[U-Boot] [PATCH v3 0/4] Add network support for Ocelots SoCs
Hello,
this the third version of a series allowing to use the switch component of the Ocelots SoC as a network interface.
The binding used is exactly the same of the one already used by Linux.
There is also a patch adding a workaround needed on the Ocelot based boards: indeed the pin connected to the DDR reset is part of the switch subsystem. So we need ensure that the DDR is not reset during the switch reset.
Gregory
Changelog: v2 -> v3:
- Use wait_for_bit_le32() whenever it is possible instead of timer_get_us() (Suggested by Daniel Schwierzeck) - Remove ocelot_ofdata_to_platdata() and get the resources directly from the probe function (Suggested by Daniel Schwierzeck) - Use dev_remap_addr_name() to simplify the address mapping (Suggested by Daniel Schwierzeck) - Simplify the mdio initialization by only manage the internal PHY for now
v1 -> v2: - Use wait_for_bit_le32() (suggested by Stefan Roese) - Use debug() instead of printf() for the debug messages in mscc_switch_reset.
Gregory CLEMENT (4): MIPS: mscc: ocelot: Add ethernet nodes for Ocelot net: add MSCC Ocelot switch support MIPS: mscc: ocelot: add switch reset support configs: mscc_ocelot: add network support
MAINTAINERS | 1 + arch/mips/dts/mscc,ocelot.dtsi | 97 ++++ arch/mips/dts/ocelot_pcb123.dts | 20 + board/mscc/ocelot/ocelot.c | 24 + configs/mscc_ocelot_defconfig | 1 + drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/ocelot_switch.c | 765 ++++++++++++++++++++++++++++++++ 8 files changed, 916 insertions(+) create mode 100644 drivers/net/ocelot_switch.c
Import Ethernet related nodes from Linux
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- arch/mips/dts/mscc,ocelot.dtsi | 97 +++++++++++++++++++++++++++++++++ arch/mips/dts/ocelot_pcb123.dts | 20 +++++++ 2 files changed, 117 insertions(+)
diff --git a/arch/mips/dts/mscc,ocelot.dtsi b/arch/mips/dts/mscc,ocelot.dtsi index 2592003103..4f3fe356c4 100644 --- a/arch/mips/dts/mscc,ocelot.dtsi +++ b/arch/mips/dts/mscc,ocelot.dtsi @@ -112,6 +112,98 @@ status = "disabled"; };
+ switch@1010000 { + pinctrl-0 = <&miim1_pins>; + pinctrl-names = "default"; + + compatible = "mscc,vsc7514-switch"; + reg = <0x1010000 0x10000>, /* VTSS_TO_SYS */ + <0x1030000 0x10000>, /* VTSS_TO_REW */ + <0x1080000 0x100>, /* VTSS_TO_DEVCPU_QS */ + <0x10d0000 0x10000>, /* VTSS_TO_HSIO */ + <0x11e0000 0x100>, /* VTSS_TO_DEV_0 */ + <0x11f0000 0x100>, /* VTSS_TO_DEV_1 */ + <0x1200000 0x100>, /* VTSS_TO_DEV_2 */ + <0x1210000 0x100>, /* VTSS_TO_DEV_3 */ + <0x1220000 0x100>, /* VTSS_TO_DEV_4 */ + <0x1230000 0x100>, /* VTSS_TO_DEV_5 */ + <0x1240000 0x100>, /* VTSS_TO_DEV_6 */ + <0x1250000 0x100>, /* VTSS_TO_DEV_7 */ + <0x1260000 0x100>, /* VTSS_TO_DEV_8 */ + <0x1270000 0x100>, /* NA */ + <0x1280000 0x100>, /* NA */ + <0x1800000 0x80000>, /* VTSS_TO_QSYS */ + <0x1880000 0x10000>; /* VTSS_TO_ANA */ + reg-names = "sys", "rew", "qs", "hsio", "port0", + "port1", "port2", "port3", "port4", "port5", + "port6", "port7", "port8", "port9", + "port10", "qsys", "ana"; + interrupts = <21 22>; + interrupt-names = "xtr", "inj"; + status = "okay"; + + ethernet-ports { + #address-cells = <1>; + #size-cells = <0>; + + port0: port@0 { + reg = <0>; + }; + port1: port@1 { + reg = <1>; + }; + port2: port@2 { + reg = <2>; + }; + port3: port@3 { + reg = <3>; + }; + port4: port@4 { + reg = <4>; + }; + port5: port@5 { + reg = <5>; + }; + port6: port@6 { + reg = <6>; + }; + port7: port@7 { + reg = <7>; + }; + port8: port@8 { + reg = <8>; + }; + port9: