[U-Boot] [PATCH v2 u-boot] ARM: meson: rename GXBB to GX
Taking into account the Amlogic Family name starts with GX, including the GXBB, GXL and GXM SoCs.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com ---
Changes since v1: - Resent as single patch since cpuinfo needs further work - Aligned the defines in gx.h
arch/arm/include/asm/arch-meson/gx.h | 70 +++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-meson/gxbb.h | 70 ------------------------------- arch/arm/mach-meson/board.c | 28 ++++++------- arch/arm/mach-meson/eth.c | 24 +++++------ arch/arm/mach-meson/sm.c | 2 +- board/amlogic/khadas-vim/khadas-vim.c | 2 +- board/amlogic/libretech-cc/libretech-cc.c | 6 +-- board/amlogic/odroid-c2/odroid-c2.c | 10 ++--- board/amlogic/p212/p212.c | 2 +- include/configs/khadas-vim.h | 2 +- include/configs/libretech-cc.h | 2 +- include/configs/meson-gx-common.h | 47 +++++++++++++++++++++ include/configs/meson-gxbb-common.h | 47 --------------------- include/configs/odroid-c2.h | 2 +- include/configs/p212.h | 2 +- 15 files changed, 158 insertions(+), 158 deletions(-) create mode 100644 arch/arm/include/asm/arch-meson/gx.h delete mode 100644 arch/arm/include/asm/arch-meson/gxbb.h create mode 100644 include/configs/meson-gx-common.h delete mode 100644 include/configs/meson-gxbb-common.h
diff --git a/arch/arm/include/asm/arch-meson/gx.h b/arch/arm/include/asm/arch-meson/gx.h new file mode 100644 index 0000000..2b311cd --- /dev/null +++ b/arch/arm/include/asm/arch-meson/gx.h @@ -0,0 +1,70 @@ +/* + * (C) Copyright 2016 - Beniamino Galvani b.galvani@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __GX_H__ +#define __GX_H__ + +#define GX_FIRMWARE_MEM_SIZE 0x1000000 + +#define GX_AOBUS_BASE 0xc8100000 +#define GX_PERIPHS_BASE 0xc8834400 +#define GX_HIU_BASE 0xc883c000 +#define GX_ETH_BASE 0xc9410000 + +/* Always-On Peripherals registers */ +#define GX_AO_ADDR(off) (GX_AOBUS_BASE + ((off) << 2)) + +#define GX_AO_SEC_GP_CFG0 GX_AO_ADDR(0x90) +#define GX_AO_SEC_GP_CFG3 GX_AO_ADDR(0x93) +#define GX_AO_SEC_GP_CFG4 GX_AO_ADDR(0x94) +#define GX_AO_SEC_GP_CFG5 GX_AO_ADDR(0x95) + +#define GX_AO_MEM_SIZE_MASK 0xFFFF0000 +#define GX_AO_MEM_SIZE_SHIFT 16 +#define GX_AO_BL31_RSVMEM_SIZE_MASK 0xFFFF0000 +#define GX_AO_BL31_RSVMEM_SIZE_SHIFT 16 +#define GX_AO_BL32_RSVMEM_SIZE_MASK 0xFFFF + +/* Peripherals registers */ +#define GX_PERIPHS_ADDR(off) (GX_PERIPHS_BASE + ((off) << 2)) + +/* GPIO registers 0 to 6 */ +#define _GX_GPIO_OFF(n) ((n) == 6 ? 