6 100644 --- a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_CONTROLCENTERD=y CONFIG_SYS_EXTRA_OPTIONS="TRAILBLAZER,SPIFLASH,DEVELOP" CONFIG_BOOTDELAY=-2 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/controlcenterd_TRAILBLAZER_defconfig b/configs/controlcenterd_TRAILBLAZER_defconfig index cd1c6c4..7879659 100644 --- a/configs/controlcenterd_TRAILBLAZER_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_CONTROLCENTERD=y CONFIG_SYS_EXTRA_OPTIONS="TRAILBLAZER,SPIFLASH" CONFIG_BOOTDELAY=-2 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index b33c5c4..c9ce633 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_COREBOOT=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index a55e4a3..cfd868d 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -2,6 +2,7 @@ CONFIG_X86=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="cougarcanyon2" CONFIG_TARGET_COUGARCANYON2=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index b37fce7..137975c 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -8,6 +8,7 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y CONFIG_FIT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index fa06576..683c81f 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -5,6 +5,7 @@ CONFIG_IDENT_STRING=" D2 v2" CONFIG_SYS_EXTRA_OPTIONS="D2NET_V2" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="d2v2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 1de5d4a..25ae702 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA114=y CONFIG_TARGET_DALMORE=y CONFIG_DEFAULT_DEVICE_TREE="tegra114-dalmore" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra114 (Dalmore) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 3931896..585d48c 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -14,6 +14,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/digsy_mtc_RAMBOOT_defconfig b/configs/digsy_mtc_RAMBOOT_defconfig index d0743c8..2494412 100644 --- a/configs/digsy_mtc_RAMBOOT_defconfig +++ b/configs/digsy_mtc_RAMBOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00100000" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/digsy_mtc_defconfig b/configs/digsy_mtc_defconfig index e2156a1..1f4c15c 100644 --- a/configs/digsy_mtc_defconfig +++ b/configs/digsy_mtc_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" diff --git a/configs/digsy_mtc_rev5_RAMBOOT_defconfig b/configs/digsy_mtc_rev5_RAMBOOT_defconfig index 3b7a7c1..8d77864 100644 --- a/configs/digsy_mtc_rev5_RAMBOOT_defconfig +++ b/configs/digsy_mtc_rev5_RAMBOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00100000,DIGSY_REV5" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/digsy_mtc_rev5_defconfig b/configs/digsy_mtc_rev5_defconfig index 75888ff..56e14e1 100644 --- a/configs/digsy_mtc_rev5_defconfig +++ b/configs/digsy_mtc_rev5_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="DIGSY_REV5" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index db5adcf..5042a82 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_SYS_DDR_1G=y CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index e36f3dc..da741b4 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index de2c4aa..ac09175 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DNS325=y CONFIG_IDENT_STRING="\nD-Link DNS-325" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index 64f9cbc..351e133 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP44XX=y # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_DUOVERO=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/e2220-1170_defconfig b/configs/e2220-1170_defconfig index 9a4c556..4df533f 100644 --- a/configs/e2220-1170_defconfig +++ b/configs/e2220-1170_defconfig @@ -3,6 +3,7 @@ CONFIG_TEGRA=y CONFIG_TEGRA210=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-e2220-1170" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (E2220-1170) # " # CONFIG_CMD_IMI is not set diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index a808145..8d4b5b4 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_EA20=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index eb55e93..c47f314 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -3,6 +3,7 @@ CONFIG_VENDOR_EFI=y CONFIG_DEFAULT_DEVICE_TREE="efi" CONFIG_TARGET_EFI=y CONFIG_FIT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/espresso7420_defconfig b/configs/espresso7420_defconfig index 0ab0437..c4394e5 100644 --- a/configs/espresso7420_defconfig +++ b/configs/espresso7420_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for ESPRESSO7420" CONFIG_DEFAULT_DEVICE_TREE="exynos7420-espresso7420" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y CONFIG_SYS_PROMPT="ESPRESSO7420 # " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index f5525db..da36783 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-evb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 4ce748b..cced43e 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-fennec" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index 697a147..eda7a14 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="FO300" CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index f79ee2e..ef6ce97 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -9,6 +9,7 @@ CONFIG_GENERATE_ACPI_TABLE=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index 8577167..29010f3 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B450V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index c5f391e..e0eeb46 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B650V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index 2c5aa05..9b4b917 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B850V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 8eeeafb..d932539 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_GOFLEXHOME=y CONFIG_IDENT_STRING="\nSeagate GoFlex Home" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_SYS_PROMPT="GoFlexHome> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index c0904b1..7107e38 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -17,6 +17,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/h2200_defconfig b/configs/h2200_defconfig index ed2217a..653840f 100644 --- a/configs/h2200_defconfig +++ b/configs/h2200_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_H2200=y CONFIG_FIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="> " # CONFIG_CMD_BDI is not set diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index c4bd2c5..76dd833 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -9,6 +9,7 @@ CONFIG_USB1_VBUS_PIN="PL6" CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-allwinner-h8homlet-v2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/haleakala_defconfig b/configs/haleakala_defconfig index 270d2a3..5861769 100644 --- a/configs/haleakala_defconfig +++ b/configs/haleakala_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="HALEAKALA" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 8c1174e..366abaa 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -4,6 +4,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 4bc0def..b18dcb1 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/igep0030_nand_defconfig b/configs/igep0030_nand_defconfig index e053e4d..0493ce7 100644 --- a/configs/igep0030_nand_defconfig +++ b/configs/igep0030_nand_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index b2c5c71..4fbbf63 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/imx31_phycore_eet_defconfig b/configs/imx31_phycore_eet_defconfig index 96252c3..a210abb 100644 --- a/configs/imx31_phycore_eet_defconfig +++ b/configs/imx31_phycore_eet_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_IMX31_PHYCORE=y CONFIG_SYS_EXTRA_OPTIONS="IMX31_PHYCORE_EET" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 2144894..77f7c34 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -5,6 +5,7 @@ CONFIG_IDENT_STRING=" IS v2" CONFIG_SYS_EXTRA_OPTIONS="INETSPACE_V2" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/io64_defconfig b/configs/io64_defconfig index 58db5ca..8dc24ab 100644 --- a/configs/io64_defconfig +++ b/configs/io64_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y diff --git a/configs/ipek01_defconfig b/configs/ipek01_defconfig index 54b873f..0042d3f 100644 --- a/configs/ipek01_defconfig +++ b/configs/ipek01_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_IPEK01=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index 6c284a1..4544c28 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA124=y CONFIG_TARGET_JETSON_TK1=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-jetson-tk1" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Jetson TK1) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index 4827934..b73a2de 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP44XX=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_KC1=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="kc1 # " diff --git a/configs/kilauea_defconfig b/configs/kilauea_defconfig index f740b0b..a497408 100644 --- a/configs/kilauea_defconfig +++ b/configs/kilauea_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="KILAUEA" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 31d7b0d..d44ebaa 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_FSL_DDR4=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 82cdf37..1f4bd95 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_SYS_FSL_DDR4=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index a822ff0..989a9f1 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_FSL_DDR3=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index cfade1b..3591967 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_SYS_FSL_DDR3=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index da431fa..9cda390 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 20d5d7e..15766bd 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_SYS_FSL_DDR3=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index e07629f..77a8e6f 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_FSL_DDR3=y CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index d950f39..c265b3e 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_FSL_DDR3=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index b9bca02..8721ae4 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_FSL_DDR3=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index e5a0eca..fdbcbf0 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 43ba7fe..dce1592 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 8cfaeaf..cd37246 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 4762425..07f7023 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 25760e4..ab1a558 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SECURE_BOOT" CONFIG_BOOTDELAY=0 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 5f9efdf..52dc6f0 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index e272ea7..6e7289e 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 2e17a57..ef770a8 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -5,6 +5,7 @@ CONFIG_IDENT_STRING=" LS-CHLv2" CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 2cbde40..a8ec46e 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -5,6 +5,7 @@ CONFIG_IDENT_STRING=" LS-XHL" CONFIG_SYS_EXTRA_OPTIONS="LSXHL" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index b6a0bef..609a218 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_LWMON5=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index 6a057e5..efc5561 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index 03a4bfd..bce58ff 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/denx/m53evk/imximage.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/makalu_defconfig b/configs/makalu_defconfig index bb9ee2f..3e45de5 100644 --- a/configs/makalu_defconfig +++ b/configs/makalu_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_MAKALU=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index dd94d22..a31d213 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,ENV_IS_IN_SPI_FLASH" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index 28837f9..f9510a8 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -5,6 +5,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_MCX=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mcx # " diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 3dbf48a..38046f4 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="microblaze-generic" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NOR_SUPPORT=y diff --git a/configs/miniarm-rk3288_defconfig b/configs/miniarm-rk3288_defconfig index 52f1feb..134b76e 100644 --- a/configs/miniarm-rk3288_defconfig +++ b/configs/miniarm-rk3288_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-miniarm" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 1446ab6..a280432 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index 0fdec87..1c9d1b0 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -4,6 +4,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_MT_VENTOUX=y CONFIG_FIT=y CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mt_ventoux => " diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 023d99b..a7808f1 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index bd932ff..81f99d9 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 42c6383..d00bb42 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 0980045..39cf012 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_NAND" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index b9e9d97..ed89714 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index c903b41..d68d001 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX51EVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index ef1b3a1..232677d 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_MX53LOCO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53loco/imximage.cfg" CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 27c3d3b..6edc8b7 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index f9fda50..be8739f 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index dc28694..f6c702a 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index c34d834..d46cca1 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index bf4c465..7de4166 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 4b42d08..7e592c5 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index d1385c7..b502299 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index e9edba6..9cfeae9 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index c9bd1f0..96209e5 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index d013cb0..8fdd0cf 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index a829a18..f878970 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y @@ -30,10 +31,10 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_FSL_QSPI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index eaf3cfd..4b5b41a 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y @@ -30,10 +31,10 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_FSL_QSPI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 3203551..e7a72fe 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -6,6 +6,7 @@ CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/mx7dsabresd_secure_defconfig b/configs/mx7dsabresd_secure_defconfig index cf12cef..5a6657c 100644 --- a/configs/mx7dsabresd_secure_defconfig +++ b/configs/mx7dsabresd_secure_defconfig @@ -6,6 +6,7 @@ CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/nanopi_neo_defconfig b/configs/nanopi_neo_defconfig index 5adf1ff..5164245 100644 --- a/configs/nanopi_neo_defconfig +++ b/configs/nanopi_neo_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-neo" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 6ed8ea1..d7a4d4c 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -5,6 +5,7 @@ CONFIG_IDENT_STRING=" 2Big v2" CONFIG_SYS_EXTRA_OPTIONS="NET2BIG_V2" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="2big2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 6518752..798ab77 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -5,6 +5,7 @@ CONFIG_IDENT_STRING=" NS v2 Lite" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_LITE_V2" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index e5e0fcb..3dca0ba 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -5,6 +5,7 @@ CONFIG_IDENT_STRING=" NS Max v2" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MAX_V2" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 52e991b..49654bc 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -5,6 +5,7 @@ CONFIG_IDENT_STRING=" NS v2 Mini" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MINI_V2" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 8f36a60..226f830 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -5,6 +5,7 @@ CONFIG_IDENT_STRING=" NS v2" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_V2" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 849772f..d4d78b9 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 4a62c56..1dd8466 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 68cdb89..b738812 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index a380502..1012ca2 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 3c7b903..f0f310c 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 590bb27..ac0c3d1 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index da10392..9db8b86 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_NOKIA_RX51=y CONFIG_BOOTDELAY=30 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Nokia RX-51 # " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 1ffdddc..dd6e8c4 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" +CONFIG_CONSOLE_MUX=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index eabf22a..1b67495 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5422-odroidxu3" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ODROID-XU3 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 76d0968..29f40af 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos4412-odroid" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Odroid # " CONFIG_CMD_BOOTZ=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index e101614..c749588 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_PANDORA=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Pandora # " diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index e92d9c6..3f255ea 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_ZOOM1=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index fc6dda0..760e586 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -4,6 +4,7 @@ CONFIG_OMAP44XX=y # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_OMAP4_PANDA=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 64c291b..3479b70 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP44XX=y # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_OMAP4_SDP4430=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index 2207b81..4727aca 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -8,6 +8,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_USB1_VBUS_PIN="PG13" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_lite_defconfig b/configs/orangepi_lite_defconfig index a72d506..8545835 100644 --- a/configs/orangepi_lite_defconfig +++ b/configs/orangepi_lite_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-lite" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index 5a7aba1..01b4ece 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-one" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index 3f8010c..910d68e 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_pc_plus_defconfig b/configs/orangepi_pc_plus_defconfig index f8f6dab..f43682b 100644 --- a/configs/orangepi_pc_plus_defconfig +++ b/configs/orangepi_pc_plus_defconfig @@ -8,6 +8,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_plus2e_defconfig b/configs/orangepi_plus2e_defconfig index cfae5f0..df05d37 100644 --- a/configs/orangepi_plus2e_defconfig +++ b/configs/orangepi_plus2e_defconfig @@ -9,6 +9,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus2e" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 6c99aa2..bf88fef 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -10,6 +10,7 @@ CONFIG_USB1_VBUS_PIN="PG13" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPG(11),MACPWR=SUNXI_GPD(6)" +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/origen_defconfig b/configs/origen_defconfig index d667b0f..9a09d43 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ORIGEN=y CONFIG_IDENT_STRING=" for ORIGEN" CONFIG_DEFAULT_DEVICE_TREE="exynos4210-origen" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ORIGEN # " diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index db2b6b1..a8c9239 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA210=y CONFIG_TARGET_P2371_0000=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2371-0000" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2371-0000) # " # CONFIG_CMD_IMI is not set diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 1c88af9..de5817d 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA210=y CONFIG_TARGET_P2371_2180=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2371-2180" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2371-2180) # " # CONFIG_CMD_IMI is not set diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index 1375b52..a6e80f7 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA210=y CONFIG_TARGET_P2571=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2571" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2571) # " # CONFIG_CMD_IMI is not set diff --git a/configs/p2771-0000-000_defconfig b/configs/p2771-0000-000_defconfig index 5748f94..88a5b18 100644 --- a/configs/p2771-0000-000_defconfig +++ b/configs/p2771-0000-000_defconfig @@ -3,6 +3,7 @@ CONFIG_TEGRA=y CONFIG_TEGRA186=y CONFIG_DEFAULT_DEVICE_TREE="tegra186-p2771-0000-000" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra186 (P2771-0000-000) # " # CONFIG_CMD_IMI is not set diff --git a/configs/p2771-0000-500_defconfig b/configs/p2771-0000-500_defconfig index 28160c2..1633ed2 100644 --- a/configs/p2771-0000-500_defconfig +++ b/configs/p2771-0000-500_defconfig @@ -3,6 +3,7 @@ CONFIG_TEGRA=y CONFIG_TEGRA186=y CONFIG_DEFAULT_DEVICE_TREE="tegra186-p2771-0000-500" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra186 (P2771-0000-500) # " # CONFIG_CMD_IMI is not set diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 3e69f42..8f6a959 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 6f82190..348cbd4 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881915 CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 3885adb..0d3ffaa 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_PLUTUX=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-plutux" CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Plutux) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index f9a59a60..b70263a 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_PM9261=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="pm9261> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index f9f56d2..7ffde4b 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_PM9263=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="u-boot-pm9263> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 30268e5..be3cd57 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-popmetal" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 4cf0866..3cfd87f 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -8,6 +8,7 @@ CONFIG_GENERATE_ACPI_TABLE=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index fd6afb8..2ca3f90 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -5,6 +5,7 @@ CONFIG_MAX_CPUS=2 CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index c6664b0..21a7d48 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -5,6 +5,7 @@ CONFIG_MAX_CPUS=2 CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/rainier_defconfig b/configs/rainier_defconfig index c0e647e..744ef2d 100644 --- a/configs/rainier_defconfig +++ b/configs/rainier_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/rainier_ramboot_defconfig b/configs/rainier_ramboot_defconfig index 7030fe4..8c85258 100644 --- a/configs/rainier_ramboot_defconfig +++ b/configs/rainier_ramboot_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 652b13f..e9e5191 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024,ENV_IS_IN_MMC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index 591fa35..ae391d4 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_RPI_2=y CONFIG_OF_BOARD_SETUP=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 851deaa..802ac3b 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_OF_BOARD_SETUP=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index 66fcc1b..5971877 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_OF_BOARD_SETUP=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index d912945..e863e5e 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_RPI=y CONFIG_OF_BOARD_SETUP=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index cacc443..4cbf022 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_S5PC1XX=y CONFIG_TARGET_S5P_GONI=y CONFIG_DEFAULT_DEVICE_TREE="s5pc1xx-goni" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Goni # " # CONFIG_AUTOBOOT is not set diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index 1f14566..e956e7c 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_EXYNOS=y CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_S5PC210_UNIVERSAL=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-universal_c210" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Universal # " CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 9573eff..075c8d1 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 73f13bd..0a05932 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index bff891e..3ca8fbf 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -11,6 +11,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_SERIALFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index a3ffdd3..562d21f 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index d49645e..7490332 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index db243af..00a870b 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -11,6 +11,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_SERIALFLASH" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 0bdc5aa..26a53b1 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/sequoia_defconfig b/configs/sequoia_defconfig index 9bdab0b..5304bf4 100644 --- a/configs/sequoia_defconfig +++ b/configs/sequoia_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/sequoia_ramboot_defconfig b/configs/sequoia_ramboot_defconfig index 65ae39a..2a8193d 100644 --- a/configs/sequoia_ramboot_defconfig +++ b/configs/sequoia_ramboot_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index de62cb3..4189475 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-smdk5250" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5250 # " diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 04521f2..8715ec3 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5420-smdk5420" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5420 # " diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index a44082e..02b51c4 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_SNIPER=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="sniper # " diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 751769e..5d31112 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index d871c57..c930acc 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 9d41d8c..402d9fb 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_TERASIC_DE0_NANO=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 4d5622b..cc0313c 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_IS1=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_is1" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 4fe0691..2462f66 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_DENX_MCVEVK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_mcvevk" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index e216307..7b1c476 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_TERASIC_SOCKIT=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 076d713..4a26996 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_EBV_SOCRATES=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 0db8b37..770ebcd 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_SR1500=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 0b34ed3..79b0cba 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_FIT=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 75db38f..fd79510 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 9fc169d..41eb932 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -14,6 +14,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 0871408..7e3d84f 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -2,9 +2,10 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_TBS2910=y CONFIG_PRE_CONSOLE_BUFFER=y -CONFIG_PRE_CON_BUF_ADDR=0x7c000000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_PRE_CON_BUF_ADDR=0x7c000000 +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Matrix U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 352ddb7..81ffb48 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_TEC_NG=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-tec-ng" CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (TEC-NG) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 43dc2fa..60e4a39 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -14,6 +14,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 59b73ca..e226abf 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos4412-trats2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Trats2 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 2773654..66c00a9 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_TRATS=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-trats" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Trats # " CONFIG_CMD_BOOTZ=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 08aa0e0..68adf8b 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_TRIMSLICE=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-trimslice" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (TrimSlice) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index b5debc4..02d4ca9 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA124=y CONFIG_TARGET_VENICE2=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-venice2" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Venice2) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 5a91de4..345a25b 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/whistler_defconfig b/configs/whistler_defconfig index b7f1b56..4874d5b 100644 --- a/configs/whistler_defconfig +++ b/configs/whistler_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_WHISTLER=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-whistler" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Whistler) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 674c82a..3c2f99f 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 3ec1c2a..abe38f7 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -483,9 +483,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ -#endif
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 057a3cf..86419eb 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -229,8 +229,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_NS16550_MIN_FUNCTIONS #endif
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ - #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 1c8a77b..d2bdbf1 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -409,8 +409,6 @@ combinations. this should be removed later #define CONFIG_NS16550_MIN_FUNCTIONS #endif
diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index a909611..4e621a2 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -372,8 +372,6 @@ #define CONFIG_NS16550_MIN_FUNCTIONS #endif
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index bf75209..b006e31 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -105,7 +105,6 @@ /*************************************************************** * defines if the console is stored in the environment ***************************************************************/ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* stdin, stdout and stderr are in evironment */ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index efdffc4..1a331ee 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -576,8 +576,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_NS16550_MIN_FUNCTIONS #endif
diff --git a/include/configs/PATI.h b/include/configs/PATI.h index ebabdff..c8d0a58 100644 --- a/include/configs/PATI.h +++ b/include/configs/PATI.h @@ -57,7 +57,6 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* stdin, stdout and stderr are in evironment */ #define CONFIG_PREBOOT
#define CONFIG_SYS_LONGHELP /* undef to save memory */ diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 7d08f0c..d6c38c7 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -101,7 +101,6 @@ /*************************************************************** * defines if the console is stored in the environment ***************************************************************/ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* stdin, stdout and stderr are in evironment */ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index b765fac..bb5f136 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -284,8 +284,6 @@ #define CONFIG_LOGBUFFER #define CONFIG_SYS_POST_CACHE_ADDR 0x7fff0000 /* free virtual address */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */ - #define CONFIG_SUPPORT_VFAT
/*----------------------------------------------------------------------- diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 38a457d..db76cb1 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -495,7 +495,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
/* Video */ #ifdef CONFIG_PPC_T1024 /* no DIU on T1023 */ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 29df5bd..ce04285 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -503,7 +503,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
/* Video */ #undef CONFIG_FSL_DIU_FB /* RDB doesn't support DIU */ diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 4aa2f2b..1308df3 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -406,7 +406,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
/* Video */ #define CONFIG_FSL_DIU_FB diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 6bff7cb..e68af25 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -516,9 +516,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ -#endif
#if defined(CONFIG_T1042RDB_PI) || defined(CONFIG_T1042D4RDB) /* Video */ diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 297a9ef..08482c3 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -112,7 +112,6 @@ #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif /* #ifndef CONFIG_TQM5200S */
/* Partitions */ diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index ee75785..7cc52fb 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -53,7 +53,6 @@ #define CONFIG_BOOTP_SERVERIP #define CONFIG_NET_RETRY_COUNT 3 #define CONFIG_NETCONSOLE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_MTD_PARTITIONS /* needed for UBI */ #define CONFIG_FLASH_CFI_MTD diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 14a7c9d..31dbba7 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -276,7 +276,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 1379795..6d27110 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -106,7 +106,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE 1 #define CONFIG_USB_TTY 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 /* Change these to suit your needs */ #define CONFIG_USBD_VENDORID 0x0451 #define CONFIG_USBD_PRODUCTID 0x5678 diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index d6d9838..a0e9076 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -234,7 +234,6 @@ /* check this console not needed, after test remove it */ #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 5496a9f..39d81e4 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -59,8 +59,6 @@ #define CONFIG_ATMEL_LCD_BGR555 #endif
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - /* LED */ #define CONFIG_AT91_LED #define CONFIG_RED_LED AT91_PIN_PA23 /* this is the power led */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 98a0588..7c169e9 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -66,7 +66,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK 1 #define CONFIG_ATMEL_LCD 1 #define CONFIG_ATMEL_LCD_BGR555 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* LED */ #define CONFIG_AT91_LED diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 6874608..9945bd1 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -49,7 +49,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_LCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* board specific(not enough SRAM) */ #define CONFIG_AT91SAM9G45_LCD_BASE 0x73E00000
diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 403a207..424dda6 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -48,7 +48,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index c55c965..08fd8c4 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -55,7 +55,6 @@ #define CONFIG_ATMEL_LCD_RGB565 1 /* Let board_init_f handle the framebuffer allocation */ #undef CONFIG_FB_ADDR -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* LED */ #define CONFIG_AT91_LED diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 04c41cc..c5d50e2 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -44,7 +44,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* diff --git a/include/configs/bur_cfg_common.h b/include/configs/bur_cfg_common.h index 85510f0..277f36e 100644 --- a/include/configs/bur_cfg_common.h +++ b/include/configs/bur_cfg_common.h @@ -41,7 +41,6 @@
#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_ENV_OVERWRITE /* Overwrite ethaddr / serial# */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
/* As stated above, the following choices are optional. */ diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 5ee83de..6c3d98b 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -92,7 +92,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index b0d8c5f..1e168e3 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -258,8 +258,6 @@ #define CONFIG_IMX_HDMI #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_CONSOLE_MUX #define CONFIG_VIDEO_SW_CURSOR
#define CONFIG_SPLASH_SCREEN diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 07f0c41..4ffaded 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -96,7 +96,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE #define CONFIG_USB_TTY -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* commands to include */ #define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 3f8c7be..c1d7538 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -79,7 +79,6 @@ #define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 /* UART3 */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 55d8fcf..a968b10 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -228,7 +228,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index fbe9c82..37972a8 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -340,8 +340,6 @@
#define CONFIG_SYS_EXTRA_ENV_RELOC
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - /* * Command line configuration. */ diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index fb0b277..eeb59fe 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -450,8 +450,6 @@ #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL /* _VIA_CONTROL_EP */ -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif
#ifdef CONFIG_MMC diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 1b7651f..2698a89 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -83,7 +83,6 @@ #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/dns325.h b/include/configs/dns325.h index 9b192bc..ffad976 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -77,8 +77,6 @@ /* * Console configuration */ -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* * Environment variables configurations diff --git a/include/configs/ea20.h b/include/configs/ea20.h index f49284c..6054f88 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -111,7 +111,6 @@ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CMD_BMP -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #endif
diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 809ec21..87f16d9 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -121,7 +121,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 111b23d..12ceb2c 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -42,8 +42,6 @@ /* select serial console configuration */ #define CONFIG_BAUDRATE 115200 #define EXYNOS5_DEFAULT_UART_OFFSET 0x010000 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_CONSOLE_MUX
#define CONFIG_CMD_HASH
diff --git a/include/configs/exynos7420-common.h b/include/configs/exynos7420-common.h index 475d6ca..f7c4709 100644 --- a/include/configs/exynos7420-common.h +++ b/include/configs/exynos7420-common.h @@ -53,8 +53,6 @@
/* select serial console configuration */ #define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_CONSOLE_MUX
#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 9db75f3..42116e6 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -304,7 +304,6 @@
#define CONFIG_SYS_FSL_USDHC_NUM 3
/* Framebuffer */ diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index ae6539c..c17c5e9 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -43,8 +43,6 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_CMD_ENV #define CONFIG_CMD_NAND diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 0b05876..e6df86e 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -182,11 +182,9 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_LOGO #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CMD_HDMIDETECT -#define CONFIG_CONSOLE_MUX #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP #define CONFIG_VIDEO_BMP_LOGO diff --git a/include/configs/h2200.h b/include/configs/h2200.h index 3e419c6..8e77982 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -131,7 +131,6 @@
#define CONFIG_BOOTARGS "root=/dev/ram0 ro console=ttyS0,115200n8"
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_USB_DEV_PULLUP_GPIO 33 /* USB VBUS GPIO 3 */
diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 2ae6b2d..9b4b590 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -184,7 +184,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP diff --git a/include/configs/io64.h b/include/configs/io64.h index 894da84..7f2cbd5 100644 --- a/include/configs/io64.h +++ b/include/configs/io64.h @@ -394,8 +394,6 @@ #define CONFIG_LOGBUFFER #define CONFIG_SYS_POST_CACHE_ADDR 0x00800000 /* free virtual address */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - /*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup *----------------------------------------------------------------------*/ diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 9181695..e3fbcf2 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -53,7 +53,6 @@ #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 9e73e31..43b6236 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -131,12 +131,6 @@
#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION 2
-/* - * Console - */ - -#define CONFIG_SYS_CONSOLE_IS_IN_ENV - #define CONFIG_AUTO_COMPLETE
#define CONFIG_SYS_LONGHELP diff --git a/include/configs/kilauea.h b/include/configs/kilauea.h index 227504f..9741398 100644 --- a/include/configs/kilauea.h +++ b/include/configs/kilauea.h @@ -387,8 +387,6 @@ #define CONFIG_LOGBUFFER #define CONFIG_SYS_POST_CACHE_ADDR 0x00800000 /* free virtual address */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */ - /*----------------------------------------------------------------------- * PCI stuff *----------------------------------------------------------------------*/ diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index bd6c83e..3e670e6 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -145,8 +145,6 @@ /* * Console configuration */ -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* * Environment variables configurations diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 5aa823f..000973f 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -450,7 +450,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_I2C_DVI_BUS_NUM 0 diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index a6a0173..b32809d 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -332,7 +332,6 @@ #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_FSL_DCU_SII9022A #define CONFIG_SYS_I2C_DVI_BUS_NUM 1 diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index baa35db..6084c8e 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -36,7 +36,6 @@ #define CONFIG_KIRKWOOD_GPIO
#define CONFIG_SYS_NO_FLASH -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_INFO_QUIET
/* diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 7b88ad5..d8398ee 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -255,7 +255,6 @@ /* Reserve GPT0_COMP1-COMP5 for logbuffer header */ #define CONFIG_ALT_LH_ADDR (CONFIG_SYS_PERIPHERAL_BASE + GPT0_COMP1) #define CONFIG_ALT_LB_ADDR (CONFIG_SYS_OCM_BASE) -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */
/* * I2C diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index e31fdec..1338d29 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -202,7 +202,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index b156e42..8fe5db6 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -82,7 +82,6 @@ #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 24 #define CONFIG_ATMEL_HLCD -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif
/* diff --git a/include/configs/makalu.h b/include/configs/makalu.h index dcfe3d7..dea340d 100644 --- a/include/configs/makalu.h +++ b/include/configs/makalu.h @@ -252,8 +252,6 @@ #define CONFIG_LOGBUFFER #define CONFIG_SYS_POST_CACHE_ADDR 0x00800000 /* free virtual address */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */ - /*----------------------------------------------------------------------- * PCI stuff *----------------------------------------------------------------------*/ diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 2c17ef3..b5e2d71 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -372,6 +372,5 @@ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_CMD_BMP #define CONFIG_VIDEO_OMAP3 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#endif /* __CONFIG_H */ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 2a7006f..7abffdb 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -256,8 +256,6 @@
#define CONFIG_CMDLINE_EDITING
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - /* Enable flat device tree support */ #define CONFIG_LMB 1
diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index 29564d7..5f44d5f 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -58,7 +58,6 @@ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_CMD_BMP #define CONFIG_VIDEO_OMAP3 /* DSS Support */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_EXTRA_ENV_SETTINGS CONFIG_TAM3517_SETTINGS \ "bootcmd=run net_nfs\0" diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 74df84c..60f73db 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -97,7 +97,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 92d4dff..27751a5 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -217,7 +217,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 237ef04..d48fcc2 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -38,7 +38,6 @@ #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN @@ -48,7 +47,6 @@ #define CONFIG_IMX_HDMI #define CONFIG_CMD_HDMIDETECT #define CONFIG_IMX_VIDEO_SKIP -#define CONFIG_CONSOLE_MUX
/* USB */ #define CONFIG_USB_EHCI diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 7423cff..3276940 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -212,7 +212,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 4c61999..70f2162 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -212,7 +212,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index b1d318d..bbd09de 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -232,7 +232,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 8759685..3b8f2ed 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -257,7 +257,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mxs.h b/include/configs/mxs.h index d15dd5f..634556d 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -147,7 +147,6 @@ #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif
/* MMC */ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 6ad4a3e..c66a936 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -96,7 +96,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN @@ -106,7 +105,6 @@ #define CONFIG_BMP_16BPP #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CMD_HDMIDETECT -#define CONFIG_CONSOLE_MUX #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP
diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 5f7a4ac..b2625de 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -112,7 +112,6 @@ #define CONFIG_USBD_MANUFACTURER "Nokia" #define CONFIG_USBD_PRODUCT_NAME "N900"
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_NO_FLASH
/* commands to include */ diff --git a/include/configs/novena.h b/include/configs/novena.h index 8cb0282..cba0604 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -164,14 +164,12 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP #define CONFIG_VIDEO_LOGO #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CMD_HDMIDETECT -#define CONFIG_CONSOLE_MUX #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP #endif diff --git a/include/configs/odroid.h b/include/configs/odroid.h index a28244d..704d1e7 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -44,7 +44,6 @@
/* Console configuration */ #define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run autoboot" diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 0dd63df..b2a8412 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -240,7 +240,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE #define CONFIG_USB_TTY -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* Change these to suit your needs */ #define CONFIG_USBD_VENDORID 0x0451 diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 31972bd..30d3aa8 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -59,7 +59,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE 1 #define CONFIG_USB_TTY 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* Change these to suit your needs */ #define CONFIG_USBD_VENDORID 0x0451 diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 4a9f6b7..ba7d3cd 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -23,7 +23,6 @@
#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 #define CONFIG_SYS_DEVICE_NULLDEV 1
/* diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 0f28278..aa27a9e 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -48,7 +48,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE 1 #define CONFIG_USB_TTY 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 /* Change these to suit your needs */ #define CONFIG_USBD_VENDORID 0x0451 #define CONFIG_USBD_PRODUCTID 0x5678 diff --git a/include/configs/origen.h b/include/configs/origen.h index 0f76d32..a075b54 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -38,7 +38,6 @@
/* Console configuration */ #define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 76c7397..63fe444 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -52,7 +52,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_LCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* board specific(not enough SRAM) */ #define CONFIG_AT91SAM9G45_LCD_BASE 0x23E00000
diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 6ac42b8..4793b13 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -158,7 +158,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK 1 #define CONFIG_ATMEL_LCD 1 #define CONFIG_ATMEL_LCD_BGR555 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* LED */ #define CONFIG_AT91_LED diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index f112c36..db38b73 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -171,7 +171,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK 1 #define CONFIG_ATMEL_LCD 1 #define CONFIG_ATMEL_LCD_BGR555 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
#define CONFIG_LCD_IN_PSRAM 1
diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 55c213e..cf6f355 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -38,11 +38,6 @@ #define CONFIG_SPL_STACK 0xff718000 #define CONFIG_SPL_TEXT_BASE 0xff704004
-#ifndef CONFIG_SPL_BUILD -# define CONFIG_SYS_CONSOLE_IS_IN_ENV -# define CONFIG_CONSOLE_MUX -#endif - /* MMC/SD IP block */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 8d4ad5d..decf35a 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -130,8 +130,6 @@ #define CONFIG_FAT_WRITE #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_SYS_LOAD_ADDR 0x1000000 -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_PREBOOT "usb start"
/* Shell */ diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index f2aab35..124cca3 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -133,7 +133,6 @@ #define CONFIG_MISC_INIT_R
#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 9915306..e2d814f 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -30,7 +30,6 @@
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run mmcboot" diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index e684d2a..c20d6f9 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif
#ifdef CONFIG_SYS_USE_MMC diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 8b73a1b..c149e5b 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -48,7 +48,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* board specific (not enough SRAM) */ #define CONFIG_SAMA5D3_LCD_BASE 0x23E00000 diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index c90e1e6..0890cf5 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -104,7 +104,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif
#ifdef CONFIG_SYS_USE_SERIALFLASH diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index b9927e9..36da48c 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -103,7 +103,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#ifdef CONFIG_SYS_USE_SERIALFLASH /* override the bootcmd, bootargs and other configuration for spi flash env*/ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index bd005fc..b6533c3 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -149,8 +149,6 @@ /* LCD and keyboard require SDL support */ #ifdef CONFIG_SANDBOX_SDL #define CONFIG_CMD_BMP -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define LCD_BPP LCD_COLOR16 #define CONFIG_LCD_BMP_RLE8 #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index ac783d3..1afe374 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -266,8 +266,6 @@ #define CONFIG_LOGBUFFER #define CONFIG_SYS_POST_CACHE_ADDR 0x7fff0000 /* free virtual address */
/* diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index 4a623f7..c76c55f 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -77,8 +77,6 @@
/* LCD */ #define CONFIG_ATMEL_LCD -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_GURNARD_SPLASH
#define CONFIG_ATMEL_SPI diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 0e9a4cc..7fada3f 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -142,12 +142,6 @@ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
#define CONFIG_SYS_LONGHELP diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index efd2968..9bb2227 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -251,7 +251,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); /* * U-Boot environment */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_SYS_CONSOLE_ENV_OVERWRITE #if !defined(CONFIG_ENV_SIZE) diff --git a/include/configs/socrates.h b/include/configs/socrates.h index dc6878c..5b9d741 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -178,7 +178,6 @@ #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 634a4c7..8e10d84 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -296,7 +296,6 @@ extern int soft_i2c_gpio_scl; #define VIDEO_LINE_LEN (pGD->plnSizeX)
/* allow both serial and cfb console. */ -#define CONFIG_CONSOLE_MUX /* stop x86 thinking in cfbconsole from trying to init a pc keyboard */ #define CONFIG_VGA_AS_SINGLE_DEVICE
@@ -350,7 +349,6 @@ extern int soft_i2c_gpio_scl; #endif
#ifdef CONFIG_USB_KEYBOARD -#define CONFIG_CONSOLE_MUX #define CONFIG_PREBOOT #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE @@ -364,7 +362,6 @@ extern int soft_i2c_gpio_scl; #endif
#define CONFIG_MISC_INIT_R -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h> diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 90e4982..8326ceb 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -46,8 +46,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE /* select UART1/UART2 */ #define CONFIG_BAUDRATE 115200
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_CONSOLE_MUX #define CONFIG_CONS_INDEX 1
/* *** Command definition *** */ diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index e3b2490..3590be4 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -60,8 +60,6 @@
-#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #ifndef CONFIG_SPL_BUILD #define CONFIG_SYS_STDIO_DEREGISTER #endif diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index f0aea2c..3d2992f 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -73,7 +73,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE 1 #define CONFIG_USB_TTY 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* * Environment setup diff --git a/include/configs/trats.h b/include/configs/trats.h index 22b0c90..9fc6513 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -42,7 +42,6 @@
/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ #define MACH_TYPE_TRATS 3928 diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 1febaae..c437c13 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -39,7 +39,6 @@
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run autoboot" diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 999ee6d..df94389 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -78,7 +78,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index a286f05..d483232 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -61,8 +61,6 @@ 9600, 19200, 38400, 115200} #define CONFIG_SYS_NS16550_PORT_MAPPED
-#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_STDIO_DEREGISTER
#define CONFIG_CMDLINE_EDITING diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 64f21f1..cb8a067 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -677,7 +677,6 @@ CONFIG_CONSOLE CONFIG_CONSOLE_DEV CONFIG_CONSOLE_EXTRA_INFO CONFIG_CONSOLE_INFO_QUIET -CONFIG_CONSOLE_MUX CONFIG_CONSOLE_SCROLL_LINES CONFIG_CONS_EXTC_PINSEL CONFIG_CONS_EXTC_RATE @@ -4610,7 +4609,6 @@ CONFIG_SYS_CONSOLE_BG_COL CONFIG_SYS_CONSOLE_ENV_OVERWRITE CONFIG_SYS_CONSOLE_FG_COL CONFIG_SYS_CONSOLE_INFO_QUIET -CONFIG_SYS_CONSOLE_IS_IN_ENV CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_CORE_SRAM CONFIG_SYS_CORE_SRAM_SIZE
On Mon, Oct 17, 2016 at 08:12:37PM -0600, Simon Glass wrote:
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_IS_IN_ENV CONFIG_CONSOLE_MUX
Signed-off-by: Simon Glass sjg@chromium.org
This is not really a config. Rename it to avoid confusion.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v4: None Changes in v3: None Changes in v2: None
include/configs/MPC8349ITX.h | 6 +++--- scripts/config_whitelist.txt | 1 - 2 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index c2f79a3..9e061bc 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -356,7 +356,7 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200}
-#define CONFIG_CONSOLE ttyS0 +#define CONSOLE ttyS0 #define CONFIG_BAUDRATE 115200
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x4500) @@ -738,10 +738,10 @@ boards, we say we have two, but don't display a message if we find only one. */ __stringify(CONFIG_GATEWAYIP) ":" \ __stringify(CONFIG_NETMASK) ":" \ CONFIG_HOSTNAME ":" CONFIG_NETDEV ":off" \ - " console=" __stringify(CONFIG_CONSOLE) "," __stringify(CONFIG_BAUDRATE) + " console=" __stringify(CONSOLE) "," __stringify(CONFIG_BAUDRATE)
#define CONFIG_EXTRA_ENV_SETTINGS \ - "console=" __stringify(CONFIG_CONSOLE) "\0" \ + "console=" __stringify(CONSOLE) "\0" \ "netdev=" CONFIG_NETDEV "\0" \ "uboot=" CONFIG_UBOOTPATH "\0" \ "tftpflash=tftpboot $loadaddr $uboot; " \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index cb8a067..dd03e21 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -673,7 +673,6 @@ CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_UBI CONFIG_COMPACT_FLASH CONFIG_COMPAT -CONFIG_CONSOLE CONFIG_CONSOLE_DEV CONFIG_CONSOLE_EXTRA_INFO CONFIG_CONSOLE_INFO_QUIET
Reviewed-by: Jagan Teki jteki@openedev.com
thanks!
