[U-Boot] [PATCH] [PATCH v3] mx6qsabrelite: Remove mx6qsabrelite code in favor of nitrogen6x
mx6qsabrelite and nitrogen6q boards are hardware compatible, so let's avoid the code duplication and only use the nitrogen6x source code to make board code maintainance easier.
Tested booting a mainline device tree kernel on a mx6qsabrelite board.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v2: - Rebased against u-boot-imx Changes since v1: - Update MAINTAINERS file
MAINTAINERS | 2 +- board/boundary/nitrogen6x/README.mx6qsabrelite | 72 +++ board/freescale/mx6qsabrelite/Makefile | 41 -- board/freescale/mx6qsabrelite/README | 72 --- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 848 ------------------------- boards.cfg | 2 +- include/configs/mx6qsabrelite.h | 297 --------- include/configs/nitrogen6x.h | 80 ++- 8 files changed, 153 insertions(+), 1261 deletions(-) create mode 100644 board/boundary/nitrogen6x/README.mx6qsabrelite delete mode 100644 board/freescale/mx6qsabrelite/Makefile delete mode 100644 board/freescale/mx6qsabrelite/README delete mode 100644 board/freescale/mx6qsabrelite/mx6qsabrelite.c delete mode 100644 include/configs/mx6qsabrelite.h
diff --git a/MAINTAINERS b/MAINTAINERS index 081cf96..0a900dc 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -601,7 +601,6 @@ Jason Liu r64343@freescale.com mx53evk i.MX53 mx53loco i.MX53 mx6qarm2 i.MX6Q - mx6qsabrelite i.MX6Q
Enric Balletbo i Serra eballetbo@iseebcn.com
@@ -1067,6 +1066,7 @@ Pali Rohár pali.rohar@gmail.com nokia_rx51 ARM ARMV7 (OMAP34xx SoC)
Eric Nelson eric.nelson@boundarydevices.com + mx6qsabrelite i.MX6Q 1GB nitrogen6dl i.MX6DL 1GB nitrogen6dl2g i.MX6DL 2GB nitrogen6q i.MX6Q/6D 1GB diff --git a/board/boundary/nitrogen6x/README.mx6qsabrelite b/board/boundary/nitrogen6x/README.mx6qsabrelite new file mode 100644 index 0000000..12a9c85 --- /dev/null +++ b/board/boundary/nitrogen6x/README.mx6qsabrelite @@ -0,0 +1,72 @@ +U-Boot for the Freescale i.MX6q SabreLite board + +This file contains information for the port of U-Boot to the Freescale +i.MX6q SabreLite board. + +1. Boot source, boot from SD card +--------------------------------- + +The recent mainline U-Boot for the Freescale i.MX6q SabreLite board supports +boot from SD card only. However, by default, the SabreLite +boards boot from the SPI NOR flash. These boards need to be reflashed with +a small SD card loader to support boot from SD card. This small SD card loader +will be flashed into the SPI NOR. The board will still boot from SPI NOR, but +the loader will in turn request the BootROM to load the U-Boot from SD card. + +The SD card loader is available from + +https://wiki.linaro.org/Boards/MX6QSabreLite + +under a open-source 3-clause BSD license. + +To update the SPI-NOR on the SabreLite board without the Freescale +manufacturing tool use the following procedure: + +1. Write this SD card loader onto a large SD card using: + + sudo dd if=iMX6DQ_SPI_to_uSDHC3.bin of=/dev/sXx + +Note: Replace sXx with the device representing the SD card in your system. + +Note: This writes SD card loader at address 0 + +2. Put this SD card into the slot for the large SD card (SD3 on the bottom of +the board). Make sure SW1 switch is at position "00", so that it can boot +from the fuses. + +3. Power-up the SabreLite, press 'space' to enter command mode in the U-Boot +(the default one the board is shipped with, starting from the SPI NOR) and +enter the following commands: + + MX6Q SABRELITE U-Boot > mmc dev 0 + MX6Q SABRELITE U-Boot > mmc read 0x10800000 0 200 + MX6Q SABRELITE U-Boot > sf probe + MX6Q SABRELITE U-Boot > sf erase 0 0x40000 + MX6Q SABRELITE U-Boot > sf write 0x10800000 0 0x40000 + +4. done. + +In case you somehow do not succeed with this procedure you will have to use +the Freescale manufacturing tool in order to reflash the SPI-NOR. + +Note: The board now boots from full size SD3 on the bottom of the board. NOT + the micro SD4/BOOT slot on the top of the board. I.e. you have to use + full size SD cards. + +This information is taken from + +https://wiki.linaro.org/Boards/MX6QSabreLite + +2. Build +-------- + +To build U-Boot for the SabreLite board: + + make mx6qsabrelite_config + make + +To copy the resulting u-boot.imx to the SD card: + + sudo dd if=u-boot.imx of=/dev/sXx bs=512 seek=2&&sudo sync + +Note: Replace sXx with the device representing the SD card in your system. diff --git a/board/freescale/mx6qsabrelite/Makefile b/board/freescale/mx6qsabrelite/Makefile deleted file mode 100644 index cf344e4..0000000 --- a/board/freescale/mx6qsabrelite/Makefile +++ /dev/null @@ -1,41 +0,0 @@ -# -# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de -# -# (C) Copyright 2011 Freescale Semiconductor, Inc. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx6qsabrelite.