0x08 : 0x0c + 3 * (n)) +#define GX_GPIO_EN(n) GX_PERIPHS_ADDR(_GX_GPIO_OFF(n) + 0) +#define GX_GPIO_IN(n) GX_PERIPHS_ADDR(_GX_GPIO_OFF(n) + 1) +#define GX_GPIO_OUT(n) GX_PERIPHS_ADDR(_GX_GPIO_OFF(n) + 2) + +#define GX_ETH_REG_0 GX_PERIPHS_ADDR(0x50) +#define GX_ETH_REG_1 GX_PERIPHS_ADDR(0x51) +#define GX_ETH_REG_2 GX_PERIPHS_ADDR(0x56) +#define GX_ETH_REG_3 GX_PERIPHS_ADDR(0x57) + +#define GX_ETH_REG_0_PHY_INTF BIT(0) +#define GX_ETH_REG_0_TX_PHASE(x) (((x) & 3) << 5) +#define GX_ETH_REG_0_TX_RATIO(x) (((x) & 7) << 7) +#define GX_ETH_REG_0_PHY_CLK_EN BIT(10) +#define GX_ETH_REG_0_INVERT_RMII_CLK BIT(11) +#define GX_ETH_REG_0_CLK_EN BIT(12) + +/* HIU registers */ +#define GX_HIU_ADDR(off) (GX_HIU_BASE + ((off) << 2)) + +#define GX_MEM_PD_REG_0 GX_HIU_ADDR(0x40) + +/* Ethernet memory power domain */ +#define GX_MEM_PD_REG_0_ETH_MASK (BIT(2) | BIT(3)) + +/* Clock gates */ +#define GX_GCLK_MPEG_0 GX_HIU_ADDR(0x50) +#define GX_GCLK_MPEG_1 GX_HIU_ADDR(0x51) +#define GX_GCLK_MPEG_2 GX_HIU_ADDR(0x52) +#define GX_GCLK_MPEG_OTHER GX_HIU_ADDR(0x53) +#define GX_GCLK_MPEG_AO GX_HIU_ADDR(0x54) + +#define GX_GCLK_MPEG_0_I2C BIT(9) +#define GX_GCLK_MPEG_1_ETH BIT(3) + +#endif /* __GX_H__ */ diff --git a/arch/arm/include/asm/arch-meson/gxbb.h b/arch/arm/include/asm/arch-meson/gxbb.h deleted file mode 100644 index ef63dea..0000000 --- a/arch/arm/include/asm/arch-meson/gxbb.h +++ /dev/null @@ -1,70 +0,0 @@ -/* - * (C) Copyright 2016 - Beniamino Galvani b.galvani@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __GXBB_H__ -#define __GXBB_H__ - -#define GXBB_FIRMWARE_MEM_SIZE 0x1000000 - -#define GXBB_AOBUS_BASE 0xc8100000 -#define GXBB_PERIPHS_BASE 0xc8834400 -#define GXBB_HIU_BASE 0xc883c000 -#define GXBB_ETH_BASE 0xc9410000 - -/* Always-On Peripherals registers */ -#define GXBB_AO_ADDR(off) (GXBB_AOBUS_BASE + ((off) << 2)) - -#define GXBB_AO_SEC_GP_CFG0 GXBB_AO_ADDR(0x90) -#define GXBB_AO_SEC_GP_CFG3 GXBB_AO_ADDR(0x93) -#define GXBB_AO_SEC_GP_CFG4 GXBB_AO_ADDR(0x94) -#define GXBB_AO_SEC_GP_CFG5 GXBB_AO_ADDR(0x95) - -#define GXBB_AO_MEM_SIZE_MASK 0xFFFF0000 -#define GXBB_AO_MEM_SIZE_SHIFT 16 -#define GXBB_AO_BL31_RSVMEM_SIZE_MASK 0xFFFF0000 -#define GXBB_AO_BL31_RSVMEM_SIZE_SHIFT 16 -#define GXBB_AO_BL32_RSVMEM_SIZE_MASK 0xFFFF - -/* Peripherals registers */ -#define GXBB_PERIPHS_ADDR(off) (GXBB_PERIPHS_BASE + ((off) << 2)) - -/* GPIO registers 0 to 6 */ -#define _GXBB_GPIO_OFF(n) ((n) == 6 ? 0x08 : 0x0c + 3 * (n)) -#define GXBB_GPIO_EN(n) GXBB_PERIPHS_ADDR(_GXBB_GPIO_OFF(n) + 0) -#define GXBB_GPIO_IN(n) GXBB_PERIPHS_ADDR(_GXBB_GPIO_OFF(n) + 1) -#define GXBB_GPIO_OUT(n) GXBB_PERIPHS_ADDR(_GXBB_GPIO_OFF(n) + 2) - -#define GXBB_ETH_REG_0 GXBB_PERIPHS_ADDR(0x50) -#define GXBB_ETH_REG_1 GXBB_PERIPHS_ADDR(0x51) -#define GXBB_ETH_REG_2 GXBB_PERIPHS_ADDR(0x56) -#define GXBB_ETH_REG_3 GXBB_PERIPHS_ADDR(0x57) - -#define GXBB_ETH_REG_0_PHY_INTF BIT(0) -#define GXBB_ETH_REG_0_TX_PHASE(x) (((x) & 3) << 5) -#define GXBB_ETH_REG_0_TX_RATIO(x) (((x) & 7) << 7) -#define GXBB_ETH_REG_0_PHY_CLK_EN BIT(10) -#define GXBB_ETH_REG_0_INVERT_RMII_CLK BIT(11) -#define GXBB_ETH_REG_0_CLK_EN BIT(12) - -/* HIU