[U-Boot] [PATCH v2] MAKEALL ARM: Use boards.cfg
Use the boards from boards.cfg for building ./MAKEALL ARMx.
Note: ARM10 systems don't seem to exist any more.
Signed-off-by: Dirk Behme dirk.behme@googlemail.com
--- Changes in v2: Instead of dublicating the missing boards from boards.cfg to MAKEALL, use the boards defined in boards.cfg directly.
MAKEALL | 134 ++++------------------------------------------------------------ 1 file changed, 9 insertions(+), 125 deletions(-)
Index: u-boot.git/MAKEALL =================================================================== --- u-boot.git.orig/MAKEALL +++ u-boot.git/MAKEALL @@ -300,144 +300,28 @@ LIST_SA="$(boards_by_cpu sa1100)" ## ARM7 Systems #########################################################################
-LIST_ARM7=" \ - ap7 \ - ap720t \ - armadillo \ - B2 \ - ep7312 \ - evb4510 \ - impa7 \ - integratorap \ - lpc2292sodimm \ - modnet50 \ - SMN42 \ -" +LIST_ARM7="$(boards_by_cpu arm720t)"
######################################################################### ## ARM9 Systems #########################################################################
-LIST_ARM9=" \ - a320evb \ - ap920t \ - ap922_XA10 \ - ap926ejs \ - ap946es \ - ap966 \ - aspenite \ - cp920t \ - cp922_XA10 \ - cp926ejs \ - cp946es \ - cp966 \ - da830evm \ - da850evm \ - edb9301 \ - edb9302 \ - edb9302a \ - edb9307 \ - edb9307a \ - edb9312 \ - edb9315 \ - edb9315a \ - edminiv2 \ - guruplug \ - imx27lite \ - jadecpu \ - km_kirkwood \ - lpd7a400 \ - magnesium \ - mv88f6281gtw_ge \ - mx1ads \ - mx1fs2 \ - netstar \ - nhk8815 \ - nhk8815_onenand \ - omap1510inn \ - omap1610h2 \ - omap1610inn \ - omap5912osk \ - omap730p2 \ - openrd_base \ - openrd_client \ - openrd_ultimate \ - portl2 \ - rd6281a \ - sbc2410x \ - scb9328 \ - sheevaplug \ - smdk2400 \ - smdk2410 \ - spear300 \ - spear310 \ - spear320 \ - spear600 \ - VCMA9 \ - versatile \ - versatileab \ - versatilepb \ - voiceblue \ - davinci_dvevm \ - davinci_schmoogie \ - davinci_sffsdr \ - davinci_sonata \ - davinci_dm355evm \ - davinci_dm355leopard \ - davinci_dm365evm \ - davinci_dm6467evm \ -" - -######################################################################### -## ARM10 Systems -######################################################################### -LIST_ARM10=" \ - integratorcp \ - cp1026 \ -" +LIST_ARM9="$(boards_by_cpu arm920t) + $(boards_by_cpu arm925t) + $(boards_by_cpu arm926ejs)"
######################################################################### ## ARM11 Systems ######################################################################### -LIST_ARM11=" \ - cp1136 \ - omap2420h4 \ - apollon \ - imx31_litekit \ - imx31_phycore \ - imx31_phycore_eet \ - mx31ads \ - mx31pdk \ - mx31pdk_nand \ - qong \ - smdk6400 \ - tnetv107x_evm \ -" + +LIST_ARM11="$(boards_by_cpu arm1136) + $(boards_by_cpu arm1176)"
######################################################################### ## ARMV7 Systems ######################################################################### -LIST_ARMV7=" \ - am3517_crane \ - am3517_evm \ - ca9x4_ct_vxp \ - devkit8000 \ - dig297 \ - igep0020 \ - igep0030 \ - mx51evk \ - omap3_beagle \ - omap3_overo \ - omap3_evm \ - omap3_pandora \ - omap3_sdp3430 \ - omap3_zoom1 \ - omap3_zoom2 \ - omap4_panda \ - omap4_sdp4430 \ - s5p_goni \ - smdkc100 \ -" + +LIST_ARMV7="$(boards_by_cpu armv7)"
######################################################################### ## AT91 Systems
Dear Dirk Behme,
Wrong: a simple grep shows that those are still in Makefile.
This sentence does not make sense to me... How can something that is missing be duplicated? I think you were wanting to say: "remove all boards that are in boards.cfg from MAKEALL"
Are all those boards removed here in boards.cfg? Answer: NO Are none of them still in Makefile? Answer: NO
Remember: 1. boards must either be in Makefile OR boards.cfg 2. boards that are still in Makefile MUST BE in MAKEALL 3. boards that are in boards.cfg SHOULD NOT be in MAKEALL
Of the boards removed from MAKEALL by your patch, I found several in Makefile but not in boards.cfg.
By removing them from MAKEALL they will not be built any more in MAKEALL runs and this would hide their possible brokenness!
Best Regards, Reinhard
Dirk Behme
Reinhard Meyer