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/freescale/mx6qsabrelite/README b/board/freescale/mx6qsabrelite/README deleted file mode 100644 index 12a9c85..0000000 --- a/board/freescale/mx6qsabrelite/README +++ /dev/null @@ -1,72 +0,0 @@ -U-Boot for the Freescale i.MX6q SabreLite board - -This file contains information for the port of U-Boot to the Freescale -i.MX6q SabreLite board. - -1. Boot source, boot from SD card ---------------------------------- - -The recent mainline U-Boot for the Freescale i.MX6q SabreLite board supports -boot from SD card only. However, by default, the SabreLite -boards boot from the SPI NOR flash. These boards need to be reflashed with -a small SD card loader to support boot from SD card. This small SD card loader -will be flashed into the SPI NOR. The board will still boot from SPI NOR, but -the loader will in turn request the BootROM to load the U-Boot from SD card. - -The SD card loader is available from - -https://wiki.linaro.org/Boards/MX6QSabreLite - -under a open-source 3-clause BSD license. - -To update the SPI-NOR on the SabreLite board without the Freescale -manufacturing tool use the following procedure: - -1. Write this SD card loader onto a large SD card using: - - sudo dd if=iMX6DQ_SPI_to_uSDHC3.bin of=/dev/sXx - -Note: Replace sXx with the device representing the SD card in your system. - -Note: This writes SD card loader at address 0 - -2. Put this SD card into the slot for the large SD card (SD3 on the bottom of -the board). Make sure SW1 switch is at position "00", so that it can boot -from the fuses. - -3. Power-up the SabreLite, press 'space' to enter command mode in the U-Boot -(the default one the board is shipped with, starting from the SPI NOR) and -enter the following commands: - - MX6Q SABRELITE U-Boot > mmc dev 0 - MX6Q SABRELITE U-Boot > mmc read 0x10800000 0 200 - MX6Q SABRELITE U-Boot > sf probe - MX6Q SABRELITE U-Boot > sf erase 0 0x40000 - MX6Q SABRELITE U-Boot > sf write 0x10800000 0 0x40000 - -4. done. - -In case you somehow do not succeed with this procedure you will have to use -the Freescale manufacturing tool in order to reflash the SPI-NOR. - -Note: The board now boots from full size SD3 on the bottom of the board. NOT - the micro SD4/BOOT slot on the top of the board. I.e. you have to use - full size SD cards. - -This information is taken from - -https://wiki.linaro.org/Boards/MX6QSabreLite - -2. Build --------- - -To build U-Boot for the SabreLite board: - - make mx6qsabrelite_config - make - -To copy the resulting u-boot.imx to the SD card: - - sudo dd if=u-boot.imx of=/dev/sXx bs=512 seek=2&&sudo sync - -Note: Replace sXx with the device representing the SD card in your system. diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c deleted file mode 100644 index 862bc30..0000000 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ /dev/null @@ -1,848 +0,0 @@ -/* - * Copyright (C) 2010-2011 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/imx-regs.h> -#include <asm/arch/iomux.h> -#include <asm/arch/mx6q_pins.h> -#include <asm/errno.h> -#include <asm/gpio.h> -#include <asm/imx-common/iomux-v3.h> -#include <asm/imx-common/mxc_i2c.h> -#include <asm/imx-common/boot_mode.h> -#include <mmc.h> -#include <fsl_esdhc.h> -#include <malloc.h> -#include <micrel.h> -#include <miiphy.h> -#include <netdev.h> -#include <linux/fb.h> -#include <ipu_pixfmt.h> -#include <asm/arch/crm_regs.h> -#include <asm/arch/mxc_hdmi.h> -#include <i2c.h> - -DECLARE_GLOBAL_DATA_PTR; - -#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ - PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ - PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ - PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - -#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) - -#define BUTTON_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - -#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE | PAD_CTL_SRE_FAST) - -int dram_init(void) -{ - gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); - - return 0; -} - -iomux_v3_cfg_t const uart1_pads[] = { - MX6_PAD_SD3_DAT6__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_SD3_DAT7__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - -iomux_v3_cfg_t const uart2_pads[] = { - MX6_PAD_EIM_D26__UART2_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_EIM_D27__UART2_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - -#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) - -/* I2C1, SGTL5000 */ -struct i2c_pads_info i2c_pad_info0 = { - .scl = { - .i2c_mode = MX6_PAD_EIM_D21__I2C1_SCL | PC, - .gpio_mode = MX6_PAD_EIM_D21__GPIO_3_21 | PC, - .gp = IMX_GPIO_NR(3, 21) - }, - .sda = { - .i2c_mode = MX6_PAD_EIM_D28__I2C1_SDA | PC, - .gpio_mode = MX6_PAD_EIM_D28__GPIO_3_28 | PC, - .gp = IMX_GPIO_NR(3, 28) - } -}; - -/* I2C2 Camera, MIPI */ -struct i2c_pads_info i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL | PC, - .gpio_mode = MX6_PAD_KEY_COL3__GPIO_4_12 | PC, - .gp = IMX_GPIO_NR(4, 12) - }, - .sda = { - .