registers */ -#define GXBB_HIU_ADDR(off) (GXBB_HIU_BASE + ((off) << 2)) - -#define GXBB_MEM_PD_REG_0 GXBB_HIU_ADDR(0x40) - -/* Ethernet memory power domain */ -#define GXBB_MEM_PD_REG_0_ETH_MASK (BIT(2) | BIT(3)) - -/* Clock gates */ -#define GXBB_GCLK_MPEG_0 GXBB_HIU_ADDR(0x50) -#define GXBB_GCLK_MPEG_1 GXBB_HIU_ADDR(0x51) -#define GXBB_GCLK_MPEG_2 GXBB_HIU_ADDR(0x52) -#define GXBB_GCLK_MPEG_OTHER GXBB_HIU_ADDR(0x53) -#define GXBB_GCLK_MPEG_AO GXBB_HIU_ADDR(0x54) - -#define GXBB_GCLK_MPEG_0_I2C BIT(9) -#define GXBB_GCLK_MPEG_1_ETH BIT(3) - -#endif /* __GXBB_H__ */ diff --git a/arch/arm/mach-meson/board.c b/arch/arm/mach-meson/board.c index b6d3a17..0693d9d 100644 --- a/arch/arm/mach-meson/board.c +++ b/arch/arm/mach-meson/board.c @@ -7,7 +7,7 @@ #include <common.h> #include <linux/libfdt.h> #include <linux/err.h> -#include <asm/arch/gxbb.h> +#include <asm/arch/gx.h> #include <asm/arch/sm.h> #include <asm/armv8/mmu.h> #include <asm/unaligned.h> @@ -40,8 +40,8 @@ int dram_init(void) phys_size_t get_effective_memsize(void) { /* Size is reported in MiB, convert it in bytes */ - return ((readl(GXBB_AO_SEC_GP_CFG0) & GXBB_AO_MEM_SIZE_MASK) - >> GXBB_AO_MEM_SIZE_SHIFT) * SZ_1M; + return ((readl(GX_AO_SEC_GP_CFG0) & GX_AO_MEM_SIZE_MASK) + >> GX_AO_MEM_SIZE_SHIFT) * SZ_1M; }
static void meson_board_add_reserved_memory(void *fdt, u64 start, u64 size) @@ -72,27 +72,27 @@ void meson_gx_init_reserved_memory(void *fdt) * - AO_SEC_GP_CFG4: bl32 physical start address, can be NULL */
- reg = readl(GXBB_AO_SEC_GP_CFG3); + reg = readl(GX_AO_SEC_GP_CFG3);
- bl31_size = ((reg & GXBB_AO_BL31_RSVMEM_SIZE_MASK) - >> GXBB_AO_BL31_RSVMEM_SIZE_SHIFT) * SZ_1K; - bl32_size = (reg & GXBB_AO_BL32_RSVMEM_SIZE_MASK) * SZ_1K; + bl31_size = ((reg & GX_AO_BL31_RSVMEM_SIZE_MASK) + >> GX_AO_BL31_RSVMEM_SIZE_SHIFT) * SZ_1K; + bl32_size = (reg & GX_AO_BL32_RSVMEM_SIZE_MASK) * SZ_1K;
- bl31_start = readl(GXBB_AO_SEC_GP_CFG5); - bl32_start = readl(GXBB_AO_SEC_GP_CFG4); + bl31_start = readl(GX_AO_SEC_GP_CFG5); + bl32_start = readl(GX_AO_SEC_GP_CFG4);
/* - * Early Meson GXBB Firmware revisions did not provide the reserved + * Early Meson GX Firmware revisions did not provide the reserved * memory zones in the registers, keep fixed memory zone handling. */ - if (IS_ENABLED(CONFIG_MESON_GXBB) && + if (IS_ENABLED(CONFIG_MESON_GX) && !reg && !bl31_start && !bl32_start) { bl31_start = 0x10000000; bl31_size = 0x200000; }
/* Add first 16MiB reserved zone */ - meson_board_add_reserved_memory(fdt, 0, GXBB_FIRMWARE_MEM_SIZE); + meson_board_add_reserved_memory(fdt, 0, GX_FIRMWARE_MEM_SIZE);
/* Add BL31 reserved zone */ if (bl31_start && bl31_size) @@ -108,7 +108,7 @@ void reset_cpu(ulong addr) psci_system_reset(); }