port@9 { + reg = <9>; + }; + port10: port@10 { + reg = <10>; + }; + }; + }; + + mdio0: mdio@107009c { + #address-cells = <1>; + #size-cells = <0>; + compatible = "mscc,ocelot-miim"; + reg = <0x107009c 0x24>, <0x10700f0 0x8>; + interrupts = <14>; + status = "disabled"; + + phy0: ethernet-phy@0 { + reg = <0>; + }; + phy1: ethernet-phy@1 { + reg = <1>; + }; + phy2: ethernet-phy@2 { + reg = <2>; + }; + phy3: ethernet-phy@3 { + reg = <3>; + }; + }; + reset@1070008 { compatible = "mscc,ocelot-chip-reset"; reg = <0x1070008 0x4>; @@ -144,6 +236,11 @@ function = "si"; };
+ miim1_pins: miim1-pins { + pins = "GPIO_14", "GPIO_15"; + function = "miim1"; + }; + spi_cs2_pin: spi-cs2-pin { pins = "GPIO_9"; function = "si"; diff --git a/arch/mips/dts/ocelot_pcb123.dts b/arch/mips/dts/ocelot_pcb123.dts index c4cb7a1194..a4fa37001f 100644 --- a/arch/mips/dts/ocelot_pcb123.dts +++ b/arch/mips/dts/ocelot_pcb123.dts @@ -35,3 +35,23 @@ status = "okay"; mscc,sgpio-ports = <0x00FFFFFF>; }; + +&mdio0 { + status = "okay"; +}; + +&port0 { + phy-handle = <&phy0>; +}; + +&port1 { + phy-handle = <&phy1>; +}; + +&port2 { + phy-handle = <&phy2>; +}; + +&port3 { + phy-handle = <&phy3>; +};
This patch adds support for the Microsemi Ethernet switch present on Ocelot SoCs.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- MAINTAINERS | 1 + drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/ocelot_switch.c | 765 ++++++++++++++++++++++++++++++++++++ 4 files changed, 774 insertions(+) create mode 100644 drivers/net/ocelot_switch.c
diff --git a/MAINTAINERS b/MAINTAINERS index 3fa5d3e96f..af44e19eae 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -529,6 +529,7 @@ F: drivers/gpio/mscc_sgpio.c F: drivers/spi/mscc_bb_spi.c F: include/configs/vcoreiii.h F: drivers/pinctrl/mscc/ +F: drivers/net/ocelot_switch.c
MIPS JZ4780 M: Ezequiel Garcia ezequiel@collabora.com diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 7044c6adf3..10ac15cc6c 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -432,6 +432,13 @@ config SNI_AVE This driver implements support for the Socionext AVE Ethernet controller, as found on the Socionext UniPhier family.
+config MSCC_OCELOT_SWITCH + bool "Ocelot switch driver" + depends on DM_ETH && ARCH_MSCC + select PHYLIB + help + This driver supports the Ocelot network switch device. + config ETHER_ON_FEC1 bool "FEC1" depends on MPC8XX_FEC diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 0dbfa03306..bd108c21d1 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -74,3 +74,4 @@ obj-$(CONFIG_DWC_ETH_QOS) += dwc_eth_qos.o obj-$(CONFIG_FSL_PFE) += pfe_eth/ obj-$(CONFIG_SNI_AVE) += sni_ave.o obj-y += ti/ +obj-$(CONFIG_MSCC_OCELOT_SWITCH) += ocelot_switch.o diff --git a/drivers/net/ocelot_switch.c b/drivers/net/ocelot_switch.c new file mode 100644 index 0000000000..9fed26cd94 --- /dev/null +++ b/drivers/net/ocelot_switch.c @@ -0,0 +1,765 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> +#include <config.h> +#include <dm.h> +#include <dm/of_access.h> +#include <dm/of_addr.h> +#include <fdt_support.h> +#include <linux/io.h> +#include <linux/ioport.h> +#include <miiphy.h> +#include <net.h> +#include <wait_bit.h> + +#define MIIM_STATUS 0x0 +#define MIIM_STAT_BUSY BIT(3) +#define MIIM_CMD 0x8 +#define MIIM_CMD_SCAN BIT(0) +#define MIIM_CMD_OPR_WRITE BIT(1) +#define MIIM_CMD_OPR_READ BIT(2) +#define MIIM_CMD_SINGLE_SCAN BIT(3) +#define MIIM_CMD_WRDATA(x) ((x) << 4) +#define MIIM_CMD_REGAD(x) ((x) << 20) +#define MIIM_CMD_PHYAD(x) ((x) << 25) +#define MIIM_CMD_VLD