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC, - .gpio_mode = MX6_PAD_KEY_ROW3__GPIO_4_13 | PC, - .gp = IMX_GPIO_NR(4, 13) - } -}; - -/* I2C3, J15 - RGB connector */ -struct i2c_pads_info i2c_pad_info2 = { - .scl = { - .i2c_mode = MX6_PAD_GPIO_5__I2C3_SCL | PC, - .gpio_mode = MX6_PAD_GPIO_5__GPIO_1_5 | PC, - .gp = IMX_GPIO_NR(1, 5) - }, - .sda = { - .i2c_mode = MX6_PAD_GPIO_16__I2C3_SDA | PC, - .gpio_mode = MX6_PAD_GPIO_16__GPIO_7_11 | PC, - .gp = IMX_GPIO_NR(7, 11) - } -}; - -iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT5__GPIO_7_0 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ -}; - -iomux_v3_cfg_t const usdhc4_pads[] = { - MX6_PAD_SD4_CLK__USDHC4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_CMD__USDHC4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT0__USDHC4_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT1__USDHC4_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT2__USDHC4_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD4_DAT3__USDHC4_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_D6__GPIO_2_6 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ -}; - -iomux_v3_cfg_t const enet_pads1[] = { - MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), - /* pin 35 - 1 (PHY_AD2) on reset */ - MX6_PAD_RGMII_RXC__GPIO_6_30 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* pin 32 - 1 - (MODE0) all */ - MX6_PAD_RGMII_RD0__GPIO_6_25 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* pin 31 - 1 - (MODE1) all */ - MX6_PAD_RGMII_RD1__GPIO_6_27 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* pin 28 - 1 - (MODE2) all */ - MX6_PAD_RGMII_RD2__GPIO_6_28 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* pin 27 - 1 - (MODE3) all */ - MX6_PAD_RGMII_RD3__GPIO_6_29 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */ - MX6_PAD_RGMII_RX_CTL__GPIO_6_24 | MUX_PAD_CTRL(NO_PAD_CTRL), - /* pin 42 PHY nRST */ - MX6_PAD_EIM_D23__GPIO_3_23 | MUX_PAD_CTRL(NO_PAD_CTRL), -}; - -iomux_v3_cfg_t const enet_pads2[] = { - MX6_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), -}; - -/* Button assignments for J14 */ -static iomux_v3_cfg_t const button_pads[] = { - /* Menu */ - MX6_PAD_NANDF_D1__GPIO_2_1 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), - /* Back */ - MX6_PAD_NANDF_D2__GPIO_2_2 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), - /* Labelled Search (mapped to Power under Android) */ - MX6_PAD_NANDF_D3__GPIO_2_3 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), - /* Home */ - MX6_PAD_NANDF_D4__GPIO_2_4 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), - /* Volume Down */ - MX6_PAD_GPIO_19__GPIO_4_5 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), - /* Volume Up */ - MX6_PAD_GPIO_18__GPIO_7_13 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), -}; - -static void setup_iomux_enet(void) -{ - gpio_direction_output(IMX_GPIO_NR(3, 23), 0); - gpio_direction_output(IMX_GPIO_NR(6, 30), 1); - gpio_direction_output(IMX_GPIO_NR(6, 25), 1); - gpio_direction_output(IMX_GPIO_NR(6, 27), 1); - gpio_direction_output(IMX_GPIO_NR(6, 28), 1); - gpio_direction_output(IMX_GPIO_NR(6, 29), 1); - imx_iomux_v3_setup_multiple_pads(enet_pads1, ARRAY_SIZE(enet_pads1)); - gpio_direction_output(IMX_GPIO_NR(6, 24), 1); - - /* Need delay 10ms according to KSZ9021 spec */ - udelay(1000 * 10); - gpio_set_value(IMX_GPIO_NR(3, 23), 1); - - imx_iomux_v3_setup_multiple_pads(enet_pads2, ARRAY_SIZE(enet_pads2)); -} - -iomux_v3_cfg_t const usb_pads[] = { - MX6_PAD_GPIO_17__GPIO_7_12 | MUX_PAD_CTRL(NO_PAD_CTRL), -}; - -static void setup_iomux_uart(void) -{ - imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); - imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); -} - -#ifdef CONFIG_USB_EHCI_MX6 -int board_ehci_hcd_init(int port) -{ - imx_iomux_v3_setup_multiple_pads(usb_pads, ARRAY_SIZE(usb_pads)); - - /* Reset USB hub */ - gpio_direction_output(IMX_GPIO_NR(7, 12), 0); - mdelay(2); - gpio_set_value(IMX_GPIO_NR(7, 12), 1); - - return 0; -} -#endif - -#ifdef CONFIG_FSL_ESDHC -struct fsl_esdhc_cfg usdhc_cfg[2] = { - {USDHC3_BASE_ADDR}, - {USDHC4_BASE_ADDR}, -}; - -int board_mmc_getcd(struct mmc *mmc) -{ - struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; - int ret; - - if (cfg->esdhc_base == USDHC3_BASE_ADDR) { - gpio_direction_input(IMX_GPIO_NR(7, 0)); - ret = !gpio_get_value(IMX_GPIO_NR(7, 0)); - } else { - gpio_direction_input(IMX_GPIO_NR(2, 6)); - ret = !gpio_get_value(IMX_GPIO_NR(2, 6)); - } - - return ret; -} - -int board_mmc_init(bd_t *bis) -{ - s32 status = 0; - u32 index = 0; - - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); - - usdhc_cfg[0].max_bus_width = 4; - usdhc_cfg[1].max_bus_width = 4; - - for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { - switch (index) { - case 0: - imx_iomux_v3_setup_multiple_pads( - usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); - break; - case 1: - imx_iomux_v3_setup_multiple_pads( - usdhc4_pads, ARRAY_SIZE(usdhc4_pads)); - break; - default: - printf("Warning: you configured more USDHC controllers" - "(%d) then supported by the board (%d)\n", - index + 1, CONFIG_SYS_FSL_USDHC_NUM); - return status; - } - - status |= fsl_esdhc_initialize(bis, &usdhc_cfg[index]); - } - - return status; -} -#endif - -#ifdef CONFIG_MXC_SPI -iomux_v3_cfg_t const ecspi1_pads[] = { - /* SS1 */ - MX6_PAD_EIM_D19__GPIO_3_19 | MUX_PAD_CTRL(SPI_PAD_CTRL), - MX6_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), - MX6_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), - MX6_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), -}; - -void setup_spi(void) -{ - imx_iomux_v3_setup_multiple_pads(ecspi1_pads, - ARRAY_SIZE(ecspi1_pads)); -} -#endif - -int board_phy_config(struct phy_device *phydev) -{ - /* min rx data delay */ - ksz9021_phy_extended_write(phydev, - MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, 0x0); - /* min tx data delay */ - ksz9021_phy_extended_write(phydev, - MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, 0x0); - /* max rx/tx clock delay, min rx/tx control */ - ksz9021_phy_extended_write(phydev, - MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, 0xf0f0); - if (phydev->drv->config) - phydev->drv->config(phydev); - - return 0; -} - -int board_eth_init(bd_t *bis) -{ - uint32_t base = IMX_FEC_BASE; - struct mii_dev *bus = NULL; - struct phy_device *phydev = NULL; - int ret; - - setup_iomux_enet(); - -#ifdef CONFIG_FEC_MXC - bus = fec_get_miibus(base, -1); - if (!bus) - return 0; - /* scan phy 4,5,6,7 */ - phydev = phy_find_by_mask(bus, (0xf << 4), PHY_INTERFACE_MODE_RGMII); - if (!phydev) { - free(bus); - return 0; - } - printf("using phy at %d\n", phydev->addr); - ret = fec_probe(bis, -1, base, bus, phydev); - if (ret) { - printf("FEC MXC: %s:failed\n", __func__); - free(phydev); - free(bus); - } -#endif - return 0; -} - -static void setup_buttons(void) -{ - imx_iomux_v3_setup_multiple_pads(button_pads, - ARRAY_SIZE(button_pads)); -} - -#ifdef CONFIG_CMD_SATA - -int setup_sata(void) -{ - struct iomuxc_base_regs *const iomuxc_regs - = (struct iomuxc_base_regs *) IOMUXC_BASE_ADDR; - int ret = enable_sata_clock(); - if (ret) - return ret; - - clrsetbits_le32(&iomuxc_regs->gpr[13], - IOMUXC_GPR13_SATA_MASK, - IOMUXC_GPR13_SATA_PHY_8_RXEQ_3P0DB - |IOMUXC_GPR13_SATA_PHY_7_SATA2M - |IOMUXC_GPR13_SATA_SPEED_3G - |(3<<IOMUXC_GPR13_SATA_PHY_6_SHIFT) - |IOMUXC_GPR13_SATA_SATA_PHY_5_SS_DISABLED - |IOMUXC_GPR13_SATA_SATA_PHY_4_ATTEN_9_16 - |IOMUXC_GPR13_SATA_PHY_3_TXBOOST_0P00_DB - |IOMUXC_GPR13_SATA_PHY_2_TX_1P104V - |IOMUXC_GPR13_SATA_PHY_1_SLOW); - - return 0; -} -#endif - -#if defined(CONFIG_VIDEO_IPUV3) - -static iomux_v3_cfg_t const backlight_pads[] = { - /* Backlight on RGB connector: J15 */ - MX6_PAD_SD1_DAT3__GPIO_1_21 | MUX_PAD_CTRL(NO_PAD_CTRL), -#define RGB_BACKLIGHT_GP IMX_GPIO_NR(1, 21) - - /* Backlight on LVDS connector: J6 */ - MX6_PAD_SD1_CMD__GPIO_1_18 | MUX_PAD_CTRL(NO_PAD_CTRL), -#define LVDS_BACKLIGHT_GP IMX_GPIO_NR(1, 18) -}; - -static iomux_v3_cfg_t const rgb_pads[] = { - MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK, - MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15, - MX6_PAD_DI0_PIN2__IPU1_DI0_PIN2, - MX6_PAD_DI0_PIN3__IPU1_DI0_PIN3, - MX6_PAD_DI0_PIN4__GPIO_4_20, - MX6_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0, - MX6_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1, - MX6_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2, - MX6_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3, - MX6_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4, - MX6_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5, - MX6_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6, - MX6_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7, - MX6_PAD_DISP0_DAT8__IPU1_DISP0_DAT_8, - MX6_PAD_DISP0_DAT9__IPU1_DISP0_DAT_9, - MX6_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10, - MX6_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11, - MX6_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12, - MX6_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13, - MX6_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14, - MX6_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15, - MX6_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16, - MX6_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17, - MX6_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18, - MX6_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19, - MX6_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20, - MX6_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21, - MX6_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22, - MX6_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23, -}; - -struct