-static struct mm_region gxbb_mem_map[] = { +static struct mm_region gx_mem_map[] = { { .virt = 0x0UL, .phys = 0x0UL, @@ -128,4 +128,4 @@ static struct mm_region gxbb_mem_map[] = { } };
-struct mm_region *mem_map = gxbb_mem_map; +struct mm_region *mem_map = gx_mem_map; diff --git a/arch/arm/mach-meson/eth.c b/arch/arm/mach-meson/eth.c index 8c6577b..8050bfa 100644 --- a/arch/arm/mach-meson/eth.c +++ b/arch/arm/mach-meson/eth.c @@ -8,7 +8,7 @@ #include <common.h> #include <dm.h> #include <asm/io.h> -#include <asm/arch/gxbb.h> +#include <asm/arch/gx.h> #include <asm/arch/eth.h> #include <phy.h>
@@ -23,23 +23,23 @@ void meson_gx_eth_init(phy_interface_t mode, unsigned int flags) case PHY_INTERFACE_MODE_RGMII_RXID: case PHY_INTERFACE_MODE_RGMII_TXID: /* Set RGMII mode */ - setbits_le32(GXBB_ETH_REG_0, GXBB_ETH_REG_0_PHY_INTF | - GXBB_ETH_REG_0_TX_PHASE(1) | - GXBB_ETH_REG_0_TX_RATIO(4) | - GXBB_ETH_REG_0_PHY_CLK_EN | - GXBB_ETH_REG_0_CLK_EN); + setbits_le32(GX_ETH_REG_0, GX_ETH_REG_0_PHY_INTF | + GX_ETH_REG_0_TX_PHASE(1) | + GX_ETH_REG_0_TX_RATIO(4) | + GX_ETH_REG_0_PHY_CLK_EN | + GX_ETH_REG_0_CLK_EN); break;
case PHY_INTERFACE_MODE_RMII: /* Set RMII mode */ - out_le32(GXBB_ETH_REG_0, GXBB_ETH_REG_0_INVERT_RMII_CLK | - GXBB_ETH_REG_0_CLK_EN); + out_le32(GX_ETH_REG_0, GX_ETH_REG_0_INVERT_RMII_CLK | + GX_ETH_REG_0_CLK_EN);
/* Use GXL RMII Internal PHY */ if (IS_ENABLED(CONFIG_MESON_GXL) && (flags & MESON_GXL_USE_INTERNAL_RMII_PHY)) { - writel(0x10110181, GXBB_ETH_REG_2); - writel(0xe40908ff, GXBB_ETH_REG_3); + writel(0x10110181, GX_ETH_REG_2); + writel(0xe40908ff, GX_ETH_REG_3); }
break; @@ -50,6 +50,6 @@ void meson_gx_eth_init(phy_interface_t mode, unsigned int flags) }
/* Enable power and clock gate */ - setbits_le32(GXBB_GCLK_MPEG_1, GXBB_GCLK_MPEG_1_ETH); - clrbits_le32(GXBB_MEM_PD_REG_0, GXBB_MEM_PD_REG_0_ETH_MASK); + setbits_le32(GX_GCLK_MPEG_1, GX_GCLK_MPEG_1_ETH); + clrbits_le32(GX_MEM_PD_REG_0, GX_MEM_PD_REG_0_ETH_MASK); } diff --git a/arch/arm/mach-meson/sm.c b/arch/arm/mach-meson/sm.c index 1b35a22..b374031 100644 --- a/arch/arm/mach-meson/sm.c +++ b/arch/arm/mach-meson/sm.c @@ -7,7 +7,7 @@ */
#include <common.h> -#include <asm/arch/gxbb.h> +#include <asm/arch/gx.h> #include <linux/kernel.h>
#define FN_GET_SHARE_MEM_INPUT_BASE 0x82000020 diff --git a/board/amlogic/khadas-vim/khadas-vim.c b/board/amlogic/khadas-vim/khadas-vim.c index 83b1b6e..c23ddab 100644 --- a/board/amlogic/khadas-vim/khadas-vim.c +++ b/board/amlogic/khadas-vim/khadas-vim.c @@ -9,7 +9,7 @@ #include <dm.h> #include <environment.h> #include <asm/io.h> -#include <asm/arch/gxbb.h> +#include <asm/arch/gx.h> #include <asm/arch/mem.h> #include <asm/arch/sm.h> #include <asm/arch/eth.h> diff --git a/board/amlogic/libretech-cc/libretech-cc.c b/board/amlogic/libretech-cc/libretech-cc.c index 5795340..36fda46 100644 --- a/board/amlogic/libretech-cc/libretech-cc.c +++ b/board/amlogic/libretech-cc/libretech-cc.c @@ -9,7 +9,7 @@ #include <dm.h> #include <environment.h> #include <asm/io.h> -#include <asm/arch/gxbb.h> +#include <asm/arch/gx.h> #include <asm/arch/sm.h> #include <asm/arch/eth.h> #include <asm/arch/mem.h> @@ -34,8 +34,8 @@ int misc_init_r(void) MESON_GXL_USE_INTERNAL_RMII_PHY);
