[U-Boot] [PATCH v3 8/8] dm: define dev_*() log functions in DM header
Many drivers had started to use dev_err, dev_info, etc. for log functions. Currently, we are relying on <linux/compat.h>, but I guess the best home is <dm/device.h>, taking into account that Linux defines them in <linux/device.h>.
For now, I am leaving the ones in <linux/compat.h> because lots of Linux-originated code uses dev_*(), but the first argument is not struct udevice, so we need to ignore the bogus argument. More efforts are needed to iron out the issues.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v3: - Rename dev_emerge to dev_emerg to adjust to Linux
Changes in v2: - Newly added
include/dm/device.h | 72 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/linux/compat.h | 17 ++++++++++++ 2 files changed, 89 insertions(+)
diff --git a/include/dm/device.h b/include/dm/device.h index 4866f7c..813e49f 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -18,6 +18,7 @@ #include <linux/compat.h> #include <linux/kernel.h> #include <linux/list.h> +#include <linux/printk.h>
struct driver_info;
@@ -879,4 +880,75 @@ static inline void devm_kfree(struct udevice *dev, void *ptr)
#endif /* ! CONFIG_DEVRES */
+/* + * REVISIT: + * remove the following after resolving conflicts with <linux/compat.h> + */ +#ifdef dev_dbg +#undef dev_dbg +#endif +#ifdef dev_vdbg +#undef dev_vdbg +#endif +#ifdef dev_info +#undef dev_info +#endif +#ifdef dev_err +#undef dev_err +#endif +#ifdef dev_warn +#undef dev_warn +#endif + +/* + * REVISIT: + * print device name like Linux + */ +#define dev_printk(dev, fmt, ...) \ +({ \ + printk(fmt, ##__VA_ARGS__); \ +}) + +#define __dev_printk(level, dev, fmt, ...) \ +({ \ + if (level < CONFIG_VAL(LOGLEVEL)) \ + dev_printk(dev, fmt, ##__VA_ARGS__); \ +}) + +#define dev_emerg(dev, fmt, ...) \ + __dev_printk(0, dev, fmt, ##__VA_ARGS__) +#define dev_alert(dev, fmt, ...) \ + __dev_printk(1, dev, fmt, ##__VA_ARGS__) +#define dev_crit(dev, fmt, ...) \ + __dev_printk(2, dev, fmt, ##__VA_ARGS__) +#define dev_err(dev, fmt, ...) \ + __dev_printk(3, dev, fmt, ##__VA_ARGS__) +#define dev_warn(dev, fmt, ...) \ + __dev_printk(4, dev, fmt, ##__VA_ARGS__) +#define dev_notice(dev, fmt, ...) \ + __dev_printk(5, dev, fmt, ##__VA_ARGS__) +#define dev_info(dev, fmt, ...) \ + __dev_printk(6, dev, fmt, ##__VA_ARGS__) + +#ifdef DEBUG +#define dev_dbg(dev, fmt, ...) \ + __dev_printk(7, dev, fmt, ##__VA_ARGS__) +#else +#define dev_dbg(dev, fmt, ...) \ +({ \ + if (0) \ + __dev_printk(7, dev, fmt, ##__VA_ARGS__); \ +}) +#endif + +#ifdef VERBOSE_DEBUG +#define dev_vdbg dev_dbg +#else +#define dev_vdbg(dev, fmt, ...) \ +({ \ + if (0) \ + __dev_printk(7, dev, fmt, ##__VA_ARGS__); \ +}) +#endif + #endif diff --git a/include/linux/compat.h b/include/linux/compat.h index 1b3f089..8711fe2 100644 --- a/include/linux/compat.h +++ b/include/linux/compat.h @@ -15,6 +15,23 @@ struct p_current{
extern struct p_current *current;
+/* avoid conflict with <dm/device.h> */ +#ifdef dev_dbg +#undef dev_dbg +#endif +#ifdef dev_vdbg +#undef dev_vdbg +#endif +#ifdef dev_info +#undef dev_info +#endif +#ifdef dev_err +#undef dev_err +#endif +#ifdef dev_warn +#undef dev_warn +#endif + #define dev_dbg(dev, fmt, args...) \ debug(fmt, ##args) #define dev_vdbg(dev, fmt, args...) \
Masahiro Yamada