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Jagan Teki jteki@openedev.com
include/configs/advantech_dms-ba16.h | 4 ++-- include/configs/aristainetos-common.h | 2 +- include/configs/aristainetos.h | 2 +- include/configs/aristainetos2.h | 2 +- include/configs/aristainetos2b.h | 2 +- include/configs/cgtqmx6eval.h | 4 ++-- include/configs/el6x_common.h | 2 +- include/configs/embestmx6boards.h | 2 +- include/configs/ge_bx50v3.h | 4 ++-- include/configs/mx6cuboxi.h | 4 ++-- include/configs/mx6qsabreauto.h | 2 +- include/configs/mx6sabre_common.h | 2 +- include/configs/mx6sabresd.h | 2 +- include/configs/o2dnt-common.h | 6 +++--- include/configs/pcm058.h | 2 +- include/configs/tqma6.h | 2 +- include/configs/tqma6_mba6.h | 2 +- include/configs/tqma6_wru4.h | 2 +- include/configs/zc5202.h | 2 +- include/configs/zc5601.h | 2 +- scripts/config_whitelist.txt | 1 - 21 files changed, 26 insertions(+), 27 deletions(-)
diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 31dbba7..d5b7348 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -16,7 +16,7 @@ #define CONFIG_DEFAULT_FDT_FILE "imx6q-dms-ba16.dtb"
#define CONFIG_MXC_UART_BASE UART4_BASE -#define CONFIG_CONSOLE_DEV "ttymxc3" +#define CONSOLE_DEV "ttymxc3" #define CONFIG_EXTRA_BOOTARGS "panic=10"
#define CONFIG_BOOT_DIR "" @@ -114,7 +114,7 @@ "fdt_addr=0x18000000\0" \ "boot_fdt=yes\0" \ "ip_dyn=yes\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "sddev=0\0" \ diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index a0e9076..3401f66 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -57,7 +57,7 @@ "rescue_sys_length=f10000\0" \ "panel=lb07wv8\0" \ "splashpos=m,m\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ diff --git a/include/configs/aristainetos.h b/include/configs/aristainetos.h index be93deb..1799cc1 100644 --- a/include/configs/aristainetos.h +++ b/include/configs/aristainetos.h @@ -18,7 +18,7 @@ #define CONFIG_BOARDNAME "aristainetos"
#define CONFIG_MXC_UART_BASE UART5_BASE -#define CONFIG_CONSOLE_DEV "ttymxc4" +#define CONSOLE_DEV "ttymxc4"
#define CONFIG_FEC_XCV_TYPE RMII
diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h index 152f5e9..8fa3eb5 100644 --- a/include/configs/aristainetos2.h +++ b/include/configs/aristainetos2.h @@ -19,7 +19,7 @@ #define CONFIG_BOARD_LATE_INIT
#define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONSOLE_DEV "ttymxc1"
#define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_PHY_MICREL_KSZ9031 diff --git a/include/configs/aristainetos2b.h b/include/configs/aristainetos2b.h index 78791db..df9b5c9 100644 --- a/include/configs/aristainetos2b.h +++ b/include/configs/aristainetos2b.h @@ -19,7 +19,7 @@ #define CONFIG_BOARD_LATE_INIT
#define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_PHY_MICREL_KSZ9031 diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 6c3d98b..8090200 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -128,7 +128,7 @@ /* Command definition */
#define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONSOLE_DEV "ttymxc1" #define CONFIG_MMCROOT "/dev/mmcblk0p2" #define CONFIG_SYS_MMC_ENV_DEV 0
@@ -140,7 +140,7 @@ "fdt_addr_r=0x18000000\0" \ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "dfuspi=dfu 0 sf 0:0:10000000:0\0" \ "dfu_alt_info_spl=spl raw 0x400\0" \ "dfu_alt_info_img=u-boot raw 0x10000\0" \ diff --git a/include/configs/el6x_common.h b/include/configs/el6x_common.h index 81b79b2..7e9bcb1 100644 --- a/include/configs/el6x_common.h +++ b/include/configs/el6x_common.h @@ -73,7 +73,7 @@ "board="__stringify(CONFIG_BOARD_NAME)"\0" \ "cma_size="__stringify(EL6Q_CMA_SIZE)"\0" \ "chp_size="__stringify(EL6Q_COHERENT_POOL_SIZE)"\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "fdtfile=undefined\0" \ "fdt_high=0xffffffff\0" \ "fdt_addr_r=0x18000000\0" \ diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 87f16d9..6266d95 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -14,7 +14,7 @@ #define __RIOTBOARD_CONFIG_H
#define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONSOLE_DEV "ttymxc1" #define CONFIG_MMCROOT "/dev/mmcblk1p2"
#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024) diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 42116e6..d2568df 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -34,7 +34,7 @@ #endif
#define CONFIG_MXC_UART_BASE UART3_BASE -#define CONFIG_CONSOLE_DEV "ttymxc2" +#define CONSOLE_DEV "ttymxc2"
#define CONFIG_SUPPORT_EMMC_BOOT
@@ -140,7 +140,7 @@ "fdt_addr=0x18000000\0" \ "boot_fdt=yes\0" \ "ip_dyn=yes\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "sddev=0\0" \ diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index d48fcc2..6e4a4f8 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -72,7 +72,7 @@ /* Command definition */
#define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_CONSOLE_DEV "ttymxc0" +#define CONSOLE_DEV "ttymxc0" #define CONFIG_SYS_FSL_USDHC_NUM 1 #define CONFIG_SYS_MMC_ENV_DEV 0 /* SDHC2 */
@@ -90,7 +90,7 @@ "initrd_high=0xffffffff\0" \ "fdt_high=0xffffffff\0" \ "ip_dyn=yes\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "bootm_size=0x10000000\0" \ "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ "update_sd_firmware=" \ diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index 9cf3c2c..f849f34 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -11,7 +11,7 @@
#define CONFIG_MACH_TYPE 3529 #define CONFIG_MXC_UART_BASE UART4_BASE -#define CONFIG_CONSOLE_DEV "ttymxc3" +#define CONSOLE_DEV "ttymxc3" #define CONFIG_MMCROOT "/dev/mmcblk0p2"
/* USB Configs */ diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 3276940..32ebb51 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -74,7 +74,7 @@ "fdt_addr=0x18000000\0" \ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "dfuspi=dfu 0 sf 0:0:10000000:0\0" \ "dfu_alt_info_spl=spl raw 0x400\0" \ "dfu_alt_info_img=u-boot raw 0x10000\0" \ diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 5c2734d..789c407 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -15,7 +15,7 @@
#define CONFIG_MACH_TYPE 3980 #define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_CONSOLE_DEV "ttymxc0" +#define CONSOLE_DEV "ttymxc0" #define CONFIG_MMCROOT "/dev/mmcblk1p2"
#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ diff --git a/include/configs/o2dnt-common.h b/include/configs/o2dnt-common.h index 4d79165..f927107 100644 --- a/include/configs/o2dnt-common.h +++ b/include/configs/o2dnt-common.h @@ -94,8 +94,8 @@
#undef CONFIG_BOOTARGS
-#if !defined(CONFIG_CONSOLE_DEV) -#define CONFIG_CONSOLE_DEV "ttyPSC1" +#if !defined(CONSOLE_DEV) +#define CONSOLE_DEV "ttyPSC1" #endif
/* @@ -130,7 +130,7 @@ "addmem=setenv bootargs ${bootargs} ${memlimit}\0" \ "addmisc=sete bootargs ${bootargs} ${miscargs}\0" \ "addtty=sete bootargs ${bootargs} console=" \ - CONFIG_CONSOLE_DEV ",${baudrate}\0" \ + CONSOLE_DEV ",${baudrate}\0" \ "bootfile="CONFIG_BOARD_NAME"/uImage_"CONFIG_BOARD_NAME"_act\0" \ "kernel_addr_r=600000\0" \ "initrd_high=0x03e00000\0" \ diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index c36245b..2869c4e 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -24,7 +24,7 @@ /* Serial */ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONSOLE_DEV "ttymxc1"
diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 029eddd..983153f 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -295,7 +295,7 @@ "uboot=u-boot.imx\0" \ "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr="__stringify(TQMA6_FDT_ADDRESS)"\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "addtty=setenv bootargs ${bootargs} console=${console},${baudrate}\0" \ diff --git a/include/configs/tqma6_mba6.h b/include/configs/tqma6_mba6.h index 2f52598..3cae4fe 100644 --- a/include/configs/tqma6_mba6.h +++ b/include/configs/tqma6_mba6.h @@ -25,6 +25,6 @@ #define CONFIG_PHY_KSZ9031
#endif /* __CONFIG_TQMA6_MBA6_H */ diff --git a/include/configs/tqma6_wru4.h b/include/configs/tqma6_wru4.h index 8896bc3..3e88391 100644 --- a/include/configs/tqma6_wru4.h +++ b/include/configs/tqma6_wru4.h @@ -21,7 +21,7 @@
/* UART */ #define CONFIG_MXC_UART_BASE UART4_BASE -#define CONFIG_CONSOLE_DEV "ttymxc3" +#define CONSOLE_DEV "ttymxc3"
diff --git a/include/configs/zc5202.h b/include/configs/zc5202.h index 073a42c..8e75c40 100644 --- a/include/configs/zc5202.h +++ b/include/configs/zc5202.h @@ -10,7 +10,7 @@ #define __EL_ZC5202_H
#define CONFIG_DEFAULT_FDT_FILE "imx6q-zc5202.dtb" diff --git a/include/configs/zc5601.h b/include/configs/zc5601.h index 28b9c6b..6ede668 100644 --- a/include/configs/zc5601.h +++ b/include/configs/zc5601.h @@ -11,7 +11,7 @@
#define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONSOLE_DEV "ttymxc1" #define CONFIG_MMCROOT "/dev/mmcblk0p1"
#define CONFIG_DEFAULT_FDT_FILE "imx6q-zc5601.dtb" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index dd03e21..473889b 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -673,7 +673,6 @@ CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_UBI CONFIG_COMPACT_FLASH CONFIG_COMPAT -CONFIG_CONSOLE_DEV CONFIG_CONSOLE_EXTRA_INFO CONFIG_CONSOLE_INFO_QUIET CONFIG_CONSOLE_SCROLL_LINES
thanks!
This converts the following to Kconfig: CONFIG_VIDEO
README | 5 ----- configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8544DS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + configs/MiniFAP_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/TQM5200_B_HIGHBOOT_defconfig | 1 + configs/TQM5200_B_defconfig | 1 + configs/TQM5200_STK100_defconfig | 1 + configs/TQM5200_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/charon_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/cm-bf548_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/digsy_mtc_RAMBOOT_defconfig | 1 + configs/digsy_mtc_defconfig | 1 + configs/digsy_mtc_rev5_RAMBOOT_defconfig | 1 + configs/digsy_mtc_rev5_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/ea20_defconfig | 1 + configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + configs/fo300_defconfig | 1 + configs/gwventana_defconfig | 1 + configs/icon_defconfig | 1 + configs/imx31_phycore_eet_defconfig | 1 + configs/ipek01_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mcx_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlsabreauto_defconfig | 1 + configs/mx6dlsabresd_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 1 + configs/mx6qsabreauto_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6qsabresd_defconfig | 1 + configs/mx6sabresd_spl_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/mx7dsabresd_defconfig | 1 + configs/mx7dsabresd_secure_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/novena_defconfig | 1 + configs/pdm360ng_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/rut_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/socrates_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/theadorable_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/xfi3_defconfig | 1 + drivers/video/Kconfig | 9 +++++++++ include/configs/MIP405.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1022DS.h | 2 -- include/configs/PIP405.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/TQM5200.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/aria.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/bf527-ezkit.h | 3 --- include/configs/bf533-stamp.h | 1 - include/configs/bf548-ezkit.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm-bf548.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/digsy_mtc.h | 1 - include/configs/ea20.h | 1 - include/configs/eb_cpu5282.h | 2 -- include/configs/embestmx6boards.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/icon.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/ipek01.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m28evk.h | 1 - include/configs/m53evk.h | 1 - include/configs/mcx.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/mt_ventoux.h | 1 - include/configs/mx23evk.h | 2 -- include/configs/mx28evk.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/nokia_rx51.h | 1 - include/configs/novena.h | 1 - include/configs/pdm360ng.h | 1 - include/configs/pxm2.h | 1 - include/configs/rut.h | 1 - include/configs/sansa_fuze_plus.h | 2 -- include/configs/sequoia.h | 1 - include/configs/socrates.h | 1 - include/configs/tbs2910.h | 1 - include/configs/theadorable.h | 1 - include/configs/wandboard.h | 1 - include/configs/xfi3.h | 2 -- 202 files changed, 147 insertions(+), 74 deletions(-)
diff --git a/README b/README index fff5772..e1ac6e3 100644 --- a/README +++ b/README @@ -1662,11 +1662,6 @@ CBFS (Coreboot Filesystem) support instead.
- Video support: - CONFIG_VIDEO - - Define this to enable video support (for output to - video). - CONFIG_VIDEO_CT69000
Enable Chips & Technologies 69000 Video chip diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 6f144a4..c977887 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING="\n(c) 2003 by MPL AG Switzerland, MEV-10082-001 released" +CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_MIP405T=y CONFIG_BOOTDELAY=5 diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 66590b1..b5542fe 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING="\n(c) 2003 by MPL AG Switzerland, MEV-10072-001 released" +CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_MIP405=y CONFIG_BOOTDELAY=5 diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index 27d5826..e6a73ab 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8536DS=y CONFIG_PHYS_64BIT=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index eaeacca..78b11d6 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index 525ccad..f161b61 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index 0ff061b..aebf39d 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index 13bbe84..d337b7a 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8544DS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index ec57018..1f17fa0 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8572DS=y CONFIG_PHYS_64BIT=y diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index 0639b4f..0b744df 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8572DS=y CONFIG_FIT=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 10607e8..2c03ba2 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC86xx=y CONFIG_TARGET_MPC8610HPCD=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index 2292360..0c3d60b 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC86xx=y CONFIG_TARGET_MPC8641HPCN=y CONFIG_PHYS_64BIT=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index d8f74b3..d2250ec 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC86xx=y CONFIG_TARGET_MPC8641HPCN=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index aec6b9a..31602ab 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index f7bdf5a..052f354 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING="\n(c) 2002 by MPL AG Switzerland, MEV-10066-001 released" +CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_PIP405=y CONFIG_BOOTDELAY=5 diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index 93637e4..c46576d 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index ac419b4..7c1a07a 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index 6ed4e9e..4069fa6 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index 243b2b1..901668d 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index e3a249f..c38aa6b 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 8a8b854..8b8dddd 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index b5c6c1e..fac904e 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 8526426..7e336e7 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T1040QDS=y CONFIG_FIT=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index 6dee606..65fa78b 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T1040QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 716490b..8fbb287 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T1040QDS=y CONFIG_FIT=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index ce34ec1..e40fe49 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 63e88df..2665b05 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index 9035ab9..1d2548b 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index b26304c..611881f 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index ff39f15..7f172cd 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index 3e4e9e2..c80db93 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 5fd9c1e..cebe3c9 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 95a4c8a..433c856 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index f05e33c..6c3ba81 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index 07faad5..8932572 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index 353fdc1..cdba626 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index ec3655d..ddd356b 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 823e2ae..541a37a 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index c47ff76..1d31439 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 2f1e4da..b7443d9 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS2=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 708bc24..d365606 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS2B=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index de00afd..a1d2c4e 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" CONFIG_BOOTDELAY=3 diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 1c3625f..426efc8 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="bayleybay" CONFIG_TARGET_BAYLEYBAY=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index f1ee51d..85080b6 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/charon_defconfig b/configs/charon_defconfig index 8517f2b..a7e60b7 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_CHARON=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 2e5cbf4..bf630d6 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -1,5 +1,6 @@ CONFIG_X86=y CONFIG_SYS_MALLOC_F_LEN=0x1800 +CONFIG_VIDEO=y CONFIG_VENDOR_GOOGLE=y CONFIG_DEFAULT_DEVICE_TREE="chromebook_link" CONFIG_TARGET_CHROMEBOOK_LINK=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 1ae6102..919bc7b 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_GOOGLE=y CONFIG_DEFAULT_DEVICE_TREE="chromebox_panther" CONFIG_TARGET_CHROMEBOX_PANTHER=y diff --git a/configs/cm-bf548_defconfig b/configs/cm-bf548_defconfig index bcf6d8f..f749392 100644 --- a/configs/cm-bf548_defconfig +++ b/configs/cm-bf548_defconfig @@ -1,4 +1,5 @@ CONFIG_BLACKFIN=y +# CONFIG_VIDEO is not set CONFIG_TARGET_CM_BF548=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 693ccad..25e399b 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL,SPL" CONFIG_BOOTDELAY=3 diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 8fe1e04..52abd7b 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_COLIBRI_IMX7=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_DEFAULT_DEVICE_TREE="imx7-colibri" +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_imx7/imximage.cfg,MX7D" CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 9af9774..d5c6ca3 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_CONGATEC=y CONFIG_TARGET_CONGA_QEVAL20_QA3_E3845=y CONFIG_DEFAULT_DEVICE_TREE="conga-qeval20-qa3-e3845" diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 077630e..38efbbe 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_CONGATEC=y CONFIG_TARGET_CONGA_QEVAL20_QA3_E3845=y CONFIG_DEFAULT_DEVICE_TREE="conga-qeval20-qa3-e3845" diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index e73cc76..0714eef 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" controlcenterd 0.01" +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_CONTROLCENTERD=y CONFIG_PHYS_64BIT=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index c3c60d8..c5cdf79 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" controlcenterd 0.01" +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_CONTROLCENTERD=y CONFIG_PHYS_64BIT=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index c9ce633..67febaa 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_COREBOOT=y CONFIG_TARGET_COREBOOT=y CONFIG_FIT=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 137975c..4ccffe1 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="crownbay" CONFIG_TARGET_CROWNBAY=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 585d48c..3b498c6 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_DFI=y CONFIG_DEFAULT_DEVICE_TREE="dfi-bt700-q7x-151" CONFIG_TARGET_DFI_BT700=y diff --git a/configs/digsy_mtc_RAMBOOT_defconfig b/configs/digsy_mtc_RAMBOOT_defconfig index 2494412..695f5bb 100644 --- a/configs/digsy_mtc_RAMBOOT_defconfig +++ b/configs/digsy_mtc_RAMBOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/digsy_mtc_defconfig b/configs/digsy_mtc_defconfig index 1f4c15c..2fae7a4 100644 --- a/configs/digsy_mtc_defconfig +++ b/configs/digsy_mtc_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/digsy_mtc_rev5_RAMBOOT_defconfig b/configs/digsy_mtc_rev5_RAMBOOT_defconfig index 8d77864..a0541d1 100644 --- a/configs/digsy_mtc_rev5_RAMBOOT_defconfig +++ b/configs/digsy_mtc_rev5_RAMBOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/digsy_mtc_rev5_defconfig b/configs/digsy_mtc_rev5_defconfig index 56e14e1..c66328d 100644 --- a/configs/digsy_mtc_rev5_defconfig +++ b/configs/digsy_mtc_rev5_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index 5042a82..f0dcb1d 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_SYS_DDR_1G=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index da741b4..468b3a7 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 8d4b5b4..ba922ed 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_EA20=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index 60eab39..bbcce82 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -1,4 +1,5 @@ CONFIG_M68K=y +CONFIG_VIDEO=y CONFIG_TARGET_EB_CPU5282=y CONFIG_SYS_TEXT_BASE=0xFF000000 CONFIG_SYS_EXTRA_OPTIONS="SYS_MONITOR_BASE=0xFF000400" diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index 1b1702e..7e865d8 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -1,4 +1,5 @@ CONFIG_M68K=y +CONFIG_VIDEO=y CONFIG_TARGET_EB_CPU5282=y CONFIG_SYS_TEXT_BASE=0xF0000000 CONFIG_SYS_EXTRA_OPTIONS="SYS_MONITOR_BASE=0xF0000418" diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index eda7a14..49fb0dc 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index 7107e38..759443b 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SPL_STACK_R_ADDR=0x18000000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/icon_defconfig b/configs/icon_defconfig index cc08b5a..78a9a76 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_ICON=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/imx31_phycore_eet_defconfig b/configs/imx31_phycore_eet_defconfig index a210abb..b43c81d 100644 --- a/configs/imx31_phycore_eet_defconfig +++ b/configs/imx31_phycore_eet_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_IMX31_PHYCORE=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX31_PHYCORE_EET" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/ipek01_defconfig b/configs/ipek01_defconfig index 0042d3f..ee36fab 100644 --- a/configs/ipek01_defconfig +++ b/configs/ipek01_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_IPEK01=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index d44ebaa..f601f2d 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 1f4bd95..a4b531c 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 989a9f1..5d4e148 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 3591967..0c82857 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 9cda390..87af2c6 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 15766bd..4361f26 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 77a8e6f..439b398 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index c265b3e..c4590fb 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 8721ae4..68aab09 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index fdbcbf0..8d2124f 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_VIDEO=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index dce1592..b076675 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index cd37246..7c9d4ef 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-lpuart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 07f7023..430fb5c 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index ab1a558..3685a54 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 52dc6f0..f7b4984 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 6e7289e..25f6741 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index 609a218..a2259b4 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" - v2.0" +CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_LWMON5=y CONFIG_FIT=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index efc5561..ff36e04 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index bce58ff..aca7bc6 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/denx/m53evk/imximage.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index a31d213..bc76dfd 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,ENV_IS_IN_SPI_FLASH" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index f9510a8..18a9915 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_GPIO_SUPPORT is not set # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_MCX=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index a280432..0825bc6 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="minnowmax" CONFIG_TARGET_MINNOWMAX=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index 1c9d1b0..4772a8c 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_MT_VENTOUX=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index a7808f1..b6e308e 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 81f99d9..bf10c7f 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index d00bb42..273e41c 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 39cf012..74f394bc 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_NAND" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index ed89714..3101fee 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index d68d001..02cbf57 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_MX51EVK=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index 232677d..21573e1 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_MX53LOCO=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53loco/imximage.cfg" CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 6edc8b7..59ae1a1 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index be8739f..68c1a6b 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index f6c702a..1dbfe53 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index d46cca1..1445b75 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index 7de4166..004206b 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 7e592c5..3dab823 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index b502299..0f3cc7a 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index 9cfeae9..6d58495 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 96209e5..22993ca 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABRESD=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 8fdd0cf..42d920a 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index f878970..9a29ff6 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 4b5b41a..8c5a0f3 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index e7a72fe..a09fb3b 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MX7DSABRESD=y # CONFIG_ARMV7_VIRT is not set CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx7dsabresd_secure_defconfig b/configs/mx7dsabresd_secure_defconfig index 5a6657c..7d85381 100644 --- a/configs/mx7dsabresd_secure_defconfig +++ b/configs/mx7dsabresd_secure_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MX7DSABRESD=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index d4d78b9..d1be7b5 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 1dd8466..6212755 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index b738812..d05608e 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 1012ca2..452a16c 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index f0f310c..158df5d 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index ac0c3d1..fb8fa4c 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 9db8b86..43f0552 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_NOKIA_RX51=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=30 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index dd6e8c4..f0116f8 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_CONSOLE_MUX=y diff --git a/configs/pdm360ng_defconfig b/configs/pdm360ng_defconfig index 8225506..1d87091 100644 --- a/configs/pdm360ng_defconfig +++ b/configs/pdm360ng_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC512X=y CONFIG_TARGET_PDM360NG=y CONFIG_FIT=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 602fc9f..ffdfcfe 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="am335x-pxm50" CONFIG_FIT=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 3cfd87f..da1b00a 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" CONFIG_SMP=y CONFIG_MAX_CPUS=2 diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 2ca3f90..8ec6c91 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" CONFIG_SMP=y CONFIG_MAX_CPUS=2 diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 21a7d48..3fd9b1d 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" CONFIG_SMP=y CONFIG_MAX_CPUS=2 diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index e9e5191..9ad02e4 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024,ENV_IS_IN_MMC" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 99b732c..a6a4bb9 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="am335x-rut" CONFIG_FIT=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 26a53b1..7d31ed2 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index fd79510..372918f 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_SOCRATES=y CONFIG_FIT=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 41eb932..c4408cf 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_ADVANTECH=y CONFIG_TARGET_SOM_DB5800_SOM_6867=y CONFIG_DEFAULT_DEVICE_TREE="baytrail_som-db5800-som-6867" diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 7e3d84f..0194c0c 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_TBS2910=y CONFIG_PRE_CONSOLE_BUFFER=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_PRE_CON_BUF_ADDR=0x7c000000 diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 60e4a39..50bc016 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_DFI=y CONFIG_DEFAULT_DEVICE_TREE="theadorable-x86-dfi-bt700" CONFIG_TARGET_DFI_BT700=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index ef04911..7e89afc 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index fd569e5..e64a605 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 345a25b..329d5e4 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 3c2f99f..8af69d2 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 86db0da..866fafd 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -434,4 +434,13 @@ config VIDEO_TEGRA124
source "drivers/video/bridge/Kconfig"
+config VIDEO + bool "Enable legacy video support" + depends on !DM_VIDEO + help + Define this for video support, without using driver model. Some + drivers use this because they are not yet converted to driver + model. Video drivers typically provide a colour text console and + cursor. + endmenu diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index b006e31..e9101a0 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -342,7 +342,6 @@ /************************************************************ * Video support ************************************************************/ -#define CONFIG_VIDEO /*To enable video controller support */ #define CONFIG_VIDEO_CT69000 #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 2fe8483..3d753ad 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -503,7 +503,6 @@ /*#define VIDEO_IO_OFFSET CONFIG_SYS_PCI1_IO_VIRT*/
/* video */ -#define CONFIG_VIDEO
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index c8fec70..332d4bc 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -275,7 +275,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /*#define VIDEO_IO_OFFSET CONFIG_SYS_PCI1_IO_VIRT*/
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index e4d55d0..6ec2efa 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -462,7 +462,6 @@ #define VIDEO_IO_OFFSET CONFIG_SYS_PCIE1_IO_VIRT
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 26f8d91..046f2e0 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -23,7 +23,6 @@
#ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x2c000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index bcbccd8..f2ecd83 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -375,7 +375,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /*#define VIDEO_IO_OFFSET CONFIG_SYS_PCIE1_IO_VIRT*/
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 9820eca..e939dcb 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -378,7 +378,6 @@
#ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR @@ -398,7 +397,6 @@
#ifdef CONFIG_ATI #define VIDEO_IO_OFFSET CONFIG_SYS_PCIE1_IO_VIRT -#define CONFIG_VIDEO #define CONFIG_BIOSEMU #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index d6c38c7..8649cdb 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -302,7 +302,6 @@ /************************************************************ * Video support ************************************************************/ -#define CONFIG_VIDEO /*To enable video controller support */ #define CONFIG_VIDEO_CT69000 #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index db76cb1..80d893d 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -502,7 +502,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_FSL_DIU_FB #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index ce04285..5df1853 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -508,7 +508,6 @@ unsigned long get_board_ddr_clk(void); #undef CONFIG_FSL_DIU_FB /* RDB doesn't support DIU */ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 1308df3..51ff392 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -412,7 +412,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_FSL_DIU_FB #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index e68af25..87e6333 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -524,7 +524,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #ifdef CONFIG_FSL_DIU_FB #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_CFB_CONSOLE_ANSI diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 08482c3..9c466d9 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -97,7 +97,6 @@ * Video console */ #ifndef CONFIG_TQM5200S /* No graphics controller on TQM5200S */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_SM501 #define CONFIG_VIDEO_SM501_32BPP #define CONFIG_CFB_CONSOLE diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index d5b7348..025e1d3 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -272,7 +272,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 3
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/aria.h b/include/configs/aria.h index 278676e..97e6fee 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -37,7 +37,6 @@ #define CONFIG_SYS_TEXT_BASE 0xFFF00000
/* video */ -#undef CONFIG_VIDEO
#if defined(CONFIG_VIDEO) #define CONFIG_CFB_CONSOLE diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 3401f66..60f2bac 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -229,7 +229,6 @@ #define CONFIG_IMX_WATCHDOG
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 /* check this console not needed, after test remove it */ #define CONFIG_CFB_CONSOLE diff --git a/include/configs/bf527-ezkit.h b/include/configs/bf527-ezkit.h index ddc4a25..d945b8d 100644 --- a/include/configs/bf527-ezkit.h +++ b/include/configs/bf527-ezkit.h @@ -134,9 +134,6 @@ #endif
/* Don't waste time transferring a logo over the UART */ -#if (CONFIG_BFIN_BOOT_MODE != BFIN_BOOT_UART) -/*# define CONFIG_VIDEO*/ -#endif
/* * Video Settings diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index c2466ca..ec4d93c 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -204,7 +204,6 @@ #endif
/* define to enable splash screen support */ -/* #define CONFIG_VIDEO */
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf548-ezkit.h b/include/configs/bf548-ezkit.h index 811dae8..9376283 100644 --- a/include/configs/bf548-ezkit.h +++ b/include/configs/bf548-ezkit.h @@ -167,7 +167,6 @@
#define CONFIG_ADI_GPIO2
-#undef CONFIG_VIDEO #ifdef CONFIG_VIDEO #define EASYLOGO_HEADER < asm/bfin_logo_230x230_gzip.h > #define CONFIG_DEB_DMA_URGENT diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 8090200..03cf96c 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -88,7 +88,6 @@ #define CONFIG_FASTBOOT_BUF_SIZE 0x07000000
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/cm-bf548.h b/include/configs/cm-bf548.h index d1aa262..c5b82f7 100644 --- a/include/configs/cm-bf548.h +++ b/include/configs/cm-bf548.h @@ -113,7 +113,6 @@ #ifndef __ADSPBF542__ /* Don't waste time transferring a logo over the UART */ # if (CONFIG_BFIN_BOOT_MODE != BFIN_BOOT_UART) -# define CONFIG_VIDEO # define EASYLOGO_HEADER <asm/bfin_logo_230x230_gzip.h> # endif # define CONFIG_DEB_DMA_URGENT diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 1e168e3..9406dfa 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -252,7 +252,6 @@ #define CONFIG_SPL_SPI_LOAD
/* Display */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_IMX_HDMI diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index a968b10..b883407 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -221,7 +221,6 @@ #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_16M #define DFU_DEFAULT_POLL_TIMEOUT 300
-#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 37972a8..a952f62 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -225,7 +225,6 @@ */ #define CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) -#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 2698a89..e6aa84f 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -72,7 +72,6 @@ /* * Video */ -#define CONFIG_VIDEO
#ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MB862xx diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 6054f88..68f597e 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -21,7 +21,6 @@ #define CONFIG_DRIVER_TI_EMAC_RMII_NO_NEGOTIATE #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_LATE_INIT -#define CONFIG_VIDEO #define CONFIG_PREBOOT
/* diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 6d469a3..4a868c5 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -251,8 +251,6 @@ * VIDEO configuration */
-#define CONFIG_VIDEO - #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_VCXK 1
diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 6266d95..97a912b 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -117,7 +117,6 @@ #endif
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index e6df86e..8665d7a 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -178,7 +178,6 @@ #define CONFIG_USB_FUNCTION_MASS_STORAGE
/* Framebuffer and LCD */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/icon.h b/include/configs/icon.h index 7e9e7e6..7fc2da2 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -126,7 +126,6 @@ /* * Video options */ -#define CONFIG_VIDEO
#ifdef CONFIG_VIDEO #define CONFIG_VIDEO_SM501 diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 9b4b590..2ce80cd 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -178,7 +178,6 @@
#define CONFIG_S6E63D6
-#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MX3 #define CONFIG_VIDEO_LOGO diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index e3fbcf2..cfa3917 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -43,7 +43,6 @@ /* * Video configuration for LIME GDC */ -#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 000973f..fe68303 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -444,7 +444,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DCU_FB
#ifdef CONFIG_FSL_DCU_FB -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index b32809d..a1ea57a 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -326,7 +326,6 @@ #define CONFIG_FSL_DCU_FB
#ifdef CONFIG_FSL_DCU_FB -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index d8398ee..00d0c19 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -353,7 +353,6 @@ #define CONFIG_PHY1_ADDR 1
/* Video console */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL #define CONFIG_CFB_CONSOLE diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 894973f..25884b4 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -24,7 +24,6 @@ #define CONFIG_CMD_EEPROM #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS -#define CONFIG_VIDEO
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 1338d29..4c7ce52 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -31,7 +31,6 @@ #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS #define CONFIG_CMD_SATA -#define CONFIG_VIDEO
/* * Memory configurations diff --git a/include/configs/mcx.h b/include/configs/mcx.h index b5e2d71..f633e05 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -365,7 +365,6 @@ #define CONFIG_NET_RETRY_COUNT 10 #endif
-#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index 0511d03..3d0f66e 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -36,7 +36,6 @@ /* video */ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_IMMR + 0x2100) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index 5f44d5f..bb3da6f 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -51,7 +51,6 @@ #define CONFIG_FPGA_DELAY() udelay(1) #define CONFIG_SYS_FPGA_PROG_FEEDBACK
-#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx23evk.h b/include/configs/mx23evk.h index 12df0ad..ecb6e4d 100644 --- a/include/configs/mx23evk.h +++ b/include/configs/mx23evk.h @@ -17,8 +17,6 @@ #define CONFIG_SYS_NO_FLASH #define CONFIG_DOS_PARTITION
-#define CONFIG_VIDEO - /* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ #define PHYS_SDRAM_1 0x40000000 /* Base address */ diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index b460f7e..5963d39 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -22,7 +22,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS -#define CONFIG_VIDEO
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 60f73db..f9242cd 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -93,7 +93,6 @@
/* Framebuffer and LCD */ #define CONFIG_PREBOOT -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 27751a5..011eda3 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -213,7 +213,6 @@
/* Framebuffer and LCD */ #define CONFIG_PREBOOT -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 6e4a4f8..e658c52 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -33,7 +33,6 @@ #define CONFIG_PHY_ATHEROS
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CFB_CONSOLE diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 32ebb51..dc7be11 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -208,7 +208,6 @@ #endif
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 70f2162..66bff1e 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -205,7 +205,6 @@ #endif
#ifndef CONFIG_SPL_BUILD -#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index bbd09de..e3cceeb 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -225,7 +225,6 @@ #define CONFIG_IMX_THERMAL
#ifndef CONFIG_SPL_BUILD -#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 3b8f2ed..38bcad2 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -250,7 +250,6 @@
-#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index c66a936..850d560 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -92,7 +92,6 @@ #define CONFIG_CMD_BMODE
/* Framebuffer and LCD */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index b2625de..a8ccf3c 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -224,7 +224,6 @@ * Framebuffer */ /* Video console */ -#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_CFB_CONSOLE_ANSI /* Enable ANSI escape codes in framebuffer */ #define CONFIG_VIDEO_LOGO diff --git a/include/configs/novena.h b/include/configs/novena.h index cba0604..7fcb2f8 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -24,7 +24,6 @@ #define CONFIG_FAT_WRITE #define CONFIG_CMD_PCI #define CONFIG_CMD_SATA -#define CONFIG_VIDEO
/* U-Boot general configurations */
diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h index 9791665..881a937 100644 --- a/include/configs/pdm360ng.h +++ b/include/configs/pdm360ng.h @@ -38,7 +38,6 @@ #define CONFIG_SYS_DEVICE_NULLDEV
/* Video */ -#define CONFIG_VIDEO
#if defined(CONFIG_VIDEO) #define CONFIG_CFB_CONSOLE diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 99a201c..541005c 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -124,7 +124,6 @@ #endif #endif /* CONFIG_SPL_BUILD */
-#define CONFIG_VIDEO #if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX #define CONFIG_CFB_CONSOLE diff --git a/include/configs/rut.h b/include/configs/rut.h index 5f62358..e19ed75 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -118,7 +118,6 @@ #undef CONFIG_HW_WATCHDOG #endif
-#define CONFIG_VIDEO #if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX #define CONFIG_CFB_CONSOLE diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index 65cf143..0b2821d 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -13,8 +13,6 @@ #define CONFIG_SYS_NO_FLASH #define CONFIG_DOS_PARTITION
-#define CONFIG_VIDEO - /* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ #define PHYS_SDRAM_1 0x40000000 /* Base address */ diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 1afe374..7392fe3 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -45,7 +45,6 @@ * Define this if you want support for video console with radeon 9200 pci card * Also set CONFIG_SYS_TEXT_BASE to 0xFFF80000 in board/amcc/sequoia/config.mk in this case */ -#undef CONFIG_VIDEO
#ifdef CONFIG_VIDEO /* diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 5b9d741..900232f 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -168,7 +168,6 @@ #define CONFIG_SYS_BR2_PRELIM 0xc80018a1 /* UPMB, 32-bit */ #define CONFIG_SYS_OR2_PRELIM 0xfc000000 /* 64 MB */
-#define CONFIG_VIDEO #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL #define CONFIG_CFB_CONSOLE diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 8326ceb..974e96d 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -73,7 +73,6 @@ #define CONFIG_PHY_ATHEROS
/* Framebuffer */ -#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index d27ab9c..0c18dbf 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -96,7 +96,6 @@ /* Enable LCD and reserve 512KB from top of memory*/ #define CONFIG_SYS_MEM_TOP_HIDE 0x80000
-#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index df94389..b5e287a 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -74,7 +74,6 @@ #define CONFIG_PHY_ATHEROS
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index e291ff7..ae9ab71 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -13,8 +13,6 @@ #define CONFIG_SYS_NO_FLASH #define CONFIG_DOS_PARTITION
On Tue, Oct 18, 2016 at 7:42 AM, Simon Glass sjg@chromium.org wrote:
This converts the following to Kconfig: CONFIG_VIDEO
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
Reviewed-by: Jagan Teki jteki@openedev.com
thanks!