BIT(31) +#define MIIM_DATA 0xC +#define MIIM_DATA_ERROR (0x2 << 16) + +#define PHY_CFG 0x0 +#define PHY_CFG_ENA 0xF +#define PHY_CFG_COMMON_RST BIT(4) +#define PHY_CFG_RST (0xF << 5) +#define PHY_STAT 0x4 +#define PHY_STAT_SUPERVISOR_COMPLETE BIT(0) + +#define ANA_PORT_VLAN_CFG(x) (0x7000 + 0x100 * (x)) +#define ANA_PORT_VLAN_CFG_AWARE_ENA BIT(20) +#define ANA_PORT_VLAN_CFG_POP_CNT(x) ((x) << 18) +#define ANA_PORT_PORT_CFG(x) (0x7070 + 0x100 * (x)) +#define ANA_PORT_PORT_CFG_RECV_ENA BIT(6) +#define ANA_TABLES_MACHDATA 0x8b34 +#define ANA_TABLES_MACLDATA 0x8b38 +#define ANA_TABLES_MACACCESS 0x8b3c +#define ANA_TABLES_MACACCESS_VALID BIT(11) +#define ANA_TABLES_MACACCESS_ENTRYTYPE(x) ((x) << 9) +#define ANA_TABLES_MACACCESS_DEST_IDX(x) ((x) << 3) +#define ANA_TABLES_MACACCESS_MAC_TABLE_CMD(x) (x) +#define ANA_TABLES_MACACCESS_MAC_TABLE_CMD_M GENMASK(2, 0) +#define MACACCESS_CMD_IDLE 0 +#define MACACCESS_CMD_LEARN 1 +#define MACACCESS_CMD_GET_NEXT 4 +#define ANA_PGID(x) (0x8c00 + 4 * (x)) + +#define SYS_FRM_AGING 0x574 +#define SYS_FRM_AGING_ENA BIT(20) + +#define SYS_SYSTEM_RST_CFG 0x508 +#define SYS_SYSTEM_RST_MEM_INIT BIT(0) +#define SYS_SYSTEM_RST_MEM_ENA BIT(1) +#define SYS_SYSTEM_RST_CORE_ENA BIT(2) +#define SYS_PORT_MODE(x) (0x514 + 0x4 * (x)) +#define SYS_PORT_MODE_INCL_INJ_HDR(x) ((x) << 3) +#define SYS_PORT_MODE_INCL_INJ_HDR_M GENMASK(4, 3) +#define SYS_PORT_MODE_INCL_XTR_HDR(x) ((x) << 1) +#define SYS_PORT_MODE_INCL_XTR_HDR_M GENMASK(2, 1) +#define SYS_PAUSE_CFG(x) (0x608 + 0x4 * (x)) +#define SYS_PAUSE_CFG_PAUSE_ENA BIT(0) + +#define QSYS_SWITCH_PORT_MODE(x) (0x11234 + 0x4 * (x)) +#define QSYS_SWITCH_PORT_MODE_PORT_ENA BIT(14) +#define QSYS_QMAP 0x112d8 +#define QSYS_EGR_NO_SHARING 0x1129c + +/* Port registers */ +#define DEV_CLOCK_CFG 0x0 +#define DEV_CLOCK_CFG_LINK_SPEED_1000 1 +#define DEV_MAC_ENA_CFG 0x1c +#define DEV_MAC_ENA_CFG_RX_ENA BIT(4) +#define DEV_MAC_ENA_CFG_TX_ENA BIT(0) + +#define DEV_MAC_IFG_CFG 0x30 +#define DEV_MAC_IFG_CFG_TX_IFG(x) ((x) << 8) +#define DEV_MAC_IFG_CFG_RX_IFG2(x) ((x) << 4) +#define DEV_MAC_IFG_CFG_RX_IFG1(x) (x) + +#define PCS1G_CFG 0x48 +#define PCS1G_MODE_CFG_SGMII_MODE_ENA BIT(0) +#define PCS1G_MODE_CFG 0x4c +#define PCS1G_MODE_CFG_UNIDIR_MODE_ENA BIT(4) +#define PCS1G_MODE_CFG_SGMII_MODE_ENA BIT(0) +#define PCS1G_SD_CFG 0x50 +#define PCS1G_ANEG_CFG 0x54 +#define PCS1G_ANEG_CFG_ADV_ABILITY(x) ((x) << 16) + +#define QS_XTR_GRP_CFG(x) (4 * (x)) +#define QS_XTR_GRP_CFG_MODE(x) ((x) << 2) +#define QS_XTR_GRP_CFG_STATUS_WORD_POS BIT(1) +#define QS_XTR_GRP_CFG_BYTE_SWAP BIT(0) +#define QS_XTR_RD(x) (0x8 + 4 * (x)) +#define QS_XTR_FLUSH 0x18 +#define QS_XTR_FLUSH_FLUSH GENMASK(1, 0) +#define QS_XTR_DATA_PRESENT 0x1c +#define QS_INJ_GRP_CFG(x) (0x24 + (x) * 4) +#define QS_INJ_GRP_CFG_MODE(x) ((x) << 2) +#define QS_INJ_GRP_CFG_BYTE_SWAP BIT(0) +#define QS_INJ_WR(x) (0x2c + 4 * (x)) +#define QS_INJ_CTRL(x) (0x34 + 4 * (x)) +#define QS_INJ_CTRL_GAP_SIZE(x) ((x) << 21) +#define QS_INJ_CTRL_EOF BIT(19) +#define QS_INJ_CTRL_SOF BIT(18) +#define QS_INJ_CTRL_VLD_BYTES(x) ((x) << 16) + +#define XTR_EOF_0 ntohl(0x80000000u) +#define XTR_EOF_1 ntohl(0x80000001u) +#define XTR_EOF_2 ntohl(0x80000002u) +#define XTR_EOF_3 ntohl(0x80000003u) +#define XTR_PRUNED ntohl(0x80000004u) +#define XTR_ABORT ntohl(0x80000005u) +#define XTR_ESCAPE ntohl(0x80000006u) +#define XTR_NOT_READY ntohl(0x80000007u) + +#define IFH_INJ_BYPASS BIT(31) +#define IFH_TAG_TYPE_C 0 +#define XTR_VALID_BYTES(x) (4 - ((x) & 3)) +#define MAC_VID 1 +#define CPU_PORT 