if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, diff --git a/board/amlogic/odroid-c2/odroid-c2.c b/board/amlogic/odroid-c2/odroid-c2.c index 8645f22..0ec0771 100644 --- a/board/amlogic/odroid-c2/odroid-c2.c +++ b/board/amlogic/odroid-c2/odroid-c2.c @@ -8,7 +8,7 @@ #include <dm.h> #include <environment.h> #include <asm/io.h> -#include <asm/arch/gxbb.h> +#include <asm/arch/gx.h> #include <asm/arch/sm.h> #include <asm/arch/eth.h> #include <asm/arch/mem.h> @@ -32,13 +32,13 @@ int misc_init_r(void) meson_gx_eth_init(PHY_INTERFACE_MODE_RGMII, 0);
/* Enable power and clock gate */ - setbits_le32(GXBB_GCLK_MPEG_0, GXBB_GCLK_MPEG_0_I2C); + setbits_le32(GX_GCLK_MPEG_0, GX_GCLK_MPEG_0_I2C);
/* Reset PHY on GPIOZ_14 */ - clrbits_le32(GXBB_GPIO_EN(3), BIT(14)); - clrbits_le32(GXBB_GPIO_OUT(3), BIT(14)); + clrbits_le32(GX_GPIO_EN(3), BIT(14)); + clrbits_le32(GX_GPIO_OUT(3), BIT(14)); mdelay(10); - setbits_le32(GXBB_GPIO_OUT(3), BIT(14)); + setbits_le32(GX_GPIO_OUT(3), BIT(14));
if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, diff --git a/board/amlogic/p212/p212.c b/board/amlogic/p212/p212.c index 7c0abbc..10f6b23 100644 --- a/board/amlogic/p212/p212.c +++ b/board/amlogic/p212/p212.c @@ -9,7 +9,7 @@ #include <dm.h> #include <environment.h> #include <asm/io.h> -#include <asm/arch/gxbb.h> +#include <asm/arch/gx.h> #include <asm/arch/sm.h> #include <asm/arch/eth.h> #include <asm/arch/mem.h> diff --git a/include/configs/khadas-vim.h b/include/configs/khadas-vim.h index f44b388..8f14208 100644 --- a/include/configs/khadas-vim.h +++ b/include/configs/khadas-vim.h @@ -14,6 +14,6 @@
#define MESON_FDTFILE_SETTING "fdtfile=amlogic/meson-gxl-s905x-khadas-vim.dtb\0"
-#include <configs/meson-gxbb-common.h> +#include <configs/meson-gx-common.h>
#endif /* __CONFIG_H */ diff --git a/include/configs/libretech-cc.h b/include/configs/libretech-cc.h index 08dfb30..897a697 100644 --- a/include/configs/libretech-cc.h +++ b/include/configs/libretech-cc.h @@ -14,6 +14,6 @@
#define MESON_FDTFILE_SETTING "fdtfile=amlogic/meson-gxl-s905x-libretech-cc.dtb\0"