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Jagan Teki jteki@openedev.com
This converts the following to Kconfig: CONFIG_CFB_CONSOLE
Changes in v4: None Changes in v3: - Change CONFIG_CFB_CONSOLE to default y if CONFIG_VIDEO
Changes in v2: None
README | 39 --------------------------------- configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + drivers/video/Kconfig | 41 +++++++++++++++++++++++++++++++++++ include/configs/MIP405.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1022DS.h | 2 -- include/configs/PIP405.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/TQM5200.h | 1 - include/configs/ac14xx.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/aria.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/chromebook_samus.h | 2 -- include/configs/cm_fx6.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/digsy_mtc.h | 1 - include/configs/ea20.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/icon.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/ipek01.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m53evk.h | 1 - include/configs/mcx.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/mt_ventoux.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mxs.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/nokia_rx51.h | 1 - include/configs/novena.h | 1 - include/configs/pdm360ng.h | 1 - include/configs/pxm2.h | 1 - include/configs/rut.h | 1 - include/configs/sequoia.h | 1 - include/configs/socrates.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/tbs2910.h | 1 - include/configs/theadorable.h | 1 - include/configs/wandboard.h | 1 - scripts/config_whitelist.txt | 1 - 62 files changed, 43 insertions(+), 99 deletions(-)
diff --git a/README b/README index e1ac6e3..b4dc217 100644 --- a/README +++ b/README @@ -770,49 +770,10 @@ The following options need to be configured: port routines must be defined elsewhere (i.e. serial_init(), serial_getc(), ...)
- CONFIG_CFB_CONSOLE - Enables console device for a color framebuffer. Needs following - defines (cf. smiLynxEM, i8042) - VIDEO_FB_LITTLE_ENDIAN graphic memory organisation - (default big endian) - VIDEO_HW_RECTFILL graphic chip supports - rectangle fill - (cf. smiLynxEM) - VIDEO_HW_BITBLT graphic chip supports - bit-blit (cf. smiLynxEM) - VIDEO_VISIBLE_COLS visible pixel columns - (cols=pitch) - VIDEO_VISIBLE_ROWS visible pixel rows - VIDEO_PIXEL_SIZE bytes per pixel - VIDEO_DATA_FORMAT graphic data format - (0-5, cf. cfb_console.c) - VIDEO_FB_ADRS framebuffer address - VIDEO_KBD_INIT_FCT keyboard int fct - (i.e. rx51_kp_init()) - VIDEO_TSTC_FCT test char fct - (i.e. rx51_kp_tstc) - VIDEO_GETC_FCT get char fct - (i.e. rx51_kp_getc) - CONFIG_VIDEO_LOGO display Linux logo in - upper left corner - CONFIG_VIDEO_BMP_LOGO use bmp_logo.h instead of - linux_logo.h for logo. - Requires CONFIG_VIDEO_LOGO - CONFIG_CONSOLE_EXTRA_INFO - additional board info beside - the logo - CONFIG_HIDE_LOGO_VERSION - do not display bootloader - version string - When CONFIG_CFB_CONSOLE_ANSI is defined, console will support a limited number of ANSI escape sequences (cursor control, erase functions and limited graphics rendition control).
- When CONFIG_CFB_CONSOLE is defined, video console is - default i/o. Serial console can be forced with - environment 'console=serial'. - CONFIG_SYS_CONSOLE_BG_COL: define the backgroundcolor, default is 0x00. CONFIG_SYS_CONSOLE_FG_COL: define the foregroundcolor, default diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index bbcce82..0c0b4d3 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -11,3 +11,4 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y +# CONFIG_CFB_CONSOLE is not set diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index 7e865d8..c464647 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -10,3 +10,4 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y +# CONFIG_CFB_CONSOLE is not set diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 866fafd..14518a8 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -443,4 +443,45 @@ config VIDEO model. Video drivers typically provide a colour text console and cursor.
+config CFB_CONSOLE + bool "Enable colour frame buffer console" + depends on VIDEO + default y if VIDEO + help + Enables the colour frame buffer driver. This supports colour + output on a bitmap display from an in-memory frame buffer. + Several colour devices are supported along with various options to + adjust the supported features. The driver is implemented in + cfb_console.c + + The following defines are needed (cf. smiLynxEM, i8042) + VIDEO_FB_LITTLE_ENDIAN graphic memory organisation + (default big endian) + VIDEO_HW_RECTFILL graphic chip supports + rectangle fill (cf. smiLynxEM) + VIDEO_HW_BITBLT graphic chip supports + bit-blit (cf. smiLynxEM) + VIDEO_VISIBLE_COLS visible pixel columns (cols=pitch) + VIDEO_VISIBLE_ROWS visible pixel rows + VIDEO_PIXEL_SIZE bytes per pixel + VIDEO_DATA_FORMAT graphic data format + (0-5, cf. cfb_console.c) + VIDEO_FB_ADRS framebuffer address + VIDEO_KBD_INIT_FCT keyboard int fct (i.e. rx51_kp_init()) + VIDEO_TSTC_FCT test char fct (i.e. rx51_kp_tstc) + VIDEO_GETC_FCT get char fct (i.e. rx51_kp_getc) + CONFIG_VIDEO_LOGO display Linux logo in upper left corner + CONFIG_VIDEO_BMP_LOGO use bmp_logo.h instead of linux_logo.h + for logo. Requires CONFIG_VIDEO_LOGO + CONFIG_CONSOLE_EXTRA_INFO + additional board info beside + the logo + CONFIG_HIDE_LOGO_VERSION + do not display bootloader + version string + + When CONFIG_CFB_CONSOLE is defined, the video console is the + default console. The serial console can be forced by setting the + environment 'console=serial'. + endmenu diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index e9101a0..e9f0369 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -343,7 +343,6 @@ * Video support ************************************************************/ #define CONFIG_VIDEO_CT69000 -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 3d753ad..50e30e2 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -506,7 +506,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 332d4bc..fdce09f 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -278,7 +278,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 6ec2efa..c0abd0e 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -465,7 +465,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 046f2e0..8eff79e 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -24,7 +24,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x2c000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index f2ecd83..c4dc8da 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -378,7 +378,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index e939dcb..c4ff922 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -379,7 +379,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO @@ -402,7 +401,6 @@ #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #endif
diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 8649cdb..6110f28 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -303,7 +303,6 @@ * Video support ************************************************************/ #define CONFIG_VIDEO_CT69000 -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 80d893d..b5f1712 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -503,7 +503,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 5df1853..3d221e3 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -509,7 +509,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 51ff392..ca87180 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -413,7 +413,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 87e6333..92a6d8b 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -525,7 +525,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_CFB_CONSOLE_ANSI #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 9c466d9..cc8d2cd 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -99,7 +99,6 @@ #ifndef CONFIG_TQM5200S /* No graphics controller on TQM5200S */ #define CONFIG_VIDEO_SM501 #define CONFIG_VIDEO_SM501_32BPP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO
#ifndef CONFIG_FO300 diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index b18ee91..bdff6db 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -32,7 +32,6 @@ #define CONFIG_SYS_TEXT_BASE 0xFFF00000
#if defined(CONFIG_VIDEO) -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #endif
diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 025e1d3..db50a71 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -273,7 +273,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/aria.h b/include/configs/aria.h index 97e6fee..ec13b58 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -39,7 +39,6 @@ /* video */
diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 60f2bac..0ec5732 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -231,7 +231,6 @@ /* Framebuffer */ #define CONFIG_VIDEO_IPUV3 /* check this console not needed, after test remove it */ -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 03cf96c..1c76b5e 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -89,7 +89,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/chromebook_samus.h b/include/configs/chromebook_samus.h index b89ba41..1234bff 100644 --- a/include/configs/chromebook_samus.h +++ b/include/configs/chromebook_samus.h @@ -16,8 +16,6 @@ #include <configs/x86-common.h> #include <configs/x86-chromebook.h>
-#undef CONFIG_CFB_CONSOLE - #undef CONFIG_STD_DEVICES_SETTINGS #define CONFIG_STD_DEVICES_SETTINGS "stdin=usbkbd,i8042-kbd,serial\0" \ "stdout=vidconsole,serial\0" \ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 9406dfa..767368c 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -255,7 +255,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_IMX_HDMI -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR
diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index b883407..23b298d 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -222,7 +222,6 @@ #define DFU_DEFAULT_POLL_TIMEOUT 300
#ifdef CONFIG_VIDEO -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index a952f62..47a3002 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -225,7 +225,6 @@ */ #define CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP
diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index e6aa84f..5e1a86b 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -77,7 +77,6 @@ #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL #define CONFIG_VIDEO_CORALP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 68f597e..d3ca706 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -102,7 +102,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 97a912b..e115fd5 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -118,7 +118,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index d2568df..57eec0c 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -309,7 +309,6 @@ /* Framebuffer */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 8665d7a..c0dadd0 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -179,7 +179,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_IPUV3_CLK 260000000 diff --git a/include/configs/icon.h b/include/configs/icon.h index 7fc2da2..f858b99 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -132,7 +132,6 @@ #define CONFIG_VIDEO_SM501_32BPP #define CONFIG_VIDEO_SM501_PCI #define VIDEO_FB_LITTLE_ENDIAN -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 2ce80cd..ece3d45 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -178,7 +178,6 @@
-#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MX3 #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index cfa3917..447190a 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -47,7 +47,6 @@ #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL #define VIDEO_FB_16BPP_WORD_SWAP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CONSOLE_EXTRA_INFO diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index fe68303..93c7864 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -445,7 +445,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FSL_DCU_FB #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index a1ea57a..8da01dd 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -327,7 +327,6 @@
#ifdef CONFIG_FSL_DCU_FB #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 00d0c19..58446b5 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -355,7 +355,6 @@ /* Video console */ #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define VIDEO_FB_16BPP_PIXEL_SWAP diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 4c7ce52..2fa56d6 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -199,7 +199,6 @@ */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_GZIP diff --git a/include/configs/mcx.h b/include/configs/mcx.h index f633e05..d113ec4 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -365,7 +365,6 @@ #define CONFIG_NET_RETRY_COUNT 10 #endif
-#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index 3d0f66e..ddf6c7c 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -37,7 +37,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_IMMR + 0x2100) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index bb3da6f..3ec2358 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -51,7 +51,6 @@ #define CONFIG_FPGA_DELAY() udelay(1) #define CONFIG_SYS_FPGA_PROG_FEEDBACK
-#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index f9242cd..e02decb 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -94,7 +94,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 011eda3..f5ee433 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -214,7 +214,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index e658c52..158858f 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -35,7 +35,6 @@ /* Framebuffer */ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index dc7be11..fb380ba 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -209,7 +209,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 66bff1e..e288ad8 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -206,7 +206,6 @@
#ifndef CONFIG_SPL_BUILD #ifdef CONFIG_VIDEO -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index e3cceeb..5354f4b 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -226,7 +226,6 @@
#ifndef CONFIG_SPL_BUILD #ifdef CONFIG_VIDEO -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 38bcad2..c7715a0 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -251,7 +251,6 @@ #define CONFIG_USB_FUNCTION_MASS_STORAGE
#ifdef CONFIG_VIDEO -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 634556d..52083c8 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -143,7 +143,6 @@
/* LCD */ #ifdef CONFIG_VIDEO -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 850d560..d18c177 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -93,7 +93,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index a8ccf3c..334d13c 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -224,7 +224,6 @@ * Framebuffer */ /* Video console */ -#define CONFIG_CFB_CONSOLE #define CONFIG_CFB_CONSOLE_ANSI /* Enable ANSI escape codes in framebuffer */ #define CONFIG_VIDEO_LOGO #define VIDEO_FB_16BPP_PIXEL_SWAP diff --git a/include/configs/novena.h b/include/configs/novena.h index 7fcb2f8..40194f0 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -161,7 +161,6 @@ /* Video output */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h index 881a937..efb312f 100644 --- a/include/configs/pdm360ng.h +++ b/include/configs/pdm360ng.h @@ -40,7 +40,6 @@ /* Video */
#if defined(CONFIG_VIDEO) -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_LOGO diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 541005c..ba14593 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -126,7 +126,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/rut.h b/include/configs/rut.h index e19ed75..ca812e4 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -120,7 +120,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 7392fe3..facfdac 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -410,7 +410,6 @@ #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO -#define CONFIG_CFB_CONSOLE #define CONFIG_SPLASH_SCREEN #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 900232f..ad32b91 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -170,7 +170,6 @@
#define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CONSOLE_EXTRA_INFO diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 8e10d84..c95efd9 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -288,7 +288,6 @@ extern int soft_i2c_gpio_scl;
#define CONFIG_VIDEO_SUNXI
-#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_STD_TIMINGS diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 974e96d..db267ac 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -76,7 +76,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 -#define CONFIG_CFB_CONSOLE #define CONFIG_CFB_CONSOLE_ANSI #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 0c18dbf..365019a 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -96,7 +96,6 @@ /* Enable LCD and reserve 512KB from top of memory*/ #define CONFIG_SYS_MEM_TOP_HIDE 0x80000
diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index b5e287a..ab0ca15 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -75,7 +75,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 473889b..ba1f6fd 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -492,7 +492,6 @@ CONFIG_CDP_PORT_ID CONFIG_CDP_POWER_CONSUMPTION CONFIG_CDP_TRIGGER CONFIG_CDP_VERSION -CONFIG_CFB_CONSOLE CONFIG_CFB_CONSOLE_ANSI CONFIG_CFG_DATA_SECTOR CONFIG_CFG_FAT
This converts the following to Kconfig: CONFIG_CFB_CONSOLE_ANSI
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v4: None Changes in v3: None Changes in v2: None
README | 4 ---- configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/tbs2910_defconfig | 1 + drivers/video/Kconfig | 9 +++++++++ include/configs/T104xRDB.h | 1 - include/configs/nokia_rx51.h | 1 - include/configs/tbs2910.h | 1 - scripts/config_whitelist.txt | 1 - 18 files changed, 21 insertions(+), 8 deletions(-)
diff --git a/README b/README index b4dc217..5996598 100644 --- a/README +++ b/README @@ -770,10 +770,6 @@ The following options need to be configured: port routines must be defined elsewhere (i.e. serial_init(), serial_getc(), ...)
- When CONFIG_CFB_CONSOLE_ANSI is defined, console will support - a limited number of ANSI escape sequences (cursor control, - erase functions and limited graphics rendition control). - CONFIG_SYS_CONSOLE_BG_COL: define the backgroundcolor, default is 0x00. CONFIG_SYS_CONSOLE_FG_COL: define the foregroundcolor, default diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index e40fe49..a644929 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -38,4 +38,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 2665b05..ebd0990 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -38,4 +38,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index 1d2548b..54a8b5f 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -31,6 +31,7 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 611881f..a0920bb 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -39,4 +39,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 7f172cd..35284df 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -29,4 +29,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index c80db93..e885816 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -42,6 +42,7 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index cebe3c9..67ae007 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -38,4 +38,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 433c856..87d2a29 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -38,4 +38,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 6c3ba81..b28b46c 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -39,4 +39,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index 8932572..571e4e9 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -29,4 +29,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 43f0552..0599c19 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -22,3 +22,4 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y +CONFIG_CFB_CONSOLE_ANSI=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 0194c0c..8c342eb 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -38,4 +38,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="TBS" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 14518a8..d759c5b 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -484,4 +484,13 @@ config CFB_CONSOLE default console. The serial console can be forced by setting the environment 'console=serial'.
+config CFB_CONSOLE_ANSI + bool "Support ANSI escape sequences" + depends on CFB_CONSOLE + help + This allows the colour buffer frame buffer driver to support + a limited number of ANSI escape sequences (cursor control, + erase functions and limited graphics rendition control). Normal + output from U-Boot will pass through this filter. + endmenu diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 92a6d8b..50ca2d7 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -525,7 +525,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE_ANSI #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 334d13c..45c46a0 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -224,7 +224,6 @@ * Framebuffer */ /* Video console */ -#define CONFIG_CFB_CONSOLE_ANSI /* Enable ANSI escape codes in framebuffer */ #define CONFIG_VIDEO_LOGO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index db267ac..f77e88e 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -76,7 +76,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 -#define CONFIG_CFB_CONSOLE_ANSI #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index ba1f6fd..1beb89f 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -492,7 +492,6 @@ CONFIG_CDP_PORT_ID CONFIG_CDP_POWER_CONSUMPTION CONFIG_CDP_TRIGGER CONFIG_CDP_VERSION -CONFIG_CFB_CONSOLE_ANSI CONFIG_CFG_DATA_SECTOR CONFIG_CFG_FAT CONFIG_CFG_USB
This converts the following to Kconfig: CONFIG_VIDEO_CT69000
README | 23 ----------------------- configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/PIP405_defconfig | 1 + drivers/video/Kconfig | 27 +++++++++++++++++++++++++++ include/configs/MIP405.h | 1 - include/configs/PIP405.h | 1 - scripts/config_whitelist.txt | 1 - 8 files changed, 30 insertions(+), 26 deletions(-)
diff --git a/README b/README index 5996598..7443b9f 100644 --- a/README +++ b/README @@ -1619,35 +1619,12 @@ CBFS (Coreboot Filesystem) support instead.
- Video support: - CONFIG_VIDEO_CT69000 - - Enable Chips & Technologies 69000 Video chip - CONFIG_VIDEO_SMI_LYNXEM Enable Silicon Motion SMI 712/710/810 Video chip. The video output is selected via environment 'videoout' (1 = LCD and 2 = CRT). If videoout is undefined, CRT is assumed.
- For the CT69000 and SMI_LYNXEM drivers, videomode is - selected via environment 'videomode'. Two different ways - are possible: - - "videomode=num" 'num' is a standard LiLo mode numbers. - Following standard modes are supported (* is default): - - Colors 640x480 800x600 1024x768 1152x864 1280x1024 - -------------+--------------------------------------------- - 8 bits | 0x301* 0x303 0x305 0x161 0x307 - 15 bits | 0x310 0x313 0x316 0x162 0x319 - 16 bits | 0x311 0x314 0x317 0x163 0x31A - 24 bits | 0x312 0x315 0x318 ? 0x31B - -------------+--------------------------------------------- - (i.e. setenv videomode 317; saveenv; reset;) - - - "videomode=bootargs" all the video parameters are parsed - from the bootargs. (See drivers/video/videomodes.c) - - CONFIG_VIDEO_SED13806 Enable Epson SED13806 driver. This driver supports 8bpp and 16bpp modes defined by CONFIG_VIDEO_SED13806_8BPP diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index c977887..ddc5c36 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -15,3 +15,4 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y +CONFIG_VIDEO_CT69000=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index b5542fe..2610899 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -18,3 +18,4 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_VIDEO_CT69000=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 052f354..73ed894 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -18,3 +18,4 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_VIDEO_CT69000=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index d759c5b..47b82f4 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -493,4 +493,31 @@ config CFB_CONSOLE_ANSI erase functions and limited graphics rendition control). Normal output from U-Boot will pass through this filter.
+config VIDEO_CT69000 + bool "Enable Chips & Technologies 69000 video driver" + depends on VIDEO + help + This enables a frame buffer driver for the Chips & Technologies + ct69000, a fairly old graphics device (circa 2000) which is used + on some hardware. It operates over the ISA bus, and supports + some acceleration features. + + For the CT69000 and SMI_LYNXEM drivers, videomode is + selected via environment 'videomode'. Two different ways + are possible: + - "videomode=num" 'num' is a standard LiLo mode numbers. + Following standard modes are supported (* is default): + + Colors 640x480 800x600 1024x768 1152x864 1280x1024 + -------------+--------------------------------------------- + 8 bits | 0x301* 0x303 0x305 0x161 0x307 + 15 bits | 0x310 0x313 0x316 0x162 0x319 + 16 bits | 0x311 0x314 0x317 0x163 0x31A + 24 bits | 0x312 0x315 0x318 ? 0x31B + -------------+--------------------------------------------- + (i.e. setenv videomode 317; saveenv; reset;) + + - "videomode=bootargs" all the video parameters are parsed + from the bootargs. (See drivers/video/videomodes.c) + endmenu diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index e9f0369..501411b 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -342,7 +342,6 @@ /************************************************************ * Video support ************************************************************/ -#define CONFIG_VIDEO_CT69000 #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 6110f28..54dbe4c 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -302,7 +302,6 @@ /************************************************************ * Video support ************************************************************/ -#define CONFIG_VIDEO_CT69000 #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 1beb89f..37934c1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8261,7 +8261,6 @@ CONFIG_VIDEO_BMP_GZIP CONFIG_VIDEO_BMP_LOGO CONFIG_VIDEO_BMP_RLE8 CONFIG_VIDEO_CORALP -CONFIG_VIDEO_CT69000 CONFIG_VIDEO_DA8XX CONFIG_VIDEO_DT_SIMPLEFB CONFIG_VIDEO_FONT_4X6
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_BG_COL CONFIG_SYS_CONSOLE_FG_COL
README | 5 --- configs/pxm2_defconfig | 2 + configs/rut_defconfig | 2 + drivers/video/Kconfig | 22 ++++++++++ drivers/video/cfb_console.c | 98 ++++++++++++++++++++++---------------------- drivers/video/ct69000.c | 3 +- include/configs/pxm2.h | 2 - include/configs/rut.h | 2 - include/video_fb.h | 8 ---- scripts/config_whitelist.txt | 2 - 10 files changed, 78 insertions(+), 68 deletions(-)
diff --git a/README b/README index 7443b9f..b528abd 100644 --- a/README +++ b/README @@ -770,11 +770,6 @@ The following options need to be configured: port routines must be defined elsewhere (i.e. serial_init(), serial_getc(), ...)
