[U-Boot] [PATCH] ppc: Fix warning in TSEC Ethernet driver
Fixes: tsec.c: In function 'tsec_initialize': tsec.c:638:12: warning: assignment from incompatible pointer type
Tested on MPC8313e-RDB
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- drivers/net/tsec.c | 5 ++--- 1 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 160bc05..3c1c8f0 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -44,8 +44,7 @@ static RTXBD rtx __attribute__ ((aligned(8))); #error "rtx must be 64-bit aligned" #endif
-static int tsec_send(struct eth_device *dev, - volatile void *packet, int length); +static int tsec_send(struct eth_device *dev, void *packet, int length);
/* Default initializations for TSEC controllers. */
@@ -377,7 +376,7 @@ static void startup_tsec(struct eth_device *dev) * do the same. Presumably, this would be zero if there were no * errors */ -static int tsec_send(struct eth_device *dev, volatile void *packet, int length) +static int tsec_send(struct eth_device *dev, void *packet, int length) { int i; int result = 0;
On Mon, May 21, 2012 at 2:46 PM, Joe Hershberger joe.hershberger@ni.com wrote:
Applied.
Joe Hershberger
Joe Hershberger
