[U-Boot] [PATCH 04/19] 4xx_pcie.c: Fix GCC 4.6 build warnings
Fix: 4xx_pcie.c: In function 'pcie_read_config': 4xx_pcie.c:230:6: warning: variable 'address' set but not used [-Wunused-but-set-variable] 4xx_pcie.c: In function 'pcie_write_config': 4xx_pcie.c:290:6: warning: variable 'address' set but not used [-Wunused-but-set-variable] 4xx_pcie.c: In function 'ppc4xx_setup_pcie_rootpoint': 4xx_pcie.c:1066:17: warning: variable 'rmbase' set but not used [-Wunused-but-set-variable]
Signed-off-by: Stefan Roese sr@denx.de --- arch/powerpc/cpu/ppc4xx/4xx_pcie.c | 11 ++--------- 1 files changed, 2 insertions(+), 9 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/4xx_pcie.c b/arch/powerpc/cpu/ppc4xx/4xx_pcie.c index a87e93b..43b972f 100644 --- a/arch/powerpc/cpu/ppc4xx/4xx_pcie.c +++ b/arch/powerpc/cpu/ppc4xx/4xx_pcie.c @@ -227,7 +227,6 @@ static void pcie_dmer_enable(void) static int pcie_read_config(struct pci_controller *hose, unsigned int devfn, int offset, int len, u32 *val) {
- u8 *address; *val = 0;
if (validate_endpoint(hose)) @@ -255,7 +254,7 @@ static int pcie_read_config(struct pci_controller *hose, unsigned int devfn, ((PCI_BUS(devfn) == 0) || (PCI_BUS(devfn) == 1))) return 0;
- address = pcie_get_base(hose, devfn); + pcie_get_base(hose, devfn); offset += devfn << 4;
/* @@ -287,8 +286,6 @@ static int pcie_read_config(struct pci_controller *hose, unsigned int devfn, static int pcie_write_config(struct pci_controller *hose, unsigned int devfn, int offset, int len, u32 val) {
- u8 *address; - if (validate_endpoint(hose)) return 0; /* No upstream config access */
@@ -307,7 +304,7 @@ static int pcie_write_config(struct pci_controller *hose, unsigned int devfn, ((PCI_BUS(devfn) == 0) || (PCI_BUS(devfn) == 1))) return 0;
/* @@ -1063,7 +1060,6 @@ int ppc4xx_init_pcie_endport(int port) void ppc4xx_setup_pcie_rootpoint(struct pci_controller *hose, int port) { volatile void *mbase = NULL; - volatile void *rmbase = NULL;
pci_set_ops(hose, pcie_read_config_byte, @@ -1076,18 +1072,15 @@ void ppc4xx_setup_pcie_rootpoint(struct pci_controller *hose, int port) switch (port) { case 0: mbase = (u32 *)CONFIG_SYS_PCIE0_XCFGBASE; - rmbase = (u32 *)CONFIG_SYS_PCIE0_CFGBASE; hose->cfg_data = (u8 *)CONFIG_SYS_PCIE0_CFGBASE; break; case 1: mbase = (u32 *)CONFIG_SYS_PCIE1_XCFGBASE; - rmbase = (u32 *)CONFIG_SYS_PCIE1_CFGBASE; hose->cfg_data = (u8 *)CONFIG_SYS_PCIE1_CFGBASE; break; #if CONFIG_SYS_PCIE_NR_PORTS > 2 case 2: mbase = (u32 *)CONFIG_SYS_PCIE2_XCFGBASE; - rmbase = (u32 *)CONFIG_SYS_PCIE2_CFGBASE; hose->cfg_data = (u8 *)CONFIG_SYS_PCIE2_CFGBASE; break; #endif
Dear Stefan Roese,
Applied, thanks.
Stefan Roese