- CONFIG_SYS_CONSOLE_BG_COL: define the backgroundcolor, default - is 0x00. - CONFIG_SYS_CONSOLE_FG_COL: define the foregroundcolor, default - is 0xa0. - - Console Baudrate: CONFIG_BAUDRATE - in bps Select one of the baudrates listed in diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index ffdfcfe..76ea361 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -61,3 +61,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_SYS_CONSOLE_BG_COL=0xff +CONFIG_SYS_CONSOLE_FG_COL=0x00 diff --git a/configs/rut_defconfig b/configs/rut_defconfig index a6a4bb9..8811eb2 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -61,3 +61,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_SYS_CONSOLE_BG_COL=0xff +CONFIG_SYS_CONSOLE_FG_COL=0x00 diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 47b82f4..3249275 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -520,4 +520,26 @@ config VIDEO_CT69000 - "videomode=bootargs" all the video parameters are parsed from the bootargs. (See drivers/video/videomodes.c)
+config SYS_CONSOLE_BG_COL + hex "Background colour" + depends on CFB_CONSOLE || VIDEO_CT69000 + default 0x00 + help + Defines the background colour for the console. The value is from + 0x00 to 0xff and the meaning depends on the graphics card. + Typically, 0x00 means black and 0xff means white. Do not set + the background and foreground to the same colour or you will see + nothing. + +config SYS_CONSOLE_FG_COL + hex "Foreground colour" + depends on CFB_CONSOLE || VIDEO_CT69000 + default 0xa0 + help + Defines the foreground colour for the console. The value is from + 0x00 to 0xff and the meaning depends on the graphics card. + Typically, 0x00 means black and 0xff means white. Do not set + the background and foreground to the same colour or you will see + nothing. + endmenu diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 30b53db..949187c 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -2093,70 +2093,72 @@ static int video_init(void) /* Init drawing pats */ switch (VIDEO_DATA_FORMAT) { case GDF__8BIT_INDEX: - video_set_lut(0x01, CONSOLE_FG_COL, CONSOLE_FG_COL, - CONSOLE_FG_COL); - video_set_lut(0x00, CONSOLE_BG_COL, CONSOLE_BG_COL, - CONSOLE_BG_COL); + video_set_lut(0x01, CONFIG_SYS_CONSOLE_FG_COL, + CONFIG_SYS_CONSOLE_FG_COL, + CONFIG_SYS_CONSOLE_FG_COL); + video_set_lut(0x00, CONFIG_SYS_CONSOLE_BG_COL, + CONFIG_SYS_CONSOLE_BG_COL, + CONFIG_SYS_CONSOLE_BG_COL); fgx = 0x01010101; bgx = 0x00000000; break; case GDF__8BIT_332RGB: - color8 = ((CONSOLE_FG_COL & 0xe0) | - ((CONSOLE_FG_COL >> 3) & 0x1c) | - CONSOLE_FG_COL >> 6); + color8 = ((CONFIG_SYS_CONSOLE_FG_COL & 0xe0) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) & 0x1c) | + CONFIG_SYS_CONSOLE_FG_COL >> 6); fgx = (color8 << 24) | (color8 << 16) | (color8 << 8) | color8; - color8 = ((CONSOLE_BG_COL & 0xe0) | - ((CONSOLE_BG_COL >> 3) & 0x1c) | - CONSOLE_BG_COL >> 6); + color8 = ((CONFIG_SYS_CONSOLE_BG_COL & 0xe0) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) & 0x1c) | + CONFIG_SYS_CONSOLE_BG_COL >> 6); bgx = (color8 << 24) | (color8 << 16) | (color8 << 8) | color8; break; case GDF_15BIT_555RGB: - fgx = (((CONSOLE_FG_COL >> 3) << 26) | - ((CONSOLE_FG_COL >> 3) << 21) | - ((CONSOLE_FG_COL >> 3) << 16) | - ((CONSOLE_FG_COL >> 3) << 10) | - ((CONSOLE_FG_COL >> 3) << 5) | - (CONSOLE_FG_COL >> 3)); - bgx = (((CONSOLE_BG_COL >> 3) << 26) | - ((CONSOLE_BG_COL >> 3) << 21) | - ((CONSOLE_BG_COL >> 3) << 16) | - ((CONSOLE_BG_COL >> 3) << 10) | - ((CONSOLE_BG_COL >> 3) << 5) | - (CONSOLE_BG_COL >> 3)); + fgx = (((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 26) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 21) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 16) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 10) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 5) | + (CONFIG_SYS_CONSOLE_FG_COL >> 3)); + bgx = (((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 26) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 21) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 16) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 10) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 5) | + (CONFIG_SYS_CONSOLE_BG_COL >> 3)); break; case GDF_16BIT_565RGB: - fgx = (((CONSOLE_FG_COL >> 3) << 27) | - ((CONSOLE_FG_COL >> 2) << 21) | - ((CONSOLE_FG_COL >> 3) << 16) | - ((CONSOLE_FG_COL >> 3) << 11) | - ((CONSOLE_FG_COL >> 2) << 5) | - (CONSOLE_FG_COL >> 3)); - bgx = (((CONSOLE_BG_COL >> 3) << 27) | - ((CONSOLE_BG_COL >> 2) << 21) | - ((CONSOLE_BG_COL >> 3) << 16) | - ((CONSOLE_BG_COL >> 3) << 11) | - ((CONSOLE_BG_COL >> 2) << 5) | - (CONSOLE_BG_COL >> 3)); + fgx = (((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 27) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 2) << 21) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 16) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 11) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 2) << 5) | + (CONFIG_SYS_CONSOLE_FG_COL >> 3)); + bgx = (((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 27) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 2) << 21) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 16) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 11) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 2) << 5) | + (CONFIG_SYS_CONSOLE_BG_COL >> 3)); break; case GDF_32BIT_X888RGB: - fgx = (CONSOLE_FG_COL << 16) | - (CONSOLE_FG_COL << 8) | - CONSOLE_FG_COL; - bgx = (CONSOLE_BG_COL << 16) | - (CONSOLE_BG_COL << 8) | - CONSOLE_BG_COL; + fgx = (CONFIG_SYS_CONSOLE_FG_COL << 16) | + (CONFIG_SYS_CONSOLE_FG_COL << 8) | + CONFIG_SYS_CONSOLE_FG_COL; + bgx = (CONFIG_SYS_CONSOLE_BG_COL << 16) | + (CONFIG_SYS_CONSOLE_BG_COL << 8) | + CONFIG_SYS_CONSOLE_BG_COL; break; case GDF_24BIT_888RGB: - fgx = (CONSOLE_FG_COL << 24) | - (CONSOLE_FG_COL << 16) | - (CONSOLE_FG_COL << 8) | - CONSOLE_FG_COL; - bgx = (CONSOLE_BG_COL << 24) | - (CONSOLE_BG_COL << 16) | - (CONSOLE_BG_COL << 8) | - CONSOLE_BG_COL; + fgx = (CONFIG_SYS_CONSOLE_FG_COL << 24) | + (CONFIG_SYS_CONSOLE_FG_COL << 16) | + (CONFIG_SYS_CONSOLE_FG_COL << 8) | + CONFIG_SYS_CONSOLE_FG_COL; + bgx = (CONFIG_SYS_CONSOLE_BG_COL << 24) | + (CONFIG_SYS_CONSOLE_BG_COL << 16) | + (CONFIG_SYS_CONSOLE_BG_COL << 8) | + CONFIG_SYS_CONSOLE_BG_COL; break; } eorx = fgx ^ bgx; diff --git a/drivers/video/ct69000.c b/drivers/video/ct69000.c index 22b3441..349da5e 100644 --- a/drivers/video/ct69000.c +++ b/drivers/video/ct69000.c @@ -870,7 +870,8 @@ video_init_hw_cursor (int font_width, int font_height) xr_80 = ctRead_i (CT_XR_O, 0x80); xr_80 |= 0x1; /* alternate palette select */ ctWrite_i (CT_XR_O, 0x80, xr_80); - video_set_lut (4, CONSOLE_FG_COL, CONSOLE_FG_COL, CONSOLE_FG_COL); + video_set_lut(4, CONFIG_SYS_CONSOLE_FG_COL, CONFIG_SYS_CONSOLE_FG_COL, + CONFIG_SYS_CONSOLE_FG_COL); /* position 4 is color 0 cursor 0 */ xr_80 &= 0xfe; /* normal palette select */ ctWrite_i (CT_XR_O, 0x80, xr_80); diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index ba14593..6cc8d6c 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -136,8 +136,6 @@ #define DA8XX_LCD_CNTL_BASE LCD_CNTL_BASE #define PWM_TICKS 0x1388 #define PWM_DUTY 0x200 -#define CONFIG_SYS_CONSOLE_BG_COL 0xff -#define CONFIG_SYS_CONSOLE_FG_COL 0x00 #endif
#endif /* ! __CONFIG_PXM2_H */ diff --git a/include/configs/rut.h b/include/configs/rut.h index ca812e4..11f9a25 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -136,8 +136,6 @@ #define CONFIG_ARCH_EARLY_INIT_R #define CONFIG_FORMIKE #define DISPL_PLL_SPREAD_SPECTRUM -#define CONFIG_SYS_CONSOLE_BG_COL 0xff -#define CONFIG_SYS_CONSOLE_FG_COL 0x00 #endif
#endif /* ! __CONFIG_RUT_H */ diff --git a/include/video_fb.h b/include/video_fb.h index 55ec24d..b7e3aee 100644 --- a/include/video_fb.h +++ b/include/video_fb.h @@ -18,14 +18,6 @@ #ifndef _VIDEO_FB_H_ #define _VIDEO_FB_H_
-#if defined(CONFIG_SYS_CONSOLE_FG_COL) && defined(CONFIG_SYS_CONSOLE_BG_COL) -#define CONSOLE_BG_COL CONFIG_SYS_CONSOLE_BG_COL -#define CONSOLE_FG_COL CONFIG_SYS_CONSOLE_FG_COL -#else -#define CONSOLE_BG_COL 0x00 -#define CONSOLE_FG_COL 0xa0 -#endif - /* * Graphic Data Format (GDF) bits for VIDEO_DATA_FORMAT */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 37934c1..8f3c680 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4601,9 +4601,7 @@ CONFIG_SYS_CMXFCR_VALUE1 CONFIG_SYS_CMXFCR_VALUE2 CONFIG_SYS_CMXFCR_VALUE3 CONFIG_SYS_CMXSCR_VALUE -CONFIG_SYS_CONSOLE_BG_COL CONFIG_SYS_CONSOLE_ENV_OVERWRITE -CONFIG_SYS_CONSOLE_FG_COL CONFIG_SYS_CONSOLE_INFO_QUIET CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_CORE_SRAM
This is not used in U-Boot anymore.
README | 6 - drivers/video/Makefile | 1 - drivers/video/cfb_console.c | 13 - drivers/video/smiLynxEM.c | 835 ------------------------------------------- scripts/config_whitelist.txt | 1 - 5 files changed, 856 deletions(-) delete mode 100644 drivers/video/smiLynxEM.c
diff --git a/README b/README index b528abd..8925837 100644 --- a/README +++ b/README @@ -1614,12 +1614,6 @@ CBFS (Coreboot Filesystem) support instead.
- Video support: - CONFIG_VIDEO_SMI_LYNXEM - Enable Silicon Motion SMI 712/710/810 Video chip. The - video output is selected via environment 'videoout' - (1 = LCD and 2 = CRT). If videoout is undefined, CRT is - assumed. - CONFIG_VIDEO_SED13806 Enable Epson SED13806 driver. This driver supports 8bpp and 16bpp modes defined by CONFIG_VIDEO_SED13806_8BPP diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 4a42417..951d021 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -54,7 +54,6 @@ obj-$(CONFIG_VIDEO_S3C) += s3c-fb.o videomodes.o obj-$(CONFIG_VIDEO_SANDBOX_SDL) += sandbox_sdl.o obj-$(CONFIG_VIDEO_SED13806) += sed13806.o obj-$(CONFIG_VIDEO_SM501) += sm501.o -obj-$(CONFIG_VIDEO_SMI_LYNXEM) += smiLynxEM.o videomodes.o obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o videomodes.o obj-$(CONFIG_VIDEO_TEGRA20) += tegra.o obj-$(CONFIG_VIDEO_VCXK) += bus_vcxk.o diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 949187c..a087d2e 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -27,7 +27,6 @@ * * (for SMI LynxE graphic chip) * - * CONFIG_VIDEO_SMI_LYNXEM - use graphic driver for SMI 710,712,810 * VIDEO_FB_LITTLE_ENDIAN - framebuffer organisation default: big endian * VIDEO_HW_RECTFILL - graphic driver supports hardware rectangle fill * VIDEO_HW_BITBLT - graphic driver supports hardware bit blt @@ -87,18 +86,6 @@ #include <linux/compiler.h>
/* - * Console device defines with SMI graphic - * Any other graphic must change this section - */ - -#ifdef CONFIG_VIDEO_SMI_LYNXEM - -#define VIDEO_FB_LITTLE_ENDIAN -#define VIDEO_HW_RECTFILL -#define VIDEO_HW_BITBLT -#endif - -/* * Defines for the CT69000 driver */ #ifdef CONFIG_VIDEO_CT69000 diff --git a/drivers/video/smiLynxEM.c b/drivers/video/smiLynxEM.c deleted file mode 100644 index 1880ccc..0000000 --- a/drivers/video/smiLynxEM.c +++ /dev/null @@ -1,835 +0,0 @@ -/* - * (C) Copyright 1997-2002 ELTEC Elektronik AG - * Frank Gottschling fgottschling@eltec.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * smiLynxEM.c - * - * Silicon Motion graphic interface for sm810/sm710/sm712 accelerator - * - * modification history - * -------------------- - * 04-18-2002 Rewritten for U-Boot fgottschling@eltec.de. - * - * 18-03-2004 - Unify videomodes handling with the ct69000 - * - The video output can be set via the variable "videoout" - * in the environment. - * videoout=1 output on LCD - * videoout=2 output on CRT (default value) - * p.aubert@staubli.com - */ - -#include <common.h> - -#include <pci.h> -#include <video_fb.h> -#include "videomodes.h" -/* - * Export Graphic Device - */ -GraphicDevice smi; - -/* - * SMI 710/712 have 4MB internal RAM; SMI 810 2MB internal + 2MB external - */ -#define VIDEO_MEM_SIZE 0x400000 - - -/* - * ISA mapped regs - */ -#define SMI_INDX_C4 (pGD->isaBase + 0x03c4) /* index reg */ -#define SMI_DATA_C5 (pGD->isaBase + 0x03c5) /* data reg */ -#define SMI_INDX_D4 (pGD->isaBase + 0x03d4) /* index reg */ -#define SMI_DATA_D5 (pGD->isaBase + 0x03d5) /* data reg */ -#define SMI_ISR1 (pGD->isaBase + 0x03ca) -#define SMI_INDX_CE (pGD->isaBase + 0x03ce) /* index reg */ -#define SMI_DATA_CF (pGD->isaBase + 0x03cf) /* data reg */ -#define SMI_LOCK_REG (pGD->isaBase + 0x03c3) /* unlock/lock ext crt reg */ -#define SMI_MISC_REG (pGD->isaBase + 0x03c2) /* misc reg */ -#define SMI_LUT_MASK (pGD->isaBase + 0x03c6) /* lut mask reg */ -#define SMI_LUT_START (pGD->isaBase + 0x03c8) /* lut start index */ -#define SMI_LUT_RGB (pGD->isaBase + 0x03c9) /* lut colors auto incr.*/ -#define SMI_INDX_ATTR (pGD->isaBase + 0x03c0) /* attributes index reg */ - -/* - * Video processor control - */ -typedef struct { - unsigned int control; - unsigned int colorKey; - unsigned int colorKeyMask; - unsigned int start; - unsigned short offset; - unsigned short width; - unsigned int fifoPrio; - unsigned int fifoERL; - unsigned int YUVtoRGB; -} SmiVideoProc; - -/* - * Video window control - */ -typedef struct { - unsigned short top; - unsigned short left; - unsigned short bottom; - unsigned short right; - unsigned int srcStart; - unsigned short width; - unsigned short offset; - unsigned char hStretch; - unsigned char vStretch; -} SmiVideoWin; - -/* - * Capture port control - */ -typedef struct { - unsigned int control; - unsigned short topClip; - unsigned short leftClip; - unsigned short srcHeight; - unsigned short srcWidth; - unsigned int srcBufStart1; - unsigned int srcBufStart2; - unsigned short srcOffset; - unsigned short fifoControl; -} SmiCapturePort; - - -/* - * Register values for common video modes - */ -static char SMI_SCR[] = { - /* all modes */ - 0x10, 0xff, 0x11, 0xff, 0x12, 0xff, 0x13, 0xff, 0x15, 0x90, - 0x17, 0x20, 0x18, 0xb1, 0x19, 0x00, -}; -static char SMI_EXT_CRT[] = { - 0x31, 0x00, 0x32, 0x00, 0x33, 0x00, 0x34, 0x00, 0x35, 0x00, - 0x36, 0x00, 0x3b, 0x00, 0x3c, 0x00, 0x3d, 0x00, 0x3e, 0x00, 0x3f, 0x00, -}; -static char SMI_ATTR [] = { - 0x00, 0x00, 0x01, 0x01, 0x02, 0x02, 0x03, 0x03, 0x04, 0x04, 0x05, 0x05, - 0x06, 0x06, 0x07, 0x07, 0x08, 0x08, 0x09, 0x09, 0x0a, 0x0a, 0x0b, 0x0b, - 0x0c, 0x0c, 0x0d, 0x0d, 0x0e, 0x0e, 0x0f, 0x0f, 0x10, 0x41, 0x11, 0x00, - 0x12, 0x0f, 0x13, 0x00, 0x14, 0x00, -}; -static char SMI_GCR[18] = { - 0x00, 0x00, 0x01, 0x00, 0x02, 0x00, 0x03, 0x00, 0x04, 0x00, 0x05, 0x40, - 0x06, 0x05, 0x07, 0x0f, 0x08, 0xff, -}; -static char SMI_SEQR[] = { - 0x00, 0x00, 0x01, 0x01, 0x02, 0x0f, 0x03, 0x03, 0x04, 0x0e, 0x00, 0x03, -}; -static char SMI_PCR [] = { - 0x20, 0x04, 0x21, 0x30, 0x22, 0x00, 0x23, 0x00, 0x24, 0x00, -}; -static char SMI_MCR[] = { - 0x60, 0x01, 0x61, 0x00, -}; - -static char SMI_HCR[] = { - 0x80, 0xff, 0x81, 0x07, 0x82, 0x00, 0x83, 0xff, 0x84, 0xff, 0x88, 0x00, - 0x89, 0x02, 0x8a, 0x80, 0x8b, 0x01, 0x8c, 0xff, 0x8d, 0x00, -}; - - -/******************************************************************************* - * - * Write SMI ISA register - */ -static void smiWrite (unsigned short index, char reg, char val) -{ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - - out8 ((pGD->isaBase + index), reg); - out8 ((pGD->isaBase + index + 1), val); -} - -/******************************************************************************* - * - * Write a table of SMI ISA register - */ -static void smiLoadRegs ( - unsigned int iReg, - unsigned int dReg, - char *regTab, - unsigned int tabSize - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - register int i; - - for (i=0; i<tabSize; i+=2) { - if (iReg == SMI_INDX_ATTR) { - /* Reset the Flip Flop */ - in8 (SMI_ISR1); - out8 (iReg, regTab[i]); - out8 (iReg, regTab[i+1]); - } else { - out8 (iReg, regTab[i]); - out8 (dReg, regTab[i+1]); - } - } -} - -/******************************************************************************* - * - * Init capture port registers - */ -static void smiInitCapturePort (void) -{ - SmiCapturePort smiCP = { 0x01400600, 0x30, 0x40, 480, 640, 0, 0, 2560, 6 }; - register GraphicDevice *pGD = (GraphicDevice *)&smi; - register SmiCapturePort *pCP = (SmiCapturePort *)&smiCP; - - out32r ((pGD->cprBase + 0x0004), ((pCP->topClip<<16) | pCP->leftClip)); - out32r ((pGD->cprBase + 0x0008), ((pCP->srcHeight<<16) | pCP->srcWidth)); - out32r ((pGD->cprBase + 0x000c), pCP->srcBufStart1/8); - out32r ((pGD->cprBase + 0x0010), pCP->srcBufStart2/8); - out32r ((pGD->cprBase + 0x0014), pCP->srcOffset/8); - out32r ((pGD->cprBase + 0x0018), pCP->fifoControl); - out32r ((pGD->cprBase + 0x0000), pCP->control); -} - - -/******************************************************************************* - * - * Init video processor registers - */ -static void smiInitVideoProcessor (void) -{ - SmiVideoProc smiVP = { 0x100000, 0, 0, 0, 0, 1600, 0x1200543, 4, 0xededed }; - SmiVideoWin smiVW = { 0, 0, 599, 799, 0, 1600, 0, 0, 0 }; - register GraphicDevice *pGD = (GraphicDevice *)&smi; - register SmiVideoProc *pVP = (SmiVideoProc *)&smiVP; - register SmiVideoWin *pVWin = (SmiVideoWin *)&smiVW; - - pVP->width = pGD->plnSizeX * pGD->gdfBytesPP; - pVP->control |= pGD->gdfIndex << 16; - pVWin->bottom = pGD->winSizeY - 1; - pVWin->right = pGD->winSizeX - 1; - pVWin->width = pVP->width; - - /* color key */ - out32r ((pGD->vprBase + 0x0004), pVP->colorKey); - - /* color key mask */ - out32r ((pGD->vprBase + 0x0008), pVP->colorKeyMask); - - /* data src start adrs */ - out32r ((pGD->vprBase + 0x000c), pVP->start / 8); - - /* data width and offset */ - out32r ((pGD->vprBase + 0x0010), - ((pVP->offset / 8 * pGD->gdfBytesPP) << 16) | - (pGD->plnSizeX / 8 * pGD->gdfBytesPP)); - - /* video window 1 */ - out32r ((pGD->vprBase + 0x0014), - ((pVWin->top << 16) | pVWin->left)); - - out32r ((pGD->vprBase + 0x0018), - ((pVWin->bottom << 16) | pVWin->right)); - - out32r ((pGD->vprBase + 0x001c), pVWin->srcStart / 8); - - out32r ((pGD->vprBase + 0x0020), - (((pVWin->offset / 8) << 16) | (pVWin->width / 8))); - - out32r ((pGD->vprBase + 0x0024), - (((pVWin->hStretch) << 8) | pVWin->vStretch)); - - /* video window 2 */ - out32r ((pGD->vprBase + 0x0028), - ((pVWin->top << 16) | pVWin->left)); - - out32r ((pGD->vprBase + 0x002c), - ((pVWin->bottom << 16) | pVWin->right)); - - out32r ((pGD->vprBase + 0x0030), - pVWin->srcStart / 8); - - out32r ((pGD->vprBase + 0x0034), - (((pVWin->offset / 8) << 16) | (pVWin->width / 8))); - - out32r ((pGD->vprBase + 0x0038), - (((pVWin->hStretch) << 8) | pVWin->vStretch)); - - /* fifo prio control */ - out32r ((pGD->vprBase + 0x0054), pVP->fifoPrio); - - /* fifo empty request levell */ - out32r ((pGD->vprBase + 0x0058), pVP->fifoERL); - - /* conversion constant */ - out32r ((pGD->vprBase + 0x005c), pVP->YUVtoRGB); - - /* vpr control word */ - out32r ((pGD->vprBase + 0x0000), pVP->control); -} - -/****************************************************************************** - * - * Init drawing engine registers - */ -static void smiInitDrawingEngine (void) -{ - GraphicDevice *pGD = (GraphicDevice *)&smi; - unsigned int val; - - /* don't start now */ - out32r ((pGD->dprBase + 0x000c), 0x000f0000); - - /* set rop2 to copypen */ - val = 0xffff3ff0 & in32r ((pGD->dprBase + 0x000c)); - out32r ((pGD->dprBase + 0x000c), (val | 0x8000 | 0x0c)); - - /* set clip rect */ - out32r ((pGD->dprBase + 0x002c), 0); - out32r ((pGD->dprBase + 0x0030), - ((pGD->winSizeY<<16) | pGD->winSizeX * pGD->gdfBytesPP )); - - /* src row pitch */ - val = 0xffff0000 & (in32r ((pGD->dprBase + 0x0010))); - out32r ((pGD->dprBase + 0x0010), - (val | pGD->plnSizeX * pGD->gdfBytesPP)); - - /* dst row pitch */ - val = 0x0000ffff & (in32r ((pGD->dprBase + 0x0010))); - out32r ((pGD->dprBase + 0x0010), - (((pGD->plnSizeX * pGD->gdfBytesPP)<<16) | val)); - - /* window width src/dst */ - out32r ((pGD->dprBase + 0x003c), - (((pGD->plnSizeX * pGD->gdfBytesPP & 0x0fff)<<16) | - (pGD->plnSizeX * pGD->gdfBytesPP & 0x0fff))); - out16r ((pGD->dprBase + 0x001e), 0x0000); - - /* src base adrs */ - out32r ((pGD->dprBase + 0x0040), - (((pGD->frameAdrs/8) & 0x000fffff))); - - /* dst base adrs */ - out32r ((pGD->dprBase + 0x0044), - (((pGD->frameAdrs/8) & 0x000fffff))); - - /* foreground color */ - out32r ((pGD->dprBase + 0x0014), pGD->fg); - - /* background color */ - out32r ((pGD->dprBase + 0x0018), pGD->bg); - - /* xcolor */ - out32r ((pGD->dprBase + 0x0020), 0x00ffffff); - - /* xcolor mask */ - out32r ((pGD->dprBase + 0x0024), 0x00ffffff); - - /* bit mask */ - out32r ((pGD->dprBase + 0x0028), 0x00ffffff); - - /* load mono pattern */ - out32r ((pGD->dprBase + 0x0034), 0); - out32r ((pGD->dprBase + 0x0038), 0); -} - -static struct pci_device_id supported[] = { - { PCI_VENDOR_ID_SMI, PCI_DEVICE_ID_SMI_710 }, - { PCI_VENDOR_ID_SMI, PCI_DEVICE_ID_SMI_712 }, - { PCI_VENDOR_ID_SMI, PCI_DEVICE_ID_SMI_810 }, - { } -}; - -/*****************************************************************************/ -static void smiLoadMsr (struct ctfb_res_modes *mode) -{ - unsigned char h_synch_high, v_synch_high; - register GraphicDevice *pGD = (GraphicDevice *)&smi; - - h_synch_high = (mode->sync & FB_SYNC_HOR_HIGH_ACT) ? 0 : 0x40; /* horizontal Synch High active */ - v_synch_high = (mode->sync & FB_SYNC_VERT_HIGH_ACT) ? 0 : 0x80; /* vertical Synch High active */ - out8 (SMI_MISC_REG, (h_synch_high | v_synch_high | 0x29)); - /* upper64K==0x20, CLC2select==0x08, RAMenable==0x02!(todo), CGA==0x01 - * Selects the upper 64KB page.Bit5=1 - * CLK2 (left reserved in standard VGA) Bit3|2=1|0 - * Disables CPU access to frame buffer. Bit1=0 - * Sets the I/O address decode for ST01, FCR, and all CR registers - * to the 3Dx I/O address range (CGA emulation). Bit0=1 - */ -} -/*****************************************************************************/ -static void smiLoadCrt (struct ctfb_res_modes *var, int bits_per_pixel) -{ - unsigned char cr[0x7a]; - int i; - unsigned int hd, hs, he, ht, hbs, hbe; /* Horizontal. */ - unsigned int vd, vs, ve, vt, vbs, vbe; /* vertical */ - unsigned int bpp, wd, dblscan, interlaced; - - const int LineCompare = 0x3ff; - unsigned int TextScanLines = 1; /* this is in fact a vertical zoom factor */ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - - /* Horizontal */ - hd = (var->xres) / 8; /* HDisp. */ - hs = (var->xres + var->right_margin) / 8; /* HsStrt */ - he = (var->xres + var->right_margin + var->hsync_len) / 8; /* HsEnd */ - ht = (var->left_margin + var->xres + var->right_margin + var->hsync_len) / 8; /* HTotal */ - /* Blank */ - hbs = hd; - hbe = 0; /* Blank end at 0 */ - - /* Vertical */ - vd = var->yres; /* VDisplay */ - vs = var->yres + var->lower_margin; /* VSyncStart */ - ve = var->yres + var->lower_margin + var->vsync_len; /* VSyncEnd */ - vt = var->upper_margin + var->yres + var->lower_margin + var->vsync_len; /* VTotal */ - vbs = vd; - vbe = 0; - - bpp = bits_per_pixel; - dblscan = (var->vmode & FB_VMODE_DOUBLE) ? 1 : 0; - interlaced = var->vmode & FB_VMODE_INTERLACED; - - - if (bpp == 15) - bpp = 16; - wd = var->xres * bpp / 64; /* double words per line */ - if (interlaced) { /* we divide all vertical timings, exept vd */ - vs >>= 1; - vbs >>= 1; - ve >>= 1; - vt >>= 1; - } - - memset (cr, 0, sizeof (cr)); - cr[0x00] = ht - 5; - cr[0x01] = hd - 1; - cr[0x02] = hbs - 1; - cr[0x03] = (hbe & 0x1F); - cr[0x04] = hs; - cr[0x05] = ((hbe & 0x20) << 2) | (he & 0x1f); - - cr[0x06] = (vt - 2) & 0xFF; - cr[0x07] = (((vt - 2) & 0x100) >> 8) - | (((vd - 1) & 0x100) >> 7) - | ((vs & 0x100) >> 6) - | (((vbs - 1) & 0x100) >> 5) - | ((LineCompare & 0x100) >> 4) - | (((vt - 2) & 0x200) >> 4) - | (((vd - 1) & 0x200) >> 3) - | ((vs & 0x200) >> 2); - - cr[0x30] = ((vt - 2) & 0x400) >> 7 - | (((vd - 1) & 0x400) >> 8) - | (((vbs - 1) & 0x400) >> 9) - | ((vs & 0x400) >> 10) - | (interlaced) ? 0x80 : 0; - - - cr[0x08] = 0x00; - cr[0x09] = (dblscan << 7) - | ((LineCompare & 0x200) >> 3) - | (((vbs - 1) & 0x200) >> 4) - | (TextScanLines - 1); - - cr[0x10] = vs & 0xff; /* VSyncPulseStart */ - cr[0x11] = (ve & 0x0f); - cr[0x12] = (vd - 1) & 0xff; /* LineCount */ - cr[0x13] = wd & 0xff; - cr[0x14] = 0x40; - cr[0x15] = (vbs - 1) & 0xff; - cr[0x16] = vbe & 0xff; - cr[0x17] = 0xe3; /* but it does not work */ - cr[0x18] = 0xff & LineCompare; - cr[0x22] = 0x00; /* todo? */ - - - /* now set the registers */ - for (i = 0; i <= 0x18; i++) { /*CR00 .. CR18 */ - smiWrite (SMI_INDX_D4, i, cr[i]); - } - i = 0x22; /*CR22 */ - smiWrite (SMI_INDX_D4, i, cr[i]); - i = 0x30; /*CR30 */ - smiWrite (SMI_INDX_D4, i, cr[i]); -} - -/*****************************************************************************/ -#define REF_FREQ 14318180 -#define PMIN 1 -#define PMAX 255 -#define QMIN 1 -#define QMAX 63 - -static unsigned int FindPQ (unsigned int freq, unsigned int *pp, unsigned int *pq) -{ - unsigned int n = QMIN, m = 0; - long long int L = 0, P = freq, Q = REF_FREQ, H = P >> 1; - long long int D = 0x7ffffffffffffffLL; - - for (n = QMIN; n <= QMAX; n++) { - m = PMIN; /* p/q ~ freq/ref -> p*ref-freq*q ~ 0 */ - L = P * n - m * Q; - while (L > 0 && m < PMAX) { - L -= REF_FREQ; /* difference is greater as 0 subtract fref */ - m++; /* and increment m */ - } - /* difference is less or equal than 0 or m > maximum */ - if (m > PMAX) - break; /* no solution: if we increase n we get the same situation */ - /* L is <= 0 now */ - if (-L > H && m > PMIN) { /* if difference > the half fref */ - L += REF_FREQ; /* we take the situation before */ - m--; /* because its closer to 0 */ - } - L = (L < 0) ? -L : +L; /* absolute value */ - if (D < L) /* if last difference was better take next n */ - continue; - D = L; - *pp = m; - *pq = n; /* keep improved data */ - if (D == 0) - break; /* best result we can get */ - } - return (unsigned int) (0xffffffff & D); -} - -/*****************************************************************************/ -static void smiLoadCcr (struct ctfb_res_modes *var, unsigned short device_id) -{ - unsigned int p = 0; - unsigned int q = 0; - long long freq; - register GraphicDevice *pGD = (GraphicDevice *)&smi; - - smiWrite (SMI_INDX_C4, 0x65, 0); - smiWrite (SMI_INDX_C4, 0x66, 0); - smiWrite (SMI_INDX_C4, 0x68, 0x50); - if (device_id == PCI_DEVICE_ID_SMI_810) { - smiWrite (SMI_INDX_C4, 0x69, 0x3); - } else { - smiWrite (SMI_INDX_C4, 0x69, 0x0); - } - - /* Memory clock */ - switch (device_id) { - case PCI_DEVICE_ID_SMI_710 : - smiWrite (SMI_INDX_C4, 0x6a, 0x75); - break; - case PCI_DEVICE_ID_SMI_712 : - smiWrite (SMI_INDX_C4, 0x6a, 0x80); - break; - default : - smiWrite (SMI_INDX_C4, 0x6a, 0x53); - break; - } - smiWrite (SMI_INDX_C4, 0x6b, 0x15); - - /* VCLK */ - freq = 1000000000000LL / var -> pixclock; - - FindPQ ((unsigned int)freq, &p, &q); - - smiWrite (SMI_INDX_C4, 0x6c, p); - smiWrite (SMI_INDX_C4, 0x6d, q); - -} - -/******************************************************************************* - * - * Init video chip with common Linux graphic modes (lilo) - */ -void *video_hw_init (void) -{ - GraphicDevice *pGD = (GraphicDevice *)&smi; - unsigned short device_id; - pci_dev_t devbusfn; - int videomode; - unsigned long t1, hsynch, vsynch; - unsigned int pci_mem_base, *vm; - char *penv; - int tmp, i, bits_per_pixel; - struct ctfb_res_modes *res_mode; - struct ctfb_res_modes var_mode; - unsigned char videoout; - - /* Search for video chip */ - printf("Video: "); - - if ((devbusfn = pci_find_devices(supported, 0)) < 0) - { - printf ("Controller not found !\n"); - return (NULL); - } - - /* PCI setup */ - pci_write_config_dword (devbusfn, PCI_COMMAND, (PCI_COMMAND_MEMORY | PCI_COMMAND_IO)); - pci_read_config_word (devbusfn, PCI_DEVICE_ID, &device_id); - pci_read_config_dword (devbusfn, PCI_BASE_ADDRESS_0, &pci_mem_base); - pci_mem_base = pci_mem_to_phys (devbusfn, pci_mem_base); - - tmp = 0; - - videomode = CONFIG_SYS_DEFAULT_VIDEO_MODE; - /* get video mode via environment */ - if ((penv = getenv ("videomode")) != NULL) { - /* deceide if it is a string */ - if (penv[0] <= '9') { - videomode = (int) simple_strtoul (penv, NULL, 16); - tmp = 1; - } - } else { - tmp = 1; - } - if (tmp) { - /* parameter are vesa modes */ - /* search params */ - for (i = 0; i < VESA_MODES_COUNT; i++) { - if (vesa_modes[i].vesanr == videomode) - break; - } - if (i == VESA_MODES_COUNT) { - printf ("no VESA Mode found, switching to mode 0x%x ", CONFIG_SYS_DEFAULT_VIDEO_MODE); - i = 0; - } - res_mode = - (struct ctfb_res_modes *) &res_mode_init[vesa_modes[i]. - resindex]; - bits_per_pixel = vesa_modes[i].bits_per_pixel; - } else { - - res_mode = (struct ctfb_res_modes *) &var_mode; - bits_per_pixel = video_get_params (res_mode, penv); - } - - /* calculate hsynch and vsynch freq (info only) */ - t1 = (res_mode->left_margin + res_mode->xres + - res_mode->right_margin + res_mode->hsync_len) / 8; - t1 *= 8; - t1 *= res_mode->pixclock; - t1 /= 1000; - hsynch = 1000000000L / t1; - t1 *= - (res_mode->upper_margin + res_mode->yres + - res_mode->lower_margin + res_mode->vsync_len); - t1 /= 1000; - vsynch = 1000000000L / t1; - - /* fill in Graphic device struct */ - sprintf (pGD->modeIdent, "%dx%dx%d %ldkHz %ldHz", res_mode->xres, - res_mode->yres, bits_per_pixel, (hsynch / 1000), - (vsynch / 1000)); - printf ("%s\n", pGD->modeIdent); - pGD->winSizeX = res_mode->xres; - pGD->winSizeY = res_mode->yres; - pGD->plnSizeX = res_mode->xres; - pGD->plnSizeY = res_mode->yres; - switch (bits_per_pixel) { - case 8: - pGD->gdfBytesPP = 1; - pGD->gdfIndex = GDF__8BIT_INDEX; - break; - case 15: - pGD->gdfBytesPP = 2; - pGD->gdfIndex = GDF_15BIT_555RGB; - break; - case 16: - pGD->gdfBytesPP = 2; - pGD->gdfIndex = GDF_16BIT_565RGB; - break; - case 24: - pGD->gdfBytesPP = 3; - pGD->gdfIndex = GDF_24BIT_888RGB; - break; - } - - pGD->isaBase = CONFIG_SYS_ISA_IO; - pGD->pciBase = pci_mem_base; - pGD->dprBase = (pci_mem_base + 0x400000 + 0x8000); - pGD->vprBase = (pci_mem_base + 0x400000 + 0xc000); - pGD->cprBase = (pci_mem_base + 0x400000 + 0xe000); - pGD->frameAdrs = pci_mem_base; - pGD->memSize = VIDEO_MEM_SIZE; - - /* Set up hardware : select color mode, - set Register base to isa 3dx for 3?x regs*/ - out8 (SMI_MISC_REG, 0x01); - - /* Turn off display */ - smiWrite (SMI_INDX_C4, 0x01, 0x20); - - /* Unlock ext. crt regs */ - out8 (SMI_LOCK_REG, 0x40); - - /* Unlock crt regs 0-7 */ - smiWrite (SMI_INDX_D4, 0x11, 0x0e); - - /* Sytem Control Register */ - smiLoadRegs (SMI_INDX_C4, SMI_DATA_C5, SMI_SCR, sizeof(SMI_SCR)); - - /* extented CRT Register */ - smiLoadRegs (SMI_INDX_D4, SMI_DATA_D5, SMI_EXT_CRT, sizeof(SMI_EXT_CRT)); - - /* Attributes controller registers */ - smiLoadRegs (SMI_INDX_ATTR, SMI_INDX_ATTR, SMI_ATTR, sizeof(SMI_ATTR)); - - /* Graphics Controller Register */ - smiLoadRegs (SMI_INDX_CE, SMI_DATA_CF, SMI_GCR, sizeof(SMI_GCR)); - - /* Sequencer Register */ - smiLoadRegs (SMI_INDX_C4, SMI_DATA_C5, SMI_SEQR, sizeof(SMI_SEQR)); - - /* Power Control Register */ - smiLoadRegs (SMI_INDX_C4, SMI_DATA_C5, SMI_PCR, sizeof(SMI_PCR)); - - /* Memory Control Register */ - /* Register MSR62 is a power on configurable register. We don't */ - /* modify it */ - smiLoadRegs (SMI_INDX_C4, SMI_DATA_C5, SMI_MCR, sizeof(SMI_MCR)); - - /* Set misc output register */ - smiLoadMsr (res_mode); - - /* Set CRT and Clock control registers */ - smiLoadCrt (res_mode, bits_per_pixel); - - smiLoadCcr (res_mode, device_id); - - /* Hardware Cusor Register */ - smiLoadRegs (SMI_INDX_C4, SMI_DATA_C5, SMI_HCR, sizeof(SMI_HCR)); - - /* Enable Display */ - videoout = 2; /* Default output is CRT */ - if ((penv = getenv ("videoout")) != NULL) { - /* deceide if it is a string */ - videoout = (int) simple_strtoul (penv, NULL, 16); - } - smiWrite (SMI_INDX_C4, 0x31, videoout); - - /* Video processor default setup */ - smiInitVideoProcessor (); - - /* Capture port default setup */ - smiInitCapturePort (); - - /* Drawing engine default setup */ - smiInitDrawingEngine (); - - /* Turn on display */ - smiWrite (0x3c4, 0x01, 0x01); - - /* Clear video memory */ - i = pGD->memSize/4; - vm = (unsigned int *)pGD->pciBase; - while(i--) - *vm++ = 0; - return ((void*)&smi); -} - -/******************************************************************************* - * - * Drawing engine fill on screen region - */ -void video_hw_rectfill ( - unsigned int bpp, /* bytes per pixel */ - unsigned int dst_x, /* dest pos x */ - unsigned int dst_y, /* dest pos y */ - unsigned int dim_x, /* frame width */ - unsigned int dim_y, /* frame height */ - unsigned int color /* fill color */ - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - register unsigned int control; - - dim_x *= bpp; - - out32r ((pGD->dprBase + 0x0014), color); - out32r ((pGD->dprBase + 0x0004), ((dst_x<<16) | dst_y)); - out32r ((pGD->dprBase + 0x0008), ((dim_x<<16) | dim_y)); - - control = 0x0000ffff & in32r ((pGD->dprBase + 0x000c)); - - control |= 0x80010000; - - out32r ((pGD->dprBase + 0x000c), control); - - /* Wait for drawing processor */ - do - { - out8 ((pGD->isaBase + 0x3c4), 0x16); - } while (in8 (pGD->isaBase + 0x3c5) & 0x08); -} - -/******************************************************************************* - * - * Drawing engine bitblt with screen region - */ -void video_hw_bitblt ( - unsigned int bpp, /* bytes per pixel */ - unsigned int src_x, /* source pos x */ - unsigned int src_y, /* source pos y */ - unsigned int dst_x, /* dest pos x */ - unsigned int dst_y, /* dest pos y */ - unsigned int dim_x, /* frame width */ - unsigned int dim_y /* frame height */ - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - register unsigned int control; - - dim_x *= bpp; - - if ((src_y<dst_y) || ((src_y==dst_y) && (src_x<dst_x))) - { - out32r ((pGD->dprBase + 0x0000), (((src_x+dim_x-1)<<16) | (src_y+dim_y-1))); - out32r ((pGD->dprBase + 0x0004), (((dst_x+dim_x-1)<<16) | (dst_y+dim_y-1))); - control = 0x88000000; - } else { - out32r ((pGD->dprBase + 0x0000), ((src_x<<16) | src_y)); - out32r ((pGD->dprBase + 0x0004), ((dst_x<<16) | dst_y)); - control = 0x80000000; - } - - out32r ((pGD->dprBase + 0x0008), ((dim_x<<16) | dim_y)); - control |= (0x0000ffff & in32r ((pGD->dprBase + 0x000c))); - out32r ((pGD->dprBase + 0x000c), control); - - /* Wait for drawing processor */ - do - { - out8 ((pGD->isaBase + 0x3c4), 0x16); - } while (in8 (pGD->isaBase + 0x3c5) & 0x08); -} - -/******************************************************************************* - * - * Set a RGB color in the LUT (8 bit index) - */ -void video_set_lut ( - unsigned int index, /* color number */ - unsigned char r, /* red */ - unsigned char g, /* green */ - unsigned char b /* blue */ - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - - out8 (SMI_LUT_MASK, 0xff); - - out8 (SMI_LUT_START, (char)index); - - out8 (SMI_LUT_RGB, r>>2); /* red */ - udelay (10); - out8 (SMI_LUT_RGB, g>>2); /* green */ - udelay (10); - out8 (SMI_LUT_RGB, b>>2); /* blue */ - udelay (10); -} diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 8f3c680..696f77e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8279,7 +8279,6 @@ CONFIG_VIDEO_SM501_16BPP CONFIG_VIDEO_SM501_32BPP CONFIG_VIDEO_SM501_8BPP CONFIG_VIDEO_SM501_PCI -CONFIG_VIDEO_SMI_LYNXEM CONFIG_VIDEO_STD_TIMINGS CONFIG_VIDEO_SUNXI CONFIG_VIDEO_SW_CURSOR
This is not used anywhere in U-Boot.