display_info_t { - int bus; - int addr; - int pixfmt; - int (*detect)(struct display_info_t const *dev); - void (*enable)(struct display_info_t const *dev); - struct fb_videomode mode; -}; - - -static int detect_hdmi(struct display_info_t const *dev) -{ - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - return readb(&hdmi->phy_stat0) & HDMI_PHY_HPD; -} - -static void enable_hdmi(struct display_info_t const *dev) -{ - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - u8 reg; - printf("%s: setup HDMI monitor\n", __func__); - reg = readb(&hdmi->phy_conf0); - reg |= HDMI_PHY_CONF0_PDZ_MASK; - writeb(reg, &hdmi->phy_conf0); - - udelay(3000); - reg |= HDMI_PHY_CONF0_ENTMDS_MASK; - writeb(reg, &hdmi->phy_conf0); - udelay(3000); - reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; - writeb(reg, &hdmi->phy_conf0); - writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); -} - -static int detect_i2c(struct display_info_t const *dev) -{ - return ((0 == i2c_set_bus_num(dev->bus)) - && - (0 == i2c_probe(dev->addr))); -} - -static void enable_lvds(struct display_info_t const *dev) -{ - struct iomuxc *iomux = (struct iomuxc *) - IOMUXC_BASE_ADDR; - u32 reg = readl(&iomux->gpr[2]); - reg |= IOMUXC_GPR2_DATA_WIDTH_CH0_24BIT; - writel(reg, &iomux->gpr[2]); - gpio_direction_output(LVDS_BACKLIGHT_GP, 1); -} - -static void enable_rgb(struct display_info_t const *dev) -{ - imx_iomux_v3_setup_multiple_pads( - rgb_pads, - ARRAY_SIZE(rgb_pads)); - gpio_direction_output(RGB_BACKLIGHT_GP, 1); -} - -static struct display_info_t const displays[] = {{ - .bus = -1, - .addr = 0, - .pixfmt = IPU_PIX_FMT_RGB24, - .detect = detect_hdmi, - .enable = enable_hdmi, - .mode = { - .name = "HDMI", - .refresh = 60, - .xres = 1024, - .yres = 768, - .pixclock = 15385, - .left_margin = 220, - .right_margin = 40, - .upper_margin = 21, - .lower_margin = 7, - .hsync_len = 60, - .vsync_len = 10, - .sync = FB_SYNC_EXT, - .vmode = FB_VMODE_NONINTERLACED -} }, { - .bus = 2, - .addr = 0x4, - .pixfmt = IPU_PIX_FMT_LVDS666, - .detect = detect_i2c, - .enable = enable_lvds, - .mode = { - .name = "Hannstar-XGA", - .refresh = 60, - .xres = 1024, - .yres = 768, - .pixclock = 15385, - .left_margin = 220, - .right_margin = 40, - .upper_margin = 21, - .lower_margin = 7, - .hsync_len = 60, - .vsync_len = 10, - .sync = FB_SYNC_EXT, - .vmode = FB_VMODE_NONINTERLACED -} }, { - .bus = 2, - .addr = 0x38, - .pixfmt = IPU_PIX_FMT_LVDS666, - .detect = detect_i2c, - .enable = enable_lvds, - .mode = { - .name = "wsvga-lvds", - .refresh = 60, - .xres = 1024, - .yres = 600, - .pixclock = 15385, - .left_margin = 220, - .right_margin = 40, - .upper_margin = 21, - .lower_margin = 7, - .hsync_len = 60, - .vsync_len = 10, - .sync = FB_SYNC_EXT, - .vmode = FB_VMODE_NONINTERLACED -} }, { - .bus = 2, - .addr = 0x48, - .pixfmt = IPU_PIX_FMT_RGB666, - .detect = detect_i2c, - .enable = enable_rgb, - .mode = { - .name = "wvga-rgb", - .refresh = 57, - .xres = 800, - .yres = 480, - .pixclock = 37037, - .left_margin = 40, - .right_margin = 60, - .upper_margin = 10, - .lower_margin = 10, - .hsync_len = 20, - .vsync_len = 10, - .sync = 0, - .vmode = FB_VMODE_NONINTERLACED -} } }; - -int board_video_skip(void) -{ - int i; - int ret; - char const *panel = getenv("panel"); - if (!panel) { - for (i = 0; i < ARRAY_SIZE(displays); i++) { - struct display_info_t const *dev = displays+i; - if (dev->detect(dev)) { - panel = dev->mode.name; - printf("auto-detected panel %s\n", panel); - break; - } - } - if (!panel) { - panel = displays[0].mode.name; - printf("No panel detected: default to %s\n", panel); - } - } else { - for (i = 0; i < ARRAY_SIZE(displays); i++) { - if (!strcmp(panel, displays[i].mode.name)) - break; - } - } - if (i < ARRAY_SIZE(displays)) { - ret = ipuv3_fb_init(&displays[i].mode, 0, - displays[i].pixfmt); - if (!ret) { - displays[i].enable(displays+i); - printf("Display: %s (%ux%u)\n", - displays[i].mode.name, - displays[i].mode.xres, - displays[i].mode.yres); - } else - printf("LCD %s cannot be configured: %d\n", - displays[i].mode.name, ret); - } else { - printf("unsupported panel %s\n", panel); - ret = -EINVAL; - } - return (0 != ret); -} - -static void setup_display(void) -{ - struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; - struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; - - int reg; - - /* Turn on LDB0,IPU,IPU DI0 clocks */ - reg = __raw_readl(&mxc_ccm->CCGR3); - reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET - |MXC_CCM_CCGR3_LDB_DI0_MASK; - writel(reg, &mxc_ccm->CCGR3); - - /* Turn on HDMI PHY clock */ - reg = __raw_readl(&mxc_ccm->CCGR2); - reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK - |MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; - writel(reg, &mxc_ccm->CCGR2); - - /* clear