[U-Boot] [PATCH] imx: spl: Fix NAND bootmode detection
commit 20f14714169 ("imx: spl: Update NAND bootmode detection bit") broke the NAND bootmode detection by checking if BOOT_CFG1[7:4] == 0x8 for NAND boot mode. This commit essentially reverts it, while using the IMX6_BMODE_* macros that were introduced since.
Tables 8-7 & 8-10 from IMX6DQRM say the NAND boot mode selection is done when BOOT_CFG1[7] is 1, but BOOT_CFG1[6:4] is not necessarily 0x0 in this case. Actually, NAND boot mode is when 0x8 <= BOOT_CFG1[7:4] <= 0xf, like it was in the code before.
Signed-off-by: Eran Matityahu eran.m@variscite.com Cc: Stefano Babic sbabic@denx.de Cc: Jagan Teki jagan@openedev.com Cc: Tim Harvey tharvey@gateworks.com --- arch/arm/include/asm/mach-imx/sys_proto.h | 3 ++- arch/arm/mach-imx/spl.c | 2 +- board/engicam/common/board.c | 2 +- 3 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/sys_proto.h b/arch/arm/include/asm/mach-imx/sys_proto.h index a80a392..9bdb40f 100644 --- a/arch/arm/include/asm/mach-imx/sys_proto.h +++ b/arch/arm/include/asm/mach-imx/sys_proto.h @@ -81,7 +81,8 @@ enum imx6_bmode { IMX6_BMODE_ESD, IMX6_BMODE_MMC, IMX6_BMODE_EMMC, - IMX6_BMODE_NAND, + IMX6_BMODE_NAND_MIN, + IMX6_BMODE_NAND_MAX = 0xf, };
static inline u8 imx6_is_bmode_from_gpr9(void) diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index d0d1b73..723f51f 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -91,7 +91,7 @@ u32 spl_boot_device(void) case IMX6_BMODE_EMMC: return BOOT_DEVICE_MMC1; /* NAND Flash: 8.5.2, Table 8-10 */ - case IMX6_BMODE_NAND: + case IMX6_BMODE_NAND_MIN ... IMX6_BMODE_NAND_MAX: return BOOT_DEVICE_NAND; } return BOOT_DEVICE_NONE; diff --git a/board/engicam/common/board.c b/board/engicam/common/board.c index f633c71..1bdd833 100644 --- a/board/engicam/common/board.c +++ b/board/engicam/common/board.c @@ -69,7 +69,7 @@ int board_late_init(void) #endif env_set("modeboot", "mmcboot"); break; - case IMX6_BMODE_NAND: + case IMX6_BMODE_NAND_MIN ... IMX6_BMODE_NAND_MAX: env_set("modeboot", "nandboot"); break; default:
Eran Matityahu