drivers/video/Makefile | 1 - drivers/video/imx25lcdc.c | 121 ---------------------------------------------- 2 files changed, 122 deletions(-) delete mode 100644 drivers/video/imx25lcdc.c
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 951d021..d6dd436 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -40,7 +40,6 @@ obj-$(CONFIG_VIDEO_BCM2835) += bcm2835.o obj-$(CONFIG_VIDEO_COREBOOT) += coreboot.o obj-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o obj-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o -obj-$(CONFIG_VIDEO_IMX25LCDC) += imx25lcdc.o videomodes.o obj-$(CONFIG_VIDEO_LCD_ANX9804) += anx9804.o obj-$(CONFIG_VIDEO_LCD_HITACHI_TX18D42VM) += hitachi_tx18d42vm_lcd.o obj-$(CONFIG_VIDEO_LCD_SSD2828) += ssd2828.o diff --git a/drivers/video/imx25lcdc.c b/drivers/video/imx25lcdc.c deleted file mode 100644 index ef5767b..0000000 --- a/drivers/video/imx25lcdc.c +++ /dev/null @@ -1,121 +0,0 @@ -/* - * (C) Copyright 2011 - * Matthias Weisser weisserm@arcor.de - * - * SPDX-License-Identifier: GPL-2.0+ - * - * imx25lcdc.c - Graphic interface for i.MX25 lcd controller - */ - -#include <common.h> - -#include <malloc.h> -#include <asm/io.h> -#include <asm/arch/imx-regs.h> -#include <video_fb.h> -#include "videomodes.h" - -/* - * 4MB (at the end of system RAM) - */ -#define VIDEO_MEM_SIZE 0x400000 - -#define FB_SYNC_CLK_INV (1<<16) /* pixel clock inverted */ - -/* - * Graphic Device - */ -static GraphicDevice imx25fb; - -void *video_hw_init(void) -{ - struct lcdc_regs *lcdc = (struct lcdc_regs *)IMX_LCDC_BASE; - struct ccm_regs *ccm = (struct ccm_regs *)IMX_CCM_BASE; - GraphicDevice *pGD = &imx25fb; - char *s; - u32 *videomem; - - memset(pGD, 0, sizeof(GraphicDevice)); - - pGD->gdfIndex = GDF_16BIT_565RGB; - pGD->gdfBytesPP = 2; - pGD->memSize = VIDEO_MEM_SIZE; - pGD->frameAdrs = PHYS_SDRAM + PHYS_SDRAM_SIZE - VIDEO_MEM_SIZE; - - videomem = (u32 *)pGD->frameAdrs; - - s = getenv("videomode"); - if (s != NULL) { - struct ctfb_res_modes var_mode; - u32 lsr, lpcr, lhcr, lvcr; - unsigned long div; - int bpp; - - /* Disable all clocks of the LCDC */ - writel(readl(&ccm->cgr0) & ~((1<<7) | (1<<24)), &ccm->cgr0); - writel(readl(&ccm->cgr1) & ~(1<<29), &ccm->cgr1); - - bpp = video_get_params(&var_mode, s); - - if (bpp == 0) { - var_mode.xres = 320; - var_mode.yres = 240; - var_mode.pixclock = 154000; - var_mode.left_margin = 68; - var_mode.right_margin = 20; - var_mode.upper_margin = 4; - var_mode.lower_margin = 18; - var_mode.hsync_len = 40; - var_mode.vsync_len = 6; - var_mode.sync = 0; - var_mode.vmode = 0; - } - - /* Fill memory with white */ - memset(videomem, 0xFF, var_mode.xres * var_mode.yres * 2); - - imx25fb.winSizeX = var_mode.xres; - imx25fb.winSizeY = var_mode.yres; - - /* LCD base clock is 66.6MHZ. We do calculations in kHz */ - div = 66000 / (1000000000L / var_mode.pixclock); - if (div > 63) - div = 63; - if (0 == div) - div = 1; - - lsr = ((var_mode.xres / 16) << 20) | - var_mode.yres; - lpcr = (1 << 31) | - (1 << 30) | - (5 << 25) | - (1 << 23) | - (1 << 22) | - (1 << 19) | - (1 << 7) | - div; - lhcr = (var_mode.right_margin << 0) | - (var_mode.left_margin << 8) | - (var_mode.hsync_len << 26); - - lvcr = (var_mode.lower_margin << 0) | - (var_mode.upper_margin << 8) | - (var_mode.vsync_len << 26); - - writel((uint32_t)videomem, &lcdc->lssar); - writel(lsr, &lcdc->lsr); - writel(var_mode.xres * 2 / 4, &lcdc->lvpwr); - writel(lpcr, &lcdc->lpcr); - writel(lhcr, &lcdc->lhcr); - writel(lvcr, &lcdc->lvcr); - writel(0x00040060, &lcdc->ldcr); - - writel(0xA90300, &lcdc->lpccr); - - /* Ensable all clocks of the LCDC */ - writel(readl(&ccm->cgr0) | ((1<<7) | (1<<24)), &ccm->cgr0); - writel(readl(&ccm->cgr1) | (1<<29), &ccm->cgr1); - } - - return pGD; -}
This is not used in U-Boot.
Signed-off-by: Simon Glass sjg@chromium.org Acked-by: Minkyu Kang mk7.kang@samsung.com Reviewed-by: Tom Rini trini@konsulko.com ---
drivers/video/Makefile | 1 - drivers/video/cfb_console.c | 2 +- drivers/video/s3c-fb.c | 172 -------------------------------------------- 3 files changed, 1 insertion(+), 174 deletions(-) delete mode 100644 drivers/video/s3c-fb.c
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index d6dd436..2d5f607 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -49,7 +49,6 @@ obj-$(CONFIG_VIDEO_IPUV3) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o obj-$(CONFIG_VIDEO_MVEBU) += mvebu_lcd.o obj-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o obj-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o -obj-$(CONFIG_VIDEO_S3C) += s3c-fb.o videomodes.o obj-$(CONFIG_VIDEO_SANDBOX_SDL) += sandbox_sdl.o obj-$(CONFIG_VIDEO_SED13806) += sed13806.o obj-$(CONFIG_VIDEO_SM501) += sm501.o diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index a087d2e..aca4444 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -104,7 +104,7 @@ #define VIDEO_HW_BITBLT #endif
-#if defined(CONFIG_VIDEO_MXS) || defined(CONFIG_VIDEO_S3C) +#if defined(CONFIG_VIDEO_MXS) #define VIDEO_FB_16BPP_WORD_SWAP #endif
diff --git a/drivers/video/s3c-fb.c b/drivers/video/s3c-fb.c deleted file mode 100644 index bea3e69..0000000 --- a/drivers/video/s3c-fb.c +++ /dev/null @@ -1,172 +0,0 @@ -/* - * S3C24x0 LCD driver - * - * NOTE: Only 16/24 bpp operation with TFT LCD is supported. - * - * Copyright (C) 2014 Marek Vasut marex@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#include <common.h> -#include <malloc.h> -#include <video_fb.h> - -#include <linux/errno.h> -#include <asm/io.h> -#include <asm/arch/s3c24x0_cpu.h> - -#include "videomodes.h" - -static GraphicDevice panel; - -/* S3C requires the FB to be 4MiB aligned. */ -#define S3CFB_ALIGN (4 << 20) - -#define S3CFB_LCDCON1_CLKVAL(x) ((x) << 8) -#define S3CFB_LCDCON1_PNRMODE_TFT (0x3 << 5) -#define S3CFB_LCDCON1_BPPMODE_TFT_16BPP (0xc << 1) -#define S3CFB_LCDCON1_BPPMODE_TFT_24BPP (0xd << 1) - -#define S3CFB_LCDCON2_VBPD(x) ((x) << 24) -#define S3CFB_LCDCON2_LINEVAL(x) ((x) << 14) -#define S3CFB_LCDCON2_VFPD(x) ((x) << 6) -#define S3CFB_LCDCON2_VSPW(x) ((x) << 0) - -#define S3CFB_LCDCON3_HBPD(x) ((x) << 19) -#define S3CFB_LCDCON3_HOZVAL(x) ((x) << 8) -#define S3CFB_LCDCON3_HFPD(x) ((x) << 0) - -#define S3CFB_LCDCON4_HSPW(x) ((x) << 0) - -#define S3CFB_LCDCON5_BPP24BL (1 << 12) -#define S3CFB_LCDCON5_FRM565 (1 << 11) -#define S3CFB_LCDCON5_HWSWP (1 << 0) - -#define PS2KHZ(ps) (1000000000UL / (ps)) - -/* - * Example: - * setenv videomode video=ctfb:x:800,y:480,depth:16,mode:0,\ - * pclk:30066,le:41,ri:89,up:45,lo:12, - * hs:1,vs:1,sync:100663296,vmode:0 - */ -static void s3c_lcd_init(GraphicDevice *panel, - struct ctfb_res_modes *mode, int bpp) -{ - uint32_t clk_divider; - struct s3c24x0_lcd *regs = s3c24x0_get_base_lcd(); - - /* Stop the controller. */ - clrbits_le32(®s->lcdcon1, 1); - - /* Calculate clock divider. */ - clk_divider = (get_HCLK() / PS2KHZ(mode->pixclock)) / 1000; - clk_divider = DIV_ROUND_UP(clk_divider, 2); - if (clk_divider) - clk_divider -= 1; - - /* Program LCD configuration. */ - switch (bpp) { - case 16: - writel(S3CFB_LCDCON1_BPPMODE_TFT_16BPP | - S3CFB_LCDCON1_PNRMODE_TFT | - S3CFB_LCDCON1_CLKVAL(clk_divider), - ®s->lcdcon1); - writel(S3CFB_LCDCON5_HWSWP | S3CFB_LCDCON5_FRM565, - ®s->lcdcon5); - break; - case 24: - writel(S3CFB_LCDCON1_BPPMODE_TFT_24BPP | - S3CFB_LCDCON1_PNRMODE_TFT | - S3CFB_LCDCON1_CLKVAL(clk_divider), - ®s->lcdcon1); - writel(S3CFB_LCDCON5_BPP24BL, ®s->lcdcon5); - break; - } - - writel(S3CFB_LCDCON2_LINEVAL(mode->yres - 1) | - S3CFB_LCDCON2_VBPD(mode->upper_margin - 1) | - S3CFB_LCDCON2_VFPD(mode->lower_margin - 1) | - S3CFB_LCDCON2_VSPW(mode->vsync_len - 1), - ®s->lcdcon2); - - writel(S3CFB_LCDCON3_HBPD(mode->right_margin - 1) | - S3CFB_LCDCON3_HFPD(mode->left_margin - 1) | - S3CFB_LCDCON3_HOZVAL(mode->xres - 1), - ®s->lcdcon3); - - writel(S3CFB_LCDCON4_HSPW(mode->hsync_len - 1), - ®s->lcdcon4); - - /* Write FB address. */ - writel(panel->frameAdrs >> 1, ®s->lcdsaddr1); - writel((panel->frameAdrs + - (mode->xres * mode->yres * panel->gdfBytesPP)) >> 1, - ®s->lcdsaddr2); - writel(mode->xres * bpp / 16, ®s->lcdsaddr3); - - /* Start the controller. */ - setbits_le32(®s->lcdcon1, 1); -} - -void *video_hw_init(void) -{ - int bpp = -1; - char *penv; - void *fb; - struct ctfb_res_modes mode; - - puts("Video: "); - - /* Suck display configuration from "videomode" variable */ - penv = getenv("videomode"); - if (!penv) { - puts("S3CFB: 'videomode' variable not set!\n"); - return NULL; - } - - bpp = video_get_params(&mode, penv); - - /* fill in Graphic device struct */ - sprintf(panel.modeIdent, "%dx%dx%d", mode.xres, mode.yres, bpp); - - panel.winSizeX = mode.xres; - panel.winSizeY = mode.yres; - panel.plnSizeX = mode.xres; - panel.plnSizeY = mode.yres; - - switch (bpp) { - case 24: - panel.gdfBytesPP = 4; - panel.gdfIndex = GDF_32BIT_X888RGB; - break; - case 16: - panel.gdfBytesPP = 2; - panel.gdfIndex = GDF_16BIT_565RGB; - break; - default: - printf("S3CFB: Invalid BPP specified! (bpp = %i)\n", bpp); - return NULL; - } - - panel.memSize = mode.xres * mode.yres * panel.gdfBytesPP; - - /* Allocate framebuffer */ - fb = memalign(S3CFB_ALIGN, roundup(panel.memSize, S3CFB_ALIGN)); - if (!fb) { - printf("S3CFB: Error allocating framebuffer!\n"); - return NULL; - } - - /* Wipe framebuffer */ - memset(fb, 0, panel.memSize); - - panel.frameAdrs = (u32)fb; - - printf("%s\n", panel.modeIdent); - - /* Start framebuffer */ - s3c_lcd_init(&panel, &mode, bpp); - - return (void *)&panel; -}
README | 5 - drivers/video/Makefile | 1 - drivers/video/cfb_console.c | 9 -- drivers/video/sed13806.c | 286 ------------------------------------------- include/sed13806.h | 81 ------------ scripts/config_whitelist.txt | 1 - 6 files changed, 383 deletions(-) delete mode 100644 drivers/video/sed13806.c delete mode 100644 include/sed13806.h
diff --git a/README b/README index 8925837..f585705 100644 --- a/README +++ b/README @@ -1614,11 +1614,6 @@ CBFS (Coreboot Filesystem) support instead.
- Video support: - CONFIG_VIDEO_SED13806 - Enable Epson SED13806 driver. This driver supports 8bpp - and 16bpp modes defined by CONFIG_VIDEO_SED13806_8BPP - or CONFIG_VIDEO_SED13806_16BPP - CONFIG_FSL_DIU_FB Enable the Freescale DIU video driver. Reference boards for SOCs that have a DIU should define this macro to enable DIU diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 2d5f607..db34904 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -50,7 +50,6 @@ obj-$(CONFIG_VIDEO_MVEBU) += mvebu_lcd.o obj-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o obj-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o obj-$(CONFIG_VIDEO_SANDBOX_SDL) += sandbox_sdl.o -obj-$(CONFIG_VIDEO_SED13806) += sed13806.o obj-$(CONFIG_VIDEO_SM501) += sm501.o obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o videomodes.o obj-$(CONFIG_VIDEO_TEGRA20) += tegra.o diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index aca4444..ac7c402 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -95,15 +95,6 @@ #define VIDEO_HW_BITBLT #endif
-/* - * Defines for the SED13806 driver - */ -#ifdef CONFIG_VIDEO_SED13806 -#define VIDEO_FB_LITTLE_ENDIAN -#define VIDEO_HW_RECTFILL -#define VIDEO_HW_BITBLT -#endif - #if defined(CONFIG_VIDEO_MXS) #define VIDEO_FB_16BPP_WORD_SWAP #endif diff --git a/drivers/video/sed13806.c b/drivers/video/sed13806.c deleted file mode 100644 index cd7fac6..0000000 --- a/drivers/video/sed13806.c +++ /dev/null @@ -1,286 +0,0 @@ -/* - * (C) Copyright 2002 - * Stäubli Faverges - <www.staubli.com> - * Pierre AUBERT p.aubert@staubli.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ -/* Video support for Epson SED13806 chipset */ - -#include <common.h> - -#include <video_fb.h> -#include <sed13806.h> - -#define readByte(ptrReg) \ - *(volatile unsigned char *)(sed13806.isaBase + ptrReg) - -#define writeByte(ptrReg,value) \ - *(volatile unsigned char *)(sed13806.isaBase + ptrReg) = value - -#define writeWord(ptrReg,value) \ - (*(volatile unsigned short *)(sed13806.isaBase + ptrReg) = ((value >> 8 ) & 0xff) | ((value << 8) & 0xff00)) - -GraphicDevice sed13806; - -/*----------------------------------------------------------------------------- - * EpsonSetRegs -- - *----------------------------------------------------------------------------- - */ -static void EpsonSetRegs (void) -{ - /* the content of the chipset register depends on the board (clocks, ...)*/ - const S1D_REGS *preg = board_get_regs (); - while (preg -> Index) { - writeByte (preg -> Index, preg -> Value); - preg ++; - } -} - -/*----------------------------------------------------------------------------- - * video_hw_init -- - *----------------------------------------------------------------------------- - */ -void *video_hw_init (void) -{ - unsigned int *vm, i; - - memset (&sed13806, 0, sizeof (GraphicDevice)); - - /* Initialization of the access to the graphic chipset - Retreive base address of the chipset - (see board/RPXClassic/eccx.c) */ - if ((sed13806.isaBase = board_video_init ()) == 0) { - return (NULL); - } - - sed13806.frameAdrs = sed13806.isaBase + FRAME_BUFFER_OFFSET; - sed13806.winSizeX = board_get_width (); - sed13806.winSizeY = board_get_height (); - -#if defined(CONFIG_VIDEO_SED13806_8BPP) - sed13806.gdfIndex = GDF__8BIT_INDEX; - sed13806.gdfBytesPP = 1; - -#elif defined(CONFIG_VIDEO_SED13806_16BPP) - sed13806.gdfIndex = GDF_16BIT_565RGB; - sed13806.gdfBytesPP = 2; - -#else -#error Unsupported SED13806 BPP -#endif - - sed13806.memSize = sed13806.winSizeX * sed13806.winSizeY * sed13806.gdfBytesPP; - - /* Load SED registers */ - EpsonSetRegs (); - - /* (see board/RPXClassic/RPXClassic.c) */ - board_validate_screen (sed13806.isaBase); - - /* Clear video memory */ - i = sed13806.memSize/4; - vm = (unsigned int *)sed13806.frameAdrs; - while(i--) - *vm++ = 0; - - - return (&sed13806); -} -/*----------------------------------------------------------------------------- - * Epson_wait_idle -- Wait for hardware to become idle - *----------------------------------------------------------------------------- - */ -static void Epson_wait_idle (void) -{ - while (readByte (BLT_CTRL0) & 0x80); - - /* Read a word in the BitBLT memory area to shutdown the BitBLT engine */ - *(volatile unsigned short *)(sed13806.isaBase + BLT_REG); -} - -/*----------------------------------------------------------------------------- - * video_hw_bitblt -- - *----------------------------------------------------------------------------- - */ -void video_hw_bitblt ( - unsigned int bpp, /* bytes per pixel */ - unsigned int src_x, /* source pos x */ - unsigned int src_y, /* source pos y */ - unsigned int dst_x, /* dest pos x */ - unsigned int dst_y, /* dest pos y */ - unsigned int dim_x, /* frame width */ - unsigned int dim_y /* frame height */ - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&sed13806; - unsigned long srcAddr, dstAddr; - unsigned int stride = bpp * pGD -> winSizeX; - - srcAddr = (src_y * stride) + (src_x * bpp); - dstAddr = (dst_y * stride) + (dst_x * bpp); - - Epson_wait_idle (); - - writeByte(BLT_ROP,0x0C); /* source */ - writeByte(BLT_OP,0x02);/* move blit in positive direction with ROP */ - writeWord(BLT_MEM_OFF0, stride / 2); - if (pGD -> gdfIndex == GDF__8BIT_INDEX) { - writeByte(BLT_CTRL1,0x00); - } - else { - writeByte(BLT_CTRL1,0x01); - } - - writeWord(BLT_WIDTH0,(dim_x - 1)); - writeWord(BLT_HEIGHT0,(dim_y - 1)); - - /* set up blit registers */ - writeByte(BLT_SRC_ADDR0,srcAddr); - writeByte(BLT_SRC_ADDR1,srcAddr>>8); - writeByte(BLT_SRC_ADDR2,srcAddr>>16); - - writeByte(BLT_DST_ADDR0,dstAddr); - writeByte(BLT_DST_ADDR1,dstAddr>>8); - writeByte(BLT_DST_ADDR2,dstAddr>>16); - - /* Engage the blt engine */ - /* rectangular region for src and dst */ - writeByte(BLT_CTRL0,0x80); - - /* wait untill current blits finished */ - Epson_wait_idle (); -} -/*----------------------------------------------------------------------------- - * video_hw_rectfill -- - *----------------------------------------------------------------------------- - */ -void video_hw_rectfill ( - unsigned int bpp, /* bytes per pixel */ - unsigned int dst_x, /* dest pos x */ - unsigned int dst_y, /* dest pos y */ - unsigned int dim_x, /* frame width */ - unsigned int dim_y, /* frame height */ - unsigned int color /* fill color */ - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&sed13806; - unsigned long dstAddr; - unsigned int stride = bpp * pGD -> winSizeX; - - dstAddr = (dst_y * stride) + (dst_x * bpp); - - Epson_wait_idle (); - - /* set up blit registers */ - writeByte(BLT_DST_ADDR0,dstAddr); - writeByte(BLT_DST_ADDR1,dstAddr>>8); - writeByte(BLT_DST_ADDR2,dstAddr>>16); - - writeWord(BLT_WIDTH0,(dim_x - 1)); - writeWord(BLT_HEIGHT0,(dim_y - 1)); - writeWord(BLT_FGCOLOR0,color); - - writeByte(BLT_OP,0x0C); /* solid fill */ - writeWord(BLT_MEM_OFF0,stride / 2); - - if (pGD -> gdfIndex == GDF__8BIT_INDEX) { - writeByte(BLT_CTRL1,0x00); - } - else { - writeByte(BLT_CTRL1,0x01); - } - - /* Engage the blt engine */ - /* rectangular region for src and dst */ - writeByte(BLT_CTRL0,0x80); - - /* wait untill current blits finished */ - Epson_wait_idle (); -} - -/*----------------------------------------------------------------------------- - * video_set_lut -- - *----------------------------------------------------------------------------- - */ -void video_set_lut ( - unsigned int index, /* color number */ - unsigned char r, /* red */ - unsigned char g, /* green */ - unsigned char b /* blue */ - ) -{ - writeByte(REG_LUT_ADDR, index ); - writeByte(REG_LUT_DATA, r); - writeByte(REG_LUT_DATA, g); - writeByte(REG_LUT_DATA, b); -} -#ifdef CONFIG_VIDEO_HW_CURSOR -/*----------------------------------------------------------------------------- - * video_set_hw_cursor -- - *----------------------------------------------------------------------------- - */ -void video_set_hw_cursor (int x, int y) -{ - writeByte (LCD_CURSOR_XL, (x & 0xff)); - writeByte (LCD_CURSOR_XM, (x >> 8)); - writeByte (LCD_CURSOR_YL, (y & 0xff)); - writeByte (LCD_CURSOR_YM, (y >> 8)); -} - -/*----------------------------------------------------------------------------- - * video_init_hw_cursor -- - *----------------------------------------------------------------------------- - */ -void video_init_hw_cursor (int font_width, int font_height) -{ - volatile unsigned char *ptr; - unsigned char pattern; - int i; - - - /* Init cursor content - Cursor size is 64x64 pixels - Start of the cursor memory depends on panel type (dual panel ...) */ - if ((i = readByte (LCD_CURSOR_START)) == 0) { - ptr = (unsigned char *)(sed13806.frameAdrs + DEFAULT_VIDEO_MEMORY_SIZE - HWCURSORSIZE); - } - else { - ptr = (unsigned char *)(sed13806.frameAdrs + DEFAULT_VIDEO_MEMORY_SIZE - (i * 8192)); - } - - /* Fill the first line and the first empty line after cursor */ - for (i = 0, pattern = 0; i < 64; i++) { - if (i < font_width) { - /* Invert background */ - pattern |= 0x3; - - } - else { - /* Background */ - pattern |= 0x2; - } - if ((i & 3) == 3) { - *ptr = pattern; - *(ptr + font_height * 16) = 0xaa; - ptr ++; - pattern = 0; - } - pattern <<= 2; - } - - /* Duplicate this line */ - for (i = 1; i < font_height; i++) { - memcpy ((void *)ptr, (void *)(ptr - 16), 16); - ptr += 16; - } - - for (; i < 64; i++) { - memcpy ((void *)(ptr + 16), (void *)ptr, 16); - ptr += 16; - } - - /* Select cursor mode */ - writeByte (LCD_CURSOR_CNTL, 1); -} -#endif diff --git a/include/sed13806.h b/include/sed13806.h deleted file mode 100644 index 1cb0b86..0000000 --- a/include/sed13806.h +++ /dev/null @@ -1,81 +0,0 @@ -/* - * (C) Copyright 2002 - * Stäubli Faverges - <www.staubli.com> - * Pierre AUBERT p.aubert@staubli.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ -/* Video support for Epson SED13806 chipset */ - - -#ifndef _SED13806_H_ -#define _SED13806_H_ - - -/* General definitions */ -#define FRAME_BUFFER_OFFSET 0x200000 /* Frame buffer offset */ -#define TOTAL_SPACE_SIZE 0x400000 - -#define DEFAULT_VIDEO_MEMORY_SIZE 0x140000 /* Video Memory Size */ - -#define HWCURSORSIZE 1024 /* Size of memory reserved - for HW cursor*/ - -/* Offset of chipset registers */ -#define BLT_CTRL0 (0x0100) -#define BLT_CTRL1 (0x0101) -#define BLT_ROP (0x0102) -#define BLT_OP (0x0103) -#define BLT_SRC_ADDR0 (0x0104) -#define BLT_SRC_ADDR1 (0x0105) -#define BLT_SRC_ADDR2 (0x0106) -#define BLT_DST_ADDR0 (0x0108) -#define BLT_DST_ADDR1 (0x0109) -#define BLT_DST_ADDR2 (0x010A) -#define BLT_MEM_OFF0 (0x010C) -#define BLT_MEM_OFF1 (0x010D) -#define BLT_WIDTH0 (0x0110) -#define BLT_WIDTH1 (0x0111) -#define BLT_HEIGHT0 (0x0112) -#define BLT_HEIGHT1 (0x0113) -#define BLT_BGCOLOR0 (0x0114) -#define BLT_BGCOLOR1 (0x0115) -#define BLT_FGCOLOR0 (0x0118) -#define BLT_FGCOLOR1 (0x0119) - -#define BLT_REG (0x100000) - -/* Lookup table registers */ -#define REG_LUT_ADDR 0x1e2 -#define REG_LUT_DATA 0x1e4 - -/* Cursor/Ink registers */ -#define LCD_CURSOR_CNTL (0x0070) -#define LCD_CURSOR_START (0x0071) -#define LCD_CURSOR_XL (0x0072) -#define LCD_CURSOR_XM (0x0073) -#define LCD_CURSOR_YL (0x0074) -#define LCD_CURSOR_YM (0x0075) -#define LCD_CURSOR_COL0_B (0x0076) -#define LCD_CURSOR_COL0_G (0x0077) -#define LCD_CURSOR_COL0_R (0x0078) -#define LCD_CURSOR_COL1_B (0x007A) -#define LCD_CURSOR_COL1_G (0x007B) -#define LCD_CURSOR_COL1_R (0x007C) -#define LCD_CURSOR_FIFO (0x007E) - -typedef struct -{ - unsigned short Index; - unsigned char Value; -} S1D_REGS; - - -/* Board specific functions */ -unsigned int board_video_init (void); -void board_validate_screen (unsigned int base); -const S1D_REGS *board_get_regs (void); -int board_get_width (void); -int board_get_height (void); - -#endif /* _SED13806_H_ */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 696f77e..7594194 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8273,7 +8273,6 @@ CONFIG_VIDEO_MXS CONFIG_VIDEO_MXS_MODE_SYSTEM CONFIG_VIDEO_OMAP3 CONFIG_VIDEO_ONBOARD -CONFIG_VIDEO_SED13806 CONFIG_VIDEO_SM501 CONFIG_VIDEO_SM501_16BPP CONFIG_VIDEO_SM501_32BPP
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this option.
Changes in v4: None Changes in v3: None Changes in v2: None
configs/Chuwi_V7_CW0825_defconfig | 1 + configs/MSI_Primo81_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/theadorable_defconfig | 1 + drivers/video/Kconfig | 10 ++++++++++ drivers/video/cfb_console.c | 6 ------ include/configs/MIP405.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1022DS.h | 2 -- include/configs/PIP405.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/TQM5200.h | 1 - include/configs/ac14xx.h | 4 ---- include/configs/advantech_dms-ba16.h | 1 - include/configs/aria.h | 4 ---- include/configs/aristainetos-common.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/digsy_mtc.h | 1 - include/configs/ea20.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/icon.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/ipek01.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m53evk.h | 1 - include/configs/mcx.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/mt_ventoux.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mxs.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/pdm360ng.h | 1 - include/configs/pxm2.h | 1 - include/configs/rut.h | 1 - include/configs/sequoia.h | 1 - include/configs/socrates.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/tbs2910.h | 1 - include/configs/theadorable.h | 1 - include/configs/wandboard.h | 1 - scripts/config_whitelist.txt | 1 - 75 files changed, 27 insertions(+), 69 deletions(-)
diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index 8507f73..a67038b 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -22,3 +22,4 @@ CONFIG_USB_MUSB_HOST=y CONFIG_VIDEO_LCD_SPI_CS="PA0" CONFIG_VIDEO_LCD_SPI_SCLK="PA1" CONFIG_VIDEO_LCD_SPI_MOSI="PA2" +CONFIG_CFB_CONSOLE=y diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 8847271..e9d5be4 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -25,3 +25,4 @@ CONFIG_VIDEO_LCD_SPI_CS="PH9" CONFIG_VIDEO_LCD_SPI_SCLK="PH10" CONFIG_VIDEO_LCD_SPI_MOSI="PH11" CONFIG_VIDEO_LCD_SPI_MISO="PH12" +CONFIG_CFB_CONSOLE=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 426efc8..e163250 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -59,4 +59,5 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index bf630d6..6f2fe2a 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -64,5 +64,6 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_VIDEO_IVYBRIDGE_IGD=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 919bc7b..f9927ff 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -55,5 +55,6 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index d5c6ca3..2d31774 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -67,4 +67,5 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 38efbbe..4b6f24e 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -66,4 +66,5 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 4ccffe1..0d36863 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -52,4 +52,5 @@ CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 3b498c6..6babcc2 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -64,4 +64,5 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 0825bc6..3ffcbdc 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -63,4 +63,5 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index da1b00a..8ca4a25 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -50,4 +50,5 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 8ec6c91..1e76799 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -47,6 +47,7 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_EFI=y CONFIG_EFI_STUB=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 3fd9b1d..00dd846 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -47,6 +47,7 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_EFI=y CONFIG_EFI_STUB=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index c4408cf..43c3c71 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -61,4 +61,5 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 50bc016..dc38313 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -61,4 +61,5 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 7e89afc..b88be20 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -51,3 +51,4 @@ CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_VIDEO_MVEBU=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index e64a605..27fa8c8 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -41,5 +41,6 @@ CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_VIDEO_MVEBU=y +CONFIG_CFB_CONSOLE=y CONFIG_REGEX=y CONFIG_LIB_RAND=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 3249275..42db0ad 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -493,6 +493,16 @@ config CFB_CONSOLE_ANSI erase functions and limited graphics rendition control). Normal output from U-Boot will pass through this filter.