#endif /* __CONFIG_H */ diff --git a/include/configs/meson-gx-common.h b/include/configs/meson-gx-common.h new file mode 100644 index 0000000..1131643 --- /dev/null +++ b/include/configs/meson-gx-common.h @@ -0,0 +1,47 @@ +/* + * Configuration for Amlogic Meson GX SoCs + * (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __MESON_GX_COMMON_CONFIG_H +#define __MESON_GX_COMMON_CONFIG_H + +#define CONFIG_CPU_ARMV8 +#define CONFIG_REMAKE_ELF +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MAXARGS 32 +#define CONFIG_SYS_MALLOC_LEN (32 << 20) +#define CONFIG_SYS_CBSIZE 1024 + +#define CONFIG_SYS_SDRAM_BASE 0 +#define CONFIG_SYS_INIT_SP_ADDR 0x20000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE + +/* Generic Interrupt Controller Definitions */ +#define GICD_BASE 0xc4301000 +#define GICC_BASE 0xc4302000 + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) \ + func(MMC, mmc, 2) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_addr_r=0x01000000\0" \ + "scriptaddr=0x1f000000\0" \ + "kernel_addr_r=0x01080000\0" \ + "pxefile_addr_r=0x01080000\0" \ + "ramdisk_addr_r=0x13000000\0" \ + MESON_FDTFILE_SETTING \ + BOOTENV + +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64 MiB */ + +#endif /* __MESON_GX_COMMON_CONFIG_H */ diff --git a/include/configs/meson-gxbb-common.h b/include/configs/meson-gxbb-common.h deleted file mode 100644 index 5794bc0..0000000 --- a/include/configs/meson-gxbb-common.h +++ /dev/null @@ -1,47 +0,0 @@ -/* - * Configuration for Amlogic Meson GXBB SoCs - * (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __MESON_GXBB_COMMON_CONFIG_H -#define __MESON_GXBB_COMMON_CONFIG_H - -#define CONFIG_CPU_ARMV8 -#define CONFIG_REMAKE_ELF -#define CONFIG_NR_DRAM_BANKS 1 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_SYS_MAXARGS 32 -#define CONFIG_SYS_MALLOC_LEN (32 << 20) -#define CONFIG_SYS_CBSIZE 1024 - -#define CONFIG_SYS_SDRAM_BASE 0 -#define CONFIG_SYS_INIT_SP_ADDR 0x20000000 -#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE - -/* Generic Interrupt Controller Definitions */ -#define GICD_BASE 0xc4301000 -#define GICC_BASE 0xc4302000 - -#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(MMC, mmc, 1) \ - func(MMC, mmc, 2) \ - func(PXE, pxe, na) \ - func(DHCP, dhcp, na) - -#include <config_distro_bootcmd.h> - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "fdt_addr_r=0x01000000\0" \ - "scriptaddr=0x1f000000\0" \ - "kernel_addr_r=0x01080000\0" \ - "pxefile_addr_r=0x01080000\0" \ - "ramdisk_addr_r=0x13000000\0" \ - MESON_FDTFILE_SETTING \ - BOOTENV - -#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64 MiB */ - -#endif /* __MESON_GXBB_COMMON_CONFIG_H */ diff --git a/include/configs/odroid-c2.h b/include/configs/odroid-c2.h index ff30a8a..d9914af 100644 --- a/include/configs/odroid-c2.h +++ b/include/configs/odroid-c2.h @@ -14,6 +14,6 @@
#define MESON_FDTFILE_SETTING "fdtfile=amlogic/meson-gxbb-odroidc2.dtb\0"
#endif /* __CONFIG_H */ diff --git a/include/configs/p212.h b/include/configs/p212.h index a087d86..a950da3 100644 --- a/include/configs/p212.h +++ b/include/configs/p212.h @@ -16,6 +16,6 @@
#define MESON_FDTFILE_SETTING "fdtfile=amlogic/meson-gxl-s905x-p212.dtb\0"
Neil Armstrong
