[U-Boot] [PATCH 04/11] README: Review the u-boot porting guide list
* There is no boards.cfg anymore, so drop (1). * Creating flash.c and u-boot.lds seems not mandatory as well. * Adjusting the enumerators for the above implicitly fixed for double items numbered (3).
Signed-off-by: Phil Sutter phil@nwl.cc --- README | 11 ++++------- 1 file changed, 4 insertions(+), 7 deletions(-)
diff --git a/README b/README index 4fee706..dcc9478 100644 --- a/README +++ b/README @@ -5153,14 +5153,11 @@ If the system board that you have is not listed, then you will need to port U-Boot to your hardware platform. To do this, follow these steps:
-1. Add a new configuration option for your board to the toplevel - "boards.cfg" file, using the existing entries as examples. - Follow the instructions there to keep the boards in order. -2. Create a new directory to hold your board specific code. Add any +1. Create a new directory to hold your board specific code. Add any files you need. In your board directory, you will need at least - the "Makefile", a "<board>.c", "flash.c" and "u-boot.lds". -3. Create a new configuration file "include/configs/<board>.h" for - your board + the "Makefile" and a "<board>.c". +2. Create a new configuration file "include/configs/<board>.h" for + your board. 3. If you're porting U-Boot to a new CPU, then also create a new directory to hold your CPU specific code. Add any files you need. 4. Run "make <board>_defconfig" with your new name.
Phil Sutter