+config VGA_AS_SINGLE_DEVICE + bool "Set the video as an output-only device" + depends on CFB_CONSOLE + default y + help + If enable the framebuffer device will be initialized as an + output-only device. The Keyboard driver will not be set up. This + may be used if you have no keyboard device, or more than one + (USB Keyboard, AT Keyboard). + config VIDEO_CT69000 bool "Enable Chips & Technologies 69000 video driver" depends on VIDEO diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index ac7c402..3a8e20b 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -58,12 +58,6 @@ * info); * that fills a info buffer at i=row. * s.a: board/eltec/bab7xx. - * CONFIG_VGA_AS_SINGLE_DEVICE - If set the framebuffer device will be - * initialized as an output only device. - * The Keyboard driver will not be - * set-up. This may be used, if you have - * no or more than one Keyboard devices - * (USB Keyboard, AT Keyboard). * * CONFIG_VIDEO_SW_CURSOR: - Draws a cursor after the last * character. No blinking is provided. diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 501411b..0fc3131 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -344,7 +344,6 @@ ************************************************************/ #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #undef CONFIG_VIDEO_ONBOARD /************************************************************ diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 50e30e2..949b807 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -507,7 +507,6 @@ #if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS CONFIG_SYS_PCIE3_IO_VIRT diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index fdce09f..0e90783 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -279,7 +279,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index c0abd0e..034940a 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -466,7 +466,6 @@ #if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 8eff79e..bd2e57e 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -25,7 +25,6 @@ #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x2c000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index c4dc8da..3571836 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -379,7 +379,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS CONFIG_SYS_PCIE2_IO_VIRT diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index c4ff922..cf258de 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -380,7 +380,6 @@ #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS @@ -401,7 +400,6 @@ #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET -#define CONFIG_VGA_AS_SINGLE_DEVICE #endif
/* I2C */ diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 54dbe4c..2b3cf19 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -304,7 +304,6 @@ ************************************************************/ #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_ONBOARD /* Video controller is on-board */
diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index b5f1712..893155d 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -504,7 +504,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 3d221e3..9bed457 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -510,7 +510,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index ca87180..e82ef89 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -414,7 +414,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 50ca2d7..35019d7 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -526,7 +526,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index cc8d2cd..da8fb55 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -107,7 +107,6 @@ #define CONFIG_VIDEO_BMP_LOGO #endif
-#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #endif /* #ifndef CONFIG_TQM5200S */ diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index bdff6db..2d1c099 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -31,10 +31,6 @@
#define CONFIG_SYS_TEXT_BASE 0xFFF00000
-#if defined(CONFIG_VIDEO) -#define CONFIG_VGA_AS_SINGLE_DEVICE -#endif - #define CONFIG_SYS_MPC512X_CLKIN 25000000 /* in Hz */ #define SCFR1_IPS_DIV 2 #define SCFR1_LPC_DIV 2 diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index db50a71..854c0c4 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -273,7 +273,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/aria.h b/include/configs/aria.h index ec13b58..b08e90c 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -38,10 +38,6 @@
/* video */
-#if defined(CONFIG_VIDEO) -#define CONFIG_VGA_AS_SINGLE_DEVICE -#endif - /* CONFIG_PCI is defined at config time */
#define CONFIG_SYS_MPC512X_CLKIN 33000000 /* in Hz */ diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 0ec5732..93083fc 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -231,7 +231,6 @@ /* Framebuffer */ #define CONFIG_VIDEO_IPUV3 /* check this console not needed, after test remove it */ -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 1c76b5e..b016f20 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -89,7 +89,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 767368c..3b55d20 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -255,7 +255,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_IMX_HDMI -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR
#define CONFIG_SPLASH_SCREEN diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 23b298d..3a4da86 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -225,7 +225,6 @@ #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 47a3002..6770bd0 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -225,7 +225,6 @@ */ #define CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP
/* diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 5e1a86b..f62dba4 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -80,7 +80,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index d3ca706..8c35688 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -102,7 +102,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_CONSOLE_INFO_QUIET diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index e115fd5..9e0c945 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -118,7 +118,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 57eec0c..44155e7 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -309,7 +309,6 @@ /* Framebuffer */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index c0dadd0..83a1453 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -179,7 +179,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CMD_HDMIDETECT diff --git a/include/configs/icon.h b/include/configs/icon.h index f858b99..c38a254 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -134,7 +134,6 @@ #define VIDEO_FB_LITTLE_ENDIAN #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index ece3d45..f8dcf29 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -181,7 +181,6 @@ #define CONFIG_VIDEO_MX3 #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 447190a..d7a52a0 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -50,7 +50,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 93c7864..eb4d037 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -445,7 +445,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FSL_DCU_FB #define CONFIG_CMD_BMP -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 8da01dd..dd95a67 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -327,7 +327,6 @@
diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 58446b5..d812e66 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -360,7 +360,6 @@ #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP
diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 2fa56d6..7e05bfd 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -199,7 +199,6 @@ */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mcx.h b/include/configs/mcx.h index d113ec4..b9a2ad3 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -365,7 +365,6 @@ #define CONFIG_NET_RETRY_COUNT 10 #endif
-#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_CMD_BMP diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index ddf6c7c..0181887 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -38,7 +38,6 @@ #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_IMMR + 0x2100) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index 3ec2358..2420612 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -51,7 +51,6 @@ #define CONFIG_FPGA_DELAY() udelay(1) #define CONFIG_SYS_FPGA_PROG_FEEDBACK
-#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_CMD_BMP diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index e02decb..664e2dd 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -94,7 +94,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index f5ee433..2ee6d98 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -214,7 +214,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 158858f..82957d6 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -35,7 +35,6 @@ /* Framebuffer */ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index fb380ba..9a0b0a2 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -209,7 +209,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index e288ad8..b45ad72 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -209,7 +209,6 @@ #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 5354f4b..0cead00 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -229,7 +229,6 @@ #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index c7715a0..978b4fa 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -254,7 +254,6 @@ #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 52083c8..33459d7 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -145,7 +145,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #endif
/* MMC */ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index d18c177..63ef4e7 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -93,7 +93,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/novena.h b/include/configs/novena.h index 40194f0..0983b96 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -161,7 +161,6 @@ /* Video output */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h index efb312f..eca984a 100644 --- a/include/configs/pdm360ng.h +++ b/include/configs/pdm360ng.h @@ -40,7 +40,6 @@ /* Video */
#if defined(CONFIG_VIDEO) -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 6cc8d6c..2aa184a 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -126,7 +126,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO diff --git a/include/configs/rut.h b/include/configs/rut.h index 11f9a25..3d7b85f 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -120,7 +120,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index facfdac..153646f 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -411,7 +411,6 @@ #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_SPLASH_SCREEN -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP #endif
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index ad32b91..2328c78 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -175,7 +175,6 @@ #define CONFIG_CONSOLE_EXTRA_INFO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index c95efd9..239f84a 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -296,7 +296,6 @@ extern int soft_i2c_gpio_scl;
/* allow both serial and cfb console. */ /* stop x86 thinking in cfbconsole from trying to init a pc keyboard */ -#define CONFIG_VGA_AS_SINGLE_DEVICE
#endif /* CONFIG_VIDEO */
diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index f77e88e..cf4134f 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -77,7 +77,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 365019a..fe2ca6f 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -96,7 +96,6 @@ /* Enable LCD and reserve 512KB from top of memory*/ #define CONFIG_SYS_MEM_TOP_HIDE 0x80000
/* FPGA programming support */ diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index ab0ca15..d089b53 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -75,7 +75,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 7594194..e1fd94d 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8252,7 +8252,6 @@ CONFIG_VERY_BIG_RAM CONFIG_VEXPRESS_EXTENDED_MEMORY_MAP CONFIG_VEXPRESS_ORIGINAL_MEMORY_MAP CONFIG_VF610 -CONFIG_VGA_AS_SINGLE_DEVICE CONFIG_VID CONFIG_VIDEO_BCM2835 CONFIG_VIDEO_BMP_GZIP
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
drivers/video/cfb_console.c | 33 +----------------- drivers/video/ct69000.c | 79 -------------------------------------------- include/video_fb.h | 4 --- scripts/config_whitelist.txt | 1 - 4 files changed, 1 insertion(+), 116 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 3a8e20b..a99fc00 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -63,14 +63,6 @@ * character. No blinking is provided. * Uses the macros CURSOR_SET and * CURSOR_OFF. - * - * CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability - * of the graphic chip. Uses the macro - * CURSOR_SET. ATTENTION: If booting an - * OS, the display driver must disable - * the hardware register of the graphic - * chip. Otherwise a blinking field is - * displayed. */
#include <common.h> @@ -154,13 +146,8 @@ * CONFIG_VIDEO_SW_CURSOR: Draws a cursor after the last character. No * blinking is provided. Uses the macros CURSOR_SET * and CURSOR_OFF. - * CONFIG_VIDEO_HW_CURSOR: Uses the hardware cursor capability of the - * graphic chip. Uses the macro CURSOR_SET. - * ATTENTION: If booting an OS, the display driver - * must disable the hardware register of the graphic - * chip. Otherwise a blinking field is displayed */ -#if !defined(CONFIG_VIDEO_SW_CURSOR) && !defined(CONFIG_VIDEO_HW_CURSOR) +#if !defined(CONFIG_VIDEO_SW_CURSOR) /* no Cursor defined */ #define CURSOR_ON #define CURSOR_OFF @@ -168,10 +155,6 @@ #endif
#if defined(CONFIG_VIDEO_SW_CURSOR) -#if defined(CONFIG_VIDEO_HW_CURSOR) -#error only one of CONFIG_VIDEO_SW_CURSOR or CONFIG_VIDEO_HW_CURSOR can be \ - defined -#endif void console_cursor(int state);
#define CURSOR_ON console_cursor(1) @@ -179,17 +162,6 @@ void console_cursor(int state); #define CURSOR_SET video_set_cursor() #endif /* CONFIG_VIDEO_SW_CURSOR */
-#ifdef CONFIG_VIDEO_HW_CURSOR -#ifdef CURSOR_ON -#error only one of CONFIG_VIDEO_SW_CURSOR or CONFIG_VIDEO_HW_CURSOR can be \ - defined -#endif -#define CURSOR_ON -#define CURSOR_OFF -#define CURSOR_SET video_set_hw_cursor(console_col * VIDEO_FONT_WIDTH, \ - (console_row * VIDEO_FONT_HEIGHT) + video_logo_height) -#endif /* CONFIG_VIDEO_HW_CURSOR */ - #ifdef CONFIG_VIDEO_LOGO #ifdef CONFIG_VIDEO_BMP_LOGO #include <bmp_logo.h> @@ -2056,9 +2028,6 @@ static int video_init(void) return -1;
video_fb_address = (void *) VIDEO_FB_ADRS; -#ifdef CONFIG_VIDEO_HW_CURSOR - video_init_hw_cursor(VIDEO_FONT_WIDTH, VIDEO_FONT_HEIGHT); -#endif
cfb_do_flush_cache = cfb_fb_is_in_dram() && dcache_status();
diff --git a/drivers/video/ct69000.c b/drivers/video/ct69000.c index 349da5e..a74e4e6 100644 --- a/drivers/video/ct69000.c +++ b/drivers/video/ct69000.c @@ -804,85 +804,6 @@ video_dump_reg (void)
#endif
-#ifdef CONFIG_VIDEO_HW_CURSOR -/*************************************************************** - * Set Hardware Cursor in Pixel - */ -void -video_set_hw_cursor (int x, int y) -{ - int sig_x = 0, sig_y = 0; - if (x < 0) { - x *= -1; - sig_x = 1; - } - if (y < 0) { - y *= -1; - sig_y = 1; - } - ctWrite_i (CT_XR_O, 0xa4, x & 0xff); - ctWrite_i (CT_XR_O, 0xa5, (x >> 8) & 0x7); - ctWrite_i (CT_XR_O, 0xa6, y & 0xff); - ctWrite_i (CT_XR_O, 0xa7, (y >> 8) & 0x7); -} - -/*************************************************************** - * Init Hardware Cursor. To know the size of the Cursor, - * we have to know the Font size. - */ -void -video_init_hw_cursor (int font_width, int font_height) -{ - unsigned char xr_80; - unsigned long *curs, pattern; - int i; - int cursor_start; - GraphicDevice *pGD = (GraphicDevice *) & ctfb; - - cursor_start = pGD->dprBase; - xr_80 = ctRead_i (CT_XR_O, 0x80); - /* set start address */ - ctWrite_i (CT_XR_O, 0xa2, (cursor_start >> 8) & 0xf0); - ctWrite_i (CT_XR_O, 0xa3, (cursor_start >> 16) & 0x3f); - /* set cursor shape */ - curs = (unsigned long *) cursor_start; - i = 0; - while (i < 0x400) { - curs[i++] = 0xffffffff; /* AND mask */ - curs[i++] = 0xffffffff; /* AND mask */ - curs[i++] = 0; /* XOR mask */ - curs[i++] = 0; /* XOR mask */ - /* Transparent */ - } - pattern = 0xffffffff >> font_width; - i = 0; - while (i < (font_height * 2)) { - curs[i++] = pattern; /* AND mask */ - curs[i++] = pattern; /* AND mask */ - curs[i++] = 0; /* XOR mask */ - curs[i++] = 0; /* XOR mask */ - /* Cursor Color 0 */ - } - /* set blink rate */ - ctWrite_i (CT_FP_O, 0x19, 0xf); - - /* set cursors colors */ - xr_80 = ctRead_i (CT_XR_O, 0x80); - xr_80 |= 0x1; /* alternate palette select */ - ctWrite_i (CT_XR_O, 0x80, xr_80); - video_set_lut(4, CONFIG_SYS_CONSOLE_FG_COL, CONFIG_SYS_CONSOLE_FG_COL, - CONFIG_SYS_CONSOLE_FG_COL); - /* position 4 is color 0 cursor 0 */ - xr_80 &= 0xfe; /* normal palette select */ - ctWrite_i (CT_XR_O, 0x80, xr_80); - /* cursor enable */ - ctWrite_i (CT_XR_O, 0xa0, 0x91); - xr_80 |= 0x10; /* enable hwcursor */ - ctWrite_i (CT_XR_O, 0x80, xr_80); - video_set_hw_cursor (0, 0); -} -#endif /* CONFIG_VIDEO_HW_CURSOR */ - /*************************************************************** * Wait for BitBlt ready */ diff --git a/include/video_fb.h b/include/video_fb.h index b7e3aee..b008853 100644 --- a/include/video_fb.h +++ b/include/video_fb.h @@ -88,9 +88,5 @@ void video_set_lut ( unsigned char g, /* green */ unsigned char b /* blue */ ); -#ifdef CONFIG_VIDEO_HW_CURSOR -void video_set_hw_cursor(int x, int y); /* x y in pixel */ -void video_init_hw_cursor(int font_width, int font_height); -#endif
#endif /*_VIDEO_FB_H_ */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e1fd94d..578fb5f 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8261,7 +8261,6 @@ CONFIG_VIDEO_CORALP CONFIG_VIDEO_DA8XX CONFIG_VIDEO_DT_SIMPLEFB CONFIG_VIDEO_FONT_4X6 -CONFIG_VIDEO_HW_CURSOR CONFIG_VIDEO_IPUV3 CONFIG_VIDEO_LCD_I2C_BUS CONFIG_VIDEO_LOGO
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR
drivers/video/Kconfig | 10 ++++++++++ drivers/video/cfb_console.c | 6 ------ include/configs/MIP405.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1022DS.h | 2 -- include/configs/PIP405.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/TQM5200.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/digsy_mtc.h | 1 - include/configs/icon.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/ipek01.h | 1 - include/configs/lwmon5.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mxs.h | 1 - include/configs/nokia_rx51.h | 1 - include/configs/sequoia.h | 1 - include/configs/socrates.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/tbs2910.h | 1 - scripts/config_whitelist.txt | 1 - 33 files changed, 10 insertions(+), 38 deletions(-)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 42db0ad..7cb73a0 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -503,6 +503,16 @@ config VGA_AS_SINGLE_DEVICE may be used if you have no keyboard device, or more than one (USB Keyboard, AT Keyboard).
+config VIDEO_SW_CURSOR + bool "Enable a software cursor" + depends on CFB_CONSOLE + default y if CFB_CONSOLE + help + This draws a cursor after the last character. No blinking is + provided. This makes it possible to see the current cursor + position when entering text on the console. It is recommended to + enable this. + config VIDEO_CT69000 bool "Enable Chips & Technologies 69000 video driver" depends on VIDEO diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index a99fc00..56d3c15 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -141,12 +141,6 @@ #include <splash.h> #endif
-/* - * Cursor definition: - * CONFIG_VIDEO_SW_CURSOR: Draws a cursor after the last character. No - * blinking is provided. Uses the macros CURSOR_SET - * and CURSOR_OFF. - */ #if !defined(CONFIG_VIDEO_SW_CURSOR) /* no Cursor defined */ #define CURSOR_ON diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 0fc3131..257fa47 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -344,7 +344,6 @@ ************************************************************/ #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VIDEO_SW_CURSOR #undef CONFIG_VIDEO_ONBOARD /************************************************************ * USB support EXPERIMENTAL diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 949b807..13d6aa2 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -506,7 +506,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS CONFIG_SYS_PCIE3_IO_VIRT diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 0e90783..1de22d8 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -278,7 +278,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 034940a..102c261 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -465,7 +465,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index bd2e57e..5981755 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -24,7 +24,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x2c000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 3571836..11b10bc 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -378,7 +378,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS CONFIG_SYS_PCIE2_IO_VIRT diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index cf258de..89ef3e1 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -379,7 +379,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS @@ -396,7 +395,6 @@ #ifdef CONFIG_ATI #define VIDEO_IO_OFFSET CONFIG_SYS_PCIE1_IO_VIRT #define CONFIG_BIOSEMU -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 2b3cf19..70e75c1 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -304,7 +304,6 @@ ************************************************************/ #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_ONBOARD /* Video controller is on-board */
/************************************************************ diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 893155d..2613a0f 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -503,7 +503,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 9bed457..030d2d0 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -509,7 +509,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index e82ef89..36c69b9 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -413,7 +413,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 35019d7..fa7d6cd 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -525,7 +525,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index da8fb55..20a0575 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -107,7 +107,6 @@ #define CONFIG_VIDEO_BMP_LOGO #endif
-#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #endif /* #ifndef CONFIG_TQM5200S */
diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 3b55d20..0b3f034 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -255,7 +255,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_IMX_HDMI -#define CONFIG_VIDEO_SW_CURSOR
#define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SOURCE diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 3a4da86..d1b733d 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -224,7 +224,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index f62dba4..b91e63d 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -79,7 +79,6 @@ #define CONFIG_VIDEO_CORALP #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/icon.h b/include/configs/icon.h index c38a254..3a72a66 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -134,7 +134,6 @@ #define VIDEO_FB_LITTLE_ENDIAN #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CFG_CONSOLE_IS_IN_ENV diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index f8dcf29..4910b51 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -180,7 +180,6 @@
#define CONFIG_VIDEO_MX3 #define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index d7a52a0..7fcfb73 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -50,7 +50,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index d812e66..2e89b1a 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -360,7 +360,6 @@ #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP
/* diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index 0181887..aa915e2 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -37,7 +37,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_IMMR + 0x2100) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index b45ad72..ecaeccf 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -208,7 +208,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 0cead00..c08294c 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -228,7 +228,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 978b4fa..aea598a 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -253,7 +253,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 33459d7..df0cc23 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -144,7 +144,6 @@ /* LCD */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS -#define CONFIG_VIDEO_SW_CURSOR #endif
/* MMC */ diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 45c46a0..d1230a5 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -227,7 +227,6 @@ #define CONFIG_VIDEO_LOGO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN
/* functions for cfb_console */ diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 153646f..ff2f6c0 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -408,7 +408,6 @@ #define CONFIG_ATI_RADEON_FB /* use radeon framebuffer driver */ #define VIDEO_IO_OFFSET 0xe8000000 #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 2328c78..0d1969d 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -175,7 +175,6 @@ #define CONFIG_CONSOLE_EXTRA_INFO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 239f84a..f98a48b 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -288,7 +288,6 @@ extern int soft_i2c_gpio_scl;
#define CONFIG_VIDEO_SUNXI
-#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_STD_TIMINGS #define CONFIG_I2C_EDID diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index cf4134f..f610b71 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -76,7 +76,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 578fb5f..84ed7c9 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8278,7 +8278,6 @@ CONFIG_VIDEO_SM501_8BPP CONFIG_VIDEO_SM501_PCI CONFIG_VIDEO_STD_TIMINGS CONFIG_VIDEO_SUNXI -CONFIG_VIDEO_SW_CURSOR CONFIG_VIDEO_VCXK CONFIG_VID_FLS_ENV CONFIG_VM86
Since all boards enable this, we may as well drop the option.
This is a separate patch from the previous one, so it can be skipped if someone identifies a need.
README | 1 - drivers/video/Kconfig | 10 ---------- drivers/video/cfb_console.c | 46 ++++++++++++--------------------------------- 3 files changed, 12 insertions(+), 45 deletions(-)
diff --git a/README b/README index f585705..1140ccb 100644 --- a/README +++ b/README @@ -1623,7 +1623,6 @@ CBFS (Coreboot Filesystem) support CONFIG_VIDEO CONFIG_CMD_BMP CONFIG_CFB_CONSOLE - CONFIG_VIDEO_SW_CURSOR CONFIG_VGA_AS_SINGLE_DEVICE CONFIG_VIDEO_LOGO CONFIG_VIDEO_BMP_LOGO diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 7cb73a0..42db0ad 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -503,16 +503,6 @@ config VGA_AS_SINGLE_DEVICE may be used if you have no keyboard device, or more than one (USB Keyboard, AT Keyboard).
-config VIDEO_SW_CURSOR - bool "Enable a software cursor" - depends on CFB_CONSOLE - default y if CFB_CONSOLE - help - This draws a cursor after the last character. No blinking is - provided. This makes it possible to see the current cursor - position when entering text on the console. It is recommended to - enable this. - config VIDEO_CT69000 bool "Enable Chips & Technologies 69000 video driver" depends on VIDEO diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 56d3c15..c788651 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -58,11 +58,6 @@ * info); * that fills a info buffer at i=row. * s.a: board/eltec/bab7xx. - * - * CONFIG_VIDEO_SW_CURSOR: - Draws a cursor after the last - * character. No blinking is provided. - * Uses the macros CURSOR_SET and - * CURSOR_OFF. */
#include <common.h> @@ -141,21 +136,6 @@ #include <splash.h> #endif
-#if !defined(CONFIG_VIDEO_SW_CURSOR) -/* no Cursor defined */ -#define CURSOR_ON -#define CURSOR_OFF -#define CURSOR_SET -#endif - -#if defined(CONFIG_VIDEO_SW_CURSOR) -void console_cursor(int state); - -#define CURSOR_ON console_cursor(1) -#define CURSOR_OFF console_cursor(0) -#define CURSOR_SET video_set_cursor() -#endif /* CONFIG_VIDEO_SW_CURSOR */ - #ifdef CONFIG_VIDEO_LOGO #ifdef CONFIG_VIDEO_BMP_LOGO #include <bmp_logo.h> @@ -529,14 +509,6 @@ static void video_putchar(int xx, int yy, unsigned char c) video_drawchars(xx, yy + video_logo_height, &c, 1); }
-#if defined(CONFIG_VIDEO_SW_CURSOR) -static void video_set_cursor(void) -{ - if (cursor_state) - console_cursor(0); - console_cursor(1); -} - static void video_invertchar(int xx, int yy) { int firstx = xx * VIDEO_PIXEL_SIZE; @@ -552,7 +524,7 @@ static void video_invertchar(int xx, int yy) } }
-void console_cursor(int state) +static void console_cursor(int state) { if (cursor_state != state) { if (cursor_state) { @@ -573,7 +545,13 @@ void console_cursor(int state) if (cfb_do_flush_cache) flush_cache(VIDEO_FB_ADRS, VIDEO_SIZE); } -#endif + +static void video_set_cursor(void) +{ + if (cursor_state) + console_cursor(0); + console_cursor(1); +}
#ifndef VIDEO_HW_RECTFILL static void memsetl(int *p, int c, int v) @@ -779,7 +757,7 @@ static void parse_putc(const char c) static int nl = 1;
if (console_cursor_is_visible()) - CURSOR_OFF; + console_cursor(0);
switch (c) { case 13: /* back to first column */ @@ -820,7 +798,7 @@ static void parse_putc(const char c) }
if (console_cursor_is_visible()) - CURSOR_SET; + video_set_cursor(); }
static void video_putc(struct stdio_dev *dev, const char c) @@ -951,7 +929,7 @@ static void video_putc(struct stdio_dev *dev, const char c)
if (flush) { if (!ansi_cursor_hidden) - CURSOR_OFF; + console_cursor(0); ansi_buf_size = 0; switch (cchar) { case 'A': @@ -1025,7 +1003,7 @@ static void video_putc(struct stdio_dev *dev, const char c) break; } if (!ansi_cursor_hidden) - CURSOR_SET; + video_set_cursor(); } } else { parse_putc(c);
In size testing this series there are a few boards that do disable this option so I've dropped this patch. Thanks!
This converts the following to Kconfig: CONFIG_CONSOLE_EXTRA_INFO
configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/MiniFAP_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/TQM5200_B_HIGHBOOT_defconfig | 1 + configs/TQM5200_B_defconfig | 1 + configs/TQM5200_STK100_defconfig | 1 + configs/TQM5200_defconfig | 1 + configs/charon_defconfig | 1 + configs/icon_defconfig | 1 + configs/ipek01_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/socrates_defconfig | 1 + drivers/video/Kconfig | 10 ++++++++++ include/configs/MIP405.h | 1 - include/configs/PIP405.h | 1 - include/configs/TQM5200.h | 1 - include/configs/icon.h | 1 - include/configs/ipek01.h | 1 - include/configs/lwmon5.h | 1 - include/configs/socrates.h | 1 - scripts/config_whitelist.txt | 1 - 22 files changed, 23 insertions(+), 8 deletions(-)
diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index ddc5c36..1d72a74 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -15,4 +15,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 2610899..91d5db8 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index 31602ab..e426cd1 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 73ed894..939c58f 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index cdba626..085e4f2 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index ddd356b..54ae558 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 541a37a..5ee99e3 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index 1d31439..faf5802 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/charon_defconfig b/configs/charon_defconfig index a7e60b7..5c8b949 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/icon_defconfig b/configs/icon_defconfig index 78a9a76..e415ac5 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ipek01_defconfig b/configs/ipek01_defconfig index ee36fab..d81d95c 100644 --- a/configs/ipek01_defconfig +++ b/configs/ipek01_defconfig @@ -14,4 +14,5 @@ CONFIG_CMD_MII=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index a2259b4..0282d28 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 372918f..867db13 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 42db0ad..83dc5c8 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -503,6 +503,16 @@ config VGA_AS_SINGLE_DEVICE may be used if you have no keyboard device, or more than one (USB Keyboard, AT Keyboard).
+config CONSOLE_EXTRA_INFO + bool "Display additional board information" + depends on CFB_CONSOLE + help + Display additional board information strings that normally go to + the serial port. When this option is enabled, a board-specific + function video_get_info_str() is called to get the string for + each line of the display. The function should return the string, + which can be empty if there is nothing to display for that line. + config VIDEO_CT69000 bool "Enable Chips & Technologies 69000 video driver" depends on VIDEO diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 257fa47..43468ef 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -343,7 +343,6 @@ * Video support ************************************************************/ #define CONFIG_VIDEO_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #undef CONFIG_VIDEO_ONBOARD /************************************************************ * USB support EXPERIMENTAL diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 70e75c1..685922c 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -303,7 +303,6 @@ * Video support ************************************************************/ #define CONFIG_VIDEO_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VIDEO_ONBOARD /* Video controller is on-board */
/************************************************************ diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 20a0575..1160a97 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -102,7 +102,6 @@ #define CONFIG_VIDEO_LOGO
#ifndef CONFIG_FO300 -#define CONFIG_CONSOLE_EXTRA_INFO #else #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/icon.h b/include/configs/icon.h index 3a72a66..c60df49 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -133,7 +133,6 @@ #define CONFIG_VIDEO_SM501_PCI #define VIDEO_FB_LITTLE_ENDIAN #define CONFIG_VIDEO_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CFG_CONSOLE_IS_IN_ENV diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 7fcfb73..2de8e2e 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -49,7 +49,6 @@ #define VIDEO_FB_16BPP_WORD_SWAP #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 2e89b1a..2fed3e0 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -356,7 +356,6 @@ #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL #define CONFIG_VIDEO_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 0d1969d..0bd7f02 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -172,7 +172,6 @@ #define CONFIG_VIDEO_MB862xx_ACCEL #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP #define CONFIG_SPLASH_SCREEN diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 84ed7c9..ce5f34e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -671,7 +671,6 @@ CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_UBI CONFIG_COMPACT_FLASH CONFIG_COMPAT -CONFIG_CONSOLE_EXTRA_INFO CONFIG_CONSOLE_INFO_QUIET CONFIG_CONSOLE_SCROLL_LINES CONFIG_CONS_EXTC_PINSEL
This should be defined in a header file so that arguments are checked. Move it to video.h.
Changes in v4: None Changes in v3: None Changes in v2: None
board/liebherr/lwmon5/lwmon5.c | 1 + board/mosaixtech/icon/icon.c | 1 + board/mpl/common/common_util.c | 1 + board/tqc/tqm5200/tqm5200.c | 1 + drivers/video/cfb_console.c | 25 ++++++++----------------- include/video.h | 11 +++++++++++ 6 files changed, 23 insertions(+), 17 deletions(-)
diff --git a/board/liebherr/lwmon5/lwmon5.c b/board/liebherr/lwmon5/lwmon5.c index 8ad6712..bb99a3b 100644 --- a/board/liebherr/lwmon5/lwmon5.c +++ b/board/liebherr/lwmon5/lwmon5.c @@ -13,6 +13,7 @@ #include <asm/io.h> #include <post.h> #include <flash.h> +#include <video.h> #include <mtd/cfi_flash.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/mosaixtech/icon/icon.c b/board/mosaixtech/icon/icon.c index 1795464..7558234 100644 --- a/board/mosaixtech/icon/icon.c +++ b/board/mosaixtech/icon/icon.c @@ -11,6 +11,7 @@ #include <libfdt.h> #include <fdt_support.h> #include <netdev.h> +#include <video.h> #include <asm/processor.h> #include <asm/io.h> #include <asm/ppc4xx-gpio.h> diff --git a/board/mpl/common/common_util.c b/board/mpl/common/common_util.c index 3c110fa..a6edb6d 100644 --- a/board/mpl/common/common_util.c +++ b/board/mpl/common/common_util.c @@ -15,6 +15,7 @@ #include <pci.h> #include <malloc.h> #include <bzlib.h> +#include <video.h>
#ifdef CONFIG_PIP405 #include "../pip405/pip405.h" diff --git a/board/tqc/tqm5200/tqm5200.c b/board/tqc/tqm5200/tqm5200.c index 8b82c34..fef9d2b 100644 --- a/board/tqc/tqm5200/tqm5200.c +++ b/board/tqc/tqm5200/tqm5200.c @@ -18,6 +18,7 @@ #include <asm/processor.h> #include <libfdt.h> #include <netdev.h> +#include <video.h>
#ifdef CONFIG_VIDEO_SM501 #include <sm501.h> diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index c788651..b02a153 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -64,6 +64,7 @@ #include <fdtdec.h> #include <version.h> #include <malloc.h> +#include <video.h> #include <linux/compiler.h>
/* @@ -215,16 +216,6 @@ #endif #endif
-#ifdef CONFIG_CONSOLE_EXTRA_INFO -/* - * setup a board string: type, speed, etc. - * - * line_number: location to place info string beside logo - * info: buffer for info string - */ -extern void video_get_info_str(int line_number, char *info); -#endif - DECLARE_GLOBAL_DATA_PTR;
/* Locals */ @@ -801,7 +792,7 @@ static void parse_putc(const char c) video_set_cursor(); }
-static void video_putc(struct stdio_dev *dev, const char c) +static void cfb_video_putc(struct stdio_dev *dev, const char c) { #ifdef CONFIG_CFB_CONSOLE_ANSI int i; @@ -1015,7 +1006,7 @@ static void video_putc(struct stdio_dev *dev, const char c) flush_cache(VIDEO_FB_ADRS, VIDEO_SIZE); }
-static void video_puts(struct stdio_dev *dev, const char *s) +static void cfb_video_puts(struct stdio_dev *dev, const char *s) { int flush = cfb_do_flush_cache; int count = strlen(s); @@ -1024,7 +1015,7 @@ static void video_puts(struct stdio_dev *dev, const char *s) cfb_do_flush_cache = 0;
while (count--) - video_putc(dev, *s++); + cfb_video_putc(dev, *s++);
if (flush) { cfb_do_flush_cache = flush; @@ -1991,7 +1982,7 @@ void video_clear(void) #endif }
-static int video_init(void) +static int cfg_video_init(void) { unsigned char color8;
@@ -2117,7 +2108,7 @@ int drv_video_init(void) return 0;
/* Init video chip - returns with framebuffer cleared */ - if (video_init() == -1) + if (cfg_video_init() == -1) return 0;
if (board_cfb_skip()) @@ -2142,8 +2133,8 @@ int drv_video_init(void) memset(&console_dev, 0, sizeof(console_dev)); strcpy(console_dev.name, "vga"); console_dev.flags = DEV_FLAGS_OUTPUT; - console_dev.putc = video_putc; /* 'putc' function */ - console_dev.puts = video_puts; /* 'puts' function */ + console_dev.putc = cfb_video_putc; /* 'putc' function */ + console_dev.puts = cfb_video_puts; /* 'puts' function */
#if !defined(CONFIG_VGA_AS_SINGLE_DEVICE) if (have_keyboard && keyboard_ok) { diff --git a/include/video.h b/include/video.h index 0d5bd21..5b4e78b 100644 --- a/include/video.h +++ b/include/video.h @@ -245,6 +245,17 @@ int lg4573_spi_startup(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int spi_mode); #endif
+/* + * video_get_info_str() - obtain a board string: type, speed, etc. + * + * This is called if CONFIG_CONSOLE_EXTRA_INFO is enabled. + * + * line_number: location to place info string beside logo + * info: buffer for info string (empty if nothing to display on this + * line) + */ +void video_get_info_str(int line_number, char *info); + #endif /* CONFIG_DM_VIDEO */
#endif
This is not used in U-Boot. Drop it.