HDMI PHY reset */ - writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); - - /* set PFD1_FRAC to 0x13 == 455 MHz (480*18)/0x13 */ - writel(ANATOP_PFD_480_PFD1_FRAC_MASK, &anatop->pfd_480_clr); - writel(0x13<<ANATOP_PFD_480_PFD1_FRAC_SHIFT, &anatop->pfd_480_set); - - /* set LDB0, LDB1 clk select to 011/011 */ - reg = readl(&mxc_ccm->cs2cdr); - reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK - |MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK); - reg |= (3<<MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET) - |(3<<MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET); - writel(reg, &mxc_ccm->cs2cdr); - - reg = readl(&mxc_ccm->cscmr2); - reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV; - writel(reg, &mxc_ccm->cscmr2); - - reg = readl(&mxc_ccm->chsccdr); - reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK - |MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK - |MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); - reg |= (CHSCCDR_CLK_SEL_LDB_DI0 - <<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) - |(CHSCCDR_PODF_DIVIDE_BY_3 - <<MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) - |(CHSCCDR_IPU_PRE_CLK_540M_PFD - <<MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); - writel(reg, &mxc_ccm->chsccdr); - - reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES - |IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH - |IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW - |IOMUXC_GPR2_BIT_MAPPING_CH1_SPWG - |IOMUXC_GPR2_DATA_WIDTH_CH1_18BIT - |IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG - |IOMUXC_GPR2_DATA_WIDTH_CH0_18BIT - |IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED - |IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0; - writel(reg, &iomux->gpr[2]); - - reg = readl(&iomux->gpr[3]); - reg = (reg & ~IOMUXC_GPR3_LVDS0_MUX_CTL_MASK) - | (IOMUXC_GPR3_MUX_SRC_IPU1_DI0 - <<IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET); - writel(reg, &iomux->gpr[3]); - - /* backlights off until needed */ - imx_iomux_v3_setup_multiple_pads(backlight_pads, - ARRAY_SIZE(backlight_pads)); - gpio_direction_input(LVDS_BACKLIGHT_GP); - gpio_direction_input(RGB_BACKLIGHT_GP); -} -#endif - -int board_early_init_f(void) -{ - setup_iomux_uart(); - setup_buttons(); - -#if defined(CONFIG_VIDEO_IPUV3) - setup_display(); -#endif - return 0; -} - -/* - * Do not overwrite the console - * Use always serial for U-Boot console - */ -int overwrite_console(void) -{ - return 1; -} - -int board_init(void) -{ - /* address of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; - -#ifdef CONFIG_MXC_SPI - setup_spi(); -#endif - setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0); - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); - setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); - -#ifdef CONFIG_CMD_SATA - setup_sata(); -#endif - - return 0; -} - -int checkboard(void) -{ - puts("Board: MX6Q-Sabre Lite\n"); - - return 0; -} - -struct button_key { - char const *name; - unsigned gpnum; - char ident; -}; - -static struct button_key const buttons[] = { - {"back", IMX_GPIO_NR(2, 2), 'B'}, - {"home", IMX_GPIO_NR(2, 4), 'H'}, - {"menu", IMX_GPIO_NR(2, 1), 'M'}, - {"search", IMX_GPIO_NR(2, 3), 'S'}, - {"volup", IMX_GPIO_NR(7, 13), 'V'}, - {"voldown", IMX_GPIO_NR(4, 5), 'v'}, -}; - -/* - * generate a null-terminated string containing the buttons pressed - * returns number of keys pressed - */ -static int read_keys(char *buf) -{ - int i, numpressed = 0; - for (i = 0; i < ARRAY_SIZE(buttons); i++) { - if (!gpio_get_value(buttons[i].gpnum)) - buf[numpressed++] = buttons[i].ident; - } - buf[numpressed] = '\0'; - return numpressed; -} - -static int do_kbd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - char envvalue[ARRAY_SIZE(buttons)+1]; - int numpressed = read_keys(envvalue); - setenv("keybd", envvalue); - return numpressed == 0; -} - -U_BOOT_CMD( - kbd, 1, 1, do_kbd, - "Tests for keypresses, sets 'keybd' environment variable", - "Returns 0 (true) to shell if key is pressed." -); - -#ifdef CONFIG_PREBOOT -static char const kbd_magic_prefix[] = "key_magic"; -static char const kbd_command_prefix[] = "key_cmd"; - -static void preboot_keys(void) -{ - int numpressed; - char keypress[ARRAY_SIZE(buttons)+1]; - numpressed = read_keys(keypress); - if (numpressed) { - char *kbd_magic_keys = getenv("magic_keys"); - char *suffix; - /* - * loop over all magic keys - */ - for (suffix = kbd_magic_keys; *suffix; ++suffix) { - char *keys; - char magic[sizeof(kbd_magic_prefix) + 1]; - sprintf(magic, "%s%c", kbd_magic_prefix, *suffix); - keys = getenv(magic); - if (keys) { - if (!strcmp(keys, keypress)) - break; - } - } - if (*suffix) { - char cmd_name[sizeof(kbd_command_prefix) + 1]; - char *cmd; - sprintf(cmd_name, "%s%c", kbd_command_prefix, *suffix); - cmd = getenv(cmd_name); - if (cmd) { - setenv("preboot", cmd); - return; - } - } - } -} -#endif - -#ifdef CONFIG_CMD_BMODE -static const struct boot_mode board_boot_modes[] = { - /* 4 bit bus width */ - {"mmc0", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)}, - {"mmc1", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)}, - {NULL, 0}, -}; -#endif - -int misc_init_r(void) -{ -#ifdef CONFIG_PREBOOT - preboot_keys(); -#endif - -#ifdef CONFIG_CMD_BMODE - add_board_boot_modes(board_boot_modes); -#endif - return 0; -} diff --git a/boards.cfg b/boards.cfg index 6a368de..f919c53 100644 --- a/boards.cfg +++ b/boards.cfg @@ -268,7 +268,7 @@ vision2 arm armv7 vision2 ttcontr cgtqmx6qeval arm armv7 cgtqmx6eval congatec mx6 cgtqmx6eval:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q mx6qarm2 arm armv7 mx6qarm2 freescale mx6 mx6qarm2:IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q -mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg +mx6qsabrelite arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE mx6dlsabresd arm armv7 mx6sabresd freescale mx6 mx6sabresd:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL mx6qsabresd arm armv7 mx6sabresd freescale mx6 mx6sabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q mx6slevk arm armv7 mx6slevk freescale mx6 mx6slevk:IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h deleted file mode 100644 index c7db81d..0000000 --- a/include/configs/mx6qsabrelite.h +++ /dev/null @@ -1,297 +0,0 @@ -/* - * Copyright (C) 2010-2011 Freescale Semiconductor, Inc. - * - * Configuration settings for the Freescale i.MX6Q Sabre Lite board. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CONFIG_MX6 -#define CONFIG_MX6Q - -#include "mx6_common.h" - -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO - -#define CONFIG_MACH_TYPE 3769 - -#include <asm/arch/imx-regs.h> -#include <asm/imx-common/gpio.h> - -#define CONFIG_CMDLINE_TAG -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG -#define CONFIG_REVISION_TAG - -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024) - -#define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_MISC_INIT_R -#define CONFIG_MXC_GPIO - -#define CONFIG_CMD_FUSE -#ifdef CONFIG_CMD_FUSE -#define CONFIG_MXC_OCOTP -#endif - -#define CONFIG_MXC_UART -#define CONFIG_MXC_UART_BASE UART2_BASE - -#define CONFIG_CMD_SF -#ifdef CONFIG_CMD_SF -#define CONFIG_SPI_FLASH -#define CONFIG_SPI_FLASH_SST -#define CONFIG_MXC_SPI -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS (0|(IMX_GPIO_NR(3, 19)<<8)) -#define CONFIG_SF_DEFAULT_SPEED 25000000 -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) -#endif - -/* I2C Configs */ -#define CONFIG_CMD_I2C -#define CONFIG_I2C_MULTI_BUS -#define CONFIG_I2C_MXC -#define CONFIG_SYS_I2C_SPEED 100000 - -/* MMC Configs */ -#define CONFIG_FSL_ESDHC -#define CONFIG_FSL_USDHC -#define CONFIG_SYS_FSL_ESDHC_ADDR 0 -#define CONFIG_SYS_FSL_USDHC_NUM 2 - -#define CONFIG_MMC -#define CONFIG_CMD_MMC -#define CONFIG_GENERIC_MMC -#define CONFIG_BOUNCE_BUFFER -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION - -#define CONFIG_CMD_SATA -/* - * SATA Configs - */ -#ifdef CONFIG_CMD_SATA -#define CONFIG_DWC_AHSATA -#define CONFIG_SYS_SATA_MAX_DEVICE 1 -#define CONFIG_DWC_AHSATA_PORT_ID 0 -#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR -#define CONFIG_LBA48 -#define CONFIG_LIBATA -#endif - -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_MII -#define CONFIG_CMD_NET -#define CONFIG_FEC_MXC -#define CONFIG_MII -#define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_XCV_TYPE RGMII -#define CONFIG_ETHPRIME "FEC" -#define CONFIG_FEC_MXC_PHYADDR 6 -#define CONFIG_PHYLIB -#define CONFIG_PHY_MICREL -#define CONFIG_PHY_MICREL_KSZ9021 - -/* USB Configs */ -#define CONFIG_CMD_USB -#define CONFIG_CMD_FAT -#define CONFIG_USB_EHCI -#define CONFIG_USB_EHCI_MX6 -#define CONFIG_USB_STORAGE -#define CONFIG_USB_HOST_ETHER -#define CONFIG_USB_ETHER_ASIX -#define CONFIG_USB_ETHER_SMSC95XX -#define CONFIG_MXC_USB_PORT 1 -#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CONFIG_MXC_USB_FLAGS 0 - -/* Miscellaneous commands */ -#define CONFIG_CMD_BMODE - -/* Framebuffer and LCD */ -#define CONFIG_VIDEO -#define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE -#define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#define CONFIG_VIDEO_BMP_RLE8 -#define CONFIG_SPLASH_SCREEN -#define CONFIG_BMP_16BPP -#define CONFIG_VIDEO_LOGO -#define CONFIG_IPUV3_CLK 260000000 - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_CONS_INDEX 1 -#define CONFIG_BAUDRATE 115200 - -/* Command definition */ -#include <config_cmd_default.h> - -#undef CONFIG_CMD_IMLS - -#define CONFIG_BOOTDELAY 1 - -#define CONFIG_PREBOOT "" - -#define CONFIG_LOADADDR 0x12000000 -#define CONFIG_SYS_TEXT_BASE 0x17800000 - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "script=boot.scr\0" \ - "uimage=uImage\0" \ - "console=ttymxc1\0" \ - "fdt_high=0xffffffff\0" \ - "initrd_high=0xffffffff\0" \ - "fdt_file=imx6q-sabrelite.dtb\0" \ - "fdt_addr=0x11000000\0" \ - "boot_fdt=try\0" \ - "ip_dyn=yes\0" \ - "mmcdev=0\0" \ - "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ - "mmcargs=setenv bootargs console=${console},${baudrate} " \ - "root=${mmcroot}\0" \ - "loadbootscript=" \ - "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ - "bootscript=echo Running bootscript from mmc ...; " \ - "source\0" \ - "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ - "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ - "if run loadfdt; then " \ - "bootm ${loadaddr} - ${fdt_addr}; " \ - "else " \ - "if test ${boot_fdt} = try; then " \ - "bootm; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi; " \ - "fi; " \ - "else " \ - "bootm; " \ - "fi;\0" \ - "netargs=setenv bootargs console=${console},${baudrate} " \ - "root=/dev/nfs " \ - "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ - "netboot=echo Booting from net ...; " \ - "run netargs; " \ - "if test ${ip_dyn} = yes; then " \ - "setenv get_cmd dhcp; " \ - "else " \ - "setenv get_cmd tftp; " \ - "fi; " \ - "${get_cmd} ${uimage}; " \ - "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ - "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ - "bootm ${loadaddr} - ${fdt_addr}; " \ - "else " \ - "if test ${boot_fdt} = try; then " \ - "bootm; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi; " \ - "fi; " \ - "else " \ - "bootm; " \ - "fi;\0" - -#define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loaduimage; then " \ - "run mmcboot; " \ - "else run netboot; " \ - "fi; " \ - "fi; " \ - "else run netboot; fi" - -/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "MX6QSABRELITE U-Boot > " -#define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_CBSIZE 256 - -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -#define CONFIG_SYS_MEMTEST_START 0x10000000 -#define CONFIG_SYS_MEMTEST_END 0x10010000 -#define CONFIG_SYS_MEMTEST_SCRATCH 0x10800000 - -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR -#define CONFIG_SYS_HZ 1000 - -#define CONFIG_CMDLINE_EDITING - -/* Physical Memory Map */ -#define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR -#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024) - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM -#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR -#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE - -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - -/* FLASH and environment organization */ -#define CONFIG_SYS_NO_FLASH - -#define CONFIG_ENV_SIZE (8 * 1024) - -#define CONFIG_ENV_IS_IN_MMC -/* #define CONFIG_ENV_IS_IN_SPI_FLASH */ - -#if defined(CONFIG_ENV_IS_IN_MMC) -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) -#define CONFIG_SYS_MMC_ENV_DEV 0 -#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) -#define CONFIG_ENV_OFFSET (768 * 1024) -#define CONFIG_ENV_SECT_SIZE (8 * 1024) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED -#endif - -#define CONFIG_OF_LIBFDT -#define CONFIG_CMD_BOOTZ - -#ifndef CONFIG_SYS_DCACHE_OFF -#define CONFIG_CMD_CACHE -#endif - -#endif /* __CONFIG_H */ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 74df66c..85eecfc 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -186,6 +186,80 @@
#define CONFIG_DRIVE_TYPES CONFIG_DRIVE_SATA CONFIG_DRIVE_MMC
+#if defined(CONFIG_SABRELITE) +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ + "console=ttymxc1\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx6q-sabrelite.dtb\0" \ + "fdt_addr=0x11000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev=0\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" +#else #define CONFIG_EXTRA_ENV_SETTINGS \ "console=ttymxc1\0" \ "clearenv=if sf probe || sf probe || sf probe 1 ; then " \ @@ -219,6 +293,7 @@ "done ; " \ "done\0" \
+#endif /* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP #define CONFIG_SYS_HUSH_PARSER @@ -258,8 +333,11 @@
-/* #define CONFIG_ENV_IS_IN_MMC */ +#if defined(CONFIG_SABRELITE) +#define CONFIG_ENV_IS_IN_MMC +#else #define CONFIG_ENV_IS_IN_SPI_FLASH +#endif
#if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_ENV_OFFSET (6 * 64 * 1024)
Hi Fabio,
Thanks, no corruption at all - and as the new version differs only for the mail format, there is no need to wait for inclusion.
Best regards, Stefano Babic
Thanks Stefano,
On 07/26/2013 07:46 AM, Stefano Babic wrote:
Hi Fabio,
Do we now need updated patches from Pardeep and Robert, who have patches pending that include changes to board/freescale/mx6qsabrelite/?
Please advise,
Eric
Hi Eric,
On 26/07/2013 18:12, Eric Nelson wrote:
Thanks Stefano,
Hi Fabio,
No need - I fixed it myself and applied.
Regards, Stefano
Eric Nelson
Fabio Estevam
Stefano Babic
