[U-Boot-Users] [PATCH] net: uec_phy: handle 88e1111 rev.B2 erratum 5.6
erratum 5.6 states the autoneg completion bit is functional only if the autoneg bit is asserted.
This fixes any secondarily-issued networking commands on non-gigabit links on the mpc8360 mds board.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- gvb, please test, and give us your blessings if this fixes your second ping failing issue.
To go through biggerbadderben, for 1.3.2.
drivers/qe/uec_phy.c | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/drivers/qe/uec_phy.c b/drivers/qe/uec_phy.c index c549b6b..cf9921b 100644 --- a/drivers/qe/uec_phy.c +++ b/drivers/qe/uec_phy.c @@ -574,6 +574,7 @@ void marvell_phy_interface_mode (struct eth_device *dev, { uec_private_t *uec = (uec_private_t *) dev->priv; struct uec_mii_info *mii_info; + u16 status;
if (!uec->mii_info) { printf ("%s: the PHY not intialized\n", __FUNCTION__); @@ -609,6 +610,13 @@ void marvell_phy_interface_mode (struct eth_device *dev, phy_write (mii_info, 0x00, 0x8100); udelay (1000000); } + + /* handle 88e1111 rev.B2 erratum 5.6 */ + if (mii_info->autoneg) { + status = phy_read (mii_info, PHY_BMCR); + phy_write (mii_info, PHY_BMCR, status | PHY_BMCR_AUTON); + } + /* now the B2 will correctly report autoneg completion status */ }
void change_phy_interface_mode (struct eth_device *dev, enet_interface_e mode)
YES! That fixed the problem for real.
Ben (Wolfgang), please apply to 1.3.2rc2, this fixes a very real problem.
Acked-by: Gerald Van Baren vanbaren@cideas.com
Thanks, Kim! gvb
Wolfgang,
Please pull directly into 1.3.2 if possible
thanks, Ben
Acked-by: Ben Warren biggerbadderben@gmail.com
On Wed, Feb 27, 2008 at 4:06 PM, Kim Phillips kim.phillips@freescale.com wrote:
u16 status; if (!uec->mii_info) { printf ("%s: the PHY not intialized\n", __FUNCTION__);
1.5.4.23.gef5b9
In message f8328f7c0802271646v1d3b289j265f1360bc400bbe@mail.gmail.com you wrote:
Wolfgang,
Sure, done.
Applied, thanks.
Ben Warren
Jerry Van Baren
Kim Phillips