include/configs/edminiv2.h | 1 - include/configs/km/km_arm.h | 1 - include/configs/mv-common.h | 1 - include/configs/mvebu_db-88f3720.h | 1 - include/configs/mvebu_db-88f7040.h | 1 - scripts/config_whitelist.txt | 1 - 6 files changed, 6 deletions(-)
diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 1671438..af7b470 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -208,7 +208,6 @@ /* * Other required minimal configurations */ -#define CONFIG_CONSOLE_INFO_QUIET /* some code reduction */ #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ #define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ #define CONFIG_NR_DRAM_BANKS 1 diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index c55c5d2..98aec7c 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -146,7 +146,6 @@ /* * Other required minimal configurations */ -#define CONFIG_CONSOLE_INFO_QUIET /* some code reduction */ #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ #define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ #define CONFIG_NR_DRAM_BANKS 4 diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index 73e9a03..b28030c 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -83,7 +83,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_CONSOLE_INFO_QUIET /* some code reduction */ #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ #define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ #define CONFIG_BOARD_EARLY_INIT_F /* call board_init_f for early inits */ diff --git a/include/configs/mvebu_db-88f3720.h b/include/configs/mvebu_db-88f3720.h index e785f24..7a50c4e 100644 --- a/include/configs/mvebu_db-88f3720.h +++ b/include/configs/mvebu_db-88f3720.h @@ -51,7 +51,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_CONSOLE_INFO_QUIET /* some code reduction */ #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ #define CONFIG_BOARD_EARLY_INIT_F /* call board_init_f for early inits */ #define CONFIG_SYS_LOAD_ADDR 0x00800000 /* default load adr- 8M */ diff --git a/include/configs/mvebu_db-88f7040.h b/include/configs/mvebu_db-88f7040.h index cfb0191..709098f 100644 --- a/include/configs/mvebu_db-88f7040.h +++ b/include/configs/mvebu_db-88f7040.h @@ -54,7 +54,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_CONSOLE_INFO_QUIET /* some code reduction */ #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ #define CONFIG_BOARD_EARLY_INIT_F /* call board_init_f for early inits */ #define CONFIG_SYS_LOAD_ADDR 0x00800000 /* default load adr- 8M */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index ce5f34e..fbf1b3c 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -671,7 +671,6 @@ CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_UBI CONFIG_COMPACT_FLASH CONFIG_COMPAT -CONFIG_CONSOLE_INFO_QUIET CONFIG_CONSOLE_SCROLL_LINES CONFIG_CONS_EXTC_PINSEL CONFIG_CONS_EXTC_RATE
This converts the following to Kconfig: CONFIG_LCD
configs/TQM823L_LCD_defconfig | 3 ++- configs/TTTech_defconfig | 3 ++- configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cm_t3517_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/snow_defconfig | 1 + configs/spring_defconfig | 1 + configs/wtk_defconfig | 3 ++- configs/zipitz2_defconfig | 1 + drivers/video/Kconfig | 8 ++++++++ include/configs/M52277EVB.h | 1 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/brppt1.h | 1 - include/configs/brxre1.h | 1 - include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/exynos5-dt-common.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/peach-pi.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/rpi.h | 1 - include/configs/sama5d2_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/smdk5250.h | 1 - include/configs/smdk5420.h | 1 - include/configs/zipitz2.h | 1 - scripts/config_whitelist.txt | 1 - 77 files changed, 61 insertions(+), 29 deletions(-)
diff --git a/configs/TQM823L_LCD_defconfig b/configs/TQM823L_LCD_defconfig index 38f5119..9bc8c73 100644 --- a/configs/TQM823L_LCD_defconfig +++ b/configs/TQM823L_LCD_defconfig @@ -2,7 +2,7 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="LCD,NEC_NL6448BC20" +CONFIG_SYS_EXTRA_OPTIONS="NEC_NL6448BC20" CONFIG_BOOTDELAY=5 CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y @@ -10,4 +10,5 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/TTTech_defconfig b/configs/TTTech_defconfig index e545848..9649012 100644 --- a/configs/TTTech_defconfig +++ b/configs/TTTech_defconfig @@ -2,7 +2,7 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ104V7DS01" +CONFIG_SYS_EXTRA_OPTIONS="SHARP_LQ104V7DS01" CONFIG_BOOTDELAY=5 CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y @@ -10,4 +10,5 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 31c18e5..aed1e74 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 3338e4b..d5a23f8 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 92c2a73..4ca9fdc 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 7f1a6e5..b99ca91 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -22,4 +22,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 7f1a6e5..b99ca91 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -22,4 +22,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index c17f702..444f8ae 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -22,4 +22,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index f6d8a63..5ad1c69 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -22,4 +22,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 2e056de..a9a3d1b 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -22,4 +22,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 4e1d27b..1f1b624 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index e6b59da..7c5548a 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index efa4101..85077c7 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index c655c81..7c7db6b 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -30,4 +30,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index e1d8a17..deffaaf 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -28,4 +28,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 63b5ba3..73a36ec 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -22,4 +22,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 2914685..3131641 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -28,4 +28,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index c248b2e..40c9856 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -29,4 +29,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index e1597aa..b1b6dd4 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index 443f06f..ea7ef47 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 9450da9..34ddd39 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 516f54b..7625b92 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -24,4 +24,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 0a181b4..e60130b 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -24,4 +24,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index a6204b6..a4356ab 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -30,4 +30,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 9b1238e..1663aad 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -31,4 +31,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 7277cd1..336ef02 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -47,4 +47,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 3e02895..22e43bc 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -47,4 +47,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index d7d0f66..230af46 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -55,4 +55,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 5acc776..4f91ec7 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -46,5 +46,6 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index b131b27..3bca796 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -23,4 +23,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 9a2f624..0fbc08b 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -24,4 +24,5 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index e5f34a1..df160ae 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -67,5 +67,6 @@ CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y +CONFIG_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index ddcb451..abc23c4 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -67,5 +67,6 @@ CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y +CONFIG_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 8f6a959..351088f 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -31,4 +31,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index b70263a..609547f 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -18,3 +18,4 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 7ffde4b..be58975 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -17,3 +17,4 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index ae391d4..13016c1 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -23,5 +23,6 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 802ac3b..e27d24c 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -25,5 +25,6 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index 5971877..9536bd8 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -24,5 +24,6 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index e863e5e..3c8fdc2 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -23,5 +23,6 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 075c8d1..e889918 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -32,4 +32,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 0a05932..4fd0795 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -30,4 +30,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 3ca8fbf..26dd5b1 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -31,4 +31,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 562d21f..917f351 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -33,4 +33,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 7490332..85a2175 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -31,4 +31,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 00a870b..7775a22 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -32,4 +32,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index a5754f8..c5d8d39 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -75,5 +75,6 @@ CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_VIDEO_BRIDGE_NXP_PTN3460=y +CONFIG_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 0c394c8..8aab175 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -74,5 +74,6 @@ CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y +CONFIG_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/wtk_defconfig b/configs/wtk_defconfig index 336d8e4..3e4f386 100644 --- a/configs/wtk_defconfig +++ b/configs/wtk_defconfig @@ -2,7 +2,7 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ065T9DR51U" +CONFIG_SYS_EXTRA_OPTIONS="SHARP_LQ065T9DR51U" CONFIG_BOOTDELAY=5 CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y @@ -10,4 +10,5 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig index d9819a5..5899215 100644 --- a/configs/zipitz2_defconfig +++ b/configs/zipitz2_defconfig @@ -15,5 +15,6 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 83dc5c8..ee3f27a 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -562,4 +562,12 @@ config SYS_CONSOLE_FG_COL the background and foreground to the same colour or you will see nothing.
+config LCD + bool "Enable legacy LCD support" + help + Define this to enable LCD support (for output to LCD display). + You will also need to select an LCD driver using an additional + CONFIG option. See the README for details. Drives which have been + converted to driver model will instead used CONFIG_DM_VIDEO. + endmenu diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index 898ed7d..6230948 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -84,7 +84,6 @@
/* LCD */ #ifdef CONFIG_CMD_BMP -#define CONFIG_LCD #define CONFIG_SPLASH_SCREEN #define CONFIG_LCD_LOGO #define CONFIG_SHARP_LQ035Q7DH06 diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 39d81e4..cc37236 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -47,7 +47,6 @@ #define CONFIG_BAUDRATE 115200
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO #undef LCD_TEST_PATTERN diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 7c169e9..cc1695e 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -57,7 +57,6 @@ #define CONFIG_BAUDRATE 115200
/* LCD */ -#define CONFIG_LCD 1 #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO 1 #undef LCD_TEST_PATTERN diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 9945bd1..5e37e2a 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -40,7 +40,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO #undef LCD_TEST_PATTERN diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 424dda6..7fddf4f 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -39,7 +39,6 @@ #define CONFIG_BAUDRATE 115200
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 24 #define CONFIG_LCD_LOGO diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 08fd8c4..5b3a3d1 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -44,7 +44,6 @@ #define CONFIG_BAUDRATE 115200
/* LCD */ -#define CONFIG_LCD 1 #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO 1 #undef LCD_TEST_PATTERN diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index c5d50e2..db9bdef 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -35,7 +35,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 24 #define CONFIG_LCD_LOGO diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index ccc5bb4..0e13864 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -16,7 +16,6 @@ #include <configs/bur_am335x_common.h> /* ------------------------------------------------------------------------- */ #define CONFIG_AM335X_LCD -#define CONFIG_LCD #define CONFIG_LCD_ROTATION #define CONFIG_LCD_DT_SIMPLEFB #define CONFIG_SYS_WHITE_ON_BLACK diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index 1e8426f..b9f69be 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -16,7 +16,6 @@ #include <configs/bur_am335x_common.h> /* ------------------------------------------------------------------------- */ #define CONFIG_AM335X_LCD -#define CONFIG_LCD #define CONFIG_LCD_NOSTDOUT #define CONFIG_SYS_WHITE_ON_BLACK #define LCD_BPP LCD_COLOR32 diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 4ffaded..6caac1d 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -280,7 +280,6 @@ #define CONFIG_VIDEO_OMAP3 #define LCD_BPP LCD_COLOR16
-#define CONFIG_LCD #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SOURCE #define CONFIG_CMD_BMP diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index c1d7538..edb52be 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -281,7 +281,6 @@ #define CONFIG_VIDEO_OMAP3 #define LCD_BPP LCD_COLOR16
-#define CONFIG_LCD #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASHIMAGE_GUARD #define CONFIG_CMD_BMP diff --git a/include/configs/exynos5-dt-common.h b/include/configs/exynos5-dt-common.h index 3d81f94..7cb3a29 100644 --- a/include/configs/exynos5-dt-common.h +++ b/include/configs/exynos5-dt-common.h @@ -27,7 +27,6 @@ #define CONFIG_BOARD_COMMON
/* Display */ -#define CONFIG_LCD #ifdef CONFIG_LCD #define CONFIG_EXYNOS_FB #define CONFIG_EXYNOS_DP diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 8fe5db6..91037d6 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -21,7 +21,6 @@ */ #define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE -/*#define CONFIG_LCD*/
/* * Memory configurations diff --git a/include/configs/peach-pi.h b/include/configs/peach-pi.h index b01fe4c..296d77a 100644 --- a/include/configs/peach-pi.h +++ b/include/configs/peach-pi.h @@ -30,7 +30,6 @@ #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
/* Display */ -#define CONFIG_LCD #ifdef CONFIG_LCD #define CONFIG_EXYNOS_FB #define CONFIG_EXYNOS_DP diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 63fe444..64db0da 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -43,7 +43,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO #undef LCD_TEST_PATTERN diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 4793b13..c19e7dc 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -149,7 +149,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ -#define CONFIG_LCD 1 #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO 1 #undef LCD_TEST_PATTERN diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index db38b73..eddc81a 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -162,7 +162,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ -#define CONFIG_LCD 1 #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO 1 #undef LCD_TEST_PATTERN diff --git a/include/configs/rpi.h b/include/configs/rpi.h index decf35a..4ad98e1 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -71,7 +71,6 @@ /* GPIO */ #define CONFIG_BCM2835_GPIO /* LCD */ -#define CONFIG_LCD #define CONFIG_LCD_DT_SIMPLEFB #define LCD_BPP LCD_COLOR16 /* diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index c20d6f9..30fb9a4 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -86,7 +86,6 @@ #define CONFIG_MACB_SEARCH_PHY
/* LCD */ -/* #define CONFIG_LCD */
#ifdef CONFIG_LCD #define LCD_BPP LCD_COLOR16 diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index c149e5b..1b053a6 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -39,7 +39,6 @@ #define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 24 #define CONFIG_LCD_LOGO diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index 0890cf5..249e661 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -94,7 +94,6 @@ #define CONFIG_MACB_SEARCH_PHY
/* LCD */ -/* #define CONFIG_LCD */ #ifdef CONFIG_LCD #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 24 diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 36da48c..00ed400 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -94,7 +94,6 @@ #define CONFIG_MACB_SEARCH_PHY
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 18 #define CONFIG_LCD_LOGO diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 5c60887..c152459 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -13,7 +13,6 @@ #include <configs/exynos5-dt-common.h> #include <configs/exynos5-common.h>
-#undef CONFIG_LCD #undef CONFIG_EXYNOS_FB #undef CONFIG_EXYNOS_DP #undef CONFIG_KEYBOARD diff --git a/include/configs/smdk5420.h b/include/configs/smdk5420.h index d8d095f..502772c 100644 --- a/include/configs/smdk5420.h +++ b/include/configs/smdk5420.h @@ -13,7 +13,6 @@ #include <configs/exynos5-dt-common.h> #include <configs/exynos5-common.h>
diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 6e83cc9..ed2c9ac 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -75,7 +75,6 @@ */ #ifdef CONFIG_CMD_SPI #define CONFIG_SOFT_SPI -#define CONFIG_LCD #define CONFIG_LCD_ROTATION #define CONFIG_PXA_LCD #define CONFIG_LMS283GF05 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index fbf1b3c..fbfbe27 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1876,7 +1876,6 @@ CONFIG_LAYERSCAPE_NS_ACCESS CONFIG_LBA48 CONFIG_LBD CONFIG_LBDAF -CONFIG_LCD CONFIG_LCD_ALIGNMENT CONFIG_LCD_BMP_RLE8 CONFIG_LCD_DT_SIMPLEFB
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
Reviewed-by: Jagan Teki jteki@openedev.com
thanks!
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Jagan Teki jteki@openedev.com
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
README | 6 ------ configs/bayleybay_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/harmony_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/paz00_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/rock2_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/ventana_defconfig | 1 + drivers/video/Kconfig | 10 ++++++++++ include/configs/chromebook_jerry.h | 1 - include/configs/colibri_pxa270.h | 1 - include/configs/colibri_t20.h | 1 - include/configs/evb_rk3288.h | 1 - include/configs/evb_rk3399.h | 1 - include/configs/fennec_rk3288.h | 1 - include/configs/firefly-rk3288.h | 1 - include/configs/harmony.h | 1 - include/configs/miniarm_rk3288.h | 1 - include/configs/paz00.h | 1 - include/configs/popmetal_rk3288.h | 1 - include/configs/rock2.h | 1 - include/configs/rpi.h | 1 - include/configs/seaboard.h | 1 - include/configs/ventana.h | 1 - include/configs/x86-common.h | 5 ----- include/lcd_console.h | 3 --- scripts/config_whitelist.txt | 1 - 43 files changed, 33 insertions(+), 30 deletions(-)
diff --git a/README b/README index 1140ccb..0257c80 100644 --- a/README +++ b/README @@ -1692,12 +1692,6 @@ CBFS (Coreboot Filesystem) support here, since it is cheaper to change data cache settings on a per-section basis.
- CONFIG_CONSOLE_SCROLL_LINES - - When the console need to be scrolled, this is the number of - lines to scroll by. It defaults to 1. Increasing this makes - the console jump but can help speed up operation when scrolling - is slow.
CONFIG_LCD_ROTATION
diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index e163250..21b0135 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -60,4 +60,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index b3c6970..8b2f53f 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -79,6 +79,7 @@ CONFIG_SYSRESET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y +CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 6f2fe2a..da251a1 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -65,5 +65,6 @@ CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_VIDEO_IVYBRIDGE_IGD=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 1822970..7e9857e 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -60,5 +60,6 @@ CONFIG_DM_VIDEO=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_VIDEO_BROADWELL_IGD=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index f9927ff..5566508 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -56,5 +56,6 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index d070a27..897cd01 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -54,3 +54,4 @@ CONFIG_G_DNL_VENDOR_NUM=0x0955 CONFIG_G_DNL_PRODUCT_NUM=0x701a CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 2d31774..af96a00 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -68,4 +68,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 4b6f24e..3d67935 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -67,4 +67,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 67febaa..99e9a94 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -44,5 +44,6 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_COREBOOT=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 0d36863..8753271 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -53,4 +53,5 @@ CONFIG_DM_VIDEO=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 6babcc2..67ab280 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -65,4 +65,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 61c46de..d0b9595 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -68,6 +68,7 @@ CONFIG_SYSRESET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y +CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index e1691f6..5c76af3 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -41,3 +41,4 @@ CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 3ffcbdc..e327f77 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -64,4 +64,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 815cf4c..5e82a01 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -39,3 +39,4 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 8ca4a25..091c814 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -51,4 +51,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 1e76799..e52bfa4 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -48,6 +48,7 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_EFI=y CONFIG_EFI_STUB=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 00dd846..d06686f 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -48,6 +48,7 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_EFI=y CONFIG_EFI_STUB=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index def639f..ee00040 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -66,6 +66,7 @@ CONFIG_SYSRESET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y +CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 326ec28..2457b11 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -42,3 +42,4 @@ CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 43c3c71..097720d 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -62,4 +62,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index dc38313..63c65b7 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -62,4 +62,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index a3b1b42..33ca0bd 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -41,3 +41,4 @@ CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index ee3f27a..573e781 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -513,6 +513,16 @@ config CONSOLE_EXTRA_INFO each line of the display. The function should return the string, which can be empty if there is nothing to display for that line.
+config CONSOLE_SCROLL_LINES + int "Number of lines to scroll the console by" + depends on CFB_CONSOLE || DM_VIDEO || LCD + default 1 + help + When the console need to be scrolled, this is the number of + lines to scroll by. It defaults to 1. Increasing this makes the + console jump but can help speed up operation when scrolling + is slow. + config VIDEO_CT69000 bool "Enable Chips & Technologies 69000 video driver" depends on VIDEO diff --git a/include/configs/chromebook_jerry.h b/include/configs/chromebook_jerry.h index 180527a..b15cc26 100644 --- a/include/configs/chromebook_jerry.h +++ b/include/configs/chromebook_jerry.h @@ -23,6 +23,5 @@ #define CONFIG_KEYBOARD
#define CONFIG_SYS_WHITE_ON_BLACK -#define CONFIG_CONSOLE_SCROLL_LINES 10
#endif diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index ba8d93c..429f571 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -67,7 +67,6 @@ #define CONFIG_PXA_LCD #define CONFIG_PXA_VGA #define CONFIG_SYS_WHITE_ON_BLACK -#define CONFIG_CONSOLE_SCROLL_LINES 10 #define CONFIG_CMD_BMP #define CONFIG_LCD_LOGO #endif diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index b299e15..4634989 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -47,7 +47,6 @@
/* LCD support */ #define CONFIG_SYS_WHITE_ON_BLACK -#define CONFIG_CONSOLE_SCROLL_LINES 10 #define CONFIG_CMD_BMP #define CONFIG_LCD_LOGO
diff --git a/include/configs/evb_rk3288.h b/include/configs/evb_rk3288.h index 390c243..77b647e 100644 --- a/include/configs/evb_rk3288.h +++ b/include/configs/evb_rk3288.h @@ -19,6 +19,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/evb_rk3399.h b/include/configs/evb_rk3399.h index 047850a..f453640 100644 --- a/include/configs/evb_rk3399.h +++ b/include/configs/evb_rk3399.h @@ -21,6 +21,5 @@ #define SDRAM_BANK_SIZE (2UL << 30)
#endif diff --git a/include/configs/fennec_rk3288.h b/include/configs/fennec_rk3288.h index 390c243..77b647e 100644 --- a/include/configs/fennec_rk3288.h +++ b/include/configs/fennec_rk3288.h @@ -19,6 +19,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/firefly-rk3288.h b/include/configs/firefly-rk3288.h index ee924c3..14fdead 100644 --- a/include/configs/firefly-rk3288.h +++ b/include/configs/firefly-rk3288.h @@ -23,6 +23,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/harmony.h b/include/configs/harmony.h index 2ecae65..3d6b5fc 100644 --- a/include/configs/harmony.h +++ b/include/configs/harmony.h @@ -54,7 +54,6 @@
#include "tegra-common-post.h"
diff --git a/include/configs/miniarm_rk3288.h b/include/configs/miniarm_rk3288.h index aa259db..9451365 100644 --- a/include/configs/miniarm_rk3288.h +++ b/include/configs/miniarm_rk3288.h @@ -24,6 +24,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/paz00.h b/include/configs/paz00.h index 5e59ccb..a8bb3ff 100644 --- a/include/configs/paz00.h +++ b/include/configs/paz00.h @@ -45,7 +45,6 @@
diff --git a/include/configs/popmetal_rk3288.h b/include/configs/popmetal_rk3288.h index 390c243..77b647e 100644 --- a/include/configs/popmetal_rk3288.h +++ b/include/configs/popmetal_rk3288.h @@ -19,6 +19,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/rock2.h b/include/configs/rock2.h index 99d6915..b9c2290 100644 --- a/include/configs/rock2.h +++ b/include/configs/rock2.h @@ -32,6 +32,5 @@ #endif
#endif diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 4ad98e1..7fe469c 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -81,7 +81,6 @@ #define CONFIG_FB_ADDR 0 #define CONFIG_VIDEO_BCM2835 #define CONFIG_SYS_WHITE_ON_BLACK -#define CONFIG_CONSOLE_SCROLL_LINES 10
/* SD/MMC configuration */ #define CONFIG_GENERIC_MMC diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index 3076ef4..fe68437 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -61,7 +61,6 @@
/* NAND support */ #define CONFIG_CMD_NAND diff --git a/include/configs/ventana.h b/include/configs/ventana.h index b282467..d3843d4 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -46,7 +46,6 @@
diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index d483232..e8e199a 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -126,11 +126,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x20000000
/*----------------------------------------------------------------------- - * Video Configuration - */ -#define CONFIG_CONSOLE_SCROLL_LINES 5 - -/*----------------------------------------------------------------------- * CPU Features */
diff --git a/include/lcd_console.h b/include/lcd_console.h index 2e0f56f..eac227f 100644 --- a/include/lcd_console.h +++ b/include/lcd_console.h @@ -5,9 +5,6 @@ */
/* By default we scroll by a single line */ -#ifndef CONFIG_CONSOLE_SCROLL_LINES -#define CONFIG_CONSOLE_SCROLL_LINES 1 -#endif
struct console_t { short curr_col, curr_row; diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index fbfbe27..bc37626 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -671,7 +671,6 @@ CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_UBI CONFIG_COMPACT_FLASH CONFIG_COMPAT -CONFIG_CONSOLE_SCROLL_LINES CONFIG_CONS_EXTC_PINSEL CONFIG_CONS_EXTC_RATE CONFIG_CONS_NONE
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_ENV_OVERWRITE
README | 3 --- common/Kconfig | 9 +++++++++ configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + include/configs/MIP405.h | 1 - include/configs/MigoR.h | 1 - include/configs/PIP405.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/ecovec.h | 1 - include/configs/kzm9g.h | 1 - include/configs/ms7722se.h | 1 - include/configs/r0p7734.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/socfpga_common.h | 1 - scripts/config_whitelist.txt | 1 - 29 files changed, 18 insertions(+), 21 deletions(-)
diff --git a/README b/README index 0257c80..ef4015c 100644 --- a/README +++ b/README @@ -3532,9 +3532,6 @@ Configuration Settings: - CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Enable the call to overwrite_console().
-- CONFIG_SYS_CONSOLE_ENV_OVERWRITE - Enable overwrite of previous console environment settings. - - CONFIG_SYS_MEMTEST_START, CONFIG_SYS_MEMTEST_END: Begin and End addresses of the area used by the simple memory test. diff --git a/common/Kconfig b/common/Kconfig index 777724f..13a59c5 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -309,6 +309,15 @@ config SYS_CONSOLE_IS_IN_ENV environment variables can be updated after boot to change the input/output devices.
+config SYS_CONSOLE_ENV_OVERWRITE + bool "Update environment variables during console init" + help + The console environment variables (stdout, stdin, stderr) can be + used to determine the correct console devices on start-up. This + option writes the console devices to these variables on console + start-up (after relocation). This causes the environment to be + updated to match the console devices actually chosen. + endmenu
config SYS_NO_FLASH diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 5d31112..246ba00 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index c930acc..bc550e5 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 402d9fb..140ac4d 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index cc0313c..6a50f5b 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_is1" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 2462f66..cc0938d 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_mcvevk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 7b1c476..a208856 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 4a26996..b9e72c8 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 770ebcd..2766827 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 79b0cba..c9b0178 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_FIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 43468ef..8ad34b1 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -114,7 +114,6 @@ * defines if the overwrite_console should be stored in the * environment **************************************************************/ -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
/************************************************************** * loads config diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index a4eabe5..588ddd4 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -43,7 +43,6 @@ #undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (MIGO_R_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 685922c..b77aacb 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -110,7 +110,6 @@ * defines if the overwrite_console should be stored in the * environment **************************************************************/ -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
/************************************************************** * loads config diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 32acb08..795a7d2 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -57,7 +57,6 @@ /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (AP325RXA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index d41b624..fc08d7b 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -73,7 +73,6 @@ /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index e616da4..3198df5 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -60,7 +60,6 @@ #define CONFIG_SCIF_A #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (ARMADILLO_800EVA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index c8508ff..8ab26e6 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -93,7 +93,6 @@ /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index a5c872c..4ea9ba2 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -56,7 +56,6 @@ #define CONFIG_CONS_SCIF4 #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (KZM_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END \ diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index 9b0c166..d0b6e58 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -42,7 +42,6 @@ #define CONFIG_CONS_SCIF0 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (MS7722SE_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index 2d7e326..408ae21 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -78,7 +78,6 @@ /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index b24652f..1891242 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -42,7 +42,6 @@ /* console */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index 1e9752b..cf1af66 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -50,7 +50,6 @@ /* console */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index cfcde81..fd32ddc 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -46,7 +46,6 @@ #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (SH7752EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index fefdbb4..57c8e76 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -46,7 +46,6 @@ #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (SH7753EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index 262d390..cb09a7c 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -46,7 +46,6 @@ #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (SH7757LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 80e61a4..6eee51e 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -62,7 +62,6 @@ #define CONFIG_SCIF_EXT_CLOCK 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (SH7785LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 9bb2227..e76e072 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -252,7 +252,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * U-Boot environment */ #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#define CONFIG_SYS_CONSOLE_ENV_OVERWRITE #if !defined(CONFIG_ENV_SIZE) #define CONFIG_ENV_SIZE 4096 #endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index bc37626..8b49304 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4597,7 +4597,6 @@ CONFIG_SYS_CMXFCR_VALUE1 CONFIG_SYS_CMXFCR_VALUE2 CONFIG_SYS_CMXFCR_VALUE3 CONFIG_SYS_CMXSCR_VALUE -CONFIG_SYS_CONSOLE_ENV_OVERWRITE CONFIG_SYS_CONSOLE_INFO_QUIET CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_CORE_SRAM
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
Changes in v4: None Changes in v3: None Changes in v2: None
README | 3 --- common/Kconfig | 9 +++++++++ configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/ea20_defconfig | 1 + configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx6dlsabreauto_defconfig | 1 + configs/mx6dlsabresd_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 1 + configs/mx6qsabreauto_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6qsabresd_defconfig | 1 + configs/mx6sabresd_spl_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/wandboard_defconfig | 1 + include/configs/MIP405.h | 1 - include/configs/MigoR.h | 1 - include/configs/PIP405.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/bur_cfg_common.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/ea20.h | 1 - include/configs/ecovec.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/ge_bx50v3.h | 2 -- include/configs/kzm9g.h | 1 - include/configs/ms7722se.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/r0p7734.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/wandboard.h | 1 - scripts/config_whitelist.txt | 1 - 76 files changed, 53 insertions(+), 34 deletions(-)
diff --git a/README b/README index ef4015c..7642615 100644 --- a/README +++ b/README @@ -3529,9 +3529,6 @@ Configuration Settings: - CONFIG_SYS_CONSOLE_INFO_QUIET Suppress display of console information at boot.
-- CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE - Enable the call to overwrite_console(). - - CONFIG_SYS_MEMTEST_START, CONFIG_SYS_MEMTEST_END: Begin and End addresses of the area used by the simple memory test. diff --git a/common/Kconfig b/common/Kconfig index 13a59c5..dd85b2d 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -309,6 +309,15 @@ config SYS_CONSOLE_IS_IN_ENV environment variables can be updated after boot to change the input/output devices.
+config SYS_CONSOLE_OVERWRITE_ROUTINE + bool "Allow board control over console overwriting" + help + If this is enabled, and the board-specific function + overwrite_console() returns 1, the stdin, stderr and stdout are + switched to the serial port, else the settings in the environment + are used. If this is not enabled, the console will not be switched + to serial. + config SYS_CONSOLE_ENV_OVERWRITE bool "Update environment variables during console init" help diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 1d72a74..868a4e3 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_MIP405T=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 91d5db8..e321774 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_MIP405=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 939c58f..d4594fe 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_PIP405=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index b7443d9..dbb5374 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index d365606..66e3985 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index a1d2c4e..7e68d48 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 336ef02..c76e1fd 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,EMMC_BOOT" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 22e43bc..31b4d49 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 230af46..5c3d55c 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,SPI_BOOT,EMMC_BOOT" CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 4f91ec7..21c32e7 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 85080b6..3499914 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index f0dcb1d..3236788 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_DDR_1G=y CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index 468b3a7..2c14ce5 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index ba922ed..691e425 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_EA20=y CONFIG_VIDEO=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index 29010f3..117f68d 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_GE_B450V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index e0eeb46..73b559b 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_GE_B650V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index 9b4b917..80d5315 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_GE_B850V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index bc76dfd..4104164 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,ENV_IS_IN_SPI_FLASH" CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index 02cbf57..4bba151 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -4,6 +4,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index 21573e1..f58040f 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53loco/imximage.cfg" CONFIG_BOOTDELAY=1 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index 68c1a6b..49c2161 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index 1dbfe53..b380342 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index 1445b75..a523632 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index 004206b..c7e1f4f 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 3dab823..d4e3c3d 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index 0f3cc7a..e377284 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index 6d58495..147d2b3 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index d1be7b5..33c6da7 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 6212755..a39e502 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index d05608e..7dacaeb 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 452a16c..63ceb01 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 158df5d..094fe5a 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index fb8fa4c..ad58fa4 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 9ad02e4..22ebf5c 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024,ENV_IS_IN_MMC" CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 246ba00..d91990c 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index bc550e5..905f766 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 140ac4d..7daf81a 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 6a50f5b..a0f04d0 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_is1" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index cc0938d..5a53246 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_mcvevk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index a208856..9450d21 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index b9e72c8..84a8890 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 2766827..9cc2f7a 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index c9b0178..608cdf8 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_FIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 329d5e4..affaa5f 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 8ad34b1..1a4d602 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -108,7 +108,6 @@ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_SYS_CONSOLE_INFO_QUIET /*************************************************************** * defines if the overwrite_console should be stored in the diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index 588ddd4..b31d51b 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -42,7 +42,6 @@ #define CONFIG_CONS_SCIF0 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console information at boot */ -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (MIGO_R_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index b77aacb..5f7706df 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -104,7 +104,6 @@ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_SYS_CONSOLE_INFO_QUIET /*************************************************************** * defines if the overwrite_console should be stored in the diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 854c0c4..2341e97 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -273,7 +273,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 795a7d2..153d162 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -56,7 +56,6 @@
/* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (AP325RXA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index fc08d7b..e922cdf 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -72,7 +72,6 @@
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 93083fc..56530fd 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -231,7 +231,6 @@ /* Framebuffer */ #define CONFIG_VIDEO_IPUV3 /* check this console not needed, after test remove it */ -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index 3198df5..1d1dd39 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -59,7 +59,6 @@ #define SCIF4_BASE 0xe6c80000 #define CONFIG_SCIF_A #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (ARMADILLO_800EVA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/bur_cfg_common.h b/include/configs/bur_cfg_common.h index 277f36e..16237e6 100644 --- a/include/configs/bur_cfg_common.h +++ b/include/configs/bur_cfg_common.h @@ -41,7 +41,6 @@
#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_ENV_OVERWRITE /* Overwrite ethaddr / serial# */ -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
/* As stated above, the following choices are optional. */ #define CONFIG_SYS_LONGHELP diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index b016f20..d474bc1 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -89,7 +89,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 8c35688..e3fdc5e 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -108,7 +108,6 @@ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CMD_BMP -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #endif
/* diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index 8ab26e6..dd925a9 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -92,7 +92,6 @@
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 9e0c945..2106e86 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -118,7 +118,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 44155e7..ae3b1e4 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -304,8 +304,6 @@
#define CONFIG_SYS_FSL_USDHC_NUM 3
-#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE - /* Framebuffer */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 4ea9ba2..b2d9394 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -55,7 +55,6 @@ #define CONFIG_SCIF_CONSOLE #define CONFIG_CONS_SCIF4 #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (KZM_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END \ diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index d0b6e58..17485b5 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -41,7 +41,6 @@ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF0 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console information at boot */ -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (MS7722SE_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 664e2dd..3c1d53f 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -94,7 +94,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 2ee6d98..6cc5d9c 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -214,7 +214,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 9a0b0a2..e404d5b 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -209,7 +209,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 63ef4e7..b32e49e 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -93,7 +93,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index 408ae21..d7ecdb8 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -77,7 +77,6 @@
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 1891242..9f92ff7 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -41,7 +41,6 @@
/* console */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index cf1af66..59934c0 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -49,7 +49,6 @@
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index fd32ddc..bdb8101 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -45,7 +45,6 @@ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (SH7752EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 57c8e76..eaa862c 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -45,7 +45,6 @@ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (SH7753EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index cb09a7c..8e4ff1c 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -45,7 +45,6 @@ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (SH7757LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 6eee51e..86057c1 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -61,7 +61,6 @@ #define CONFIG_CONS_SCIF1 1 #define CONFIG_SCIF_EXT_CLOCK 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (SH7785LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index e76e072..d37e595 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -251,7 +251,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); /* * U-Boot environment */ -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #if !defined(CONFIG_ENV_SIZE) #define CONFIG_ENV_SIZE 4096 #endif diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index d089b53..8c5cf33 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -75,7 +75,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 8b49304..43814cf 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4598,7 +4598,6 @@ CONFIG_SYS_CMXFCR_VALUE2 CONFIG_SYS_CMXFCR_VALUE3 CONFIG_SYS_CMXSCR_VALUE CONFIG_SYS_CONSOLE_INFO_QUIET -CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_CORE_SRAM CONFIG_SYS_CORE_SRAM_SIZE CONFIG_SYS_CORTEX_R4
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_INFO_QUIET
Changes in v4: None Changes in v3: None Changes in v2: - Make CONFIG_SYS_CONSOLE_INFO_QUIET the default if !CONFIG_MUX
README | 3 --- common/Kconfig | 9 +++++++++ configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/ea20_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/galileo_defconfig | 1 + configs/icon_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/rut_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/theadorable_defconfig | 1 + include/configs/10m50_devboard.h | 1 - include/configs/3c120_devboard.h | 1 - include/configs/CPCI2DP.h | 2 -- include/configs/CPCI4052.h | 2 +- include/configs/M5249EVB.h | 1 - include/configs/MIP405.h | 1 - include/configs/MigoR.h | 2 -- include/configs/PIP405.h | 1 - include/configs/PLU405.h | 2 -- include/configs/PMC405DE.h | 1 - include/configs/VOM405.h | 2 -- include/configs/a3m071.h | 2 -- include/configs/amcc-common.h | 1 - include/configs/amcore.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/bur_cfg_common.h | 1 - include/configs/clearfog.h | 1 - include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/ea20.h | 1 - include/configs/ecovec.h | 1 - include/configs/hrcon.h | 2 -- include/configs/kzm9g.h | 1 - include/configs/lsxl.h | 1 - include/configs/lwmon5.h | 2 -- include/configs/maxbcm.h | 1 - include/configs/ms7722se.h | 1 - include/configs/mvebu_db-88f3720.h | 1 - include/configs/mvebu_db-88f7040.h | 1 - include/configs/odroid.h | 1 - include/configs/openrisc-generic.h | 1 - include/configs/origen.h | 1 - include/configs/r0p7734.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/s5pc210_universal.h | 1 - include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/socfpga_sr1500.h | 1 - include/configs/spear-common.h | 1 - include/configs/strider.h | 2 -- include/configs/theadorable.h | 1 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_armv7_common.h | 1 - include/configs/trats.h | 1 - include/configs/trats2.h | 1 - include/configs/vct.h | 1 - include/configs/x600.h | 1 - include/configs/x86-common.h | 2 -- include/configs/xilinx-ppc.h | 1 - include/configs/xpress.h | 1 - scripts/config_whitelist.txt | 1 - 94 files changed, 42 insertions(+), 72 deletions(-)
diff --git a/README b/README index 7642615..dae8921 100644 --- a/README +++ b/README @@ -3526,9 +3526,6 @@ Configuration Settings: - CONFIG_SYS_BAUDRATE_TABLE: List of legal baudrate settings for this board.