11 +#define INTERNAL_PORT_MSK 0xF +#define IFH_LEN 4 +#define OCELOT_BUF_CELL_SZ 60 +#define ETH_ALEN 6 +#define PGID_BROADCAST 13 +#define PGID_UNICAST 14 +#define PGID_SRC 80 + +enum ocelot_target { + ANA, + QS, + QSYS, + REW, + SYS, + HSIO, + PORT0, + PORT1, + PORT2, + PORT3, + TARGET_MAX, +}; + +#define MAX_PORT (PORT3 - PORT0) + +/* MAC table entry types. + * ENTRYTYPE_NORMAL is subject to aging. + * ENTRYTYPE_LOCKED is not subject to aging. + * ENTRYTYPE_MACv4 is not subject to aging. For IPv4 multicast. + * ENTRYTYPE_MACv6 is not subject to aging. For IPv6 multicast. + */ +enum macaccess_entry_type { + ENTRYTYPE_NORMAL = 0, + ENTRYTYPE_LOCKED, + ENTRYTYPE_MACv4, + ENTRYTYPE_MACv6, +}; + +enum ocelot_mdio_target { + MIIM, + PHY, + TARGET_MDIO_MAX, +}; + +enum ocelot_phy_id { + INTERNAL, + EXTERNAL, + NUM_PHY, +}; + +struct ocelot_private { + void __iomem *regs[TARGET_MAX]; + + struct mii_dev *bus[NUM_PHY]; + struct phy_device *phydev; + int phy_mode; + int max_speed; + + int rx_pos; + int rx_siz; + int rx_off; + int tx_num; + + u8 tx_adj_packetbuf[PKTSIZE_ALIGN + PKTALIGN]; + void *tx_adj_buf; +}; + +struct mscc_miim_dev { + void __iomem *regs; + void __iomem *phy_regs; +}; + +struct mscc_miim_dev miim[NUM_PHY]; + +static int mscc_miim_wait_ready(struct mscc_miim_dev *miim) +{ + return wait_for_bit_le32(miim->regs + MIIM_STATUS, MIIM_STAT_BUSY, + false, 250, false); +} + +static int mscc_miim_reset(struct mii_dev *bus) +{ + struct mscc_miim_dev *miim = (struct mscc_miim_dev *)bus->priv; + + if (miim->phy_regs) { + writel(0, miim->phy_regs + PHY_CFG); + writel(PHY_CFG_RST | PHY_CFG_COMMON_RST + | PHY_CFG_ENA, miim->phy_regs + PHY_CFG); + mdelay(500); + } + + return 0; +} + +static int mscc_miim_read(struct mii_dev *bus, int addr, int devad, int reg) +{ + struct mscc_miim_dev *miim = (struct mscc_miim_dev *)bus->priv; + u32 val; + int ret; + + ret = mscc_miim_wait_ready(miim); + if (ret) + goto out; + + writel(MIIM_CMD_VLD | MIIM_CMD_PHYAD(addr) | + MIIM_CMD_REGAD(reg) | MIIM_CMD_OPR_READ, + miim->regs + MIIM_CMD); + + ret = mscc_miim_wait_ready(miim); + if (ret) + goto out; + + val = readl(miim->regs + MIIM_DATA); + if (val & MIIM_DATA_ERROR) { + ret = -EIO; + goto out; + } + + ret = val & 0xFFFF; + out: + return ret; +} + +static int mscc_miim_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 val) +{ + struct mscc_miim_dev *miim = (struct mscc_miim_dev *)bus->priv; + int ret; + + ret = mscc_miim_wait_ready(miim); + if (ret < 0) + goto out; + + writel(MIIM_CMD_VLD | MIIM_CMD_PHYAD(addr) | + MIIM_CMD_REGAD(reg) | MIIM_CMD_WRDATA(val) | + MIIM_CMD_OPR_WRITE, miim->regs + MIIM_CMD); + out: + return ret; +} + +/* For now only setup the internal mdio bus */ +static struct mii_dev *ocelot_mdiobus_init(struct udevice *dev) +{ + unsigned long phy_size[TARGET_MAX]; + phys_addr_t phy_base[TARGET_MAX]; + struct ofnode_phandle_args phandle; + ofnode eth_node, node, mdio_node; + struct resource res; + struct mii_dev *bus; + fdt32_t faddr; + int i; + + bus = mdio_alloc(); + + if (!bus) + return NULL; + + /* gathered only the first mdio bus */ + eth_node = dev_read_first_subnode(dev); + node = ofnode_first_subnode(eth_node); + ofnode_parse_phandle_with_args(node, "phy-handle", NULL, 0, 0, + &phandle); + mdio_node = ofnode_get_parent(phandle.node); + + for (i = 0; i < TARGET_MDIO_MAX; i++) { + if (ofnode_read_resource(mdio_node, i, &res)) { + pr_err("%s: get OF resource failed\n", __func__); + return NULL; + } + faddr = cpu_to_fdt32(res.start); + phy_base[i] = ofnode_translate_address(mdio_node, &faddr); + phy_size[i] = res.end - res.start; + } + + strcpy(bus->name, "miim-internal"); + miim[INTERNAL].phy_regs = ioremap(phy_base[PHY], phy_size[PHY]); + miim[INTERNAL].regs = ioremap(phy_base[MIIM], phy_size[MIIM]); + bus->priv = &miim[INTERNAL]; + bus->reset = mscc_miim_reset; + bus->read = mscc_miim_read; + bus->write = mscc_miim_write; + + if (mdio_register(bus)) + return NULL; + else + return bus; +} + +__weak void mscc_switch_reset(void) +{ +} + +static void ocelot_stop(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + int i; + + mscc_switch_reset(); + for (i = 0; i < NUM_PHY; i++) + if (priv->bus[i]) + mscc_miim_reset(priv->bus[i]); +} + +static void ocelot_cpu_capture_setup(struct ocelot_private *priv) +{ + int i; + + /* map the 8 CPU extraction queues to CPU port 11 */ + writel(0, priv->regs[QSYS] + QSYS_QMAP); + + for (i = 0; i <= 1; i++) { + /* + * Do byte-swap and expect status after last data word + * Extraction: Mode: manual extraction) | Byte_swap + */ + writel(QS_XTR_GRP_CFG_MODE(1) | QS_XTR_GRP_CFG_BYTE_SWAP, + priv->regs[QS] + QS_XTR_GRP_CFG(i)); + /* + * Injection: Mode: manual extraction | Byte_swap + */ + writel(QS_INJ_GRP_CFG_MODE(1) | QS_INJ_GRP_CFG_BYTE_SWAP, + priv->regs[QS] + QS_INJ_GRP_CFG(i)); + } + + for (i = 0; i <= 1; i++) + /* Enable IFH insertion/parsing on CPU ports */ + writel(SYS_PORT_MODE_INCL_INJ_HDR(1) | + SYS_PORT_MODE_INCL_XTR_HDR(1), + priv->regs[SYS] + SYS_PORT_MODE(CPU_PORT + i)); + /* + * Setup the CPU port as VLAN aware to support switching frames + * based on tags + */ + writel(ANA_PORT_VLAN_CFG_AWARE_ENA | ANA_PORT_VLAN_CFG_POP_CNT(1) | + MAC_VID, priv->regs[ANA] + ANA_PORT_VLAN_CFG(CPU_PORT)); + + /* Disable learning (only RECV_ENA must be set) */ + writel(ANA_PORT_PORT_CFG_RECV_ENA, + priv->regs[ANA] + ANA_PORT_PORT_CFG(CPU_PORT)); + + /* Enable switching to/from cpu port */ + setbits_le32(priv->regs[QSYS] + QSYS_SWITCH_PORT_MODE(CPU_PORT), + QSYS_SWITCH_PORT_MODE_PORT_ENA); + + /* No pause on CPU port - not needed (off by default) */ + clrbits_le32(priv->regs[SYS] + SYS_PAUSE_CFG(CPU_PORT), + SYS_PAUSE_CFG_PAUSE_ENA); + + setbits_le32(priv->regs[QSYS] + QSYS_EGR_NO_SHARING, BIT(CPU_PORT)); +} + +static void ocelot_port_init(struct ocelot_private *priv, int port) +{ + void __iomem *regs = priv->regs[port]; + + /* Enable PCS */ + writel(PCS1G_MODE_CFG_SGMII_MODE_ENA, regs + PCS1G_CFG); + + /* Disable Signal Detect */ + writel(0, regs + PCS1G_SD_CFG); + + /* Enable MAC RX and TX */ + writel(DEV_MAC_ENA_CFG_RX_ENA | DEV_MAC_ENA_CFG_TX_ENA, + regs + DEV_MAC_ENA_CFG); + + /* Clear sgmii_mode_ena */ + writel(0, regs + PCS1G_MODE_CFG); + + /* + * Clear sw_resolve_ena(bit 0) and set adv_ability to + * something meaningful just in case + */ + writel(PCS1G_ANEG_CFG_ADV_ABILITY(0x20), regs + PCS1G_ANEG_CFG); + + /* Set MAC IFG Gaps */ + writel(DEV_MAC_IFG_CFG_TX_IFG(5) | DEV_MAC_IFG_CFG_RX_IFG1(5) | + DEV_MAC_IFG_CFG_RX_IFG2(1), regs + DEV_MAC_IFG_CFG); + + /* Set link speed and release all resets */ + writel(DEV_CLOCK_CFG_LINK_SPEED_1000, regs + DEV_CLOCK_CFG); + + /* Make VLAN aware for CPU traffic */ + writel(ANA_PORT_VLAN_CFG_AWARE_ENA | ANA_PORT_VLAN_CFG_POP_CNT(1) | + MAC_VID, priv->regs[ANA] + ANA_PORT_VLAN_CFG(port - PORT0)); + + /* Enable the port in the core */ + setbits_le32(priv->regs[QSYS] + QSYS_SWITCH_PORT_MODE(port - PORT0), + QSYS_SWITCH_PORT_MODE_PORT_ENA); +} + +static int ocelot_switch_init(struct ocelot_private *priv) +{ + /* Reset switch & memories */ + writel(SYS_SYSTEM_RST_MEM_ENA | SYS_SYSTEM_RST_MEM_INIT, + priv->regs[SYS] + SYS_SYSTEM_RST_CFG); + + /* Wait to complete */ + if (wait_for_bit_le32(priv->regs[SYS] + SYS_SYSTEM_RST_CFG, + SYS_SYSTEM_RST_MEM_INIT, false, 2000, false)) { + pr_err("Timeout in memory reset\n"); + return -EIO; + } + + /* Enable switch core */ + setbits_le32(priv->regs[SYS] + SYS_SYSTEM_RST_CFG, + SYS_SYSTEM_RST_CORE_ENA); + + return 0; +} + +static void ocelot_switch_flush(struct ocelot_private *priv) +{ + /* All Queues flush */ + setbits_le32(priv->regs[QS] + QS_XTR_FLUSH, QS_XTR_FLUSH_FLUSH); + /* Allow to drain */ + mdelay(1); + /* All Queues normal */ + clrbits_le32(priv->regs[QS] + QS_XTR_FLUSH, QS_XTR_FLUSH_FLUSH); +} + +static int ocelot_initialize(struct ocelot_private *priv) +{ + int ret, i; + + /* Initialize switch memories, enable core */ + ret = ocelot_switch_init(priv); + if (ret) + return ret; + /* + * Disable port-to-port by switching + * Put fron ports in "port isolation modes" - i.e. they cant send + * to other ports - via the PGID sorce masks. + */ + for (i = 0; i <= MAX_PORT; i++) + writel(0, priv->regs[ANA] + ANA_PGID(PGID_SRC + i)); + + /* Flush queues */ + ocelot_switch_flush(priv); + + /* Setup frame ageing - "2 sec" - The unit is 6.5us on Ocelot */ + writel(SYS_FRM_AGING_ENA | (20000000 / 65), + priv->regs[SYS] + SYS_FRM_AGING); + + for (i = PORT0; i <= PORT3; i++) + ocelot_port_init(priv, i); + + ocelot_cpu_capture_setup(priv); + + debug("Ports enabled\n"); + + return 0; +} + +static inline int ocelot_vlant_wait_for_completion(struct ocelot_private *priv) +{ + unsigned int val, timeout = 10; + + /* Wait for the issued mac table command to be completed, or timeout. + * When the command read from ANA_TABLES_MACACCESS is + * MACACCESS_CMD_IDLE, the issued command completed successfully. + */ + do { + val = readl(priv->regs[ANA] + ANA_TABLES_MACACCESS); + val &= ANA_TABLES_MACACCESS_MAC_TABLE_CMD_M; + } while (val != MACACCESS_CMD_IDLE && timeout--); + + if (!timeout) + return -ETIMEDOUT; + + return 0; +} + +static int ocelot_mac_table_add(struct ocelot_private *priv, + const unsigned char mac[ETH_ALEN], int pgid) +{ + u32 macl = 0, mach = 0; + int ret; + + /* Set the MAC address to handle and the vlan associated in a format + * understood by the hardware. + */ + mach |= MAC_VID << 16; + mach |= ((u32)mac[0]) << 8; + mach |= ((u32)mac[1]) << 0; + macl |= ((u32)mac[2]) << 24; + macl |= ((u32)mac[3]) << 16; + macl |= ((u32)mac[4]) << 8; + macl |= ((u32)mac[5]) << 0; + + writel(macl, priv->regs[ANA] + ANA_TABLES_MACLDATA); + writel(mach, priv->regs[ANA] + ANA_TABLES_MACHDATA); + + writel(ANA_TABLES_MACACCESS_VALID | + ANA_TABLES_MACACCESS_DEST_IDX(pgid) | + ANA_TABLES_MACACCESS_ENTRYTYPE(ENTRYTYPE_LOCKED) | + ANA_TABLES_MACACCESS_MAC_TABLE_CMD(MACACCESS_CMD_LEARN), + priv->regs[ANA] + ANA_TABLES_MACACCESS); + + ret = ocelot_vlant_wait_for_completion(priv); + + return ret; +} + +static int ocelot_write_hwaddr(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + + ocelot_mac_table_add(priv, pdata->enetaddr, PGID_UNICAST); + + writel(BIT(CPU_PORT), priv->regs[ANA] + ANA_PGID(PGID_UNICAST)); + + return 0; +} + +static int ocelot_start(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + const unsigned char mac[ETH_ALEN] = { 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff }; + int ret; + + ret = ocelot_initialize(priv); + if (ret) + return ret; + + /* Set MAC address tables entries for CPU redirection */ + ocelot_mac_table_add(priv, mac, PGID_BROADCAST); + + writel(BIT(CPU_PORT) | INTERNAL_PORT_MSK, + priv->regs[ANA] + ANA_PGID(PGID_BROADCAST)); + + /* It should be setup latter in ocelot_write_hwaddr */ + ocelot_mac_table_add(priv, pdata->enetaddr, PGID_UNICAST); + + writel(BIT(CPU_PORT), priv->regs[ANA] + ANA_PGID(PGID_UNICAST)); + + return 0; +} + +static int ocelot_send(struct udevice *dev, void *packet, int length) +{ + struct ocelot_private *priv = dev_get_priv(dev); + u32 ifh[IFH_LEN]; + int port = BIT(0); /* use port 0 */ + u8 grp = 0; /* Send everything on CPU group 0 */ + int i, count = (length + 3) / 4, last = length % 4; + u32 *buf = packet; + + writel(QS_INJ_CTRL_GAP_SIZE(1) | QS_INJ_CTRL_SOF, + priv->regs[QS] + QS_INJ_CTRL(grp)); + + /* + * Generate the IFH for frame injection + * + * The IFH is a 128bit-value + * bit 127: bypass the analyzer processing + * bit 56-67: destination mask + * bit 28-29: pop_cnt: 3 disables all rewriting of the frame + * bit 20-27: cpu extraction queue mask + * bit 16: tag type 0: C-tag, 1: S-tag + * bit 0-11: VID + */ + ifh[0] = IFH_INJ_BYPASS; + ifh[1] = (0xf00 & port) >> 8; + ifh[2] = (0xff & port) << 24; + ifh[3] = (IFH_TAG_TYPE_C << 16); + + for (i = 0; i < IFH_LEN; i++) + writel(ifh[i], priv->regs[QS] + QS_INJ_WR(grp)); + + for (i = 0; i < count; i++) + writel(buf[i], priv->regs[QS] + QS_INJ_WR(grp)); + + /* Add padding */ + while (i < (OCELOT_BUF_CELL_SZ / 4)) { + writel(0, priv->regs[QS] + QS_INJ_WR(grp)); + i++; + } + + /* Indicate EOF and valid bytes in last word */ + writel(QS_INJ_CTRL_GAP_SIZE(1) | + QS_INJ_CTRL_VLD_BYTES(length < OCELOT_BUF_CELL_SZ ? 0 : last) | + QS_INJ_CTRL_EOF, priv->regs[QS] + QS_INJ_CTRL(grp)); + + /* Add dummy CRC */ + writel(0, priv->regs[QS] + QS_INJ_WR(grp)); + + return 0; +} + +static int ocelot_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct ocelot_private *priv = dev_get_priv(dev); + u8 grp = 0; /* Send everything on CPU group 0 */ + u32 *rxbuf = (u32 *)net_rx_packets[0]; + int i, byte_cnt = 0; + bool eof_flag = false, pruned_flag = false, abort_flag = false; + + if (!(readl(priv->regs[QS] + QS_XTR_DATA_PRESENT) & BIT(grp))) + return -EAGAIN; + + /* skip IFH */ + for (i = 0; i < IFH_LEN; i++) + readl(priv->regs[QS] + QS_XTR_RD(grp)); + + while (!eof_flag) { + u32 val = readl(priv->regs[QS] + QS_XTR_RD(grp)); + + switch (val) { + case XTR_NOT_READY: + debug("%d NOT_READY...?\n", byte_cnt); + break; + case XTR_ABORT: + /* really nedeed?? not done in linux */ + *rxbuf = readl(priv->regs[QS] + QS_XTR_RD(grp)); + abort_flag = true; + eof_flag = true; + debug("XTR_ABORT\n"); + break; + case XTR_EOF_0: + case XTR_EOF_1: + case XTR_EOF_2: + case XTR_EOF_3: + byte_cnt += XTR_VALID_BYTES(val); + *rxbuf = readl(priv->regs[QS] + QS_XTR_RD(grp)); + eof_flag = true; + debug("EOF\n"); + break; + case XTR_PRUNED: + /* But get the last 4 bytes as well */ + eof_flag = true; + pruned_flag = true; + debug("PRUNED\n"); + /* fallthrough */ + case XTR_ESCAPE: + *rxbuf = readl(priv->regs[QS] + QS_XTR_RD(grp)); + byte_cnt += 4; + rxbuf++; + debug("ESCAPED\n"); + break; + default: + *rxbuf = val; + byte_cnt += 4; + rxbuf++; + } + } + + if (abort_flag || pruned_flag || !eof_flag) { + debug("Discarded frame: abort:%d pruned:%d eof:%d\n", + abort_flag, pruned_flag, eof_flag); + return -EAGAIN; + } + + *packetp = net_rx_packets[0]; + + return byte_cnt; +} + +static int ocelot_probe(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + int ret, i; + + struct { + enum ocelot_target id; + char *name; + } reg[] = { + { SYS, "sys" }, + { REW, "rew" }, + { QSYS, "qsys" }, + { ANA, "ana" }, + { QS, "qs" }, + { HSIO, "hsio" }, + { PORT0, "port0" }, + { PORT1, "port1" }, + { PORT2, "port2" }, + { PORT3, "port3" }, + }; + + for (i = 0; i < ARRAY_SIZE(reg); i++) { + priv->regs[reg[i].id] = dev_remap_addr_name(dev, reg[i].name); + if (!priv->regs[reg[i].id]) { + pr_err + ("Error %d: can't get regs base addresses for %s\n", + ret, reg[i].name); + return -ENOMEM; + } + } + + priv->bus[INTERNAL] = ocelot_mdiobus_init(dev); + + for (i = 0; i < 4; i++) { + phy_connect(priv->bus[INTERNAL], i, dev, + PHY_INTERFACE_MODE_NONE); + } + + return 0; +} + +static int ocelot_remove(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + int i; + + for (i = 0; i < NUM_PHY; i++) { + mdio_unregister(priv->bus[i]); + mdio_free(priv->bus[i]); + } + + return 0; +} + +static const struct eth_ops ocelot_ops = { + .start = ocelot_start, + .stop = ocelot_stop, + .send = ocelot_send, + .recv = ocelot_recv, + .write_hwaddr = ocelot_write_hwaddr, +}; + +static const struct udevice_id mscc_ocelot_ids[] = { + {.compatible = "mscc,vsc7514-switch"}, + { /* Sentinel */ } +}; + +U_BOOT_DRIVER(ocelot) = { + .name = "ocelot-switch", + .id = UCLASS_ETH, + .of_match = mscc_ocelot_ids, + .probe = ocelot_probe, + .remove = ocelot_remove, + .ops = &ocelot_ops, + .priv_auto_alloc_size = sizeof(struct ocelot_private), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +};
Am 17.01.19 um 17:07 schrieb Gregory CLEMENT:
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
On some ocelots platform a workaround is needed in order to be able to reset the switch without resetting the DDR.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- board/mscc/ocelot/ocelot.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/board/mscc/ocelot/ocelot.c b/board/mscc/ocelot/ocelot.c index 0f7a532158..532d06f000 100644 --- a/board/mscc/ocelot/ocelot.c +++ b/board/mscc/ocelot/ocelot.c @@ -10,6 +10,7 @@ #include <environment.h> #include <spi.h> #include <led.h> +#include <wait_bit.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -18,6 +19,29 @@ enum { BOARD_TYPE_PCB123, };
+void mscc_switch_reset(bool enter) +{ + /* Nasty workaround to avoid GPIO19 (DDR!) being reset */ + mscc_gpio_set_alternate(19, 2); + + debug("applying SwC reset\n"); + + writel(ICPU_RESET_CORE_RST_PROTECT, BASE_CFG + ICPU_RESET); + writel(PERF_SOFT_RST_SOFT_CHIP_RST, BASE_DEVCPU_GCB + PERF_SOFT_RST); + + if (wait_for_bit_le32(BASE_DEVCPU_GCB + PERF_SOFT_RST, + PERF_SOFT_RST_SOFT_CHIP_RST, false, 5000, false)) + pr_err("Tiemout while waiting for switch reset\n"); + + /* + * Reset GPIO19 mode back as regular GPIO, output, high (DDR + * not reset) (Order is important) + */ + setbits_le32(BASE_DEVCPU_GCB + PERF_GPIO_OE, BIT(19)); + writel(BIT(19), BASE_DEVCPU_GCB + PERF_GPIO_OUT_SET); + mscc_gpio_set_alternate(19, 0); +} + void board_debug_uart_init(void) { /* too early for the pinctrl driver, so configure the UART pins here */
Now that network support is added for the ocelot platform, let's add it in the default configuration.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- configs/mscc_ocelot_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index fb6a5bdc31..792d00e646 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -60,6 +60,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_MTD=y CONFIG_DM_ETH=y +CONFIG_MSCC_OCELOT_SWITCH=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_DM_SERIAL=y
Hello,
Gregory
v1 -> v2:
series applied to u-boot-mips, thanks.
Daniel Schwierzeck
Gregory CLEMENT
