[GIT PULL] Please pull u-boot-imx-master-20240304
Hi Tom,
Please pull from u-boot-imx, thanks.
The following changes since commit eac52e4be4e234d563d6911737ee7ccdc0ada1f1:
Merge patch series "ARM: renesas: Rename R-Mobile to Renesas" (2024-03-02 14:30:25 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20240304
for you to fetch changes up to 9b9f022e7368cacafa368beaa7fadd931f2cfcdb:
video: mxsfb: add back imx6ul/imx6ull support (2024-03-04 08:18:48 -0300)
u-boot-imx-master-20240304 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/19817
- Fix i.MX93 OP-TEE support. - Use the container image for i.MX93 revision A1. - Fix display regression on opos6uldev. ---------------------------------------------------------------- Mathieu Othacehe (3): imx9: Fix OP-TEE support tools: imx9_image: Reword warning message. imx9: Update to mx93 A1 chip revision.
Sébastien Szymanski (2): opos6uldev: make the LCD work again video: mxsfb: add back imx6ul/imx6ull support
arch/arm/dts/imx6ul-opos6uldev-u-boot.dtsi | 28 ++++++++++++++++++++++------ arch/arm/mach-imx/imx9/container.cfg | 3 ++- arch/arm/mach-imx/imx9/imximage.cfg | 2 +- board/armadeus/opos6uldev/opos6uldev.env | 1 - board/freescale/imx93_evk/spl.c | 7 +++++++ board/phytec/phycore_imx93/spl.c | 7 +++++++ board/variscite/imx93_var_som/spl.c | 6 ++++++ configs/opos6uldev_defconfig | 3 --- doc/board/nxp/imx93_11x11_evk.rst | 8 ++++---- doc/board/phytec/imx93-phyboard-segin.rst | 8 ++++---- doc/board/variscite/imx93_var_som.rst | 8 ++++---- drivers/video/mxsfb.c | 1 + tools/imx9_image.sh | 2 +- 13 files changed, 59 insertions(+), 25 deletions(-)
On Mon, Mar 04, 2024 at 02:52:51PM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