-- CONFIG_SYS_CONSOLE_INFO_QUIET - Suppress display of console information at boot. - - CONFIG_SYS_MEMTEST_START, CONFIG_SYS_MEMTEST_END: Begin and End addresses of the area used by the simple memory test. diff --git a/common/Kconfig b/common/Kconfig index dd85b2d..e0bc1bb 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -327,6 +327,15 @@ config SYS_CONSOLE_ENV_OVERWRITE start-up (after relocation). This causes the environment to be updated to match the console devices actually chosen.
+config SYS_CONSOLE_INFO_QUIET + bool "Don't display the console devices on boot" + default y if !CONSOLE_MUX + help + Normally U-Boot displays the current settings for stdout, stdin + and stderr on boot when the post-relocation console is set up. + Enable this option to supress this output. It can be obtained by + calling stdio_print_current_devices() from board code. + endmenu
config SYS_NO_FLASH diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 868a4e3..66f1db5 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index e321774..a316ef9 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index d4594fe..64d7b1b 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -7,6 +7,7 @@ CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 21b0135..9b734de 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index c76e1fd..4aa619f 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,EMMC_BOOT" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 31b4d49..2948be8 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 5c3d55c..a9a6926 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -17,6 +17,7 @@ CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 21c32e7..4b48fa4 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index da251a1..4e4829d 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 7e9857e..72b864e 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -10,6 +10,7 @@ CONFIG_SMP=y CONFIG_HAVE_VGA_BIOS=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 5566508..c49e68c 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index af96a00..ad90d8e 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 3d67935..42932ba 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 99e9a94..8e79c38 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index cfd868d..949a8fc 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -3,6 +3,7 @@ CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="cougarcanyon2" CONFIG_TARGET_COUGARCANYON2=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 8753271..cad8369 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -10,6 +10,7 @@ CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y CONFIG_FIT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 67ab280..02a691c 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 691e425..8bbdf52 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index c47f314..ce4ca84 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -4,6 +4,7 @@ CONFIG_DEFAULT_DEVICE_TREE="efi" CONFIG_TARGET_EFI=y CONFIG_FIT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index ef6ce97..c66f24a 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/icon_defconfig b/configs/icon_defconfig index e415ac5..a431ed8 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -4,6 +4,7 @@ CONFIG_4xx=y CONFIG_TARGET_ICON=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index 0282d28..4e59303 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index e327f77..b2e81ff 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 76ea361..234a242 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -20,6 +20,7 @@ CONFIG_FIT=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 091c814..c43e82a 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index e52bfa4..0c8a629 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index d06686f..ec0569e 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 8811eb2..fef58b5 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -20,6 +20,7 @@ CONFIG_FIT=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 097720d..3e1973d 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 63c65b7..ec52cc5 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index b88be20..f4ce082 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" CONFIG_FIT=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index 27fa8c8..e0cf053 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" CONFIG_FIT=y CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/include/configs/10m50_devboard.h b/include/configs/10m50_devboard.h index 2e5d6f7..2cb8f5a 100644 --- a/include/configs/10m50_devboard.h +++ b/include/configs/10m50_devboard.h @@ -18,7 +18,6 @@ * SERIAL */ #define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress console info */ #define CONFIG_SYS_NS16550_MEM32
/* diff --git a/include/configs/3c120_devboard.h b/include/configs/3c120_devboard.h index 965ebc3..b9f5439 100644 --- a/include/configs/3c120_devboard.h +++ b/include/configs/3c120_devboard.h @@ -18,7 +18,6 @@ * SERIAL */ #define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress console info */
/* * CFI Flash diff --git a/include/configs/CPCI2DP.h b/include/configs/CPCI2DP.h index 2e9512a..b5e4f31 100644 --- a/include/configs/CPCI2DP.h +++ b/include/configs/CPCI2DP.h @@ -74,8 +74,6 @@
#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */
#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index 6232059..af3e67e 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -95,7 +95,7 @@
-#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ +#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */
#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 735c4da..d61c68f 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -52,7 +52,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */
#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */
diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 1a4d602..db92967 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -108,7 +108,6 @@ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /*************************************************************** * defines if the overwrite_console should be stored in the * environment diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index b31d51b..bb12785 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -40,8 +40,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF0 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console - information at boot */
#define CONFIG_SYS_MEMTEST_START (MIGO_R_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 5f7706df..1db7b5d 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -104,7 +104,6 @@ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /*************************************************************** * defines if the overwrite_console should be stored in the * environment diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index e49e5ce..c5a5c64 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -92,8 +92,6 @@
#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ diff --git a/include/configs/PMC405DE.h b/include/configs/PMC405DE.h index d5e521e..7e06fc7 100644 --- a/include/configs/PMC405DE.h +++ b/include/configs/PMC405DE.h @@ -73,7 +73,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */
#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console info */
#define CONFIG_SYS_MEMTEST_START 0x0100000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x3000000 /* 1 ... 48 MB in DRAM */ diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index fc6cf78..50d2405 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -82,8 +82,6 @@
-#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - #define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */
diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index 7cc52fb..a0306ca 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -246,8 +246,6 @@
#define CONFIG_SYS_LOAD_ADDR 0x00100000
-#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/ - /* * Various low-level settings */ diff --git a/include/configs/amcc-common.h b/include/configs/amcc-common.h index f4261e9..7974c53 100644 --- a/include/configs/amcc-common.h +++ b/include/configs/amcc-common.h @@ -78,7 +78,6 @@ #define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/
#define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ diff --git a/include/configs/amcore.h b/include/configs/amcore.h index fcb82e2..4a54cb6 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -51,7 +51,6 @@ /* Boot argument buffer size */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
-#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* no console @ startup */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */
diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 153d162..9a4d2c9 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -55,7 +55,6 @@ #define CONFIG_CONS_SCIF5 1
/* Suppress display of console information at boot */ -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (AP325RXA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index e922cdf..93205aa 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -71,7 +71,6 @@ #define CONFIG_CONS_SCIF4 1
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index 1d1dd39..2d24253 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -58,7 +58,6 @@ #define SCIF2_BASE 0xe6c60000 #define SCIF4_BASE 0xe6c80000 #define CONFIG_SCIF_A -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (ARMADILLO_800EVA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/bur_cfg_common.h b/include/configs/bur_cfg_common.h index 16237e6..5c99860 100644 --- a/include/configs/bur_cfg_common.h +++ b/include/configs/bur_cfg_common.h @@ -39,7 +39,6 @@ #define CONFIG_NETCONSOLE 1 #define CONFIG_BOOTP_MAY_FAIL /* if we don't have DHCP environment */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_ENV_OVERWRITE /* Overwrite ethaddr / serial# */
/* As stated above, the following choices are optional. */ diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 3990900..21b391b 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -87,7 +87,6 @@ #define CONFIG_PCI_SCAN_SHOW #endif
-#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */ #define CONFIG_SYS_ALT_MEMTEST
/* Keep device tree and initrd in lower memory so the kernel can access them */ diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h index a134889..282d5e8 100644 --- a/include/configs/db-88f6720.h +++ b/include/configs/db-88f6720.h @@ -50,7 +50,6 @@ #define CONFIG_PHY_MARVELL /* there is a marvell phy */ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* Additional FS support/configuration */ diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index a6d0221..446596e 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -72,7 +72,6 @@ #define CONFIG_SYS_NAND_USE_FLASH_BBT #define CONFIG_SYS_NAND_ONFI_DETECTION
/* Keep device tree and initrd in lower memory so the kernel can access them */ diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 48b4b2e..1f2f6b8 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -88,7 +88,6 @@ #define CONFIG_PCI_SCAN_SHOW #endif
/* Keep device tree and initrd in lower memory so the kernel can access them */ diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index c43dece..d81efa9 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -55,7 +55,6 @@ #define CONFIG_PHY_MARVELL /* there is a marvell phy */ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* SATA support */ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index e3fdc5e..f897145 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -104,7 +104,6 @@ #define CONFIG_VIDEO_DA8XX #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO -#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CMD_BMP diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index dd925a9..e1e3c78 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -91,7 +91,6 @@ #define CONFIG_CONS_SCIF0 1
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index 99dcb75..c2ffc08 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -539,8 +539,6 @@ void fpga_control_clear(unsigned int bus, int pin);
#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET - /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index b2d9394..9402aca 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -54,7 +54,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE #define CONFIG_CONS_SCIF4 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (KZM_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END \ diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 6084c8e..0caca4c 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -36,7 +36,6 @@ #define CONFIG_KIRKWOOD_GPIO
#define CONFIG_SYS_NO_FLASH -#define CONFIG_SYS_CONSOLE_INFO_QUIET
/* * Enable u-boot API for standalone programs. diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 2fed3e0..638682f 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -426,8 +426,6 @@ #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/ - #ifndef DEBUG #define CONFIG_HW_WATCHDOG 1 /* Use external HW-Watchdog */ #endif diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index 29ed284..9f4308f 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -46,7 +46,6 @@ #define CONFIG_PHY_MARVELL /* there is a marvell phy */ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index 17485b5..a473eec 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -40,7 +40,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF0 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console information at boot */
#define CONFIG_SYS_MEMTEST_START (MS7722SE_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/mvebu_db-88f3720.h b/include/configs/mvebu_db-88f3720.h index 7a50c4e..7ddde8c 100644 --- a/include/configs/mvebu_db-88f3720.h +++ b/include/configs/mvebu_db-88f3720.h @@ -59,7 +59,6 @@ #define CONFIG_SYS_RESET_ADDRESS 0xffff0000 /* Rst Vector Adr */ #define CONFIG_SYS_MAXARGS 32 /* max number of command args */
/* End of 16M scrubbed by training in bootrom */ diff --git a/include/configs/mvebu_db-88f7040.h b/include/configs/mvebu_db-88f7040.h index 709098f..6feb8d7 100644 --- a/include/configs/mvebu_db-88f7040.h +++ b/include/configs/mvebu_db-88f7040.h @@ -62,7 +62,6 @@ #define CONFIG_SYS_RESET_ADDRESS 0xffff0000 /* Rst Vector Adr */ #define CONFIG_SYS_MAXARGS 32 /* max number of command args */
/* End of 16M scrubbed by training in bootrom */ diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 704d1e7..2828f07 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -43,7 +43,6 @@ #define CONFIG_BAUDRATE 115200
/* Console configuration */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run autoboot" diff --git a/include/configs/openrisc-generic.h b/include/configs/openrisc-generic.h index 227c0ca..9decae7 100644 --- a/include/configs/openrisc-generic.h +++ b/include/configs/openrisc-generic.h @@ -38,7 +38,6 @@
#define CONFIG_BAUDRATE CONFIG_SYS_UART_BAUD #define CONFIG_SYS_BAUDRATE_TABLE {CONFIG_BAUDRATE} -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress console info */ #define CONSOLE_ARG "console=console=ttyS0,115200\0"
/* diff --git a/include/configs/origen.h b/include/configs/origen.h index a075b54..26fe402 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -37,7 +37,6 @@ #define CONFIG_BAUDRATE 115200
/* Console configuration */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index d7ecdb8..0552003 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -76,7 +76,6 @@ #define CONFIG_CONS_SCIF3 1
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 9f92ff7..459b077 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -40,7 +40,6 @@ #define CONFIG_SH_GPIO_PFC
/* console */ -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index 59934c0..ec4d54e 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -48,7 +48,6 @@ #define CONFIG_SH_GPIO_PFC
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index e2d814f..0210c5b 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -29,7 +29,6 @@ #define CONFIG_BAUDRATE 115200
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run mmcboot" diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index bdb8101..38bf408 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -44,7 +44,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (SH7752EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index eaa862c..3718bc5 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -44,7 +44,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (SH7753EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index 8e4ff1c..8820e15 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -44,7 +44,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (SH7757LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 86057c1..11a4cf9 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -60,7 +60,6 @@ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF1 1 #define CONFIG_SCIF_EXT_CLOCK 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (SH7785LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index c53bd66..7de3cf6 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -110,7 +110,6 @@
-#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_SERIAL1 1 #define CONFIG_CONS_INDEX 1
diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index 286e746..0407f03 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -25,7 +25,6 @@ #define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" #define CONFIG_LOADADDR 0x01000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */
/* Ethernet on SoC (EMAC) */ #define CONFIG_PHY_INTERFACE_MODE PHY_INTERFACE_MODE_RGMII diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index f609136..912b776 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -189,7 +189,6 @@ #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_LOAD_ADDR 0x00800000 -#define CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_FLASH_EMPTY_INFO
diff --git a/include/configs/strider.h b/include/configs/strider.h index 5cd37d7..92ad95e 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -573,8 +573,6 @@ void fpga_control_clear(unsigned int bus, int pin);
-#define CONFIG_SYS_CONSOLE_INFO_QUIET - /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index fe2ca6f..a51ffb5 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -63,7 +63,6 @@ #define CONFIG_PHY_MARVELL /* there is a marvell phy */ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */ #define CONFIG_SYS_ALT_MEMTEST #define CONFIG_PREBOOT
diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 22a8e4f..e7f4fba 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -149,7 +149,6 @@
#define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1 -#define CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_ENV_IS_NOWHERE
diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 79f436c..390c5ae 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -112,7 +112,6 @@ #define CONFIG_SERIAL2 #define CONFIG_SERIAL3 #define CONFIG_CONS_INDEX 1 -#define CONFIG_SYS_CONSOLE_INFO_QUIET
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index f31d5d3..0d74c50 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -147,7 +147,6 @@ * console baudrate of 115200 and use the default baud rate table. */ #define CONFIG_SYS_MALLOC_LEN SZ_32M -#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_BAUDRATE 115200 #define CONFIG_ENV_VARS_UBOOT_CONFIG /* Strongly encouraged */ #define CONFIG_ENV_OVERWRITE /* Overwrite ethaddr / serial# */ diff --git a/include/configs/trats.h b/include/configs/trats.h index 9fc6513..a26d663 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -41,7 +41,6 @@ #define CONFIG_BAUDRATE 115200
/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ #define MACH_TYPE_TRATS 3928 diff --git a/include/configs/trats2.h b/include/configs/trats2.h index c437c13..1633c67 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -38,7 +38,6 @@ #define CONFIG_BAUDRATE 115200
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run autoboot" diff --git a/include/configs/vct.h b/include/configs/vct.h index 210d0ef..6ff22c2 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -140,7 +140,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_TIMESTAMP /* Print image info with timestamp */ #define CONFIG_CMDLINE_EDITING /* add command line history */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/
/* * FLASH and environment organization diff --git a/include/configs/x600.h b/include/configs/x600.h index 13b0b95..5e51f65 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -155,7 +155,6 @@ #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_LOAD_ADDR 0x00800000 -#define CONFIG_SYS_CONSOLE_INFO_QUIET
/* Use last 2 lwords in internal SRAM for bootcounter */ #define CONFIG_BOOTCOUNT_LIMIT diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index e8e199a..90bdab3 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -83,8 +83,6 @@ #endif #define CONFIG_PARTITION_UUIDS
-#define CONFIG_SYS_CONSOLE_INFO_QUIET - /* x86 GPIOs are accessed through a PCI device */ #define CONFIG_INTEL_ICH6_GPIO
diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index 6c52582..47c1ddf 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -57,7 +57,6 @@ #define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */ #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20) diff --git a/include/configs/xpress.h b/include/configs/xpress.h index c45dcda..41d4c07 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -42,7 +42,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR #define CONFIG_SYS_HZ 1000
-#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_CMDLINE_EDITING
/* Physical Memory Map */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 43814cf..a0306a6 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4597,7 +4597,6 @@ CONFIG_SYS_CMXFCR_VALUE1 CONFIG_SYS_CMXFCR_VALUE2 CONFIG_SYS_CMXFCR_VALUE3 CONFIG_SYS_CMXSCR_VALUE -CONFIG_SYS_CONSOLE_INFO_QUIET CONFIG_SYS_CORE_SRAM CONFIG_SYS_CORE_SRAM_SIZE CONFIG_SYS_CORTEX_R4
This converts the following to Kconfig: CONFIG_USB_KEYBOARD
Changes in v4: None Changes in v3: None Changes in v2: - Add new patch to convert CONFIG_USB_KEYBOARD to Kconfig
configs/Cyrus_P5020_defconfig | 1 + configs/Cyrus_P5040_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/VCMA9_defconfig | 1 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/galileo_defconfig | 1 + configs/gwventana_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/novena_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/smdk2410_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/ventana_defconfig | 1 + include/configs/MIP405.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/PIP405.h | 1 - include/configs/VCMA9.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/at91rm9200ek.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cyrus.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/rpi.h | 1 - include/configs/seaboard.h | 1 - include/configs/smdk2410.h | 1 - include/configs/tbs2910.h | 1 - include/configs/ventana.h | 1 - include/configs/x86-common.h | 1 - 66 files changed, 46 insertions(+), 20 deletions(-)
diff --git a/configs/Cyrus_P5020_defconfig b/configs/Cyrus_P5020_defconfig index 6495440..5eb56602 100644 --- a/configs/Cyrus_P5020_defconfig +++ b/configs/Cyrus_P5020_defconfig @@ -26,4 +26,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_OF_LIBFDT=y diff --git a/configs/Cyrus_P5040_defconfig b/configs/Cyrus_P5040_defconfig index 4566abb..e33340b 100644 --- a/configs/Cyrus_P5040_defconfig +++ b/configs/Cyrus_P5040_defconfig @@ -26,4 +26,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_OF_LIBFDT=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index a316ef9..aa2f16e 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -20,5 +20,6 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 64d7b1b..40e3ae1 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -20,5 +20,6 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/VCMA9_defconfig b/configs/VCMA9_defconfig index da568a1..e464c21 100644 --- a/configs/VCMA9_defconfig +++ b/configs/VCMA9_defconfig @@ -14,3 +14,4 @@ CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index e6569aa..b6db8c4 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -16,4 +16,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index ad81400..e042f0b 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -17,4 +17,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_OF_LIBFDT=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 9b734de..ba8284e 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -57,6 +57,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 3499914..82e972a 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -44,6 +44,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 4e4829d..24fd285 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -61,6 +61,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 72b864e..ca882e4 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -57,6 +57,7 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index c49e68c..d16c87a 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -53,6 +53,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index ad90d8e..e020f84 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -65,6 +65,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 42932ba..512bb1f 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -64,6 +64,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 8e79c38..96ddde3 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -45,6 +45,7 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_COREBOOT=y +CONFIG_USB_KEYBOARD=y CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 949a8fc..233fe09 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -34,4 +34,5 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index cad8369..d53a794 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -51,6 +51,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_CFB_CONSOLE=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 02a691c..fab61c0 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -62,6 +62,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index 3236788..3ccba12 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index 2c14ce5..e765403 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index ce4ca84..b31c73b 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -32,4 +32,5 @@ CONFIG_ICH_SPI=y CONFIG_TIMER=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_EFI=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index c66f24a..0220357 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -50,4 +50,5 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index 759443b..beb40d2 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -50,6 +50,7 @@ CONFIG_E1000=y CONFIG_DM_SERIAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index b2e81ff..29543c6 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -61,6 +61,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 59ae1a1..6fb3d98 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -34,4 +34,5 @@ CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index d4e3c3d..14e2f1f 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -33,6 +33,7 @@ CONFIG_SPI_FLASH_SST=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 33c6da7..b6e0c46 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index a39e502..5b9c13e 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 7dacaeb..b9bd0be 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 63ceb01..2d90ed5 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 094fe5a..1806c48 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index ad58fa4..cd0aeff 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index f0116f8..81c0297 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_OF_LIBFDT=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index c43e82a..a33ee0d 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -48,6 +48,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 0c8a629..1fab624 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -45,6 +45,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index ec0569e..1f9d0c2 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -45,6 +45,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index 13016c1..4abe489 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index e27d24c..0e66ba2 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index 9536bd8..ae360a9 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 3c8fdc2..f8ddce4 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 2457b11..34947a8 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_USB=y CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/smdk2410_defconfig b/configs/smdk2410_defconfig index d6aa2dd..c84ce52 100644 --- a/configs/smdk2410_defconfig +++ b/configs/smdk2410_defconfig @@ -14,3 +14,4 @@ CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 3e1973d..eb8a11a 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -59,6 +59,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 8c342eb..d63bd6e 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -32,6 +32,7 @@ CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index ec52cc5..cc0a3b6 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -59,6 +59,7 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 33ca0bd..c86c0d9 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -39,6 +39,7 @@ CONFIG_DM_USB=y CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index db92967..0538332 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -346,7 +346,6 @@ ************************************************************/ #if !defined(CONFIG_TARGET_MIP405T) #define CONFIG_USB_UHCI -#define CONFIG_USB_KEYBOARD
/* Enable needed helper functions */ #define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 5981755..4021be7 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -283,7 +283,6 @@ ************************************************************/ #define CONFIG_PCI_OHCI 1 #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_USB_KEYBOARD 1 #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL 1 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ohci_pci" diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 11b10bc..94a9399 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -361,7 +361,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); ************************************************************/ #define CONFIG_PCI_OHCI 1 #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_USB_KEYBOARD 1 #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL 1 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ohci_pci" diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 1db7b5d..eaa8b26 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -306,7 +306,6 @@ * USB support ************************************************************/ #define CONFIG_USB_UHCI -#define CONFIG_USB_KEYBOARD
/* Enable needed helper functions */ #define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index e012417..75c6d50 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -100,7 +100,6 @@ /* USB support (currently only works with D-cache off) */ #define CONFIG_USB_OHCI #define CONFIG_USB_OHCI_S3C24XX -#define CONFIG_USB_KEYBOARD #define CONFIG_DOS_PARTITION
/* Enable needed helper functions */ diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 2341e97..4b8723f 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -69,7 +69,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP
#define CONFIG_USBD_HS diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 3cc8d89..ed0daf5 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -144,7 +144,6 @@ #define CONFIG_USB_ATMEL 1 #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_USB_KEYBOARD 1 #define CONFIG_DOS_PARTITION 1
#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index d474bc1..bccfedf 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -74,7 +74,6 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 /* Enabled USB controller number */ -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP
#define CONFIG_USBD_HS diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index eeb59fe..cb85c6b 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -446,7 +446,6 @@ #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_EHCI_IS_TDI -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL /* _VIA_CONTROL_EP */ diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index ae3b1e4..79a814e 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -84,7 +84,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP
#define CONFIG_CI_UDC diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 83a1453..ea3e865 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -167,7 +167,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_KEYBOARD #define CONFIG_USBD_HS #define CONFIG_USB_ETHER #define CONFIG_USB_ETH_CDC diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 82957d6..446b3bc 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -52,7 +52,6 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL #define CONFIG_PREBOOT \ "if hdmidet; then " \ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index b32e49e..8ab2486 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -85,7 +85,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP
/* Miscellaneous commands */ diff --git a/include/configs/novena.h b/include/configs/novena.h index 0983b96..ee4267a 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -142,7 +142,6 @@ #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP #define CONFIG_USB_HOST_ETHER diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 7fe469c..25a90cc 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -100,7 +100,6 @@ #define CONFIG_USB_ETHER_SMSC95XX #define CONFIG_TFTP_TSIZE #define CONFIG_MISC_INIT_R -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL #define CONFIG_SYS_STDIO_DEREGISTER #endif diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index fe68437..2b6509a 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -57,7 +57,6 @@ #define CONFIG_KEYBOARD
/* USB keyboard */ -#define CONFIG_USB_KEYBOARD
/* LCD support */ #define CONFIG_SYS_WHITE_ON_BLACK diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index f76fa75..1578310 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -50,7 +50,6 @@ ************************************************************/ #define CONFIG_USB_OHCI #define CONFIG_USB_OHCI_S3C24XX -#define CONFIG_USB_KEYBOARD #define CONFIG_DOS_PARTITION
/************************************************************ diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index f610b71..b541937 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -114,7 +114,6 @@ #define CONFIG_USBD_HS #define CONFIG_USB_FUNCTION_MASS_STORAGE #endif /* CONFIG_CMD_USB_MASS_STORAGE */ -#define CONFIG_USB_KEYBOARD #ifdef CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE #define CONFIG_SYS_STDIO_DEREGISTER diff --git a/include/configs/ventana.h b/include/configs/ventana.h index d3843d4..7a38869 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -42,7 +42,6 @@ /* General networking support */
/* LCD support */ #define CONFIG_SYS_WHITE_ON_BLACK diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 90bdab3..f2c2b50 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -160,7 +160,6 @@ #define CONFIG_USB_EHCI_PCI #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 12 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL
Signed-off-by: Simon Glass sjg@chromium.org
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
Changes in v4: - Rebase to master
Changes in v3: None Changes in v2: - Make CONFIG_SYS_STDIO_DEREGISTER the default if USB_KEYBOARD - Drop Kconfig changes
common/Kconfig | 9 +++++++++ common/stdio.c | 6 +++--- common/usb_kbd.c | 2 +- configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + drivers/serial/serial-uclass.c | 2 +- include/configs/MIP405.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/PIP405.h | 1 - include/configs/VCMA9.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cyrus.h | 1 - include/configs/gr_ep2s60.h | 1 - include/configs/novena.h | 1 - include/configs/rpi.h | 1 - include/configs/sandbox.h | 2 -- include/configs/sunxi-common.h | 1 - include/configs/tbs2910.h | 1 - include/configs/tegra-common.h | 4 ---- include/configs/x86-common.h | 2 -- include/stdio_dev.h | 2 +- scripts/config_whitelist.txt | 1 - 24 files changed, 18 insertions(+), 27 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index e0bc1bb..0a3e114 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -336,6 +336,15 @@ config SYS_CONSOLE_INFO_QUIET Enable this option to supress this output. It can be obtained by calling stdio_print_current_devices() from board code.
+config SYS_STDIO_DEREGISTER + bool "Allow deregistering stdio devices" + default y if USB_KEYBOARD + help + Generally there is no need to deregister stdio devices since they + are never deactivated. But if a stdio device is used which can be + removed (for example a USB keyboard) then this option can be + enabled to ensure this is handled correctly. + endmenu
config SYS_NO_FLASH diff --git a/common/stdio.c b/common/stdio.c index ab9b05d..8e4a9be 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -37,7 +37,7 @@ char *stdio_names[MAX_FILES] = { "stdin", "stdout", "stderr" }; #define CONFIG_SYS_DEVICE_NULLDEV 1 #endif
-#ifdef CONFIG_SYS_STDIO_DEREGISTER +#if CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) #define CONFIG_SYS_DEVICE_NULLDEV 1 #endif
@@ -245,7 +245,7 @@ int stdio_register(struct stdio_dev *dev) /* deregister the device "devname". * returns 0 if success, -1 if device is assigned and 1 if devname not found */ -#ifdef CONFIG_SYS_STDIO_DEREGISTER +#if CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) int stdio_deregister_dev(struct stdio_dev *dev, int force) { int l; @@ -292,7 +292,7 @@ int stdio_deregister(const char *devname, int force)
return stdio_deregister_dev(dev, force); } -#endif /* CONFIG_SYS_STDIO_DEREGISTER */ +#endif /* CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) */
int stdio_init_tables(void) { diff --git a/common/usb_kbd.c b/common/usb_kbd.c index a9872a6..5f9a64a 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -570,7 +570,7 @@ int drv_usb_kbd_init(void) /* Deregister the keyboard. */ int usb_kbd_deregister(int force) { -#ifdef CONFIG_SYS_STDIO_DEREGISTER +#if CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) struct stdio_dev *dev; struct usb_device *usb_kbd_dev; struct usb_kbd_pdata *data; diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 2c03ba2..1ff4fdb 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_MPC8610HPCD=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index 0c3d60b..dafdf58 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_PHYS_64BIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index d2250ec..1f7ceb3 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_MPC8641HPCN=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index 19f38e1..43c028e 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -346,7 +346,7 @@ static int serial_post_probe(struct udevice *dev)
static int serial_pre_remove(struct udevice *dev) { -#ifdef CONFIG_SYS_STDIO_DEREGISTER +#if CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) struct serial_dev_priv *upriv = dev_get_uclass_priv(dev);
if (stdio_deregister_dev(upriv->sdev, 0)) diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 0538332..9aba1dd 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -348,7 +348,6 @@ #define CONFIG_USB_UHCI
/* Enable needed helper functions */ -#define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ #endif /************************************************************ * Debug support diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 4021be7..e3c9e5b 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -283,7 +283,6 @@ ************************************************************/ #define CONFIG_PCI_OHCI 1 #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL 1 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ohci_pci" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 94a9399..e0b856f 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -361,7 +361,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); ************************************************************/ #define CONFIG_PCI_OHCI 1 #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL 1 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ohci_pci" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index eaa8b26..8516eb7 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -308,7 +308,6 @@ #define CONFIG_USB_UHCI
/************************************************************ * Debug support diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 75c6d50..bb26261 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -103,7 +103,6 @@ #define CONFIG_DOS_PARTITION
/* RTC */ #define CONFIG_RTC_S3C24X0 diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 0b3f034..0ac3ec7 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -210,7 +210,6 @@ #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */ -#define CONFIG_SYS_STDIO_DEREGISTER
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index cb85c6b..8ce23e6 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -446,7 +446,6 @@ #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_EHCI_IS_TDI -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL /* _VIA_CONTROL_EP */ #endif diff --git a/include/configs/gr_ep2s60.h b/include/configs/gr_ep2s60.h index 36a91c6..ad0c126 100644 --- a/include/configs/gr_ep2s60.h +++ b/include/configs/gr_ep2s60.h @@ -58,7 +58,6 @@ #if USE_GRUSB #define CONFIG_USB_UHCI /* Enable needed helper functions */ -#define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ #endif
/* diff --git a/include/configs/novena.h b/include/configs/novena.h index ee4267a..ecc7e7e 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -142,7 +142,6 @@ #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 25a90cc..45c8234 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -101,7 +101,6 @@ #define CONFIG_TFTP_TSIZE #define CONFIG_MISC_INIT_R #define CONFIG_SYS_USB_EVENT_POLL -#define CONFIG_SYS_STDIO_DEREGISTER #endif
/* Console UART */ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index b6533c3..31ab765 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -25,8 +25,6 @@ #define CONFIG_SYS_TIMER_RATE 1000000 #endif
-#define CONFIG_SYS_STDIO_DEREGISTER - /* * Number of bits in a C 'long' on this architecture. Set this to 32 when * building on a 32-bit machine. diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index f98a48b..e0464df 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -347,7 +347,6 @@ extern int soft_i2c_gpio_scl;
#ifdef CONFIG_USB_KEYBOARD #define CONFIG_PREBOOT -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE #endif
diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index b541937..61bd489 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -116,7 +116,6 @@ #endif /* CONFIG_CMD_USB_MASS_STORAGE */ #ifdef CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_PREBOOT \ "usb start; " \ "if hdmidet; then " \ diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 3590be4..63b711b 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -60,10 +60,6 @@
-#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_STDIO_DEREGISTER -#endif - /* * Increasing the size of the IO buffer as default nfsargs size is more * than 256 and so it is not possible to edit it diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index f2c2b50..3bf42b5 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -61,8 +61,6 @@ 9600, 19200, 38400, 115200} #define CONFIG_SYS_NS16550_PORT_MAPPED
-#define CONFIG_SYS_STDIO_DEREGISTER - #define CONFIG_CMDLINE_EDITING #define CONFIG_COMMAND_HISTORY #define CONFIG_AUTO_COMPLETE diff --git a/include/stdio_dev.h b/include/stdio_dev.h index 13f76be..e4fc8b1 100644 --- a/include/stdio_dev.h +++ b/include/stdio_dev.h @@ -100,7 +100,7 @@ int stdio_add_devices(void); int stdio_init(void);
void stdio_print_current_devices(void); -#ifdef CONFIG_SYS_STDIO_DEREGISTER +#if CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) int stdio_deregister(const char *devname, int force); int stdio_deregister_dev(struct stdio_dev *dev, int force); #endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index a0306a6..11b5a22 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -7681,7 +7681,6 @@ CONFIG_SYS_STACK_LENGTH CONFIG_SYS_STACK_SIZE CONFIG_SYS_STATUS_C CONFIG_SYS_STATUS_OK -CONFIG_SYS_STDIO_DEREGISTER CONFIG_SYS_STMICRO_BOOT CONFIG_SYS_SUPPORT_64BIT_DATA CONFIG_SYS_SXCNFG_VAL
On Mon, Oct 17, 2016 at 08:12:33PM -0600, Simon Glass wrote:
This series moves a number of console-related CONFIG options to Kconfig. Those that are not currently used are removed.
A few unused video drivers are also removed and there are a few minor adjustments to improve the code. But mostly this follows the output of the moveconfig tool.
So I've merged this now, and while I got almost everything correct with some re-ordering of patches and a few re-runnings of moveconfig.py, there's a few changes I want to make everyone aware of.
A number of PowerPC Freescale boards have a small SPL size increase because they used to do: #ifndef CONFIG_SPL_BUILD #define CONFIG_CONSOLE_MUX #define CONFIG_CONSOLE_IS_IN_ENV #endif
And now they do not.
Finally, sandbox_spl has a small size increase too that comes in at the stdio deregister patch but I don't see _why_.
Thanks for doing the conversion Simon!
Hi Tom,
Thanks for sorting this out and getting it in!
Jagan Teki
